  4. Node-Red
  5. 3 Werte vergleichen und über Switch Ausgabe gleich/ungleich
    6.5k
5 Beiträge 2 Kommentatoren 557 Aufrufe 2 Beobachtet
  • _ Offline
    _ Offline
    _R_A_L_F_
    ich habe folgenden Flow:
    Hierbei möchte ich an der Switch Node vergleichen, ob der Payload von Wert 1 - 3 gleich ist (Ausgang 1). Falls einer davon abweicht = Ausgang 2 am Switch.
    Wie vergleiche ich das ganze? Geht das über einen JSONata-Ausdruck?
    Anbei der aktuell Flow:
            "id": "197a11c1f440578d",
            "type": "tab",
            "label": "Flow 6",
            "disabled": false,
            "info": "",
            "env": []
            "id": "f0e9aad3a7235f24",
            "type": "inject",
            "z": "197a11c1f440578d",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "Wert1",
            "payload": "30",
            "payloadType": "num",
            "x": 440,
            "y": 280,
            "wires": [
                    "5edc115ae5058566"
            "id": "b8e4c456e4c046f0",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "Wert2",
            "payload": "30",
            "x": 440,
            "y": 320,
            "wires": [
                    "5edc115ae5058566"
            "id": "8fe50b86dfbc96e9",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "Wert3",
            "payload": "30",
            "x": 440,
            "y": 360,
            "wires": [
                    "5edc115ae5058566"
            "id": "5edc115ae5058566",
            "type": "join",
            "name": "",
            "mode": "custom",
            "build": "object",
            "property": "payload",
            "propertyType": "msg",
            "key": "topic",
            "joiner": "\\n",
            "joinerType": "str",
            "accumulate": true,
            "timeout": "",
            "count": "3",
            "reduceRight": false,
            "reduceExp": "",
            "reduceInit": "",
            "reduceInitType": "",
            "reduceFixup": "",
            "x": 650,
            "y": 320,
            "wires": [
    Vielen Dank
    • _ _R_A_L_F_
              "type": "tab",
              "label": "Flow 6",
              "disabled": false,
              "info": "",
              "env": []
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "Wert1",
              "payload": "30",
              "x": 440,
              "y": 280,
              "wires": [
                      "5edc115ae5058566"
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "Wert2",
              "payload": "30",
              "x": 440,
              "y": 320,
              "wires": [
                      "5edc115ae5058566"
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "Wert3",
              "payload": "30",
              "x": 440,
              "y": 360,
              "wires": [
                      "5edc115ae5058566"
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "object",
              "key": "topic",
              "joiner": "\\n",
              "accumulate": true,
              "timeout": "",
              "count": "3",
              "reduceExp": "",
              "reduceInit": "",
              "reduceFixup": "",
              "x": 650,
              "y": 320,
              "wires": [
      Vielen Dank
      mickymM Offline
      mickymM Offline
      mickym
      @_r_a_l_f_
      Man muss alle Werte miteinander vergleichen muss aber eine AND Verknüpfung nehmen.
      Wert1 = Wert2 = Wert3 funktioniert nicht, da JSONATA immer von links nach rechts arbeitet und deshalb wird hier immer falsch rauskommen, da ein Boolean true mit 30 verglichen wird. ;)
      Deswegen solltest Du die Switch Node nicht die payload überprüfen lassen, sondern den JSONATA Ausdruck. ;)
      Hier der Rest Deines Flows:
             "id": "5986e9485ce40dc3",
             "type": "debug",
             "name": "wahr",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 690,
             "y": 120,
             "wires": []
             "id": "e9987d83609820b3",
             "type": "debug",
             "name": "falsch",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 690,
             "y": 180,
             "wires": []
             "id": "44eac2488650b66d",
             "type": "switch",
             "name": "",
             "property": "(payload.Wert1 = payload.Wert2) and (payload.Wert2 = payload.Wert3)",
             "propertyType": "jsonata",
             "rules": [
                     "t": "true"
                     "t": "false"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 470,
             "y": 160,
             "wires": [
                     "5986e9485ce40dc3"
                     "e9987d83609820b3"
      _ 1 Antwort Letzte Antwort
      • mickymM mickym
        @_r_a_l_f_
               "type": "debug",
               "name": "wahr",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 690,
               "y": 120,
               "wires": []
               "type": "debug",
               "name": "falsch",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 690,
               "y": 180,
               "wires": []
               "type": "switch",
               "name": "",
               "rules": [
                       "t": "true"
                       "t": "false"
               "checkall": "true",
               "repair": false,
               "outputs": 2,
               "x": 470,
               "y": 160,
               "wires": [
                       "5986e9485ce40dc3"
                       "e9987d83609820b3"
        _ Offline
        _ Offline
        _R_A_L_F_
        @mickym Mega. Genau so habe ich mir die Lösung vorgestellt. Ich wusste nur nicht, wie ich das ganze im Switch Node abfragen muss. Aber vielen vielen Dank für die Antwort.
        • _ _R_A_L_F_
          mickymM Offline
          mickymM Offline
          mickym
          @_r_a_l_f_ sagte in 3 Werte vergleichen und über Switch Ausgabe gleich/ungleich:
          Hier noch eine Version, die unabhängig von der Anzahl der zu vergleichenden Werte ist.
          payload.*#$i.($$.payload.*[0] = $$.payload.*[$i]) ~> $reduce(function($i, $j){$i and $j})
          Hier der Code:
                 "id": "7a194f84b999469f",
                 "type": "switch",
                 "name": "AND?",
                 "property": "payload.*#$i.($$.payload.*[0] = $$.payload.*[$i]) ~> $reduce(function($i, $j){$i and $j})",
                 "rules": [
                         "t": "true"
                         "t": "false"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 2,
                 "x": 630,
                 "y": 340,
                 "wires": [
                         "3c04406fef7d9523"
                         "baf2ab75bc89e1ae"
                 "info": "# All properties of an object must be true.\n\nAll properties of an object must be true.\n\n`{\n    \"Office\": true,\n    \"Bedroom\": true,\n    \"Living Room Balcony\": true,\n    \"Living Room Right Window\": true,\n    \"Living Room Left Window\": true\n}`\n\nis true,\n\n`{\n    \"Office\": true,\n    \"Bedroom\": false,\n    \"Living Room Balcony\": true,\n    \"Living Room Right Window\": true,\n    \"Living Room Left Window\": true\n}`\n\nis false.\n\n# Alle Eigenschaften eines Objektes müssen wahr sein\n\nAlle Eigenschaften eines Objektes müssen wahr sein.\n\n`{\n    \"Büro Balkon\": true,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": true,\n    \"Wohnzimmer rechtes Fenster\": true,\n    \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt true,\n\n`{\n    \"Büro Balkon\": true,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": true,\n    \"Wohnzimmer rechtes Fenster\": false,\n    \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt false."
                 "id": "3c04406fef7d9523",
                 "type": "debug",
                 "name": "wahr",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 770,
                 "y": 320,
                 "wires": []
                 "id": "baf2ab75bc89e1ae",
                 "type": "debug",
                 "name": "falsch",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 770,
                 "y": 360,
                 "wires": []
          Hier wird der ERSTE Wert mit allen anderen verglichen.
          Dadurch wird ein boolesches Array mit den Ergebnissen erzeugt,
          deren Elemente mit UND verknüpft werden und zum Gesamtergebnis führen.
          • mickymM mickym
            Hier der Code:
                   "type": "switch",
                   "name": "AND?",
                   "rules": [
                           "t": "true"
                           "t": "false"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 630,
                   "y": 340,
                   "wires": [
                           "3c04406fef7d9523"
                           "baf2ab75bc89e1ae"
                   "type": "debug",
                   "name": "wahr",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 770,
                   "y": 320,
                   "wires": []
                   "type": "debug",
                   "name": "falsch",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 770,
                   "y": 360,
                   "wires": []
            _ Offline
            _ Offline
            _R_A_L_F_
            @mickym Absoluter Hammer. Wie man darauf nur kommt :D Das ist natürlich die Königslösung ;)
