  4. Node-Red
  5. variabler Variablenzugriff For-Schleife
    6.4k
15 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • mickymM mickym
    @_r_a_l_f_ Warum macht ihr es Euch immer so schwer mit der Codiererei in JS und function Nodes?
            "id": "e57655daa0bd9ef0",
            "type": "inject",
            "z": "7e6af0015415146d",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "msg0",
            "payload": "1",
            "payloadType": "num",
            "x": 1970,
            "y": 3980,
            "wires": [
                    "98f85018e2a38123"
            "id": "dc34177ec62cce41",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "msg1",
            "payload": "2",
            "x": 1970,
            "y": 4020,
            "wires": [
                    "98f85018e2a38123"
            "id": "254923a83d409954",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "msg2",
            "payload": "3",
            "x": 1970,
            "y": 4060,
            "wires": [
                    "98f85018e2a38123"
            "id": "30ee2f88095e17e3",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "msg3",
            "payload": "0",
            "x": 1970,
            "y": 4100,
            "wires": [
                    "98f85018e2a38123"
            "id": "98f85018e2a38123",
            "type": "join",
            "name": "",
            "mode": "custom",
            "build": "object",
            "property": "payload",
            "propertyType": "msg",
            "key": "topic",
            "joiner": "\\n",
            "joinerType": "str",
            "accumulate": true,
            "timeout": "",
            "count": "1",
            "reduceRight": false,
            "reduceExp": "",
            "reduceInit": "",
            "reduceInitType": "",
            "reduceFixup": "",
            "x": 2150,
            "y": 4040,
            "wires": [
                    "e45441109d3778e4",
                    "579e44244bb475b4"
            "id": "e45441109d3778e4",
            "type": "debug",
            "name": "Objekt",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 2330,
            "y": 3980,
            "wires": []
            "id": "579e44244bb475b4",
            "type": "change",
            "name": "Durchschnitt",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "$map(payload.*,function($val){$val != 0 ? $val})~>$average()",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 2330,
            "y": 4040,
            "wires": [
                    "ab038a94221abb0b"
            "id": "ab038a94221abb0b",
            "type": "debug",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 2530,
            "y": 4040,
            "wires": []
    Ansonsten hat @OliverIO ja den Code entsprechend geliefert, damit Dir das nicht zu Teiler hinzugezählt wird. im Übrigen hast Du ein gewaltigen Bug in Deinem Code - das ist kein Array, das Du definierst, aber @OliverIO hat es ja schon bereinigt.
    Wenn nur eine 0 im Objekt steht - dann ist halt undefined:
    Das Ganze in JSONATA ist relativ simpel:
    Wenn Du alles in einem Objekt hast via JOIN Node - dann fällt Dir auch das Programmieren in Javascript leichter, wenn Du so ein JS-Fan bist.
    Du bekommst dann ja als payload ein Objekt, dass Du durchiterieren kannst.
    hier mal die function Node . die das gleiche macht, halt mit mehr Code. ;)
    var arr = [];
    for (var key in msg.payload) {
        if (msg.payload[key]) arr.push(msg.payload[key]);
    if (arr.length > 0){
        var sum = 0;
        arr.forEach(val => sum += val);
        msg.payload = sum/arr.length;
        return msg;
    _ Offline
    _ Offline
    _R_A_L_F_
    @mickym Danke für die Antwort :) .
    Wie kommt man auf das JSONATA Ergebnis? Gibt es hier ein Nachschlagewerk? Bisher bin ich dazu leider nicht wirklich fündig geworden :(.
    Ich versuche ja eh generell auf JS in Functions zu verzichten aber oftmals fehlt mir das Know How es anders zu lösen. Daher frage ich ja und bin froh um jede Hilfe ;)
    • _ _R_A_L_F_
      mickymM Offline
      mickymM Offline
      mickym
      @_r_a_l_f_ sagte in variabler Variablenzugriff For-Schleife:
      War ja auch nicht als Vorwurf gemeint, sondern war zugegebenermaßen provokativ. Ich hab ja selbst ewig gebraucht, bis ich dahinter stieg und probiere oft immer noch viel. Also so aus dem Ärmel schüttle ich das auch nicht. Die Doku dürrste du aber kennen und auch das Probierfenster (https://docs.jsonata.org/overview.html).
      Mich selbst beeindruckt immer wieder mit wie wenig Code man zu einem Ergebnis kommt und wenn du Lust hast, dann gehen wir den Code Stück für Stück durch.
      _ 1 Antwort Letzte Antwort
      • mickymM Offline
        mickymM Offline
        mickym
        Das Ganze geht übrigens noch kürzer. War jetzt mein persönlicher Ehrgeiz. ;)
        $average(payload.*[$!=0])
        Kannst du hier ausprobieren und testen: https://try.jsonata.org/czsL_Yhdr
        und jetzt vergleiche mal diesen Ausdruck mit dem JavaScript Code. Ist das nicht genial?
        Bin selbst immer wieder begeistert. In dem JSONATA Fenster siehst du auch sofort das Ergebnis und kannst gleich mit verschiedenen Inputs testen.
        • mickymM mickym
          _ Offline
          _ Offline
          _R_A_L_F_
          @mickym Alles gut, ich lerne immer gerne dazu und bin nicht unbedingt ein Fan von fertige Lösungen, da ich ja so nie selbständig werde ;) Und JSONata ist wirklich mächtig!
          Danke schon mal für die Doku. Da lese ich mich auf jeden Fall ein. Zusätzlich habe ich mich über den Link https://konfuzio.com/de/jsonata/ etwas mehr in das ganze reingelesen was das Grundverständnis anging.
          Ich sag mal so, dieses Beispiel verstehe ich noch recht gut (hoffentlich :D)
          Average als JS Funktion
          Gefiltert wird der Payload als Regular Expression der ausschließt die Payloads ungleich 0
          Korrigiere mich gerne, wenn ich falsch liege ;)
          Aber hier oben tue ich mich aktuell noch schwer:
          Map => befülle ein Array mit den Werten aus dem Payload welche dem Regular Expression lt. function entsprechen $val != 0 und führe anschließend über das Array hinweg die $average JS Funktion aus oder? Dazu hätte ich folgende Frage. Ist $val ein x beliebiger Variablenname oder hat das einen Hintergrund?
          Sorry wenn ich vielleicht etwas blöd Frage aber nur so denke ich immer, lerne ich wenigstens dazu ;)
          • mickymM Offline
            mickymM Offline
            mickym
            Nein im Prinzip ist das sogar eine Abkürzung der unteren Funktion und mit Javascript hat das gar nichts zu tun. Javascript hat mit JSONATA 0,0 zu tun.
            Die $average Funktion ist eine aggregierende Funktion, die den Durchschnitt aus einem Array bildet.
            https://docs.jsonata.org/aggregation-functions
            Das Array wird aus dem payload Objekt gebildet und zwar aus allen Objekten unabhängig vom Eigenschaftsnamen auf der 1. Ebene also
            payload.*
            https://docs.jsonata.org/path-operators
            Grundsätzlich arbeitet JSONATA so, dass das Ergebnis entweder ein Einzelwert ist oder wenn das Ergebnis mehrfach ist, dann wird ein Array gebildet.
            Ich habe Dir ja den Link geschickt in JSONATA try geschickt:
            Wie Du siehtst, wird aus dem payload Objekt mit unterschiedlichen Eigenschaften ein Array.
            Das nächste ist die FilterFunktion:
            Sprich aus dem Array payload.* filtern wir alle Objekte aus, die ungleich 0 sind.
            und aus diesem Array bilden wir dann den Durchschnitt
            Die Funktion habe ich ja oben beschrieben. Die map funktion ist viel umständlicher - man kann sie nutzen, wenn der Filter zum komplex wird.
            https://docs.jsonata.org/higher-order-functions
            Hier kannst Du dann selbst Funktionen definieren, wobei Du auf den Wert jedes Arraymitglieds, den Index oder das gesamte Array zugreifen kannst.
            JSONATA hat mit JavaScript NICHTS zu tun und es wurde auch KEIN regulärer Ausdruck benutzt sondern der Wildcard Path Parameter im JSONATA.
            • _ _R_A_L_F_
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @_r_a_l_f_
              ja $val ist beliebig.
              der Grundbefehl ist
              $map(filter,callbackFunction)
              der Befehl $map ruft für jedes element, welches über das filterkriterium ermittelt werden konnte die callback funktion auf. die notation nennt sich anonyme funktion
              https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Functions?retiredLocale=de
              Beispiel
              // Expression; the function is anonymous but assigned to a variable
              const multiply = function (x, y) {
                return x * y;
              Die Bezeichnung der parameter kannst du selber wählen. die anzahl der parameter muss mit der dokumentation des aufrufenden Befehls übereinstimmen.
              die siehst du hier 1 pflicht-parameter + 2 optionale (mit den spitzen klammern sind sie optional)
              https://docs.jsonata.org/higher-order-functions#map
              Meine Adapter und Widgets
              Links im Profil
              mickymM _ 2 Antworten Letzte Antwort
              • OliverIOO OliverIO
                @_r_a_l_f_
                der Grundbefehl ist
                Beispiel
                  return x * y;
                mickymM Offline
                mickymM Offline
                mickym
                @oliverio Du schmeist in meinen Augen JSONATA mit JavaScript durcheinander, Es gibt auch ein Map Funktion in Javascript, aber in JSONATA gibt es keine Callback Funktionen. Es ist eine Interpretersprache, die immer sequentiell von der Bibliothek abgearbeitet wird. Der Map Befehl in JSONATA iteriert einfach durch das Array, das als Parameter mitgegeben wird.
                • mickymM mickym
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @mickym
                  jsonata ist ebenfalls in javascript geschrieben.
                  der parser setzt nur die argumente in entsprechende javascript aufrufe um.
                  hier der aufruf der callback funktion für den map-befehl
                  https://github.com/jsonata-js/jsonata/blob/1df9fc96d9e476645070184187d6b46e4cd02eb6/src/functions.js#L1485
                  in der doku von jsonata steht das ja ebenfalls so
                  @_R_A_L_F_ diesen post nicht beachten. das bringt dich nur durcheinander und ist nerdiges blamen :)
                  Links im Profil
                    @mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @oliverio sagte in variabler Variablenzugriff For-Schleife:
                    Na gut ich höre schon auf. - Im Gegensatz zum mir, bist du ja ein Entwickler.
                    • mickymM mickym
                      payload.*
                      _ Offline
                      _ Offline
                      _R_A_L_F_
                      @mickym Ok, soweit verstanden und Danke für die Erklärung. Ich muss mich jetzt einfach mal durch die Doku wühlen ;). Trotzdem vielen vielen Dank für die so ausführliche Erklärung ;)
                        @_r_a_l_f_
                        der Grundbefehl ist
                        Beispiel
                          return x * y;
                        _ Offline
                        _ Offline
                        _R_A_L_F_
                        @oliverio Japp, soweit habe ich es verstanden. Auch dir vielen lieben Dank für die ausführliche Erklärung :)
