  4. Neuer Adapter für Roborock-Staubsauger
    6.3k
1.1k Beiträge 155 Kommentatoren 474.9k Aufrufe 138 Beobachtet
  • S SpacerX
    Ich habe nun mal Chrome installiert. Das ändert leider Garnichts.
    Noch mal eine Ausgabe dazu.
    [11:01:04.438][10.0.0.1:54441] server connect 142.250.184.206:443
    [11:01:04.485][10.0.0.1:54441] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for clients3.google.com, this may indicate that the client does not trust the proxy's certificate.
    [11:01:04.485][10.0.0.1:54441] client disconnect
    [11:01:04.485][10.0.0.1:54441] server disconnect 142.250.184.206:443
    [11:01:04.500][10.0.0.1:49611] client connect
    [11:01:04.610][10.0.0.1:54442] client connect
    [11:01:04.625][10.0.0.1:54442] server connect 142.250.184.206:443
    [11:01:04.672][10.0.0.1:54442] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for clients3.google.com, this may indicate that the client does not trust the proxy's certificate.
    [11:01:04.672][10.0.0.1:54442] client disconnect
    [11:01:04.672][10.0.0.1:54442] server disconnect 142.250.184.206:443
    [11:01:07.218][10.0.0.1:54381] client connect
    [11:01:07.250][10.0.0.1:54381] server connect 52.29.91.104:8883
    [11:01:07.359][10.0.0.1:54381] client disconnect
    [11:01:07.359][10.0.0.1:54381] server disconnect 52.29.91.104:8883
    [11:01:09.109][10.0.0.1:54443] client connect
    [11:01:09.124][10.0.0.1:54444] client connect
    [11:01:09.140][10.0.0.1:54443] server connect 18.195.207.39:443
    [11:01:09.155][10.0.0.1:54444] server connect 52.29.136.229:443
    [11:01:09.218][10.0.0.1:54443] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for api-eu.roborock.com, this may indicate that the client does not trust the proxy's certificate.
    [11:01:09.218][10.0.0.1:54443] client disconnect
    [11:01:09.218][10.0.0.1:54443] server disconnect 18.195.207.39:443
    [11:01:09.218][10.0.0.1:54444] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for awsde0.fds.api.xiaomi.com, this may indicate that the client does not trust the proxy's certificate.
    Die Verbindung zum iPhone mit WireGuard scheint zu Funktionieren nur vom Proxy zu Roborock usw. klappt anscheinend nicht weil was mit dem Zertifikat nicht hin haut.
    Ehrlich gesagt ist so langsam meine Frustschwelle erreicht.
    <frust = on>
    Wer sich den ganzen Müll mit den Zertifikaten ausgedacht hat gehört geteert und gefedert.
    <frust = off>
    Vielleicht war mein Vorgehen bei der ganzen Installation auch falsch.
    • Python installiert
    • pip installiert [python -m pip install --user pipx]
    • Dann die Installationen zu mitmproxy
      • py -m pipx install mitmproxy --force
      • py -m pipx inject mitmproxy websocket
      • py -m pipx inject mitmproxy websocket-client
    Noch jemand eine Idee wie man das Prob gelöst bekommt?
    @copystring
    Geht der Installationskram auch anders. In der Wiki ist von Python als Voraussetzung nicht die Rede. Ich nehme mal an durch die Programmiererei hast du den Kram eh auf dem Rechner. Deshalb klappts bei dir ohne Prob. Ich hab's nur nicht so mit den Zertifikaten und hab immer versucht dem aus dem Weg zu gehen.
    copystringC Offline
    copystringC Offline
    copystring
    #99
    @spacerx said in Neuer Adapter für Roborock-Staubsauger:
    Nein. mitmproxy braucht zwingend Python.
    Hast du das Zertifikat von mitmproxy denn auf dem iPhone als root Zertifikat hinzugefügt?
    Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
    https://paypal.me/copystring
    • copystringC copystring
      SpacerX
      #100
      @copystring ja habe ich.
      DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
      copystringC 1 Antwort Letzte Antwort
      • S SpacerX
        copystringC Offline
        copystringC Offline
        copystring
        schrieb am zuletzt editiert von copystring
        #101
        @spacerx mit iPhone kenne ich mich nur wenig aus. Sicher, dass es als root Zertifikat hinzugefügt ist? Alle anderen Zertifikatstypen wären falsch.
          SpacerX
          #102
          @copystring das war das Stichwort. Es reichte nicht das Profil zu Installieren. Da muss man beim iPhone doch tiefer in die Abgründe der Einstellungen.
          Jedenfalls zappelt jetzt was.
          • S SpacerX
            SpacerX
            #103
            @spacerx
            Ab und an tauchen folgende Meldungen auf.
            C:\Users\SpacerX\.local\pipx\venvs\mitmproxy\Scripts\python.exe
            [21:15:18.262] Packet type CONNACK is not supported yet!
            [21:15:18.262] Addon error: unpack requires a buffer of 2 bytes
            Traceback (most recent call last):
              File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 286, in tcp_message
                mqtt_packet = MQTTControlPacket(message.content)
              File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 83, in __init__
                self._parse_publish_variable_headers()
              File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 136, in _parse_publish_variable_headers
                field_length, field_content_bytes = self._parse_length_prefixed_bytes(offset)
              File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 127, in _parse_length_prefixed_bytes
                field_length = struct.unpack("!H", field_length_bytes)[0]
            struct.error: unpack requires a buffer of 2 bytes
            [21:15:18.309] [PUBLISH]
            Die Sniffing Message taucht bei mir leider auch nicht im Log auf.
            Jetzt weis ich noch nicht genau nach was ich schauen soll.
            • S SpacerX
              @spacerx
              copystringC Offline
              copystringC Offline
              copystring
              #104
              @spacerx okay. Kann ich mir aktuell nicht angucken. Bin im Urlaub. Du müsstest dich gedulden oder selber mal schauen was das sein kann.
                SpacerX
                #105
                @copystring Alles gut!
                Nachdem ich 24h Lebenszeit in das Unternehmen Sniffing verschwendet habe, habe ich der PC-Kiste erst mal den Strom abgedreht. Zur Frustbewältigung ein Eis gegessen und 3 Kippen verschlungen.
                Nu hat es mir dann doch keine Ruhe gelassen. Also PC wieder an. ioBroker-Dienst + mitmproxy gestartet, Wireguard auf iPone angeschalten und Roborock App gestartet.
                Jetzt passt auf was kommt!
                Es Läuft. Decoded sniffing in der Log-Ausgabe.
                Hier schon mal rausgepickt was ich herausfinden will.
                2023-08-05 22:12:19.101  - roborock.0 (8400) Decoded sniffing message: {"dps":{"101":"{"id":277019,"method":"get_wash_towel_mode","params":{}}"},"t":1691266339}
                2023-08-05 22:12:19.181  - roborock.0 (8400) dps debug: {"id":277019,"result":{"wash_mode":1}}
                2023-08-05 22:12:19.204  - roborock.0 (8400) Decoded sniffing message: {"dps":{"101":"{"id":277020,"method":"get_smart_wash_params","params":{}}"},"t":1691266339}
                2023-08-05 22:12:19.296  - roborock.0 (8400) dps debug: {"id":277020,"result":{"smart_wash":0,"wash_interval":1200}}
                Das sind Teile von den Einstellungen der Dockingstation.
                Ich bin erst mal Happy.
                Falls jemand für das Sniffing mit Roborock App auf iPhone Unterstützung braucht kann ich gern mit meinen Notizen von diesem Amoklauf behilflich sein.
                Gut Nächtle.
                • jahnbesJ jahnbes
                  @spacerx
                  Danke! Ich werde mich am Wochenende darum kümmern und das Wiki ergänzen.
                  Kannst Du mir / uns das "Kleines Blockly zum loggen der Datenpunkte vom Sauger geschrieben." zukommen lassen?
                  Gruß Bert.
                  SpacerX
                  #106
                  @jahnbes Bevor ich es vergessen!
                  In der Doku zu den Objekten vom Robi Hast du eingetragen:
                  wash_ready wird nach meiner Beobachtung und den Logs von oben immer dann auf TRUE wenn der Robi zum Mopp Waschen richtig herum an der Station angedockt hat. Unter dem Wasserbefüllstutzen am Roboter ist ein Mikroschalter der durch eine kleine Nase unter dem Wasserstutzen der Station betätigt wird.
                  wash_ready wird FALSE wenn der Robi nach dem Mopp Waschen wieder abdockt und der Robi dreht rum um in Ladeposition wieder anzudocken.
                  jahnbesJ 1 Antwort Letzte Antwort
                  • jahnbesJ jahnbes
                    @matt77che
                    Danke, so habe ich es jetzt auch im Wiki eingetragen.
                    Gruß Bert.
                    tritanium
                    #107
                    @jahnbes sagte in Neuer Adapter für Roborock-Staubsauger:
                    @matt77che
                    Wenn ihr schon mal dabei seid, das Wiki zu vervollständigen :-D wir haben einen Q7 Max+
                    Mehrfache Tests haben ergeben:
                    clean_type:
                    1 = Gesamt Reinigung (alle Räume)
                    2 = Zonenreinigung (ausgewählt über die App z.b.)
                    3 = Raumreinigung
                    start_type:
                    1 = manuell (Knopfdruck am Roboter)
                    2 = via App (aus der App gestartet oder per ioBroker.Adapter)
                    3 = Planstart (durch Zeitplanung in der App)
                    complete Type
                    1 = normal beendet
                    <> 1 = abgebrochen
                    Andere Werte habe ich auch noch, die schicke ich nachher noch nach :-)
                    Gruß Micha
                    • S SpacerX
                      jahnbesJ Offline
                      jahnbesJ Offline
                      jahnbes
                      #108
                      @spacerx Danke, ist geändert!
                      • T tritanium
                        @matt77che
                        clean_type:
                        3 = Raumreinigung
                        start_type:
                        complete Type
                        1 = normal beendet
                        <> 1 = abgebrochen
                        Gruß Micha
                        jahnbesJ Offline
                        jahnbesJ Offline
                        jahnbes
                        #109
                        @tritanium
                        Danke, MIcha, ich habe das Wiki ergänzt. Und warte auf Weiteres!
                        Ein schönes Wochenende noch, Gruß Bert.
                        • jahnbesJ jahnbes
                          SpacerX
                          schrieb am zuletzt editiert von SpacerX
                          #110
                          @jahnbes Sorry das ich nerve.
                          Es ist genau umgekehrt!
                          0 = Nicht bereit zum Mopp Waschen
                          1 = Bereit zum Mopp Waschen und ggf. Wasser nachtanken
                          Sagt aus das der Saugroboter richtig herum in der Station steht und bereit ist um den Mopp zu Waschen oder Wasser nachzutanken.
                          Wenn der Robi beim Andocken zum Waschen den Befüllstutzen nicht treffen würde bleibt wash_ready auf 0 (FALSE)
                          • S SpacerX
                            jahnbesJ Offline
                            jahnbesJ Offline
                            jahnbes
                            schrieb am zuletzt editiert von jahnbes
                            #111
                            @spacerx
                            Oh je, ich habe 0 und 1 und die Zuordnung von true und false dazu verwechselt. Mea culpa.
                            Gruß Bert.
                            • jahnbesJ jahnbes
                              @spacerx
                              Gruß Bert.
                              tritanium
                              schrieb am zuletzt editiert von tritanium
                              #112
                              @jahnbes
                              So, diesmal habe ich mich mit dem Aufbau der JSON befasst.
                              Datenpunkt ...CleaningInfo.JSON:
                              begin + end:-------> Im TS Format
                              duration:-----------> in Sekunden
                              area:----------------> Gereingte Fläche (durch 1000000, für m²)
                              error:---------------> 0 = ohne Fehler beendet
                              complete:----------> 0 = abgebrochene Reinigung, 1 = Reingung beendet
                              start_type:---------> siehe Wiki
                              clean_type:--------> siehe Wiki
                              dust_collection_Status: -----> 0 = Staub eingesammelt (nur), 1 = gesaugt + gewischt
                              map_flag:-----------> Karten ID (bei mir immer 0, da nur eine Karte verwendet wird)
                              Den DP "finish_reason" gibt es übrigens mit folgenden Ergebnissen:
                              21
                              24
                              52
                              54
                              56
                              Die bin ich aber noch am "testen" :-)
                              Habe die JSON bei mir in der VIS drin und dementspreechend formatiert:
                              Melde mich wieder wenn ich mehr habe, bis dahin lg MIcha
                              • T tritanium
                                @jahnbes
                                21
                                24
                                52
                                54
                                56
                                jahnbesJ Offline
                                jahnbesJ Offline
                                jahnbes
                                #113
                                @tritanium
                                Danke!
                                • jahnbesJ Offline
                                  jahnbesJ Offline
                                  jahnbes
                                  #114
                                  Im Wiki ist die Unterteilung in "Roboter" und "Dock" aufgelöst. Sie war nicht mehr durchzuhalten. Jetzt ist alles wie im ioBroker angeordnet, also alphabetisch anhand des Objektnamens
                                  Wenn ein Objekt nur für eine Station relevant ist, wird das gleich nach seinem Namen durch das Wort "Dock" angezeigt.
                                  • Daniel SybergD Offline
                                    Daniel Syberg
                                    #115
                                    ich habe gerade den Adapter installiert, die Instanz lässt sich auch öffnen.
                                    Allerdings bekomme ich keine Verbindung, es kommen immer wieder Fehlermeldungen und es erfolgt alle paar Sekunden ein Neutstart.
                                    Anbei die Meldungen im Log:
                                    Kann mir vielleicht jemand helfen?
                                    • Daniel SybergD Daniel Syberg
                                      #116
                                      @daniel-syberg
                                      Bitte nicht als Screenshot.
                                      Und nodejs15 ist vollkommen falsch.
                                      Ungerade Versionen sind für die Entwicklung vorgesehen, produktiv setzt man gerade Versionen von nodejs ein. Installier da die aktuelle Empfehlung v18.
                                      N 1 Antwort Letzte Antwort
                                        @daniel-syberg
                                        N Offline
                                        N Offline
                                        nu_81
                                        #117
                                        ist es auch möglich die Reinigung mehrerer Räume auf einmal anzustoßen?
                                        • N nu_81
                                          andibr
                                          #118
                                          Hallo zusammen
                                          Kleine Frage: "wurde da irgendwo irgendwas verändert?" Seit heute (Samstag 12.08.2023:12.34) macht mein Iob einen auf Terror mit dem Roborock-Adapter. Ich habe ihn jetzt mal deaktiviert.
                                          host.iobroker
                                          		2023-08-12 17:24:07.645	info	Do not restart adapter system.adapter.roborock.0 because disabled or deleted
                                          host.iobroker
                                          		2023-08-12 17:24:07.645	error	instance system.adapter.roborock.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                                          roborock.0
                                          	5273	2023-08-12 17:24:07.047	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                                          roborock.0
                                          	5273	2023-08-12 17:24:06.999	error	adapter disabled
                                          host.iobroker
                                          		2023-08-12 17:23:49.676	info	"system.adapter.roborock.0" disabled
                                          mqtt.1
                                          		2023-08-12 17:23:34.190	info	Restart adapter system.adapter.roborock.0 because enabled
                                          host.iobroker
                                          		2023-08-12 17:23:34.190	info	instance system.adapter.roborock.0 terminated with code NaN ()
                                          host.iobroker
                                          		2023-08-12 17:23:34.190	warn	instance system.adapter.roborock.0 terminated due to SIGABRT
                                          host.iobroker
                                          		2023-08-12 17:23:34.190	error	Caught by controller[7]: 8: 0x17036b9 [io.roborock.0]
                                          host.iobroker
                                          		2023-08-12 17:23:34.190	error	Caught by controller[6]: 7: 0xdc3def v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.roborock.0]
                                          host.iobroker
                                          		2023-08-12 17:23:34.190	error	Caught by controller[5]: 6: 0xdc28b0 [io.roborock.0]
                                          host.iobroker
                                          		2023-08-12 17:23:34.189	error	Caught by controller[4]: 5: 0x7eff119f53d3 [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                                          host.iobroker
                                          		2023-08-12 17:23:34.189	error	Caught by controller[4]: 4: 0x7eff11a0347c Context2d::GetImageData(Nan::FunctionCallbackInfo<v8::Value> const&) [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                                          host.iobroker
                                          		2023-08-12 17:23:34.189	error	Caught by controller[4]: 3: 0xd644da v8::Utils::ReportApiFailure(char const*, char const*) [io.roborock.0]
                                          host.iobroker
                                          		2023-08-12 17:23:34.189	error	Caught by controller[3]: 2: 0xa94749 node::OOMErrorHandler(char const*, bool) [io.roborock.0]
                                          host.iobroker
                                          		2023-08-12 17:23:34.189	error	Caught by controller[2]: 1: 0xb83f50 node::Abort() [io.roborock.0]
                                          host.iobroker
                                          		2023-08-12 17:23:34.189	error	Caught by controller[1]: FATAL ERROR: v8::ToLocalChecked Empty MaybeLocal.
                                          host.iobroker
                                          		2023-08-12 17:23:34.188	error	Caught by controller[0]: Downloading AlexxIT/go2rtc@v1.6.2...
                                          roborock.0
                                          	5234	2023-08-12 17:23:11.328	info	MQTT initialized
                                          roborock.0
                                          	5234	2023-08-12 17:23:09.896	info	starting. Version 0.2.1 (non-npm: copystring/ioBroker.roborock#cea0cc4fa080d5a2041706a71b4190f153c773b4) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.17.1, js-controller: 4.0.24
                                          Das ganze wiederholt sich alle paar Minuten und füllt das Log. Ich muss auch gestehen, ich habe bis jetzt noch gar nichts mit den Daten gemacht, ausser in den Objekten angeschaut. Auch erst 1x die Map angeschaut und studiert wie ich das verwenden kann.
                                          Seit ca. 2 Wochen hat das ganze jetzt einfach sauber die Objekte gefüllt und keine Probleme verursacht.
                                          Ist das auch bei anderen so?
                                          Andi
