iIstallation Fehlermeldung CRIPT DEPRECATION WARNING
ich habe eben den ioBroker auf einem neuen System aufgesetzt.
Dabei ist folgende Warnung gekommen.Was bedeutet das?
curl -sLf https://iobroker.net/install.sh | bash - library: loaded Library version=2022-12-09 ========================================================================== Welcome to the ioBroker installer! Installer version: 2023-09-13 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/4) ========================================================================== OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://deb.debian.org/debian bookworm-updates InRelease OK:3 http://security.debian.org/debian-security bookworm-security InRelease Paketlisten werden gelesen… Fertig ========================================================================== Node.js not found. Installing... ========================================================================== ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) ... k -
curl -sLf https://iobroker.net/install.sh | bash - library: loaded Library version=2022-12-09 ========================================================================== Welcome to the ioBroker installer! Installer version: 2023-09-13 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/4) ========================================================================== OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://deb.debian.org/debian bookworm-updates InRelease OK:3 http://security.debian.org/debian-security bookworm-security InRelease Paketlisten werden gelesen… Fertig ========================================================================== Node.js not found. Installing... ========================================================================== ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) ... k@david-g sagte in ioBroker installation:
Was bedeutet das?
Das bedeutet, das im iobroker-Installer im Moment noch der alte nodejs-Installer aufgerufen wird, der sich halt mit dieser Meldung zu erkennen gibt.
Was bedeutet das?
Okay.
Hab eh nach dem installieren deinen Node fixer drüber laufen lassen. -
Okay.
Hab eh nach dem installieren deinen Node fixer drüber laufen lassen.@david-g
Dann bist du ja jetzt wieder auf dem richtigen Gleis.
