  4. Nicht vorhandener Datenpunkt im Log
    5.1k
7 Beiträge 3 Kommentatoren 704 Aufrufe 3 Beobachtet
  • R Offline
    Radi
    Ich betreibe meinen IOBroker in einer VM unter Proxmox. Das System dürfte halbwegs aktuell sein.
                            v.2023-10-10
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-26-amd64
          Architecture: x86-64
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               amd64
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/node           v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            /usr/bin/corepack       0.19.0
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem:            9.9G        7.1G        1.5G        0.0K        1.4G        2.6G
    Swap:           974M        5.0M        969M
    Total:           10G        7.1G        2.4G
    Active iob-Instances:   68
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.10.1
    Objects type: jsonl
    States  type: redis
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    + system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
    Objects:                75800
    States:                 57074
    Size of iob-Database:
    58M     /opt/iobroker/iobroker-data/objects.jsonl
    8.7M    /opt/iobroker/iobroker-data/states.jsonl
    Nun taucht in meinem Log regelmäßig alle 3 Minuten folgende Fehlermeldung auf:
    web.1
    	2023-10-24 08:57:04.991	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:57:04.958	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:57:04.780	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    web.1
    	2023-10-24 08:57:04.676	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:54:04.981	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:54:04.957	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:54:04.956	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:54:04.775	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:54:04.620	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:51:05.287	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:51:05.204	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    web.1
    	2023-10-24 08:51:05.159	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    web.1
    	2023-10-24 08:51:04.872	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
    Den zugehörigen Datenpunkt gibt es bei mir aber gar nicht.
    Selbst bei ausgeschalteter Milight- Instanz kommt die Fehlermeldung alle 3 Minuten.
    Wie bekomme ich diese wieder weg?
    Wo kann ich noch suchen? Werden noch Infos benötigt?
    • R Radi
                              v.2023-10-10
                 Chassis: vm
          Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
      MEMORY:
                              admin                   6.10.1
      Objects type: jsonl
      States  type: redis
      Objects:                75800
      States:                 57074
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      web.1
      sigi234S Online
      sigi234S Online
      @radi
      Objekte löschen und neu einlesen lassen
      R 1 Antwort Letzte Antwort
      • sigi234S sigi234
        @radi
        Radi
        @sigi234 Gesagt, getan. Die Objekte des Milight-Adapters gelöscht, die Instanz wieder gestartet.
        Der Fehler ist immer noch da.
        web.1
        	2023-10-24 09:21:04.176	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:21:04.092	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:21:04.029	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:21:03.964	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:21:03.831	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:18:04.532	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:18:04.462	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:18:04.445	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:18:04.212	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:18:04.154	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:15:05.373	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:15:05.178	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        	2023-10-24 09:15:05.177	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        web.1
        web.1
        	2023-10-24 09:15:04.899	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
        Was mich wundert ist, das die web.1-Instanz meckert. Ich habe noch eine zweite web-Instanz laufen. Die sagt nichts.
        W 1 Antwort Letzte Antwort
        • R Radi
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          web.1
          W Online
          W Online
          Wildbill
          @radi Hast Du eventuell irgendeine Visualisierung, bei der dieser fehlende Punkt irgendwie enthalten ist? Oder ein Script, welches auf diesen Punkt triggert?
          Ich meine, ich hatte sowas mal, als ich ein Gerät getauscht hatte, in einer VIS-View aber noch irgendwo der Datenpunkt enthalten war.
          Gruss, Jürgen
          • W Wildbill
            Gruss, Jürgen
            Radi
            schrieb am zuletzt editiert von Radi
            @wildbill Danke für den Hinweis. Ich schaue mal durch meine Vis und meine Scripte. Was mich irritiert ist, das ich Bad nie einen Milight-Strip oder -Leuchte verbaut hatte.
            Gruss Ralf
            • R Radi
              Gruss Ralf
              W Online
              W Online
              Wildbill
              schrieb am zuletzt editiert von Wildbill
              @radi Gibt es bei Dir einen
              milight-smart-light.0.bad.xxx
              ? Also irgendein Gerät, was so heisst und wo nur dieser Datenpunkt fehlt?
              Gruss, Jürgen
              EDIT: Unter Scripts kannst Du ja mal direkt nach
              suchen, oben links als Filter setzen. Dann siehst Du gleich, ob da irgendein Script darauf triggert. Wenn nicht, bleibt nur die VIS.
              • W Wildbill
                Gruss, Jürgen
                Radi
                @wildbill sagte in Nicht vorhandener Datenpunkt im Log:
                Jürgen, du bist mein Held. Ich hatte mal in meiner Vis mit einem farbtastic Widget herumgespielt und da stand doch wirklich dieser Datenpunkt drin. Hab den erstmal gelöscht und warte ab was passiert.
                Die 3 Minuten sind rum und keine Fehlermeldung mehr.
                Danke sagt Ralf
