  4. Neuer Adapter für Roborock-Staubsauger
    6.3k
1.1k Beiträge 155 Kommentatoren 474.9k Aufrufe 138 Beobachtet
  • S SpacerX
    @copystring Nein im Cmd von mitmproxy.
    Der Start.
    mit Bash Script
    C:\Users\SpacerX\.local\pipx\venvs\mitmproxy\Scripts\mitmweb.exe --listen-port 9090 --web-port 9091  --set tls_version_client_min=TLS1_3 --mode wireguard -s C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py
    Pause
    [23:47:57.984] Loading script C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py
    [23:47:58.017] Initializing WireGuard server ...
    [23:47:58.017] WireGuard server listening for UDP connections on 0.0.0.0:9090 and [::]:9090 ...
    [23:47:58.017] WireGuard server successfully initialized.
    [23:47:58.017] ------------------------------------------------------------
    [Interface]
    PrivateKey =
    Address = 10.0.0.1/32
    DNS = 10.0.0.53
    [Peer]
    PublicKey =
    AllowedIPs = 0.0.0.0/0
    Endpoint = 10.0.0.3:9090
    [23:47:58.034] WireGuard server listening at *:9090.
    [23:47:58.034] Web server listening at http://127.0.0.1:9091/
    [23:48:08.804][10.0.0.1:57020] client connect
    [23:48:08.804][10.0.0.1:62599] client connect
    [23:48:08.804][10.0.0.1:61335] client connect
    [23:48:08.804][10.0.0.1:64527] client connect
    [23:48:08.804][10.0.0.1:49858] client connect
    [23:48:08.830][10.0.0.1:60201] client connect
    [23:48:08.864][10.0.0.1:64843] client connect
    [23:48:08.881][10.0.0.1:64843] server connect 17.248.209.64:443
    [23:48:09.695][10.0.0.1:64843] Client TLS handshake failed. Client and mitmproxy cannot agree on a TLS version to use. You may need to adjust mitmproxy's tls_version_client_min option.
    [23:48:09.695][10.0.0.1:64843] client disconnect
    dann fortlaufen.
    [23:49:21.680][10.0.0.1:52312] client disconnect
    [23:49:22.146][10.0.0.1:49597] client connect
    [23:49:22.284][10.0.0.1:63804] client connect
    [23:49:22.304][10.0.0.1:63804] server connect 216.58.212.174:443
    [23:49:22.323][10.0.0.1:63805] client connect
    [23:49:22.354][10.0.0.1:63805] server connect 17.248.209.64:443
    [23:49:22.361][10.0.0.1:63804] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for clients3.google.com, this may indicate that the client does not trust the proxy's certificate.
    [23:49:22.364][10.0.0.1:63804] client disconnect
    [23:49:22.365][10.0.0.1:63804] server disconnect 216.58.212.174:443
    [23:49:22.365][10.0.0.1:52816] client connect
    [23:49:22.384][10.0.0.1:63805] Client TLS handshake failed. Client and mitmproxy cannot agree on a TLS version to use. You may need to adjust mitmproxy's tls_version_client_min option.
    [23:49:22.387][10.0.0.1:63805] client disconnect
    [23:49:22.389][10.0.0.1:63805] server disconnect 17.248.209.64:443
    [23:49:22.519][10.0.0.1:63806] client connect
    [23:49:22.541][10.0.0.1:63806] server connect 216.58.212.174:443
    [23:49:22.603][10.0.0.1:63806] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for clients3.google.com, this may indicate that the client does not trust the proxy's certificate.
    [23:49:22.605][10.0.0.1:63806] client disconnect
    [23:49:22.605][10.0.0.1:63806] server disconnect 216.58.212.174:443
    [23:49:22.611][10.0.0.1:55374] client connect
    [23:49:22.738][10.0.0.1:63807] client connect
    [23:49:22.757][10.0.0.1:63807] server connect 216.58.212.174:443
    [23:49:22.821][10.0.0.1:63807] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for clients3.google.com, this may indicate that the client does not trust the proxy's certificate.
    [23:49:22.821][10.0.0.1:63807] client disconnect
    [23:49:22.821][10.0.0.1:63807] server disconnect 216.58.212.174:443
    [23:49:24.700][10.0.0.1:63808] client connect
    [23:49:24.728][10.0.0.1:63808] server connect 17.248.209.64:443
    [23:49:24.754][10.0.0.1:63808] Client TLS handshake failed. Client and mitmproxy cannot agree on a TLS version to use. You may need to adjust mitmproxy's tls_version_client_min option.
    [23:49:24.754][10.0.0.1:63808] client disconnect
    [23:49:24.754][10.0.0.1:63808] server disconnect 17.248.209.64:443
    [23:49:26.493][10.0.0.1:60191] Closing connection due to inactivity: Client(10.0.0.1:60191, state=open)
    copystringC Offline
    copystringC Offline
    copystring
    #92
    @spacerx warum hast du --set tls_version_client_min=TLS1_3 hinzugefügt?
    Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
    https://paypal.me/copystring
    • copystringC copystring
      SpacerX
      #93
      @copystring im log stand auch ohne diese Option
      Das war mein Versuch, nachdem ich nach dem Fehler im i-Net gegoggelt hatte und dies als Möglichkeit fand.
      Habe, von TLS1_1 über TLS1_2 bis SSL3 alles ausprobiert.
      DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
      copystringC 1 Antwort Letzte Antwort
      • S SpacerX
        copystringC Offline
        copystringC Offline
        copystring
        #94
        @spacerx welchen Browser nimmst du? Bei lief es mit Chrome
          SpacerX
          #95
          @copystring im Moment Edge. Der ist eigentlich Chrome basierend.
          • S SpacerX
            SpacerX
            #96
            Ich habe nun mal Chrome installiert. Das ändert leider Garnichts.
            Noch mal eine Ausgabe dazu.
            [11:01:04.438][10.0.0.1:54441] server connect 142.250.184.206:443
            [11:01:04.485][10.0.0.1:54441] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for clients3.google.com, this may indicate that the client does not trust the proxy's certificate.
            [11:01:04.485][10.0.0.1:54441] client disconnect
            [11:01:04.485][10.0.0.1:54441] server disconnect 142.250.184.206:443
            [11:01:04.500][10.0.0.1:49611] client connect
            [11:01:04.610][10.0.0.1:54442] client connect
            [11:01:04.625][10.0.0.1:54442] server connect 142.250.184.206:443
            [11:01:04.672][10.0.0.1:54442] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for clients3.google.com, this may indicate that the client does not trust the proxy's certificate.
            [11:01:04.672][10.0.0.1:54442] client disconnect
            [11:01:04.672][10.0.0.1:54442] server disconnect 142.250.184.206:443
            [11:01:07.218][10.0.0.1:54381] client connect
            [11:01:07.250][10.0.0.1:54381] server connect 52.29.91.104:8883
            [11:01:07.359][10.0.0.1:54381] client disconnect
            [11:01:07.359][10.0.0.1:54381] server disconnect 52.29.91.104:8883
            [11:01:09.109][10.0.0.1:54443] client connect
            [11:01:09.124][10.0.0.1:54444] client connect
            [11:01:09.140][10.0.0.1:54443] server connect 18.195.207.39:443
            [11:01:09.155][10.0.0.1:54444] server connect 52.29.136.229:443
            [11:01:09.218][10.0.0.1:54443] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for api-eu.roborock.com, this may indicate that the client does not trust the proxy's certificate.
            [11:01:09.218][10.0.0.1:54443] client disconnect
            [11:01:09.218][10.0.0.1:54443] server disconnect 18.195.207.39:443
            [11:01:09.218][10.0.0.1:54444] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for awsde0.fds.api.xiaomi.com, this may indicate that the client does not trust the proxy's certificate.
            Die Verbindung zum iPhone mit WireGuard scheint zu Funktionieren nur vom Proxy zu Roborock usw. klappt anscheinend nicht weil was mit dem Zertifikat nicht hin haut.
            Ehrlich gesagt ist so langsam meine Frustschwelle erreicht.
            <frust = on>
            Wer sich den ganzen Müll mit den Zertifikaten ausgedacht hat gehört geteert und gefedert.
            <frust = off>
            Vielleicht war mein Vorgehen bei der ganzen Installation auch falsch.
            • Python installiert
            • pip installiert [python -m pip install --user pipx]
            • Dann die Installationen zu mitmproxy
              • py -m pipx install mitmproxy --force
              • py -m pipx inject mitmproxy websocket
              • py -m pipx inject mitmproxy websocket-client
            Noch jemand eine Idee wie man das Prob gelöst bekommt?
            @copystring
            Geht der Installationskram auch anders. In der Wiki ist von Python als Voraussetzung nicht die Rede. Ich nehme mal an durch die Programmiererei hast du den Kram eh auf dem Rechner. Deshalb klappts bei dir ohne Prob. Ich hab's nur nicht so mit den Zertifikaten und hab immer versucht dem aus dem Weg zu gehen.
            • S SpacerX
              Ich möchte meine heutige Ausbeute teilen.
              Es geht um Funktionen Rund um die Station vom S7 MaxV Ultra.
              Meine Voraussetzungen:
              • Kleines Blockly zum loggen der Datenpunkte vom Sauger geschrieben.
              • Adapter vorrübergehend die Aktualisierung 5s gestellt.
              • Mit Taschenlampe vor die Station gehockt und aufgeschrieben was passiert.
              • Robi steht in der Station zum laden, dann Mopp Waschen gestartet.
              Meine Aufzeichnungen dazu:
              Log Mopp Waschen mit Roboter Wassertank leer.
              2023-08-03 18:29:08.482 # Robi -> State [deviceStatus.state] = 8 -> 26 (Fahre Mopp waschen)
              2023-08-03 18:29:08.487 # Robi -> Is returning [deviceStatus.in_returning] = 0 -> 1
              2023-08-03 18:29:08.488 # Robi -> In Fresh State [deviceStatus.in_fresh_state] = 1 -> 0
              2023-08-03 18:29:08.489 # Robi -> Back Type [deviceStatus.back_type] = -1 -> 1
              2023-08-03 18:29:48.716 # Robi -> State [deviceStatus.state] = 26 -> 23 (Mopp waschen)
              2023-08-03 18:29:48.719 # Robi -> Is returning [deviceStatus.in_returning] = 1 -> 0
              2023-08-03 18:29:48.721 # Robi -> Back Type [deviceStatus.back_type] = 1 -> -1
              2023-08-03 18:29:48.721 # Robi -> Wash Phase [deviceStatus.wash_phase] = 0 -> 11
              2023-08-03 18:29:48.722 # Robi -> Wash Ready [deviceStatus.wash_ready] = 0 -> 1
              2023-08-03 18:29:49.365 # Robi -> Water Filter [consumables.strainer_work_times] = 4 -> 5
              2023-08-03 18:29:49.366 # Robi -> High-speed maintenance brush [consumables.cleaning_brush_work_times] = 4 -> 5
              2023-08-03 18:31:03.661 # Robi -> Wash Phase [deviceStatus.wash_phase] = 11 -> 12
              2023-08-03 18:31:08.651 # Robi -> Wash Phase [deviceStatus.wash_phase] = 12 -> 10
              2023-08-03 18:31:38.662 # Robi -> Wash Phase [deviceStatus.wash_phase] = 10 -> 13
              2023-08-03 18:32:53.675 # Robi -> Wash Phase [deviceStatus.wash_phase] = 13 -> 12
              2023-08-03 18:32:58.637 # Robi -> Wash Phase [deviceStatus.wash_phase] = 12 -> 14
              2023-08-03 18:33:08.634 # Robi -> State [deviceStatus.state] = 23 -> 6 (Rückkehr zur Station)
              2023-08-03 18:33:08.677 # Robi -> Is returning [deviceStatus.in_returning] = 0 -> 1
              2023-08-03 18:33:08.679 # Robi -> Back Type [deviceStatus.back_type] = -1 -> 0
              2023-08-03 18:33:08.680 # Robi -> Wash Phase [deviceStatus.wash_phase] = 14 -> 0
              2023-08-03 18:33:13.670 # Robi -> Wash Ready [deviceStatus.wash_ready] = 1 -> 0
              2023-08-03 18:33:31.225 # Robi -> Times Dust Collected [cleaningInfo.dust_collection_count] = 77 -> 78 "Wahrscheinlicht Staubbehälterantleerungen"
              2023-08-03 18:33:33.671 # Robi -> State [deviceStatus.state] = 6 -> 8 (Akku laden)
              2023-08-03 18:33:33.674 # Robi -> Is returning [deviceStatus.in_returning] = 1 -> 0
              2023-08-03 18:33:33.674 # Robi -> In Fresh State [deviceStatus.in_fresh_state] = 0 -> 1
              2023-08-03 18:33:33.675 # Robi -> Back Type [deviceStatus.back_type] = 0 -> -1
              Mopp Waschen mit Roboter Wassertank 100% voll.
              2023-08-03 18:40:38.661 # Robi -> State [deviceStatus.state] = 8 -> 26 (Fahre Mopp waschen)
              2023-08-03 18:40:38.706 # Robi -> Is returning [deviceStatus.in_returning] = 0 -> 1
              2023-08-03 18:40:38.706 # Robi -> In Fresh State [deviceStatus.in_fresh_state] = 1 -> 0
              2023-08-03 18:40:38.708 # Robi -> Back Type [deviceStatus.back_type] = -1 -> 1
              2023-08-03 18:41:18.782 # Robi -> State [deviceStatus.state] = 26 -> 23 (Mopp waschen)
              2023-08-03 18:41:18.787 # Robi -> Is returning [deviceStatus.in_returning] = 1 -> 0
              2023-08-03 18:41:18.793 # Robi -> Back Type [deviceStatus.back_type] = 1 -> -1
              2023-08-03 18:41:18.805 # Robi -> Wash Phase [deviceStatus.wash_phase] = 0 -> 11
              2023-08-03 18:41:18.806 # Robi -> Wash Ready [deviceStatus.wash_ready] = 0 -> 1
              2023-08-03 18:41:19.536 # Robi -> Water Filter [consumables.strainer_work_times] = 5 -> 6
              2023-08-03 18:41:19.537 # Robi -> High-speed maintenance brush [consumables.cleaning_brush_work_times] = 5 -> 6
              2023-08-03 18:42:58.756 # Robi -> Wash Phase [deviceStatus.wash_phase] = 11 -> 12
              2023-08-03 18:43:03.720 # Robi -> Wash Phase [deviceStatus.wash_phase] = 12 -> 13
              2023-08-03 18:44:38.786 # Robi -> Wash Phase [deviceStatus.wash_phase] = 13 -> 12
              2023-08-03 18:44:43.771 # Robi -> Wash Phase [deviceStatus.wash_phase] = 12 -> 14
              2023-08-03 18:44:48.739 # Robi -> State [deviceStatus.state] = 23 -> 6 (Rückkehr zur Station)
              2023-08-03 18:44:48.741 # Robi -> Is returning [deviceStatus.in_returning] = 0 -> 1
              2023-08-03 18:44:48.781 # Robi -> Back Type [deviceStatus.back_type] = -1 -> 0
              2023-08-03 18:44:48.782 # Robi -> Wash Phase [deviceStatus.wash_phase] = 14 -> 0
              2023-08-03 18:44:58.779 # Robi -> Wash Ready [deviceStatus.wash_ready] = 1 -> 0
              2023-08-03 18:45:18.992 # Robi -> State [deviceStatus.state] = 6 -> 8 (Akku laden)
              2023-08-03 18:45:18.994 # Robi -> Is returning [deviceStatus.in_returning] = 1 -> 0
              2023-08-03 18:45:18.995 # Robi -> In Fresh State [deviceStatus.in_fresh_state] = 0 -> 1
              2023-08-03 18:45:18.996 # Robi -> Back Type [deviceStatus.back_type] = 0 -> -1
              Mopp Waschen mit Roboter Wassertank 50% voll.
              2023-08-03 12:51:35.610 # Robi -> State [deviceStatus.state] = 8 -> 26 (Fahre Mopp waschen)
              2023-08-03 12:51:35.653 # Robi -> Is returning [deviceStatus.in_returning] = 0 -> 1
              2023-08-03 12:51:35.654 # Robi -> In Fresh State [deviceStatus.in_fresh_state] = 1 -> 0
              2023-08-03 12:51:35.655 # Robi -> Back Type [deviceStatus.back_type] = -1 -> 1
              2023-08-03 12:52:05.895 # Robi -> State [deviceStatus.state] = 26 -> 23 (Mopp waschen)
              2023-08-03 12:52:05.899 # Robi -> Is returning [deviceStatus.in_returning] = 1 -> 0
              2023-08-03 12:52:05.901 # Robi -> Back Type [deviceStatus.back_type] = 1 -> -1
              2023-08-03 12:52:05.902 # Robi -> Wash Ready [deviceStatus.wash_ready] = 0 -> 1
              2023-08-03 12:52:06.393 # Robi -> Water Filter [consumables.strainer_work_times] = 3 -> 4
              2023-08-03 12:52:06.394 # Robi -> High-speed maintenance brush [consumables.cleaning_brush_work_times] = 3 -> 4
              2023-08-03 12:52:10.868 # Robi -> Wash Phase [deviceStatus.wash_phase] = 0 -> 11	"11 = Mopp Waschen mit Bürste und Wasser"
              2023-08-03 12:53:25.678 # Robi -> Wash Phase [deviceStatus.wash_phase] = 11 -> 12	"12 = Wasserauffang unter Bürste leeren"
              2023-08-03 12:53:30.667 # Robi -> Wash Phase [deviceStatus.wash_phase] = 12 -> 10	"10 = scheint das Befüllen vom Wassertank zu sein"
              2023-08-03 12:53:40.630 # Robi -> Wash Phase [deviceStatus.wash_phase] = 10 -> 13	"13 = Mopp abbürsten ohne Wasser (Auswringen???)"
              2023-08-03 12:54:55.687 # Robi -> Wash Phase [deviceStatus.wash_phase] = 13 -> 12	"12 = Wasserauffang unter Bürste leeren"
              2023-08-03 12:55:00.703 # Robi -> Wash Phase [deviceStatus.wash_phase] = 12 -> 14	"14 = Bürste in Parkposition fahren"
              2023-08-03 12:55:05.641 # Robi -> State [deviceStatus.state] = 23 -> 6 (Rückkehr zur Station)
              2023-08-03 12:55:05.685 # Robi -> Is returning [deviceStatus.in_returning] = 0 -> 1
              2023-08-03 12:55:05.687 # Robi -> Back Type [deviceStatus.back_type] = -1 -> 0
              2023-08-03 12:55:05.688 # Robi -> Wash Phase [deviceStatus.wash_phase] = 14 -> 0
              2023-08-03 12:55:10.693 # Robi -> Wash Ready [deviceStatus.wash_ready] = 1 -> 0
              2023-08-03 12:55:30.906 # Robi -> State [deviceStatus.state] = 6 -> 8 (Akku laden)
              2023-08-03 12:55:30.910 # Robi -> Is returning [deviceStatus.in_returning] = 1 -> 0
              2023-08-03 12:55:30.915 # Robi -> In Fresh State [deviceStatus.in_fresh_state] = 0 -> 1
              2023-08-03 12:55:30.916 # Robi -> Back Type [deviceStatus.back_type] = 0 -> -1
              Dazu meine Erkenntnisse.
              10 = Befüllen Roboter Wassertank
              11 = Mopp Waschen mit Wasser und Reinigungsbürste
              12 = Wasserauffang der Station unter Reinigungsbürste leeren
              13 = Mopp Waschen nur Reinigungsbürste (Auswringen)
              14 = Reinigungsbürste in Parkposition fahren
              Das Befüllen des Roboter-Wassertanks wird immer bei Mopp-Waschen ausgeführt wenn der Tank nicht voll ist.
              Dazu gleich noch für Später den Schmutzwasserbehälter vor jedem Start leer gemacht und vor dem Mopp-Waschen Befehl den Moppwaschmodus umgestellt um den Wasserverbrauch beim Mopp-Waschen zu ermitteln.
              • Moppwäsche-Modus = Wassersparend -> Schmutzwasserbehälter = ca.130ml
              • Moppwäsche-Modus = Mittel -> Schmutzwasserbehälter = ca.200ml
              • Moppwäsche-Modus = Intensiv -> Schmutzwasserbehälter = ca.290ml
              Für den Moppwaschmodus den man in der App wählen kann scheint es noch kein equivalenten Datenpunkt im Adapter zu geben.
              Robi steht in Station zum laden, dann Staubbehälter entleeren gestartet.
              2023-08-03 19:00:48.710 # Robi -> State [deviceStatus.state] = 8 -> 22 (Staubbehälter entleeren)
              2023-08-03 19:00:48.713 # Robi -> In Fresh State [deviceStatus.in_fresh_state] = 1 -> 0
              2023-08-03 19:01:18.709 # Robi -> State [deviceStatus.state] = 22 -> 8 (Akku laden)
              2023-08-03 19:01:18.712 # Robi -> In Fresh State [deviceStatus.in_fresh_state] = 0 -> 1
              Der Datenpunkt deviceStatus.back_type scheint zu definieren wie rum der Roboter an die Station heran gefahren ist.
              -1 = NULL (wird immer auf diesen Wert zurück gesetzt.)
              0 = Vorwärts -> Laden und Staubbehälter entleeren.
              1 = Rückwärts -> Mopp Waschen
              Zur Bedeutung von deviceStatus.in_fresh_state hab ich eine Idee die ich aber erst mit Test bestätigen muss.
              jahnbesJ Offline
              jahnbesJ Offline
              jahnbes
              #97
              @spacerx
              Hallo, ich habe das Wiki ergänzt, vielen Dank.
              Und Dein kleines Skript ist Klasse, ich habe bisher in der langen Liste immer geschaut, ob sich ein Datenpunkt ändert und wenn ja, wie.
              Viele Grüße, Bert.
              • jahnbesJ jahnbes
                @spacerx
                Viele Grüße, Bert.
                SpacerX
                #98
                @jahnbes sagte in Neuer Adapter für Roborock-Staubsauger:
                Das war mein Ansinnen. Weil man die Objekte ja nicht mit einmal auf den Bildschirm bekommt ist es unmöglich das vernünftig nach zu vollziehen.
                • S SpacerX
                  <frust = on>
                  <frust = off>
                  @copystring
                  copystringC Offline
                  copystringC Offline
                  copystring
                  #99
                  @spacerx said in Neuer Adapter für Roborock-Staubsauger:
                  Nein. mitmproxy braucht zwingend Python.
                  Hast du das Zertifikat von mitmproxy denn auf dem iPhone als root Zertifikat hinzugefügt?
                    SpacerX
                    #100
                    @copystring ja habe ich.
                    • S SpacerX
                      copystringC Offline
                      copystringC Offline
                      copystring
                      schrieb am zuletzt editiert von copystring
                      #101
                      @spacerx mit iPhone kenne ich mich nur wenig aus. Sicher, dass es als root Zertifikat hinzugefügt ist? Alle anderen Zertifikatstypen wären falsch.
                        SpacerX
                        #102
                        @copystring das war das Stichwort. Es reichte nicht das Profil zu Installieren. Da muss man beim iPhone doch tiefer in die Abgründe der Einstellungen.
                        Jedenfalls zappelt jetzt was.
                        • S SpacerX
                          SpacerX
                          #103
                          @spacerx
                          Ab und an tauchen folgende Meldungen auf.
                          C:\Users\SpacerX\.local\pipx\venvs\mitmproxy\Scripts\python.exe
                          [21:15:18.262] Packet type CONNACK is not supported yet!
                          [21:15:18.262] Addon error: unpack requires a buffer of 2 bytes
                          Traceback (most recent call last):
                            File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 286, in tcp_message
                              mqtt_packet = MQTTControlPacket(message.content)
                            File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 83, in __init__
                              self._parse_publish_variable_headers()
                            File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 136, in _parse_publish_variable_headers
                              field_length, field_content_bytes = self._parse_length_prefixed_bytes(offset)
                            File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 127, in _parse_length_prefixed_bytes
                              field_length = struct.unpack("!H", field_length_bytes)[0]
                          struct.error: unpack requires a buffer of 2 bytes
                          [21:15:18.309] [PUBLISH]
                          Die Sniffing Message taucht bei mir leider auch nicht im Log auf.
                          Jetzt weis ich noch nicht genau nach was ich schauen soll.
                          • S SpacerX
                            @spacerx
                            copystringC Offline
                            copystringC Offline
                            copystring
                            #104
                            @spacerx okay. Kann ich mir aktuell nicht angucken. Bin im Urlaub. Du müsstest dich gedulden oder selber mal schauen was das sein kann.
                              SpacerX
                              #105
                              @copystring Alles gut!
                              Nachdem ich 24h Lebenszeit in das Unternehmen Sniffing verschwendet habe, habe ich der PC-Kiste erst mal den Strom abgedreht. Zur Frustbewältigung ein Eis gegessen und 3 Kippen verschlungen.
                              Nu hat es mir dann doch keine Ruhe gelassen. Also PC wieder an. ioBroker-Dienst + mitmproxy gestartet, Wireguard auf iPone angeschalten und Roborock App gestartet.
                              Jetzt passt auf was kommt!
                              Es Läuft. Decoded sniffing in der Log-Ausgabe.
                              Hier schon mal rausgepickt was ich herausfinden will.
                              2023-08-05 22:12:19.101  - roborock.0 (8400) Decoded sniffing message: {"dps":{"101":"{"id":277019,"method":"get_wash_towel_mode","params":{}}"},"t":1691266339}
                              2023-08-05 22:12:19.181  - roborock.0 (8400) dps debug: {"id":277019,"result":{"wash_mode":1}}
                              2023-08-05 22:12:19.204  - roborock.0 (8400) Decoded sniffing message: {"dps":{"101":"{"id":277020,"method":"get_smart_wash_params","params":{}}"},"t":1691266339}
                              2023-08-05 22:12:19.296  - roborock.0 (8400) dps debug: {"id":277020,"result":{"smart_wash":0,"wash_interval":1200}}
                              Das sind Teile von den Einstellungen der Dockingstation.
                              Ich bin erst mal Happy.
                              Falls jemand für das Sniffing mit Roborock App auf iPhone Unterstützung braucht kann ich gern mit meinen Notizen von diesem Amoklauf behilflich sein.
                              Gut Nächtle.
                              • jahnbesJ jahnbes
                                @spacerx
                                Danke! Ich werde mich am Wochenende darum kümmern und das Wiki ergänzen.
                                Kannst Du mir / uns das "Kleines Blockly zum loggen der Datenpunkte vom Sauger geschrieben." zukommen lassen?
                                Gruß Bert.
                                SpacerX
                                #106
                                @jahnbes Bevor ich es vergessen!
                                In der Doku zu den Objekten vom Robi Hast du eingetragen:
                                wash_ready wird nach meiner Beobachtung und den Logs von oben immer dann auf TRUE wenn der Robi zum Mopp Waschen richtig herum an der Station angedockt hat. Unter dem Wasserbefüllstutzen am Roboter ist ein Mikroschalter der durch eine kleine Nase unter dem Wasserstutzen der Station betätigt wird.
                                wash_ready wird FALSE wenn der Robi nach dem Mopp Waschen wieder abdockt und der Robi dreht rum um in Ladeposition wieder anzudocken.
                                jahnbesJ 1 Antwort Letzte Antwort
                                • jahnbesJ jahnbes
                                  @matt77che
                                  Danke, so habe ich es jetzt auch im Wiki eingetragen.
                                  Gruß Bert.
                                  tritanium
                                  #107
                                  @matt77che
                                  Wenn ihr schon mal dabei seid, das Wiki zu vervollständigen :-D wir haben einen Q7 Max+
                                  Mehrfache Tests haben ergeben:
                                  clean_type:
                                  1 = Gesamt Reinigung (alle Räume)
                                  2 = Zonenreinigung (ausgewählt über die App z.b.)
                                  3 = Raumreinigung
                                  start_type:
                                  1 = manuell (Knopfdruck am Roboter)
                                  2 = via App (aus der App gestartet oder per ioBroker.Adapter)
                                  3 = Planstart (durch Zeitplanung in der App)
                                  complete Type
                                  1 = normal beendet
                                  <> 1 = abgebrochen
                                  Andere Werte habe ich auch noch, die schicke ich nachher noch nach :-)
                                  Gruß Micha
                                  • S SpacerX
                                    jahnbesJ Offline
                                    jahnbesJ Offline
                                    jahnbes
                                    #108
                                    @spacerx Danke, ist geändert!
                                    • T tritanium
                                      @matt77che
                                      clean_type:
                                      3 = Raumreinigung
                                      start_type:
                                      complete Type
                                      1 = normal beendet
                                      <> 1 = abgebrochen
                                      Gruß Micha
                                      jahnbesJ Offline
                                      jahnbesJ Offline
                                      jahnbes
                                      #109
                                      @tritanium
                                      Danke, MIcha, ich habe das Wiki ergänzt. Und warte auf Weiteres!
                                      Ein schönes Wochenende noch, Gruß Bert.
                                      • jahnbesJ jahnbes
                                        SpacerX
                                        schrieb am zuletzt editiert von SpacerX
                                        #110
                                        @jahnbes Sorry das ich nerve.
                                        Es ist genau umgekehrt!
                                        0 = Nicht bereit zum Mopp Waschen
                                        1 = Bereit zum Mopp Waschen und ggf. Wasser nachtanken
                                        Sagt aus das der Saugroboter richtig herum in der Station steht und bereit ist um den Mopp zu Waschen oder Wasser nachzutanken.
                                        Wenn der Robi beim Andocken zum Waschen den Befüllstutzen nicht treffen würde bleibt wash_ready auf 0 (FALSE)
                                        • S SpacerX
                                          jahnbesJ Offline
                                          jahnbesJ Offline
                                          jahnbes
                                          schrieb am zuletzt editiert von jahnbes
                                          #111
                                          @spacerx
                                          Oh je, ich habe 0 und 1 und die Zuordnung von true und false dazu verwechselt. Mea culpa.
                                          Gruß Bert.
