  3. Einsteigerfragen
  4. Installation
  5. iobroker mit node.js 16 installieren
31 Beiträge 6 Kommentatoren 2.9k Aufrufe 5 Beobachtet
  • ch90045C ch90045
    @meister-mopper Ja, die Idee ist mir dann auch gekommen ... aber:
    ./install.sh
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installer!
        Installer version: 2023-04-16
        Installing prerequisites (1/4)
    Hit:1 http://security.debian.org bullseye-security InRelease
    Hit:2 http://ftp.debian.org/debian bullseye InRelease
    Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
    Reading package lists... Done
    Installed npm
    Changing npm registry to https://registry.npmjs.org
    Installed build-essential
    Installed gcc-c++
    Installed libavahi-compat-libdnssd-dev
    Installed libudev-dev
    Installed libpam0g-dev
    Installed git
    Installed libcairo2-dev
    Installed libpango1.0-dev
    Installed libjpeg-dev
    Installed libgif-dev
    Installed librsvg2-dev
    Installed net-tools
    Installed cmake
        Creating ioBroker user and directory (2/4)
    User iobroker created
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    npm ERR! code EBADENGINE
    npm ERR! engine Unsupported engine
    npm ERR! engine Not compatible with your version of node/npm: iobroker.backitup@2.6.23
    npm ERR! notsup Not compatible with your version of node/npm: iobroker.backitup@2.6.23
    npm ERR! notsup Required: {"node":">=14.0.0"}
    npm ERR! notsup Actual:   {"npm":"7.5.2","node":"v12.22.12"}
    npm ERR!     /root/.npm/_logs/2023-07-20T15_57_04_799Z-debug.log
        Finalizing installation (4/4)
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.0.67:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    root@tempbroker:~# iob status
    internal/modules/cjs/loader.js:818
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
        at Function.Module._load (internal/modules/cjs/loader.js:667:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    root@tempbroker:~# iob fix
    library: loaded
    ioBroker is not installed in /opt/iobroker! Cannot fix anything...
    root@tempbroker:~# cd /opt/
    root@tempbroker:/opt# cd iobroker/
    root@tempbroker:/opt/iobroker# ls
    INSTALLER_INFO.txt  iob  iobroker  package.json
    root@tempbroker:/opt/iobroker# ./iob
    iob       iobroker
      throw err;
      requireStack: []
    Meister MopperM Online
    Meister Mopper
    @ch90045
    Ich dachte eher an
    iob stop
    die node.js Ziffer ändern
    sudo apt update && sudo apt full-upgrade
    sicherheitshalber einen reboot
    und dann sollte es leben.
    Proxmox und HA ...
    ch90045C 1 Antwort Letzte Antwort
      @ch90045
      Ich dachte eher an
      iob stop
      ch90045C Offline
      ch90045C Offline
      ch90045
      @meister-mopper Proxmox sei dank - gib mir 5min ....
      • ch90045C ch90045
        @ch90045
        Installier gezielt eine bestimmte Version von nodejs. Wie das geht steht in meiner Signatur. Ganz unabhängig von proxmox. Allerdings hampelt man auch da NICHT als root durch die Gegend.
        • ch90045C ch90045
          @ch90045
          Ich meine mich erinnern zu können das der Adapter im GitHub auch mit nodejs@18 parat kommt.
            @ch90045
            ch90045C Offline
            ch90045C Offline
            ch90045
            @thomas-braun Lieber Thomas, ich hampel nicht! Dein Tipp hat funktioniert. Ich lege bloss nicht für eine Testinstallation noch einen Benutzer an um ihn 3min später wieder mit dem ganzen Container zu löschen.
              @ch90045
              ch90045C Offline
              ch90045C Offline
              ch90045
              • ch90045C ch90045
                @ch90045
                root shell ist immer Gehampel.
                https://github.com/Apollon77/ioBroker.daikin-cloud/issues/188
                • ch90045C ch90045
                  @ch90045
                  Hier installiert das Ding sauber mit nodejs@18.17.0 und auch sonst bleeding edge Versionen. Wurde allerdings nicht in einer root shell ausgeführt.
                  iobroker url https://github.com/Apollon77/ioBroker.daikin-cloud --host chet --debug
                  install Apollon77/ioBroker.daikin-cloud#03b831dac009b1d9cd0a7399f7e9a38486d06d19
                  NPM version: 9.6.7
                  Installing Apollon77/ioBroker.daikin-cloud#03b831dac009b1d9cd0a7399f7e9a38486d06d19... (System call)
                  npm WARN skipping integrity check for git dependency ssh://git@github.com/Apollon77/ioBroker.daikin-cloud.git
                  107 packages are looking for funding run `npm fund` for details
                  upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                  upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                  upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/index_m.html index_m.html text/html
                  upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/style.css style.css text/css
                  upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                  upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                  Process exited with code 0
                    @ch90045
                    NPM version: 9.6.7
                    ch90045C Offline
                    ch90045C Offline
                    ch90045
                    schrieb am zuletzt editiert von ch90045
                    @thomas-braun Die Installation stand nie in Frage - eine Instanz wird mit dem Hinweis auf Version 18 abgelehnt. Dein Root Gemeckere nervt - du weisst nicht mit wem du sprichst, ich halte mich bei jemandem, den ich nicht kenne mit nicht zielführender (heisst, mit Nachweiss, dass der Punkt Auslöser für das Problem ist) Kritik zurück - aber vielleicht empfinde ich allein dies als unhöflich/übergriffig.
                    Ich habe das Problem gelöst - danke an alle, die zielführend geholfen haben.
                    -1
                    • ch90045C ch90045
                      @ch90045 sagte in iobroker mit node.js 16 installieren:
                      ich weiss nicht ob ich dazu auch etwas allgemeingültiges in einen Thread gegossen habe.
                      kurz die Essenz:
                      Die Verwendung von root kann dazu führen, dass Rechte dermaßen verbogen wurden, dass der Sysemuser iobroker nicht mehr normal arbeiten kann.
                        kurz die Essenz:
                        ch90045C Offline
                        ch90045C Offline
                        ch90045
                        @homoran Ich weiss, dass man root nicht nutzen soll. Ich nutze root nicht auf meinem "Produktionssystem" welches genau den Fehler (keine Instanz für den Daikin Cloud Adapter bei node.js >= 18.x) hatte. Ich habe nur "schnell" die tempbroker container instanz installiert um zu testen, ob ich die Version 16 bekommen kann, welche das Installationsskript nicht installiert. Die Lebensdauer der tempbroker instanz lag unter 5min - was ich übrigens auch geschrieben habe - da dann über "du benutzt ja root" zu meckern und nicht einen Hinweis/Nachweis, warum root HIER ein Problem ist, zu geben, welcher hilfreich ist für die Problemstellung, nervt.
                        Die Frage, wie man bei einem aktuellen iobroker Installationsskript node.js <=16 installiert hat wirklich nichts mit root/normaler Nutzer zu tun und war somit auch nicht Teil meiner Frage.
                        • ch90045C ch90045
                          @ch90045
                          Verbogene Rechte gerade biegen nervt noch mehr.
                          Einfach immer ordentlich mit einem Debian umgehen, passt.
                            @ch90045
                            ch90045C Offline
                            ch90045C Offline
                            ch90045
                            @thomas-braun Ungefragte Antworten zu bekommen nervt am meisten - immer noch.
                            • ch90045C ch90045
                              @ch90045
                              Hast doch eine Antwort bekommen wie man andere Versions-Linien richtig installiert.
                              Den Hinweis auf den root gab es gratis dazu.
                                @ch90045
                                ch90045C Offline
                                ch90045C Offline
                                ch90045
                                @thomas-braun Und den brauchte ich nicht einmal - aber das willst du ja nicht hören/verstehen ... lässt auf eine herablassende Ignoranz schliessen.
                                -1
                                • ch90045C ch90045
                                  @ch90045
                                  Nein, weil der Adapter in aktuellster Version auch mit nodejs@18 kompatibel ist. Hab ich verstanden/gewusst.
                                  Eine user shell ist wie mit dem Anschnallgurt im Auto. Musst du auch anlegen, und wenn es nur bis zum Bäcker die Straße runter ist. Wenn du der Rennleitung ohne Gurt entgegekommst kriegst du da auch ungefragt ein Ticket.
                                    @ch90045
                                    @thomas-braun sagte in iobroker mit node.js 16 installieren:
                                    Moin,
                                    kann nicht wiederstehen :)
                                    !!! OT on !!!
                                    Das ist nicht wie zum Becker, das ist, ich fahre auf dem eigenen Grundstück, und da muss ich mich nicht anschnallen ;)
                                    Wenn ich dabei etwas zerstöre oder mich verletze, ist das mein Schaden, das muss mir nur bewusst sein, auch dass Versicherungen sich weigern werden da etwas zu zahlen.
                                    !!! OT off !!!
                                    Ich entschuldige mich schon mal für alles, was jetzt daraus wird :)
                                    Bernd
                                    P.S.: root sollte trotzdem mit Vorsicht genutzt werden :)
                                    -1
                                      Moin,
                                      !!! OT on !!!
                                      !!! OT off !!!
                                      Bernd
                                      @dp20eic
                                      root wird zu 99,99% immer genau von den Kandidaten verwendet, die es eben tunlichst mangels Ahnung nicht machen sollten.
                                      Die mit Ahnung wissen nur zu gut wie gefährlich das sein kann.
                                      Der Waldarbeiter schaltet seine Kettensäge ja auch während seiner Frühstückspause ab und lässt die nicht laufen, weil er die ja in ein paar Minuten wieder braucht.
                                        @dp20eic
                                        ch90045C Offline
                                        ch90045C Offline
                                        ch90045
                                        @thomas-braun Schon wieder eine Vorverurteilung - ich zwischen 1999-2011 Solaris OS support gemacht, bin seit 2011 bei einer IT Firma die unter der Appliance BSD nutzt - ich weiss mit root umzugehen das magst du anders sehen, geht mir aber am ... - noch immer - nichts davon hatte etwas mit meiner Frage zu tun.
                                        • ch90045C ch90045
                                          @ch90045
                                          Das ist ja beeindruckend...
                                          Dann kennst du ja Paketmanager und weißt wie man gezielt andere Versionszweige installiert, wenn eine andere als die im Installationsskript hinterlegte benötigt.
