  4. nach Update JS-Controler - Kein Zugriff auf Iobroker mehr
    5.1k
22 Beiträge 4 Kommentatoren 2.6k Aufrufe 3 Beobachtet
  • R Rennuy
    @thomas-braun meinst die Fassung
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
            Machine ID: b874799b42e540eab9a2175a8d330f3b
               Boot ID: 6b228d7ca6614f4cb28bea04225ace72
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     08:29:10 up  9:00,  1 user,  load average: 0.60, 0.58, 0.56
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=45.7'C
    volt=0.8563V
    *** Time and Time Zones ***
                   Local time: Sun 2023-10-08 08:29:11 CEST
               Universal time: Sun 2023-10-08 06:29:11 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        287M        1.7G        119M        1.8G        3.4G
    Swap:            99M          0B         99M
    Total:          3.9G        287M        1.8G
             3793 M total memory
              287 M used memory
              553 M active memory
             1090 M inactive memory
             1704 M free memory
              335 M buffer memory
             1465 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      459G   21G  419G   5% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G  120M  1.8G   7% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Oct  7 23:29:03 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:800x600M@60D smsc95xx.macaddr=DC:A6:32:59:C0:E4 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  115200 console=tty1 root=PARTUUID=88db0d7f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Oct  7 23:29:05 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Oct  7 23:29:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Oct  7 23:29:07 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime
    |-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.2G    /var/
    482M    /var/log
    372M    /var/cache
    359M    /var/cache/apt
    300M    /var/cache/apt/archives
    Archived and active journals take up 118.5M in the file system.
    /opt/iobroker/backups:
    5.3G    /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    497M    /opt/iobroker/iobroker-data/files
    235M    /opt/iobroker/iobroker-data/backup-objects
    224M    /opt/iobroker/iobroker-data/history
    97M     /opt/iobroker/iobroker-data/node-red
    58M     /opt/iobroker/iobroker-data/states.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    No connection to databases possible ...
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        1
    States:         1
    E: The repository 'https://repos.influxdata.com/raspbian bullseye Release' does not have a Release file.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          363285     32677/cupsd
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          20489      500/connmand
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          20640      636/vncserver-x11-c
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       19260      543/deCONZ
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        17051      413/influxd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20230      651/sshd
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       20222      543/deCONZ
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        20925      413/influxd
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          20639      636/vncserver-x11-c
    tcp6       0      0 ::1:53                  :::*                    LISTEN      0          20493      500/connmand
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20232      651/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          363284     32677/cupsd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        18276      452/avahi-daemon: r
    udp        0      0 0.0.0.0:50674           0.0.0.0:*                           0          21802      500/connmand
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       19265      543/deCONZ
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          20481      500/connmand
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          20403      555/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          361858     32680/cups-browsed
    udp        0      0 0.0.0.0:55952           0.0.0.0:*                           108        18278      452/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        18277      452/avahi-daemon: r
    udp6       0      0 ::1:53                  :::*                                0          20485      500/connmand
    udp6       0      0 :::33225                :::*                                108        18279      452/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          20427      555/dhcpcd
    2023-10-08 08:31:05.326  - info: host.raspberrypi iobroker _restart
    2023-10-08 08:31:11.922  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
    2023-10-08 08:31:11.933  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-10-08 08:31:11.935  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
    2023-10-08 08:31:11.936  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
    2023-10-08 08:31:41.964  - error: host.raspberrypi No connection to databases possible, restart
    2023-10-08 08:31:41.974  - info: host.raspberrypi iobroker _restart
    2023-10-08 08:31:48.426  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
    2023-10-08 08:31:48.434  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-10-08 08:31:48.435  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
    2023-10-08 08:31:48.436  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
    2023-10-08 08:32:18.468  - error: host.raspberrypi No connection to databases possible, restart
    2023-10-08 08:32:18.477  - info: host.raspberrypi iobroker _restart
    2023-10-08 08:32:24.977  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
    2023-10-08 08:32:24.985  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-10-08 08:32:24.987  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
    2023-10-08 08:32:24.987  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
    2023-10-08 08:32:55.013  - error: host.raspberrypi No connection to databases possible, restart
    2023-10-08 08:32:55.023  - info: host.raspberrypi iobroker _restart
    2023-10-08 08:33:01.395  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
    2023-10-08 08:33:01.403  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-10-08 08:33:01.404  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
    2023-10-08 08:33:01.405  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
    2023-10-08 08:33:31.429  - error: host.raspberrypi No connection to databases possible, restart
    2023-10-08 08:33:31.440  - info: host.raspberrypi iobroker _restart
    HomoranH Offline
    HomoranH Offline
    @rennuy wofür ist vnc und cups?
    läuft alles auf einer SSD oder ist das eine 512GB SD?
    Ein slave ist das aber nicht, oder?
      @rennuy
      Hattest du redis am Start?
      Rennuy
      @thomas-braun sagte in nach Update JS-Controler - Kein Zugriff auf Iobroker mehr:
      Nein, nicht bewusst. Zumindest sagt mir redis nix.
      @homoran sagte in nach Update JS-Controler - Kein Zugriff auf Iobroker mehr:
      Mit VNC hatte ich mal rumgetestet, ob die graphische Oberfläche war bringt.
      cups sagt mir auch nichts.
      Evtl. habe ich mir bei meinen try an error Versuchen solche Sachen installiert. Trotzdem lief der PI bis gestern ohne Ausfälle.
      Ja, das System läuft auf einer SSD.
      • R Rennuy
        @rennuy
        sudo apt update
        sagt?
        R 1 Antwort Letzte Antwort
          @rennuy
          sudo apt update
          sagt?
          Rennuy
          @Homoran VNC und Cups habe ich mal gelöscht. Cups schient ein Druckerserver zu sein.
          @thomas
          pi@raspberrypi:~ $ sudo apt update
          OK:1 http://phoscon.de/apt/deconz buster InRelease
          OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Ign:4 https://repos.influxdata.com/raspbian bullseye InRelease
          OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Fehl:6 https://repos.influxdata.com/raspbian bullseye Release
            404  Not Found [IP: 2600:9000:20c3:8000:11:fe8d:7d40:93a1 443]
          E: Das Depot »https://repos.influxdata.com/raspbian bullseye Release« enthält keine Release-Datei.
          N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
          N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
          • R Rennuy
            @thomas
            @rennuy
            Das influx-Repo muss frisch angelegt werden.
            Hat aber nichts mit dem Problem zu tun.
            Was meinst du mit 'hab ich gelöscht?'
            Wie machst du das 'löschen'?
              @rennuy
              Rennuy
               sudo apt purge realvnc-vnc-server
              sudo apt purge cups
              sudo apt autoremove
              sudo reboot
              danach waren die Installationen in der diag-Ausgabe raus.
              • R Rennuy
                sudo apt purge cups
                sudo apt autoremove
                sudo reboot
                Rennuy
                Das Influx-Repo schein wieder zu laufen.
                Danke @thomas für die Anleitung
                https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden/53?_=1696754572642
                sudo apt update
                OK:4 https://repos.influxdata.com/debian stable InRelease
                Aktualisierung für 509 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                Das Problem mit iobroker konnte ich aber noch nicht eingrenzen
                iob diag sagt jetzt folgendes:
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                         Icon name: computer
                           Boot ID: 5bb584627ff04242a22bcc2913cde215
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : armhf
                 11:10:58 up  1:25,  1 user,  load average: 0.58, 0.63, 0.65
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=46.7'C
                volt=0.8563V
                               Local time: Sun 2023-10-08 11:10:58 CEST
                           Universal time: Sun 2023-10-08 09:10:58 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            3.8G        289M        2.1G         24M        1.4G        3.5G
                Swap:            99M          0B         99M
                Total:          3.9G        289M        2.2G
                         3793 M total memory
                          288 M used memory
                          542 M active memory
                          755 M inactive memory
                         2094 M free memory
                          281 M buffer memory
                         1128 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                tmpfs          tmpfs     1.9G   25M  1.9G   2% /run
                [Sun Oct  8 09:45:41 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:800x600M@60D smsc95xx.macaddr=DC:A6:32:59:C0:E4 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  115200 console=tty1 root=PARTUUID=88db0d7f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Sun Oct  8 09:45:43 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                [Sun Oct  8 09:45:43 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Sun Oct  8 09:45:45 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                /var:
                1.3G    /var/
                490M    /var/log
                372M    /var/cache
                359M    /var/cache/apt
                Archived and active journals take up 23.7M in the file system.
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                ioBroker Status
                admin:          6.10.1
                javascript:     7.1.4
                Adapter State
                Objects and States
                Objects:        1
                States:         1
                Hit:1 https://repos.influxdata.com/debian stable InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:4 http://phoscon.de/apt/deconz buster InRelease
                Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        21556      439/influxd
                tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       18986      504/deCONZ
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19731      633/sshd
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18951      504/deCONZ
                tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          20753      404/connmand
                tcp6       0      0 :::22                   :::*                    LISTEN      0          19733      633/sshd
                tcp6       0      0 ::1:53                  :::*                    LISTEN      0          20757      404/connmand
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        19107      439/influxd
                udp        0      0 0.0.0.0:44265           0.0.0.0:*                           0          861126     404/connmand
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14247      410/avahi-daemon: r
                udp        0      0 0.0.0.0:36338           0.0.0.0:*                           108        14249      410/avahi-daemon: r
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18990      504/deCONZ
                udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          20745      404/connmand
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          21042      459/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        14248      410/avahi-daemon: r
                udp6       0      0 ::1:53                  :::*                                0          20749      404/connmand
                udp6       0      0 :::53325                :::*                                108        14250      410/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          861113     459/dhcpcd
                2023-10-08 11:13:02.466  - info: host.raspberrypi iobroker _restart
                2023-10-08 11:13:08.916  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                2023-10-08 11:13:08.928  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                2023-10-08 11:13:08.929  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                2023-10-08 11:13:08.931  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                2023-10-08 11:13:38.969  - error: host.raspberrypi No connection to databases possible, restart
                2023-10-08 11:13:38.978  - info: host.raspberrypi iobroker _restart
                2023-10-08 11:13:45.333  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                2023-10-08 11:13:45.341  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                2023-10-08 11:13:45.343  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                2023-10-08 11:13:45.343  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                2023-10-08 11:14:15.378  - error: host.raspberrypi No connection to databases possible, restart
                2023-10-08 11:14:15.395  - info: host.raspberrypi iobroker _restart
                2023-10-08 11:14:22.108  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                2023-10-08 11:14:22.117  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                2023-10-08 11:14:22.118  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                2023-10-08 11:14:22.119  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                2023-10-08 11:14:52.150  - error: host.raspberrypi No connection to databases possible, restart
                2023-10-08 11:14:52.162  - info: host.raspberrypi iobroker _restart
                2023-10-08 11:14:58.578  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                2023-10-08 11:14:58.589  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                2023-10-08 11:14:58.591  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                2023-10-08 11:14:58.592  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                2023-10-08 11:15:28.622  - error: host.raspberrypi No connection to databases possible, restart
                2023-10-08 11:15:28.631  - info: host.raspberrypi iobroker _restart
                • R Rennuy
                  sudo apt update
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : armhf
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=46.7'C
                  volt=0.8563V
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           3793 M total memory
                            288 M used memory
                            542 M active memory
                           2094 M free memory
                            281 M buffer memory
                           1128 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  1.3G    /var/
                  490M    /var/log
                  372M    /var/cache
                  359M    /var/cache/apt
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  nodejs:
                    Version table:
                  ioBroker Status
                  admin:          6.10.1
                  javascript:     7.1.4
                  Adapter State
                  Objects and States
                  Objects:        1
                  States:         1
                  Pending Updates: 0
                  @rennuy
                  Ääääh...
                  FeuersturmF R 2 Antworten Letzte Antwort
                    @rennuy
                    Ääääh...
                    FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    @thomas-braun neuer Rekord 😂
                      @rennuy
                      Ääääh...
                      Rennuy
                      @thomas-braun ja, daran hänge ich gerade. sudo apt full-upgrade bringt mir einen lib-Fehler.
                      pi@raspberrypi:~ $ sudo apt full-upgrade
                      Paketaktualisierung (Upgrade) wird berechnet... Fehler!
                      Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
                      Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
                      Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
                      nicht erstellt wurden oder Incoming noch nicht verlassen haben.
                      Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
                      Die folgenden Pakete haben unerfüllte Abhängigkeiten:
                       libc6-dev : Beschädigt: libgcc-8-dev (< 8.4.0-2~) aber 8.3.0-6+rpi1 soll installiert werden
                      E: Fehler: Unterbrechungen durch pkgProblemResolver::Resolve hervorgerufen; dies könnte durch zurückgehaltene Pakete verursacht worden sein.
                      Bin kurz davor das System mit Bookworm gleich neu aufzusetzen.
                      • R Rennuy
                        @rennuy
                        Was haste denn da gemacht?
                        Upgrade von Buster kommend auf Bullseye versucht?
                        Bookworm ist noch nicht für Raspberry OS veröffentlicht.
                          @rennuy
                          Rennuy
                          Versucht ist gut. Das Update habe ich vor zwei Wochen gemacht, danach lief der iobroker noch. Gestern habe ich den JS-Controler auf 5.0.12 aktualisiert.
                          • R Rennuy
                            @rennuy
                            Das Upgrade ist aber bei der Hälfte in die Hose gegangen. Zu gcc8 stand aber glaube ich was in meinem HowTo zu dem Thema drin.
                              @rennuy
                              Rennuy
                              @thomas-braun Danke, für den Wink!!! Die howto hatte ich zwar gelesen, wohl aber nicht verstanden. Jetzt bin ich soweit, dass keine Pakete mehr zum Upgrade vorgesehen sind.
                              Alle Pakete sind aktuell.
                              Bei iob diag ist schonmal die Meldung No connection to databases possible ... raus. Die vorhandenen Fehler muss ich später noch filtern.
                              Skript v.2023-06-20
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                         Boot ID: 0b5e69359b5d4280bedccac0032ee984
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                               13:03:42 up 25 min,  1 user,  load average: 1.63, 1.35, 0.98
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=48.2'C
                              volt=0.8563V
                                             Local time: Sun 2023-10-08 13:03:43 CEST
                                         Universal time: Sun 2023-10-08 11:03:43 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            3.8G        228M        1.8G        1.0M        1.7G        3.5G
                              Swap:            99M          0B         99M
                              Total:          3.9G        228M        1.9G
                                       3793 M total memory
                                        228 M used memory
                                        583 M active memory
                                       1022 M inactive memory
                                       1836 M free memory
                                        396 M buffer memory
                                       1331 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /dev/root      ext4      459G   17G  423G   4% /
                              tmpfs          tmpfs     759M  1.1M  758M   1% /run
                              tmpfs          tmpfs     380M   28K  380M   1% /run/user/1000
                              [Sun Oct  8 12:37:57 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:800x600M@60D smsc95xx.macaddr=DC:A6:32:59:C0:E4 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  115200 console=tty1 root=PARTUUID=88db0d7f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                              [Sun Oct  8 12:37:59 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Sun Oct  8 12:37:59 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                              [Sun Oct  8 12:38:01 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                              /var:
                              1.4G    /var/
                              575M    /var/log
                              394M    /var/cache
                              381M    /var/cache/apt
                              317M    /var/cache/apt/archives
                              Archived and active journals take up 72.0M in the file system.
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              node:internal/modules/cjs/loader:1080
                                throw err;
                              Error: Cannot find module 'tar'
                              Require stack:
                              - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
                              - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
                              - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                  at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                  at Module._load (node:internal/modules/cjs/loader:922:27)
                                  at Module.require (node:internal/modules/cjs/loader:1143:19)
                                  at require (node:internal/modules/cjs/helpers:119:18)
                                  at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
                                  at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                  at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                  at Module.load (node:internal/modules/cjs/loader:1119:32)
                                  at Module._load (node:internal/modules/cjs/loader:960:12)
                                  at Module.require (node:internal/modules/cjs/loader:1143:19) {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: [
                                  '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
                                  '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
                                  '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              Node.js v18.18.0
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.18.0
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.18.0
                              js-controller:
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.18.0
                              admin:
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.18.0
                              javascript:
                              Adapters from github:   0
                              Adapter State
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.18.0
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.18.0
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.18.0
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.18.0
                              Objects and States
                              Objects:        0
                              States:         0
                              Hit:1 http://phoscon.de/apt/deconz buster InRelease
                              Hit:2 https://repos.influxdata.com/debian stable InRelease
                              Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Pending Updates: 0
                              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16579      440/influxd
                              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16664      401/deCONZ
                              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15592      401/deCONZ
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4010       626/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          16534      394/connmand
                              tcp6       0      0 :::4369                 :::*                    LISTEN      0          13439      1/init
                              tcp6       0      0 ::1:53                  :::*                    LISTEN      0          16538      394/connmand
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          4012       626/sshd: /usr/sbin
                              tcp6       0      0 :::8086                 :::*                    LISTEN      999        4094       440/influxd
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14717      390/avahi-daemon: r
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15682      401/deCONZ
                              udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          16526      394/connmand
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15684      517/dhcpcd
                              udp        0      0 0.0.0.0:33633           0.0.0.0:*                           108        14719      390/avahi-daemon: r
                              udp        0      0 0.0.0.0:56477           0.0.0.0:*                           0          16349      394/connmand
                              udp6       0      0 :::5353                 :::*                                108        14718      390/avahi-daemon: r
                              udp6       0      0 ::1:53                  :::*                                0          16530      394/connmand
                              udp6       0      0 :::37274                :::*                                108        14720      390/avahi-daemon: r
                              udp6       0      0 :::546                  :::*                                0          16150      517/dhcpcd
                              2023-10-08 11:45:16.680  - info: host.raspberrypi iobroker _restart
                              2023-10-08 11:45:33.899  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                              2023-10-08 11:45:33.907  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                              2023-10-08 11:45:33.908  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                              2023-10-08 11:45:33.909  - info: host.raspberrypi ip addresses: 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                              2023-10-08 11:46:18.431  - error: host.raspberrypi No connection to databases possible, restart
                              2023-10-08 11:46:18.442  - info: host.raspberrypi iobroker _restart
                              2023-10-08 11:46:24.787  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                              2023-10-08 11:46:24.795  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                              2023-10-08 11:46:24.797  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                              2023-10-08 11:46:24.798  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                              2023-10-08 11:46:54.845  - error: host.raspberrypi No connection to databases possible, restart
                              2023-10-08 11:46:54.855  - info: host.raspberrypi iobroker _restart
                              2023-10-08 11:47:01.335  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                              2023-10-08 11:47:01.343  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                              2023-10-08 11:47:01.344  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                              2023-10-08 11:47:01.345  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                              2023-10-08 11:47:31.377  - error: host.raspberrypi No connection to databases possible, restart
                              2023-10-08 11:47:31.387  - info: host.raspberrypi iobroker _restart
                              2023-10-08 11:47:38.136  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                              2023-10-08 11:47:38.146  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                              2023-10-08 11:47:38.148  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                              2023-10-08 11:47:38.149  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                              2023-10-08 11:48:08.189  - error: host.raspberrypi No connection to databases possible, restart
                              2023-10-08 11:48:08.198  - info: host.raspberrypi iobroker _restart
                              • R Rennuy
                                Skript v.2023-06-20
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : armhf
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=48.2'C
                                volt=0.8563V
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         3793 M total memory
                                          228 M used memory
                                          583 M active memory
                                         1836 M free memory
                                          396 M buffer memory
                                         1331 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                1.4G    /var/
                                575M    /var/log
                                394M    /var/cache
                                381M    /var/cache/apt
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.18.0
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.18.0
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.18.0
                                js-controller:
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.18.0
                                admin:
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.18.0
                                javascript:
                                Adapter State
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.18.0
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.18.0
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.18.0
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.18.0
                                Objects and States
                                Objects:        0
                                States:         0
                                Pending Updates: 0
                                @rennuy
                                Zu
                                gab es bereits Threads.
                                • R Rennuy
                                  Skript v.2023-06-20
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : armhf
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=48.2'C
                                  volt=0.8563V
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           3793 M total memory
                                            228 M used memory
                                            583 M active memory
                                           1836 M free memory
                                            396 M buffer memory
                                           1331 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  1.4G    /var/
                                  575M    /var/log
                                  394M    /var/cache
                                  381M    /var/cache/apt
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                  js-controller:
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                  admin:
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                  javascript:
                                  Adapter State
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.18.0
                                  Objects and States
                                  Objects:        0
                                  States:         0
                                  Pending Updates: 0
                                  @rennuy
                                  Und das deconz-Repo musst du auch auf 'bullseye' umstellen.
                                  • R Offline
                                    Rennuy
                                    Den Thread hab ich gefunden.
                                    https://forum.iobroker.net/topic/33596/nach-update-läuft-nichts-mehr/364
                                    Scheint so als ob mein npm auch über n und nicht über den Paketmanager installiert ist.
                                    Das "tar"-Problem scheint behoben. Trotzdem bin ich noch am Anfang.
                                    pi@raspberrypi:~ $ iob status
                                    Skript v.2023-06-20
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                               Boot ID: 3f1c3fa14b4a4a02b1601781840bb043
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : armhf
                                     18:41:21 up  5:27,  1 user,  load average: 0.79, 0.58, 0.57
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=45.7'C
                                    volt=0.8563V
                                                   Local time: Sun 2023-10-08 18:41:21 CEST
                                               Universal time: Sun 2023-10-08 16:41:21 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.8G        273M        2.1G        1.0M        1.4G        3.5G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        273M        2.2G
                                             3793 M total memory
                                              273 M used memory
                                              700 M active memory
                                             2120 M free memory
                                              181 M buffer memory
                                             1218 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4      459G   18G  423G   4% /
                                    [Sun Oct  8 13:13:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:800x600M@60D smsc95xx.macaddr=DC:A6:32:59:C0:E4 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  115200 console=tty1 root=PARTUUID=88db0d7f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    [Sun Oct  8 13:13:30 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Sun Oct  8 13:13:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                    [Sun Oct  8 13:13:32 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                    /var:
                                    1.4G    /var/
                                    673M    /var/log
                                    394M    /var/cache
                                    381M    /var/cache/apt
                                    Archived and active journals take up 152.0M in the file system.
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    admin:          6.10.1
                                    javascript:     "javascript" not found
                                    Adapter State
                                    Objects and States
                                    Objects:        1
                                    States:         1
                                    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          15668      395/connmand
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       16465      399/deCONZ
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13866      634/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16575      399/deCONZ
                                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        3996       453/influxd
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13868      634/sshd: /usr/sbin
                                    tcp6       0      0 :::4369                 :::*                    LISTEN      0          15432      1/init
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        16580      453/influxd
                                    tcp6       0      0 ::1:53                  :::*                    LISTEN      0          15672      395/connmand
                                    udp        0      0 0.0.0.0:48814           0.0.0.0:*                           0          25835      395/connmand
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17421      399/deCONZ
                                    udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          15660      395/connmand
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14090      530/dhcpcd
                                    udp        0      0 0.0.0.0:47490           0.0.0.0:*                           108        3563       391/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3561       391/avahi-daemon: r
                                    udp6       0      0 ::1:53                  :::*                                0          15664      395/connmand
                                    udp6       0      0 :::546                  :::*                                0          24283      530/dhcpcd
                                    udp6       0      0 :::33644                :::*                                108        3564       391/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        3562       391/avahi-daemon: r
                                    2023-10-08 18:43:18.041  - info: host.raspberrypi iobroker _restart
                                    2023-10-08 18:43:24.424  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                                    2023-10-08 18:43:24.439  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                    2023-10-08 18:43:24.441  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                                    2023-10-08 18:43:24.442  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                                    2023-10-08 18:43:54.483  - error: host.raspberrypi No connection to databases possible, restart
                                    2023-10-08 18:43:54.491  - info: host.raspberrypi iobroker _restart
                                    2023-10-08 18:44:00.891  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                                    2023-10-08 18:44:00.900  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                    2023-10-08 18:44:00.902  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                                    2023-10-08 18:44:00.903  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                                    2023-10-08 18:44:30.943  - error: host.raspberrypi No connection to databases possible, restart
                                    2023-10-08 18:44:30.961  - info: host.raspberrypi iobroker _restart
                                    2023-10-08 18:44:37.503  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                                    2023-10-08 18:44:37.512  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                    2023-10-08 18:44:37.513  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                                    2023-10-08 18:44:37.515  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                                    2023-10-08 18:45:07.547  - error: host.raspberrypi No connection to databases possible, restart
                                    2023-10-08 18:45:07.555  - info: host.raspberrypi iobroker _restart
                                    2023-10-08 18:45:13.901  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                                    2023-10-08 18:45:13.913  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                    2023-10-08 18:45:13.914  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.0
                                    2023-10-08 18:45:13.916  - info: host.raspberrypi ip addresses: 192.168.178.32 2003:ee:1f1b:e900:12d5:7e83:876a:dbc1 fe80::1dbd:7958:b90b:4a04
                                    2023-10-08 18:45:43.955  - error: host.raspberrypi No connection to databases possible, restart
                                    2023-10-08 18:45:43.964  - info: host.raspberrypi iobroker _restart
                                    Ich hab das System vor drei Jahren mit viel Unwissen aufgebaut. Hat bislang gut und stabil funktioniert. Jetzt ist wohl der Zeitpunkt gekommen, das System mal sauber aufzusetzen.
                                    Danke @Thomas-Braun für Deinen raschen sonntäglichen Support.
                                    • R Rennuy
                                      Skript v.2023-06-20
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : armhf
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=45.7'C
                                      volt=0.8563V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               3793 M total memory
                                                273 M used memory
                                                700 M active memory
                                               2120 M free memory
                                                181 M buffer memory
                                               1218 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      1.4G    /var/
                                      673M    /var/log
                                      394M    /var/cache
                                      381M    /var/cache/apt
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      admin:          6.10.1
                                      Adapter State
                                      Objects and States
                                      Objects:        1
                                      States:         1
                                      Pending Updates: 0
                                      @rennuy sagte in nach Update JS-Controler - Kein Zugriff auf Iobroker mehr:
                                      Nein, das ist jetzt richtig.
                                      Dann nimm diesmal ein reines 4bit-System.
