  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Hichi IR Lesekopf verbindet sich nicht mit Smartmeter
    6.7k
134 Beiträge 17 Kommentatoren 33.3k Aufrufe 15 Beobachtet
  • T tonishi
    hbe Anzahl wakeup mal frei gelassen:
    log-file
    2023-09-08 19:56:23.073  - debug: smartmeter.0 (929) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-09-08 19:56:23.180  - debug: smartmeter.0 (929) Objects client ready ... initialize now
    2023-09-08 19:56:23.187  - debug: smartmeter.0 (929) Objects create System PubSub Client
    2023-09-08 19:56:23.190  - debug: smartmeter.0 (929) Objects create User PubSub Client
    2023-09-08 19:56:23.256  - debug: smartmeter.0 (929) Objects client initialize lua scripts
    2023-09-08 19:56:23.273  - debug: smartmeter.0 (929) Objects connected to redis: 127.0.0.1:9001
    2023-09-08 19:56:23.322  - debug: smartmeter.0 (929) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-09-08 19:56:23.342  - debug: smartmeter.0 (929) States create System PubSub Client
    2023-09-08 19:56:23.344  - debug: smartmeter.0 (929) States create User PubSub Client
    2023-09-08 19:56:23.372  - debug: smartmeter.0 (929) States connected to redis: 127.0.0.1:9000
    2023-09-08 19:56:23.445  - debug: smartmeter.0 (929) Plugin sentry Initialize Plugin (enabled=true)
    2023-09-08 19:56:24.324  - info: smartmeter.0 (929) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.17.1, js-controller: 4.0.24
    2023-09-08 19:56:24.400  - debug: smartmeter.0 (929) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"6","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0019-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":1000,"protocolD0WakeupCharacters":null,"obisFallbackMedium":1}
    2023-09-08 19:56:24.407  - debug: smartmeter.0 (929) CREATE SERIALPORT: 9600 8 1 none
    2023-09-08 19:56:24.427  - debug: smartmeter.0 (929) SERIALPORT OPEN
    2023-09-08 19:56:24.496  - debug: smartmeter.0 (929) SET MESSAGE TIMEOUT TIMER: 1000
    2023-09-08 19:56:24.507  - debug: smartmeter.0 (929) ADD NEW DATA (0 + NEW 25)
    2023-09-08 19:56:24.515  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.517  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:9" -> null
    2023-09-08 19:56:24.534  - debug: smartmeter.0 (929) ADD NEW DATA (25 + NEW 15)
    2023-09-08 19:56:24.537  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.541  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LO" -> null
    2023-09-08 19:56:24.553  - debug: smartmeter.0 (929) ADD NEW DATA (40 + NEW 22)
    2023-09-08 19:56:24.555  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.557  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8." -> null
    2023-09-08 19:56:24.570  - debug: smartmeter.0 (929) ADD NEW DATA (62 + NEW 14)
    2023-09-08 19:56:24.572  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.573  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6" -> null
    2023-09-08 19:56:24.588  - debug: smartmeter.0 (929) ADD NEW DATA (76 + NEW 15)
    2023-09-08 19:56:24.591  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.593  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2" -> null
    2023-09-08 19:56:24.599  - debug: smartmeter.0 (929) connected set to false
    2023-09-08 19:56:24.602  - debug: smartmeter.0 (929) ADD NEW DATA (91 + NEW 18)
    2023-09-08 19:56:24.605  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.606  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.00" -> null
    2023-09-08 19:56:24.615  - debug: smartmeter.0 (929) ADD NEW DATA (109 + NEW 12)
    2023-09-08 19:56:24.617  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.618  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0" -> null
    2023-09-08 19:56:24.626  - debug: smartmeter.0 (929) ADD NEW DATA (121 + NEW 11)
    2023-09-08 19:56:24.628  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.629  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(" -> null
    2023-09-08 19:56:24.636  - debug: smartmeter.0 (929) ADD NEW DATA (132 + NEW 10)
    2023-09-08 19:56:24.638  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.641  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432" -> null
    2023-09-08 19:56:24.648  - debug: smartmeter.0 (929) ADD NEW DATA (142 + NEW 10)
    2023-09-08 19:56:24.649  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.650  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504" -> null
    2023-09-08 19:56:24.658  - debug: smartmeter.0 (929) ADD NEW DATA (152 + NEW 9)
    2023-09-08 19:56:24.659  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.660  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96" -> null
    2023-09-08 19:56:24.669  - debug: smartmeter.0 (929) ADD NEW DATA (161 + NEW 9)
    2023-09-08 19:56:24.671  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.673  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255" -> null
    2023-09-08 19:56:24.678  - debug: smartmeter.0 (929) ADD NEW DATA (170 + NEW 12)
    2023-09-08 19:56:24.680  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.700  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:" -> null
    2023-09-08 19:56:24.709  - debug: smartmeter.0 (929) ADD NEW DATA (182 + NEW 25)
    2023-09-08 19:56:24.710  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.712  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r" -> null
    2023-09-08 19:56:24.720  - debug: smartmeter.0 (929) ADD NEW DATA (207 + NEW 1)
    2023-09-08 19:56:24.722  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:24.723  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6298*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n" -> null
    2023-09-08 19:56:25.498  - debug: smartmeter.0 (929) MESSAGE TIMEOUT TRIGGERED
    2023-09-08 19:56:25.500  - debug: smartmeter.0 (929) Error: No or too long answer from Serial Device after last request.
    2023-09-08 19:56:25.503  - warn: smartmeter.0 (929) No or too long answer from Serial Device after last request.
    2023-09-08 19:56:25.504  - debug: smartmeter.0 (929) Error: No or too long answer from Serial Device after last request.
    2023-09-08 19:56:25.505  - debug: smartmeter.0 (929) Transport Reset!! Restart = true
    2023-09-08 19:56:25.513  - debug: smartmeter.0 (929) SERIALPORT CLOSE
    2023-09-08 19:56:25.516  - debug: smartmeter.0 (929) SCHEDULE NEXT RUN IN 6s
    2023-09-08 19:56:31.517  - debug: smartmeter.0 (929) CREATE SERIALPORT: 9600 8 1 none
    2023-09-08 19:56:31.524  - debug: smartmeter.0 (929) SERIALPORT OPEN
    2023-09-08 19:56:31.529  - debug: smartmeter.0 (929) SET MESSAGE TIMEOUT TIMER: 1000
    2023-09-08 19:56:31.587  - debug: smartmeter.0 (929) ADD NEW DATA (0 + NEW 1)
    2023-09-08 19:56:31.588  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.589  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "�" -> null
    2023-09-08 19:56:31.593  - debug: smartmeter.0 (929) ADD NEW DATA (1 + NEW 4)
    2023-09-08 19:56:31.595  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.596  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b" -> null
    2023-09-08 19:56:31.601  - debug: smartmeter.0 (929) ADD NEW DATA (5 + NEW 6)
    2023-09-08 19:56:31.603  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.604  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE8" -> null
    2023-09-08 19:56:31.611  - debug: smartmeter.0 (929) ADD NEW DATA (11 + NEW 9)
    2023-09-08 19:56:31.612  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.614  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n" -> null
    2023-09-08 19:56:31.620  - debug: smartmeter.0 (929) ADD NEW DATA (20 + NEW 8)
    2023-09-08 19:56:31.622  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.623  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1" -> null
    2023-09-08 19:56:31.630  - debug: smartmeter.0 (929) ADD NEW DATA (28 + NEW 9)
    2023-09-08 19:56:31.631  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.632  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(00" -> null
    2023-09-08 19:56:31.638  - debug: smartmeter.0 (929) ADD NEW DATA (37 + NEW 8)
    2023-09-08 19:56:31.640  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.641  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065" -> null
    2023-09-08 19:56:31.647  - debug: smartmeter.0 (929) ADD NEW DATA (45 + NEW 8)
    2023-09-08 19:56:31.649  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.651  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r" -> null
    2023-09-08 19:56:31.656  - debug: smartmeter.0 (929) ADD NEW DATA (53 + NEW 8)
    2023-09-08 19:56:31.658  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.659  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8" -> null
    2023-09-08 19:56:31.665  - debug: smartmeter.0 (929) ADD NEW DATA (61 + NEW 8)
    2023-09-08 19:56:31.666  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.668  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(0" -> null
    2023-09-08 19:56:31.674  - debug: smartmeter.0 (929) ADD NEW DATA (69 + NEW 8)
    2023-09-08 19:56:31.676  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.677  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.63" -> null
    2023-09-08 19:56:31.683  - debug: smartmeter.0 (929) ADD NEW DATA (77 + NEW 8)
    2023-09-08 19:56:31.685  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.686  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r" -> null
    2023-09-08 19:56:31.694  - debug: smartmeter.0 (929) ADD NEW DATA (85 + NEW 10)
    2023-09-08 19:56:31.695  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.696  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0" -> null
    2023-09-08 19:56:31.702  - debug: smartmeter.0 (929) ADD NEW DATA (95 + NEW 8)
    2023-09-08 19:56:31.704  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.705  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000" -> null
    2023-09-08 19:56:31.711  - debug: smartmeter.0 (929) ADD NEW DATA (103 + NEW 9)
    2023-09-08 19:56:31.713  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.714  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*" -> null
    2023-09-08 19:56:31.720  - debug: smartmeter.0 (929) ADD NEW DATA (112 + NEW 8)
    2023-09-08 19:56:31.722  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.723  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-" -> null
    2023-09-08 19:56:31.728  - debug: smartmeter.0 (929) ADD NEW DATA (120 + NEW 7)
    2023-09-08 19:56:31.730  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.731  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0" -> null
    2023-09-08 19:56:31.738  - debug: smartmeter.0 (929) ADD NEW DATA (127 + NEW 9)
    2023-09-08 19:56:31.739  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.740  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver." -> null
    2023-09-08 19:56:31.746  - debug: smartmeter.0 (929) ADD NEW DATA (136 + NEW 8)
    2023-09-08 19:56:31.748  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.749  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F," -> null
    2023-09-08 19:56:31.755  - debug: smartmeter.0 (929) ADD NEW DATA (144 + NEW 8)
    2023-09-08 19:56:31.757  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.758  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504" -> null
    2023-09-08 19:56:31.765  - debug: smartmeter.0 (929) ADD NEW DATA (152 + NEW 10)
    2023-09-08 19:56:31.767  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.768  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96." -> null
    2023-09-08 19:56:31.774  - debug: smartmeter.0 (929) ADD NEW DATA (162 + NEW 9)
    2023-09-08 19:56:31.775  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.777  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(" -> null
    2023-09-08 19:56:31.783  - debug: smartmeter.0 (929) ADD NEW DATA (171 + NEW 7)
    2023-09-08 19:56:31.784  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.786  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n" -> null
    2023-09-08 19:56:31.791  - debug: smartmeter.0 (929) ADD NEW DATA (178 + NEW 8)
    2023-09-08 19:56:31.793  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.794  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.9" -> null
    2023-09-08 19:56:31.800  - debug: smartmeter.0 (929) ADD NEW DATA (186 + NEW 8)
    2023-09-08 19:56:31.802  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.803  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(" -> null
    2023-09-08 19:56:31.810  - debug: smartmeter.0 (929) ADD NEW DATA (194 + NEW 9)
    2023-09-08 19:56:31.811  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.813  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)" -> null
    2023-09-08 19:56:31.819  - debug: smartmeter.0 (929) ADD NEW DATA (203 + NEW 5)
    2023-09-08 19:56:31.820  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:31.821  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n" -> null
    2023-09-08 19:56:32.477  - debug: smartmeter.0 (929) ADD NEW DATA (208 + NEW 1)
    2023-09-08 19:56:32.479  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:32.480  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n�" -> null
    2023-09-08 19:56:32.484  - debug: smartmeter.0 (929) ADD NEW DATA (209 + NEW 4)
    2023-09-08 19:56:32.485  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:32.487  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n����L" -> null
    2023-09-08 19:56:32.492  - debug: smartmeter.0 (929) ADD NEW DATA (213 + NEW 6)
    2023-09-08 19:56:32.494  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:32.495  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n����LK13BE8" -> null
    2023-09-08 19:56:32.500  - debug: smartmeter.0 (929) ADD NEW DATA (219 + NEW 7)
    2023-09-08 19:56:32.502  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:32.504  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n����LK13BE803039\r\n" -> null
    2023-09-08 19:56:32.510  - debug: smartmeter.0 (929) ADD NEW DATA (226 + NEW 9)
    2023-09-08 19:56:32.511  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:32.513  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n����LK13BE803039\r\n\r\n1-0:96." -> null
    2023-09-08 19:56:32.519  - debug: smartmeter.0 (929) ADD NEW DATA (235 + NEW 8)
    2023-09-08 19:56:32.520  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:32.522  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n����LK13BE803039\r\n\r\n1-0:96.1.0*255(" -> null
    2023-09-08 19:56:32.528  - debug: smartmeter.0 (929) ADD NEW DATA (243 + NEW 7)
    2023-09-08 19:56:32.529  - debug: smartmeter.0 (929) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2023-09-08 19:56:32.531  - debug: smartmeter.0 (929) MATCH-RESULT SIGNON: "����b-�3BE803039\r\n\r\n1-0:96.1.0*255(001LOG0065318742)\r\n1-0:1.8.0*255(017786.6352*kWh)\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n����LK13BE803039\r\n\r\n1-0:96.1.0*255(001LOG0" -> null
    2023-09-08 19:56:32.536  - debug: smartmeter.0 (929) MESSAGE TIMEOUT TRIGGERED
    2023-09-08 19:56:32.538  - debug: smartmeter.0 (929) Error: No or too long answer from Serial Device after last request.
    2023-09-08 19:56:32.539  - warn: smartmeter.0 (929) No or too long answer from Serial Device after last request.
    2023-09-08 19:56:32.541  - debug: smartmeter.0 (929) Error: No or too long answer from Serial Device after last request.
    2023-09-08 19:56:32.542  - debug: smartmeter.0 (929) Transport Reset!! Restart = true
    2023-09-08 19:56:32.544  - debug: smartmeter.0 (929) NEW DATA AFTER STOP ... ignore
    2023-09-08 19:56:32.552  - debug: smartmeter.0 (929) SERIALPORT CLOSE
    2023-09-08 19:56:32.553  - debug: smartmeter.0 (929) SCHEDULE NEXT RUN IN 6s
    2023-09-08 19:56:36.085  - info: smartmeter.0 (929) Got terminate signal TERMINATE_YOURSELF
    2023-09-08 19:56:36.090  - info: smartmeter.0 (929) terminating
    2023-09-08 19:56:36.094  - debug: smartmeter.0 (929) Plugin sentry destroyed
    2023-09-08 19:56:36.096  - info: smartmeter.0 (929) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    EDIT: In der smartmeter konfiguration steht, dass wenn Anzahl wakeup frei gelassen wird, dann wird dafür 0 eingesetzt.
    #112
    @tonishi ganz dumme Frage: ist der Zähler verschlüsselt?
      tonishi
      schrieb am zuletzt editiert von tonishi
      #113
      @homoran ich hatte gestern den PIN eingegeben mit Lichtimpulsen. Sollte eigentlich freigeschaltet sein.
      EDIT: oder gibt es noch eine andere Verschlüsselung bei den Dingern?
        tonishi
        #114
        nochmal auf diese Seite zurückzukommen: https://wiki.volkszaehler.org/hardware/channels/meters/power/logarex_lk13b
        Was ist denn "read_timeout" und "interval", weißt du das?
        • T tonishi
          #115
          @tonishi sagte in Hichi IR Lesekopf verbindet sich nicht mit Smartmeter:
          leider nein. hätte auf "Abstand zwischen zwei signon" und "Datenabfrageintervall" getippt. Dann müssen es aber andere Einheiten sein.
          ich hatte mal nach der Meldung PROCESS STEP 0 IN CHECKMESSAGEgesucht und beim Querlesen nichts passendes gefunden.
          Jetzt kann ich nur noch hoffen, dass @apollon77 noch was dazu einfällt
          • T tonishi
            #116
            zumindest in Österreich
              tonishi
              #117
              @homoran bin in Deutschland, daher vmtl. hier nicht relevant.
              Hier https://www.photovoltaikforum.com/thread/111153-vzlogger-liest-keine-daten-vom-logarex-zähler/ wird noch von schlechten Dioden berichtet. Aber gut ob es das ist bei nur einem Bericht darüber? Es werden ja Daten gesendet und über den log kann man sehen, dass der Gesamtverbrauch übereinstimmt.
              • T tonishi
                #118
                das ust brksnnt. Auch deswegen die Frage nach lesbaren Ergebnissen über andere Wege
                  tonishi
                  #119
                  Hab das mal so versucht wie der Beitragssteller hier https://www.photovoltaikforum.com/thread/111153-vzlogger-liest-keine-daten-vom-logarex-zähler/
                  Das sieht gut aus was zurück kommt:
                  • T tonishi
                    #120
                    bis auf die Tatsache, dass der aktuelle Verbrauch fehlt (16.7.0.255).
                    Ich denke INF ist nicht auf ON, der PIN ist drin, Bezug kWh hat Nachkommastellen, Einspeisung ist wohl 0, weil du nichts einspeist.
                      tonishi
                      #121
                      @homoran das stimmtt. Das mit dem Verbrauch wundert mich auch. Sollte ja eigentlich da sein wenn ich den PIN eingegeben habe oder?
                      Einspeisung ist 0 genau.
                      Was bedeutet INF ist nicht auf ON?
                      • T tonishi
                        #122
                        nach der Eingabe des PIN musst du weiter durchs Menü bis zum Punkt INF und diesen auf ON stellen
                          tonishi
                          #123
                          @homoran ok jetzt wirds ganz verrückt, zumindest für mich. Habe das gemacht, also INF auf ON gestellt am Zähler. Nun mit der d0 Standardkonfiguration im smartmeter kommt folgender log (nix lesbares mehr)
                          2023-09-08 20:49:42.876  - info: admin.0 (738) ==> Connected system.user.admin from ::ffff:192.168.2.113
                          2023-09-08 20:49:51.886  - info: admin.0 (738) <== Disconnect system.user.admin from ::ffff:192.168.2.113
                          2023-09-08 20:49:56.529  - info: host.raspberrypi "system.adapter.smartmeter.0" enabled
                          2023-09-08 20:49:56.614  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 938
                          2023-09-08 20:50:00.464  - debug: smartmeter.0 (938) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2023-09-08 20:50:00.567  - debug: smartmeter.0 (938) Objects client ready ... initialize now
                          2023-09-08 20:50:00.574  - debug: smartmeter.0 (938) Objects create System PubSub Client
                          2023-09-08 20:50:00.578  - debug: smartmeter.0 (938) Objects create User PubSub Client
                          2023-09-08 20:50:00.662  - debug: smartmeter.0 (938) Objects client initialize lua scripts
                          2023-09-08 20:50:00.682  - debug: smartmeter.0 (938) Objects connected to redis: 127.0.0.1:9001
                          2023-09-08 20:50:00.729  - debug: smartmeter.0 (938) Redis States: Use Redis connection: 127.0.0.1:9000
                          2023-09-08 20:50:00.748  - debug: smartmeter.0 (938) States create System PubSub Client
                          2023-09-08 20:50:00.751  - debug: smartmeter.0 (938) States create User PubSub Client
                          2023-09-08 20:50:00.779  - debug: smartmeter.0 (938) States connected to redis: 127.0.0.1:9000
                          2023-09-08 20:50:00.845  - debug: smartmeter.0 (938) Plugin sentry Initialize Plugin (enabled=true)
                          2023-09-08 20:50:01.717  - info: smartmeter.0 (938) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.17.1, js-controller: 4.0.24
                          2023-09-08 20:50:01.804  - debug: smartmeter.0 (938) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"6","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0019-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":1000,"protocolD0WakeupCharacters":null,"obisFallbackMedium":1}
                          2023-09-08 20:50:01.810  - debug: smartmeter.0 (938) CREATE SERIALPORT: 9600 8 1 none
                          2023-09-08 20:50:01.835  - debug: smartmeter.0 (938) SERIALPORT OPEN
                          2023-09-08 20:50:01.881  - debug: smartmeter.0 (938) SET MESSAGE TIMEOUT TIMER: 1000
                          2023-09-08 20:50:01.919  - debug: smartmeter.0 (938) connected set to false
                          2023-09-08 20:50:02.723  - debug: smartmeter.0 (938) ADD NEW DATA (0 + NEW 1)
                          2023-09-08 20:50:02.726  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.727  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "�" -> null
                          2023-09-08 20:50:02.734  - debug: smartmeter.0 (938) ADD NEW DATA (1 + NEW 7)
                          2023-09-08 20:50:02.736  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.738  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?" -> null
                          2023-09-08 20:50:02.743  - debug: smartmeter.0 (938) ADD NEW DATA (8 + NEW 9)
                          2023-09-08 20:50:02.746  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.747  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r" -> null
                          2023-09-08 20:50:02.753  - debug: smartmeter.0 (938) ADD NEW DATA (17 + NEW 7)
                          2023-09-08 20:50:02.755  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.756  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs" -> null
                          2023-09-08 20:50:02.763  - debug: smartmeter.0 (938) ADD NEW DATA (24 + NEW 11)
                          2023-09-08 20:50:02.765  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.766  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���" -> null
                          2023-09-08 20:50:02.775  - debug: smartmeter.0 (938) ADD NEW DATA (35 + NEW 7)
                          2023-09-08 20:50:02.776  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.778  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M" -> null
                          2023-09-08 20:50:02.785  - debug: smartmeter.0 (938) ADD NEW DATA (42 + NEW 11)
                          2023-09-08 20:50:02.786  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.788  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1K�" -> null
                          2023-09-08 20:50:02.795  - debug: smartmeter.0 (938) ADD NEW DATA (53 + NEW 8)
                          2023-09-08 20:50:02.796  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.798  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S��" -> null
                          2023-09-08 20:50:02.806  - debug: smartmeter.0 (938) ADD NEW DATA (61 + NEW 10)
                          2023-09-08 20:50:02.808  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.811  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S���ǃ���ûs�" -> null
                          2023-09-08 20:50:02.816  - debug: smartmeter.0 (938) ADD NEW DATA (71 + NEW 9)
                          2023-09-08 20:50:02.818  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.819  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S���ǃ���ûs����SZ�JC�" -> null
                          2023-09-08 20:50:02.827  - debug: smartmeter.0 (938) ADD NEW DATA (80 + NEW 8)
                          2023-09-08 20:50:02.829  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.830  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S���ǃ���ûs����SZ�JC�k�ӓs�s�" -> null
                          2023-09-08 20:50:02.836  - debug: smartmeter.0 (938) ADD NEW DATA (88 + NEW 10)
                          2023-09-08 20:50:02.838  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.839  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S���ǃ���ûs����SZ�JC�k�ӓs�s�S���C�����" -> null
                          2023-09-08 20:50:02.845  - debug: smartmeter.0 (938) ADD NEW DATA (98 + NEW 8)
                          2023-09-08 20:50:02.847  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.848  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S���ǃ���ûs����SZ�JC�k�ӓs�s�S���C������󆇃�S�" -> null
                          2023-09-08 20:50:02.855  - debug: smartmeter.0 (938) ADD NEW DATA (106 + NEW 7)
                          2023-09-08 20:50:02.857  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.858  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S���ǃ���ûs����SZ�JC�k�ӓs�s�S���C������󆇃�S��{�Lxk�" -> null
                          2023-09-08 20:50:02.864  - debug: smartmeter.0 (938) ADD NEW DATA (113 + NEW 11)
                          2023-09-08 20:50:02.866  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.867  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S���ǃ���ûs����SZ�JC�k�ӓs�s�S���C������󆇃�S��{�Lxk�Ӌ����S���" -> null
                          2023-09-08 20:50:02.873  - debug: smartmeter.0 (938) ADD NEW DATA (124 + NEW 7)
                          2023-09-08 20:50:02.874  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.876  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S���ǃ���ûs����SZ�JC�k�ӓs�s�S���C������󆇃�S��{�Lxk�Ӌ����S���C������" -> null
                          2023-09-08 20:50:02.882  - debug: smartmeter.0 (938) ADD NEW DATA (131 + NEW 9)
                          2023-09-08 20:50:02.884  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:02.886  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "����*�\u0013?ホ���k\u000b\r�1K�ϳs�s�S���C���c=\u001d���M�û��Kj�1KӋs�s�S���ǃ���ûs����SZ�JC�k�ӓs�s�S���C������󆇃�S��{�Lxk�Ӌ����S���C����������Lxk��" -> null
                          2023-09-08 20:50:02.892  - debug: smartmeter.0 (938) MESSAGE TIMEOUT TRIGGERED
                          2023-09-08 20:50:02.894  - debug: smartmeter.0 (938) Error: No or too long answer from Serial Device after last request.
                          2023-09-08 20:50:02.898  - warn: smartmeter.0 (938) No or too long answer from Serial Device after last request.
                          2023-09-08 20:50:02.899  - debug: smartmeter.0 (938) Error: No or too long answer from Serial Device after last request.
                          2023-09-08 20:50:02.901  - debug: smartmeter.0 (938) Transport Reset!! Restart = true
                          2023-09-08 20:50:02.907  - debug: smartmeter.0 (938) NEW DATA AFTER STOP ... ignore
                          2023-09-08 20:50:02.914  - debug: smartmeter.0 (938) SERIALPORT CLOSE
                          2023-09-08 20:50:02.917  - debug: smartmeter.0 (938) SCHEDULE NEXT RUN IN 6s
                          2023-09-08 20:50:08.919  - debug: smartmeter.0 (938) CREATE SERIALPORT: 9600 8 1 none
                          2023-09-08 20:50:08.930  - debug: smartmeter.0 (938) SERIALPORT OPEN
                          2023-09-08 20:50:08.936  - debug: smartmeter.0 (938) ADD NEW DATA (0 + NEW 6)
                          2023-09-08 20:50:08.938  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:08.940  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "�����" -> null
                          2023-09-08 20:50:08.943  - debug: smartmeter.0 (938) SET MESSAGE TIMEOUT TIMER: 1000
                          2023-09-08 20:50:08.949  - debug: smartmeter.0 (938) ADD NEW DATA (6 + NEW 9)
                          2023-09-08 20:50:08.952  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:08.954  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "�����S���C����" -> null
                          2023-09-08 20:50:08.963  - debug: smartmeter.0 (938) ADD NEW DATA (15 + NEW 14)
                          2023-09-08 20:50:08.965  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:08.967  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "�����S���C�����S���Lxk�ӛ���" -> null
                          2023-09-08 20:50:08.975  - debug: smartmeter.0 (938) ADD NEW DATA (29 + NEW 11)
                          2023-09-08 20:50:08.980  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:08.984  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "�����S���C�����S���Lxk�ӛ�����S���C����" -> null
                          2023-09-08 20:50:08.995  - debug: smartmeter.0 (938) ADD NEW DATA (40 + NEW 14)
                          2023-09-08 20:50:09.001  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          2023-09-08 20:50:09.003  - debug: smartmeter.0 (938) MATCH-RESULT SIGNON: "�����S���C�����S���Lxk�ӛ�����S���C����S\u001e�����ӫ\u0017��" -> null
                          2023-09-08 20:50:09.009  - debug: smartmeter.0 (938) ADD NEW DATA (54 + NEW 17)
                          2023-09-08 20:50:09.011  - debug: smartmeter.0 (938) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          • T tonishi
                            #124
                            doch sml?
                            ich hab keine Ahnung mehr
                            er scheint diverse signon messages durchzuprobieten, jeweils ohne Antwort.
                            Dazu gibt es was!
                            stay tuned!
                              doch sml?
                              Dazu gibt es was!
                              stay tuned!
                              tonishi
                              #125
                              @homoran SML hatte ich auch ausprobiert, auch da kommt nix sinnvolles:
                              2023-09-08 21:04:12.208  - info: admin.0 (738) ==> Connected system.user.admin from ::ffff:192.168.2.113
                              2023-09-08 21:04:23.270  - info: admin.0 (738) <== Disconnect system.user.admin from ::ffff:192.168.2.113
                              2023-09-08 21:04:25.742  - info: host.raspberrypi "system.adapter.smartmeter.0" enabled
                              2023-09-08 21:04:25.825  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 984
                              2023-09-08 21:04:29.645  - debug: smartmeter.0 (984) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2023-09-08 21:04:29.744  - debug: smartmeter.0 (984) Objects client ready ... initialize now
                              2023-09-08 21:04:29.751  - debug: smartmeter.0 (984) Objects create System PubSub Client
                              2023-09-08 21:04:29.754  - debug: smartmeter.0 (984) Objects create User PubSub Client
                              2023-09-08 21:04:29.823  - debug: smartmeter.0 (984) Objects client initialize lua scripts
                              2023-09-08 21:04:29.841  - debug: smartmeter.0 (984) Objects connected to redis: 127.0.0.1:9001
                              2023-09-08 21:04:29.886  - debug: smartmeter.0 (984) Redis States: Use Redis connection: 127.0.0.1:9000
                              2023-09-08 21:04:29.905  - debug: smartmeter.0 (984) States create System PubSub Client
                              2023-09-08 21:04:29.908  - debug: smartmeter.0 (984) States create User PubSub Client
                              2023-09-08 21:04:29.936  - debug: smartmeter.0 (984) States connected to redis: 127.0.0.1:9000
                              2023-09-08 21:04:30.006  - debug: smartmeter.0 (984) Plugin sentry Initialize Plugin (enabled=true)
                              2023-09-08 21:04:30.862  - info: smartmeter.0 (984) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.17.1, js-controller: 4.0.24
                              2023-09-08 21:04:30.933  - debug: smartmeter.0 (984) SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"6","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0019-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false,"obisFallbackMedium":1}
                              2023-09-08 21:04:30.939  - debug: smartmeter.0 (984) CREATE SERIALPORT: 9600 8 1 none
                              2023-09-08 21:04:30.960  - debug: smartmeter.0 (984) SERIALPORT OPEN
                              2023-09-08 21:04:31.020  - debug: smartmeter.0 (984) ADD NEW DATA (0 + NEW 17)
                              2023-09-08 21:04:31.024  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530f" -> null
                              2023-09-08 21:04:31.027  - debug: smartmeter.0 (984) SET MESSAGE TIMEOUT TIMER: 120000
                              2023-09-08 21:04:31.037  - debug: smartmeter.0 (984) ADD NEW DATA (17 + NEW 48)
                              2023-09-08 21:04:31.039  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be8353" -> null
                              2023-09-08 21:04:31.048  - debug: smartmeter.0 (984) ADD NEW DATA (65 + NEW 16)
                              2023-09-08 21:04:31.050  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6ab" -> null
                              2023-09-08 21:04:31.061  - debug: smartmeter.0 (984) ADD NEW DATA (81 + NEW 8)
                              2023-09-08 21:04:31.062  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d9" -> null
                              2023-09-08 21:04:31.070  - debug: smartmeter.0 (984) ADD NEW DATA (89 + NEW 9)
                              2023-09-08 21:04:31.071  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38b" -> null
                              2023-09-08 21:04:31.073  - debug: smartmeter.0 (984) connected set to false
                              2023-09-08 21:04:31.082  - debug: smartmeter.0 (984) ADD NEW DATA (98 + NEW 9)
                              2023-09-08 21:04:31.083  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38bf3fef39653b6abaf43" -> null
                              2023-09-08 21:04:31.095  - debug: smartmeter.0 (984) ADD NEW DATA (107 + NEW 10)
                              2023-09-08 21:04:31.097  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38bf3fef39653b6abaf43b6a3935366d95fee8fcc" -> null
                              2023-09-08 21:04:31.105  - debug: smartmeter.0 (984) ADD NEW DATA (117 + NEW 11)
                              2023-09-08 21:04:31.107  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38bf3fef39653b6abaf43b6a3935366d95fee8fcccbd3c39ff3fff3e6a796ab" -> null
                              2023-09-08 21:04:31.114  - debug: smartmeter.0 (984) ADD NEW DATA (128 + NEW 9)
                              2023-09-08 21:04:31.116  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38bf3fef39653b6abaf43b6a3935366d95fee8fcccbd3c39ff3fff3e6a796abab43879faf5723595f" -> null
                              2023-09-08 21:04:31.122  - debug: smartmeter.0 (984) ADD NEW DATA (137 + NEW 9)
                              2023-09-08 21:04:31.124  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38bf3fef39653b6abaf43b6a3935366d95fee8fcccbd3c39ff3fff3e6a796abab43879faf5723595ff94c286b82d3c38b73" -> null
                              2023-09-08 21:04:31.130  - debug: smartmeter.0 (984) ADD NEW DATA (146 + NEW 7)
                              2023-09-08 21:04:31.132  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38bf3fef39653b6abaf43b6a3935366d95fee8fcccbd3c39ff3fff3e6a796abab43879faf5723595ff94c286b82d3c38b73fef79eab53b6ab" -> null
                              2023-09-08 21:04:31.137  - debug: smartmeter.0 (984) ADD NEW DATA (153 + NEW 6)
                              2023-09-08 21:04:31.139  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38bf3fef39653b6abaf43b6a3935366d95fee8fcccbd3c39ff3fff3e6a796abab43879faf5723595ff94c286b82d3c38b73fef79eab53b6abab43869b9357" -> null
                              2023-09-08 21:04:31.144  - debug: smartmeter.0 (984) ADD NEW DATA (159 + NEW 7)
                              2023-09-08 21:04:31.145  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38bf3fef39653b6abaf43b6a3935366d95fee8fcccbd3c39ff3fff3e6a796abab43879faf5723595ff94c286b82d3c38b73fef79eab53b6abab43869b935766d95ff94c386b" -> null
                              2023-09-08 21:04:31.152  - debug: smartmeter.0 (984) ADD NEW DATA (166 + NEW 6)
                              2023-09-08 21:04:31.154  - debug: smartmeter.0 (984) MATCH-RESULT MESSAGE: "f3fef386d796abab4387838bf3bf93530fc3e1cccbd7ab8beffef38653b6ffab43868783f7deab530eeffe8fcccbd3bb8bf3fef38653b6afab43868383f3be83530ae7ee8fcccbd3c38bf3fff39e53b6abab478e8bcf5366d95fa95c386b86d3c38bf3fef39653b6abaf43b6a3935366d95fee8fcccbd3c39ff3fff3e6a796abab43879faf5723595ff94c286b82d3c38b73fef79eab53b6abab43869b935766d95ff94c386b86d3c38bf3fe" -> null
                              2023-09-08 21:04:31.160  - debug: smartmeter.0 (984) ADD NEW DATA (172 + NEW 6)
                              • T tonishi
                                #126
                                @tonishi sieh mal ob das hier passen könnte
                                https://forum.iobroker.net/post/940824
                                Ansonsten würde ich den gesamten Adapter mal löschen und neu installieren.
                                Dann auf d0 und mit default starten
                                  tonishi
                                  #127
                                  ok, hab einfach am Zähler neben INF auf ON die PIN auf ON gehabt. Hab das jetzt auf OFF gestellt. Nun bekomme ich alle Daten:
                                  2023-09-08 21:13:01.298  - info: admin.0 (738) <== Disconnect system.user.admin from ::ffff:192.168.2.113 admin
                                  2023-09-08 21:13:57.538  - info: admin.0 (738) ==> Connected system.user.admin from ::ffff:192.168.2.113
                                  2023-09-08 21:14:11.874  - info: admin.0 (738) ==> Connected system.user.admin from ::ffff:192.168.2.113
                                  2023-09-08 21:14:36.677  - info: admin.0 (738) <== Disconnect system.user.admin from ::ffff:192.168.2.113
                                  2023-09-08 21:14:38.383  - info: host.raspberrypi "system.adapter.smartmeter.0" enabled
                                  2023-09-08 21:14:38.500  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 1086
                                  2023-09-08 21:14:42.363  - debug: smartmeter.0 (1086) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2023-09-08 21:14:42.459  - debug: smartmeter.0 (1086) Objects client ready ... initialize now
                                  2023-09-08 21:14:42.467  - debug: smartmeter.0 (1086) Objects create System PubSub Client
                                  2023-09-08 21:14:42.471  - debug: smartmeter.0 (1086) Objects create User PubSub Client
                                  2023-09-08 21:14:42.539  - debug: smartmeter.0 (1086) Objects client initialize lua scripts
                                  2023-09-08 21:14:42.558  - debug: smartmeter.0 (1086) Objects connected to redis: 127.0.0.1:9001
                                  2023-09-08 21:14:42.608  - debug: smartmeter.0 (1086) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2023-09-08 21:14:42.628  - debug: smartmeter.0 (1086) States create System PubSub Client
                                  2023-09-08 21:14:42.631  - debug: smartmeter.0 (1086) States create User PubSub Client
                                  2023-09-08 21:14:42.661  - debug: smartmeter.0 (1086) States connected to redis: 127.0.0.1:9000
                                  2023-09-08 21:14:42.774  - debug: smartmeter.0 (1086) Plugin sentry Initialize Plugin (enabled=true)
                                  2023-09-08 21:14:43.682  - info: smartmeter.0 (1086) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.17.1, js-controller: 4.0.24
                                  2023-09-08 21:14:43.765  - debug: smartmeter.0 (1086) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"6","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0019-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":1000,"protocolD0WakeupCharacters":null,"obisFallbackMedium":1}
                                  2023-09-08 21:14:43.771  - debug: smartmeter.0 (1086) CREATE SERIALPORT: 9600 8 1 none
                                  2023-09-08 21:14:43.796  - debug: smartmeter.0 (1086) SERIALPORT OPEN
                                  2023-09-08 21:14:43.861  - debug: smartmeter.0 (1086) ADD NEW DATA (0 + NEW 21)
                                  2023-09-08 21:14:43.866  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:43.868  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr�" -> null
                                  2023-09-08 21:14:43.870  - debug: smartmeter.0 (1086) SET MESSAGE TIMEOUT TIMER: 1000
                                  2023-09-08 21:14:43.882  - debug: smartmeter.0 (1086) ADD NEW DATA (21 + NEW 60)
                                  2023-09-08 21:14:43.886  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:43.888  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(0003" -> null
                                  2023-09-08 21:14:43.897  - debug: smartmeter.0 (1086) ADD NEW DATA (81 + NEW 17)
                                  2023-09-08 21:14:43.899  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:43.902  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0" -> null
                                  2023-09-08 21:14:43.918  - debug: smartmeter.0 (1086) ADD NEW DATA (98 + NEW 14)
                                  2023-09-08 21:14:43.919  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:43.920  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r" -> null
                                  2023-09-08 21:14:43.927  - debug: smartmeter.0 (1086) ADD NEW DATA (112 + NEW 15)
                                  2023-09-08 21:14:43.930  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:43.932  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255" -> null
                                  2023-09-08 21:14:43.935  - debug: smartmeter.0 (1086) connected set to false
                                  2023-09-08 21:14:43.944  - debug: smartmeter.0 (1086) ADD NEW DATA (127 + NEW 12)
                                  2023-09-08 21:14:43.946  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:43.947  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1" -> null
                                  2023-09-08 21:14:43.961  - debug: smartmeter.0 (1086) ADD NEW DATA (139 + NEW 15)
                                  2023-09-08 21:14:43.963  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:43.965  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(2" -> null
                                  2023-09-08 21:14:43.973  - debug: smartmeter.0 (1086) ADD NEW DATA (154 + NEW 15)
                                  2023-09-08 21:14:43.975  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:43.977  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31" -> null
                                  2023-09-08 21:14:43.989  - debug: smartmeter.0 (1086) ADD NEW DATA (169 + NEW 12)
                                  2023-09-08 21:14:43.991  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:43.995  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001" -> null
                                  2023-09-08 21:14:44.003  - debug: smartmeter.0 (1086) ADD NEW DATA (181 + NEW 16)
                                  2023-09-08 21:14:44.005  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.007  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7" -> null
                                  2023-09-08 21:14:44.016  - debug: smartmeter.0 (1086) ADD NEW DATA (197 + NEW 10)
                                  2023-09-08 21:14:44.018  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.020  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000" -> null
                                  2023-09-08 21:14:44.028  - debug: smartmeter.0 (1086) ADD NEW DATA (207 + NEW 13)
                                  2023-09-08 21:14:44.029  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.031  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:7" -> null
                                  2023-09-08 21:14:44.040  - debug: smartmeter.0 (1086) ADD NEW DATA (220 + NEW 10)
                                  2023-09-08 21:14:44.041  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.043  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(" -> null
                                  2023-09-08 21:14:44.050  - debug: smartmeter.0 (1086) ADD NEW DATA (230 + NEW 10)
                                  2023-09-08 21:14:44.051  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.052  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A��" -> null
                                  2023-09-08 21:14:44.060  - debug: smartmeter.0 (1086) ADD NEW DATA (240 + NEW 8)
                                  2023-09-08 21:14:44.062  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.063  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�" -> null
                                  2023-09-08 21:14:44.070  - debug: smartmeter.0 (1086) ADD NEW DATA (248 + NEW 11)
                                  2023-09-08 21:14:44.072  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.073  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���R" -> null
                                  2023-09-08 21:14:44.080  - debug: smartmeter.0 (1086) ADD NEW DATA (259 + NEW 8)
                                  2023-09-08 21:14:44.081  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.083  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-" -> null
                                  2023-09-08 21:14:44.090  - debug: smartmeter.0 (1086) ADD NEW DATA (267 + NEW 9)
                                  2023-09-08 21:14:44.092  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.093  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*" -> null
                                  2023-09-08 21:14:44.102  - debug: smartmeter.0 (1086) ADD NEW DATA (276 + NEW 11)
                                  2023-09-08 21:14:44.103  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.105  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg" -> null
                                  2023-09-08 21:14:44.111  - debug: smartmeter.0 (1086) ADD NEW DATA (287 + NEW 8)
                                  2023-09-08 21:14:44.113  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.114  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:8" -> null
                                  2023-09-08 21:14:44.121  - debug: smartmeter.0 (1086) ADD NEW DATA (295 + NEW 10)
                                  2023-09-08 21:14:44.123  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.124  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(" -> null
                                  2023-09-08 21:14:44.131  - debug: smartmeter.0 (1086) ADD NEW DATA (305 + NEW 9)
                                  2023-09-08 21:14:44.132  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.134  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r" -> null
                                  2023-09-08 21:14:44.141  - debug: smartmeter.0 (1086) ADD NEW DATA (314 + NEW 9)
                                  2023-09-08 21:14:44.142  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.144  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7" -> null
                                  2023-09-08 21:14:44.150  - debug: smartmeter.0 (1086) ADD NEW DATA (323 + NEW 9)
                                  2023-09-08 21:14:44.151  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.153  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(0" -> null
                                  2023-09-08 21:14:44.176  - debug: smartmeter.0 (1086) ADD NEW DATA (332 + NEW 7)
                                  2023-09-08 21:14:44.177  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.178  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)" -> null
                                  2023-09-08 21:14:44.182  - debug: smartmeter.0 (1086) ADD NEW DATA (339 + NEW 23)
                                  2023-09-08 21:14:44.184  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.186  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*d" -> null
                                  2023-09-08 21:14:44.194  - debug: smartmeter.0 (1086) ADD NEW DATA (362 + NEW 8)
                                  2023-09-08 21:14:44.196  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.197  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0" -> null
                                  2023-09-08 21:14:44.207  - debug: smartmeter.0 (1086) ADD NEW DATA (370 + NEW 12)
                                  2023-09-08 21:14:44.209  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.210  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(" -> null
                                  2023-09-08 21:14:44.217  - debug: smartmeter.0 (1086) ADD NEW DATA (382 + NEW 10)
                                  2023-09-08 21:14:44.220  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.221  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f" -> null
                                  2023-09-08 21:14:44.227  - debug: smartmeter.0 (1086) ADD NEW DATA (392 + NEW 11)
                                  2023-09-08 21:14:44.229  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.231  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*9" -> null
                                  2023-09-08 21:14:44.238  - debug: smartmeter.0 (1086) ADD NEW DATA (403 + NEW 9)
                                  2023-09-08 21:14:44.239  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.241  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8" -> null
                                  2023-09-08 21:14:44.247  - debug: smartmeter.0 (1086) ADD NEW DATA (412 + NEW 9)
                                  2023-09-08 21:14:44.249  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.251  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-" -> null
                                  2023-09-08 21:14:44.258  - debug: smartmeter.0 (1086) ADD NEW DATA (421 + NEW 9)
                                  2023-09-08 21:14:44.259  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.261  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*9" -> null
                                  2023-09-08 21:14:44.268  - debug: smartmeter.0 (1086) ADD NEW DATA (430 + NEW 9)
                                  2023-09-08 21:14:44.269  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.271  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4" -> null
                                  2023-09-08 21:14:44.279  - debug: smartmeter.0 (1086) ADD NEW DATA (439 + NEW 11)
                                  2023-09-08 21:14:44.282  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.283  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:" -> null
                                  2023-09-08 21:14:44.290  - debug: smartmeter.0 (1086) ADD NEW DATA (450 + NEW 10)
                                  2023-09-08 21:14:44.291  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.293  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(0" -> null
                                  2023-09-08 21:14:44.299  - debug: smartmeter.0 (1086) ADD NEW DATA (460 + NEW 9)
                                  2023-09-08 21:14:44.301  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.303  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kW" -> null
                                  2023-09-08 21:14:44.309  - debug: smartmeter.0 (1086) ADD NEW DATA (469 + NEW 10)
                                  2023-09-08 21:14:44.310  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.312  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1." -> null
                                  2023-09-08 21:14:44.320  - debug: smartmeter.0 (1086) ADD NEW DATA (479 + NEW 7)
                                  2023-09-08 21:14:44.321  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.323  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(" -> null
                                  2023-09-08 21:14:44.328  - debug: smartmeter.0 (1086) ADD NEW DATA (486 + NEW 11)
                                  2023-09-08 21:14:44.330  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.332  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh" -> null
                                  2023-09-08 21:14:44.338  - debug: smartmeter.0 (1086) ADD NEW DATA (497 + NEW 9)
                                  2023-09-08 21:14:44.340  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.342  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1." -> null
                                  2023-09-08 21:14:44.350  - debug: smartmeter.0 (1086) ADD NEW DATA (506 + NEW 8)
                                  2023-09-08 21:14:44.352  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.353  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(" -> null
                                  2023-09-08 21:14:44.360  - debug: smartmeter.0 (1086) ADD NEW DATA (514 + NEW 12)
                                  2023-09-08 21:14:44.361  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.363  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)" -> null
                                  2023-09-08 21:14:44.369  - debug: smartmeter.0 (1086) ADD NEW DATA (526 + NEW 9)
                                  2023-09-08 21:14:44.371  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.372  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2" -> null
                                  2023-09-08 21:14:44.380  - debug: smartmeter.0 (1086) ADD NEW DATA (535 + NEW 9)
                                  2023-09-08 21:14:44.382  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.384  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2.0*255(ve" -> null
                                  2023-09-08 21:14:44.391  - debug: smartmeter.0 (1086) ADD NEW DATA (544 + NEW 11)
                                  2023-09-08 21:14:44.392  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.394  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2.0*255(ver.03,432F,2" -> null
                                  2023-09-08 21:14:44.401  - debug: smartmeter.0 (1086) ADD NEW DATA (555 + NEW 9)
                                  2023-09-08 21:14:44.402  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.404  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r" -> null
                                  2023-09-08 21:14:44.412  - debug: smartmeter.0 (1086) ADD NEW DATA (564 + NEW 9)
                                  2023-09-08 21:14:44.413  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.415  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.9" -> null
                                  2023-09-08 21:14:44.422  - debug: smartmeter.0 (1086) ADD NEW DATA (573 + NEW 11)
                                  2023-09-08 21:14:44.423  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.425  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F6" -> null
                                  2023-09-08 21:14:44.433  - debug: smartmeter.0 (1086) ADD NEW DATA (584 + NEW 9)
                                  2023-09-08 21:14:44.434  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.436  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:9" -> null
                                  2023-09-08 21:14:44.443  - debug: smartmeter.0 (1086) ADD NEW DATA (593 + NEW 10)
                                  2023-09-08 21:14:44.444  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.446  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255" -> null
                                  2023-09-08 21:14:44.453  - debug: smartmeter.0 (1086) ADD NEW DATA (603 + NEW 9)
                                  2023-09-08 21:14:44.454  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.456  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000" -> null
                                  2023-09-08 21:14:44.462  - debug: smartmeter.0 (1086) ADD NEW DATA (612 + NEW 6)
                                  2023-09-08 21:14:44.465  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:44.467  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "1-0:1.8.0*2MM\t���ºr���SZ]��\r\n1-0:2.8.0*255(000000.0000*kWh)\r\n1-0:16.7.0*255(000398*W)\r\n1-0:32.7.0*255(227.6*V)\r\n1-0:52.7.0*255(227.6*V)\r\n1-0:72.7.0*255(229.8*V)\r\n1-0:31.7.0*255(001.73*A)\r\n1-0:51.7.0*255(000.05*A)\r\n1-0:71.7.0*255(000.17*A�á���Êr�r�R���B���Rf���\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(019*deg)\r\n1-0:81.7.15*255(054*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\u000f1-�:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)\r\n1-0:1.8.0*99(04355.7*kWh)\r\n1-0:1.8.0*100(17787.5*kWh)\r\n1-0:0.2.0*255(ver.03,432F,20170504)\r\n1-0:96.90.2*255(0F66)\r\n1-0:97.97.0*255(00000000)\r\n!\r\n" -> null
                                  2023-09-08 21:14:44.872  - debug: smartmeter.0 (1086) MESSAGE TIMEOUT TRIGGERED
                                  2023-09-08 21:14:44.874  - debug: smartmeter.0 (1086) Error: No or too long answer from Serial Device after last request.
                                  2023-09-08 21:14:44.877  - warn: smartmeter.0 (1086) No or too long answer from Serial Device after last request.
                                  2023-09-08 21:14:44.878  - debug: smartmeter.0 (1086) Error: No or too long answer from Serial Device after last request.
                                  2023-09-08 21:14:44.879  - debug: smartmeter.0 (1086) Transport Reset!! Restart = true
                                  2023-09-08 21:14:44.885  - debug: smartmeter.0 (1086) SERIALPORT CLOSE
                                  2023-09-08 21:14:44.886  - debug: smartmeter.0 (1086) SCHEDULE NEXT RUN IN 6s
                                  2023-09-08 21:14:50.887  - debug: smartmeter.0 (1086) CREATE SERIALPORT: 9600 8 1 none
                                  2023-09-08 21:14:50.895  - debug: smartmeter.0 (1086) SERIALPORT OPEN
                                  2023-09-08 21:14:50.898  - debug: smartmeter.0 (1086) ADD NEW DATA (0 + NEW 3)
                                  2023-09-08 21:14:50.900  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.902  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*25" -> null
                                  2023-09-08 21:14:50.904  - debug: smartmeter.0 (1086) SET MESSAGE TIMEOUT TIMER: 1000
                                  2023-09-08 21:14:50.909  - debug: smartmeter.0 (1086) ADD NEW DATA (3 + NEW 7)
                                  2023-09-08 21:14:50.910  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.913  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8" -> null
                                  2023-09-08 21:14:50.920  - debug: smartmeter.0 (1086) ADD NEW DATA (10 + NEW 9)
                                  2023-09-08 21:14:50.922  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.923  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:" -> null
                                  2023-09-08 21:14:50.929  - debug: smartmeter.0 (1086) ADD NEW DATA (19 + NEW 11)
                                  2023-09-08 21:14:50.931  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.933  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(" -> null
                                  2023-09-08 21:14:50.940  - debug: smartmeter.0 (1086) ADD NEW DATA (30 + NEW 9)
                                  2023-09-08 21:14:50.942  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.944  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r" -> null
                                  2023-09-08 21:14:50.949  - debug: smartmeter.0 (1086) ADD NEW DATA (39 + NEW 10)
                                  2023-09-08 21:14:50.951  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.952  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7." -> null
                                  2023-09-08 21:14:50.958  - debug: smartmeter.0 (1086) ADD NEW DATA (49 + NEW 7)
                                  2023-09-08 21:14:50.960  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.962  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(2" -> null
                                  2023-09-08 21:14:50.968  - debug: smartmeter.0 (1086) ADD NEW DATA (56 + NEW 9)
                                  2023-09-08 21:14:50.969  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.971  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n" -> null
                                  2023-09-08 21:14:50.976  - debug: smartmeter.0 (1086) ADD NEW DATA (65 + NEW 8)
                                  2023-09-08 21:14:50.978  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.979  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7" -> null
                                  2023-09-08 21:14:50.984  - debug: smartmeter.0 (1086) ADD NEW DATA (73 + NEW 7)
                                  2023-09-08 21:14:50.986  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.987  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(" -> null
                                  2023-09-08 21:14:50.993  - debug: smartmeter.0 (1086) ADD NEW DATA (80 + NEW 8)
                                  2023-09-08 21:14:50.994  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:50.996  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A" -> null
                                  2023-09-08 21:14:51.002  - debug: smartmeter.0 (1086) ADD NEW DATA (88 + NEW 8)
                                  2023-09-08 21:14:51.003  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.004  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:5" -> null
                                  2023-09-08 21:14:51.010  - debug: smartmeter.0 (1086) ADD NEW DATA (96 + NEW 7)
                                  2023-09-08 21:14:51.012  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.013  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*2" -> null
                                  2023-09-08 21:14:51.019  - debug: smartmeter.0 (1086) ADD NEW DATA (103 + NEW 9)
                                  2023-09-08 21:14:51.020  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.022  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04" -> null
                                  2023-09-08 21:14:51.027  - debug: smartmeter.0 (1086) ADD NEW DATA (112 + NEW 8)
                                  2023-09-08 21:14:51.029  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.030  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0" -> null
                                  2023-09-08 21:14:51.037  - debug: smartmeter.0 (1086) ADD NEW DATA (120 + NEW 11)
                                  2023-09-08 21:14:51.038  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.040  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255" -> null
                                  2023-09-08 21:14:51.044  - debug: smartmeter.0 (1086) ADD NEW DATA (131 + NEW 5)
                                  2023-09-08 21:14:51.046  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.047  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000." -> null
                                  2023-09-08 21:14:51.053  - debug: smartmeter.0 (1086) ADD NEW DATA (136 + NEW 7)
                                  2023-09-08 21:14:51.054  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.056  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n" -> null
                                  2023-09-08 21:14:51.062  - debug: smartmeter.0 (1086) ADD NEW DATA (143 + NEW 7)
                                  2023-09-08 21:14:51.064  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.066  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81." -> null
                                  2023-09-08 21:14:51.072  - debug: smartmeter.0 (1086) ADD NEW DATA (150 + NEW 11)
                                  2023-09-08 21:14:51.075  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.077  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121" -> null
                                  2023-09-08 21:14:51.083  - debug: smartmeter.0 (1086) ADD NEW DATA (161 + NEW 10)
                                  2023-09-08 21:14:51.084  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.085  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0" -> null
                                  2023-09-08 21:14:51.092  - debug: smartmeter.0 (1086) ADD NEW DATA (171 + NEW 8)
                                  2023-09-08 21:14:51.093  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.095  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*" -> null
                                  2023-09-08 21:14:51.101  - debug: smartmeter.0 (1086) ADD NEW DATA (179 + NEW 7)
                                  2023-09-08 21:14:51.102  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.103  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240" -> null
                                  2023-09-08 21:14:51.109  - debug: smartmeter.0 (1086) ADD NEW DATA (186 + NEW 8)
                                  2023-09-08 21:14:51.110  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.111  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1" -> null
                                  2023-09-08 21:14:51.117  - debug: smartmeter.0 (1086) ADD NEW DATA (194 + NEW 7)
                                  2023-09-08 21:14:51.119  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.120  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7" -> null
                                  2023-09-08 21:14:51.142  - debug: smartmeter.0 (1086) ADD NEW DATA (201 + NEW 8)
                                  2023-09-08 21:14:51.144  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.145  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(0" -> null
                                  2023-09-08 21:14:51.152  - debug: smartmeter.0 (1086) ADD NEW DATA (209 + NEW 24)
                                  2023-09-08 21:14:51.154  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.156  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255" -> null
                                  2023-09-08 21:14:51.164  - debug: smartmeter.0 (1086) ADD NEW DATA (233 + NEW 12)
                                  2023-09-08 21:14:51.166  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.167  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1" -> null
                                  2023-09-08 21:14:51.173  - debug: smartmeter.0 (1086) ADD NEW DATA (245 + NEW 9)
                                  2023-09-08 21:14:51.175  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.176  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.2" -> null
                                  2023-09-08 21:14:51.182  - debug: smartmeter.0 (1086) ADD NEW DATA (254 + NEW 8)
                                  2023-09-08 21:14:51.183  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.184  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(06" -> null
                                  2023-09-08 21:14:51.190  - debug: smartmeter.0 (1086) ADD NEW DATA (262 + NEW 7)
                                  2023-09-08 21:14:51.192  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.193  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r" -> null
                                  2023-09-08 21:14:51.199  - debug: smartmeter.0 (1086) ADD NEW DATA (269 + NEW 8)
                                  2023-09-08 21:14:51.200  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.202  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14." -> null
                                  2023-09-08 21:14:51.207  - debug: smartmeter.0 (1086) ADD NEW DATA (277 + NEW 8)
                                  2023-09-08 21:14:51.209  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.210  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(" -> null
                                  2023-09-08 21:14:51.216  - debug: smartmeter.0 (1086) ADD NEW DATA (285 + NEW 7)
                                  2023-09-08 21:14:51.217  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.219  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz" -> null
                                  2023-09-08 21:14:51.224  - debug: smartmeter.0 (1086) ADD NEW DATA (292 + NEW 10)
                                  2023-09-08 21:14:51.226  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.227  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8" -> null
                                  2023-09-08 21:14:51.237  - info: host.raspberrypi "system.adapter.smartmeter.0" disabled
                                  2023-09-08 21:14:51.232  - debug: smartmeter.0 (1086) ADD NEW DATA (302 + NEW 6)
                                  2023-09-08 21:14:51.234  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.235  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8.0*96(" -> null
                                  2023-09-08 21:14:51.241  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
                                  2023-09-08 21:14:51.241  - debug: smartmeter.0 (1086) ADD NEW DATA (308 + NEW 8)
                                  2023-09-08 21:14:51.242  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.244  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8.0*96(00011.8*" -> null
                                  2023-09-08 21:14:51.249  - debug: smartmeter.0 (1086) ADD NEW DATA (316 + NEW 8)
                                  2023-09-08 21:14:51.251  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.252  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8.0*96(00011.8*kWh)\r\n1-" -> null
                                  2023-09-08 21:14:51.258  - debug: smartmeter.0 (1086) ADD NEW DATA (324 + NEW 8)
                                  2023-09-08 21:14:51.260  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.261  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*" -> null
                                  2023-09-08 21:14:51.266  - debug: smartmeter.0 (1086) ADD NEW DATA (332 + NEW 9)
                                  2023-09-08 21:14:51.268  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.269  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080." -> null
                                  2023-09-08 21:14:51.275  - debug: smartmeter.0 (1086) ADD NEW DATA (341 + NEW 7)
                                  2023-09-08 21:14:51.277  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.278  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r" -> null
                                  2023-09-08 21:14:51.283  - debug: smartmeter.0 (1086) ADD NEW DATA (348 + NEW 8)
                                  2023-09-08 21:14:51.284  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.286  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8" -> null
                                  2023-09-08 21:14:51.292  - debug: smartmeter.0 (1086) ADD NEW DATA (356 + NEW 7)
                                  2023-09-08 21:14:51.294  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.296  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(0" -> null
                                  2023-09-08 21:14:51.303  - debug: smartmeter.0 (1086) ADD NEW DATA (363 + NEW 11)
                                  2023-09-08 21:14:51.305  - debug: smartmeter.0 (1086) CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                                  2023-09-08 21:14:51.306  - debug: smartmeter.0 (1086) MATCH-RESULT SIGNON: "*255(227.8*V)\r\n1-0:52.7.0*255(227.3*V)\r\n1-0:72.7.0*255(229.9*V)\r\n1-0:31.7.0*255(001.82*A)\r\n1-0:51.7.0*255(000.04*A)\r\n1-0:71.7.0*255(000.17*A)\r\n1-0:81.7.1*255(121*deg)\r\n1-0:81.7.2*255(240*deg)\r\n1-0:81.7.4*255(021*deg)\r\n1-0:81.7.15*255(055*deg)\r\n1-0:81.7.26*255(060*deg)\r\n1-0:14.7.0*255(50.0*Hz)\r\n1-0:1.8.0*96(00011.8*kWh)\r\n1-0:1.8.0*97(00080.4*kWh)\r\n1-0:1.8.0*98(00261.7*kWh)" -> null
                                  2023-09-08 21:14:51.313  - info: smartmeter.0 (1086) Got terminate signal TERMINATE_YOURSELF
                                  2023-09-08 21:14:51.320  - debug: smartmeter.0 (1086) NEW DATA AFTER STOP ... ignore
                                  2023-09-08 21:14:51.326  - debug: smartmeter.0 (1086) SERIALPORT CLOSE
                                  2023-09-08 21:14:51.329  - info: smartmeter.0 (1086) terminating
                                  2023-09-08 21:14:51.332  - debug: smartmeter.0 (1086) Plugin sentry destroyed
                                  2023-09-08 21:14:51.334  - info: smartmeter.0 (1086) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2023-09-08 21:14:51.353  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 send kill signal
                                  2023-09-08 21:14:51.949  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  Hier noch die zugehörige Konfiguration, falls doch noch wer ne Idee hat
                                  Auch über cat erhalte ich sinnvolle und vollständige Daten:
                                  Leider ist die smartmeter instanz noch immer nicht grün. Ich schaue mir deinen Link mal an
                                  • T tonishi
                                    #128
                                    @tonishi sagte in Hichi IR Lesekopf verbindet sich nicht mit Smartmeter:
                                    nicht das cat noch die Schnittstelle blockiert
                                      tonishi
                                      #129
                                      @homoran ich habe den Pi nochmal neu gestartet, dann dürfte ja nichts den USB Port blockieren --> leider mit dem gleichen Ergebnis
                                        tonishi
                                        #130
                                        @homoran WTF -> Adapter deinstalliert und neu installiert -> und zack nun funzt alles. Hammer vielen vielen Dank nochmal für deine geduldige Hilfe @Homoran!
                                        • apollon77A Offline
                                          #131
                                          Ich finde es spitze das Ihr das alles ohne mich hinbekommt. Danke, nimmt mir viel Arbeit ab. Auch Danke @Homoran und alle anderen die Helfen!
