  4. Nach Update läuft nichts mehr!
    6.7k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 96.7k Aufrufe 9 Beobachtet
    @speedyblade
    Das Skript funktioniert und zaubert dir eine senkrechte Installation von nodejs 18 und Konsorten hin.
    iob diag
    sagt nun?
    SpeedyBlade
    #311
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     09:44:56 up 23 min,  1 user,  load average: 1.22, 0.89, 0.49
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=48.7'C
    volt=0.8700V
    *** Time and Time Zones ***
                   Local time: Fri 2023-09-29 09:44:56 CEST
               Universal time: Fri 2023-09-29 07:44:56 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.8G         58M        7.1G         16M        673M        7.5G
    Swap:           99M          0B         99M
    Total:         7.9G         58M        7.2G
             7846 M total memory
               58 M used memory
              280 M active memory
              345 M inactive memory
             7113 M free memory
              115 M buffer memory
              557 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      916G  3.2G  866G   1% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G   17M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     785M     0  785M   0% /run/user/1000
    [Fri Sep 29 09:21:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D6:FD:D6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=206cf84d-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Sep 29 09:21:43 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Sep 29 09:21:43 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Sep 29 09:21:47 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime,stripe=8191
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    393M    /var/
    193M    /var/cache
    188M    /var/cache/apt
    128M    /var/cache/apt/archives
    93M     /var/lib
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    17M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    122M    /opt/iobroker/iobroker-data/
    59M     /opt/iobroker/iobroker-data/backup-objects
    25M     /opt/iobroker/iobroker-data/files
    23M     /opt/iobroker/iobroker-data/node-red/node_modules
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.2M    /opt/iobroker/iobroker-data/files/knx.admin/static/js/main.fcc1088d.js.map
    5.1M    /opt/iobroker/iobroker-data/objects.json.migrated
    5.1M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    4.5M    /opt/iobroker/iobroker-data/objects.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1080
      throw err;
    Error: Cannot find module 'tar'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Module.require (node:internal/modules/cjs/loader:1143:19)
        at require (node:internal/modules/cjs/helpers:119:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        at Module.load (node:internal/modules/cjs/loader:1119:32)
        at Module._load (node:internal/modules/cjs/loader:960:12)
        at Module.require (node:internal/modules/cjs/loader:1143:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.18.0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    Core adapters versions
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    js-controller:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    admin:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    javascript:
    Adapters from github:   0
    Adapter State
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    ioBroker-Repositories
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    Installed ioBroker-Instances
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.18.0
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16156      624/sshd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16158      624/sshd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17451      615/dhcpcd
    udp        0      0 0.0.0.0:45185           0.0.0.0:*                           108        15399      387/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15397      387/avahi-daemon: r
    udp6       0      0 :::43947                :::*                                108        15400      387/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15573      615/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        15398      387/avahi-daemon: r
    2023-09-29 08:20:45.300  - error: host.RaspberryPi4 Caught by controller[6]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.300  - error: host.RaspberryPi4 Caught by controller[7]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[8]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[9]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[10]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.301  - error: host.RaspberryPi4 Caught by controller[11]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.305  - error: host.RaspberryPi4 Caught by controller[12]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[13]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[14]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[15]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[16]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.306  - error: host.RaspberryPi4 Caught by controller[17]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[18]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[19]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[20]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.307  - error: host.RaspberryPi4 Caught by controller[21]: sh: 0: getcwd() failed: No such file or directory
    2023-09-29 08:20:45.308  - info: host.RaspberryPi4 instance system.adapter.rpi2.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.309  - info: host.RaspberryPi4 instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.408  - info: host.RaspberryPi4 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.409  - info: host.RaspberryPi4 instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.470  - info: host.RaspberryPi4 instance system.adapter.knx.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.687  - info: host.RaspberryPi4 instance system.adapter.node-red.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.687  - info: host.RaspberryPi4 instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2023-09-29 08:20:45.688  - info: host.RaspberryPi4 All instances are stopped.
    2023-09-29 08:20:45.862  - info: host.RaspberryPi4 terminated
    • S SpeedyBlade
      @codierknecht
      wo steht dies?
      #312
      @speedyblade
      Das sind die Releases von nodejs.
      Das heißt aber noch lange nicht, das die neueste Version auch für den ioBroker empfohlen wird.
      Davon abgesehen stehst du auf 'Buster'.
      • S SpeedyBlade
        @codierknecht
        wo steht dies?
        CodierknechtC Offline
        Codierknecht
        #313
        @speedyblade sagte in Nach Update läuft nichts mehr!:
        wo steht dies?
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
          @speedyblade
          SpeedyBlade
          schrieb am zuletzt editiert von SpeedyBlade
          #314
          @thomas-braun sagte in Nach Update läuft nichts mehr!:
          => das heißt?
          Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
          • CodierknechtC Codierknecht
            wo steht dies?
            SpeedyBlade
            #315
            @codierknecht
            wo oder wie holst du dir diese Info her?
            • S SpeedyBlade
              @codierknecht
              #316
              Er kennt den ioBroker.
              Die Empfehlung steht im Admin und auch im diag-Skript drin.
              • S SpeedyBlade
                => das heißt?
                #317
                => das heißt?
                Das heißt, das du Debian 10 'Buster' fährst und nicht 'Bullseye'.
                Und das solltest du auch schleunigst updaten, besser als 64Bit-Version neuinstallieren.
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                ausführen.
                • S SpeedyBlade
                  => das heißt?
                  Codierknecht
                  #318
                  @speedyblade
                  Davon abgesehen stehst du auf 'Buster'. => das heißt?
                  Dass Du ein totes Pferd reitest.
                  "Buster" (Debian 10) ist abgekündigt. Du kannst "Bullseye" (Debian 11) nehmen oder gleich auf "Bookworm" (Debian 12) gehen.
                  Sagt Dir u.a. iob diag. Quasi das "Swiss-Army-Knife" für den ioBroker ;-)
                  S 2 Antworten Letzte Antwort
                    @speedyblade
                    SpeedyBlade
                    #319
                    @codierknecht sagte in Nach Update läuft nichts mehr!:
                    iob diag
                    kann ich per console auf Debian 12 gehen ohne, dass ich alles neu aufsetzen muss?
                    • amg_666A Offline
                      amg_666A Offline
                      amg_666
                      #320
                      @speedyblade ja und du kannst auch die Suchfunktion hier im Forum nutzen :-)
                      https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                      • amg_666A amg_666
                        Codierknecht
                        #321
                        @amg_666
                        Er hat aber noch Debian 10 auf seiner Kiste.
                        @SpeedyBlade
                        Meine Empfehlung: Aktuelles OS installieren und Backup wiederherstellen.
                        Dann ist's wenigstens sauber.
                        • S SpeedyBlade
                          iob diag
                          #322
                          Nicht direkt von einer 10 aus. Raspberry OS gibt es aber auch noch nicht auf 12 basierend.
                          Für einen Wechsel auf die 64Bit-Architektur muss ohnehin eine Neuinstallation vorgenommen werden.
                          • S SpeedyBlade
                            iob diag
                            #323
                            @speedyblade
                            Hast du jetzt den js-controller nochmal installiert?
                              SpeedyBlade
                              #324
                              ist das diese hier?
                              https://cdimage.debian.org/debian-cd/current/amd64/iso-cd/debian-12.1.0-amd64-netinst.iso
                                @speedyblade
                                SpeedyBlade
                                #325
                                egal was ich mache, läuft alles zusammen nicht mehr
                                keine ahnung warum, aber alle 1 bis 2 jahre die selbe Sch..... bei ioBroker
                                • S SpeedyBlade
                                  ist das diese hier?
                                  #326
                                  @speedyblade
                                  Nein. Das ist die falsche Architektur. Bei nodejs hast du auch schon daneben gegriffen...
                                  Schau mal durch meine Themen, da gibt es sowas wie:
                                  Installation - Einfacher geht's nicht
                                  oder so ähnlich.
                                  • S SpeedyBlade
                                    #327
                                    Aber warum machst du den Blödsinn dann immer wieder? Mit ordentlichem Setup funktioniert es auch.
                                      SpeedyBlade
                                      #328
                                      der Blödsinn läuft von selbst
                                      habe gestern von 3 verschiedenen raspi das update gemacht, einwandfrei
                                      nur dieser eine geht wieder gar nichts, das ist null nachvollziehbar, wenn alles 1:1 gleich gemacht wird
                                      Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                                      • S SpeedyBlade
                                        #329
                                        Nein, den Blödsinn fabriziert der Admin von der Kiste. Da läuft nix von selbst.
                                        • S SpeedyBlade
                                          #330
                                          Dann ist dieser eine verfummelt gewesen. Siehe nodejs-Installation.
