  4. backitup Fehlermeldung
    6.7k
39 Beiträge 4 Kommentatoren 6.2k Aufrufe 4 Beobachtet
  • M maximinus
    Ich greife das Thema nocheinmal auf. Nach Befolgung deiner Hinweise zeigt die Telegram Nachricht über das nächtliche Backup immer noch die selben Warnungen, obwohl die Backups alle auber gespeichert werden. Im Zusammenhanfg mit einer Aktualisierung des am selben Raspberry laufenden evcc, bekomme ich nach sudo apt update diese Warnungen:
    pi@raspberrypi:~ $ Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
    W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://repos.influx        data.com/debian bullseye InRelease: The following signatures couldn't be verifie        d because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://packages.gra        fana.com/oss/deb stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease        The following signatures couldn't be verified because the public key is not avai        lable: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease
    Nach Studium dieses Links scheint mir deren Behebeung als Linux Neuling zu kompliziert (gefährlich)
    https://itsfoss.com/apt-key-deprecated/
    sudo apt keylist bringt diese Ausgabe
    pi@raspberrypi:~ $ sudo apt-key list
    /etc/apt/trusted.gpg
    pub   rsa2048 2012-04-01 [SC]
          A0DA 38D0 D76E 8B5D 6388  7281 9165 938D 90FD DD2E
    uid           [ unknown] Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>
    sub   rsa2048 2012-04-01 [E]
    pub   rsa4096 2015-09-28 [SC]
          05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
    uid           [ unknown] InfluxDB Packaging Service <support@influxdb.com>
    sub   rsa4096 2015-09-28 [E]
    /etc/apt/trusted.gpg.d/raspberrypi-archive-stable.gpg
    pub   rsa2048 2012-06-17 [SC]
          CF8A 1AF5 02A2 AA2D 763B  AE7E 82B1 2992 7FA3 303E
    uid           [ unknown] Raspberry Pi Archive Signing Key
    sub   rsa2048 2012-06-17 [E]
    Gibt es eine einfachere Möglichkeit diese Warnungen zu beseitigen oder soll man das so lassen?
    Vielleicht hat das auch etwas mit den nicht endenden Fehlermeldungen des backitup adapters zu tun.
    LG Gerhard
    @maximinus
    https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
      @maximinus
      maximinus
      Danke habe ich alles gemacht. da kommt aber jetzt das:
      pi@raspberrypi:~ $ sudo apt update
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://apt.grafana.com stable InRelease
      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5,127 B]
      Ign:6 https://repos.influxdata.com/raspbian bullseye InRelease
      Err:7 https://repos.influxdata.com/raspbian bullseye Release
        404  Not Found [IP: 18.66.26.28 443]
      Reading package lists... Done
      E: The repository 'https://repos.influxdata.com/raspbian bullseye Release' does not have a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      pi@raspberrypi:~ $
      Hast Du dafür auch eine Lösung?
      RasPi 4 4GB bookworm
      nodejs v20.19.4
      npm 10.8.2
      Objects type: jsonl
      States type: redis
      js-controller: 7.0.6
      admin: 7.6.17
      javascript: 8.9.2
      • M maximinus
        pi@raspberrypi:~ $
        @maximinus
        Ähnliche Übung für das influx-Repository.
        Steht in dem Thread etwas später drin.
          @maximinus
          maximinus
          schrieb am zuletzt editiert von maximinus
          Ich habe alles gelesen aber leider kapier ichs nicht
          mach ich das:
          sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
          kommt:
          pi@raspberrypi:~ $ sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
          OK
          pi@raspberrypi:~ $
          rm /etc/apt/sources.list.d/influxdata.list
          da kommt das:
          pi@raspberrypi:~ $ rm /etc/apt/sources.list.d/influxdata.list
          rm: cannot remove '/etc/apt/sources.list.d/influxdata.list': No such file or directory
          pi@raspberrypi:~ $
          dann:
          wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
          export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
          echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
          File '/usr/share/keyrings/influxdb.gpg' exists. Overwrite? (y/N) y
          da kommt nichts und dann immer noch der gleiche Fehler:
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
          Hit:4 https://apt.grafana.com stable InRelease
          Ign:5 https://repos.influxdata.com/raspbian bullseye InRelease
          Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5,127 B]
          pi@raspberrypi:~ $
          dann:
          pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
          pi@raspberrypi:~ $ gpg --with-fingerprint  --show-keys ./inluxdata-archive_compat.key
          gpg: directory '/home/pi/.gnupg' created
          gpg: keybox '/home/pi/.gnupg/pubring.kbx' created
          gpg: can't open './inluxdata-archive_compat.key': No such file or directory
          pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/influx*
          deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/raspbian bullseye stable
          pi@raspberrypi:~ $ cat /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg
          cat: /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg: No such file or directory
          pi@raspberrypi:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
          pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
          uid                      InfluxData Package Signing Key <support@influxdata.com>
          Ich denke das sieht nicht schlecht aus aber nach neu booten kommt nach sudo apt update die gleiche Meldung wie bisher. Irgend etwas muss ich übersehen haben.
          Eben merke ich da ist ein Schreibfehler "inlux" satt "influx". Aber auch bei richtiger Schreibweise bleibt der Fehler
          LG Gerhard
          nodejs v20.19.4
          npm 10.8.2
          Objects type: jsonl
          States type: redis
          admin: 7.6.17
          javascript: 8.9.2
          • M maximinus
            mach ich das:
            kommt:
            OK
            pi@raspberrypi:~ $
            da kommt das:
            pi@raspberrypi:~ $
            dann:
            pi@raspberrypi:~ $
            dann:
            LG Gerhard
            @maximinus
            ls -lah /etc/apt/sources.list.d/
            apt-key list | grep -i influx
            sagt?
              @maximinus
              sagt?
              maximinus
              pi@raspberrypi:~ $ ls -lah /etc/apt/sources.list.d/
              total 28K
              drwxr-xr-x 2 root root 4.0K Jun 20 13:25 .
              drwxr-xr-x 8 root root 4.0K Jul 23 11:43 ..
              -rw-r--r-- 1 root root  418 Jun 20 13:25 evcc-stable.list
              -rw-r--r-- 1 root root   84 Jul 23 11:37 grafana.list
              -rw-r--r-- 1 root root  103 Jul 23 18:08 influxdb.list
              -rw-r--r-- 1 root root  208 Aug 23  2022 nodesource.list
              -rw-r--r-- 1 root root  191 Apr  4  2022 raspi.list
              pi@raspberrypi:~ $
              nodejs v20.19.4
              npm 10.8.2
              Objects type: jsonl
              States type: redis
              admin: 7.6.17
              javascript: 8.9.2
              • M maximinus
                total 28K
                pi@raspberrypi:~ $
                @maximinus
                sudo rm /etc/apt/sources.list.d/influxdb.list
                echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                rm influxdata-archive_compat.key
                  maximinus
                  Danke Thomas das wars
                  pi@raspberrypi:~ $ apt list --upgradable
                  Listing... Done
                  grafana/stable 10.0.2 armhf [upgradable from: 9.1.3]
                  N: There are 237 additional versions. Please use the '-a' switch to see them.
                  pi@raspberrypi:~ $
                  Ist es ratsam auf 10.0.2 zu wechseln? ich bin bei influxdb noch auf version1.x
                  nodejs v20.19.4
                  npm 10.8.2
                  Objects type: jsonl
                  States type: redis
                  admin: 7.6.17
                  javascript: 8.9.2
                  • M maximinus
                    Listing... Done
                    pi@raspberrypi:~ $
                    @maximinus sagte in backitup Fehlermeldung:
                    Moin,
                    verwechselst Du da was?
                    Grafana ≠ influx
                    Bernd
                      Moin,
                      Grafana ≠ influx
                      Bernd
                      maximinus
                      @dp20eic
                      Grafana verarbeitet doch die Daten aus der influxdb. Es wäre ja möglich dass eine neue Version von Grafana auch eine neue Version von influxdb bedingt. Da ich bisher aber nichts vermisse würde ich lieber alles so lassen wie es ist. Es sei denn es wäre dringend angeraten doch upzugraden. Das war gemeint.
                      LG Gerhard
                      nodejs v20.19.4
                      npm 10.8.2
                      Objects type: jsonl
                      States type: redis
                      admin: 7.6.17
                      javascript: 8.9.2
                      • M maximinus
                        @dp20eic
                        LG Gerhard
                        @maximinus
                        Updates sind zeitnah einzuspielen.
                        • M maximinus
                          @dp20eic
                          LG Gerhard
                          @maximinus
                          Was spuckt ein
                          sudo apt update
                          jetzt aus?
                            maximinus
                            Hit:3 https://repos.influxdata.com/debian stable InRelease
                            Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                            Fetched 5,127 B in 2s (3,290 B/s)
                            1 package can be upgraded. Run 'apt list --upgradable' to see it.
                            pi@raspberrypi:~ $
                            Daher die Frage.
                            nodejs v20.19.4
                            npm 10.8.2
                            Objects type: jsonl
                            States type: redis
                            admin: 7.6.17
                            javascript: 8.9.2
                            • M maximinus
                              pi@raspberrypi:~ $
                              Daher die Frage.
                              @maximinus
                              Ja, zieh die Version auf den letzten Stand.
