  4. Admin Adapter lässt sich nicht neuinstallieren.
    5.3k
53 Beiträge 8 Kommentatoren 6.6k Aufrufe 6 Beobachtet
  • K klee
    @thomas-braun adamin war n tippfehler ;)
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : none
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     22:33:44 up 281 days,  4:32,  1 user,  load average: 0.85, 0.69, 1.40
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Thu 2023-08-10 22:33:44 CEST
               Universal time: Thu 2023-08-10 20:33:44 UTC
                     RTC time: Thu 2023-08-10 20:33:44
                    Time zone: Europe/Paris (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    johannes
    /home/johannes
    johannes dialout cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            3.9G        539M        1.4G        0.0K        2.0G        3.1G
    Swap:           975M         80M        895M
    Total:          4.9G        620M        2.3G
             3913 M total memory
              539 M used memory
             1030 M active memory
             1152 M inactive memory
             1374 M free memory
              595 M buffer memory
             1403 M swap cache
              975 M total swap
               80 M used swap
              895 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     392M  664K  391M   1% /run
    /dev/sda1      ext4      233G   11G  211G   5% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
    [Tue Dec  6 23:08:24 2022]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Wed Dec  7 17:11:33 2022]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Thu Dec  8 17:12:03 2022]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Thu Dec  8 22:53:03 2022]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Thu Dec  8 22:56:00 2022]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Fri Dec  9 11:17:36 2022]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Fri Dec  9 11:22:50 2022]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Fri Dec  9 20:19:14 2022]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Fri Dec  9 20:53:20 2022]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Mon May 15 11:49:38 2023]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Mon May 15 17:36:26 2023]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Wed Jul 26 23:10:33 2023]  ext4_filemap_fault+0x2d/0x50 [ext4]
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.8G	/var/
    1.7G	/var/cache/apt
    1.7G	/var/cache
    1.6G	/var/cache/apt/archives
    783M	/var/log
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    6.1M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    413M	/opt/iobroker/iobroker-data/
    244M	/opt/iobroker/iobroker-data/files
    73M	/opt/iobroker/iobroker-data/backup-objects
    72M	/opt/iobroker/iobroker-data/node-red
    72M	/opt/iobroker/iobroker-data/files/telegram.admin
    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    15M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    13M	/opt/iobroker/iobroker-data/objects.jsonl
    8.2M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v14.21.3
    /usr/bin/node 		v14.21.3
    /usr/bin/npm 		6.14.18
    /usr/bin/npx 		6.14.18
    nodejs:
      Installed: 14.21.3-deb-1nodesource1
      Candidate: 14.21.3-deb-1nodesource1
      Version table:
     *** 14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.23
    admin: 		6.7.2
    javascript: 	7.0.3
    npm ERR! peer dep missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
    npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@5.0.4
    Adapters from github: 	3
    Adapter State
      system.adapter.admin.0                  : admin                 : APU                                      -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.admin.1                  : admin                 : APU                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.chromecast.0             : chromecast            : APU                                      -  enabled
      system.adapter.daswetter.0              : daswetter             : APU                                      -  enabled
    + system.adapter.discovery.0              : discovery             : APU                                      -  enabled
    + system.adapter.ekey.0                   : ekey                  : APU                                      -  enabled, port: 56000, bind: 0.0.0.0
    + system.adapter.hue.0                    : hue                   : APU                                      -  enabled, port: 443
    + system.adapter.influxdb.0               : influxdb              : APU                                      -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : APU                                      -  enabled
    + system.adapter.iot.0                    : iot                   : APU                                      -  enabled
    + system.adapter.javascript.0             : javascript            : APU                                      -  enabled
    + system.adapter.knx.0                    : knx                   : APU                                      -  enabled, bind: 172.16.2.12
    + system.adapter.mqtt.0                   : mqtt                  : APU                                      -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : APU                                      -  enabled, port: 1880, bind: 172.16.2.12
    + system.adapter.sayit.0                  : sayit                 : APU                                      -  enabled
    + system.adapter.sayit.1                  : sayit                 : APU                                      -  enabled
    + system.adapter.simple-api.0             : simple-api            : APU                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : APU                                      -  enabled
    + system.adapter.telegram.0               : telegram              : APU                                      -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : APU                                      -  enabled
    + system.adapter.unifi-protect.0          : unifi-protect         : APU                                      -  enabled
    + system.adapter.unifi.0                  : unifi                 : APU                                      -  enabled
      system.adapter.vis.0                    : vis                   : APU                                      -  enabled
    + system.adapter.web.0                    : web                   : APU                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : APU                                      -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.7.2    , installed 6.7.2
    Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "discovery"    : 3.2.0    , installed 3.1.0  [Updatable]
    Adapter    "ekey"         : 1.2.3    , installed 1.2.3
    Adapter    "hue"          : 3.9.5    , installed 3.9.3  [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 7.0.3  [Updatable]
    Controller "js-controller": 5.0.11   , installed 4.0.23 [Updatable]
    Adapter    "knx"          : 2.0.22   , installed 2.0.17 [Updatable]
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.2    , installed 4.2.0  [Updatable]
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "unifi-protect": 0.0.13   , installed 0.0.12 [Updatable]
    Adapter    "weatherflow_udp": 0.1.3  , installed 0.1.3
    Adapter    "web"          : 6.1.0    , installed 4.3.0  [Updatable]
    Adapter    "wled"         : 0.7.0    , installed 0.6.7  [Updatable]
    Adapter    "ws"           : 2.5.3    , installed 1.3.0  [Updatable]
    Objects and States
    Objects: 	5950
    States: 	4743
    E: The repository 'http://security.debian.org/debian-security bullseye/updates Release' does not have a Release file.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14873      458/sshd: /usr/sbin
    tcp        0      0 172.16.2.12:1880        0.0.0.0:*               LISTEN      1001       168803242  1130840/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        92780      2677/mosquitto
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       168802709  1130640/iobroker.js
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       168802118  1130640/iobroker.js
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       168806613  1131105/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        112093632  841467/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14884      458/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       168806456  1131050/io.simple-a
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        135089797  960893/grafana-serv
    udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1001       168806578  1131127/io.ekey.0
    udp        0      0 172.16.2.12:47826       0.0.0.0:*                           1001       168803789  1130984/io.knx.0
    udp        0      0 172.16.2.12:33649       0.0.0.0:*                           1001       168805669  1130984/io.knx.0
    udp        0      0 0.0.0.0:37771           0.0.0.0:*                           1001       168803724  1130840/node-red
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       168803894  1131199/io.chromeca
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       168804990  1131244/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       168803719  1130840/node-red
    udp        0      0 0.0.0.0:58630           0.0.0.0:*                           1001       168803722  1130840/node-red
    udp        0      0 172.16.2.12:46735       0.0.0.0:*                           1001       168804947  1130984/io.knx.0
    udp        0      0 172.16.2.12:46902       0.0.0.0:*                           1001       168806481  1130984/io.knx.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14793      422/dhclient
    2023-08-10 22:37:06.268  - info: host.APU iobroker npm-rebuild: > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme> node scripts/postinstall
    2023-08-10 22:37:06.826  - info: host.APU iobroker npm-rebuild: > bcrypt@5.0.1 install /opt/iobroker/node_modules/bcrypt> node-pre-gyp install --fallback-to-build
    2023-08-10 22:37:08.329  - info: host.APU iobroker npm-rebuild: [bcrypt] Success: "/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node" already installed
    2023-08-10 22:37:08.333  - info: host.APU iobroker npm-rebuild: Pass --update-binary to reinstall or --build-from-source to recompile
    2023-08-10 22:37:08.800  - info: host.APU iobroker npm-rebuild: > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
    2023-08-10 22:37:08.802  - info: host.APU iobroker npm-rebuild: > node-gyp rebuild
    2023-08-10 22:37:11.806  - info: chromecast.0 (1131199) New port for device Erdgeschoss: 32055
    2023-08-10 22:37:11.808  - info: chromecast.0 (1131199) Reconnecting Erdgeschoss to 172.16.3.145:32055
    2023-08-10 22:37:11.812  - info: chromecast.0 (1131199) Erdgeschoss - client disconnected
    2023-08-10 22:37:11.845  - info: chromecast.0 (1131199) Received keep alive for disconnected device Erdgeschoss
    2023-08-10 22:37:11.847  - info: chromecast.0 (1131199) New port for device Erdgeschoss: 32056
    2023-08-10 22:37:11.848  - info: chromecast.0 (1131199) Reconnecting Erdgeschoss to 172.16.3.145:32056
    2023-08-10 22:37:11.904  - info: chromecast.0 (1131199) Erdgeschoss - Connected client
    2023-08-10 22:37:11.992  - info: chromecast.0 (1131199) New URL for device Küche: 172.16.3.166
    2023-08-10 22:37:11.994  - info: chromecast.0 (1131199) New port for device Küche: 8009
    2023-08-10 22:37:11.996  - info: chromecast.0 (1131199) Reconnecting Küche to 172.16.3.166:8009
    2023-08-10 22:37:11.998  - info: chromecast.0 (1131199) Küche - client disconnected
    2023-08-10 22:37:12.063  - info: chromecast.0 (1131199) Küche - Connected client
    2023-08-10 22:37:12.515  - info: host.APU iobroker npm-rebuild: make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
    2023-08-10 22:37:12.524  - info: host.APU iobroker npm-rebuild:   CXX(target) Release/obj.target/diskusage/src/main.o
    2023-08-10 22:37:12.804  - info: chromecast.0 (1131199) New port for device Erdgeschoss: 32055
    2023-08-10 22:37:12.806  - info: chromecast.0 (1131199) Reconnecting Erdgeschoss to 172.16.3.145:32055
    2023-08-10 22:37:12.809  - info: chromecast.0 (1131199) Erdgeschoss - client disconnected
    2023-08-10 22:37:12.869  - info: chromecast.0 (1131199) Erdgeschoss - Connected client
    2023-08-10 22:37:15.249  - info: smartmeter.0 (1130892) Received 12 values, 7 updated
    @klee sagte in Admin Adapter lässt sich nicht neuinstallieren.:
    war n tippfehler
    Deswegen kopiert man diese Dinge auch vollständig aus seinem Terminal.
    • K klee
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:	11
      Codename:	bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      johannes
      /home/johannes
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           975M         80M        895M
               3913 M total memory
                539 M used memory
               1374 M free memory
                595 M buffer memory
               1403 M swap cache
                975 M total swap
                 80 M used swap
                895 M free swap
      *** FILESYSTEM ***
      /var:
      2.8G	/var/
      1.7G	/var/cache/apt
      1.7G	/var/cache
      783M	/var/log
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.7.2
      javascript: 	7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	5950
      States: 	4743
      Pending Updates: 0
      Du wohnst in Frankreich?
      Setz den user 'johannes' in die Gruppe 'adm'.
      nodejs zu alt, installier da v18.
      Ich glaube die Syntax hat sich da verändert.
      grafana und influx-Repo müssen angepackt/aktualisiert werden.
      Da scheint auch das ganze apt schief zu laufen. Keine sonstigen Repos aktiv? Nur die drei genannten, die dann auch noch schief sind?
        klee
        @thomas-braun said in Admin Adapter lässt sich nicht neuinstallieren.:
        Sicherlich alles Dinge um die ich mich kümmern müsste, vielen Dank für deine Zusammenfassung.
        Das war aber auch schon vorher so und lief soweit. Ich würde kurzfristig gerne erstmal wieder meine Weboberfläche erreichen.
        Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
        • K klee
          Zuerst die Basis.
          • K klee
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:	11
            Codename:	bullseye
            VERSION_ID="11"
            ID=debian
            CPU threads: 4
                          NTP service: active
                      RTC in local TZ: no
            johannes
            /home/johannes
            X-Server: 	false
            Desktop:
            Terminal: 	tty
            *** MEMORY ***
            Swap:           975M         80M        895M
                     3913 M total memory
                      539 M used memory
                     1374 M free memory
                      595 M buffer memory
                     1403 M swap cache
                      975 M total swap
                       80 M used swap
                      895 M free swap
            *** FILESYSTEM ***
            /var:
            2.8G	/var/
            1.7G	/var/cache/apt
            1.7G	/var/cache
            783M	/var/log
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin: 		6.7.2
            javascript: 	7.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects: 	5950
            States: 	4743
            Pending Updates: 0
            und ibstall wohl auch
              klee
              schrieb am zuletzt editiert von klee
              Korrekt, aber um die Uhrzeit seien mir die Tipfehler verziehen... ich wollte einfach nur kurz skizzieren was ich versucht habe.
              • K klee
                das nutzt uns nichts!
                nur vollständige original Eingaben mit anschließender Rückmeldung sind nützlich
                  klee
                  2023-08-10 23:21:18.063  - info: host.APU instance system.adapter.admin.0 started with pid 6170
                  2023-08-10 23:21:19.840  - error: host.APU Caught by controller[0]: node:internal/modules/cjs/loader:1051
                  2023-08-10 23:21:19.841  - error: host.APU Caught by controller[0]:   throw err;
                  2023-08-10 23:21:19.842  - error: host.APU Caught by controller[0]:   ^
                  2023-08-10 23:21:19.843  - error: host.APU Caught by controller[0]: Error: Cannot find module '@iobroker/types'
                  2023-08-10 23:21:19.844  - error: host.APU Caught by controller[0]: Require stack:
                  2023-08-10 23:21:19.844  - error: host.APU Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js
                  2023-08-10 23:21:19.845  - error: host.APU Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                  2023-08-10 23:21:19.845  - error: host.APU Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                  2023-08-10 23:21:19.846  - error: host.APU Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:901:27)
                  2023-08-10 23:21:19.846  - error: host.APU Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1115:19)
                  2023-08-10 23:21:19.846  - error: host.APU Caught by controller[0]:     at require (node:internal/modules/helpers:130:18)
                  2023-08-10 23:21:19.847  - error: host.APU Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js:21:1)
                  2023-08-10 23:21:19.847  - error: host.APU Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1233:14)
                  2023-08-10 23:21:19.848  - error: host.APU Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1287:10)
                  2023-08-10 23:21:19.848  - error: host.APU Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1091:32)
                  2023-08-10 23:21:19.849  - error: host.APU Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:938:12)
                  2023-08-10 23:21:19.849  - error: host.APU Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1115:19) {
                  2023-08-10 23:21:19.849  - error: host.APU Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                  2023-08-10 23:21:19.850  - error: host.APU Caught by controller[0]:   requireStack: [
                  2023-08-10 23:21:19.850  - error: host.APU Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js',
                  2023-08-10 23:21:19.851  - error: host.APU Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
                  2023-08-10 23:21:19.851  - error: host.APU Caught by controller[0]:   ]
                  2023-08-10 23:21:19.852  - error: host.APU Caught by controller[0]: }
                  2023-08-10 23:21:19.852  - error: host.APU Caught by controller[0]: Node.js v20.5.1
                  2023-08-10 23:21:19.853  - error: host.APU instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2023-08-10 23:21:19.854  - info: host.APU Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                  2023-08-10 23:21:19.863  - info: host.APU system.adapter.admin.0 will be rebuilt
                  2023-08-10 23:21:19.866  - warn: host.APU adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                  2023-08-10 23:21:19.866  - info: host.APU iobroker rebuild
                  2023-08-10 23:21:21.526  - info: host.APU iobroker npm-rebuild: Rebuilding native modules ...
                  2023-08-10 23:21:22.103  - info: host.APU instance system.adapter.admin.1 started with pid 6227
                  2023-08-10 23:21:24.811  - error: host.APU Caught by controller[0]: node:internal/modules/cjs/loader:1051
                  2023-08-10 23:21:24.813  - error: host.APU Caught by controller[0]:   throw err;
                  2023-08-10 23:21:24.814  - error: host.APU Caught by controller[0]:   ^
                  2023-08-10 23:21:24.814  - error: host.APU Caught by controller[0]: Error: Cannot find module '@iobroker/types'
                  2023-08-10 23:21:24.815  - error: host.APU Caught by controller[0]: Require stack:
                  2023-08-10 23:21:24.816  - error: host.APU Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js
                  2023-08-10 23:21:24.817  - error: host.APU Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                  2023-08-10 23:21:24.817  - error: host.APU Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                  2023-08-10 23:21:24.818  - error: host.APU Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:901:27)
                  2023-08-10 23:21:24.819  - error: host.APU Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1115:19)
                  2023-08-10 23:21:24.820  - error: host.APU Caught by controller[0]:     at require (node:internal/modules/helpers:130:18)
                  2023-08-10 23:21:24.820  - error: host.APU Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js:21:1)
                  2023-08-10 23:21:24.822  - error: host.APU Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1233:14)
                  2023-08-10 23:21:24.823  - error: host.APU Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1287:10)
                  2023-08-10 23:21:24.824  - error: host.APU Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1091:32)
                  2023-08-10 23:21:24.824  - error: host.APU Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:938:12)
                  2023-08-10 23:21:24.825  - error: host.APU Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1115:19) {
                  2023-08-10 23:21:24.826  - error: host.APU Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                  2023-08-10 23:21:24.827  - error: host.APU Caught by controller[0]:   requireStack: [
                  2023-08-10 23:21:24.827  - error: host.APU Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js',
                  2023-08-10 23:21:24.828  - error: host.APU Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
                  2023-08-10 23:21:24.829  - error: host.APU Caught by controller[0]:   ]
                  2023-08-10 23:21:24.829  - error: host.APU Caught by controller[0]: }
                  2023-08-10 23:21:24.830  - error: host.APU Caught by controller[0]: Node.js v20.5.1
                  2023-08-10 23:21:24.831  - error: host.APU instance system.adapter.admin.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  Lässt sich das Problem damit weiter eingrenzen?
                  • K klee
                    klee
                    @klee
                    Vielen Dank für eure "Hilfe" es läuft nun wieder....
                    npm i @iobroker/types
                    Konnte das fehlende Modul so ergänzen.
                    • K klee
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      Node.js v20.5.1
                      Auf "Hilfe" wirst Du sicher sehr bald wieder angewiesen sein - ob Du diese dann bekommst steht in den Sternelein ☺
                      Lehrling seit 1975 !!!
                      • K klee
                        @klee
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @klee
                        deutet drauf hin, dass die Installation noch mit der veralteten npm Version 6 versucht wurde.
                        Kann es sein, dass du zum Zeitpunkt des admin upgrades noch node 14 installiert hattest?
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • mcm1957M mcm1957
                          @klee
                          @mcm57
                          Eine ordentliche Basis war ja nicht gewünscht.
                          Man wurschtelt ja lieber weiter auf der krummen Installation herum.
                          Na jeder wie er meint.
                            @mcm57
                            mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            Ja - nur das Gradeziehen nach dem Auftreten des Problems hätte auch nix mehr gebracht.
                            Das npm 6 / adapter-core Problem müssen wir devs uns auch teilweise zurechnen lassen.
                            Node 14 ist zwar außer Wartung - aber ich habe noch nirgends gelesen, dass node 14 in Verbindung mit js-controller 4 nicht mher supported sei. Der Artikel Node 16 / 18 / 20 recommended nennt nur js-controller 5. Ergo kann ich user verstehen die noch 14 nutzen.
                            Egal - ich hab grad ein issue erstellt dass admin hier die engine requiremments anpasst - wenn das ohne Nebenwirkungen möglich ist - damit solche Fälle möglichst minimiert werden.
                            In jedem Fall aber DANKE für deine unermüdliche Arbeit hier im Forum. Und auch DANKE dass du unungterbrochen User zum Upgrade und zum Aktuell Halten der System drängst.
                            • mcm1957M mcm1957
                              @mcm57 sagte in Admin Adapter lässt sich nicht neuinstallieren.:
                              Bei dem System liegt ja noch viel mehr daneben.
                              • mcm1957M mcm1957
                                Ich ehrlich gesagt nicht. v14 ist von nodejs abgekündigt und seitens ioBroker ist die klare Empfehlung v18. Warum sollte ich mich mit den Issues von obsoleten Versionen herumschlagen? Vollkommen unnötig.
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  ja
                                    mcm1957M Offline
                                    mcm1957M Offline
                                    mcm1957
                                    Ok - das hab ich dann wohl auch übersehen.
                                    Wo steht das?
                                    • mcm1957M mcm1957
                                      Wo steht das?
                                      @mcm57
                                      Im Release Plan?
                                      https://github.com/nodejs/release#release-schedule
                                      14.x 	End-of-Life 	2023-04-30
                                      Am Rande: Nodejs@16 wird Anfang 09/2023 abgekündigt.
                                        @mcm57
                                        Im Release Plan?
                                        mcm1957M Offline
                                        mcm1957M Offline
                                        mcm1957
                                        Ich meinte wo steht dass ioBroker node 18 empfiehlt und node 14 nicht mehr unterstützt?
                                        Ich kenne nur das Posting https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18 und da steht nur drinnen dass node 14 mit js-controller 5 nicht mehr unterstützt wird.
                                        Und damit es klar ist:
                                        NEIN wir brauchen node 14 nicht mehr zu unterstützen.
                                        ABER wir sollten dass geeignet kommunizieren und bis dahin Usern klar sagen, dass sie abgraden sollen / müssen. Ihnen aber keinen Vorwurf machen, dass das noch nicht erfolgt ist.
                                        Was node 16 betrifft - mir wäre nicht bekannt, dass js-controller 5 das nicht mehr unterstützt. Wär aber zu überlegen. (Ich werds mal als issue einbringen)
                                        • mcm1957M mcm1957
                                          Node18 wird vom Installer als Basis angeschleppt und im Admin steht soweit ich weiß auch 18 als Empfehlung drin.
                                          Und v14 ergibt sich alleine daraus, das es vom Hauptprojekt nicht mehr gepflegt wird. Man setzt kein unmaintained Zeug ein, wenn es einen unterstützten Nachfolger gibt.
                                          Würde auch die Adapterentwicklung vereinfachen, wenn man auf ollen, obsoleten Kram keine Rücksicht nehmen muss.
