  4. Tuya Adapter bleibt gelb aber funktioniert trotzdem?
18 Beiträge 5 Kommentatoren 1.8k Aufrufe 4 Beobachtet
  • Horst BöttcherH Horst Böttcher
    Habe ganu das selbe Problem
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: PiMaster
             Icon name: computer
            Machine ID: a2d1eb396d2e47c7b46e6d7a290ca3dc
               Boot ID: 6041eed0117c4abc905994d72a693ab3
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     19:30:38 up 2 days,  6:42,  1 user,  load average: 0.26, 0.45, 0.36
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=50.6'C
    volt=0.8563V
    *** Time and Time Zones ***
                   Local time: Fri 2023-10-06 19:30:38 CEST
               Universal time: Fri 2023-10-06 17:30:38 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.0G        2.1G        1.0M        708M        2.7G
    Swap:            99M          0B         99M
    Total:          3.9G        1.0G        2.2G
             3793 M total memory
             1019 M used memory
             1084 M active memory
              506 M inactive memory
             2065 M free memory
               73 M buffer memory
              634 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G  3.6G   53G   7% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Wed Oct  4 12:47:47 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:87:89:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ee915a6-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Oct  4 12:47:51 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Wed Oct  4 12:47:51 2023] EXT4-fs (sda2): write access will be enabled during recovery
    [Wed Oct  4 12:47:51 2023] EXT4-fs (sda2): recovery complete
    [Wed Oct  4 12:47:51 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Oct  4 12:47:51 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Oct  4 12:47:52 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime,commit=600
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    623M    /var/
    196M    /var/log
    185M    /var/log/journal/a2d1eb396d2e47c7b46e6d7a290ca3dc
    180M    /var/cache
    Archived and active journals take up 184.0M in the file system.
    /opt/iobroker/backups:
    86M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    222M    /opt/iobroker/iobroker-data/
    167M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    34M     /opt/iobroker/iobroker-data/backup-objects
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   disabled
    Persistent activation:      disabled
    Objects:                    jsonl on 0.0.0.0
    States:                     jsonl on 0.0.0.0
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : PiMaster                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : PiMaster                                 - disabled
    + system.adapter.backitup.0               : backitup              : PiMaster                                 -  enabled
    + system.adapter.ble.0                    : ble                   : PiMaster                                 -  enabled
    + system.adapter.discovery.0              : discovery             : PiMaster                                 -  enabled
      system.adapter.hm-rega.0                : hm-rega               : PiMaster                                 - disabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : PiMaster                                 -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : PiMaster                                 - disabled, port: 0
    + system.adapter.iot.0                    : iot                   : PiMaster                                 -  enabled
    + system.adapter.javascript.0             : javascript            : PiMaster                                 -  enabled
      system.adapter.parcel.0                 : parcel                : PiMaster                                 - disabled
    + system.adapter.sonoff.0                 : sonoff                : PiMaster                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : PiMaster                                 -  enabled
      system.adapter.vis.0                    : vis                   : PiMaster                                 -  enabled
    + system.adapter.web.0                    : web                   : PiMaster                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : PiMaster                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : PiMaster                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.13.1
    Objects and States
    Objects:        2127
    States:         1695
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 20
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       92171      14161/io.sonoff.0
    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       106609     16973/sshd: pi@pts/
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       88685      13882/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14421      526/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       90206      13791/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       90213      13791/iobroker.js-c
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       89350      13972/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       89201      13809/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14423      526/sshd: /usr/sbin
    tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       106608     16973/sshd: pi@pts/
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12954      649/dhcpcd
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       100223     15701/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       100224     15701/io.tuya.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       90400      13957/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12833      391/avahi-daemon: r
    udp        0      0 0.0.0.0:48638           0.0.0.0:*                           108        12835      391/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14614      649/dhcpcd
    udp6       0      0 :::60032                :::*                                108        12836      391/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12834      391/avahi-daemon: r
    2023-10-06 19:31:22.418  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.STATE.Wifi.AP" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.462  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.STATE.Wifi.SSId" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.506  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.STATE.Wifi.BSSId" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.554  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.STATE.Wifi.Channel" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.600  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.STATE.Wifi.Mode" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.659  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.STATE.Wifi.RSSI" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.706  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.STATE.Wifi.Signal" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.754  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.STATE.Wifi.LinkCount" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.798  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.STATE.Wifi.Downtime" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.842  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.Time" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.887  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.TotalStartTime" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.935  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.Total" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:22.982  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.Yesterday" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:23.039  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.Today" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:23.086  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.Period" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:23.133  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.Power" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:23.178  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.ApparentPower" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:23.222  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.ReactivePower" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:23.266  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.Factor" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:23.310  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.Voltage" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:23.354  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.SENSOR.ENERGY.Current" has no existing object, this might lead to an error in future versions
    2023-10-06 19:31:32.145  - info: sonoff.0 (14161) Client [DVES_F0B185] connected with secret 1696613492144_8497
    2023-10-06 19:31:42.571  - info: sonoff.0 (14161) Client [TV Schrank] connected with secret 1696613502570_2084
    2023-10-06 19:31:42.864  - info: sonoff.0 (14161) Client [DVES_F0B185] connection closed: timeout
    2023-10-06 19:31:42.913  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
    Copy text starting here:
                         v.2023-06-20
             Icon name: computer
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     20
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Swap:            99M          0B         99M
    Active iob-Instances:   13
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.10.1
    Objects type: jsonl
    States  type: jsonl
    Objects:                2127
    States:                 1695
    Size of iob-Database:
    4.8M    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    War gerde dabei @DJMarc75
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @horst-böttcher sagte in Tuya Adapter bleibt gelb aber funktioniert trotzdem?:
    Das selbe Problem - dann aber bitte in Codetags posten, nicht wie @Walter-White als endlos langen Text den man nicht lesen will
    Lehrling seit 1975 !!!
    Walter WhiteW F 2 Antworten Letzte Antwort
    • DJMarc75D DJMarc75
      Walter WhiteW Offline
      Walter White
      schrieb am zuletzt editiert von Walter White
      @djmarc75 sorry habe dieses code tag Zeichen angeklickt, und dann dort eingefügt. 🥲
        Skript v.2023-06-20
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=50.6'C
        volt=0.8563V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3793 M total memory
                 1019 M used memory
                 2065 M free memory
                   73 M buffer memory
                  634 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        623M    /var/
        196M    /var/log
        180M    /var/cache
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.1
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        2127
        States:         1695
        Pending Updates: 20
                             v.2023-06-20
                 Icon name: computer
              Architecture: arm64
        Kernel:                 aarch64
        Userland:               arm64
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
        Swap:            99M          0B         99M
                                admin                   6.10.1
        Objects type: jsonl
        States  type: jsonl
        Objects:                2127
        States:                 1695
        Walter White
        @horst-böttcher funktioniert der Adapter bei dir ansonsten?
        So wie es hier aussieht ist der Adapter zwar gelb aber scheint grundsätzlich zu funktionieren.
        Horst BöttcherH 1 Antwort Letzte Antwort
          Skript v.2023-06-20
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=50.6'C
          volt=0.8563V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3793 M total memory
                   1019 M used memory
                   2065 M free memory
                     73 M buffer memory
                    634 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          623M    /var/
          196M    /var/log
          180M    /var/cache
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.10.1
          javascript:     7.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        2127
          States:         1695
          Pending Updates: 20
                               v.2023-06-20
                   Icon name: computer
                Architecture: arm64
          Kernel:                 aarch64
          Userland:               arm64
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          MEMORY:
          Swap:            99M          0B         99M
                                  admin                   6.10.1
          Objects type: jsonl
          States  type: jsonl
          Objects:                2127
          States:                 1695
          Pending Updates: 20
          Und du knallst immer noch die Kiste unsanft auf den Boden.
          Ich glaube das ist dir auch schon mehr als einmal gesagt worden.
          @Walter-White
          Schau in das log und dann startest du den Adapter mal neu.
          Für @Horst-Böttcher das gleiche...
          iob logs --watch | uniq
          dann Adapter neustarten.
          Horst BöttcherH Walter WhiteW 2 Antworten Letzte Antwort
          • Walter WhiteW Walter White
            Horst BöttcherH Offline
            Horst Böttcher
            @walter-white daten werden geholt aber nicht geschalten
            gestern gin auch nich das schalten
            ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
              Frank579
              @djmarc75 sagte in Tuya Adapter bleibt gelb aber funktioniert trotzdem?:
              Genau das hat er gemacht darf man beim iob diag NICHT
                Pending Updates: 20
                @Walter-White
                Horst Böttcher
                @thomas-braun sagte in Tuya Adapter bleibt gelb aber funktioniert trotzdem?:
                    │                 • MobaXterm Personal Edition v23.2 •                 │
                    │               (SSH client, X server and network tools)               │
                    │ ⮞ SSH session to pi@192.168.178.100                                  │
                    │   • Direct SSH      :  ✓                                             │
                    │   • SSH compression :  ✓                                             │
                    │   • SSH-browser     :  ✓                                             │
                    │   • X11-forwarding  :  ✓  (remote display is forwarded through SSH)  │
                    │ ⮞ For more info, ctrl+click on help or visit our website.            │
                Linux PiMaster 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                permitted by applicable law.
                Last login: Fri Oct  6 19:35:31 2023 from 192.168.178.33
                Wi-Fi is currently blocked by rfkill.
                Use raspi-config to set the country before use.
                pi@PiMaster:~ $ iob logs --watch | uniq
                2023-10-06 19:42:13.172  - info: sonoff.0 (14161) Client [DVES_F0B185] connected with secret 1696614133172_898
                2023-10-06 19:42:13.226  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:42:13.269  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:42:13.537  - info: host.PiMaster "system.adapter.tuya.0" disabled
                2023-10-06 19:42:13.539  - info: host.PiMaster stopInstance system.adapter.tuya.0 (force=false, process=true)
                2023-10-06 19:42:13.551  - info: tuya.0 (15701) Got terminate signal TERMINATE_YOURSELF
                2023-10-06 19:42:13.590  - info: host.PiMaster stopInstance system.adapter.tuya.0 send kill signal
                2023-10-06 19:42:16.559  - info: tuya.0 (15701) terminating
                2023-10-06 19:42:16.563  - info: tuya.0 (15701) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-10-06 19:42:17.172  - info: host.PiMaster instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-10-06 19:42:17.271  - info: host.PiMaster "system.adapter.tuya.0" enabled
                2023-10-06 19:42:17.370  - info: host.PiMaster instance system.adapter.tuya.0 started with pid 19343
                2023-10-06 19:42:20.035  - info: tuya.0 (19343) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                2023-10-06 19:42:20.874  - info: tuya.0 (19343) bfe7090bfb7be477fbbhbf: Connect locally to device
                2023-10-06 19:42:20.880  - info: tuya.0 (19343) 854560468cce4e2b75c9: Connect locally to device
                2023-10-06 19:42:20.890  - info: tuya.0 (19343) bfe738f15da8902f970vq3: Connect locally to device
                2023-10-06 19:42:20.892  - info: tuya.0 (19343) 4530056170039f4b4878: Connect locally to device
                2023-10-06 19:42:20.895  - info: tuya.0 (19343) 0478272848551959bf4f: Connect locally to device
                2023-10-06 19:42:20.973  - info: tuya.0 (19343) bf31354560b3f6bc77b56v: Connect locally to device
                2023-10-06 19:42:20.975  - info: tuya.0 (19343) Existing devices initialized
                2023-10-06 19:42:20.981  - info: tuya.0 (19343) Try to sync devices from Cloud using stored cloud credentials
                2023-10-06 19:42:21.335  - info: tuya.0 (19343) Listen for local Tuya devices on port 6666
                2023-10-06 19:42:21.336  - info: tuya.0 (19343) Listen for encrypted local Tuya devices on port 6667
                2023-10-06 19:42:22.672  - info: tuya.0 (19343) Cloud MQTT connection established successfully.
                2023-10-06 19:42:23.111  - info: tuya.0 (19343) bfe738f15da8902f970vq3: Connect locally to device
                2023-10-06 19:42:23.115  - info: tuya.0 (19343) 4530056170039f4b4878: Connect locally to device
                2023-10-06 19:42:23.162  - info: tuya.0 (19343) 0478272848551959bf4f: Connect locally to device
                2023-10-06 19:42:23.166  - info: tuya.0 (19343) 854560468cce4e2b75c9: Connect locally to device
                2023-10-06 19:42:23.175  - info: tuya.0 (19343) bf31354560b3f6bc77b56v: Connect locally to device
                2023-10-06 19:42:23.223  - info: tuya.0 (19343) bfe7090bfb7be477fbbhbf: Connect locally to device
                2023-10-06 19:42:23.588  - info: sonoff.0 (14161) Client [TV Schrank] connected with secret 1696614143588_6693
                2023-10-06 19:42:25.235  - info: sonoff.0 (14161) Client [DVES_F0B185] connection closed: timeout
                2023-10-06 19:42:25.281  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:42:33.662  - info: sonoff.0 (14161) Client [TV Schrank] connection closed: timeout
                2023-10-06 19:42:54.154  - info: sonoff.0 (14161) Client [DVES_F0B185] connected with secret 1696614174154_9636
                2023-10-06 19:42:54.213  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:42:54.257  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:43:04.921  - info: sonoff.0 (14161) Client [DVES_F0B185] connection closed: timeout
                2023-10-06 19:43:04.969  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:43:14.681  - info: sonoff.0 (14161) Client [TV Schrank] connection closed: timeout
                2023-10-06 19:43:35.174  - info: sonoff.0 (14161) Client [DVES_F0B185] connected with secret 1696614215171_6308
                2023-10-06 19:43:35.237  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:43:35.281  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:43:45.615  - info: sonoff.0 (14161) Client [TV Schrank] connected with secret 1696614225614_3451
                2023-10-06 19:43:45.887  - info: sonoff.0 (14161) Client [DVES_F0B185] connection closed: timeout
                2023-10-06 19:43:45.898  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:43:55.674  - info: sonoff.0 (14161) Client [TV Schrank] connection closed: timeout
                2023-10-06 19:44:26.635  - info: sonoff.0 (14161) Client [TV Schrank] connected with secret 1696614266627_119
                2023-10-06 19:44:36.161  - info: sonoff.0 (14161) Client [DVES_F0B185] connected with secret 1696614276160_9799
                2023-10-06 19:44:36.228  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:44:36.269  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:44:36.791  - info: sonoff.0 (14161) Client [TV Schrank] connection closed: timeout
                2023-10-06 19:44:46.886  - info: sonoff.0 (14161) Client [DVES_F0B185] connection closed: timeout
                2023-10-06 19:44:46.937  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:45:07.617  - info: sonoff.0 (14161) Client [TV Schrank] connected with secret 1696614307616_8296
                2023-10-06 19:45:17.673  - info: sonoff.0 (14161) Client [TV Schrank] connection closed: timeout
                2023-10-06 19:45:37.181  - info: sonoff.0 (14161) Client [DVES_F0B185] connected with secret 1696614337180_4565
                2023-10-06 19:45:37.259  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:45:37.301  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:45:47.903  - info: sonoff.0 (14161) Client [DVES_F0B185] connection closed: timeout
                2023-10-06 19:45:47.953  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:45:51.618  - info: sonoff.0 (14161) Client [TV Schrank] connected with secret 1696614351617_4004
                2023-10-06 19:46:01.678  - info: sonoff.0 (14161) Client [TV Schrank] connection closed: timeout
                2023-10-06 19:46:22.180  - info: sonoff.0 (14161) Client [DVES_F0B185] connected with secret 1696614382179_9902
                2023-10-06 19:46:22.253  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:46:22.297  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:46:32.617  - info: sonoff.0 (14161) Client [TV Schrank] connected with secret 1696614392609_2598
                2023-10-06 19:46:32.890  - info: sonoff.0 (14161) Client [DVES_F0B185] connection closed: timeout
                2023-10-06 19:46:32.896  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:46:42.682  - info: sonoff.0 (14161) Client [TV Schrank] connection closed: timeout
                2023-10-06 19:47:03.191  - info: sonoff.0 (14161) Client [DVES_F0B185] connected with secret 1696614423182_2930
                2023-10-06 19:47:03.251  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                2023-10-06 19:47:03.293  - warn: sonoff.0 (14161) State "sonoff.0.DVES_F0B185.alive" has no existing object, this might lead to an error in future versions
                  Pending Updates: 20
                  @Walter-White
                  Walter White
                  2023-10-06 16:31:00.812  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
                  2023-10-06 16:35:00.067  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 331961
                  2023-10-06 16:35:03.049  - info: netatmo-crawler.0 (331961) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:35:03.141  - info: netatmo-crawler.0 (331961) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 16:35:04.121  - info: host.DietPi instance system.adapter.dwd.0 started with pid 331982
                  2023-10-06 16:35:04.527  - info: netatmo-crawler.0 (331961) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 16:35:04.821  - info: netatmo-crawler.0 (331961) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 16:35:05.368  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:35:07.226  - info: dwd.0 (331982) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:35:07.915  - info: dwd.0 (331982) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 16:35:08.471  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:37:40.382  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 16:37:45.511  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 16:40:00.101  - info: host.DietPi instance system.adapter.dwd.0 started with pid 332541
                  2023-10-06 16:40:02.909  - info: dwd.0 (332541) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:40:03.802  - info: dwd.0 (332541) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 16:40:04.183  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 332572
                  2023-10-06 16:40:04.346  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:40:07.160  - info: netatmo-crawler.0 (332572) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:40:07.245  - info: netatmo-crawler.0 (332572) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 16:40:10.449  - info: netatmo-crawler.0 (332572) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 16:40:10.857  - info: netatmo-crawler.0 (332572) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 16:40:11.468  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:40:57.044  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 javascript
                  2023-10-06 16:40:57.082  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
                  2023-10-06 16:45:00.085  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 333668
                  2023-10-06 16:45:03.058  - info: netatmo-crawler.0 (333668) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:45:03.156  - info: netatmo-crawler.0 (333668) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 16:45:04.158  - info: host.DietPi instance system.adapter.dwd.0 started with pid 333703
                  2023-10-06 16:45:04.673  - info: netatmo-crawler.0 (333668) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 16:45:04.980  - info: netatmo-crawler.0 (333668) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 16:45:05.527  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:45:07.178  - info: dwd.0 (333703) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:45:07.775  - info: dwd.0 (333703) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 16:45:08.360  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:46:56.790  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.30
                  2023-10-06 16:48:05.054  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.30 admin
                  2023-10-06 16:50:00.127  - info: host.DietPi instance system.adapter.dwd.0 started with pid 334816
                  2023-10-06 16:50:02.920  - info: dwd.0 (334816) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:50:03.846  - info: dwd.0 (334816) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 16:50:04.212  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 334842
                  2023-10-06 16:50:04.392  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:50:07.162  - info: netatmo-crawler.0 (334842) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:50:07.251  - info: netatmo-crawler.0 (334842) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 16:50:08.904  - info: netatmo-crawler.0 (334842) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 16:50:09.401  - info: netatmo-crawler.0 (334842) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 16:50:10.014  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:55:00.126  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 335911
                  2023-10-06 16:55:03.040  - info: netatmo-crawler.0 (335911) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:55:03.129  - info: netatmo-crawler.0 (335911) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 16:55:04.206  - info: host.DietPi instance system.adapter.dwd.0 started with pid 335941
                  2023-10-06 16:55:04.562  - info: netatmo-crawler.0 (335911) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 16:55:04.870  - info: netatmo-crawler.0 (335911) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 16:55:05.430  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:55:07.322  - info: dwd.0 (335941) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:55:07.916  - info: dwd.0 (335941) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 16:55:08.498  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:00:00.134  - info: host.DietPi instance system.adapter.dwd.0 started with pid 337059
                  2023-10-06 17:00:03.107  - info: dwd.0 (337059) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:00:04.204  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 337092
                  2023-10-06 17:00:04.357  - info: dwd.0 (337059) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:00:04.900  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:00:07.222  - info: netatmo-crawler.0 (337092) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:00:07.314  - info: netatmo-crawler.0 (337092) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:00:08.280  - info: host.DietPi instance system.adapter.ical.0 started with pid 337113
                  2023-10-06 17:00:09.055  - info: netatmo-crawler.0 (337092) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:00:09.418  - info: netatmo-crawler.0 (337092) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:00:09.960  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:00:11.422  - info: ical.0 (337113) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:00:12.329  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 337149
                  2023-10-06 17:00:12.504  - info: ical.0 (337113) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                  2023-10-06 17:00:12.879  - info: ical.0 (337113) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                  2023-10-06 17:00:15.223  - info: luftdaten.0 (337149) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:00:18.036  - info: ical.0 (337113) Terminated (NO_ERROR): Without reason
                  2023-10-06 17:00:18.651  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 17:00:25.951  - info: luftdaten.0 (337149) Terminated (NO_ERROR): Without reason
                  2023-10-06 17:00:26.561  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 17:05:00.164  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 338161
                  2023-10-06 17:05:03.112  - info: netatmo-crawler.0 (338161) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:05:03.204  - info: netatmo-crawler.0 (338161) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:05:04.239  - info: host.DietPi instance system.adapter.dwd.0 started with pid 338202
                  2023-10-06 17:05:04.675  - info: netatmo-crawler.0 (338161) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:05:05.885  - info: netatmo-crawler.0 (338161) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:05:06.459  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:05:06.988  - info: dwd.0 (338202) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:05:07.601  - info: dwd.0 (338202) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:05:08.201  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:10:00.177  - info: host.DietPi instance system.adapter.dwd.0 started with pid 339305
                  2023-10-06 17:10:03.180  - info: dwd.0 (339305) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:10:04.118  - info: dwd.0 (339305) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:10:04.221  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 339338
                  2023-10-06 17:10:04.677  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:10:07.194  - info: netatmo-crawler.0 (339338) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:10:07.289  - info: netatmo-crawler.0 (339338) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:10:08.942  - info: netatmo-crawler.0 (339338) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:10:09.430  - info: netatmo-crawler.0 (339338) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:10:10.041  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:11:41.270  - info: alexa2.0 (2104) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                  2023-10-06 17:11:42.750  - info: alexa2.0 (2104) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-10-06 17:15:00.149  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 340539
                  2023-10-06 17:15:03.103  - info: netatmo-crawler.0 (340539) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:15:03.196  - info: netatmo-crawler.0 (340539) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:15:03.805  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.30
                  2023-10-06 17:15:04.288  - info: host.DietPi instance system.adapter.dwd.0 started with pid 340563
                  2023-10-06 17:15:05.814  - info: netatmo-crawler.0 (340539) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:15:06.272  - info: netatmo-crawler.0 (340539) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:15:07.066  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:15:08.103  - info: dwd.0 (340563) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:15:08.696  - info: dwd.0 (340563) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:15:09.270  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:16:10.757  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.30
                  2023-10-06 17:18:14.891  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.30 admin
                  2023-10-06 17:18:14.899  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.30 javascript
                  2023-10-06 17:20:00.166  - info: host.DietPi instance system.adapter.dwd.0 started with pid 341660
                  2023-10-06 17:20:03.125  - info: dwd.0 (341660) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:20:04.231  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 341683
                  2023-10-06 17:20:04.351  - info: dwd.0 (341660) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:20:04.908  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:20:07.550  - info: netatmo-crawler.0 (341683) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:20:07.643  - info: netatmo-crawler.0 (341683) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:20:09.231  - info: netatmo-crawler.0 (341683) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:20:09.627  - info: netatmo-crawler.0 (341683) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:20:10.235  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:25:00.146  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 342787
                  2023-10-06 17:25:03.060  - info: netatmo-crawler.0 (342787) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:25:03.158  - info: netatmo-crawler.0 (342787) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:25:04.214  - info: host.DietPi instance system.adapter.dwd.0 started with pid 342814
                  2023-10-06 17:25:04.659  - info: netatmo-crawler.0 (342787) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:25:04.936  - info: netatmo-crawler.0 (342787) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:25:04.968  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.30
                  2023-10-06 17:25:06.434  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:25:07.795  - info: dwd.0 (342814) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:25:08.575  - info: dwd.0 (342814) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:25:08.936  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.30 admin
                  2023-10-06 17:25:09.141  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:30:00.152  - info: host.DietPi instance system.adapter.dwd.0 started with pid 344009
                  2023-10-06 17:30:02.995  - info: dwd.0 (344009) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:30:04.232  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 344048
                  2023-10-06 17:30:05.375  - info: dwd.0 (344009) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:30:05.922  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:30:07.396  - info: netatmo-crawler.0 (344048) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:30:07.497  - info: netatmo-crawler.0 (344048) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:30:08.287  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 344086
                  2023-10-06 17:30:09.302  - info: netatmo-crawler.0 (344048) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:30:09.690  - info: netatmo-crawler.0 (344048) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:30:10.254  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:30:11.411  - info: luftdaten.0 (344086) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:30:12.368  - info: host.DietPi instance system.adapter.ical.0 started with pid 344116
                  2023-10-06 17:30:15.290  - info: ical.0 (344116) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:30:16.345  - info: ical.0 (344116) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                  2023-10-06 17:30:16.612  - info: ical.0 (344116) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                  2023-10-06 17:30:21.730  - info: ical.0 (344116) Terminated (NO_ERROR): Without reason
                  2023-10-06 17:30:22.160  - info: luftdaten.0 (344086) Terminated (NO_ERROR): Without reason
                  2023-10-06 17:30:22.321  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 17:30:22.746  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 17:35:00.130  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 345159
                  2023-10-06 17:35:03.107  - info: netatmo-crawler.0 (345159) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:35:03.198  - info: netatmo-crawler.0 (345159) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:35:04.201  - info: host.DietPi instance system.adapter.dwd.0 started with pid 345201
                  2023-10-06 17:35:04.635  - info: netatmo-crawler.0 (345159) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:35:04.929  - info: netatmo-crawler.0 (345159) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:35:05.473  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:35:07.052  - info: dwd.0 (345201) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:35:07.680  - info: dwd.0 (345201) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:35:08.300  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:40:00.127  - info: host.DietPi instance system.adapter.dwd.0 started with pid 346269
                  2023-10-06 17:40:02.873  - info: dwd.0 (346269) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:40:03.912  - info: dwd.0 (346269) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:40:04.183  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 346300
                  2023-10-06 17:40:04.467  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:40:07.245  - info: netatmo-crawler.0 (346300) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:40:07.339  - info: netatmo-crawler.0 (346300) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:40:08.908  - info: netatmo-crawler.0 (346300) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:40:09.223  - info: netatmo-crawler.0 (346300) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:40:09.805  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:44:46.788  - info: fb-checkpresence.0 (2189) newActive LeonHandy false
                  2023-10-06 17:45:00.070  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 347471
                  2023-10-06 17:45:03.004  - info: netatmo-crawler.0 (347471) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:45:03.094  - info: netatmo-crawler.0 (347471) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:45:04.120  - info: host.DietPi instance system.adapter.dwd.0 started with pid 347503
                  2023-10-06 17:45:04.493  - info: netatmo-crawler.0 (347471) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:45:04.828  - info: netatmo-crawler.0 (347471) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:45:05.419  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:45:06.974  - info: dwd.0 (347503) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:45:07.562  - info: dwd.0 (347503) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:45:08.137  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:50:00.113  - info: host.DietPi instance system.adapter.dwd.0 started with pid 348524
                  2023-10-06 17:50:03.085  - info: dwd.0 (348524) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:50:04.199  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 348556
                  2023-10-06 17:50:05.255  - info: dwd.0 (348524) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:50:05.807  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:50:07.266  - info: netatmo-crawler.0 (348556) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:50:07.375  - info: netatmo-crawler.0 (348556) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:50:08.860  - info: netatmo-crawler.0 (348556) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:50:09.499  - info: netatmo-crawler.0 (348556) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:50:10.102  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:55:00.110  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 349604
                  2023-10-06 17:55:03.205  - info: netatmo-crawler.0 (349604) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:55:03.292  - info: netatmo-crawler.0 (349604) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 17:55:04.203  - info: host.DietPi instance system.adapter.dwd.0 started with pid 349639
                  2023-10-06 17:55:04.859  - info: netatmo-crawler.0 (349604) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 17:55:05.222  - info: netatmo-crawler.0 (349604) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 17:55:05.765  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 17:55:07.144  - info: dwd.0 (349639) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 17:55:07.850  - info: dwd.0 (349639) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 17:55:08.483  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:00:00.135  - info: host.DietPi instance system.adapter.dwd.0 started with pid 350775
                  2023-10-06 18:00:02.901  - info: dwd.0 (350775) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:00:04.091  - info: dwd.0 (350775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:00:04.192  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 350818
                  2023-10-06 18:00:04.647  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:00:07.125  - info: netatmo-crawler.0 (350818) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:00:07.238  - info: netatmo-crawler.0 (350818) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:00:08.257  - info: host.DietPi instance system.adapter.ical.0 started with pid 350839
                  2023-10-06 18:00:08.714  - info: netatmo-crawler.0 (350818) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:00:09.026  - info: netatmo-crawler.0 (350818) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:00:09.585  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:00:11.578  - info: ical.0 (350839) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:00:12.330  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 350861
                  2023-10-06 18:00:12.614  - info: ical.0 (350839) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                  2023-10-06 18:00:12.945  - info: ical.0 (350839) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                  2023-10-06 18:00:15.286  - info: luftdaten.0 (350861) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:00:18.110  - info: ical.0 (350839) Terminated (NO_ERROR): Without reason
                  2023-10-06 18:00:18.708  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 18:00:25.975  - info: luftdaten.0 (350861) Terminated (NO_ERROR): Without reason
                  2023-10-06 18:00:26.548  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 18:05:00.067  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 351928
                  2023-10-06 18:05:03.186  - info: netatmo-crawler.0 (351928) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:05:03.271  - info: netatmo-crawler.0 (351928) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:05:04.150  - info: host.DietPi instance system.adapter.dwd.0 started with pid 351960
                  2023-10-06 18:05:04.626  - info: netatmo-crawler.0 (351928) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:05:04.897  - info: netatmo-crawler.0 (351928) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:05:05.473  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:05:07.006  - info: dwd.0 (351960) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:05:07.614  - info: dwd.0 (351960) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:05:08.228  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:10:00.150  - info: host.DietPi instance system.adapter.dwd.0 started with pid 353087
                  2023-10-06 18:10:02.880  - info: dwd.0 (353087) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:10:03.892  - info: dwd.0 (353087) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:10:04.245  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 353117
                  2023-10-06 18:10:04.454  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:10:07.215  - info: netatmo-crawler.0 (353117) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:10:07.325  - info: netatmo-crawler.0 (353117) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:10:08.846  - info: netatmo-crawler.0 (353117) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:10:09.443  - info: netatmo-crawler.0 (353117) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:10:10.076  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:15:00.110  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 354191
                  2023-10-06 18:15:03.210  - info: netatmo-crawler.0 (354191) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:15:03.303  - info: netatmo-crawler.0 (354191) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:15:04.177  - info: host.DietPi instance system.adapter.dwd.0 started with pid 354220
                  2023-10-06 18:15:05.264  - info: netatmo-crawler.0 (354191) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:15:05.614  - info: netatmo-crawler.0 (354191) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:15:06.182  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:15:07.334  - info: dwd.0 (354220) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:15:07.934  - info: dwd.0 (354220) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:15:08.527  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:20:00.180  - info: host.DietPi instance system.adapter.dwd.0 started with pid 355314
                  2023-10-06 18:20:02.931  - info: dwd.0 (355314) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:20:03.859  - info: dwd.0 (355314) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:20:04.242  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 355351
                  2023-10-06 18:20:04.407  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:20:07.144  - info: netatmo-crawler.0 (355351) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:20:07.246  - info: netatmo-crawler.0 (355351) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:20:09.496  - info: netatmo-crawler.0 (355351) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:20:09.956  - info: netatmo-crawler.0 (355351) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:20:10.593  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:25:00.138  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 356390
                  2023-10-06 18:25:03.148  - info: netatmo-crawler.0 (356390) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:25:03.242  - info: netatmo-crawler.0 (356390) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:25:04.187  - info: host.DietPi instance system.adapter.dwd.0 started with pid 356423
                  2023-10-06 18:25:05.139  - info: netatmo-crawler.0 (356390) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:25:05.425  - info: netatmo-crawler.0 (356390) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:25:05.982  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:25:07.135  - info: dwd.0 (356423) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:25:07.783  - info: dwd.0 (356423) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:25:08.337  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:30:00.175  - info: host.DietPi instance system.adapter.dwd.0 started with pid 357464
                  2023-10-06 18:30:02.952  - info: dwd.0 (357464) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:30:03.956  - info: dwd.0 (357464) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:30:04.255  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 357486
                  2023-10-06 18:30:04.516  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:30:07.210  - info: netatmo-crawler.0 (357486) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:30:07.396  - info: netatmo-crawler.0 (357486) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:30:08.330  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 357516
                  2023-10-06 18:30:08.901  - info: netatmo-crawler.0 (357486) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:30:09.227  - info: netatmo-crawler.0 (357486) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:30:09.774  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:30:11.081  - info: luftdaten.0 (357516) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:30:12.412  - info: host.DietPi instance system.adapter.ical.0 started with pid 357537
                  2023-10-06 18:30:15.496  - info: ical.0 (357537) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:30:16.688  - info: ical.0 (357537) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                  2023-10-06 18:30:16.759  - info: luftdaten.0 (357516) Terminated (NO_ERROR): Without reason
                  2023-10-06 18:30:16.988  - info: ical.0 (357537) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                  2023-10-06 18:30:17.345  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 18:30:22.098  - info: ical.0 (357537) Terminated (NO_ERROR): Without reason
                  2023-10-06 18:30:22.694  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 18:35:00.151  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 358607
                  2023-10-06 18:35:03.168  - info: netatmo-crawler.0 (358607) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:35:03.263  - info: netatmo-crawler.0 (358607) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:35:04.223  - info: host.DietPi instance system.adapter.dwd.0 started with pid 358639
                  2023-10-06 18:35:04.706  - info: netatmo-crawler.0 (358607) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:35:04.992  - info: netatmo-crawler.0 (358607) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:35:05.598  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:35:07.257  - info: dwd.0 (358639) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:35:07.842  - info: dwd.0 (358639) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:35:08.427  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:36:58.676  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:37:33.783  - info: host.DietPi iobroker add tuya --host DietPi
                  2023-10-06 18:37:37.926  - info: host.DietPi iobroker NPM version: 9.6.7
                  2023-10-06 18:37:37.936  - info: host.DietPi iobroker Installing iobroker.tuya@3.14.2... (System call)
                  2023-10-06 18:37:54.619  - info: host.DietPi iobroker added 71 packages in 16s126 packages are looking for funding  run `npm fund` for details
                  2023-10-06 18:37:54.731  - info: host.DietPi iobroker host.DietPi install adapter tuya
                  2023-10-06 18:37:54.957  - info: host.DietPi iobroker upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                  2023-10-06 18:37:54.997  - info: host.DietPi iobroker upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                  2023-10-06 18:37:55.015  - info: host.DietPi iobroker upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                  2023-10-06 18:37:55.032  - info: host.DietPi iobroker upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                  2023-10-06 18:37:55.211  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya created/updated
                  2023-10-06 18:37:55.364  - info: host.DietPi iobroker host.DietPi create instance tuya
                  2023-10-06 18:37:55.378  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.alive created
                  2023-10-06 18:37:55.389  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.connected created
                  2023-10-06 18:37:55.402  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.compactMode created
                  2023-10-06 18:37:55.416  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.cpu created
                  2023-10-06 18:37:55.431  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.cputime created
                  2023-10-06 18:37:55.445  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.memHeapUsed created
                  2023-10-06 18:37:55.457  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.memHeapTotal created
                  2023-10-06 18:37:55.469  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.memRss created
                  2023-10-06 18:37:55.479  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.uptime created
                  2023-10-06 18:37:55.490  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.inputCount created
                  2023-10-06 18:37:55.500  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.outputCount created
                  2023-10-06 18:37:55.510  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.eventLoopLag created
                  2023-10-06 18:37:55.540  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.sigKill created
                  2023-10-06 18:37:55.550  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.logLevel created
                  2023-10-06 18:37:55.559  - info: host.DietPi iobroker host.DietPi object tuya.0.info created
                  2023-10-06 18:37:55.568  - info: host.DietPi iobroker host.DietPi object tuya.0.info.connection created
                  2023-10-06 18:37:55.578  - info: host.DietPi iobroker host.DietPi Set default value of tuya.0.info.connection: false
                  2023-10-06 18:37:55.589  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0 created
                  2023-10-06 18:37:56.641  - info: host.DietPi iobroker exit 0
                  2023-10-06 18:37:59.861  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:38:03.256  - info: host.DietPi instance system.adapter.tuya.0 started with pid 359339
                  2023-10-06 18:38:06.389  - info: tuya.0 (359339) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:38:06.446  - info: tuya.0 (359339) http-mitm-proxy/lib/ca.js patched to only generate 1 year long certificates
                  2023-10-06 18:38:06.699  - info: tuya.0 (359339) Existing devices initialized
                  2023-10-06 18:38:06.708  - info: tuya.0 (359339) Listen for local Tuya devices on port 6666
                  2023-10-06 18:38:06.710  - info: tuya.0 (359339) Listen for encrypted local Tuya devices on port 6667
                  2023-10-06 18:38:11.746  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:38:23.908  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:39:32.701  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                  2023-10-06 18:39:32.717  - info: tuya.0 (359339) Got terminate signal TERMINATE_YOURSELF
                  2023-10-06 18:39:32.825  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                  2023-10-06 18:39:33.576  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:39:35.727  - info: tuya.0 (359339) terminating
                  2023-10-06 18:39:35.733  - info: tuya.0 (359339) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:39:36.419  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:39:40.442  - info: host.DietPi instance system.adapter.tuya.0 started with pid 359860
                  2023-10-06 18:39:43.529  - info: tuya.0 (359860) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:39:43.823  - info: tuya.0 (359860) Existing devices initialized
                  2023-10-06 18:39:43.833  - info: tuya.0 (359860) Listen for local Tuya devices on port 6666
                  2023-10-06 18:39:43.835  - info: tuya.0 (359860) Listen for encrypted local Tuya devices on port 6667
                  2023-10-06 18:40:00.157  - info: host.DietPi instance system.adapter.dwd.0 started with pid 359946
                  2023-10-06 18:40:02.939  - info: dwd.0 (359946) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:40:03.919  - info: dwd.0 (359946) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:40:04.240  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 359978
                  2023-10-06 18:40:04.474  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:40:07.173  - info: netatmo-crawler.0 (359978) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:40:07.276  - info: netatmo-crawler.0 (359978) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:40:08.946  - info: netatmo-crawler.0 (359978) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:40:09.392  - info: netatmo-crawler.0 (359978) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:40:09.984  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:43:01.805  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:43:07.371  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 javascript
                  2023-10-06 18:43:17.398  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:43:56.162  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 javascript
                  2023-10-06 18:44:31.738  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:44:37.582  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                  2023-10-06 18:44:37.594  - info: tuya.0 (359860) Got terminate signal TERMINATE_YOURSELF
                  2023-10-06 18:44:37.699  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                  2023-10-06 18:44:38.218  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:44:40.602  - info: tuya.0 (359860) terminating
                  2023-10-06 18:44:40.608  - info: tuya.0 (359860) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:44:41.330  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:44:45.456  - info: host.DietPi instance system.adapter.tuya.0 started with pid 361032
                  2023-10-06 18:44:48.602  - info: tuya.0 (361032) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:44:48.923  - info: tuya.0 (361032) Existing devices initialized
                  2023-10-06 18:44:48.933  - info: tuya.0 (361032) Listen for local Tuya devices on port 6666
                  2023-10-06 18:44:48.935  - info: tuya.0 (361032) Listen for encrypted local Tuya devices on port 6667
                  2023-10-06 18:45:00.123  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 361086
                  2023-10-06 18:45:03.121  - info: netatmo-crawler.0 (361086) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:45:03.220  - info: netatmo-crawler.0 (361086) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:45:04.193  - info: host.DietPi instance system.adapter.dwd.0 started with pid 361121
                  2023-10-06 18:45:04.818  - info: netatmo-crawler.0 (361086) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:45:05.201  - info: netatmo-crawler.0 (361086) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:45:06.448  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:45:08.028  - info: dwd.0 (361121) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:45:08.676  - info: dwd.0 (361121) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:45:09.288  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:45:23.928  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:45:55.858  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                  2023-10-06 18:45:55.877  - info: tuya.0 (361032) Got terminate signal TERMINATE_YOURSELF
                  2023-10-06 18:45:55.971  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                  2023-10-06 18:45:56.530  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:45:58.889  - info: tuya.0 (361032) terminating
                  2023-10-06 18:45:58.896  - info: tuya.0 (361032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:45:59.570  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:46:03.669  - info: host.DietPi instance system.adapter.tuya.0 started with pid 361344
                  2023-10-06 18:46:06.722  - info: tuya.0 (361344) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:46:07.082  - info: tuya.0 (361344) Existing devices initialized
                  2023-10-06 18:46:07.091  - info: tuya.0 (361344) Try to sync devices from Cloud using stored cloud credentials
                  2023-10-06 18:46:07.361  - info: tuya.0 (361344) Listen for local Tuya devices on port 6666
                  2023-10-06 18:46:07.363  - info: tuya.0 (361344) Listen for encrypted local Tuya devices on port 6667
                  2023-10-06 18:46:20.831  - info: tuya.0 (361344) Cloud login successful. Adapter restarts in 5s
                  2023-10-06 18:46:20.833  - info: tuya.0 (361344) Set data for tuya.0 to appDeviceId=wzkivi8rptp424gf6y2wvb9maby7ywkzy7he5bjun6n9 / sid=eu150169S7985241JDzUvul30bb4fe8ec5d81b5dbe49d23cf5aa0c99. Restart adapter now!
                  2023-10-06 18:46:20.849  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                  2023-10-06 18:46:20.858  - info: tuya.0 (361344) Got terminate signal TERMINATE_YOURSELF
                  2023-10-06 18:46:20.933  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                  2023-10-06 18:46:23.865  - info: tuya.0 (361344) terminating
                  2023-10-06 18:46:23.872  - info: tuya.0 (361344) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:46:24.618  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:46:28.611  - info: host.DietPi instance system.adapter.tuya.0 started with pid 361441
                  2023-10-06 18:46:31.829  - info: tuya.0 (361441) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:46:32.132  - info: tuya.0 (361441) Existing devices initialized
                  2023-10-06 18:46:32.138  - info: tuya.0 (361441) Try to sync devices from Cloud using stored cloud credentials
                  2023-10-06 18:46:32.393  - info: tuya.0 (361441) Listen for local Tuya devices on port 6666
                  2023-10-06 18:46:32.395  - info: tuya.0 (361441) Listen for encrypted local Tuya devices on port 6667
                  2023-10-06 18:46:33.274  - info: tuya.0 (361441) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
                  2023-10-06 18:46:33.814  - info: tuya.0 (361441) 06200292dc4f22305b8d: Connect locally to device
                  2023-10-06 18:46:35.700  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:46:39.930  - info: tuya.0 (361441) Try to sync devices from Cloud using cloud credentials from Admin
                  2023-10-06 18:46:59.647  - info: tuya.0 (361441) 06200292dc4f22305b8d: Connect locally to device
                  2023-10-06 18:47:10.678  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:49:03.973  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 18:50:00.065  - info: host.DietPi instance system.adapter.dwd.0 started with pid 362214
                  2023-10-06 18:50:05.578  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 362246
                  2023-10-06 18:50:06.732  - info: dwd.0 (362214) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:50:07.335  - info: dwd.0 (362214) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:50:07.968  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:50:08.836  - info: netatmo-crawler.0 (362246) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:50:08.936  - info: netatmo-crawler.0 (362246) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:50:10.594  - info: netatmo-crawler.0 (362246) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:50:11.060  - info: netatmo-crawler.0 (362246) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:50:11.617  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:50:33.606  - info: javascript.0 (1751) Stop script script.js.Eigene.LichtAbwesenheit
                  2023-10-06 18:50:33.726  - info: javascript.0 (1751) Start javascript script.js.Eigene.LichtAbwesenheit
                  2023-10-06 18:50:33.773  - info: javascript.0 (1751) script.js.Eigene.LichtAbwesenheit: registered 8 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-10-06 18:50:41.351  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 javascript
                  2023-10-06 18:55:00.133  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 363400
                  2023-10-06 18:55:03.176  - info: netatmo-crawler.0 (363400) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:55:03.278  - info: netatmo-crawler.0 (363400) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 18:55:04.203  - info: host.DietPi instance system.adapter.dwd.0 started with pid 363423
                  2023-10-06 18:55:04.712  - info: netatmo-crawler.0 (363400) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 18:55:04.999  - info: netatmo-crawler.0 (363400) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 18:55:05.544  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 18:55:07.117  - info: dwd.0 (363423) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 18:55:07.685  - info: dwd.0 (363423) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 18:55:08.281  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:00:00.216  - info: host.DietPi instance system.adapter.dwd.0 started with pid 364561
                  2023-10-06 19:00:03.236  - info: dwd.0 (364561) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:00:04.259  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 364589
                  2023-10-06 19:00:04.415  - info: dwd.0 (364561) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:00:04.973  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:00:07.539  - info: netatmo-crawler.0 (364589) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:00:07.641  - info: netatmo-crawler.0 (364589) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:00:08.326  - info: host.DietPi instance system.adapter.ical.0 started with pid 364614
                  2023-10-06 19:00:09.449  - info: netatmo-crawler.0 (364589) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:00:09.991  - info: netatmo-crawler.0 (364589) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:00:10.570  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:00:11.630  - info: ical.0 (364614) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:00:12.405  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 364642
                  2023-10-06 19:00:12.703  - info: ical.0 (364614) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                  2023-10-06 19:00:13.034  - info: ical.0 (364614) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                  2023-10-06 19:00:15.187  - info: luftdaten.0 (364642) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:00:18.174  - info: ical.0 (364614) Terminated (NO_ERROR): Without reason
                  2023-10-06 19:00:18.784  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 19:00:25.911  - info: luftdaten.0 (364642) Terminated (NO_ERROR): Without reason
                  2023-10-06 19:00:26.495  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 19:04:16.039  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 admin
                  2023-10-06 19:05:00.088  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 365719
                  2023-10-06 19:05:03.086  - info: netatmo-crawler.0 (365719) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:05:03.195  - info: netatmo-crawler.0 (365719) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:05:04.167  - info: host.DietPi instance system.adapter.dwd.0 started with pid 365753
                  2023-10-06 19:05:04.629  - info: netatmo-crawler.0 (365719) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:05:04.912  - info: netatmo-crawler.0 (365719) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:05:05.457  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:05:07.078  - info: dwd.0 (365753) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:05:07.687  - info: dwd.0 (365753) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:05:08.294  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:06:28.124  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 19:10:00.063  - info: host.DietPi instance system.adapter.dwd.0 started with pid 367130
                  2023-10-06 19:10:03.258  - info: dwd.0 (367130) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:10:04.113  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 367179
                  2023-10-06 19:10:04.167  - info: dwd.0 (367130) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:10:04.722  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:10:07.435  - info: netatmo-crawler.0 (367179) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:10:07.564  - info: netatmo-crawler.0 (367179) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:10:09.340  - info: netatmo-crawler.0 (367179) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:10:09.711  - info: netatmo-crawler.0 (367179) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:10:10.259  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:15:00.116  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 370892
                  2023-10-06 19:15:03.665  - info: netatmo-crawler.0 (370892) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:15:03.775  - info: netatmo-crawler.0 (370892) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:15:04.194  - info: host.DietPi instance system.adapter.dwd.0 started with pid 370940
                  2023-10-06 19:15:05.280  - info: netatmo-crawler.0 (370892) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:15:05.662  - info: netatmo-crawler.0 (370892) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:15:06.296  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:15:07.484  - info: dwd.0 (370940) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:15:08.093  - info: dwd.0 (370940) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:15:08.709  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:18:42.051  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 admin
                  2023-10-06 19:18:43.334  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 19:19:03.335  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 admin
                  2023-10-06 19:19:31.432  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 19:20:00.082  - info: host.DietPi instance system.adapter.dwd.0 started with pid 371582
                  2023-10-06 19:20:03.277  - info: dwd.0 (371582) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:20:04.128  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 371611
                  2023-10-06 19:20:04.316  - info: dwd.0 (371582) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:20:04.923  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:20:08.008  - info: netatmo-crawler.0 (371611) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:20:08.117  - info: netatmo-crawler.0 (371611) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:20:10.486  - info: netatmo-crawler.0 (371611) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:20:10.986  - info: netatmo-crawler.0 (371611) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:20:11.613  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:20:53.539  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 19:23:27.698  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 javascript
                  2023-10-06 19:23:51.001  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 19:25:00.064  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 372041
                  2023-10-06 19:25:03.416  - info: netatmo-crawler.0 (372041) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:25:03.518  - info: netatmo-crawler.0 (372041) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:25:04.107  - info: host.DietPi instance system.adapter.dwd.0 started with pid 372067
                  2023-10-06 19:25:04.779  - info: netatmo-crawler.0 (372041) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:25:05.051  - info: netatmo-crawler.0 (372041) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:25:05.613  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:25:07.842  - info: dwd.0 (372067) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:25:08.406  - info: dwd.0 (372067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:25:08.951  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:25:40.225  - info: javascript.0 (1751) Stop script script.js.Eigene.Luftfeuchtigkeit
                  2023-10-06 19:25:40.430  - info: javascript.0 (1751) Start javascript script.js.Eigene.Luftfeuchtigkeit
                  2023-10-06 19:25:40.515  - info: javascript.0 (1751) script.js.Eigene.Luftfeuchtigkeit: registered 12 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-10-06 19:27:28.780  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 javascript
                  2023-10-06 19:28:14.592  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 19:28:25.716  - error: backitup.0 (2086) [iobroker/influxDB] [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2023_10_06-19_28_25_backupiobroker"
                  2023-10-06 19:28:25.717  - error: backitup.0 (2086) [iobroker/influxDB] /bin/sh: 1: influxd: not found
                  2023-10-06 19:28:25.927  - error: backitup.0 (2086) [iobroker/mysql] [IGNORED] ****E****r****r****o****r****:**** ****C****o****m****m****a****n****d**** ****f****a****i****l****e****d****:**** ****m****y****s****q****l****d****u****m****p**** **** ****-****u**** **** ****-****p**** ****i****o****b****r****o****k****e****r**** ****-****h**** ****l****o****c****a****l****h****o****s****t**** ****-****P**** ****3****3****0****6**** ****>**** ****/****o****p****t****/****i****o****b****r****o****k****e****r****/****b****a****c****k****u****p****s****/****m****y****s****q****l****_****2****0****2****3****_****1****0****_****0****6****-****1****9****_****2****8****_****2****5****_****b****a****c****k****u****p****i****o****b****r****o****k****e****r****.****s****q****l****
                  2023-10-06 19:28:25.928  - error: backitup.0 (2086) [iobroker/mysql] ****m****y****s****q****l****d****u****m****p****:**** ****G****o****t**** ****e****r****r****o****r****:**** ****1****6****9****8****:**** ****"****A****c****c****e****s****s**** ****d****e****n****i****e****d**** ****f****o****r**** ****u****s****e****r**** ****'****-****p****'****@****'****l****o****c****a****l****h****o****s****t****'****"**** ****w****h****e****n**** ****t****r****y****i****n****g**** ****t****o**** ****c****o****n****n****e****c****t****
                  2023-10-06 19:28:26.099  - error: backitup.0 (2086) [iobroker/pgsql] [IGNORED] ****E****r****r****o****r****:**** ****C****o****m****m****a****n****d**** ****f****a****i****l****e****d****:**** ****p****g****_****d****u****m****p**** **** ****-****-****d****b****n****a****m****e****=****p****o****s****t****g****r****e****s****q****l****:****/****/****:****@****:****5****4****3****2****/**** ****>**** ****/****o****p****t****/****i****o****b****r****o****k****e****r****/****b****a****c****k****u****p****s****/****p****g****s****q****l****_****2****0****2****3****_****1****0****_****0****6****-****1****9****_****2****8****_****2****6****_****b****a****c****k****u****p****i****o****b****r****o****k****e****r****.****s****q****l****
                  2023-10-06 19:28:26.100  - error: backitup.0 (2086) [iobroker/pgsql] ****/****b****i****n****/****s****h****:**** ****1****:**** ****p****g****_****d****u****m****p****:**** ****n****o****t**** ****f****o****u****n****d****
                  2023-10-06 19:28:26.305  - error: backitup.0 (2086) [iobroker/sqlite] Error: Command failed: sqlite3 /opt/sqlite/data.db .dump > /opt/iobroker/backups/sqlite_2023_10_06-19_28_26_backupiobroker.sql
                  2023-10-06 19:28:26.309  - error: backitup.0 (2086) [iobroker/sqlite] /bin/sh: 1: sqlite3: not found
                  2023-10-06 19:28:26.309  - error: backitup.0 (2086) [iobroker/sqlite] [IGNORED] Error: Command failed: sqlite3 /opt/sqlite/data.db .dump > /opt/iobroker/backups/sqlite_2023_10_06-19_28_26_backupiobroker.sql
                  2023-10-06 19:28:26.310  - error: backitup.0 (2086) [iobroker/sqlite] /bin/sh: 1: sqlite3: not found
                  2023-10-06 19:28:28.236  - error: backitup.0 (2086) [iobroker/grafana] Grafana Backup cannot created. Please check your Configuration
                  2023-10-06 19:28:33.056  - error: backitup.0 (2086) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/influxDB_2023_10_06-19_28_25_backupiobroker.tar.gz" not found
                  2023-10-06 19:28:33.208  - error: backitup.0 (2086) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/mysql_2023_10_06-19_28_25_backupiobroker.tar.gz" not found
                  2023-10-06 19:28:33.359  - error: backitup.0 (2086) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/pgsql_2023_10_06-19_28_26_backupiobroker.tar.gz" not found
                  2023-10-06 19:28:33.510  - error: backitup.0 (2086) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/sqlite_2023_10_06-19_28_26_backupiobroker.tar.gz" not found
                  2023-10-06 19:28:41.381  - error: backitup.0 (2086) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                  2023-10-06 19:30:00.127  - info: host.DietPi instance system.adapter.dwd.0 started with pid 372674
                  2023-10-06 19:30:03.475  - info: dwd.0 (372674) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:30:04.168  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 372700
                  2023-10-06 19:30:04.739  - info: dwd.0 (372674) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:30:05.322  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:30:07.806  - info: netatmo-crawler.0 (372700) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:30:07.965  - info: netatmo-crawler.0 (372700) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:30:08.212  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 372729
                  2023-10-06 19:30:09.716  - info: netatmo-crawler.0 (372700) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:30:10.275  - info: netatmo-crawler.0 (372700) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:30:11.057  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:30:11.678  - info: luftdaten.0 (372729) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:30:12.263  - info: host.DietPi instance system.adapter.ical.0 started with pid 372746
                  2023-10-06 19:30:15.914  - info: ical.0 (372746) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:30:17.308  - info: ical.0 (372746) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                  2023-10-06 19:30:18.684  - info: ical.0 (372746) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                  2023-10-06 19:30:20.106  - info: luftdaten.0 (372729) Terminated (NO_ERROR): Without reason
                  2023-10-06 19:30:20.705  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 19:30:24.096  - info: ical.0 (372746) Terminated (NO_ERROR): Without reason
                  2023-10-06 19:30:24.656  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-10-06 19:34:47.436  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 19:34:47.465  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
                  2023-10-06 19:35:00.072  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 373669
                  2023-10-06 19:35:03.455  - info: netatmo-crawler.0 (373669) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:35:03.567  - info: netatmo-crawler.0 (373669) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:35:04.130  - info: host.DietPi instance system.adapter.dwd.0 started with pid 373687
                  2023-10-06 19:35:04.999  - info: netatmo-crawler.0 (373669) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:35:05.276  - info: netatmo-crawler.0 (373669) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:35:05.842  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:35:08.550  - info: dwd.0 (373687) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:35:09.144  - info: dwd.0 (373687) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:35:09.695  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:38:24.191  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                  2023-10-06 19:38:44.193  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 admin
                  2023-10-06 19:40:00.063  - info: host.DietPi instance system.adapter.dwd.0 started with pid 374757
                  2023-10-06 19:40:03.410  - info: dwd.0 (374757) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:40:04.113  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 374792
                  2023-10-06 19:40:04.238  - info: dwd.0 (374757) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:40:04.821  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:40:07.198  - info: netatmo-crawler.0 (374792) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:40:07.299  - info: netatmo-crawler.0 (374792) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:40:08.486  - info: netatmo-crawler.0 (374792) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:40:08.862  - info: netatmo-crawler.0 (374792) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:40:09.405  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:45:00.117  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 375933
                  2023-10-06 19:45:04.160  - info: host.DietPi instance system.adapter.dwd.0 started with pid 375984
                  2023-10-06 19:45:04.192  - info: netatmo-crawler.0 (375933) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:45:04.313  - info: netatmo-crawler.0 (375933) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:45:05.838  - info: netatmo-crawler.0 (375933) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:45:06.297  - info: netatmo-crawler.0 (375933) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:45:06.999  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:45:07.723  - info: dwd.0 (375984) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:45:08.275  - info: dwd.0 (375984) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:45:08.826  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:46:20.341  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 19:46:45.287  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                  2023-10-06 19:46:45.294  - info: tuya.0 (361441) Got terminate signal TERMINATE_YOURSELF
                  2023-10-06 19:46:45.381  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                  2023-10-06 19:46:48.299  - info: tuya.0 (361441) terminating
                  2023-10-06 19:46:48.302  - info: tuya.0 (361441) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:46:48.904  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:46:53.054  - info: host.DietPi instance system.adapter.tuya.0 started with pid 376247
                  2023-10-06 19:46:56.989  - info: tuya.0 (376247) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:46:57.595  - info: tuya.0 (376247) 06200292dc4f22305b8d: Connect locally to device
                  2023-10-06 19:46:57.607  - info: tuya.0 (376247) Existing devices initialized
                  2023-10-06 19:46:57.612  - info: tuya.0 (376247) Try to sync devices from Cloud using stored cloud credentials
                  2023-10-06 19:46:58.057  - info: tuya.0 (376247) Listen for local Tuya devices on port 6666
                  2023-10-06 19:46:58.058  - info: tuya.0 (376247) Listen for encrypted local Tuya devices on port 6667
                  2023-10-06 19:46:58.691  - info: tuya.0 (376247) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
                  2023-10-06 19:46:59.232  - info: tuya.0 (376247) 06200292dc4f22305b8d: Connect locally to device
                  2023-10-06 19:48:19.152  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                  2023-10-06 19:48:19.194  - info: tuya.0 (376247) Got terminate signal TERMINATE_YOURSELF
                  2023-10-06 19:48:19.393  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                  2023-10-06 19:48:22.199  - info: tuya.0 (376247) terminating
                  2023-10-06 19:48:22.201  - info: tuya.0 (376247) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:48:22.868  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:48:27.024  - info: host.DietPi instance system.adapter.tuya.0 started with pid 376416
                  2023-10-06 19:48:30.552  - info: tuya.0 (376416) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:48:31.237  - info: tuya.0 (376416) 06200292dc4f22305b8d: Connect locally to device
                  2023-10-06 19:48:31.241  - info: tuya.0 (376416) Existing devices initialized
                  2023-10-06 19:48:31.248  - info: tuya.0 (376416) Try to sync devices from Cloud using stored cloud credentials
                  2023-10-06 19:48:31.627  - info: tuya.0 (376416) Listen for local Tuya devices on port 6666
                  2023-10-06 19:48:31.628  - info: tuya.0 (376416) Listen for encrypted local Tuya devices on port 6667
                  2023-10-06 19:48:32.235  - info: tuya.0 (376416) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
                  2023-10-06 19:48:32.716  - info: tuya.0 (376416) 06200292dc4f22305b8d: Connect locally to device
                  2023-10-06 16:31:00.812  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
                  2023-10-06 16:35:00.067  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 331961
                  2023-10-06 16:35:03.049  - info: netatmo-crawler.0 (331961) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:35:03.141  - info: netatmo-crawler.0 (331961) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 16:35:04.121  - info: host.DietPi instance system.adapter.dwd.0 started with pid 331982
                  2023-10-06 16:35:04.527  - info: netatmo-crawler.0 (331961) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 16:35:04.821  - info: netatmo-crawler.0 (331961) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 16:35:05.368  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:35:07.226  - info: dwd.0 (331982) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:35:07.915  - info: dwd.0 (331982) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 16:35:08.471  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:37:40.382  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 16:37:45.511  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                  2023-10-06 16:40:00.101  - info: host.DietPi instance system.adapter.dwd.0 started with pid 332541
                  2023-10-06 16:40:02.909  - info: dwd.0 (332541) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:40:03.802  - info: dwd.0 (332541) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 16:40:04.183  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 332572
                  2023-10-06 16:40:04.346  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:40:07.160  - info: netatmo-crawler.0 (332572) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:40:07.245  - info: netatmo-crawler.0 (332572) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 16:40:10.449  - info: netatmo-crawler.0 (332572) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 16:40:10.857  - info: netatmo-crawler.0 (332572) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 16:40:11.468  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:40:57.044  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 javascript
                  2023-10-06 16:40:57.082  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
                  2023-10-06 16:45:00.085  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 333668
                  2023-10-06 16:45:03.058  - info: netatmo-crawler.0 (333668) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 16:45:03.156  - info: netatmo-crawler.0 (333668) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 16:45:04.158  - info: host.DietPi instance system.adapter.dwd.0 started with pid 333703
                  2023-10-06 16:45:04.673  - info: netatmo-crawler.0 (333668) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 16:45:04.980  - info: netatmo-crawler.0 (333668) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 16:45:05.527  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 16:45:07.178  - info: dwd.0 (333703) st2023-10-06 19:50:00.105  - info: host.DietPi instance system.adapter.dwd.0 started with pid 376567
                  2023-10-06 19:50:03.490  - info: dwd.0 (376567) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:50:04.145  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 376594
                  2023-10-06 19:50:04.604  - info: dwd.0 (376567) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-06 19:50:05.197  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-06 19:50:07.307  - info: netatmo-crawler.0 (376594) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                  2023-10-06 19:50:07.419  - info: netatmo-crawler.0 (376594) Getting data for stationid:70:ee:50:65:8b:78
                  2023-10-06 19:50:08.676  - info: netatmo-crawler.0 (376594) Getting data for stationid:70:ee:50:13:60:32
                  2023-10-06 19:50:08.960  - info: netatmo-crawler.0 (376594) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-10-06 19:50:09.511  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  • Walter WhiteW Walter White
                    2023-10-06 16:45:07.178  - info: dwd.0 (333703) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:45:07.775  - info: dwd.0 (333703) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 16:45:08.360  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 16:46:56.790  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.30
                    2023-10-06 16:48:05.054  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.30 admin
                    2023-10-06 16:50:00.127  - info: host.DietPi instance system.adapter.dwd.0 started with pid 334816
                    2023-10-06 16:50:02.920  - info: dwd.0 (334816) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:50:03.846  - info: dwd.0 (334816) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 16:50:04.212  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 334842
                    2023-10-06 16:50:04.392  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 16:50:07.162  - info: netatmo-crawler.0 (334842) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:50:07.251  - info: netatmo-crawler.0 (334842) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 16:50:08.904  - info: netatmo-crawler.0 (334842) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 16:50:09.401  - info: netatmo-crawler.0 (334842) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 16:50:10.014  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 16:55:00.126  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 335911
                    2023-10-06 16:55:03.040  - info: netatmo-crawler.0 (335911) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:55:03.129  - info: netatmo-crawler.0 (335911) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 16:55:04.206  - info: host.DietPi instance system.adapter.dwd.0 started with pid 335941
                    2023-10-06 16:55:04.562  - info: netatmo-crawler.0 (335911) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 16:55:04.870  - info: netatmo-crawler.0 (335911) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 16:55:05.430  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 16:55:07.322  - info: dwd.0 (335941) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:55:07.916  - info: dwd.0 (335941) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 16:55:08.498  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:00:00.134  - info: host.DietPi instance system.adapter.dwd.0 started with pid 337059
                    2023-10-06 17:00:03.107  - info: dwd.0 (337059) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:00:04.204  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 337092
                    2023-10-06 17:00:04.357  - info: dwd.0 (337059) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:00:04.900  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:00:07.222  - info: netatmo-crawler.0 (337092) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:00:07.314  - info: netatmo-crawler.0 (337092) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:00:08.280  - info: host.DietPi instance system.adapter.ical.0 started with pid 337113
                    2023-10-06 17:00:09.055  - info: netatmo-crawler.0 (337092) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:00:09.418  - info: netatmo-crawler.0 (337092) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:00:09.960  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:00:11.422  - info: ical.0 (337113) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:00:12.329  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 337149
                    2023-10-06 17:00:12.504  - info: ical.0 (337113) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                    2023-10-06 17:00:12.879  - info: ical.0 (337113) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                    2023-10-06 17:00:15.223  - info: luftdaten.0 (337149) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:00:18.036  - info: ical.0 (337113) Terminated (NO_ERROR): Without reason
                    2023-10-06 17:00:18.651  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 17:00:25.951  - info: luftdaten.0 (337149) Terminated (NO_ERROR): Without reason
                    2023-10-06 17:00:26.561  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 17:05:00.164  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 338161
                    2023-10-06 17:05:03.112  - info: netatmo-crawler.0 (338161) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:05:03.204  - info: netatmo-crawler.0 (338161) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:05:04.239  - info: host.DietPi instance system.adapter.dwd.0 started with pid 338202
                    2023-10-06 17:05:04.675  - info: netatmo-crawler.0 (338161) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:05:05.885  - info: netatmo-crawler.0 (338161) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:05:06.459  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:05:06.988  - info: dwd.0 (338202) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:05:07.601  - info: dwd.0 (338202) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:05:08.201  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:10:00.177  - info: host.DietPi instance system.adapter.dwd.0 started with pid 339305
                    2023-10-06 17:10:03.180  - info: dwd.0 (339305) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:10:04.118  - info: dwd.0 (339305) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:10:04.221  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 339338
                    2023-10-06 17:10:04.677  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:10:07.194  - info: netatmo-crawler.0 (339338) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:10:07.289  - info: netatmo-crawler.0 (339338) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:10:08.942  - info: netatmo-crawler.0 (339338) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:10:09.430  - info: netatmo-crawler.0 (339338) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:10:10.041  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:11:41.270  - info: alexa2.0 (2104) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                    2023-10-06 17:11:42.750  - info: alexa2.0 (2104) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2023-10-06 17:15:00.149  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 340539
                    2023-10-06 17:15:03.103  - info: netatmo-crawler.0 (340539) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:15:03.196  - info: netatmo-crawler.0 (340539) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:15:03.805  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.30
                    2023-10-06 17:15:04.288  - info: host.DietPi instance system.adapter.dwd.0 started with pid 340563
                    2023-10-06 17:15:05.814  - info: netatmo-crawler.0 (340539) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:15:06.272  - info: netatmo-crawler.0 (340539) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:15:07.066  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:15:08.103  - info: dwd.0 (340563) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:15:08.696  - info: dwd.0 (340563) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:15:09.270  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:16:10.757  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.30
                    2023-10-06 17:18:14.891  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.30 admin
                    2023-10-06 17:18:14.899  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.30 javascript
                    2023-10-06 17:20:00.166  - info: host.DietPi instance system.adapter.dwd.0 started with pid 341660
                    2023-10-06 17:20:03.125  - info: dwd.0 (341660) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:20:04.231  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 341683
                    2023-10-06 17:20:04.351  - info: dwd.0 (341660) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:20:04.908  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:20:07.550  - info: netatmo-crawler.0 (341683) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:20:07.643  - info: netatmo-crawler.0 (341683) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:20:09.231  - info: netatmo-crawler.0 (341683) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:20:09.627  - info: netatmo-crawler.0 (341683) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:20:10.235  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:25:00.146  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 342787
                    2023-10-06 17:25:03.060  - info: netatmo-crawler.0 (342787) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:25:03.158  - info: netatmo-crawler.0 (342787) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:25:04.214  - info: host.DietPi instance system.adapter.dwd.0 started with pid 342814
                    2023-10-06 17:25:04.659  - info: netatmo-crawler.0 (342787) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:25:04.936  - info: netatmo-crawler.0 (342787) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:25:04.968  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.30
                    2023-10-06 17:25:06.434  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:25:07.795  - info: dwd.0 (342814) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:25:08.575  - info: dwd.0 (342814) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:25:08.936  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.30 admin
                    2023-10-06 17:25:09.141  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:30:00.152  - info: host.DietPi instance system.adapter.dwd.0 started with pid 344009
                    2023-10-06 17:30:02.995  - info: dwd.0 (344009) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:30:04.232  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 344048
                    2023-10-06 17:30:05.375  - info: dwd.0 (344009) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:30:05.922  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:30:07.396  - info: netatmo-crawler.0 (344048) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:30:07.497  - info: netatmo-crawler.0 (344048) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:30:08.287  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 344086
                    2023-10-06 17:30:09.302  - info: netatmo-crawler.0 (344048) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:30:09.690  - info: netatmo-crawler.0 (344048) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:30:10.254  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:30:11.411  - info: luftdaten.0 (344086) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:30:12.368  - info: host.DietPi instance system.adapter.ical.0 started with pid 344116
                    2023-10-06 17:30:15.290  - info: ical.0 (344116) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:30:16.345  - info: ical.0 (344116) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                    2023-10-06 17:30:16.612  - info: ical.0 (344116) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                    2023-10-06 17:30:21.730  - info: ical.0 (344116) Terminated (NO_ERROR): Without reason
                    2023-10-06 17:30:22.160  - info: luftdaten.0 (344086) Terminated (NO_ERROR): Without reason
                    2023-10-06 17:30:22.321  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 17:30:22.746  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 17:35:00.130  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 345159
                    2023-10-06 17:35:03.107  - info: netatmo-crawler.0 (345159) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:35:03.198  - info: netatmo-crawler.0 (345159) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:35:04.201  - info: host.DietPi instance system.adapter.dwd.0 started with pid 345201
                    2023-10-06 17:35:04.635  - info: netatmo-crawler.0 (345159) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:35:04.929  - info: netatmo-crawler.0 (345159) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:35:05.473  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:35:07.052  - info: dwd.0 (345201) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:35:07.680  - info: dwd.0 (345201) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:35:08.300  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:40:00.127  - info: host.DietPi instance system.adapter.dwd.0 started with pid 346269
                    2023-10-06 17:40:02.873  - info: dwd.0 (346269) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:40:03.912  - info: dwd.0 (346269) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:40:04.183  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 346300
                    2023-10-06 17:40:04.467  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:40:07.245  - info: netatmo-crawler.0 (346300) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:40:07.339  - info: netatmo-crawler.0 (346300) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:40:08.908  - info: netatmo-crawler.0 (346300) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:40:09.223  - info: netatmo-crawler.0 (346300) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:40:09.805  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:44:46.788  - info: fb-checkpresence.0 (2189) newActive LeonHandy false
                    2023-10-06 17:45:00.070  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 347471
                    2023-10-06 17:45:03.004  - info: netatmo-crawler.0 (347471) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:45:03.094  - info: netatmo-crawler.0 (347471) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:45:04.120  - info: host.DietPi instance system.adapter.dwd.0 started with pid 347503
                    2023-10-06 17:45:04.493  - info: netatmo-crawler.0 (347471) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:45:04.828  - info: netatmo-crawler.0 (347471) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:45:05.419  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:45:06.974  - info: dwd.0 (347503) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:45:07.562  - info: dwd.0 (347503) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:45:08.137  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:50:00.113  - info: host.DietPi instance system.adapter.dwd.0 started with pid 348524
                    2023-10-06 17:50:03.085  - info: dwd.0 (348524) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:50:04.199  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 348556
                    2023-10-06 17:50:05.255  - info: dwd.0 (348524) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:50:05.807  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:50:07.266  - info: netatmo-crawler.0 (348556) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:50:07.375  - info: netatmo-crawler.0 (348556) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:50:08.860  - info: netatmo-crawler.0 (348556) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:50:09.499  - info: netatmo-crawler.0 (348556) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:50:10.102  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:55:00.110  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 349604
                    2023-10-06 17:55:03.205  - info: netatmo-crawler.0 (349604) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:55:03.292  - info: netatmo-crawler.0 (349604) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 17:55:04.203  - info: host.DietPi instance system.adapter.dwd.0 started with pid 349639
                    2023-10-06 17:55:04.859  - info: netatmo-crawler.0 (349604) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 17:55:05.222  - info: netatmo-crawler.0 (349604) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 17:55:05.765  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 17:55:07.144  - info: dwd.0 (349639) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 17:55:07.850  - info: dwd.0 (349639) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 17:55:08.483  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:00:00.135  - info: host.DietPi instance system.adapter.dwd.0 started with pid 350775
                    2023-10-06 18:00:02.901  - info: dwd.0 (350775) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:00:04.091  - info: dwd.0 (350775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:00:04.192  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 350818
                    2023-10-06 18:00:04.647  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:00:07.125  - info: netatmo-crawler.0 (350818) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:00:07.238  - info: netatmo-crawler.0 (350818) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:00:08.257  - info: host.DietPi instance system.adapter.ical.0 started with pid 350839
                    2023-10-06 18:00:08.714  - info: netatmo-crawler.0 (350818) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:00:09.026  - info: netatmo-crawler.0 (350818) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:00:09.585  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:00:11.578  - info: ical.0 (350839) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:00:12.330  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 350861
                    2023-10-06 18:00:12.614  - info: ical.0 (350839) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                    2023-10-06 18:00:12.945  - info: ical.0 (350839) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                    2023-10-06 18:00:15.286  - info: luftdaten.0 (350861) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:00:18.110  - info: ical.0 (350839) Terminated (NO_ERROR): Without reason
                    2023-10-06 18:00:18.708  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 18:00:25.975  - info: luftdaten.0 (350861) Terminated (NO_ERROR): Without reason
                    2023-10-06 18:00:26.548  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 18:05:00.067  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 351928
                    2023-10-06 18:05:03.186  - info: netatmo-crawler.0 (351928) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:05:03.271  - info: netatmo-crawler.0 (351928) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:05:04.150  - info: host.DietPi instance system.adapter.dwd.0 started with pid 351960
                    2023-10-06 18:05:04.626  - info: netatmo-crawler.0 (351928) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:05:04.897  - info: netatmo-crawler.0 (351928) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:05:05.473  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:05:07.006  - info: dwd.0 (351960) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:05:07.614  - info: dwd.0 (351960) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:05:08.228  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:10:00.150  - info: host.DietPi instance system.adapter.dwd.0 started with pid 353087
                    2023-10-06 18:10:02.880  - info: dwd.0 (353087) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:10:03.892  - info: dwd.0 (353087) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:10:04.245  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 353117
                    2023-10-06 18:10:04.454  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:10:07.215  - info: netatmo-crawler.0 (353117) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:10:07.325  - info: netatmo-crawler.0 (353117) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:10:08.846  - info: netatmo-crawler.0 (353117) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:10:09.443  - info: netatmo-crawler.0 (353117) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:10:10.076  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:15:00.110  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 354191
                    2023-10-06 18:15:03.210  - info: netatmo-crawler.0 (354191) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:15:03.303  - info: netatmo-crawler.0 (354191) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:15:04.177  - info: host.DietPi instance system.adapter.dwd.0 started with pid 354220
                    2023-10-06 18:15:05.264  - info: netatmo-crawler.0 (354191) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:15:05.614  - info: netatmo-crawler.0 (354191) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:15:06.182  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:15:07.334  - info: dwd.0 (354220) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:15:07.934  - info: dwd.0 (354220) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:15:08.527  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:20:00.180  - info: host.DietPi instance system.adapter.dwd.0 started with pid 355314
                    2023-10-06 18:20:02.931  - info: dwd.0 (355314) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:20:03.859  - info: dwd.0 (355314) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:20:04.242  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 355351
                    2023-10-06 18:20:04.407  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:20:07.144  - info: netatmo-crawler.0 (355351) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:20:07.246  - info: netatmo-crawler.0 (355351) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:20:09.496  - info: netatmo-crawler.0 (355351) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:20:09.956  - info: netatmo-crawler.0 (355351) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:20:10.593  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:25:00.138  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 356390
                    2023-10-06 18:25:03.148  - info: netatmo-crawler.0 (356390) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:25:03.242  - info: netatmo-crawler.0 (356390) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:25:04.187  - info: host.DietPi instance system.adapter.dwd.0 started with pid 356423
                    2023-10-06 18:25:05.139  - info: netatmo-crawler.0 (356390) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:25:05.425  - info: netatmo-crawler.0 (356390) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:25:05.982  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:25:07.135  - info: dwd.0 (356423) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:25:07.783  - info: dwd.0 (356423) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:25:08.337  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:30:00.175  - info: host.DietPi instance system.adapter.dwd.0 started with pid 357464
                    2023-10-06 18:30:02.952  - info: dwd.0 (357464) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:30:03.956  - info: dwd.0 (357464) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:30:04.255  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 357486
                    2023-10-06 18:30:04.516  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:30:07.210  - info: netatmo-crawler.0 (357486) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:30:07.396  - info: netatmo-crawler.0 (357486) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:30:08.330  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 357516
                    2023-10-06 18:30:08.901  - info: netatmo-crawler.0 (357486) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:30:09.227  - info: netatmo-crawler.0 (357486) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:30:09.774  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:30:11.081  - info: luftdaten.0 (357516) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:30:12.412  - info: host.DietPi instance system.adapter.ical.0 started with pid 357537
                    2023-10-06 18:30:15.496  - info: ical.0 (357537) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:30:16.688  - info: ical.0 (357537) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                    2023-10-06 18:30:16.759  - info: luftdaten.0 (357516) Terminated (NO_ERROR): Without reason
                    2023-10-06 18:30:16.988  - info: ical.0 (357537) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                    2023-10-06 18:30:17.345  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 18:30:22.098  - info: ical.0 (357537) Terminated (NO_ERROR): Without reason
                    2023-10-06 18:30:22.694  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 18:35:00.151  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 358607
                    2023-10-06 18:35:03.168  - info: netatmo-crawler.0 (358607) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:35:03.263  - info: netatmo-crawler.0 (358607) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:35:04.223  - info: host.DietPi instance system.adapter.dwd.0 started with pid 358639
                    2023-10-06 18:35:04.706  - info: netatmo-crawler.0 (358607) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:35:04.992  - info: netatmo-crawler.0 (358607) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:35:05.598  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:35:07.257  - info: dwd.0 (358639) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:35:07.842  - info: dwd.0 (358639) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:35:08.427  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:36:58.676  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:37:33.783  - info: host.DietPi iobroker add tuya --host DietPi
                    2023-10-06 18:37:37.926  - info: host.DietPi iobroker NPM version: 9.6.7
                    2023-10-06 18:37:37.936  - info: host.DietPi iobroker Installing iobroker.tuya@3.14.2... (System call)
                    2023-10-06 18:37:54.619  - info: host.DietPi iobroker added 71 packages in 16s126 packages are looking for funding  run `npm fund` for details
                    2023-10-06 18:37:54.731  - info: host.DietPi iobroker host.DietPi install adapter tuya
                    2023-10-06 18:37:54.957  - info: host.DietPi iobroker upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                    2023-10-06 18:37:54.997  - info: host.DietPi iobroker upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                    2023-10-06 18:37:55.015  - info: host.DietPi iobroker upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                    2023-10-06 18:37:55.032  - info: host.DietPi iobroker upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                    2023-10-06 18:37:55.211  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya created/updated
                    2023-10-06 18:37:55.364  - info: host.DietPi iobroker host.DietPi create instance tuya
                    2023-10-06 18:37:55.378  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.alive created
                    2023-10-06 18:37:55.389  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.connected created
                    2023-10-06 18:37:55.402  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.compactMode created
                    2023-10-06 18:37:55.416  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.cpu created
                    2023-10-06 18:37:55.431  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.cputime created
                    2023-10-06 18:37:55.445  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.memHeapUsed created
                    2023-10-06 18:37:55.457  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.memHeapTotal created
                    2023-10-06 18:37:55.469  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.memRss created
                    2023-10-06 18:37:55.479  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.uptime created
                    2023-10-06 18:37:55.490  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.inputCount created
                    2023-10-06 18:37:55.500  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.outputCount created
                    2023-10-06 18:37:55.510  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.eventLoopLag created
                    2023-10-06 18:37:55.540  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.sigKill created
                    2023-10-06 18:37:55.550  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0.logLevel created
                    2023-10-06 18:37:55.559  - info: host.DietPi iobroker host.DietPi object tuya.0.info created
                    2023-10-06 18:37:55.568  - info: host.DietPi iobroker host.DietPi object tuya.0.info.connection created
                    2023-10-06 18:37:55.578  - info: host.DietPi iobroker host.DietPi Set default value of tuya.0.info.connection: false
                    2023-10-06 18:37:55.589  - info: host.DietPi iobroker host.DietPi object system.adapter.tuya.0 created
                    2023-10-06 18:37:56.641  - info: host.DietPi iobroker exit 0
                    2023-10-06 18:37:59.861  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:38:03.256  - info: host.DietPi instance system.adapter.tuya.0 started with pid 359339
                    2023-10-06 18:38:06.389  - info: tuya.0 (359339) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:38:06.446  - info: tuya.0 (359339) http-mitm-proxy/lib/ca.js patched to only generate 1 year long certificates
                    2023-10-06 18:38:06.699  - info: tuya.0 (359339) Existing devices initialized
                    2023-10-06 18:38:06.708  - info: tuya.0 (359339) Listen for local Tuya devices on port 6666
                    2023-10-06 18:38:06.710  - info: tuya.0 (359339) Listen for encrypted local Tuya devices on port 6667
                    2023-10-06 18:38:11.746  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:38:23.908  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:39:32.701  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                    2023-10-06 18:39:32.717  - info: tuya.0 (359339) Got terminate signal TERMINATE_YOURSELF
                    2023-10-06 18:39:32.825  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                    2023-10-06 18:39:33.576  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:39:35.727  - info: tuya.0 (359339) terminating
                    2023-10-06 18:39:35.733  - info: tuya.0 (359339) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:39:36.419  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:39:40.442  - info: host.DietPi instance system.adapter.tuya.0 started with pid 359860
                    2023-10-06 18:39:43.529  - info: tuya.0 (359860) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:39:43.823  - info: tuya.0 (359860) Existing devices initialized
                    2023-10-06 18:39:43.833  - info: tuya.0 (359860) Listen for local Tuya devices on port 6666
                    2023-10-06 18:39:43.835  - info: tuya.0 (359860) Listen for encrypted local Tuya devices on port 6667
                    2023-10-06 18:40:00.157  - info: host.DietPi instance system.adapter.dwd.0 started with pid 359946
                    2023-10-06 18:40:02.939  - info: dwd.0 (359946) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:40:03.919  - info: dwd.0 (359946) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:40:04.240  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 359978
                    2023-10-06 18:40:04.474  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:40:07.173  - info: netatmo-crawler.0 (359978) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:40:07.276  - info: netatmo-crawler.0 (359978) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:40:08.946  - info: netatmo-crawler.0 (359978) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:40:09.392  - info: netatmo-crawler.0 (359978) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:40:09.984  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:43:01.805  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:43:07.371  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 javascript
                    2023-10-06 18:43:17.398  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:43:56.162  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 javascript
                    2023-10-06 18:44:31.738  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:44:37.582  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                    2023-10-06 18:44:37.594  - info: tuya.0 (359860) Got terminate signal TERMINATE_YOURSELF
                    2023-10-06 18:44:37.699  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                    2023-10-06 18:44:38.218  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:44:40.602  - info: tuya.0 (359860) terminating
                    2023-10-06 18:44:40.608  - info: tuya.0 (359860) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:44:41.330  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:44:45.456  - info: host.DietPi instance system.adapter.tuya.0 started with pid 361032
                    2023-10-06 18:44:48.602  - info: tuya.0 (361032) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:44:48.923  - info: tuya.0 (361032) Existing devices initialized
                    2023-10-06 18:44:48.933  - info: tuya.0 (361032) Listen for local Tuya devices on port 6666
                    2023-10-06 18:44:48.935  - info: tuya.0 (361032) Listen for encrypted local Tuya devices on port 6667
                    2023-10-06 18:45:00.123  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 361086
                    2023-10-06 18:45:03.121  - info: netatmo-crawler.0 (361086) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:45:03.220  - info: netatmo-crawler.0 (361086) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:45:04.193  - info: host.DietPi instance system.adapter.dwd.0 started with pid 361121
                    2023-10-06 18:45:04.818  - info: netatmo-crawler.0 (361086) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:45:05.201  - info: netatmo-crawler.0 (361086) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:45:06.448  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:45:08.028  - info: dwd.0 (361121) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:45:08.676  - info: dwd.0 (361121) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:45:09.288  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:45:23.928  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:45:55.858  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                    2023-10-06 18:45:55.877  - info: tuya.0 (361032) Got terminate signal TERMINATE_YOURSELF
                    2023-10-06 18:45:55.971  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                    2023-10-06 18:45:56.530  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:45:58.889  - info: tuya.0 (361032) terminating
                    2023-10-06 18:45:58.896  - info: tuya.0 (361032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:45:59.570  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:46:03.669  - info: host.DietPi instance system.adapter.tuya.0 started with pid 361344
                    2023-10-06 18:46:06.722  - info: tuya.0 (361344) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:46:07.082  - info: tuya.0 (361344) Existing devices initialized
                    2023-10-06 18:46:07.091  - info: tuya.0 (361344) Try to sync devices from Cloud using stored cloud credentials
                    2023-10-06 18:46:07.361  - info: tuya.0 (361344) Listen for local Tuya devices on port 6666
                    2023-10-06 18:46:07.363  - info: tuya.0 (361344) Listen for encrypted local Tuya devices on port 6667
                    2023-10-06 18:46:20.831  - info: tuya.0 (361344) Cloud login successful. Adapter restarts in 5s
                    2023-10-06 18:46:20.833  - info: tuya.0 (361344) Set data for tuya.0 to appDeviceId=wzkivi8rptp424gf6y2wvb9maby7ywkzy7he5bjun6n9 / sid=eu150169S7985241JDzUvul30bb4fe8ec5d81b5dbe49d23cf5aa0c99. Restart adapter now!
                    2023-10-06 18:46:20.849  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                    2023-10-06 18:46:20.858  - info: tuya.0 (361344) Got terminate signal TERMINATE_YOURSELF
                    2023-10-06 18:46:20.933  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                    2023-10-06 18:46:23.865  - info: tuya.0 (361344) terminating
                    2023-10-06 18:46:23.872  - info: tuya.0 (361344) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:46:24.618  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:46:28.611  - info: host.DietPi instance system.adapter.tuya.0 started with pid 361441
                    2023-10-06 18:46:31.829  - info: tuya.0 (361441) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:46:32.132  - info: tuya.0 (361441) Existing devices initialized
                    2023-10-06 18:46:32.138  - info: tuya.0 (361441) Try to sync devices from Cloud using stored cloud credentials
                    2023-10-06 18:46:32.393  - info: tuya.0 (361441) Listen for local Tuya devices on port 6666
                    2023-10-06 18:46:32.395  - info: tuya.0 (361441) Listen for encrypted local Tuya devices on port 6667
                    2023-10-06 18:46:33.274  - info: tuya.0 (361441) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
                    2023-10-06 18:46:33.814  - info: tuya.0 (361441) 06200292dc4f22305b8d: Connect locally to device
                    2023-10-06 18:46:35.700  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:46:39.930  - info: tuya.0 (361441) Try to sync devices from Cloud using cloud credentials from Admin
                    2023-10-06 18:46:59.647  - info: tuya.0 (361441) 06200292dc4f22305b8d: Connect locally to device
                    2023-10-06 18:47:10.678  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:49:03.973  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 18:50:00.065  - info: host.DietPi instance system.adapter.dwd.0 started with pid 362214
                    2023-10-06 18:50:05.578  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 362246
                    2023-10-06 18:50:06.732  - info: dwd.0 (362214) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:50:07.335  - info: dwd.0 (362214) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:50:07.968  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:50:08.836  - info: netatmo-crawler.0 (362246) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:50:08.936  - info: netatmo-crawler.0 (362246) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:50:10.594  - info: netatmo-crawler.0 (362246) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:50:11.060  - info: netatmo-crawler.0 (362246) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:50:11.617  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:50:33.606  - info: javascript.0 (1751) Stop script script.js.Eigene.LichtAbwesenheit
                    2023-10-06 18:50:33.726  - info: javascript.0 (1751) Start javascript script.js.Eigene.LichtAbwesenheit
                    2023-10-06 18:50:33.773  - info: javascript.0 (1751) script.js.Eigene.LichtAbwesenheit: registered 8 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2023-10-06 18:50:41.351  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 javascript
                    2023-10-06 18:55:00.133  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 363400
                    2023-10-06 18:55:03.176  - info: netatmo-crawler.0 (363400) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:55:03.278  - info: netatmo-crawler.0 (363400) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 18:55:04.203  - info: host.DietPi instance system.adapter.dwd.0 started with pid 363423
                    2023-10-06 18:55:04.712  - info: netatmo-crawler.0 (363400) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 18:55:04.999  - info: netatmo-crawler.0 (363400) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 18:55:05.544  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 18:55:07.117  - info: dwd.0 (363423) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 18:55:07.685  - info: dwd.0 (363423) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 18:55:08.281  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:00:00.216  - info: host.DietPi instance system.adapter.dwd.0 started with pid 364561
                    2023-10-06 19:00:03.236  - info: dwd.0 (364561) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:00:04.259  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 364589
                    2023-10-06 19:00:04.415  - info: dwd.0 (364561) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:00:04.973  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:00:07.539  - info: netatmo-crawler.0 (364589) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:00:07.641  - info: netatmo-crawler.0 (364589) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:00:08.326  - info: host.DietPi instance system.adapter.ical.0 started with pid 364614
                    2023-10-06 19:00:09.449  - info: netatmo-crawler.0 (364589) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:00:09.991  - info: netatmo-crawler.0 (364589) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:00:10.570  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:00:11.630  - info: ical.0 (364614) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:00:12.405  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 364642
                    2023-10-06 19:00:12.703  - info: ical.0 (364614) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                    2023-10-06 19:00:13.034  - info: ical.0 (364614) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                    2023-10-06 19:00:15.187  - info: luftdaten.0 (364642) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:00:18.174  - info: ical.0 (364614) Terminated (NO_ERROR): Without reason
                    2023-10-06 19:00:18.784  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 19:00:25.911  - info: luftdaten.0 (364642) Terminated (NO_ERROR): Without reason
                    2023-10-06 19:00:26.495  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 19:04:16.039  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 admin
                    2023-10-06 19:05:00.088  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 365719
                    2023-10-06 19:05:03.086  - info: netatmo-crawler.0 (365719) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:05:03.195  - info: netatmo-crawler.0 (365719) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:05:04.167  - info: host.DietPi instance system.adapter.dwd.0 started with pid 365753
                    2023-10-06 19:05:04.629  - info: netatmo-crawler.0 (365719) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:05:04.912  - info: netatmo-crawler.0 (365719) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:05:05.457  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:05:07.078  - info: dwd.0 (365753) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:05:07.687  - info: dwd.0 (365753) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:05:08.294  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:06:28.124  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 19:10:00.063  - info: host.DietPi instance system.adapter.dwd.0 started with pid 367130
                    2023-10-06 19:10:03.258  - info: dwd.0 (367130) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:10:04.113  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 367179
                    2023-10-06 19:10:04.167  - info: dwd.0 (367130) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:10:04.722  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:10:07.435  - info: netatmo-crawler.0 (367179) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:10:07.564  - info: netatmo-crawler.0 (367179) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:10:09.340  - info: netatmo-crawler.0 (367179) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:10:09.711  - info: netatmo-crawler.0 (367179) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:10:10.259  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:15:00.116  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 370892
                    2023-10-06 19:15:03.665  - info: netatmo-crawler.0 (370892) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:15:03.775  - info: netatmo-crawler.0 (370892) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:15:04.194  - info: host.DietPi instance system.adapter.dwd.0 started with pid 370940
                    2023-10-06 19:15:05.280  - info: netatmo-crawler.0 (370892) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:15:05.662  - info: netatmo-crawler.0 (370892) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:15:06.296  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:15:07.484  - info: dwd.0 (370940) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:15:08.093  - info: dwd.0 (370940) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:15:08.709  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:18:42.051  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 admin
                    2023-10-06 19:18:43.334  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 19:19:03.335  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 admin
                    2023-10-06 19:19:31.432  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                    2023-10-06 19:20:00.082  - info: host.DietPi instance system.adapter.dwd.0 started with pid 371582
                    2023-10-06 19:20:03.277  - info: dwd.0 (371582) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:20:04.128  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 371611
                    2023-10-06 19:20:04.316  - info: dwd.0 (371582) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:20:04.923  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:20:08.008  - info: netatmo-crawler.0 (371611) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:20:08.117  - info: netatmo-crawler.0 (371611) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:20:10.486  - info: netatmo-crawler.0 (371611) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:20:10.986  - info: netatmo-crawler.0 (371611) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:20:11.613  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:20:53.539  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                    2023-10-06 19:23:27.698  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 javascript
                    2023-10-06 19:23:51.001  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                    2023-10-06 19:25:00.064  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 372041
                    2023-10-06 19:25:03.416  - info: netatmo-crawler.0 (372041) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:25:03.518  - info: netatmo-crawler.0 (372041) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:25:04.107  - info: host.DietPi instance system.adapter.dwd.0 started with pid 372067
                    2023-10-06 19:25:04.779  - info: netatmo-crawler.0 (372041) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:25:05.051  - info: netatmo-crawler.0 (372041) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:25:05.613  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:25:07.842  - info: dwd.0 (372067) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:25:08.406  - info: dwd.0 (372067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:25:08.951  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:25:40.225  - info: javascript.0 (1751) Stop script script.js.Eigene.Luftfeuchtigkeit
                    2023-10-06 19:25:40.430  - info: javascript.0 (1751) Start javascript script.js.Eigene.Luftfeuchtigkeit
                    2023-10-06 19:25:40.515  - info: javascript.0 (1751) script.js.Eigene.Luftfeuchtigkeit: registered 12 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2023-10-06 19:27:28.780  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 javascript
                    2023-10-06 19:28:14.592  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                    2023-10-06 19:28:25.716  - error: backitup.0 (2086) [iobroker/influxDB] [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2023_10_06-19_28_25_backupiobroker"
                    2023-10-06 19:28:25.717  - error: backitup.0 (2086) [iobroker/influxDB] /bin/sh: 1: influxd: not found
                    2023-10-06 19:28:25.927  - error: backitup.0 (2086) [iobroker/mysql] [IGNORED] ****E****r****r****o****r****:**** ****C****o****m****m****a****n****d**** ****f****a****i****l****e****d****:**** ****m****y****s****q****l****d****u****m****p**** **** ****-****u**** **** ****-****p**** ****i****o****b****r****o****k****e****r**** ****-****h**** ****l****o****c****a****l****h****o****s****t**** ****-****P**** ****3****3****0****6**** ****>**** ****/****o****p****t****/****i****o****b****r****o****k****e****r****/****b****a****c****k****u****p****s****/****m****y****s****q****l****_****2****0****2****3****_****1****0****_****0****6****-****1****9****_****2****8****_****2****5****_****b****a****c****k****u****p****i****o****b****r****o****k****e****r****.****s****q****l****
                    2023-10-06 19:28:25.928  - error: backitup.0 (2086) [iobroker/mysql] ****m****y****s****q****l****d****u****m****p****:**** ****G****o****t**** ****e****r****r****o****r****:**** ****1****6****9****8****:**** ****"****A****c****c****e****s****s**** ****d****e****n****i****e****d**** ****f****o****r**** ****u****s****e****r**** ****'****-****p****'****@****'****l****o****c****a****l****h****o****s****t****'****"**** ****w****h****e****n**** ****t****r****y****i****n****g**** ****t****o**** ****c****o****n****n****e****c****t****
                    2023-10-06 19:28:26.099  - error: backitup.0 (2086) [iobroker/pgsql] [IGNORED] ****E****r****r****o****r****:**** ****C****o****m****m****a****n****d**** ****f****a****i****l****e****d****:**** ****p****g****_****d****u****m****p**** **** ****-****-****d****b****n****a****m****e****=****p****o****s****t****g****r****e****s****q****l****:****/****/****:****@****:****5****4****3****2****/**** ****>**** ****/****o****p****t****/****i****o****b****r****o****k****e****r****/****b****a****c****k****u****p****s****/****p****g****s****q****l****_****2****0****2****3****_****1****0****_****0****6****-****1****9****_****2****8****_****2****6****_****b****a****c****k****u****p****i****o****b****r****o****k****e****r****.****s****q****l****
                    2023-10-06 19:28:26.100  - error: backitup.0 (2086) [iobroker/pgsql] ****/****b****i****n****/****s****h****:**** ****1****:**** ****p****g****_****d****u****m****p****:**** ****n****o****t**** ****f****o****u****n****d****
                    2023-10-06 19:28:26.305  - error: backitup.0 (2086) [iobroker/sqlite] Error: Command failed: sqlite3 /opt/sqlite/data.db .dump > /opt/iobroker/backups/sqlite_2023_10_06-19_28_26_backupiobroker.sql
                    2023-10-06 19:28:26.309  - error: backitup.0 (2086) [iobroker/sqlite] /bin/sh: 1: sqlite3: not found
                    2023-10-06 19:28:26.309  - error: backitup.0 (2086) [iobroker/sqlite] [IGNORED] Error: Command failed: sqlite3 /opt/sqlite/data.db .dump > /opt/iobroker/backups/sqlite_2023_10_06-19_28_26_backupiobroker.sql
                    2023-10-06 19:28:26.310  - error: backitup.0 (2086) [iobroker/sqlite] /bin/sh: 1: sqlite3: not found
                    2023-10-06 19:28:28.236  - error: backitup.0 (2086) [iobroker/grafana] Grafana Backup cannot created. Please check your Configuration
                    2023-10-06 19:28:33.056  - error: backitup.0 (2086) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/influxDB_2023_10_06-19_28_25_backupiobroker.tar.gz" not found
                    2023-10-06 19:28:33.208  - error: backitup.0 (2086) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/mysql_2023_10_06-19_28_25_backupiobroker.tar.gz" not found
                    2023-10-06 19:28:33.359  - error: backitup.0 (2086) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/pgsql_2023_10_06-19_28_26_backupiobroker.tar.gz" not found
                    2023-10-06 19:28:33.510  - error: backitup.0 (2086) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/sqlite_2023_10_06-19_28_26_backupiobroker.tar.gz" not found
                    2023-10-06 19:28:41.381  - error: backitup.0 (2086) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                    2023-10-06 19:30:00.127  - info: host.DietPi instance system.adapter.dwd.0 started with pid 372674
                    2023-10-06 19:30:03.475  - info: dwd.0 (372674) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:30:04.168  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 372700
                    2023-10-06 19:30:04.739  - info: dwd.0 (372674) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:30:05.322  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:30:07.806  - info: netatmo-crawler.0 (372700) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:30:07.965  - info: netatmo-crawler.0 (372700) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:30:08.212  - info: host.DietPi instance system.adapter.luftdaten.0 started with pid 372729
                    2023-10-06 19:30:09.716  - info: netatmo-crawler.0 (372700) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:30:10.275  - info: netatmo-crawler.0 (372700) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:30:11.057  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:30:11.678  - info: luftdaten.0 (372729) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:30:12.263  - info: host.DietPi instance system.adapter.ical.0 started with pid 372746
                    2023-10-06 19:30:15.914  - info: ical.0 (372746) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:30:17.308  - info: ical.0 (372746) processing URL: Abfall https://calendar.google.com/calendar/ical/1u2h6bc370no498ug8raumm2fk%40group.calendar.google.com/private-cfb64d433f4941d424c7a5714511e304/basic.ics
                    2023-10-06 19:30:18.684  - info: ical.0 (372746) processing URL: iobroker https://calendar.google.com/calendar/ical/f44e2d88f617847643ed665d774782637920ad9aedf5d86baf34bb023eb68511%40group.calendar.google.com/private-be0cc1b7ccb854fb03d8d116f8bb201d/basic.ics
                    2023-10-06 19:30:20.106  - info: luftdaten.0 (372729) Terminated (NO_ERROR): Without reason
                    2023-10-06 19:30:20.705  - info: host.DietPi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 19:30:24.096  - info: ical.0 (372746) Terminated (NO_ERROR): Without reason
                    2023-10-06 19:30:24.656  - info: host.DietPi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2023-10-06 19:34:47.436  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54
                    2023-10-06 19:34:47.465  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
                    2023-10-06 19:35:00.072  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 373669
                    2023-10-06 19:35:03.455  - info: netatmo-crawler.0 (373669) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:35:03.567  - info: netatmo-crawler.0 (373669) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:35:04.130  - info: host.DietPi instance system.adapter.dwd.0 started with pid 373687
                    2023-10-06 19:35:04.999  - info: netatmo-crawler.0 (373669) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:35:05.276  - info: netatmo-crawler.0 (373669) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:35:05.842  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:35:08.550  - info: dwd.0 (373687) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:35:09.144  - info: dwd.0 (373687) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:35:09.695  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:38:24.191  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.41
                    2023-10-06 19:38:44.193  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.41 admin
                    2023-10-06 19:40:00.063  - info: host.DietPi instance system.adapter.dwd.0 started with pid 374757
                    2023-10-06 19:40:03.410  - info: dwd.0 (374757) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:40:04.113  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 374792
                    2023-10-06 19:40:04.238  - info: dwd.0 (374757) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:40:04.821  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:40:07.198  - info: netatmo-crawler.0 (374792) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:40:07.299  - info: netatmo-crawler.0 (374792) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:40:08.486  - info: netatmo-crawler.0 (374792) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:40:08.862  - info: netatmo-crawler.0 (374792) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:40:09.405  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:45:00.117  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 375933
                    2023-10-06 19:45:04.160  - info: host.DietPi instance system.adapter.dwd.0 started with pid 375984
                    2023-10-06 19:45:04.192  - info: netatmo-crawler.0 (375933) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:45:04.313  - info: netatmo-crawler.0 (375933) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:45:05.838  - info: netatmo-crawler.0 (375933) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:45:06.297  - info: netatmo-crawler.0 (375933) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:45:06.999  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:45:07.723  - info: dwd.0 (375984) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:45:08.275  - info: dwd.0 (375984) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:45:08.826  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:46:20.341  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                    2023-10-06 19:46:45.287  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                    2023-10-06 19:46:45.294  - info: tuya.0 (361441) Got terminate signal TERMINATE_YOURSELF
                    2023-10-06 19:46:45.381  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                    2023-10-06 19:46:48.299  - info: tuya.0 (361441) terminating
                    2023-10-06 19:46:48.302  - info: tuya.0 (361441) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:46:48.904  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:46:53.054  - info: host.DietPi instance system.adapter.tuya.0 started with pid 376247
                    2023-10-06 19:46:56.989  - info: tuya.0 (376247) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:46:57.595  - info: tuya.0 (376247) 06200292dc4f22305b8d: Connect locally to device
                    2023-10-06 19:46:57.607  - info: tuya.0 (376247) Existing devices initialized
                    2023-10-06 19:46:57.612  - info: tuya.0 (376247) Try to sync devices from Cloud using stored cloud credentials
                    2023-10-06 19:46:58.057  - info: tuya.0 (376247) Listen for local Tuya devices on port 6666
                    2023-10-06 19:46:58.058  - info: tuya.0 (376247) Listen for encrypted local Tuya devices on port 6667
                    2023-10-06 19:46:58.691  - info: tuya.0 (376247) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
                    2023-10-06 19:46:59.232  - info: tuya.0 (376247) 06200292dc4f22305b8d: Connect locally to device
                    2023-10-06 19:48:19.152  - info: host.DietPi stopInstance system.adapter.tuya.0 (force=false, process=true)
                    2023-10-06 19:48:19.194  - info: tuya.0 (376247) Got terminate signal TERMINATE_YOURSELF
                    2023-10-06 19:48:19.393  - info: host.DietPi stopInstance system.adapter.tuya.0 send kill signal
                    2023-10-06 19:48:22.199  - info: tuya.0 (376247) terminating
                    2023-10-06 19:48:22.201  - info: tuya.0 (376247) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:48:22.868  - info: host.DietPi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:48:27.024  - info: host.DietPi instance system.adapter.tuya.0 started with pid 376416
                    2023-10-06 19:48:30.552  - info: tuya.0 (376416) starting. Version 3.14.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:48:31.237  - info: tuya.0 (376416) 06200292dc4f22305b8d: Connect locally to device
                    2023-10-06 19:48:31.241  - info: tuya.0 (376416) Existing devices initialized
                    2023-10-06 19:48:31.248  - info: tuya.0 (376416) Try to sync devices from Cloud using stored cloud credentials
                    2023-10-06 19:48:31.627  - info: tuya.0 (376416) Listen for local Tuya devices on port 6666
                    2023-10-06 19:48:31.628  - info: tuya.0 (376416) Listen for encrypted local Tuya devices on port 6667
                    2023-10-06 19:48:32.235  - info: tuya.0 (376416) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
                    2023-10-06 19:48:32.716  - info: tuya.0 (376416) 06200292dc4f22305b8d: Connect locally to device
                    2023-10-06 16:31:00.812  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
                    2023-10-06 16:35:00.067  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 331961
                    2023-10-06 16:35:03.049  - info: netatmo-crawler.0 (331961) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:35:03.141  - info: netatmo-crawler.0 (331961) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 16:35:04.121  - info: host.DietPi instance system.adapter.dwd.0 started with pid 331982
                    2023-10-06 16:35:04.527  - info: netatmo-crawler.0 (331961) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 16:35:04.821  - info: netatmo-crawler.0 (331961) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 16:35:05.368  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 16:35:07.226  - info: dwd.0 (331982) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:35:07.915  - info: dwd.0 (331982) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 16:35:08.471  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 16:37:40.382  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                    2023-10-06 16:37:45.511  - info: admin.0 (1019) ==> Connected system.user.admin from ::ffff:192.168.178.54
                    2023-10-06 16:40:00.101  - info: host.DietPi instance system.adapter.dwd.0 started with pid 332541
                    2023-10-06 16:40:02.909  - info: dwd.0 (332541) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:40:03.802  - info: dwd.0 (332541) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 16:40:04.183  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 332572
                    2023-10-06 16:40:04.346  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 16:40:07.160  - info: netatmo-crawler.0 (332572) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:40:07.245  - info: netatmo-crawler.0 (332572) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 16:40:10.449  - info: netatmo-crawler.0 (332572) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 16:40:10.857  - info: netatmo-crawler.0 (332572) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 16:40:11.468  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 16:40:57.044  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 javascript
                    2023-10-06 16:40:57.082  - info: admin.0 (1019) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
                    2023-10-06 16:45:00.085  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 333668
                    2023-10-06 16:45:03.058  - info: netatmo-crawler.0 (333668) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 16:45:03.156  - info: netatmo-crawler.0 (333668) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 16:45:04.158  - info: host.DietPi instance system.adapter.dwd.0 started with pid 333703
                    2023-10-06 16:45:04.673  - info: netatmo-crawler.0 (333668) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 16:45:04.980  - info: netatmo-crawler.0 (333668) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 16:45:05.527  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 16:45:07.178  - info: dwd.0 (333703) st2023-10-06 19:50:00.105  - info: host.DietPi instance system.adapter.dwd.0 started with pid 376567
                    2023-10-06 19:50:03.490  - info: dwd.0 (376567) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:50:04.145  - info: host.DietPi instance system.adapter.netatmo-crawler.0 started with pid 376594
                    2023-10-06 19:50:04.604  - info: dwd.0 (376567) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-06 19:50:05.197  - info: host.DietPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-06 19:50:07.307  - info: netatmo-crawler.0 (376594) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
                    2023-10-06 19:50:07.419  - info: netatmo-crawler.0 (376594) Getting data for stationid:70:ee:50:65:8b:78
                    2023-10-06 19:50:08.676  - info: netatmo-crawler.0 (376594) Getting data for stationid:70:ee:50:13:60:32
                    2023-10-06 19:50:08.960  - info: netatmo-crawler.0 (376594) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    2023-10-06 19:50:09.511  - info: host.DietPi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    Ich sehe in beiden Kisten nix wildes. Aber die Systeme auf aktuellem Stand halten!
                    Walter WhiteW 1 Antwort Letzte Antwort
                      Walter WhiteW Offline
                      Walter White
                      @thomas-braun Also muss man jetzt einfach nur auf einen Adapter Update warten?
                      • Walter WhiteW Walter White
                        @walter-white
                        Wenn es sonst funktioniert...
                        Ich würde aber deine Repos anpassen.
                        Stell
                        Hit:4 https://archive.raspberrypi.org/debian bullseye InRelease
                        auf bookworm um. Und das nodesource-Repo muss auch angepackt werden. Geht z. B. mit dem Skript aus meiner Signatur. Oder händisch.
                        Horst BöttcherH 1 Antwort Letzte Antwort
                          @walter-white
                          Stell
                          Horst BöttcherH Offline
                          Horst Böttcher
                          bei mir hat sich das problem von allein gelöst heute nacht und es geht wieder
                          ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
