  4. [influxDB] - Packed 0MB so far...
    5.2k
25 Beiträge 5 Kommentatoren 846 Aufrufe 4 Beobachtet
    @sam007
    Kiste auf Stand patchen.
    Und für Backitup den SENTRY-Dienst abschalten.
    sudo apt update
    apt policy influxdb*
    sagt?
    Sam007
    Ich habe das versucht das Update zu machen habe Fehler bekommen...
    Wo stelle ich den Service den ab?
    • S Sam007
      @sam007 sagte in [influxDB] - Packed 0MB so far...:
      oha, so schlimme?
        oha, so schlimme?
        Sam007
        Hallo ich habe das Update durchgeführt aber einige Meldungen bekommen die ich so noch nie hatte. :
        sudo apt-get update
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Get:2 https://repos.influxdata.com/debian stretch InRelease [7,039 B]
        Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Get:5 https://packages.grafana.com/enterprise/deb stable InRelease [5,984 B]
        Err:2 https://repos.influxdata.com/debian stretch InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        Err:5 https://packages.grafana.com/enterprise/deb stable InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        Reading package lists... Done
        W: GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        E: The repository 'https://repos.influxdata.com/debian stretch InRelease' is not signed.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        die Datenbank Infos :
        influxdb-client:
          Installed: (none)
          Candidate: 1.6.7~rc0-1
          Version table:
             1.6.7~rc0-1 500
        influxdb-dev:
          Installed: (none)
          Candidate: (none)
          Version table:
        influxdb:
          Installed: 1.6.7~rc0-1
          Version table:
         *** 1.6.7~rc0-1 500
        pi@IOBrocker:~ $ ^C
        werde wohl mal überlegen alles neu zu machen und auf Dockers zu gehen...
        eier Sam
        DJMarc75D Thomas BraunT HomoranH 3 Antworten Letzte Antwort
        • S Sam007
          sudo apt-get update
          influxdb-client:
            Installed: (none)
            Version table:
               1.6.7~rc0-1 500
          influxdb-dev:
            Installed: (none)
            Candidate: (none)
            Version table:
          influxdb:
            Version table:
           *** 1.6.7~rc0-1 500
          pi@IOBrocker:~ $ ^C
          eier Sam
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          ja, so mit weniger als Halbwissen macht das auch total Sinn ;)
          Lehrling seit 1975 !!!
          • S Sam007
            sudo apt-get update
            influxdb-client:
              Installed: (none)
              Version table:
                 1.6.7~rc0-1 500
            influxdb-dev:
              Installed: (none)
              Candidate: (none)
              Version table:
            influxdb:
              Version table:
             *** 1.6.7~rc0-1 500
            pi@IOBrocker:~ $ ^C
            eier Sam
            @sam007
            Kein Wunder...
            Du knallst da eine Quelle für Stretch in dein Bullseye rein.
            Das geht nicht (gut). Noch dazu fehlt der key.
            Wenn du die Version der Distribution verwenden willst fehlt da noch
            apt install influxdb-client
            Dann schmeißt du aber das influx-Repo raus. Und Grafana muss so oder so mit aktuellem Key versehen werden.
            • S Sam007
              sudo apt-get update
              influxdb-client:
                Installed: (none)
                Version table:
                   1.6.7~rc0-1 500
              influxdb-dev:
                Installed: (none)
                Candidate: (none)
                Version table:
              influxdb:
                Version table:
               *** 1.6.7~rc0-1 500
              pi@IOBrocker:~ $ ^C
              eier Sam
              hast du aber schon gelesen?
              auch nach Lösungen im Forum gesucht?
                Sam007
                Dachte ich hätte den KEY hinterlegt. Aber dann hat er das nich genommen.
                ok dann werde ich das alles neu aufsetzten.
                aber dann über Dockers und auf einer anderen SD Carte.
                Laufen tut das ja so angezeigt werden die Daten, das ist schonmal gut :)
                Da gibt es ja eine gute Anleitung zu zum IO Brocker.
                Was ich ja drauf haben will ist ja nur
                • IO Brocker
                • eine DB Influx ist einfach :)
                • Grafana für die Anzeige.
                Sollte doch einfach machbar sein.
                IO Brocker Link
                https://docs.buanet.de/de/iobroker-docker-image/docs/#docker-healthcheck
                Sage schonmal Danke.
                nächstes mal werde ich alles Daten zu mein System mit reinsetzten ( dachte das das so ok ist)
                • S Sam007
                  • IO Brocker
                  IO Brocker Link
                  Das sehe ich...
                    Das sehe ich...
                    Sam007
                    Einfacher als MYSQL meinte ich.
                    den da muss ich ja einiges mehr machen oder ist das anders ?
                    Die DB tut ja auch, warum das jetzt nicht geht mit den Beckup k.a.
                    Und mit Dockers kann man ja den ganzen Container sichern...
                    • S Sam007
                      Weil du da das falsche Zeug unvollständig installiert hast.
                      Mit so wenig Rüstzeug wirst du auch im 'nächsten Level' "Docker" nicht weit kommen. Der setzt imho ein paar Grundkenntnisse bei Linux voraus.
                        Sam007
                        schrieb am zuletzt editiert von Sam007
                        Ok dan versuche ich das mal so zu sagen.
                        Linux habe ich wenn überhaupt Grundkentnisse. (Mal einen Linux Lehrgang beim Bund gehabt 2002 oder so)
                        Und ich gehe dan stück für stück Anleitungen durch die ich Online finde.
                        Ich gehe natürlich davon aus das diese Anleitungen komplett sind und des dann funktionieren sollte.
                        So wie ich dich verstanden habe rätst du mir dazu das neu "normal" zu Installieren und dann das System sauber zu haben. Wenn ich das alles sauber habe ist der nächste Schritt Dockers.
                        DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                        • S Sam007
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          Ohne Grundkenntnisse in Linux dann gleich auf Docker ?
                          Du bist ja ein Spassvogel ;)
                          • DJMarc75D DJMarc75
                            Sam007
                            @djmarc75
                            naja man muss sich ja mal Ziele setzten :)
                            • S Sam007
                              @sam007
                              Wäre sinnvoll. Docker zieht noch eine zusätzliche Ebene in das Konstrukt 'Linux' ein. Da hilft es ungemein, wenn man die Basics versteht.
                              Anleitungen, die zu einem Repo, das auf 'stretch' basiert, führen sind zu alt.
                              Davon würde ich nicht unbedingt ausgehen. Oftmals setzen Anleitungen vorhandenes Grundwissen voraus.
                              Willst du jetzt Hilfe oder mit Docker rummachen?
                              S Meister MopperM 2 Antworten Letzte Antwort
                                @sam007
                                Sam007
                                da würde ich mal schauen das ich mich vorher mal reinlese was das alles so aufsich hat.
                                Den das System an sich ist ja Interesant.
                                Aber ich möchte eigentlich kein Inflix sondern MYSQL haben.
                                Das heißt ja auf den PI etwas anders.
                                Und das werde ich jetzt so angehen.
                                • S Sam007
                                  Nennt sich mariadb und ist ein Fork von mysql.
                                    @sam007
                                    Meister MopperM Online
                                    Meister Mopper
                                    @thomas-braun sagte in [influxDB] - Packed 0MB so far...:
                                    Man kann ja lesen, dass du native unterwegs bist, aber ich finde auch, dass du die Virtualisierung (Proxmox, Docker, Kubernetes pp.) daneben nicht ignorieren solltest, die IT setzt zumindest derzeit weltweit darauf.
                                    Aber klar, ich gebe dir absolut recht, dass dies Wissen benötigt, was ich in diesem thread beim Protagonisten tatsächlich auch vermisse.
                                    Live goes on! 😊
                                    Wer hat's gesagt?
                                    Liebe nicht das Bekannte, und hasse nicht das Unbekannte.
                                    Proxmox und HA ...
                                    Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                                    S Thomas BraunT 2 Antworten Letzte Antwort
                                      Live goes on! 😊
                                      Wer hat's gesagt?
                                      Sam007
                                      @meister-mopper
                                      und nicht erschlagen wenn mal eine dumme Frage kommt.
                                      Was ich mal damals mit Linux gemacht habe war ein Systemadministrator aber schon 21 Jahre her und seit dem wenig damit gemacht...
                                        Live goes on! 😊
                                        Wer hat's gesagt?
                                        @meister-mopper sagte in [influxDB] - Packed 0MB so far...:
                                        Tu ich nicht. Ich sehe nur für den ioBroker da keine unbedingte Notwendigkeit oder einen Vorteil den einzudosen. Macht es nur unnötig komplexer.
                                        Führt aber zu OffTopic hier.
                                        • S Sam007
                                          @meister-mopper
                                          Meister Mopper
                                          Ich bin bester Hoffnung, dass ich niemanden erschlagen habe.
                                          Proxmox und HA ...
