  4. Nach Systemaktualisierung Modbus Fehler 25
35 Beiträge 5 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • D Dooley_76
    @dooley_76
    Hier noch die diag, falls es helfen sollte:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     14:26:08 up 17 min,  1 user,  load average: 0.07, 0.20, 0.28
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=54.8'C
    volt=1.3813V
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-22 14:26:08 CEST
               Universal time: Tue 2023-08-22 12:26:08 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    Holger
    /home/Holger
    Holger adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M         79M        223M        0.0K        606M        765M
    Swap:            99M          0B         99M
    Total:          1.0G         79M        323M
              909 M total memory
               79 M used memory
              125 M active memory
              445 M inactive memory
              223 M free memory
               39 M buffer memory
              567 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  2.0G   26G   7% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  976K  181M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    [Tue Aug 22 14:08:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=26b2c4cb-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Aug 22 14:08:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Aug 22 14:08:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Aug 22 14:08:58 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    476M    /var/
    180M    /var/cache
    174M    /var/cache/apt
    147M    /var/lib
    123M    /var/lib/apt/lists
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    du: cannot access '/opt/iobroker/backups/': No such file or directory
    /opt/iobroker/iobroker-data:
    du: cannot access '/opt/iobroker/iobroker-data/': No such file or directory
    find: '/opt/iobroker/iobroker-data': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    find: '/opt/iobroker/node_modules': No such file or directory
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1080
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:23:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.17.1
      throw err;
      requireStack: []
    Node.js v18.17.1
    Core adapters versions
      throw err;
      requireStack: []
    Node.js v18.17.1
    js-controller:
      throw err;
      requireStack: []
    Node.js v18.17.1
    admin:
      throw err;
      requireStack: []
    Node.js v18.17.1
    javascript:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
    npm ERR! A complete log of this run can be found in: /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
    Adapters from github:   0
    Adapter State
      throw err;
      requireStack: []
    Node.js v18.17.1
      throw err;
      requireStack: []
    Node.js v18.17.1
    ioBroker-Repositories
      throw err;
      requireStack: []
    Node.js v18.17.1
    Installed ioBroker-Instances
      throw err;
      requireStack: []
    Node.js v18.17.1
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12883      474/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12885      474/sshd: /usr/sbin
    udp        0      0 0.0.0.0:60377           0.0.0.0:*                           108        13975      354/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14343      602/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13973      354/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          1654       602/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        13974      354/avahi-daemon: r
    udp6       0      0 :::43804                :::*                                108        13976      354/avahi-daemon: r
    tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory
    Dooley_76
    @dooley_76
    und hier noch das komplette Log-File:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Docker          : false
    Release:        11
    Codename:       bullseye
    VERSION_ID="11"
    ID=debian
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    temp=54.8'C
    volt=1.3813V
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    Holger
    /home/Holger
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Swap:            99M          0B         99M
              909 M total memory
               79 M used memory
              125 M active memory
              223 M free memory
               39 M buffer memory
              567 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /var:
    476M    /var/
    180M    /var/cache
    174M    /var/cache/apt
    147M    /var/lib
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Version table:
    ioBroker Status
      throw err;
      requireStack: []
    Node.js v18.17.1
      throw err;
      requireStack: []
    Node.js v18.17.1
      throw err;
      requireStack: []
    Node.js v18.17.1
    js-controller:
      throw err;
      requireStack: []
    Node.js v18.17.1
    admin:
      throw err;
      requireStack: []
    Node.js v18.17.1
    javascript:
    Adapter State
      throw err;
      requireStack: []
    Node.js v18.17.1
      throw err;
      requireStack: []
    Node.js v18.17.1
      throw err;
      requireStack: []
    Node.js v18.17.1
      throw err;
      requireStack: []
    Node.js v18.17.1
    Objects and States
    Objects:        0
    States:         0
    Pending Updates: 0
    iob diag has finished.
    Press any key for a summary
    Holger@raspberryiobroker:~ $ cd /home/Holger/.npm/_logs
    Holger@raspberryiobroker:~/.npm/_logs $ dir -a
    .                                     2023-08-22T12_26_10_875Z-debug-0.log
    ..                                    2023-08-22T12_26_12_556Z-debug-0.log
    2023-08-22T12_11_53_157Z-debug-0.log  2023-08-22T12_26_14_191Z-debug-0.log
    2023-08-22T12_11_54_801Z-debug-0.log  2023-08-22T12_26_15_825Z-debug-0.log
    2023-08-22T12_14_59_986Z-debug-0.log  2023-08-22T12_26_18_961Z-debug-0.log
    Holger@raspberryiobroker:~/.npm/_logs $ mcedit 2023-08-22T12_26_18_961Z-debug-0.log
    -bash: mcedit: command not found
    Holger@raspberryiobroker:~/.npm/_logs $ ^C
    Holger@raspberryiobroker:~/.npm/_logs $ sudo edit 2023-08-22T12_26_18_961Z-debug-0.log
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@9.6.7
    2 info using node@v18.17.1
    3 timing npm:load:whichnode Completed in 6ms
    4 timing config:load:defaults Completed in 11ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
    6 timing config:load:builtin Completed in 6ms
    7 timing config:load:cli Completed in 14ms
    8 timing config:load:env Completed in 3ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 9ms
    10 timing config:load:project Completed in 32ms
    11 timing config:load:file:/home/Holger/.npmrc Completed in 2ms
    12 timing config:load:user Completed in 3ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:setEnvs Completed in 6ms
    16 timing config:load Completed in 80ms
    17 timing npm:load:configload Completed in 81ms
    18 timing npm:load:mkdirpcache Completed in 2ms
    19 timing npm:load:mkdirplogs Completed in 1ms
    20 verbose title npm ls
    21 verbose argv "ls"
    22 timing npm:load:setTitle Completed in 6ms
    23 timing config:load:flatten Completed in 16ms
    24 timing npm:load:display Completed in 21ms
    25 verbose logfile logs-max:10 dir:/home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-
    26 verbose logfile /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
    27 timing npm:load:logFile Completed in 50ms
    28 timing npm:load:timers Completed in 1ms
    29 timing npm:load:configScope Completed in 0ms
    30 timing npm:load Completed in 171ms
    31 timing arborist:ctor Completed in 4ms
    32 silly logfile done cleaning log files
    33 timing command:ls Completed in 1010ms
    34 verbose stack Error: missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
    34 verbose stack missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
    34 verbose stack missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
    34 verbose stack missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
    34 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:202:9)
    34 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:89:5)
    35 verbose cwd /opt/iobroker
    36 verbose Linux 6.1.21-v8+
    37 verbose node v18.17.1
    38 verbose npm  v9.6.7
    39 error code ELSPROBLEMS
    40 error missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
    40 error missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
    40 error missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
    40 error missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
    41 verbose exit 1
    42 timing npm Completed in 1352ms
    43 verbose code 1
    44 error A complete log of this run can be found in: /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
    "/home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log" 53 lines, 2732 bytes
    • D Dooley_76
      @dooley_76
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=54.8'C
      volt=1.3813V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      Holger
      /home/Holger
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
                909 M total memory
                 79 M used memory
                125 M active memory
                223 M free memory
                 39 M buffer memory
                567 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      476M    /var/
      180M    /var/cache
      174M    /var/cache/apt
      147M    /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
        throw err;
        requireStack: []
      Node.js v18.17.1
        throw err;
        requireStack: []
      Node.js v18.17.1
        throw err;
        requireStack: []
      Node.js v18.17.1
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.17.1
      admin:
        throw err;
        requireStack: []
      Node.js v18.17.1
      javascript:
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.17.1
        throw err;
        requireStack: []
      Node.js v18.17.1
        throw err;
        requireStack: []
      Node.js v18.17.1
        throw err;
        requireStack: []
      Node.js v18.17.1
      Objects and States
      Objects:        0
      States:         0
      Pending Updates: 0
      41 verbose exit 1
      43 verbose code 1
      @dooley_76
      Der Server lässt dich nicht, warum auch immer.
      ECONNREFUSED 2606:4700::6810:b22:443
        @dooley_76
        Dooley_76
        Ok, Danke für die Info. Noch eine Idee, was ich hier bei mir probieren könnte oder bin ich
        jetzt erst einmal "lahmgelegt"?
        Oder doch wieder ein Image nehmen und dann nicht auf die aktuellsten Versionen gehen? Wobei
        das ja eigentlich genau der Grund war ...
        Auf jeden Fall nochmal Danke für die Mühen :)
        • D Dooley_76
          @dooley_76 sagte in Nach Systemaktualisierung Modbus Fehler 25:
          Das nutzt dir natürlich bei 'Netzwerktrouble' nix.
          Hast du irgendwas 'ungewöhnliches' da bei dir laufen?
          pihole? Sonst irgendwas in der Richtung?
            Dooley_76
            Nur einen anderen Pi, auf der "Solaranzeige" läuft ( https://solaranzeige.de/phpBB3/solaranzeige.php )
            Aber der ist nur für die InfluxDB und Darstellung in Grafana zuständig. Die Darstellungen hatte ich dann
            bei IOBroker eingebunden.
            Und der läuft aber auch schon ewig und war auch schon bei der ersten Installation von IOB am Laufen ...
            Mit anderen Worten: Gegenüber der ersten Installation habe ich nichts verändert. Es sei denn, der Shelly
            kann hier noch etwas mit zu tun haben, denn der ist seit der letzten Installation neu dazu gekommen.
            • D Dooley_76
              Dooley_76
              @dooley_76
              Ich glaub' ich werde heute Abend mal alles andere an Netzwerk abhängen inkl. WLAN deaktivieren, so das nur noch mein Computer und der Pi noch "online" sind und mal sehen, was dann passiert. ..
              • D Dooley_76
                @dooley_76
                Jetzt bin ich ja "beruhigt" ;)) Ich hänge wieder da, wo es vorher auch schon nicht weiter ging, wenn ich IOBroker ( per curl -sLf https://iobroker.net/install.sh | bash - ) aufspiele:
                Wenn ich nichts mache, geht es nach ~ 5-6 Minuten "weiter" und es kommt dieses hier:
                Holger @raspberryiobroker: ~$ curl - sLf https://iobroker.net/install.sh | bash -
                library: loaded
                Library version = 2022 - 12 - 09
                    Welcome to the ioBroker installer!
                    Installer version: 2023-04-16
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/4)
                Reading package lists... Done
                    Node.js not found. Installing...
                ## Installing the NodeSource Node.js 18.x repo...
                ## Populating apt-get cache...
                + apt-get update
                ## Confirming "bullseye" is supported...
                + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/bullseye/Re            lease'
                ## Adding the NodeSource signing key to your keyring...
                + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor |             tee /usr/share/keyrings/nodesource.gpg >/dev/null
                ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesourc            e.com/node_18.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodes            ource.com/node_18.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                ## Running `apt-get update` for you...
                + apt-get update
                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                Get:2 https://deb.nodesource.com/node_18.x bullseye InRelease [4,586 B]
                Hit:4 http://deb.debian.org/debian bullseye InRelease
                Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                Get:6 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages [776 B]
                Get:7 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages [787 B]
                Fetched 6,149 B in 2s (2,634 B/s)
                ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                ## You may also need development tools to build native addons:
                     sudo apt-get install gcc g++ make
                ## To install the Yarn package manager, run:
                     curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo te            e /usr/share/keyrings/yarnkey.gpg >/dev/null
                     echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.co            m/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                     sudo apt-get update && sudo apt-get install yarn
                Installed nodejs
                Node.js Installed successfully!
                Changing npm registry to https://registry.npmjs.org
                Installed acl
                Installed gcc-c++
                Installed libavahi-compat-libdnssd-dev
                Installed libudev-dev
                Installed libpam0g-dev
                Installed git
                Installed libcairo2-dev
                Installed libpango1.0-dev
                Installed libjpeg-dev
                Installed libgif-dev
                Installed librsvg2-dev
                Installed cmake
                    Creating ioBroker user and directory (2/4)
                User iobroker created
                Directory /opt/iobroker created
                    Installing ioBroker (3/4)
                npm ERR! code ECONNREFUSED
                npm ERR! syscall connect
                npm ERR! errno ECONNREFUSED
                npm ERR! FetchError: request to https://registry.npmjs.org/iobroker.admin failed            , reason: connect ECONNREFUSED 2606:4700::6810:b22:443
                npm ERR!     at ClientRequest.<anonymous> (/usr/lib/node_modules/npm/node_module            s/minipass-fetch/lib/index.js:130:14)
                npm ERR!     at ClientRequest.emit (node:events:514:28)
                npm ERR!     at TLSSocket.socketErrorListener (node:_http_client:501:9)
                npm ERR!     at TLSSocket.emit (node:events:526:35)
                npm ERR!     at emitErrorNT (node:internal/streams/destroy:151:8)
                npm ERR!     at emitErrorCloseNT (node:internal/streams/destroy:116:3)
                npm ERR!     at process.processTicksAndRejections (node:internal/process/task_qu            eues:82:21)
                npm ERR!  FetchError: request to https://registry.npmjs.org/iobroker.admin faile            d, reason: connect ECONNREFUSED 2606:4700::6810:b22:443
                npm ERR!     at process.processTicksAndRejections (node:internal/process/task_qu            eues:82:21) {
                npm ERR!   code: 'ECONNREFUSED',
                npm ERR!   errno: 'ECONNREFUSED',
                npm ERR!   syscall: 'connect',
                npm ERR!   address: '2606:4700::6810:b22',
                npm ERR!   port: 443,
                npm ERR!   type: 'system',
                npm ERR!   requiredBy: '.'
                npm ERR! }
                npm ERR!
                npm ERR! If you are behind a proxy, please make sure that the
                npm ERR! 'proxy' config is set properly.  See: 'npm help config'
                npm ERR! A complete log of this run can be found in: /home/Holger/.npm/_logs/202            3-08-22T12_14_59_986Z-debug-0.log
                    Finalizing installation (4/4)
                Enabling autostart...
                Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /            lib/systemd/system/iobroker.service.
                Autostart enabled!
                    ioBroker was installed successfully
                    Open http://192.168.0.191:8081 in a browser and start configuring!
                You need to re-login before doing anything else on the console!
                Und nu' ... ?
                Holger
                HomoranH Offline
                HomoranH Offline
                der pi3 ist zwar langsam, aber so lange sollte die "Pause" nicht sein. Da wird im Hintergrund gearbeitet.
                hast du irgendwelche Blocker im Netz?
                ist das eine ipv6 Adresse von dir?
                Edit:
                da tauchen gerade die anderen Posts auf! sorry
                  Edit:
                  @homoran sagte in Nach Systemaktualisierung Modbus Fehler 25:
                  Nö, die gehört zu Cloudflare.
                    HomoranH Offline
                    HomoranH Offline
                    @thomas-braun kann es am ipv6 selbst liegen? wenn kein ipv4 läuft?
                      Eigentlich nicht. Bei mir läuft auch Kabelinternet mit ipv6 (nach draußen).
                        Dooley_76
                        Kurzes Update:
                        Alles noch einmal installiert und dieses mal über das Gast-WLAN, also keine weiteren Geräte, keine Beschränkungen, Portweiterleitungen o.ä.
                        Aber leider immer noch derselbe Fehler ... :(
                        Keine Ahnung ... ich werde es jetzt wohl noch einmal mit dem Image aufsetzen, auch wenn es dann nicht auf dem aktuellsten Stand ist, aber es funktioniert wenigstens.
                        Für weitere Ratschläge oder Ideen bin ich natürlich trotzdem jederzeit gern zu haben :)
                        In diesem Sinne aber noch einmal Danke für Eure bisherige (und vor allem schnelle :)) Hilfe ...
                        Holger
                        FabioF 1 Antwort Letzte Antwort
                        • D Dooley_76
                          Kurzes Update:
                          Holger
                          FabioF Offline
                          FabioF Offline
                          Fabio
                          @dooley_76 fahre den zweiten PI mit Solaranzeige mal runter dann nimmst du ihn vom Netzwerk Lan Kabel ziehen etc.
                          Dann machst du die Installation noch mal neu und schaust dann was passiert.
                          Was für einen Router hast du und hast du darin irgendwelche Ports geblockt oder eine Firewall. Du kannst auch mal den Router neu starten. Viel Glück, ich hau mich auf Ohr.👍
                          Iobroker:
                          • Matter over Thread Hilfe
                            Dooley_76
                            So, ein kurzes Update für alle:
                            nachdem ich mit der "normalen" Installation einfach nicht ans Ziel gekommen bin, habe ich einen anderen Weg eingeschlagen:
                            Image IOBroker installiert ( https://github.com/buanet/ioBroker.raspberry-os/releases )
                            Nach der Installation hatte ich folgende Versionen:
                            NPM 8.19.4 (9.6.7)
                            Node.js v16.20.2
                            Dann erst einmal getestet, ob ich hiermit wieder Modbus etc. installieren kann > i.O.
                            Also SD-Karte wieder platt gemacht, Image neu - ohne Modbus etc. - installiert, damit ich wieder
                            die gleiche Ausgangslage habe.
                            Danach mich an das manuelle Upgrade nach Thomas seiner wirklich guten Anleitung gemacht:
                            ( https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian )
                            Gebe zu, das war ein bisschen Arbeit, aber am Ende hatte ich alles auf aktuellem Stand:
                            NPM 9.6.7
                            Node.js v18.17.1
                            Und siehe da: Ich konnte alle Adapter installieren :)
                            Ich habe keine Ahnung, warum er die "normale" Installation nicht gemacht hat. Irgendwas scheint
                            ja aber anders zu sein. Wenn es ein genereller Netzwerkfehler ist/wäre, hätte ich doch auch hier nichts
                            installieren können müssen, oder? Zumindest habe ich bei beiden Wegen die gleichen Voraussetzungen
                            geschaffen, damit ich vergleichen kann. Also irgendwas scheint durch das Image anders zu laufen ...
                            Aber hey ... what ever: ich habe jetzt ein stabil laufendes System, welches aktuell ist und mit dem ich erst
                            einmal wieder an meiner Automation arbeiten kann.
                            Nebenbei habe ich mir aber noch eine 2te SD-Karte fertig gemacht, mit der ich zwischendrin mal
                            verschiedene Szenarien durchspielen werde. Irgendwie muss der "Fehler" ja einzugrenzen zu sein.
                            Am Ende möchte ich aber auf jeden Fall noch einmal Danke :) für Eure Zeit und Hilfe sagen.
                            Greez
                            Holger
