  4. ioBroker funktioniert nicht mehr
34 Beiträge 6 Kommentatoren 3.2k Aufrufe 4 Beobachtet
  • R rsw2004
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     20:05:33 up  2:13,  0 users,  load average: 0.00, 0.03, 0.04
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=52.5'C
    volt=0.9160V
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-08 20:05:33 CEST
               Universal time: Tue 2023-08-08 18:05:33 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    robin
    /home/robin
    robin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        230M        3.1G        1.0M        509M        3.5G
    Swap:            99M          0B         99M
    Total:          3.9G        230M        3.2G
             3794 M total memory
              230 M used memory
              296 M active memory
              334 M inactive memory
             3054 M free memory
               45 M buffer memory
              463 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       15G  3.2G   11G  24% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /devtmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  1.1M  758M   1% /runtmpfs          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Tue Aug  8 17:52:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Aug  8 17:52:03 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Aug  8 17:52:03 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Aug  8 17:52:05 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600`-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    541M    /var/
    180M    /var/cache
    174M    /var/cache/apt
    147M    /var/lib
    123M    /var/lib/apt/lists
    Archived and active journals take up 112.0M in the file system.
    /opt/iobroker/backups:
    11M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    167M    /opt/iobroker/iobroker-data/
    122M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    7.7M    /opt/iobroker/iobroker-data/objects.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    sort: write failed: 'standard output': Broken pipe
    sort: write error
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
         18.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
     *** 18.16.1-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   0
    Adapter State
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bluelink"     : 2.3.2    , installed 2.3.2
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "openknx"      : 0.5.3    , installed 0.5.3
    Adapter    "solax"        : 0.7.5    , installed 0.7.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Objects and States
    Objects:        118
    States:         79
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 20
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12735      494/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1477       494/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13683      534/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13685      534/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1490       651/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1442       391/avahi-daemon: r
    udp        0      0 0.0.0.0:42577           0.0.0.0:*                           108        1444       391/avahi-daemon: r
    udp6       0      0 :::45999                :::*                                108        1445       391/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        1443       391/avahi-daemon: r
    2023-08-08 17:39:02.271  - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewestNext"
    2023-08-08 17:39:02.282  - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmCurrent"
    2023-08-08 17:39:02.299  - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewest"
    2023-08-08 17:39:02.311  - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewestNext"
    2023-08-08 17:39:02.321  - info: host.raspberrypi4 Some obsolete host states deleted.
    2023-08-08 17:39:23.178  - info: host.raspberrypi4 received SIGTERM
    2023-08-08 17:39:23.255  - info: host.raspberrypi4 terminated
    2023-08-08 17:40:02.223  - info: host.raspberrypi4 iobroker.js-controller version 4.0.24 js-controller starting
    2023-08-08 17:40:02.230  - info: host.raspberrypi4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-08-08 17:40:02.231  - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.16.1
    2023-08-08 17:40:02.231  - info: host.raspberrypi4 ip addresses: 192.168.178.55 fd20:384a:b205:4332:15e1:cf9a:3fe7:8394 fe80::54cc:fb68:5387:7415
    2023-08-08 17:40:03.091  - info: host.raspberrypi4 connected to Objects and States
    2023-08-08 17:40:03.117  - info: host.raspberrypi4 added notifications configuration of host
    2023-08-08 17:40:03.530  - info: host.raspberrypi4  no instances found
    2023-08-08 17:51:52.065  - info: host.raspberrypi4 received SIGTERM
    2023-08-08 17:51:52.143  - info: host.raspberrypi4 terminated
    2023-08-08 17:52:00.983  - info: host.raspberrypi4 iobroker.js-controller version 4.0.24 js-controller starting
    2023-08-08 17:52:00.989  - info: host.raspberrypi4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-08-08 17:52:00.991  - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.16.1
    2023-08-08 17:52:00.991  - info: host.raspberrypi4 ip addresses:
    2023-08-08 17:52:01.984  - info: host.raspberrypi4 connected to Objects and States
    2023-08-08 17:52:02.018  - info: host.raspberrypi4 added notifications configuration of host
    2023-08-08 17:52:02.665  - info: host.raspberrypi4  no instances found
    2023-08-08 17:52:02.666  - info: host.raspberrypi4 no instances found
    @rsw2004
    iob stop
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Vor dem reboot bitte die Ausgaben von apt posten.
    R 1 Antwort Letzte Antwort
      @rsw2004
      iob stop
      sudo apt update
      sudo reboot
      rsw2004
      Reading package lists... Done
      Calculating upgrade... Done
      The following packages will be upgraded:
        firmware-atheros firmware-brcm80211
        firmware-libertas firmware-misc-nonfree
        firmware-realtek libcamera-apps-lite libcamera0
        libpam-systemd libssl1.1 libsystemd0
        libudev-dev libudev1 nodejs openssl
        python3-libcamera python3-picamera2 systemd
        systemd-sysv systemd-timesyncd udev
      20 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 107 MB of archives.
      After this operation, 5,668 kB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 http://deb.debian.org/debian bullseye-updates/main arm64 libudev-dev arm64 247.3-7+deb11u4 [124 kB]
      Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 libssl1.1 arm64 1.1.1n-0+deb11u5+rpt1 [1,393 kB]
      Get:3 http://deb.debian.org/debian bullseye-updates/main arm64 libsystemd0 arm64 247.3-7+deb11u4 [355 kB]
      Get:4 https://deb.nodesource.com/node_18.x bullseye/main arm64 nodejs arm64 18.17.0-deb-1nodesource1 [28.1 MB]
      Get:5 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-atheros all 1:20230210-5~bpo11+1+rpt1 [16.8 MB]
      Get:6 http://deb.debian.org/debian bullseye-updates/main arm64 systemd-timesyncd arm64 247.3-7+deb11u4 [130 kB]
      Get:7 http://deb.debian.org/debian bullseye-updates/main arm64 libpam-systemd arm64 247.3-7+deb11u4 [275 kB]
      Get:8 http://deb.debian.org/debian bullseye-updates/main arm64 systemd arm64 247.3-7+deb11u4 [4,155 kB]
      Get:9 http://deb.debian.org/debian bullseye-updates/main arm64 udev arm64 247.3-7+deb11u4 [1,423 kB]
      Get:10 http://deb.debian.org/debian bullseye-updates/main arm64 libudev1 arm64 247.3-7+deb11u4 [163 kB]
      Get:11 http://deb.debian.org/debian bullseye-updates/main arm64 systemd-sysv arm64 247.3-7+deb11u4 [114 kB]
      Get:12 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-brcm80211 all 1:20230210-5~bpo11+1+rpt1 [5,868 kB]
      Get:13 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-libertas all 1:20230210-5~bpo11+1+rpt1 [31.2 MB]
      Get:14 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-misc-nonfree all 1:20230210-5~bpo11+1+rpt1 [13.0 MB]
      Get:15 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-realtek all 1:20230210-5~bpo11+1+rpt1 [1,511 kB]
      Get:16 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera0 arm64 0~git20230720+bde9b04f-1 [826 kB]
      Get:17 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera-apps-lite arm64 1.2.1-1 [281 kB]
      Get:18 http://archive.raspberrypi.org/debian bullseye/main arm64 openssl arm64 1.1.1n-0+deb11u5+rpt1 [832 kB]
      Get:19 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-libcamera arm64 0~git20230720+bde9b04f-1 [190 kB]
      Get:20 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-picamera2 all 0.3.12-2 [50.4 kB]
      Fetched 107 MB in 10s (10.5 MB/s)
      Reading changelogs... Done
      Preconfiguring packages ...
      (Reading database ... 50437 files and directories currently installed.)
      Preparing to unpack .../libudev-dev_247.3-7+deb11u4_arm64.deb ...
      Unpacking libudev-dev:arm64 (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
      Preparing to unpack .../libsystemd0_247.3-7+deb11u4_arm64.deb ...
      Unpacking libsystemd0:arm64 (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
      Setting up libsystemd0:arm64 (247.3-7+deb11u4) ...
      Preparing to unpack .../systemd-timesyncd_247.3-7+deb11u4_arm64.deb ...
      Unpacking systemd-timesyncd (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
      Preparing to unpack .../libpam-systemd_247.3-7+deb11u4_arm64.deb ...
      Unpacking libpam-systemd:arm64 (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
      Preparing to unpack .../systemd_247.3-7+deb11u4_arm64.deb ...
      Unpacking systemd (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
      Preparing to unpack .../udev_247.3-7+deb11u4_arm64.deb ...
      Unpacking udev (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
      Preparing to unpack .../libudev1_247.3-7+deb11u4_arm64.deb ...
      Unpacking libudev1:arm64 (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
      Setting up libudev1:arm64 (247.3-7+deb11u4) ...
      Setting up systemd (247.3-7+deb11u4) ...
      Preparing to unpack .../systemd-sysv_247.3-7+deb11u4_arm64.deb ...
      Unpacking systemd-sysv (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
      Preparing to unpack .../libssl1.1_1.1.1n-0+deb11u5+rpt1_arm64.deb ...
      Unpacking libssl1.1:arm64 (1.1.1n-0+deb11u5+rpt1) over (1.1.1n-0+deb11u5) ...
      Setting up libssl1.1:arm64 (1.1.1n-0+deb11u5+rpt1) ...
      Preparing to unpack .../00-firmware-atheros_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
      Unpacking firmware-atheros (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
      Preparing to unpack .../01-firmware-brcm80211_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
      Unpacking firmware-brcm80211 (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
      Preparing to unpack .../02-firmware-libertas_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
      Unpacking firmware-libertas (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
      Preparing to unpack .../03-firmware-misc-nonfree_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
      Unpacking firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
      Preparing to unpack .../04-firmware-realtek_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
      Unpacking firmware-realtek (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
      Preparing to unpack .../05-libcamera0_0~git20230720+bde9b04f-1_arm64.deb ...
      Unpacking libcamera0:arm64 (0~git20230720+bde9b04f-1) over (0~git20230302+923f5d70-1) ...
      Preparing to unpack .../06-libcamera-apps-lite_1.2.1-1_arm64.deb ...
      Unpacking libcamera-apps-lite (1.2.1-1) over (0~git20230301+54a781d-1) ...
      Preparing to unpack .../07-nodejs_18.17.0-deb-1nodesource1_arm64.deb ...
      Unpacking nodejs (18.17.0-deb-1nodesource1) over (18.16.1-deb-1nodesource1) ...
      Preparing to unpack .../08-openssl_1.1.1n-0+deb11u5+rpt1_arm64.deb ...
      Unpacking openssl (1.1.1n-0+deb11u5+rpt1) over (1.1.1n-0+deb11u5) ...
      Preparing to unpack .../09-python3-libcamera_0~git20230720+bde9b04f-1_arm64.deb ...
      Unpacking python3-libcamera (0~git20230720+bde9b04f-1) over (0~git20230302+923f5d70-1) ...
      Preparing to unpack .../10-python3-picamera2_0.3.12-2_all.deb ...
      Unpacking python3-picamera2 (0.3.12-2) over (0.3.9-1) ...
      Setting up systemd-sysv (247.3-7+deb11u4) ...
      Setting up firmware-atheros (1:20230210-5~bpo11+1+rpt1) ...
      Setting up firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt1) ...
      Setting up nodejs (18.17.0-deb-1nodesource1) ...
      Setting up firmware-brcm80211 (1:20230210-5~bpo11+1+rpt1) ...
      Setting up firmware-realtek (1:20230210-5~bpo11+1+rpt1) ...
      Setting up systemd-timesyncd (247.3-7+deb11u4) ...
      Setting up udev (247.3-7+deb11u4) ...
      Setting up libudev-dev:arm64 (247.3-7+deb11u4) ...
      Setting up firmware-libertas (1:20230210-5~bpo11+1+rpt1) ...
      Setting up libpam-systemd:arm64 (247.3-7+deb11u4) ...
      Setting up libcamera0:arm64 (0~git20230720+bde9b04f-1) ...
      Setting up openssl (1.1.1n-0+deb11u5+rpt1) ...
      Setting up python3-libcamera (0~git20230720+bde9b04f-1) ...
      Setting up libcamera-apps-lite (1.2.1-1) ...
      Setting up python3-picamera2 (0.3.12-2) ...
      Processing triggers for initramfs-tools (0.140) ...Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
      Processing triggers for man-db (2.9.4-2) ...
      Processing triggers for dbus (1.12.24-0+deb11u1) ...
      • R rsw2004
        @rsw2004
        Das ist nicht alles.
        Oder es fehlt der Login Prompt, woran man das erkennen könnte.
          @rsw2004
          rsw2004
          Der code ist natürlich nach dem reboot weg. Dachte es wäre alles…
          Hier nochmal ein neuer iob diag, falls das hilft
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=debian
           20:49:52 up 1 min,  0 users,  load average: 0.47, 0.35, 0.14
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=52.1'C
          volt=0.9160V
                         Local time: Tue 2023-08-08 20:49:52 CEST
                     Universal time: Tue 2023-08-08 18:49:52 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          robin
          /home/robin
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        178M        3.4G        1.0M        190M        3.5G
          Swap:            99M          0B         99M
          Total:          3.9G        178M        3.5G
                   3794 M total memory
                    178 M used memory
                    231 M active memory
                     57 M inactive memory
                   3424 M free memory
                     19 M buffer memory
                    171 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4       15G  3.3G   11G  24% /
          [Tue Aug  8 20:48:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue Aug  8 20:48:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Aug  8 20:48:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Tue Aug  8 20:48:07 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          /var:
          550M    /var/
          180M    /var/cache
          174M    /var/cache/apt
          147M    /var/lib
          Archived and active journals take up 120.0M in the file system.
          sort: write error
          /usr/bin/nodejs         v18.17.0
          /usr/bin/node           v18.17.0
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Installed: 18.17.0-deb-1nodesource1
            Version table:
           *** 18.17.0-deb-1nodesource1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        118
          States:         79
          Pending Updates: 0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11853      467/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14162      467/iobroker.js-con
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12899      522/sshd: /usr/sbin
          tcp6       0      0 :::22                   :::*                    LISTEN      0          12901      522/sshd: /usr/sbin
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12940      664/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12739      353/avahi-daemon: r
          udp        0      0 0.0.0.0:58693           0.0.0.0:*                           108        12741      353/avahi-daemon: r
          udp6       0      0 :::53751                :::*                                108        12742      353/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        12740      353/avahi-daemon: r
          2023-08-08 20:32:59.069  - info: host.raspberrypi4 received SIGTERM
          2023-08-08 20:32:59.115  - info: host.raspberrypi4 terminated
          2023-08-08 20:48:02.032  - info: host.raspberrypi4 iobroker.js-controller version 4.0.24 js-controller starting
          2023-08-08 20:48:02.040  - info: host.raspberrypi4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-08-08 20:48:02.042  - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.17.0
          2023-08-08 20:48:02.043  - info: host.raspberrypi4 ip addresses:
          2023-08-08 20:48:03.279  - info: host.raspberrypi4 connected to Objects and States
          2023-08-08 20:48:03.312  - info: host.raspberrypi4 added notifications configuration of host
          2023-08-08 20:48:03.324  - info: host.raspberrypi4 Node.js version has changed from 18.16.1 to 18.17.02023-08-08 20:48:03.969  - info: host.raspberrypi4 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node2023-08-08 20:48:04.004  - info: host.raspberrypi4  no instances found
          2023-08-08 20:48:04.005  - info: host.raspberrypi4 no instances found
          • R rsw2004
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=debian
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=52.1'C
            volt=0.9160V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            robin
            /home/robin
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3794 M total memory
                      178 M used memory
                      231 M active memory
                     3424 M free memory
                       19 M buffer memory
                      171 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            550M    /var/
            180M    /var/cache
            174M    /var/cache/apt
            147M    /var/lib
            sort: write error
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     7.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        118
            States:         79
            Pending Updates: 0
            @rsw2004 sagte in ioBroker funktioniert nicht mehr:
            Der irritiert mich. Das sollte nicht passieren.
            iob start admin
            iob start web
              iob start admin
              iob start web
              rsw2004
              robin@raspberrypi4:/ $ iob start admin
              Cannot find any instances of "admin"!
              robin@raspberrypi4:/ $ iob start web
              Cannot find any instances of "web"!
              Muss ich vorher das Verzeichnis wechseln?
              cd /opt/iobroker
              • R rsw2004
                cd /opt/iobroker
                Nein. Aber dann add mal.
                iob add admin
                iob add web
                iob restart admin
                iob restart web
                  iob add admin
                  iob add web
                  iob restart admin
                  iob restart web
                  rsw2004
                  Das hat jetzt zumindest mal insofern funktioniert, dass ich wieder auf die Weboberfläche komme.
                  Und obwohl laut Diag alle Instanzen vorhanden sein sollten, werden mir nur die gerade hinzugefügten web und und admin Instanzen angezeigt.
                  Der Rest ist einfach weg.
                  Bei Objekten sind auch noch entsprechende Überreste vorhanden, also leere Ordner Namen der Instanzen.
                  Wie kann sich ioBroker denn so vergessen?
                  R Thomas BraunT 2 Antworten Letzte Antwort
                  • R rsw2004
                    rsw2004
                    @Thomas-Braun
                    ioBroker Backup habe ich geladen. Hat auch soweit erstmal ohne Probleme geklappt.
                    Allerdings zeigts mir im Protokoll 3 neue Meldungen an.
                    • R rsw2004
                      Die musst du jetzt hinzufügen.
                      Keine Ahnung. Irgendein File wohl korrupt. Dein sort reagiert ja auch merkwürdig. Ich würde mal den Datenträger mistrauisch beäugen.
                      • R rsw2004
                        @Thomas-Braun
                        @rsw2004
                        Bitte keine Bilder von Text. Kann ich nicht kopieren und zitieren.
                        R 2 Antworten Letzte Antwort
                          @rsw2004
                          rsw2004
                          Ok, läuft bis jetzt. Mal abwarten wie lange.
                          Vielen Dank für deine Hilfe
                            @rsw2004
                            rsw2004
                            Hat nicht lange gehalten 😕
                            Dieses mal wurden wohl die Instanzen nur deaktiviert/gestoppt.
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:        11
                            Codename:       bullseye
                            VERSION_ID="11"
                            ID=debian
                             18:17:48 up 19:23,  0 users,  load average: 0.00, 0.00, 0.00
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=52.5'C
                            volt=0.9160V
                                           Local time: Wed 2023-08-09 18:17:48 CEST
                                       Universal time: Wed 2023-08-09 16:17:48 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            robin
                            /home/robin
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            3.8G        255M        3.1G        1.0M        419M        3.5G
                            Swap:            99M          0B         99M
                            Total:          3.9G        255M        3.2G
                                     3794 M total memory
                                      255 M used memory
                                      382 M active memory
                                      192 M inactive memory
                                     3118 M free memory
                                       40 M buffer memory
                                      379 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            [Tue Aug  8 22:54:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Tue Aug  8 22:54:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Tue Aug  8 22:54:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Tue Aug  8 22:54:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            /var:
                            558M    /var/
                            180M    /var/cache
                            174M    /var/cache/apt
                            147M    /var/lib
                            131M    /var/log
                            Archived and active journals take up 128.0M in the file system.
                            8.0M    /opt/iobroker/backups/
                            181M    /opt/iobroker/iobroker-data/
                            sort: 20M       /opt/iobroker/iobroker-data/objects.jsonl
                            7.7M    /opt/iobroker/iobroker-data/states.jsonl
                            sort: write error
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.3.5
                            javascript:     7.0.3
                            Adapter State
                              system.adapter.admin.0                  : admin                 : raspberrypi4                             - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.backitup.0               : backitup              : raspberrypi4                             - disabled
                              system.adapter.geofency.0               : geofency              : raspberrypi4                             - disabled, port: 7999, bind: 0.0.0.0
                              system.adapter.info.0                   : info                  : raspberrypi4                             - disabled
                              system.adapter.iot.0                    : iot                   : raspberrypi4                             - disabled
                              system.adapter.javascript.0             : javascript            : raspberrypi4                             - disabled
                              system.adapter.openknx.0                : openknx               : raspberrypi4                             - disabled
                              system.adapter.solax.0                  : solax                 : raspberrypi4                             - disabled
                              system.adapter.web.0                    : web                   : raspberrypi4                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.yahka.0                  : yahka                 : raspberrypi4                             - disabled
                            + instance is alive
                            Objects and States
                            Objects:        905
                            States:         702
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12989      504/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12959      504/iobroker.js-con
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14039      539/sshd: /usr/sbin
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          14444      539/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12955      678/dhcpcd
                            udp        0      0 0.0.0.0:37781           0.0.0.0:*                           108        13939      372/avahi-daemon: r
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13937      372/avahi-daemon: r
                            udp6       0      0 :::55672                :::*                                108        13940      372/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        13938      372/avahi-daemon: r
                            2023-08-09 09:07:38.505  - info: host.raspberrypi4 stopInstance system.adapter.web.0 send kill signal
                            2023-08-09 09:07:38.473  - info: web.0 (1341) Got terminate signal TERMINATE_YOURSELF
                            2023-08-09 09:07:38.588  - info: web.0 (1341) terminated http server on port 8082
                            2023-08-09 09:07:38.589  - info: web.0 (1341) terminating
                            2023-08-09 09:07:38.591  - info: web.0 (1341) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2023-08-09 09:07:38.768  - info: host.raspberrypi4 "system.adapter.yahka.0" disabled
                            2023-08-09 09:07:38.769  - info: host.raspberrypi4 stopInstance system.adapter.yahka.0 (force=false, process=true)
                            2023-08-09 09:07:38.768  - info: yahka.0 (1358) Adapter is disabled => stop
                            2023-08-09 09:07:38.779  - info: yahka.0 (1358) cleaning up ...
                            2023-08-09 09:07:38.780  - info: yahka.0 (1358) cleaned up ...
                            2023-08-09 09:07:38.786  - info: yahka.0 (1358) Got terminate signal TERMINATE_YOURSELF
                            2023-08-09 09:07:38.816  - info: host.raspberrypi4 stopInstance system.adapter.yahka.0 send kill signal
                            2023-08-09 09:07:38.832  - info: yahka.0 (1358) terminating
                            2023-08-09 09:07:38.833  - info: yahka.0 (1358) Terminated (NO_ERROR): Without reason
                            2023-08-09 09:07:39.140  - info: host.raspberrypi4 instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2023-08-09 09:07:39.381  - info: host.raspberrypi4 instance system.adapter.yahka.0 terminated with code 0 (NO_ERROR)
                            2023-08-09 09:07:42.922  - info: admin.0 (574) Adapter is disabled => stop
                            2023-08-09 09:07:42.923  - info: host.raspberrypi4 "system.adapter.admin.0" disabled
                            2023-08-09 09:07:42.923  - info: host.raspberrypi4 stopInstance system.adapter.admin.0 (force=false, process=true)
                            2023-08-09 09:07:42.924  - info: admin.0 (574) terminating http server on port 8081
                            2023-08-09 09:07:42.935  - info: admin.0 (574) Got terminate signal TERMINATE_YOURSELF
                            2023-08-09 09:07:42.942  - info: admin.0 (574) terminating
                            2023-08-09 09:07:42.943  - info: admin.0 (574) Terminated (NO_ERROR): Without reason
                            2023-08-09 09:07:42.968  - info: host.raspberrypi4 stopInstance system.adapter.admin.0 send kill signal
                            2023-08-09 09:07:43.503  - info: host.raspberrypi4 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                            Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                            • R rsw2004
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        11
                              Codename:       bullseye
                              VERSION_ID="11"
                              ID=debian
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=52.5'C
                              volt=0.9160V
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              robin
                              /home/robin
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       3794 M total memory
                                        255 M used memory
                                        382 M active memory
                                       3118 M free memory
                                         40 M buffer memory
                                        379 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              558M    /var/
                              180M    /var/cache
                              174M    /var/cache/apt
                              147M    /var/lib
                              131M    /var/log
                              sort: write error
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.3.5
                              javascript:     7.0.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        905
                              States:         702
                              Pending Updates: 0
                              Wie 0 users?
                              Irgendwas stimmt da ganz und gar nicht mit dem System, würde ich sagen.
                              dmesg -T
                              sagt? Achtung, kann viel sein...
                              • R rsw2004
                                Skript v.2023-04-16
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:        11
                                Codename:       bullseye
                                VERSION_ID="11"
                                ID=debian
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=52.5'C
                                volt=0.9160V
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                robin
                                /home/robin
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         3794 M total memory
                                          255 M used memory
                                          382 M active memory
                                         3118 M free memory
                                           40 M buffer memory
                                          379 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                558M    /var/
                                180M    /var/cache
                                174M    /var/cache/apt
                                147M    /var/lib
                                131M    /var/log
                                sort: write error
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     7.0.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        905
                                States:         702
                                Pending Updates: 0
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                kann eigentlich auch so nicht stimmen 🤔
                                Lehrling seit 1975 !!!
                                  Wie 0 users?
                                  dmesg -T
                                  rsw2004
                                  [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
                                  [    0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
                                  [    0.000000] random: crng init done
                                  [    0.000000] Detected PIPT I-cache on CPU0
                                  [    0.000000] CPU features: detected: Spectre-v2
                                  [    0.000000] CPU features: detected: Spectre-v3a
                                  [    0.000000] CPU features: detected: Spectre-v4
                                  [    0.000000] CPU features: detected: Spectre-BHB
                                  [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
                                  [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
                                  [    0.000000] CPU features: detected: ARM erratum 1742098
                                  [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
                                  [    0.000000] alternatives: applying boot alternatives
                                  [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 996912
                                  [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
                                  [    0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
                                  [    0.000000] efi: UEFI not found.
                                  [    0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
                                  [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                                  [    0.000000] Zone ranges:
                                  [    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
                                  [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000fbffffff]
                                  [    0.000000]   Normal   empty
                                  [    0.000000] Movable zone start for each node
                                  [    0.000000] Early memory node ranges
                                  [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
                                  [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                                  [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                                  [    0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
                                  [    0.000000] On node 0, zone DMA32: 16384 pages in unavailable ranges
                                  [    0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
                                  [    0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
                                  [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
                                  [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                                  [    0.000000] software IO TLB: area num 4.
                                  [    0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
                                  [    0.000000] Memory: 3356948K/4050944K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 169708K reserved, 524288K cma-reserved)
                                  [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                  [    0.000000] ftrace: allocating 39744 entries in 156 pages
                                  [    0.000000] ftrace: allocated 156 pages with 4 groups
                                  [    0.000000] trace event string verifier disabled[    0.000000] rcu: Preemptible hierarchical RCU implementation.
                                  [    0.000000] rcu:     RCU event tracing is enabled.
                                  [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
                                  [    0.000000]  Trampoline variant of Tasks RCU enabled.
                                  [    0.000000]  Rude variant of Tasks RCU enabled.
                                  [    0.000000]  Tracing variant of Tasks RCU enabled.
                                  [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                                  [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                                  [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
                                  [    0.000000] Root IRQ handler: gic_handle_irq
                                  [    0.000000] GIC: Using split EOI/Deactivate mode[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
                                  [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                                  [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                                  [    0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                                  [    0.000320] Console: colour dummy device 80x25
                                  [    0.000923] printk: console [tty1] enabled
                                  [    0.000993] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
                                  [    0.001034] pid_max: default: 32768 minimum: 301[    0.001177] LSM: Security Framework initializing[    0.001412] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                  [    0.001500] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                  [    0.002842] cgroup: Disabling memory control group subsystem
                                  [    0.005174] cblist_init_generic: Setting adjustable number of callback queues.
                                  [    0.005209] cblist_init_generic: Setting shift to 2 and lim to 1.
                                  [    0.005410] cblist_init_generic: Setting shift to 2 and lim to 1.
                                  [    0.005605] cblist_init_generic: Setting shift to 2 and lim to 1.
                                  [    0.006081] rcu: Hierarchical SRCU implementation.
                                  [    0.006106] rcu:     Max phase no-delay instances is 1000.
                                  [    0.007475] EFI services will not be available.
                                  [    0.008119] smp: Bringing up secondary CPUs ...
                                  [    0.009238] Detected PIPT I-cache on CPU1
                                  [    0.009396] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
                                  [    0.010584] Detected PIPT I-cache on CPU2
                                  [    0.010705] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
                                  [    0.011862] Detected PIPT I-cache on CPU3
                                  [    0.011990] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
                                  [    0.012140] smp: Brought up 1 node, 4 CPUs
                                  [    0.012231] SMP: Total of 4 processors activated.
                                  [    0.012253] CPU features: detected: 32-bit EL0 Support
                                  [    0.012272] CPU features: detected: 32-bit EL1 Support
                                  [    0.012294] CPU features: detected: CRC32 instructions
                                  [    0.012441] CPU: All CPU(s) started at EL2
                                  [    0.012477] alternatives: applying system-wide alternatives
                                  [    0.014365] devtmpfs: initialized
                                  [    0.026516] Enabled cp15_barrier support
                                  [    0.026583] Enabled setend support
                                  [    0.026817] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                                  [    0.026870] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                                  [    0.040956] pinctrl core: initialized pinctrl subsystem
                                  [    0.041868] DMI not present or invalid.
                                  [    0.042584] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                                  [    0.046262] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
                                  [    0.046585] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                                  [    0.047571] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
                                  [    0.047683] audit: initializing netlink subsys (disabled)
                                  [    0.047983] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
                                  [    0.048646] thermal_sys: Registered thermal governor 'step_wise'
                                  [    0.048741] cpuidle: using governor menu
                                  [    0.049164] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
                                  [    0.049383] ASID allocator initialised with 32768 entries
                                  [    0.049565] Serial: AMBA PL011 UART driver
                                  [    0.063137] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                                  [    0.084311] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
                                  [    0.088327] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
                                  [    0.104676] KASLR enabled
                                  [    0.140261] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                                  [    0.146221] SCSI subsystem initialized
                                  [    0.146507] usbcore: registered new interface driver usbfs
                                  [    0.146580] usbcore: registered new interface driver hub
                                  [    0.146662] usbcore: registered new device driver usb
                                  [    0.147073] usb_phy_generic phy: supply vcc not found, using dummy regulator
                                  [    0.147309] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
                                  [    0.147691] pps_core: LinuxPPS API ver. 1 registered
                                  [    0.147716] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                                  [    0.147757] PTP clock support registered
                                  [    0.148896] vgaarb: loaded
                                  [    0.149710] clocksource: Switched to clocksource arch_sys_counter
                                  [    0.150281] VFS: Disk quotas dquot_6.6.0
                                  [    0.150377] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                                  [    0.150578] FS-Cache: Loaded
                                  [    0.150752] CacheFiles: Loaded
                                  [    0.160200] NET: Registered PF_INET protocol family
                                  [    0.160964] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
                                  [    0.165755] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
                                  [    0.165933] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
                                  [    0.165980] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
                                  [    0.166244] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
                                  [    0.167292] TCP: Hash tables configured (established 32768 bind 32768)
                                  [    0.167581] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
                                  [    0.167697] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
                                  [    0.168044] NET: Registered PF_UNIX/PF_LOCAL protocol family
                                  [    0.168924] RPC: Registered named UNIX socket transport module.
                                  [    0.168960] RPC: Registered udp transport module.
                                  [    0.168980] RPC: Registered tcp transport module.
                                  [    0.168999] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                  [    0.169035] PCI: CLS 0 bytes, default 64
                                  [    0.171722] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
                                  [    0.172153] kvm [1]: IPA Size Limit: 44 bits
                                  [    0.173502] kvm [1]: vgic interrupt IRQ9
                                  [    0.173797] kvm [1]: Hyp mode initialized successfully
                                  [    1.334410] Initialise system trusted keyrings
                                  [    1.334915] workingset: timestamp_bits=46 max_order=20 bucket_order=0
                                  [    1.342628] zbud: loaded
                                  [    1.345546] NFS: Registering the id_resolver key type
                                  [    1.345613] Key type id_resolver registered
                                  [    1.345634] Key type id_legacy registered
                                  [    1.345814] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                  [    1.345845] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                                  [    1.347312] Key type asymmetric registered
                                  [    1.347345] Asymmetric key parser 'x509' registered
                                  [    1.347439] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
                                  [    1.347734] io scheduler mq-deadline registered
                                  [    1.347762] io scheduler kyber registered
                                  [    1.349781] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)[    1.358754] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                                  [    1.358821] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff][    1.358930] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                                  [    1.359032] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
                                  [    1.360100] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                                  [    1.360134] pci_bus 0000:00: root bus resource [bus 00-ff]
                                  [    1.360163] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                                  [    1.360254] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                                  [    1.360534] pci 0000:00:00.0: PME# supported from D0 D3hot
                                  [    1.364740] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
                                  [    1.364941] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
                                  [    1.365083] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
                                  [    1.431804] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                                  [    1.431989] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                                  [    1.432131] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                                  [    1.432629] pci 0000:01:00.0: PME# supported from D0 D3hot
                                  [    1.433436] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                                  [    1.433477] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                                  [    1.433535] pci 0000:00:00.0: PCI bridge to [bus 01]
                                  [    1.433567] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                                  [    1.447270] iproc-rng200 fe104000.rng: hwrng registered
                                  [    1.447901] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                                  [    1.449533] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                                  [    1.463027] brd: module loaded
                                  [    1.472079] loop: module loaded
                                  [    1.472972] Loading iSCSI transport class v2.0-870.
                                  [    1.478582] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                                  [    1.537878] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                                  [    1.539089] usbcore: registered new interface driver r8152
                                  [    1.539178] usbcore: registered new interface driver lan78xx
                                  [    1.539273] usbcore: registered new interface driver smsc95xx
                                  [    1.586796] pci 0000:00:00.0: enabling device (0000 -> 0002)
                                  [    1.586993] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                  [    1.587037] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                                  [    1.587824] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
                                  [    1.588893] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                  [    1.588928] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                                  [    1.588965] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                                  [    1.589391] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
                                  [    1.589428] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                  [    1.589456] usb usb1: Product: xHCI Host Controller
                                  [    1.589478] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
                                  [    1.589500] usb usb1: SerialNumber: 0000:01:00.0[    1.590334] hub 1-0:1.0: USB hub found
                                  [    1.590421] hub 1-0:1.0: 1 port detected
                                  [    1.591402] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
                                  [    1.591439] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                  [    1.591466] usb usb2: Product: xHCI Host Controller
                                  [    1.591489] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
                                  [    1.591511] usb usb2: SerialNumber: 0000:01:00.0[    1.592216] hub 2-0:1.0: USB hub found
                                  [    1.592340] hub 2-0:1.0: 4 ports detected
                                  [    1.594223] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                  [    1.594604] dwc_otg: FIQ enabled
                                  [    1.594616] dwc_otg: NAK holdoff enabled
                                  [    1.594627] dwc_otg: FIQ split-transaction FSM enabled
                                  [    1.594644] Module dwc_common_port init
                                  [    1.595244] usbcore: registered new interface driver uas
                                  [    1.595367] usbcore: registered new interface driver usb-storage
                                  [    1.595625] mousedev: PS/2 mouse device common for all mice
                                  [    1.602490] sdhci: Secure Digital Host Controller Interface driver
                                  [    1.602530] sdhci: Copyright(c) Pierre Ossman
                                  [    1.603257] sdhci-pltfm: SDHCI platform and OF driver helper
                                  [    1.607001] ledtrig-cpu: registered to indicate activity on CPUs
                                  [    1.607381] hid: raw HID events driver (C) Jiri Kosina
                                  [    1.607617] usbcore: registered new interface driver usbhid
                                  [    1.607644] usbhid: USB HID core driver
                                  [    1.616816] NET: Registered PF_PACKET protocol family
                                  [    1.616991] Key type dns_resolver registered
                                  [    1.618462] registered taskstats version 1
                                  [    1.618561] Loading compiled-in X.509 certificates
                                  [    1.619507] Key type .fscrypt registered
                                  [    1.619535] Key type fscrypt-provisioning registered
                                  [    1.635627] uart-pl011 fe201000.serial: there is not valid maps for state default
                                  [    1.636409] uart-pl011 fe201000.serial: cts_event_workaround enabled
                                  [    1.636599] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                                  [    1.646078] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                  [    1.646583] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                                  [    1.647952] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                  [    1.647985] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                                  [    1.679960] of_cfs_init
                                  [    1.680106] of_cfs_init: OK
                                  [    1.712931] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                                  [    1.713531] Waiting for root device PARTUUID=105e3ec4-02...
                                  [    1.767144] mmc1: new high speed SDIO card at address 0001
                                  [    1.815348] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                                  [    1.816450] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
                                  [    1.821077]  mmcblk0: p1 p2
                                  [    1.821735] mmcblk0: mmc0:aaaa SL16G 14.8 GiB (quirks 0x00004000)
                                  [    1.845752] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                                  [    1.850330] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [    1.850439] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [    1.855942] devtmpfs: mounted
                                  [    1.864826] Freeing unused kernel memory: 4160K
                                  [    1.865049] Run /sbin/init as init process
                                  [    1.865071]   with arguments:
                                  [    1.865081]     /sbin/init
                                  [    1.865091]   with environment:
                                  [    1.865100]     HOME=/
                                  [    1.865110]     TERM=linux
                                  [    1.996424] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                                  [    1.996485] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                                  [    1.996514] usb 1-1: Product: USB2.0 Hub
                                  [    1.998823] hub 1-1:1.0: USB hub found
                                  [    1.999163] hub 1-1:1.0: 4 ports detected
                                  [    2.248990] systemd[1]: System time before build time, advancing clock.
                                  [    2.429091] NET: Registered PF_INET6 protocol family
                                  [    2.431100] Segment Routing with IPv6
                                  [    2.431161] In-situ OAM (IOAM) with IPv6
                                  [    2.508178] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
                                  [    2.509274] systemd[1]: Detected architecture arm64.
                                  [    2.520793] systemd[1]: Set hostname to <raspberrypi4>.
                                  [    3.289012] systemd[1]: Queued start job for default target Multi-User System.
                                  [    3.311430] systemd[1]: Created slice system-getty.slice.
                                  [    3.313274] systemd[1]: Created slice system-modprobe.slice.
                                  [    3.314709] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                                  [    3.315891] systemd[1]: Created slice User and Session Slice.
                                  [    3.316725] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
                                  [    3.317483] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                                  [    3.318996] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                                  [    3.319540] systemd[1]: Reached target Local Encrypted Volumes.
                                  [    3.320038] systemd[1]: Reached target Paths.
                                  [    3.320465] systemd[1]: Reached target Slices.
                                  [    3.320866] systemd[1]: Reached target Swap.
                                  [    3.326933] systemd[1]: Listening on Syslog Socket.
                                  [    3.328075] systemd[1]: Listening on fsck to fsckd communication Socket.
                                  [    3.328784] systemd[1]: Listening on initctl Compatibility Named Pipe.
                                  [    3.330439] systemd[1]: Listening on Journal Audit Socket.
                                  [    3.331557] systemd[1]: Listening on Journal Socket (/dev/log).
                                  [    3.332842] systemd[1]: Listening on Journal Socket.
                                  [    3.335075] systemd[1]: Listening on udev Control Socket.
                                  [    3.336215] systemd[1]: Listening on udev Kernel Socket.
                                  [    3.337489] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                                  [    3.358240] systemd[1]: Mounting POSIX Message Queue File System...
                                  [    3.363375] systemd[1]: Mounting RPC Pipe File System...
                                  [    3.369344] systemd[1]: Mounting Kernel Debug File System...
                                  [    3.375373] systemd[1]: Mounting Kernel Trace File System...
                                  [    3.376420] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
                                  [    3.383453] systemd[1]: Starting Restore / save the current clock...
                                  [    3.390057] systemd[1]: Starting Set the console keyboard layout...
                                  [    3.396146] systemd[1]: Starting Create list of static device nodes for the current kernel...
                                  [    3.402500] systemd[1]: Starting Load Kernel Module configfs...
                                  [    3.409132] systemd[1]: Starting Load Kernel Module drm...
                                  [    3.415968] systemd[1]: Starting Load Kernel Module fuse...
                                  [    3.419780] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.[    3.428792] systemd[1]: Starting File System Check on Root Device...
                                  [    3.439346] systemd[1]: Starting Journal Service...
                                  [    3.467401] systemd[1]: Starting Load Kernel Modules...
                                  [    3.473558] systemd[1]: Starting Coldplug All udev Devices...
                                  [    3.483740] fuse: init (API version 7.37)
                                  [    3.494242] systemd[1]: Mounted POSIX Message Queue File System.
                                  [    3.495657] systemd[1]: Mounted RPC Pipe File System.
                                  [    3.499033] systemd[1]: Mounted Kernel Debug File System.
                                  [    3.500545] systemd[1]: Mounted Kernel Trace File System.
                                  [    3.503366] systemd[1]: Finished Restore / save the current clock.
                                  [    3.510380] systemd[1]: Finished Create list of static device nodes for the current kernel.
                                  [    3.513188] systemd[1]: modprobe@configfs.service: Succeeded.
                                  [    3.516525] systemd[1]: Finished Load Kernel Module configfs.
                                  [    3.519251] systemd[1]: modprobe@fuse.service: Succeeded.
                                  [    3.520982] systemd[1]: Finished Load Kernel Module fuse.
                                  [    3.555682] systemd[1]: Mounting FUSE Control File System...
                                  [    3.569009] systemd[1]: Mounting Kernel Configuration File System...
                                  [    3.576662] systemd[1]: Started File System Check Daemon to report status.
                                  [    3.594430] systemd[1]: Finished Load Kernel Modules.
                                  [    3.595784] systemd[1]: Mounted FUSE Control File System.
                                  [    3.596760] systemd[1]: Mounted Kernel Configuration File System.
                                  [    3.603099] systemd[1]: Starting Apply Kernel Variables...
                                  [    3.625556] systemd[1]: modprobe@drm.service: Succeeded.
                                  [    3.627838] systemd[1]: Finished Load Kernel Module drm.
                                  [    3.663414] systemd[1]: Finished File System Check on Root Device.
                                  [    3.666385] systemd[1]: Finished Apply Kernel Variables.
                                  [    3.694871] systemd[1]: Starting Remount Root and Kernel File Systems...
                                  [    3.844759] systemd[1]: Started Journal Service.[    3.847279] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  [    3.962764] systemd-journald[142]: Received client request to flush runtime journal.
                                  [    3.975388] systemd-journald[142]: File /var/log/journal/d3a8466ddfb64ce6bef13e128446c843/system.journal corrupted or uncleanly shut down, renaming and replacing.
                                  [    4.905676] mc: Linux media interface: v0.10
                                  [    4.914953] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    4.917029] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                  [    4.917069] [vc_sm_connected_init]: start
                                  [    4.926201] [vc_sm_connected_init]: installed successfully
                                  [    5.018774] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
                                  [    5.046480] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
                                  [    5.169627] videodev: Linux video capture interface: v2.00
                                  [    5.173973] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    5.254392] bcm2835_audio bcm2835_audio: card created with 8 channels
                                  [    5.448834] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    5.493359] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    5.507510] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    5.523435] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    5.588822] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    5.593790] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    5.627287] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                                  [    5.648568] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                  [    5.648649] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                  [    5.655271] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                  [    5.655333] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                  [    5.675489] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                  [    5.675550] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                  [    5.676946] rpivid feb10000.codec: Device registered as /dev/video19
                                  [    5.707838] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                                  [    5.715130] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                                  [    5.715224] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                                  [    5.722136] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
                                  [    5.722197] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
                                  [    5.726668] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                                  [    5.733318] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                                  [    5.739418] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                                  [    5.740081] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                                  [    5.740123] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                  [    5.740145] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                  [    5.740171] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                  [    5.740200] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                  [    5.811652] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
                                  [    5.911546] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
                                  [    5.922153] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
                                  [    5.978814] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
                                  [    5.978863] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                  [    5.978887] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                  [    5.978922] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                  [    5.978946] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                  [    5.979378] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                  [    6.001857] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                  [    6.060334] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                  [    6.083789] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
                                  [    6.401215] brcmfmac: F1 signature read @0x18000000=0x15264345
                                  [    6.416568] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                  [    6.417891] usbcore: registered new interface driver brcmfmac
                                  [    6.687279] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
                                  [    6.797633] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
                                  [    6.817046] Registered IR keymap rc-cec
                                  [    6.818226] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
                                  [    6.819325] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
                                  [    6.853345] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
                                  [    6.878085] Registered IR keymap rc-cec
                                  [    6.878363] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
                                  [    6.878602] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
                                  [    6.935958] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
                                  [    6.946363] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
                                  [    6.970239] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
                                  [    6.973814] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
                                  [    6.974407] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
                                  [    6.974740] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
                                  [    6.975200] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
                                  [    7.078286] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                                  [    7.084554] vc4-drm gpu: [drm] Cannot find any crtc or sizes
                                  [    7.167676] uart-pl011 fe201000.serial: no DMA platform data
                                  [    7.190981] 8021q: 802.1Q VLAN Support v1.8
                                  [    7.316217] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                                  [    8.039347] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                                  [    8.048847] bcmgenet fd580000.ethernet eth0: Link is Down
                                  [   12.125872] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                                  [   12.125916] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                  [   13.888659] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                                  [   15.390312] Bluetooth: Core ver 2.22
                                  [   15.390400] NET: Registered PF_BLUETOOTH protocol family
                                  [   15.390405] Bluetooth: HCI device and connection manager initialized
                                  [   15.390421] Bluetooth: HCI socket layer initialized
                                  [   15.390429] Bluetooth: L2CAP socket layer initialized
                                  [   15.390442] Bluetooth: SCO socket layer initialized
                                  [   15.398400] Bluetooth: HCI UART driver ver 2.3
                                  [   15.398423] Bluetooth: HCI UART protocol H4 registered
                                  [   15.398847] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                  [   15.400455] Bluetooth: HCI UART protocol Broadcom registered
                                  [   15.760872] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                  [   15.760892] Bluetooth: BNEP filters: protocol multicast
                                  [   15.760908] Bluetooth: BNEP socket layer initialized
                                  [   15.765360] Bluetooth: MGMT ver 1.22
                                  [   15.774030] NET: Registered PF_ALG protocol family
                                  • R rsw2004
                                    [    1.865100]     HOME=/
                                    @rsw2004
                                    Keine Ahnung was da schief ist.
                                    Aber hast du auch
                                    dmesg -T
                                    eingegeben? Eigentlich sollten dann auch Zeitstempel in der Ausgabe erscheinen.
                                      @rsw2004
                                      Aber hast du auch
                                      dmesg -T
                                      rsw2004
                                      Neuer Versuch
                                      [Tue Aug  8 22:54:46 2023] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
                                      [Tue Aug  8 22:54:46 2023] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
                                      [Tue Aug  8 22:54:46 2023] random: crng init done
                                      [Tue Aug  8 22:54:46 2023] Machine model: Raspberry Pi 4 Model B Rev 1.4
                                      [Tue Aug  8 22:54:46 2023] efi: UEFI not found.
                                      [Tue Aug  8 22:54:46 2023] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
                                      [Tue Aug  8 22:54:46 2023] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool[Tue Aug  8 22:54:46 2023] Zone ranges:
                                      [Tue Aug  8 22:54:46 2023]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
                                      [Tue Aug  8 22:54:46 2023]   DMA32    [mem 0x0000000040000000-0x00000000fbffffff]
                                      [Tue Aug  8 22:54:46 2023]   Normal   empty
                                      [Tue Aug  8 22:54:46 2023] Movable zone start for each node
                                      [Tue Aug  8 22:54:46 2023] Early memory node ranges[Tue Aug  8 22:54:46 2023]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
                                      [Tue Aug  8 22:54:46 2023]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                                      [Tue Aug  8 22:54:46 2023] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                                      [Tue Aug  8 22:54:46 2023] On node 0, zone DMA32: 19456 pages in unavailable ranges
                                      [Tue Aug  8 22:54:46 2023] On node 0, zone DMA32: 16384 pages in unavailable ranges
                                      [Tue Aug  8 22:54:46 2023] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
                                      [Tue Aug  8 22:54:46 2023] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
                                      [Tue Aug  8 22:54:46 2023] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                                      [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU0
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-v2
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-v3a
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-v4
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-BHB
                                      [Tue Aug  8 22:54:46 2023] CPU features: kernel page table isolation forced ON by KASLR
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: Kernel page table isolation (KPTI)
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: ARM erratum 1742098
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
                                      [Tue Aug  8 22:54:46 2023] alternatives: applying boot alternatives
                                      [Tue Aug  8 22:54:46 2023] Built 1 zonelists, mobility grouping on.  Total pages: 996912
                                      [Tue Aug  8 22:54:46 2023] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] mem auto-init: stack:off, heap alloc:off, heap free:off
                                      [Tue Aug  8 22:54:46 2023] software IO TLB: area num 4.
                                      [Tue Aug  8 22:54:46 2023] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
                                      [Tue Aug  8 22:54:46 2023] Memory: 3356948K/4050944K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 169708K reserved, 524288K cma-reserved)
                                      [Tue Aug  8 22:54:46 2023] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                      [Tue Aug  8 22:54:46 2023] ftrace: allocating 39744 entries in 156 pages
                                      [Tue Aug  8 22:54:46 2023] ftrace: allocated 156 pages with 4 groups
                                      [Tue Aug  8 22:54:46 2023] trace event string verifier disabled
                                      [Tue Aug  8 22:54:46 2023] rcu: Preemptible hierarchical RCU implementation.
                                      [Tue Aug  8 22:54:46 2023] rcu:         RCU event tracing is enabled.
                                      [Tue Aug  8 22:54:46 2023] rcu:         RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
                                      [Tue Aug  8 22:54:46 2023]      Trampoline variant of Tasks RCU enabled.
                                      [Tue Aug  8 22:54:46 2023]      Rude variant of Tasks RCU enabled.
                                      [Tue Aug  8 22:54:46 2023]      Tracing variant of Tasks RCU enabled.
                                      [Tue Aug  8 22:54:46 2023] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                                      [Tue Aug  8 22:54:46 2023] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                                      [Tue Aug  8 22:54:46 2023] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
                                      [Tue Aug  8 22:54:46 2023] Root IRQ handler: gic_handle_irq
                                      [Tue Aug  8 22:54:46 2023] GIC: Using split EOI/Deactivate mode
                                      [Tue Aug  8 22:54:46 2023] rcu: srcu_init: Setting srcu_struct sizes based on contention.
                                      [Tue Aug  8 22:54:46 2023] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                                      [Tue Aug  8 22:54:46 2023] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                                      [Tue Aug  8 22:54:46 2023] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns[Tue Aug  8 22:54:46 2023] Console: colour dummy device 80x25
                                      [Tue Aug  8 22:54:46 2023] printk: console [tty1] enabled
                                      [Tue Aug  8 22:54:46 2023] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
                                      [Tue Aug  8 22:54:46 2023] pid_max: default: 32768 minimum: 301
                                      [Tue Aug  8 22:54:46 2023] LSM: Security Framework initializing
                                      [Tue Aug  8 22:54:46 2023] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] cgroup: Disabling memory control group subsystem
                                      [Tue Aug  8 22:54:46 2023] cblist_init_generic: Setting adjustable number of callback queues.
                                      [Tue Aug  8 22:54:46 2023] cblist_init_generic: Setting shift to 2 and lim to 1.
                                      [Tue Aug  8 22:54:46 2023] rcu: Hierarchical SRCU implementation.
                                      [Tue Aug  8 22:54:46 2023] rcu:         Max phase no-delay instances is 1000.
                                      [Tue Aug  8 22:54:46 2023] EFI services will not be available.
                                      [Tue Aug  8 22:54:46 2023] smp: Bringing up secondary CPUs ...
                                      [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU1
                                      [Tue Aug  8 22:54:46 2023] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
                                      [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU2
                                      [Tue Aug  8 22:54:46 2023] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
                                      [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU3
                                      [Tue Aug  8 22:54:46 2023] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
                                      [Tue Aug  8 22:54:46 2023] smp: Brought up 1 node, 4 CPUs
                                      [Tue Aug  8 22:54:46 2023] SMP: Total of 4 processors activated.
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: 32-bit EL0 Support
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: 32-bit EL1 Support
                                      [Tue Aug  8 22:54:46 2023] CPU features: detected: CRC32 instructions
                                      [Tue Aug  8 22:54:46 2023] CPU: All CPU(s) started at EL2
                                      [Tue Aug  8 22:54:46 2023] alternatives: applying system-wide alternatives
                                      [Tue Aug  8 22:54:46 2023] devtmpfs: initialized
                                      [Tue Aug  8 22:54:46 2023] Enabled cp15_barrier support
                                      [Tue Aug  8 22:54:46 2023] Enabled setend support
                                      [Tue Aug  8 22:54:46 2023] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                                      [Tue Aug  8 22:54:46 2023] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] pinctrl core: initialized pinctrl subsystem
                                      [Tue Aug  8 22:54:46 2023] DMI not present or invalid.
                                      [Tue Aug  8 22:54:46 2023] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                                      [Tue Aug  8 22:54:46 2023] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
                                      [Tue Aug  8 22:54:46 2023] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                                      [Tue Aug  8 22:54:46 2023] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations[Tue Aug  8 22:54:46 2023] audit: initializing netlink subsys (disabled)
                                      [Tue Aug  8 22:54:46 2023] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
                                      [Tue Aug  8 22:54:46 2023] thermal_sys: Registered thermal governor 'step_wise'
                                      [Tue Aug  8 22:54:46 2023] cpuidle: using governor menu
                                      [Tue Aug  8 22:54:46 2023] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
                                      [Tue Aug  8 22:54:46 2023] ASID allocator initialised with 32768 entries
                                      [Tue Aug  8 22:54:46 2023] Serial: AMBA PL011 UART driver
                                      [Tue Aug  8 22:54:46 2023] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                                      [Tue Aug  8 22:54:46 2023] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
                                      [Tue Aug  8 22:54:46 2023] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
                                      [Tue Aug  8 22:54:46 2023] KASLR enabled
                                      [Tue Aug  8 22:54:46 2023] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                                      [Tue Aug  8 22:54:46 2023] SCSI subsystem initialized
                                      [Tue Aug  8 22:54:46 2023] usbcore: registered new interface driver usbfs
                                      [Tue Aug  8 22:54:46 2023] usbcore: registered new interface driver hub
                                      [Tue Aug  8 22:54:46 2023] usbcore: registered new device driver usb
                                      [Tue Aug  8 22:54:46 2023] usb_phy_generic phy: supply vcc not found, using dummy regulator
                                      [Tue Aug  8 22:54:46 2023] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
                                      [Tue Aug  8 22:54:46 2023] pps_core: LinuxPPS API ver. 1 registered
                                      [Tue Aug  8 22:54:46 2023] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                                      [Tue Aug  8 22:54:46 2023] PTP clock support registered
                                      [Tue Aug  8 22:54:46 2023] vgaarb: loaded
                                      [Tue Aug  8 22:54:46 2023] clocksource: Switched to clocksource arch_sys_counter
                                      [Tue Aug  8 22:54:46 2023] VFS: Disk quotas dquot_6.6.0
                                      [Tue Aug  8 22:54:46 2023] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                                      [Tue Aug  8 22:54:46 2023] FS-Cache: Loaded
                                      [Tue Aug  8 22:54:46 2023] CacheFiles: Loaded
                                      [Tue Aug  8 22:54:46 2023] NET: Registered PF_INET protocol family
                                      [Tue Aug  8 22:54:46 2023] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] TCP: Hash tables configured (established 32768 bind 32768)
                                      [Tue Aug  8 22:54:46 2023] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
                                      [Tue Aug  8 22:54:46 2023] NET: Registered PF_UNIX/PF_LOCAL protocol family
                                      [Tue Aug  8 22:54:46 2023] RPC: Registered named UNIX socket transport module.
                                      [Tue Aug  8 22:54:46 2023] RPC: Registered udp transport module.
                                      [Tue Aug  8 22:54:46 2023] RPC: Registered tcp transport module.
                                      [Tue Aug  8 22:54:46 2023] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                      [Tue Aug  8 22:54:46 2023] PCI: CLS 0 bytes, default 64
                                      [Tue Aug  8 22:54:46 2023] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
                                      [Tue Aug  8 22:54:46 2023] kvm [1]: IPA Size Limit: 44 bits
                                      [Tue Aug  8 22:54:46 2023] kvm [1]: vgic interrupt IRQ9
                                      [Tue Aug  8 22:54:46 2023] kvm [1]: Hyp mode initialized successfully
                                      [Tue Aug  8 22:54:47 2023] Initialise system trusted keyrings
                                      [Tue Aug  8 22:54:47 2023] workingset: timestamp_bits=46 max_order=20 bucket_order=0
                                      [Tue Aug  8 22:54:47 2023] zbud: loaded
                                      [Tue Aug  8 22:54:47 2023] NFS: Registering the id_resolver key type
                                      [Tue Aug  8 22:54:47 2023] Key type id_resolver registered
                                      [Tue Aug  8 22:54:47 2023] Key type id_legacy registered
                                      [Tue Aug  8 22:54:47 2023] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                      [Tue Aug  8 22:54:47 2023] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                                      [Tue Aug  8 22:54:47 2023] Key type asymmetric registered
                                      [Tue Aug  8 22:54:47 2023] Asymmetric key parser 'x509' registered
                                      [Tue Aug  8 22:54:47 2023] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
                                      [Tue Aug  8 22:54:47 2023] io scheduler mq-deadline registered
                                      [Tue Aug  8 22:54:47 2023] io scheduler kyber registered
                                      [Tue Aug  8 22:54:47 2023] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
                                      [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                                      [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                                      [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                                      [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
                                      [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                                      [Tue Aug  8 22:54:47 2023] pci_bus 0000:00: root bus resource [bus 00-ff]
                                      [Tue Aug  8 22:54:47 2023] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                                      [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                                      [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: PME# supported from D0 D3hot
                                      [Tue Aug  8 22:54:47 2023] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
                                      [Tue Aug  8 22:54:47 2023] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
                                      [Tue Aug  8 22:54:47 2023] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
                                      [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                                      [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                                      [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                                      [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: PME# supported from D0 D3hot
                                      [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                                      [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                                      [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: PCI bridge to [bus 01]
                                      [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                                      [Tue Aug  8 22:54:47 2023] iproc-rng200 fe104000.rng: hwrng registered
                                      [Tue Aug  8 22:54:47 2023] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                                      [Tue Aug  8 22:54:47 2023] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                                      [Tue Aug  8 22:54:47 2023] brd: module loaded
                                      [Tue Aug  8 22:54:47 2023] loop: module loaded
                                      [Tue Aug  8 22:54:47 2023] Loading iSCSI transport class v2.0-870.
                                      [Tue Aug  8 22:54:47 2023] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                                      [Tue Aug  8 22:54:47 2023] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                                      [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver r8152
                                      [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver lan78xx
                                      [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver smsc95xx
                                      [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: enabling device (0000 -> 0002)
                                      [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                      [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                                      [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
                                      [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                                      [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                                      [Tue Aug  8 22:54:47 2023] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
                                      [Tue Aug  8 22:54:47 2023] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                      [Tue Aug  8 22:54:47 2023] usb usb1: Product: xHCI Host Controller
                                      [Tue Aug  8 22:54:47 2023] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
                                      [Tue Aug  8 22:54:47 2023] usb usb1: SerialNumber: 0000:01:00.0
                                      [Tue Aug  8 22:54:47 2023] hub 1-0:1.0: USB hub found
                                      [Tue Aug  8 22:54:47 2023] hub 1-0:1.0: 1 port detected
                                      [Tue Aug  8 22:54:47 2023] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
                                      [Tue Aug  8 22:54:47 2023] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                      [Tue Aug  8 22:54:47 2023] usb usb2: Product: xHCI Host Controller
                                      [Tue Aug  8 22:54:47 2023] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
                                      [Tue Aug  8 22:54:47 2023] usb usb2: SerialNumber: 0000:01:00.0
                                      [Tue Aug  8 22:54:47 2023] hub 2-0:1.0: USB hub found
                                      [Tue Aug  8 22:54:47 2023] hub 2-0:1.0: 4 ports detected
                                      [Tue Aug  8 22:54:47 2023] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                      [Tue Aug  8 22:54:47 2023] dwc_otg: FIQ enabled
                                      [Tue Aug  8 22:54:47 2023] dwc_otg: NAK holdoff enabled
                                      [Tue Aug  8 22:54:47 2023] dwc_otg: FIQ split-transaction FSM enabled
                                      [Tue Aug  8 22:54:47 2023] Module dwc_common_port init
                                      [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver uas
                                      [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver usb-storage
                                      [Tue Aug  8 22:54:47 2023] mousedev: PS/2 mouse device common for all mice
                                      [Tue Aug  8 22:54:47 2023] sdhci: Secure Digital Host Controller Interface driver
                                      [Tue Aug  8 22:54:47 2023] sdhci: Copyright(c) Pierre Ossman
                                      [Tue Aug  8 22:54:47 2023] sdhci-pltfm: SDHCI platform and OF driver helper
                                      [Tue Aug  8 22:54:47 2023] ledtrig-cpu: registered to indicate activity on CPUs
                                      [Tue Aug  8 22:54:47 2023] hid: raw HID events driver (C) Jiri Kosina
                                      [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver usbhid
                                      [Tue Aug  8 22:54:47 2023] usbhid: USB HID core driver
                                      [Tue Aug  8 22:54:47 2023] NET: Registered PF_PACKET protocol family
                                      [Tue Aug  8 22:54:47 2023] Key type dns_resolver registered
                                      [Tue Aug  8 22:54:47 2023] registered taskstats version 1
                                      [Tue Aug  8 22:54:47 2023] Loading compiled-in X.509 certificates
                                      [Tue Aug  8 22:54:47 2023] Key type .fscrypt registered
                                      [Tue Aug  8 22:54:47 2023] Key type fscrypt-provisioning registered
                                      [Tue Aug  8 22:54:47 2023] uart-pl011 fe201000.serial: there is not valid maps for state default
                                      [Tue Aug  8 22:54:47 2023] uart-pl011 fe201000.serial: cts_event_workaround enabled
                                      [Tue Aug  8 22:54:47 2023] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                                      [Tue Aug  8 22:54:47 2023] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                      [Tue Aug  8 22:54:47 2023] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                                      [Tue Aug  8 22:54:47 2023] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                      [Tue Aug  8 22:54:47 2023] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                                      [Tue Aug  8 22:54:47 2023] of_cfs_init
                                      [Tue Aug  8 22:54:47 2023] of_cfs_init: OK
                                      [Tue Aug  8 22:54:47 2023] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                                      [Tue Aug  8 22:54:47 2023] Waiting for root device PARTUUID=105e3ec4-02...
                                      [Tue Aug  8 22:54:47 2023] mmc1: new high speed SDIO card at address 0001
                                      [Tue Aug  8 22:54:47 2023] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                                      [Tue Aug  8 22:54:47 2023] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
                                      [Tue Aug  8 22:54:47 2023]  mmcblk0: p1 p2
                                      [Tue Aug  8 22:54:47 2023] mmcblk0: mmc0:aaaa SL16G 14.8 GiB (quirks 0x00004000)
                                      [Tue Aug  8 22:54:47 2023] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                                      [Tue Aug  8 22:54:47 2023] devtmpfs: mounted
                                      [Tue Aug  8 22:54:47 2023] Freeing unused kernel memory: 4160K
                                      [Tue Aug  8 22:54:47 2023] Run /sbin/init as init process
                                      [Tue Aug  8 22:54:47 2023]   with arguments:
                                      [Tue Aug  8 22:54:47 2023]     /sbin/init
                                      [Tue Aug  8 22:54:47 2023]   with environment:
                                      [Tue Aug  8 22:54:47 2023]     HOME=/
                                      [Tue Aug  8 22:54:47 2023]     TERM=linux
                                      [Tue Aug  8 22:54:47 2023] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                                      [Tue Aug  8 22:54:47 2023] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                                      [Tue Aug  8 22:54:47 2023] usb 1-1: Product: USB2.0 Hub
                                      [Tue Aug  8 22:54:47 2023] hub 1-1:1.0: USB hub found
                                      [Tue Aug  8 22:54:47 2023] hub 1-1:1.0: 4 ports detected
                                      [Tue Aug  8 22:54:48 2023] systemd[1]: System time before build time, advancing clock.
                                      [Tue Aug  8 22:54:48 2023] NET: Registered PF_INET6 protocol family
                                      [Tue Aug  8 22:54:48 2023] Segment Routing with IPv6
                                      [Tue Aug  8 22:54:48 2023] In-situ OAM (IOAM) with IPv6
                                      [Tue Aug  8 22:54:48 2023] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
                                      [Tue Aug  8 22:54:48 2023] systemd[1]: Detected architecture arm64.
                                      [Tue Aug  8 22:54:48 2023] systemd[1]: Set hostname to <raspberrypi4>.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Queued start job for default target Multi-User System.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice system-getty.slice.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice system-modprobe.slice.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice User and Session Slice.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Local Encrypted Volumes.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Paths.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Slices.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Swap.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Syslog Socket.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on fsck to fsckd communication Socket.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on initctl Compatibility Named Pipe.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Journal Audit Socket.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Journal Socket (/dev/log).
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Journal Socket.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on udev Control Socket.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on udev Kernel Socket.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting POSIX Message Queue File System...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting RPC Pipe File System...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting Kernel Debug File System...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting Kernel Trace File System...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Restore / save the current clock...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Set the console keyboard layout...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Create list of static device nodes for the current kernel...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Module configfs...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Module drm...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Module fuse...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting File System Check on Root Device...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Journal Service...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Modules...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Coldplug All udev Devices...
                                      [Tue Aug  8 22:54:49 2023] fuse: init (API version 7.37)
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted POSIX Message Queue File System.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted RPC Pipe File System.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted Kernel Debug File System.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted Kernel Trace File System.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Restore / save the current clock.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Create list of static device nodes for the current kernel.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: modprobe@configfs.service: Succeeded.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Module configfs.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: modprobe@fuse.service: Succeeded.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Module fuse.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting FUSE Control File System...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting Kernel Configuration File System...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Started File System Check Daemon to report status.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Modules.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted FUSE Control File System.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted Kernel Configuration File System.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Apply Kernel Variables...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: modprobe@drm.service: Succeeded.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Module drm.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Finished File System Check on Root Device.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Apply Kernel Variables.
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Remount Root and Kernel File Systems...
                                      [Tue Aug  8 22:54:49 2023] systemd[1]: Started Journal Service.
                                      [Tue Aug  8 22:54:49 2023] systemd-journald[142]: Received client request to flush runtime journal.
                                      [Tue Aug  8 22:54:49 2023] systemd-journald[142]: File /var/log/journal/d3a8466ddfb64ce6bef13e128446c843/system.journal corrupted or uncleanly shut down, renaming and replacing.
                                      [Tue Aug  8 22:54:50 2023] mc: Linux media interface: v0.10
                                      [Tue Aug  8 22:54:50 2023] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                      [Tue Aug  8 22:54:50 2023] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                      [Tue Aug  8 22:54:50 2023] [vc_sm_connected_init]: start
                                      [Tue Aug  8 22:54:50 2023] [vc_sm_connected_init]: installed successfully
                                      [Tue Aug  8 22:54:51 2023] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
                                      [Tue Aug  8 22:54:51 2023] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
                                      [Tue Aug  8 22:54:51 2023] videodev: Linux video capture interface: v2.00
                                      [Tue Aug  8 22:54:51 2023] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                      [Tue Aug  8 22:54:51 2023] bcm2835_audio bcm2835_audio: card created with 8 channels
                                      [Tue Aug  8 22:54:51 2023] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                      [Tue Aug  8 22:54:51 2023] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
                                      [Tue Aug  8 22:54:51 2023] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                      [Tue Aug  8 22:54:51 2023] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                      [Tue Aug  8 22:54:51 2023] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                      [Tue Aug  8 22:54:51 2023] rpivid feb10000.codec: Device registered as /dev/video19
                                      [Tue Aug  8 22:54:51 2023] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
                                      [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
                                      [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                      [Tue Aug  8 22:54:52 2023] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                      [Tue Aug  8 22:54:52 2023] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                      [Tue Aug  8 22:54:52 2023] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid[Tue Aug  8 22:54:52 2023] brcmfmac: F1 signature read @0x18000000=0x15264345
                                      [Tue Aug  8 22:54:52 2023] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                      [Tue Aug  8 22:54:52 2023] usbcore: registered new interface driver brcmfmac
                                      [Tue Aug  8 22:54:52 2023] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
                                      [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
                                      [Tue Aug  8 22:54:52 2023] Registered IR keymap rc-cec
                                      [Tue Aug  8 22:54:52 2023] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
                                      [Tue Aug  8 22:54:52 2023] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
                                      [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
                                      [Tue Aug  8 22:54:52 2023] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
                                      [Tue Aug  8 22:54:52 2023] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
                                      [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
                                      [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
                                      [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
                                      [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
                                      [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
                                      [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
                                      [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
                                      [Tue Aug  8 22:54:53 2023] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                                      [Tue Aug  8 22:54:53 2023] vc4-drm gpu: [drm] Cannot find any crtc or sizes
                                      [Tue Aug  8 22:54:53 2023] uart-pl011 fe201000.serial: no DMA platform data
                                      [Tue Aug  8 22:54:53 2023] 8021q: 802.1Q VLAN Support v1.8
                                      [Tue Aug  8 22:54:53 2023] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                                      [Tue Aug  8 22:54:54 2023] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                                      [Tue Aug  8 22:54:54 2023] bcmgenet fd580000.ethernet eth0: Link is Down
                                      [Tue Aug  8 22:54:58 2023] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                                      [Tue Aug  8 22:54:58 2023] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                      [Tue Aug  8 22:54:59 2023] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: Core ver 2.22[Tue Aug  8 22:55:01 2023] NET: Registered PF_BLUETOOTH protocol family
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: HCI device and connection manager initialized
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: HCI socket layer initialized
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: L2CAP socket layer initialized
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: SCO socket layer initialized
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART driver ver 2.3
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART protocol H4 registered
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART protocol Broadcom registered
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: BNEP filters: protocol multicast
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: BNEP socket layer initialized
                                      [Tue Aug  8 22:55:01 2023] Bluetooth: MGMT ver 1.22[Tue Aug  8 22:55:01 2023] NET: Registered PF_ALG protocol family
                                      R 1 Antwort Letzte Antwort
                                      • R rsw2004
                                        Neuer Versuch
                                        [Tue Aug  8 22:54:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Tue Aug  8 22:54:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Tue Aug  8 22:54:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Tue Aug  8 22:54:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        rsw2004
                                        @Thomas-Braun
                                        Was wäre denn in dem Fall wahrscheinlicher? Defekte Speicherkarte oder gar ein defekt am Raspberry?
                                        Thomas BraunT Ro75R 2 Antworten Letzte Antwort
                                        • R rsw2004
                                          @Thomas-Braun
                                          @rsw2004
                                          Keine Ahnung.
