  3. Einsteigerfragen
  4. Installation
  5. Echarts Adapter nach Update nicht mehr funktionsfähig
30 Beiträge 5 Kommentatoren 4.0k Aufrufe 5 Beobachtet
    @hen30
    Gib mal die Langfassung von iob diag
    HeN30
    @thomas-braun Kein Problem
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : microsoft
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.2 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.2 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.2 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     18:51:59 up  3:56,  3 users,  load average: 13.50, 20.44, 12.48
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Sun 2023-07-02 18:52:06 CEST
               Universal time: Sun 2023-07-02 16:52:06 UTC
                     RTC time: Sun 2023-07-02 16:52:06
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    marco
    /home/marco
    marco adm cdrom sudo dip plugdev lxd iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.9G        3.6G        131M        0.0K        221M        128M
    Swap:           3.0G        1.2G        1.8G
    Total:          6.9G        4.7G        1.9G
             3911 M total memory
             3559 M used memory
              511 M active memory
             3007 M inactive memory
              131 M free memory
               14 M buffer memory
              206 M swap cache
             2981 M total swap
             1181 M used swap
             1800 M free swap
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  392M  1.1M  391M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    44G   17G   25G  40% /
    tmpfs                             tmpfs  2.0G     0  2.0G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  253M  1.6G  14% /boot
    tmpfs                             tmpfs  392M  4.0K  392M   1% /run/user/1000
    [Sun Jul  2 14:55:32 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sun Jul  2 14:55:41 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
    [Sun Jul  2 14:55:52 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    TARGET              SOURCE                            FSTYPE   OPTIONS
    /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/snap/core20/1891 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/1950 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/23541   /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/24322   /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/19457 /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/19361 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
    `-/boot             /dev/sda2                         ext4     rw,relatime
    /var:
    5.7G    /var/
    4.3G    /var/log
    4.1G    /var/log/journal/ecc0962cbac84c6e9c5fef27b0505515
    1.1G    /var/lib
    Archived and active journals take up 4.0G in the file system.
    /opt/iobroker/backups:
    24M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    360M    /opt/iobroker/iobroker-data/
    266M    /opt/iobroker/iobroker-data/files
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    40M     /opt/iobroker/iobroker-data/backup-objects
    27M     /opt/iobroker/iobroker-data/states.jsonl
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   1
    Adapter State
      system.adapter.accuweather.0            : accuweather           : iobrokerserver                           - disabled
    + system.adapter.admin.0                  : admin                 : iobrokerserver                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobrokerserver                           -  enabled
      system.adapter.botvac.0                 : botvac                : iobrokerserver                           - disabled
      system.adapter.daswetter.0              : daswetter             : iobrokerserver                           -  enabled
    + system.adapter.discovery.0              : discovery             : iobrokerserver                           -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobrokerserver                           -  enabled
      system.adapter.flot.0                   : flot                  : iobrokerserver                           - disabled
    + system.adapter.fritzdect.0              : fritzdect             : iobrokerserver                           -  enabled
    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobrokerserver                           -  enabled
    + system.adapter.fronius.0                : fronius               : iobrokerserver                           -  enabled
    + system.adapter.history.0                : history               : iobrokerserver                           -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobrokerserver                           -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerserver                           - disabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerserver                           - disabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobrokerserver                           -  enabled, port: 12010
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobrokerserver                           -  enabled, port: 12010
    + system.adapter.hm-rpc.4                 : hm-rpc                : iobrokerserver                           -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobrokerserver                           -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobrokerserver                           -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokerserver                           -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobrokerserver                           -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobrokerserver                           -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobrokerserver                           -  enabled
    + system.adapter.linux-control.0          : linux-control         : iobrokerserver                           -  enabled
    + system.adapter.meross.0                 : meross                : iobrokerserver                           -  enabled
      system.adapter.net-tools.0              : net-tools             : iobrokerserver                           - disabled
      system.adapter.openweathermap.0         : openweathermap        : iobrokerserver                           - disabled
    + system.adapter.ping.0                   : ping                  : iobrokerserver                           -  enabled
      system.adapter.socketio.0               : socketio              : iobrokerserver                           - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.statistics.0             : statistics            : iobrokerserver                           -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokerserver                           -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobrokerserver                           -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobrokerserver                           -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobrokerserver                           -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokerserver                           - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokerserver                           -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokerserver                           - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerserver                           -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobrokerserver                           - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokerserver                           -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobrokerserver                           -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobrokerserver                           - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerserver                           - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobrokerserver                           -  enabled
      system.adapter.vis.0                    : vis                   : iobrokerserver                           -  enabled
    + system.adapter.web.0                    : web                   : iobrokerserver                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : iobrokerserver                           -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : iobrokerserver                           -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "botvac"       : 1.0.0    , installed 1.0.0
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fronius"      : 1.1.3    , installed 1.1.3
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-icontwo"  : 0.94.0   , installed 0.94.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Objects and States
    Objects:        18249
    States:         16546
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian jammy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    W: Failed to fetch https://repos.influxdata.com/debian/dists/jammy/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://repository.veeam.com/backup/linux/agent/dpkg/debian/public stable InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 https://packages.grafana.com/oss/deb stable InRelease
    Hit:5 https://deb.nodesource.com/node_18.x jammy InRelease
    Get:6 https://repos.influxdata.com/debian jammy InRelease [7037 B]
    Get:7 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease [108 kB]
    Hit:8 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Err:6 https://repos.influxdata.com/debian jammy InRelease
    Fetched 115 kB in 2s (48.8 kB/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21739      806/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          18269      1/init
    tcp        0      0 192.168.2.17:12010      0.0.0.0:*               LISTEN      1001       218019     32813/io.hm-rpc.2
    tcp        0      0 192.168.2.17:12011      0.0.0.0:*               LISTEN      1001       218043     32828/io.hm-rpc.3
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        21417      740/systemd-resolve
    tcp        0      0 127.0.0.1:10808         0.0.0.0:*               LISTEN      0          21994      926/veeamservice
    tcp        0      0 192.168.2.17:9292       0.0.0.0:*               LISTEN      1001       218352     32843/io.hm-rpc.4
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       217758     32693/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       217765     32693/iobroker.js-c
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        21874      784/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          21741      806/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          18271      1/init
    tcp6       0      0 :::3000                 :::*                    LISTEN      116        23803      1365/grafana
    tcp6       0      0 :::20002                :::*                    LISTEN      1001       221869     33873/io.web.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       219424     32970/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       217080     32711/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        23409      784/influxd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       222860     33857/io.ws.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        21416      740/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18270      1/init
    udp6       0      0 fe80::11:32ff:fe2a::546 :::*                                101        21422      738/systemd-network
    udp6       0      0 :::111                  :::*                                0          18272      1/init
    2023-07-02 18:50:38.078  - info: hm-rpc.4 (32843) xmlrpc -> 16 devices
    2023-07-02 18:50:38.703  - info: hm-rpc.4 (32843) xmlrpc <- newDevices 16
    2023-07-02 18:50:38.895  - info: hm-rpc.4 (32843) new virtual-devices devices/channels after filter: 0
    2023-07-02 18:50:38.908  - info: hm-rpc.4 (32843) xmlrpc <- setReadyConfig ["iobrokerserver:hm-rpc.4:8c270e7f52559ad3e48d108a01888a6a","INT0000003"]
    2023-07-02 18:50:38.922  - info: hm-rpc.4 (32843) xmlrpc <- setReadyConfig ["iobrokerserver:hm-rpc.4:8c270e7f52559ad3e48d108a01888a6a","INT0000004"]
    2023-07-02 18:50:42.743  - info: influxdb.0 (32738) Not connected to InfluxDB, try later
    2023-07-02 18:50:42.743  - info: influxdb.0 (32738) Error storing buffered series for fronius.0.powerflow.P_Grid before GetHistory: Not connected to InfluxDB, try later
    2023-07-02 18:50:42.747  - info: influxdb.0 (32738) Not connected to InfluxDB, try later
    2023-07-02 18:50:42.748  - info: influxdb.0 (32738) Error storing buffered series for fronius.0.powerflow.P_PV before GetHistory: Not connected to InfluxDB, try later
    2023-07-02 18:50:42.753  - info: influxdb.0 (32738) Not connected to InfluxDB, try later
    2023-07-02 18:50:42.753  - info: influxdb.0 (32738) Error storing buffered series for fronius.0.powerflow.inverter1.SOC before GetHistory: Not connected to InfluxDB, try later
    2023-07-02 18:50:42.754  - info: influxdb.0 (32738) Error storing buffered series for fronius.0.powerflow.P_Load before GetHistory: Not connected to InfluxDB, try later
    2023-07-02 18:50:45.778  - info: admin.0 (32711) ==> Connected system.user.admin from undefined
    2023-07-02 18:50:46.711  - info: admin.0 (32711) ==> Connected system.user.admin from undefined
    2023-07-02 18:50:46.712  - info: admin.0 (32711) ==> Connected system.user.admin from ::ffff:192.168.2.81
    2023-07-02 18:50:46.824  - info: admin.0 (32711) <== Disconnect system.user.admin from undefined admin
    2023-07-02 18:50:46.825  - info: admin.0 (32711) <== Disconnect system.user.admin from undefined admin
    2023-07-02 18:50:46.827  - info: admin.0 (32711) <== Disconnect system.user.admin from ::ffff:192.168.2.81 admin
    2023-07-02 18:51:36.453  - info: admin.0 (32711) ==> Connected system.user.admin from ::ffff:192.168.2.81
    2023-07-02 18:51:40.290  - info: daswetter.0 (35771) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.1, js-controller: 4.0.24
    2023-07-02 18:51:55.812  - info: daswetter.0 (35771) still wrong data structure from server received! repaired...
    2023-07-02 18:51:59.581  - info: daswetter.0 (35771) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-07-02 18:52:00.160  - info: daswetter.0 (35771) cleaned everything up...
    2023-07-02 18:52:00.229  - info: host.iobrokerserver instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    • H HeN30
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        22.04
      Codename:       jammy
      NAME="Ubuntu"
      VERSION_ID="22.04"
      ID=ubuntu
      ID_LIKE=debian
      CPU threads: 2
                    NTP service: active
                RTC in local TZ: no
      marco
      /home/marco
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               3911 M total memory
               3559 M used memory
                511 M active memory
                131 M free memory
                 14 M buffer memory
                206 M swap cache
               2981 M total swap
               1181 M used swap
               1800 M free swap
      *** FILESYSTEM ***
      /var:
      5.7G    /var/
      4.3G    /var/log
      1.1G    /var/lib
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        18249
      States:         16546
      Pending Updates: 0
      @hen30 sagte in Echarts Adapter nach Update nicht mehr funktionsfähig:
      Ich weiß nicht wie sich das auf VMs darstellt, aber die Kiste ist unter normalen Umständen 'dicht', zu ausgelastet.
      CPU threads: 2
      Spendier da mal mehr CPUs.
      RAM ist auch dicht.
      Grafana und Influx-Repo muss jeweils angepackt werden.
      Gibt dazu auch einen Thread hier im Forum.
      Was ist
      für eine Quelle?
      iob add echarts --debug
      sagt?
      • H HeN30
        Gut, dann gehen wir es mal von vorne an. Wie auch das versuchte Update brechen Installationsversuche von echarts 1.5.1 beim letzten Punkt ab;
        $ iobroker add echarts auto --host iobrokerserver --debug
        NPM version: 9.5.1
        Installing iobroker.echarts@1.5.1... (System call)
        added 38 packages in 14s120 packages are looking for funding run `npm fund` for details
        host.iobrokerserver install adapter echarts
        upload [28] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/asset-manifest.json asset-manifest.json application/json
        upload [20] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.LICENSE.txt chart/static/js/main.eb0afecd.js.LICENSE.txt text/plain
        upload [19] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.map chart/static/js/main.eb0afecd.js.map application/json
        upload [18] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/echarts.png echarts.png image/png
        upload [17] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
        upload [16] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/manifest.json manifest.json application/json
        upload [15] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/preview/asset-manifest.json preview/asset-manifest.json application/json
        upload [14] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/preview/favicon.ico preview/favicon.ico image/vnd.microsoft.icon
        upload [13] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/preview/index.html preview/index.html text/html
        upload [12] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/preview/manifest.json preview/manifest.json application/json
        upload [11] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/preview/static/css/main.f7b2c82f.css preview/static/css/main.f7b2c82f.css text/css
        upload [10] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/preview/static/css/main.f7b2c82f.css.map preview/static/css/main.f7b2c82f.css.map application/json
        upload [9] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/preview/static/js/main.1b04901d.js preview/static/js/main.1b04901d.js application/javascript
        upload [8] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/preview/static/js/main.1b04901d.js.LICENSE.txt preview/static/js/main.1b04901d.js.LICENSE.txt text/plain
        upload [7] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/preview/static/js/main.1b04901d.js.map preview/static/js/main.1b04901d.js.map application/json
        upload [3] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.7952f0f7.js.LICENSE.txt static/js/main.7952f0f7.js.LICENSE.txt text/plain
        upload [2] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.7952f0f7.js.map static/js/main.7952f0f7.js.map application/json
        der Installationsprozess bleibt dann ohne weitere Meldungen im Protokoll hängen. Danach meldet iob update echarts als installiert:
        marco@iobrokerserver:~$ iob update
        Er ist aber nicht in der Admin-Oberfläche verfügbar.
        die uploads sind noch nicht fertig (vielleicht noch anderes nicht)
        Mit der Zusatzinfo
        @thomas-braun sagte in Echarts Adapter nach Update nicht mehr funktionsfähig:
        RAM ist auch dicht.
        in weiterer Verbindung mit aktuellen Berichten, dass eCharts für die Installation viel RAM braucht, führt zu der Vermutung dass bei dir die Installation nicht durchgelaufen ist
        H 1 Antwort Letzte Antwort
          Mit der Zusatzinfo
          RAM ist auch dicht.
          HeN30
          @homoran Nach dem Hinweis auf den vollen RAM hatte ich dann etwas aufgeräumt sodass das RAM nur noch zu 45% belegt war. Leider hat das aber keinen Unterschied beim installieren von echarts gemacht - bricht immer wieder beim (vorletzten?) Punkt ab... Es sei denn natürlich gerade dieser Punkt lässt den RAM vollaufen, dann hätte ich wohl gelitten. Mehr RAM is nicht...
          • H HeN30
            55% von 4GB müssten 2.2GB free sein.
            ich glaube nicht, dass du wirklich über 2GB freischaufeln konntest.
            das könnte zu den anderen Threads passen.
            musst du mal suchen.
            was sagt denn anschließend top zum RAM
            • H HeN30
              @hen30
              Bricht es wirklich ab oder läuft es einfach nur ewig lange?
                @hen30
                HeN30
                @thomas-braun Na ja, es läuft ewig und endet vermutlich irgendwann im Timeout. Aber mal ehrlich, wenn unter Linux ein Installer 2GB RAM braucht ist am Installer was faul...
                • H HeN30
                  Da geb ich dir Recht. Das ist ungewöhnlich viel. Ich weiß aber nicht warum der Adapter so viel RAM wegschnuckelt. Ist soweit ich das weiß auch nur echarts, der sich so exzessiv verhält.
                    HeN30
                    @thomas-braun So, hatte es jetzt mal hinbekommen den Adapter zu installieren indem ich alles andere auf dem iobroker gestoppt hatte. Hatte dann 75% Ram frei und die Installation lief durch - nur um danach zu bemerken, dass nach der Installation mit laufendem echarts nur noch 25% RAM frei waren.
                    Damit ist echarts erstmal für mich gestorben. Sorry. aber meiner Meinung nach ist da doch ein gravierender Fehler in der Version wenn der im Vergleich zu vorher soviel RAM frisst.
                    HomoranH Thomas BraunT J 3 Antworten Letzte Antwort
                    • H HeN30
                      Wahrscheinlich Fehlinterpretation!
                      frei oder verfügbar?
                      • H HeN30
                        Fehler hier melden:
                        https://github.com/ioBroker/ioBroker.echarts/issues
                        • H HeN30
                          jt
                          Hallo zusammen.
                          Ich hatte dasselbe Problem. Die Installation von echarts lief nie richtig durch, blieb beim vorletzten upload hängen. Auch die Installation im Terminal unter Ausreizung aller RAM-Optimierungen auf der DS920+ mit 4GB (dem Container hatte ich 3GB zugewiesen) hing es hier
                          /usr/bin/iob: line 8:  1273 Killed                  gosu iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                          und erst nach etlichen Stunden habe ich immer erkennen müssen, dass es nicht geklappt hat. Admin sagte zwar, dass bereits der Adapter installiert ist, aber es war keine Instanz zu sehen.
                          Aber nun habe ich es geschafft, in dem ich iobroker vorher gestoppt habe, also ...
                          pkill -u iobroker
                          iob start
                          und siehe da. Ratzfaz ist die Installation durchgelaufen und eine Instanz ist da.
                          VG, Jörg
                          • J jt
                            Hallo zusammen.
                            pkill -u iobroker
                            iob start
                            VG, Jörg
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @jt sagte in Echarts Adapter nach Update nicht mehr funktionsfähig:
                            kannst du mal diese Ausgabe posten ... ist noch im Log vorhanden .
                            Hinweis :
                            nach einem
                            pkill -u iobroker
                            den " Container " neu starten und nicht dafür iob start nutzen .
                            • GlasfaserG Glasfaser
                              Hinweis :
                              nach einem
                              pkill -u iobroker
                              jt
                              @glasfaser Danke für den Hinweis mit dem Starten des Containers. Habe ich direkt notiert.
                              Wo finde ich das Log. In docker/iobroker_data/log gibt es ein log file von heute. Aber da finde ich komischerweise zwar 3 Versuche der Installation von echarts, aber nicht die manuelle Installation im Terminal.
