  4. Fehlermeldung AxiosError
    5.2k
12 Beiträge 5 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • bergjetB bergjet
    Ich bekomme jede Stunde und 10 Minuten (13:10; 14:10; 15:10) die Meldung
    javascript.0
    2023-08-07 16:10:00.470	error	AxiosError: Request failed with status code 404 at settle (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/settle.js:19:12) at RedirectableRequest.handleResponse (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:518:9) at RedirectableRequest.emit (node:events:514:28) at RedirectableRequest.emit (node:domain:489:12) at RedirectableRequest._processResponse (/opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects/index.js:356:10) at ClientRequest.RedirectableRequest._onNativeResponse (/opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects/index.js:62:10) at Object.onceWrapper (node:events:629:26) at ClientRequest.emit (node:events:526:35) at ClientRequest.emit (node:domain:489:12) at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:700:27) at HTTPParser.parserOnHeadersComplete (node:_http_common:119:17) at TLSSocket.socketOnData (node:_http_client:541:22) at TLSSocket.emit (node:events:514:28) at TLSSocket.emit (node:domain:489:12) at addChunk (node:internal/streams/readable:324:12) at readableAddChunk (node:internal/streams/readable:297:9) at TLSSocket.Readable.push (node:internal/streams/readable:234:10) at TLSWrap.onStreamRead (node:internal/stream_base_commons:190:23)
    javascript.0
    2023-08-07 16:10:00.470	error	Error: Request failed with status code 404
    javascript.0
    2023-08-07 16:10:00.469	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    Ich nehme einmal an, da wird ein Script ausgeführt.
    Wie komme ich dem Error auf die Spur?
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @bergjet sagte in Fehlermeldung AxiosError:
    Na indem Du Deine Skripte kontrollierst !
    Lehrling seit 1975 !!!
    bergjetB 1 Antwort Letzte Antwort
    • bergjetB bergjet
      javascript.0
      javascript.0
      javascript.0
      arteckA Offline
      arteckA Offline
      arteck
      @bergjet 404 ist seite nicht gefunden... kontrollier alle scripte wo du mit axios rum hampelst
      • DJMarc75D DJMarc75
        bergjetB Offline
        bergjetB Offline
        bergjet
        @djmarc75 sagte in Fehlermeldung AxiosError:
        Ich habe alle Script neu gestartet und keine Fehlermeldung bekommen. Deshalb dachte ich es kennt sich jemand aus und kann mir auf Grund der Fehlermeldung sagen, wo ich suchen soll.
        homee, ioBroker, iMac, iPhone, Sonos, Alaxa
        • bergjetB bergjet
          arteckA Offline
          arteckA Offline
          arteck
          wo ich suchen soll.
          du bist ja lustig... wir sollen uns in deien Scripten auskennen... der war gut..
          lesen kannst du aber..oder
          • arteckA arteck
            bergjetB Offline
            bergjetB Offline
            bergjet
            @arteck sagte in Fehlermeldung AxiosError:
            Also liegt der Fehler bei Axios? Möglicherweise ist es nicht mehr Verfügbar?
            arteckA HomoranH 2 Antworten Letzte Antwort
            • arteckA arteck
              wo ich suchen soll.
              bergjetB Offline
              bergjetB Offline
              bergjet
              Ich weiß nicht ob es von einem Script kommt.
              • bergjetB bergjet
                arteckA Offline
                arteckA Offline
                arteck
                @bergjet der Fehler liegt bei dir.. da du ja axios nutzt.. und in irgendeinen deinser Script wird axios auf eine Seite zugreifen die es nicht mehr gibt.
                • bergjetB bergjet
                  nein! es liegt an dem ominösen Skript, das mittels axios versuchtetwas aufzurufen, was nicht erreichbar ist
                  • bergjetB bergjet
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @bergjet im ernst
                    javascript.0 das steht doch FETT im LOG
                    • bergjetB bergjet
                      javascript.0
                      javascript.0
                      javascript.0
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      wenn du an alle axios requests in deinen skripten zuvor noch die url im log ausgibst, dann weißt du auch woran es hapert. ggfs. kannst du ja noch den skriptnamen davorsetzen. dann wird es noch einfacher
                      log('scriptname '+url);
                      Meine Adapter und Widgets
                      Links im Profil
                      • OliverIOO OliverIO
                        bergjetB Offline
                        bergjetB Offline
                        bergjet
                        @oliverio sagte in Fehlermeldung AxiosError:
                        Danke für die Hilfe. Seite gefunden.
