  5. Text in Base64 codieren und Datei von Netzlaufwerk suchen
58 Beiträge 5 Kommentatoren 7.1k Aufrufe 4 Beobachtet
  • F fastfoot
    @chris76e mach mal das Leerzeichen vor password weg
    Chris76eC Offline
    Chris76eC Offline
    Chris76e
    @fastfoot
    mount error(22): Invalid argument
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    habe schon mit smbpasswd das passwort geändert, box neugestartet......
    F 1 Antwort Letzte Antwort
    • Chris76eC Offline
      Chris76eC Offline
      Chris76e
      so sieht die smb.conf auf der Box aus
      #config version:3.6.25-vti001
      [global]
         guest account = root
         security = user
         map to guest = bad user
         server string = VTi/Vu+ network shares at %h
         workgroup = VuPlus
         socket options = TCP_NODELAY
         smb passwd file = /etc/samba/private/smbpasswd
         encrypt passwords = yes
         passdb backend = smbpasswd
         idmap backend = smbpasswd
         obey pam restrictions = no
         unix extensions = no
         wide links = yes
         unix charset = utf-8
         max stat cache size = 64
         null passwords = yes
      [rootfs]
        comment = Do not touch !
        path = /
        read only = no
        public = yes
        guest ok = yes
        valid users = root
        force create mode = 600
        force directory mode = 700
        force security mode = 600
        force directory security mode = 700
      [Harddisk]
        comment = The harddisk
        path = /media/hdd
        read only = no
        public = yes
        guest ok = yes
        valid users = root
      [VMC]
      comment = VMC
      path = /media/VMC
      read only = no
      public = yes
      guest ok = yes
      • Chris76eC Chris76e
        [global]
           security = user
           workgroup = VuPlus
           wide links = yes
        [rootfs]
          path = /
          read only = no
          public = yes
          guest ok = yes
          valid users = root
        [Harddisk]
          path = /media/hdd
          read only = no
          public = yes
          guest ok = yes
          valid users = root
        [VMC]
        comment = VMC
        path = /media/VMC
        read only = no
        public = yes
        guest ok = yes
        F Online
        F Online
        fastfoot
        @chris76e username und passwort hast du aber geändert?
          möchte gerne ein Bild in meiner VIS anzeigen. Das Bild liegt auf der Festpaltte meine VU+ Box. Durch den Enigma2 Adapter bekomme ich den Programmnamen. Dieser muss in kleinbuchstaben geändert werden, dann in Base64 codiert werden.
          Beispiel :
           Guardians of the Galaxy Vol. 2  -> guardians of the galaxy vol. 2 -> Z3VhcmRpYW5zIG9mIHRoZSBnYWxheHkgdm9sLiAy
          jetzt muss hier
          /media/hdd/AdvancedEventLibrary/cover/
          auf meiner VU+ Box nach dem Base64 codierten namen gesucht werden.
          Bis jetzt bin ich nur soweit gekommen das der Programmname klein geschrieben wird.
          Wie muss ich jetzt weiter vorgehen? Gibt es eine Blockly funktion für Base64? Wie kann auch auf der VU+ suchen?
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @chris76e
          Leider hilft dir der Pfad auf deine nas so erst mal nicht, wenn du das Bild im Browser anzeigen lassen möchtest.
          Deinem Browser kann so nicht auf das Laufwerk zugreifen.
          Jetzt könnte man das über ioBroker machen, allerdings ist es da etwas aufwändig, da man die Datei erst einmal zum Web Server hochladen muss.
          Daher schlage ich vor, dass du einen neuen Web Server einrichtest (Nginx bietet sich da an ).
          Dieser Web Server ist so konfiguriert, dass er nur dieses eine Verzeichnis anbietet.
          So musst du in vis einfach nur die URL so berechnen, dass sie auf die URL des jeweiligen Bildes zeigt. Wie du vom Film Namen zur Base 64 Bezeichnung kommst, haben wir die vorschreiber schon dargestellt
          Meine Adapter und Widgets
          Links im Profil
          F Chris76eC OliverIOO 4 Antworten Letzte Antwort
          • OliverIOO OliverIO
            @chris76e
            F Online
            F Online
            fastfoot
            @oliverio sagte in Text in Base64 codieren und Datei von Netzlaufwerk suchen:
            werk zugreifen.
            aber auch nginx braucht die Datei ja erstmal lokal? deshalb der mount
            • F fastfoot
              werk zugreifen.
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @fastfoot
              Je nachdem wo man am besten nginx laufen lässt.
              Ja wahrscheinlich erst per Mount auf die eine Maschine,
              Dort dann nginx installieren und einrichten.
              Links im Profil
                @chris76e
                Chris76eC Offline
                Chris76eC Offline
                Chris76e
                @oliverio
                Das ist eine VU+ Box, ein Enigma2 Sat Receiver 😎 Glaube nicht das da ein Webserver drauf läuft..... Möchte ja nur einfach die Datei davon laden können.
                  @fastfoot
                  F Online
                  F Online
                  fastfoot
                  @chris76e sagte in Text in Base64 codieren und Datei von Netzlaufwerk suchen:
                  @fastfoot
                  nimm mal noch das hier weg ,file_mode=0777,dir_mode=0777
                  Chris76eC 1 Antwort Letzte Antwort
                  • F fastfoot
                    @fastfoot
                    Chris76eC Offline
                    Chris76eC Offline
                    Chris76e
                    @fastfoot
                    jetzt kommt das
                    mount: /home/iobroker/vubox: can't find in /etc/fstab.
                      @chris76e
                      Chris76eC Offline
                      Chris76eC Offline
                      Chris76e
                      Hmm, dachte wenn ich den Mount von der VU+ auf meinem ioBroker habe das ich dann einfach die Datei laden kann als ob die lokal im ioBroker liegt.
                      Ist das nicht so?
                        @oliverio
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @chris76e
                        Ich lese, das es für Enigma vu+ ein webinterface / openwebif gibt
                        Wenn man über dieses webinterface schafft die Bilder anzeigen zu lassen, dann hast du deinen Webserver.
                        Dann musst du in vis nur noch die URLs so einbauen, das sie auf das webinterface zeigen.
                        Links im Profil
                          @fastfoot
                          jetzt kommt das
                          F Online
                          F Online
                          fastfoot
                          @chris76e seltsam, mit proxmox vm kenne ich mich nicht aus aber eigentlich sollte man eben keinen eintrag in der fstab benötigen.
                          da bin ich jetzt erstmal überfragt, sorry
                            @chris76e
                            Chris76eC Offline
                            Chris76eC Offline
                            Chris76e
                            @chris76e
                            Wenn ich das Versuche
                            http://192.168.0.90/media/hdd/AdvancedEventLibrary/preview/a25hc3QgaW4gZGV1dHNjaGxhbmQgLSBlMDEgLSBzdHJhZmUsIGxpZWJlLCBob2ZmbnVuZw==.jpg%22
                            kommt ein 404 Fehler.
                              @chris76e
                              F Online
                              F Online
                              fastfoot
                              @chris76e gib mal //192.168.0.90/VUUNO4KSE/Harddisk im Windows Dateiexplorer ein ob das überhaupt der richtige share ist. NICHT im Browser
                              • F fastfoot
                                Chris76eC Offline
                                Chris76eC Offline
                                Chris76e
                                schrieb am zuletzt editiert von Chris76e
                                @fastfoot
                                Also das Netztlaufwerk auf die Festplatte ist
                                \\vuuno4kse\Harddisk
                                so in Windows angebunden. Habe es auch schon mit kleinbuchstaben probiert
                                F 2 Antworten Letzte Antwort
                                  @fastfoot
                                  F Online
                                  F Online
                                  fastfoot
                                  @chris76e ja dann passt der mount point, finde nichts im Netz zu diesem fstab Fehler. Ist denn überhaupt /home/iobroker/vubox erstellt worden???
                                  • F fastfoot
                                    Chris76eC Offline
                                    Chris76eC Offline
                                    Chris76e
                                    @fastfoot
                                    der ist da
                                      @fastfoot
                                      F Online
                                      F Online
                                      fastfoot
                                      @chris76e zeige mal noch ls -l /home/iobroker
                                      • F fastfoot
                                        Chris76eC Offline
                                        Chris76eC Offline
                                        Chris76e
                                        @fastfoot sagte in Text in Base64 codieren und Datei von Netzlaufwerk suchen:
                                        chris@ioBroker:~$ ls -l /home/iobroker
                                        insgesamt 44
                                        -rw-r--r-- 1 iobroker iobroker 38567 14. Okt 17:22 iob_diag.log
                                        drwxr-xr-x 2 iobroker iobroker  4096 16. Okt 00:19 vubox
                                          insgesamt 44
                                          F Online
                                          F Online
                                          fastfoot
                                          @chris76e sieht alles gut aus, wir machen aber morgen weiter. Welches Os nutzt du? Debian, Ubuntu? welche version?
