  4. Keine Verbindung zu VIS seit Update js-controller 5.0.x
    5.2k
39 Beiträge 5 Kommentatoren 4.5k Aufrufe 3 Beobachtet
    @karacho
    Ja, so soll das aussehen.
    Ein dritter Durchlauf wird zwei Meldungen mit 'Nothing to do' bringen.
    Karacho
    ioBroker nodejs fixer 2023-09-15
    Recommended nodejs-version is: 18.17.1
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/local/bin/corepack         0.18.0
    *** nodejs is NOT correctly installed ***
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.17.1-1nodesource1
      Candidate: 18.17.1-1nodesource1
      Version table:
     *** 18.17.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    Your nodejs-Installation seems to be not correct. Shall we try to fix it?
    Press <y> to continue or any other key to quit
    Fixing your nodejs setup
    *** Deleting /usr/local/bin/corepack ***
    Wrong paths have been fixed. Run 'iob diag' or 'iob node-update' again to check if your installation is fine now
    Nothing to do, your installed version is the recommended one.
    Thomas BraunT K 2 Antworten Letzte Antwort
    • K Karacho
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      @karacho
      Ah, corepack wird natürlich erst jetzt gefunden.
      Dann nochmal Skript laufen lassen.
      • K Karacho
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        Karacho
        @karacho
        So habe jetzt noch mal durchlaufen lassen.
        2x nothing to do
        Iobroker neu gestartet.
        VIS funktioniert nicht
        solarlog Adapter startet nicht.
        Gleiches Bild wie nach dem update js-controller von 4.x. auf 5.x
        Stand iob diag
                             v.2023-06-20
           Static hostname: raspberrypi4-iob
                 Icon name: computer
                Machine ID: 7520f6fd74454b99bf8a0c3666ca6ae6
                   Boot ID: cd5e4022480d4ac5b84276a48432878e
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Kernel:                 armv7l
        Userland:               armhf
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:           3.8G        1.3G        2.0G         24M        575M        2.4G
        Swap:           99M          0B         99M
        Total:         3.9G        1.3G        2.1G
        Active iob-Instances:   31
        ioBroker Core:          js-controller           5.0.12
                                admin                   6.8.0
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                15063
        States:                 13165
        Size of iob-Database:
        17M     /opt/iobroker/iobroker-data/objects.jsonl
        11M     /opt/iobroker/iobroker-data/objects.json.migrated
        11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        6.6M    /opt/iobroker/iobroker-data/states.jsonl
        2.5M    /opt/iobroker/iobroker-data/states.json.migrated
        2.5M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        HomoranH Thomas BraunT 3 Antworten Letzte Antwort
        • K Karacho
          @karacho
          2x nothing to do
          Stand iob diag
                               v.2023-06-20
                   Icon name: computer
                Architecture: arm
          Kernel:                 armv7l
          Userland:               armhf
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          MEMORY:
          Swap:           99M          0B         99M
                                  admin                   6.8.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                15063
          States:                 13165
          @karacho sagte in Keine Verbindung zu VIS seit Update js-controller 5.0.x:
          Stand iob diag
          da gibt's noch mehr!
          Das ist nur die Summary
          • K Karacho
            @karacho
            2x nothing to do
            Stand iob diag
                                 v.2023-06-20
                     Icon name: computer
                  Architecture: arm
            Kernel:                 armv7l
            Userland:               armhf
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
            MEMORY:
            Swap:           99M          0B         99M
                                    admin                   6.8.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                15063
            States:                 13165
            Zumindest diese Baustelle ist abgeschlossen.
              Stand iob diag
              Karacho
              schrieb am zuletzt editiert von Karacho
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
              Model           : Raspberry Pi 4 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : armv7l
              Userland        : armhf
              Systemuptime and Load:
               14:21:54 up 19 min,  1 user,  load average: 0.87, 1.68, 1.25
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              Other values than 0x0 hint to temperature/voltage problems
              temp=48.7'C
              volt=0.8500V
              *** Time and Time Zones ***
                             Local time: Mon 2023-09-18 14:21:54 CEST
                         Universal time: Mon 2023-09-18 12:21:54 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:           3.8G        1.5G        1.7G         24M        607M        2.1G
              Swap:           99M          0B         99M
              Total:         3.9G        1.5G        1.8G
                       3837 M total memory
                       1533 M used memory
                        324 M active memory
                       1683 M inactive memory
                       1697 M free memory
                        110 M buffer memory
                        497 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4       59G   43G   14G  76% /
              devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
              tmpfs          tmpfs     1.9G   25M  1.9G   2% /run
              tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
              /dev/sda1      vfat      253M   49M  204M  20% /boot
              tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
              [Mon Sep 18 14:02:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC        :A6:32:61:2C:40 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=t        tyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=dead        line fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Mon Sep 18 14:02:14 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null)
              [Mon Sep 18 14:02:14 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
              [Mon Sep 18 14:02:15 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
              TARGET        SOURCE    FSTYPE OPTIONS
              /             /dev/sda2 ext4   rw,noatime
              |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
              `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,io        charset=ascii,shortname=mixed,errors=remount-ro
              /var:
              2.2G    /var/
              1.9G    /var/cache/apt
              1.9G    /var/cache
              1.8G    /var/cache/apt/archives
              117M    /var/lib
              Archived and active journals take up 24.0M in the file system.
              /opt/iobroker/backups:
              194M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.2G    /opt/iobroker/iobroker-data/
              711M    /opt/iobroker/iobroker-data/history
              261M    /opt/iobroker/iobroker-data/files
              131M    /opt/iobroker/iobroker-data/backup-objects
              52M     /opt/iobroker/iobroker-data/files/javascript.admin
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.m        ap
              *** NodeJS-Installation ***
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              No configuration change needed.
              Multihost discovery server: disabled
              Discovery authentication:   enabled
              Persistent activation:      disabled
              Objects:                    jsonl on 127.0.0.1
              States:                     jsonl on 127.0.0.1
              Core adapters versions
              js-controller:  5.0.12
              admin:          6.8.0
              javascript:     7.1.4
              Adapters from github:   3
              Adapter State
              + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
              + system.adapter.bmw.0                    : bmw                   : raspberrypi4-iob                         -  enabled
              + system.adapter.bosch-ebike.0            : bosch-ebike           : raspberrypi4-iob                         -  enabled
              + system.adapter.broadlink2.0             : broadlink2            : raspberrypi4-iob                         -  enabled
              + system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         -  enabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi4-iob                         -  enabled
                system.adapter.devices.0                : devices               : raspberrypi4-iob                         - disabled
              + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
                system.adapter.dwd.0                    : dwd                   : raspberrypi4-iob                         -  enabled
              + system.adapter.easee.0                  : easee                 : raspberrypi4-iob                         -  enabled
              + system.adapter.ems-esp.0                : ems-esp               : raspberrypi4-iob                         -  enabled
                system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         - disabled
              + system.adapter.harmony.0                : harmony               : raspberrypi4-iob                         -  enabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi4-iob                         -  enabled
              + system.adapter.history.0                : history               : raspberrypi4-iob                         -  enabled
              + system.adapter.hmip.0                   : hmip                  : raspberrypi4-iob                         -  enabled
              + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4-iob                         -  enabled
              + system.adapter.hs100.0                  : hs100                 : raspberrypi4-iob                         -  enabled
                system.adapter.ical.0                   : ical                  : raspberrypi4-iob                         -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4-iob                         - disabled
              + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
              + system.adapter.meater.0                 : meater                : raspberrypi4-iob                         -  enabled
              + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4-iob                         -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4-iob                         -  enabled, port: 54321
              + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi4-iob                         -  enabled, port: 54321
              + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi4-iob                         -  enabled
              + system.adapter.pushover.0               : pushover              : raspberrypi4-iob                         -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
              + system.adapter.scenes.0                 : scenes                : raspberrypi4-iob                         -  enabled
              + system.adapter.smartgarden.0            : smartgarden           : raspberrypi4-iob                         -  enabled
                system.adapter.solarlog.0               : solarlog              : raspberrypi4-iob                         -  enabled, port: 80
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-iob                         -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4-iob                         - disabled
                system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4-iob                         -  enabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi4-iob                         -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4-iob                         - disabled
                system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
              + system.adapter.worx.0                   : worx                  : raspberrypi4-iob                         -  enabled
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iob                         -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
              + instance is alive
              ioBroker-Repositories
              Stable (default): http://download.iobroker.net/sources-dist.json
              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
              Installed ioBroker-Instances
              Adapter    "admin"        : 6.8.0    , installed 6.8.0
              Adapter    "backitup"     : 2.6.23   , installed 2.6.23
              Adapter    "bmw"          : 2.5.7    , installed 2.6.1
              Adapter    "bosch-ebike"  : 0.0.3    , installed 0.1.0
              Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "easee"        : 1.0.10   , installed 1.0.10
              Adapter    "ems-esp"      : 2.2.0    , installed 2.2.0
              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
              Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
              Adapter    "history"      : 2.2.6    , installed 2.2.6
              Adapter    "hmip"         : 1.20.0   , installed 1.20.0
              Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
              Adapter    "hs100"        : 2.1.2    , installed 2.1.2
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "km200"        : 2.0.3    , installed 2.0.3
              Adapter    "meater"       : 1.0.0    , installed 1.0.0
              Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
              Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
              Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
              Adapter    "pushover"     : 3.0.3    , installed 3.0.3
              Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "solarlog"     : 2.2.6    , installed 2.2.6
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
              Adapter    "web"          : 6.1.2    , installed 6.1.2
              Adapter    "wireguard"    : 1.5.11   , installed 1.5.11
              Adapter    "worx"         : 2.3.2    , installed 2.3.2
              Adapter    "ws"           : 2.5.5    , installed 2.5.5
              Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
              Objects and States
              Objects:        15063
              States:         13134
              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
              Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19896      634/sshd
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13138      390/cupsd
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20239      624/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19073      624/iobroker.js-con
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18152      703/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       26159      1291/io.web.0
              tcp6       0      0 :::51989                :::*                    LISTEN      1001       26640      1777/io.nuki-extend
              tcp6       0      0 :::22                   :::*                    LISTEN      0          19898      634/sshd
              tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18692      625/xrdp-sesman
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13137      390/cupsd
              tcp6       0      0 :::3389                 :::*                    LISTEN      109        20807      646/xrdp
              tcp6       0      0 :::61991                :::*                    LISTEN      1001       21278      1090/io.harmony.0
              udp        0      0 0.0.0.0:51088           0.0.0.0:*                           1001       18420      993/io.broadlink2.0
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21279      1090/io.harmony.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16866      618/dhcpcd
              udp        0      0 0.0.0.0:48730           0.0.0.0:*                           1001       18392      993/io.broadlink2.0
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13145      481/cups-browsed
              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       18389      993/io.broadlink2.0
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       21538      896/io.mihome-vacuu
              udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       20461      911/io.mihome-vacuu
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15754      391/avahi-daemon: r
              udp        0      0 0.0.0.0:55575           0.0.0.0:*                           108        15756      391/avahi-daemon: r
              udp6       0      0 :::39894                :::*                                108        15757      391/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        15755      391/avahi-daemon: r
              2023-09-18 14:19:08.125  - debug: daswetter.0 (3046) insert NextHours.Location_1.Day_5.Hour_8.uv_index_value with 0
              2023-09-18 14:19:08.142  - debug: daswetter.0 (3046) insert NextHours.Location_1.Day_5.Hour_8.windchill_value with 11 °C
              2023-09-18 14:19:08.154  - debug: daswetter.0 (3046) insert NextHours.Location_1.Day_5.sunshineDuration with 1.44
              2023-09-18 14:19:08.204  - debug: daswetter.0 (3046) hourly forecast done
              2023-09-18 14:19:08.208  - debug: daswetter.0 (3046) exit, all done
              2023-09-18 14:19:08.209  - debug: daswetter.0 (3046) timer killed
              2023-09-18 14:19:08.210  - debug: daswetter.0 (3046) Plugin sentry destroyed
              2023-09-18 14:19:08.211  - info: daswetter.0 (3046) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2023-09-18 14:19:08.735  - info: daswetter.0 (3046) cleaned everything up...
              2023-09-18 14:19:08.760  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-09-18 14:20:00.066  - info: host.raspberrypi4-iob instance system.adapter.dwd.0 started with pid 3854
              2023-09-18 14:20:03.586  - info: dwd.0 (3854) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
              2023-09-18 14:20:05.029  - info: dwd.0 (3854) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-09-18 14:20:05.560  - info: host.raspberrypi4-iob instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-09-18 14:20:14.912  - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44 admin
              2023-09-18 14:20:14.919  - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44 admin
              2023-09-18 14:20:14.920  - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44
              2023-09-18 14:20:15.826  - info: admin.0 (703) ==> Connected system.user.admin from ::ffff:192.168.178.44
              2023-09-18 14:20:15.849  - info: admin.0 (703) ==> Connected system.user.admin from ::ffff:192.168.178.44
              2023-09-18 14:20:16.130  - info: admin.0 (703) ==> Connected system.user.admin from ::ffff:192.168.178.44
              2023-09-18 14:21:05.564  - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44
              2023-09-18 14:22:42.227  - info: admin.0 (703) ==> Connected system.user.admin from ::ffff:192.168.178.44
              2023-09-18 14:22:45.057  - info: host.raspberrypi4-iob Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
              2023-09-18 14:23:11.735  - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44
              2023-09-18 14:23:11.740  - info: admin.0 (703) <== Disconnect system.user.admin from ::ffff:192.168.178.44 admin
                Karacho
                2 Fragen
                Generell node.js mit dem Skript aktualisieren?
                Kannst Du mir einen Link schicken, wie ich den Rasp auf das neue OS umstellen kann, was weiter oben beschrieben wurde mit
                Dann würde ich das auf Debian 11 'Bullseye' bringen, der Buster dürfte in Kürze auch für Raspbian OS abgekündigt werden.
                • K Karacho
                  2 Fragen
                  und in Kürze muss der Bookworm verfügbar sein.
                  Dann Backup machen, ganz neue Installation (64bit) und Backup zurückspielen
                  • K Karacho
                    @karacho
                    2x nothing to do
                    Stand iob diag
                                         v.2023-06-20
                             Icon name: computer
                          Architecture: arm
                    Kernel:                 armv7l
                    Userland:               armhf
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            9.6.7
                                            /usr/bin/npx            9.6.7
                    MEMORY:
                    Swap:           99M          0B         99M
                                            admin                   6.8.0
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                15063
                    States:                 13165
                    kann ich erst einmal nichts sehen warum?
                    steht beim Start der Instanz irgendwas im log?
                    steht im Tester Thread zu controller v5 etwas passendes?
                    • K Karacho
                      2 Fragen
                      Nein, updates für nodejs werden nun über die übliche Systempflege mit
                      sudo apt update
                      sudo apt full-upgrade
                      mit laufen. Nur bei einem Wechsel der Empfehlung auf nodejs@20 würde das nochmal ein Thema. Aber ich vermute, bis dahin ist das Skript in ein iob node-update (oder ähnlich) Kommando überführt worden.
                      Von Dingern wie n, nvm und wie sie alle heißen also die Finger lassen, die sind für andere Fälle gedacht, nicht für eine Grundinstallation von nodejs (auf Debian-artigen Distributionen).
                        Karacho
                        Also VIS Startet nicht seit update auf JS-controller 5.x und der Solarlog Adapter
                        2023-09-18 14:59:00.339	error	instance system.adapter.solarlog.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        solarlog.0
                        2023-09-18 14:58:59.618	error	undefined is not a valid state value
                        solarlog.0
                        2023-09-18 14:58:59.618	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.setStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at setDeviceInfo (/opt/iobroker/node_modules/iobroker.solarlog/main.js:2155:19) at test (/opt/iobroker/node_modules/iobroker.solarlog/main.js:291:13) at async Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.solarlog/main.js:231:39)
                        solarlog.0
                        2023-09-18 14:58:59.612	error	unhandled promise rejection: undefined is not a valid state value
                        solarlog.0
                        2023-09-18 14:58:59.612	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2023-09-18 14:58:26.271	error	instance system.adapter.solarlog.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        solarlog.0
                        2023-09-18 14:58:25.555	error	undefined is not a valid state value
                        solarlog.0
                        2023-09-18 14:58:25.554	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.setStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at setDeviceInfo (/opt/iobroker/node_modules/iobroker.solarlog/main.js:2155:19) at test (/opt/iobroker/node_modules/iobroker.solarlog/main.js:291:13) at async Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.solarlog/main.js:231:39)
                        solarlog.0
                        2023-09-18 14:58:25.545	error	unhandled promise rejection: undefined is not a valid state value
                        solarlog.0
                        2023-09-18 14:58:25.543	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
