  4. JavaScript
  5. Roborock Adapter tester gesucht
766 Beiträge 51 Kommentatoren 324.8k Aufrufe 52 Beobachtet
  • copystringC copystring
    @andy61 In der neuen dev ist der Support dafür eingebaut. Bitte mal testen: https://github.com/copystring/ioBroker.roborock/tree/dev
    jahnbesJ Offline
    jahnbesJ Offline
    jahnbes
    #727
    @copystring Hallo copystring, ich habe die letzte dev-Version installiert. Seit heute früh geht app-segment-clean nicht mehr, es kommt folgende log-Ausschrift im iobroker s.u.
    Der entsprechende Raum ist auf "true" gesetzt.
    Viele Grüße, Bert.
    Zeit
    warn
    Nachricht
    roborock.0
    2023-06-26 08:40:36.246 warn Failed to execute app_segment_clean. Error: There was an error processing the request with id 1527 error: {"code":-10005,"message":"data for segments is invalid"}
    roborock.0
    2023-06-26 08:39:33.402 warn Failed to execute app_segment_clean. Error: There was an error processing the request with id 2037 error: {"code":-10005,"message":"data for segments is invalid"}
    roborock.0
    2023-06-26 08:39:28.425 warn Failed to execute app_segment_clean. Error: There was an error processing the request with id 7004 error: {"code":-10005,"message":"data for segments is invalid"}
    roborock.0
    2023-06-26 08:39:12.906 warn Failed to execute app_segment_clean. Error: There was an error processing the request with id 9153 error: {"code":-10005,"message":"data for segments is invalid"}
    roborock.0
    2023-06-26 08:39:08.253 warn Failed to execute app_segment_clean. Error: There was an error processing the request with id 2686 error: {"code":-10005,"message":"data for segments is invalid"}
    zigbee.0
    2023-06-26 08:18:16.789 warn DeviceAvailability:Stopping to ping 0x70ac08fffe68a9b2 TRADFRI Signal Repeater after 8 ping attempts
    hs100.0
    2023-06-26 08:01:45.788 warn getDevice Socket connection Timeout ip: 192.168.178.26 please reconnect the Device
    roborock.0
    2023-06-26 06:38:49.872 warn MQTT connection reconnect.
    roborock.0
    2023-06-26 06:38:49.868 warn MQTT connection close.
    copystringC 1 Antwort Letzte Antwort
    • jahnbesJ jahnbes
      Viele Grüße, Bert.
      Zeit
      warn
      Nachricht
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      zigbee.0
      hs100.0
      roborock.0
      roborock.0
      copystringC Offline
      copystringC Offline
      copystring
      #728
      @jahnbes Hat sich deine Karte geändert? Die dev hat sich seit über zwei Wochen nicht geändert.
      Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
      https://paypal.me/copystring
      jahnbesJ 1 Antwort Letzte Antwort
        @dimi Logs sind immer gut, aber viel wichtiger wäre erstmal, mit welcher Version es noch lief. Dann müsste man die Logs beider Versionen vergleichen.
        Dimi
        #729
        @copystring
        Hi, anbei mein LOG. In 3 Minuten wurde die Karte 3 mal gespeichert und neu geladen. Sieht man in der Roborock app. Dabei verliert der Sauger dann seine Position. Wenn ich ihn dann laufen lassen will muss er zuerst seine Position finden, auch wenn er angedockt war. Ich glaube das ist ab der Version so, wo der Q7 mit reingekommen ist. Bin mir leider nicht mehr sicher.
        2023-06-26 23:22:23.464 - info: host.ioBroker-RasPi "system.adapter.roborock.0" enabled
        2023-06-26 23:22:23.815 - info: host.ioBroker-RasPi instance system.adapter.roborock.0 started with pid 238444
        2023-06-26 23:22:26.418 - debug: roborock.0 (238444) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-06-26 23:22:26.482 - debug: roborock.0 (238444) Objects client ready ... initialize now
        2023-06-26 23:22:26.486 - debug: roborock.0 (238444) Objects create System PubSub Client
        2023-06-26 23:22:26.488 - debug: roborock.0 (238444) Objects create User PubSub Client
        2023-06-26 23:22:26.550 - debug: roborock.0 (238444) Objects client initialize lua scripts
        2023-06-26 23:22:26.584 - debug: roborock.0 (238444) Objects connected to redis: 127.0.0.1:9001
        2023-06-26 23:22:26.635 - debug: roborock.0 (238444) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-06-26 23:22:26.663 - debug: roborock.0 (238444) States create System PubSub Client
        2023-06-26 23:22:26.664 - debug: roborock.0 (238444) States create User PubSub Client
        2023-06-26 23:22:26.740 - debug: roborock.0 (238444) States connected to redis: 127.0.0.1:9000
        2023-06-26 23:22:26.863 - debug: roborock.0 (238444) Plugin sentry Initialize Plugin (enabled=true)
        2023-06-26 23:22:26.870 - info: roborock.0 (238444) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-06-26 23:22:27.024 - info: roborock.0 (238444) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.16.1, js-controller: 5.0.5
        2023-06-26 23:22:29.636 - info: roborock.0 (238444) MQTT initialized
        2023-06-26 23:22:29.638 - debug: roborock.0 (238444) RoomIDs debug: {"4517900":"Küche","4524358":"Kinderzimmer","4524368":"Schlafzimmer","4524483":"Bad","4524523":"Flur","4526290":"Gäste WC","4526403":"Wohnzimmer","4527411":"Heizraum"}
        2023-06-26 23:22:29.640 - debug: roborock.0 (238444) Robot key: roborock.vacuum.a10
        2023-06-26 23:22:34.133 - debug: roborock.0 (238444) getParameter: get_fw_features
        2023-06-26 23:22:34.135 - debug: roborock.0 (238444) Firmware features request
        2023-06-26 23:22:34.186 - debug: roborock.0 (238444) dps debug: {"id":4457,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
        2023-06-26 23:22:34.189 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:22:34.814 - debug: roborock.0 (238444) getParameter: get_multi_maps_list
        2023-06-26 23:22:34.859 - debug: roborock.0 (238444) dps debug: {"id":2824,"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":3,"map_info":[{"mapFlag":0,"add_time":1682415954,"length":11,"name":"Erdgeschoss","bak_maps":[]},{"mapFlag":1,"add_time":1675975972,"length":12,"name":"Obergeschoss","bak_maps":[]},{"mapFlag":2,"add_time":1678545840,"length":12,"name":"Dachgeschoss","bak_maps":[]}]}]}
        2023-06-26 23:22:34.860 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:22:34.862 - debug: roborock.0 (238444) Latest data requested
        2023-06-26 23:22:34.863 - debug: roborock.0 (238444) getParameter: get_status
        2023-06-26 23:22:34.904 - debug: roborock.0 (238444) dps debug: {"id":6915,"result":[{"msg_ver":2,"msg_seq":34,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}]}
        2023-06-26 23:22:34.904 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:22:34.905 - debug: roborock.0 (238444) get_status: {"msg_ver":2,"msg_seq":34,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}
        2023-06-26 23:22:34.908 - debug: roborock.0 (238444) getParameter: get_room_mapping
        2023-06-26 23:22:34.948 - debug: roborock.0 (238444) dps debug: {"id":4776,"result":[{"msg_ver":2,"msg_seq":35,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}]}
        2023-06-26 23:22:34.949 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.038 - debug: roborock.0 (238444) dps debug: {"id":7759,"result":[[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]}
        2023-06-26 23:22:35.039 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.039 - debug: roborock.0 (238444) All mapped rooms: [[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]
        2023-06-26 23:22:35.040 - debug: roborock.0 (238444) Mapped room matched: 4526290 with name: Gäste WC
        2023-06-26 23:22:35.041 - debug: roborock.0 (238444) Mapped room matched: 4526403 with name: Wohnzimmer
        2023-06-26 23:22:35.042 - debug: roborock.0 (238444) Mapped room matched: 4517900 with name: Küche
        2023-06-26 23:22:35.042 - debug: roborock.0 (238444) Mapped room matched: 4524523 with name: Flur
        2023-06-26 23:22:35.043 - debug: roborock.0 (238444) getParameter: get_consumable
        2023-06-26 23:22:35.078 - debug: roborock.0 (238444) dps debug: {"id":7529,"result":[{"main_brush_work_time":143990,"side_brush_work_time":143990,"filter_work_time":143990,"filter_element_work_time":11508,"sensor_dirty_time":4105}]}
        2023-06-26 23:22:35.079 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.080 - debug: roborock.0 (238444) Consumables of robot: [{"main_brush_work_time":143990,"side_brush_work_time":143990,"filter_work_time":143990,"filter_element_work_time":11508,"sensor_dirty_time":4105}]
        2023-06-26 23:22:35.080 - debug: roborock.0 (238444) getParameter: get_network_info
        2023-06-26 23:22:35.199 - debug: roborock.0 (238444) dps debug: {"id":6744,"result":{"ssid":"xxx","ip":"xxx","mac":"xxx","bssid":"xxx","rssi":-74}}
        2023-06-26 23:22:35.200 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.201 - debug: roborock.0 (238444) getParameter: get_server_timer
        2023-06-26 23:22:35.203 - debug: roborock.0 (238444) getParameter: get_timer
        2023-06-26 23:22:35.209 - debug: roborock.0 (238444) arch: arm64
        2023-06-26 23:22:35.210 - debug: roborock.0 (238444) platform: linux
        2023-06-26 23:22:35.210 - debug: roborock.0 (238444) System type: go2rtc_linux_arm64
        2023-06-26 23:22:35.210 - debug: roborock.0 (238444) downloadURL: https://github.com/AlexxIT/go2rtc/releases/download/v1.3.0/go2rtc_linux_arm64
        2023-06-26 23:22:35.292 - debug: roborock.0 (238444) dps debug: {"id":3748,"result":[]}
        2023-06-26 23:22:35.293 - debug: roborock.0 (238444) Length of message queue: 3
        2023-06-26 23:22:35.294 - debug: roborock.0 (238444) get_timer: []
        2023-06-26 23:22:35.323 - debug: roborock.0 (238444) dps debug: {"id":8582,"result":[142445,1446932500,213,[1687697937,1687697190,1687697047,1687693877,1687689826,1687553443,1687459150,1687458939,1687456670,1687360383,1687350295,1687350205,1687347579,1687347457,1687327994,1687327943,1687001665,1687001643,1687000187,1687000139]]}
        2023-06-26 23:22:35.324 - debug: roborock.0 (238444) Length of message queue: 2
        2023-06-26 23:22:35.330 - debug: roborock.0 (238444) dps debug: {"id":6801,"result":[["1674918037884","off",0]]}
        2023-06-26 23:22:35.331 - debug: roborock.0 (238444) Length of message queue: 2
        2023-06-26 23:22:35.332 - debug: roborock.0 (238444) get_server_timer: [["1674918037884","off",0]]
        2023-06-26 23:22:35.365 - debug: roborock.0 (238444) dps debug: {"id":6865,"result":[[1687697937,1687697980,17,0,0,0,2,3,43]]}
        2023-06-26 23:22:35.365 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.403 - debug: roborock.0 (238444) dps debug: {"id":3146,"result":[[1687697190,1687697690,467,4140000,0,1,2,3,56]]}
        2023-06-26 23:22:35.404 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.440 - debug: roborock.0 (238444) dps debug: {"id":4690,"result":[[1687697047,1687697164,11,0,0,0,2,3,43]]}
        2023-06-26 23:22:35.441 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.478 - debug: roborock.0 (238444) dps debug: {"id":7231,"result":[[1687693877,1687694797,920,7920000,0,1,2,3,56]]}
        2023-06-26 23:22:35.478 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.530 - debug: roborock.0 (238444) dps debug: {"id":1262,"result":[[1687689826,1687691139,1313,11927500,0,1,2,3,56]]}
        2023-06-26 23:22:35.530 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.566 - debug: roborock.0 (238444) dps debug: {"id":2131,"result":[[1687553443,1687553807,364,3632500,0,1,2,3,56]]}
        2023-06-26 23:22:35.566 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.602 - debug: roborock.0 (238444) dps debug: {"id":7598,"result":[[1687459150,1687459497,347,3500000,0,1,2,3,56]]}
        2023-06-26 23:22:35.603 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.637 - debug: roborock.0 (238444) dps debug: {"id":4974,"result":[[1687458939,1687459104,165,2345000,0,1,2,2,54]]}
        2023-06-26 23:22:35.638 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.673 - debug: roborock.0 (238444) dps debug: {"id":2421,"result":[[1687456670,1687457171,501,7605000,0,1,2,2,54]]}
        2023-06-26 23:22:35.674 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.713 - debug: roborock.0 (238444) dps debug: {"id":9650,"result":[[1687360383,1687361318,935,7957500,0,1,2,3,56]]}
        2023-06-26 23:22:35.714 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.757 - debug: roborock.0 (238444) dps debug: {"id":8908,"result":[[1687350295,1687350742,447,4015000,0,1,2,3,56]]}
        2023-06-26 23:22:35.758 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.800 - debug: roborock.0 (238444) exePath: /opt/iobroker/node_modules/iobroker.roborock/lib/go2rtc/go2rtc_linux_arm64
        2023-06-26 23:22:35.852 - debug: roborock.0 (238444) Made ./lib/go2rtc/go2rtc_linux_arm64 executable
        2023-06-26 23:22:35.856 - debug: roborock.0 (238444) dps debug: {"id":5212,"result":[[1687350205,1687350239,27,0,0,0,2,3,43]]}
        2023-06-26 23:22:35.856 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.876 - debug: roborock.0 (238444) Killing process with pid 108986
        2023-06-26 23:22:35.909 - debug: roborock.0 (238444) dps debug: {"id":7897,"result":[[1687347579,1687347998,419,4015000,0,1,2,3,56]]}
        2023-06-26 23:22:35.910 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.945 - debug: roborock.0 (238444) dps debug: {"id":9066,"result":[[1687347457,1687347488,31,0,0,0,2,3,62]]}
        2023-06-26 23:22:35.946 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:35.982 - debug: roborock.0 (238444) dps debug: {"id":9974,"result":[[1687327994,1687329343,1349,11975000,0,1,2,3,56]]}
        2023-06-26 23:22:35.984 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:36.019 - debug: roborock.0 (238444) homedata successfully updated
        2023-06-26 23:22:36.028 - debug: roborock.0 (238444) dps debug: {"id":1076,"result":[[1687327943,1687327974,31,0,0,0,2,3,62]]}
        2023-06-26 23:22:36.029 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:36.076 - debug: roborock.0 (238444) dps debug: {"id":7966,"result":[[1687001665,1687002334,669,11760000,0,1,2,3,56]]}
        2023-06-26 23:22:36.078 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:36.126 - debug: roborock.0 (238444) dps debug: {"id":4167,"result":[[1687001643,1687001643,0,0,0,0,2,3,43]]}
        2023-06-26 23:22:36.127 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:36.176 - debug: roborock.0 (238444) dps debug: {"id":8553,"result":[[1687000187,1687001470,1283,11840000,0,1,2,3,56]]}
        2023-06-26 23:22:36.176 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:36.217 - debug: roborock.0 (238444) dps debug: {"id":9486,"result":[[1687000139,1687000170,31,0,0,0,2,3,62]]}
        2023-06-26 23:22:36.217 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:22:36.957 - debug: roborock.0 (238444) dps debug: {"id":1401,"result":["ok"]}
        2023-06-26 23:22:36.958 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:22:36.959 - debug: roborock.0 (238444) getParameter: get_room_mapping
        2023-06-26 23:22:36.972 - debug: roborock.0 (238444) dps debug: {"id":67,"result":["ok"]}
        2023-06-26 23:22:36.994 - debug: roborock.0 (238444) dps debug: {"id":1546,"result":[{"msg_ver":2,"msg_seq":42,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}]}
        2023-06-26 23:22:36.994 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:22:37.030 - debug: roborock.0 (238444) dps debug: {"id":6789,"result":[[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]}
        2023-06-26 23:22:37.031 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:22:37.032 - debug: roborock.0 (238444) All mapped rooms: [[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]
        2023-06-26 23:22:37.032 - debug: roborock.0 (238444) Mapped room matched: 4526290 with name: Gäste WC
        2023-06-26 23:22:37.033 - debug: roborock.0 (238444) Mapped room matched: 4526403 with name: Wohnzimmer
        2023-06-26 23:22:37.034 - debug: roborock.0 (238444) Mapped room matched: 4517900 with name: Küche
        2023-06-26 23:22:37.034 - debug: roborock.0 (238444) Mapped room matched: 4524523 with name: Flur
        2023-06-26 23:23:34.133 - debug: roborock.0 (238444) Latest data requested
        2023-06-26 23:23:34.136 - debug: roborock.0 (238444) getParameter: get_status
        2023-06-26 23:23:34.252 - debug: roborock.0 (238444) dps debug: {"id":6187,"result":[{"msg_ver":2,"msg_seq":72,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}]}
        2023-06-26 23:23:34.253 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:23:34.254 - debug: roborock.0 (238444) get_status: {"msg_ver":2,"msg_seq":72,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}
        2023-06-26 23:23:34.261 - debug: roborock.0 (238444) getParameter: get_room_mapping
        2023-06-26 23:23:34.325 - debug: roborock.0 (238444) dps debug: {"id":7965,"result":[{"msg_ver":2,"msg_seq":73,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}]}
        2023-06-26 23:23:34.326 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:23:34.330 - debug: roborock.0 (238444) dps debug: {"id":115,"result":["ok"]}
        2023-06-26 23:23:34.404 - debug: roborock.0 (238444) dps debug: {"id":8299,"result":[[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]}
        2023-06-26 23:23:34.405 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:23:34.406 - debug: roborock.0 (238444) All mapped rooms: [[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]
        2023-06-26 23:23:34.406 - debug: roborock.0 (238444) Mapped room matched: 4526290 with name: Gäste WC
        2023-06-26 23:23:34.407 - debug: roborock.0 (238444) Mapped room matched: 4526403 with name: Wohnzimmer
        2023-06-26 23:23:34.407 - debug: roborock.0 (238444) Mapped room matched: 4517900 with name: Küche
        2023-06-26 23:23:34.407 - debug: roborock.0 (238444) Mapped room matched: 4524523 with name: Flur
        2023-06-26 23:23:34.408 - debug: roborock.0 (238444) getParameter: get_consumable
        2023-06-26 23:23:34.443 - debug: roborock.0 (238444) dps debug: {"id":1658,"result":[{"main_brush_work_time":143990,"side_brush_work_time":143990,"filter_work_time":143990,"filter_element_work_time":11508,"sensor_dirty_time":4105}]}
        2023-06-26 23:23:34.443 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:23:34.444 - debug: roborock.0 (238444) Consumables of robot: [{"main_brush_work_time":143990,"side_brush_work_time":143990,"filter_work_time":143990,"filter_element_work_time":11508,"sensor_dirty_time":4105}]
        2023-06-26 23:23:34.447 - debug: roborock.0 (238444) getParameter: get_network_info
        2023-06-26 23:23:34.508 - debug: roborock.0 (238444) dps debug: {"id":3812,"result":{"ssid":"xxx","ip":"xxx","mac":"xxx","bssid":"xxx","rssi":-74}}
        2023-06-26 23:23:34.508 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:23:34.509 - debug: roborock.0 (238444) getParameter: get_server_timer
        2023-06-26 23:23:34.510 - debug: roborock.0 (238444) getParameter: get_timer
        2023-06-26 23:23:34.545 - debug: roborock.0 (238444) dps debug: {"id":8921,"result":[["1674918037884","off",0]]}
        2023-06-26 23:23:34.545 - debug: roborock.0 (238444) Length of message queue: 2
        2023-06-26 23:23:34.546 - debug: roborock.0 (238444) get_server_timer: [["1674918037884","off",0]]
        2023-06-26 23:23:34.558 - debug: roborock.0 (238444) dps debug: {"id":7480,"result":[]}
        2023-06-26 23:23:34.558 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:23:34.559 - debug: roborock.0 (238444) get_timer: []
        2023-06-26 23:23:35.940 - debug: roborock.0 (238444) homedata successfully updated
        2023-06-26 23:23:36.076 - debug: roborock.0 (238444) dps debug: {"id":2201,"result":["ok"]}
        2023-06-26 23:23:36.077 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:23:36.077 - debug: roborock.0 (238444) getParameter: get_room_mapping
        2023-06-26 23:23:36.121 - debug: roborock.0 (238444) dps debug: {"id":7722,"result":[{"msg_ver":2,"msg_seq":80,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}]}
        2023-06-26 23:23:36.122 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:23:36.190 - debug: roborock.0 (238444) dps debug: {"id":1217,"result":[[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]}
        2023-06-26 23:23:36.190 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:23:36.191 - debug: roborock.0 (238444) All mapped rooms: [[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]
        2023-06-26 23:23:36.191 - debug: roborock.0 (238444) Mapped room matched: 4526290 with name: Gäste WC
        2023-06-26 23:23:36.192 - debug: roborock.0 (238444) Mapped room matched: 4526403 with name: Wohnzimmer
        2023-06-26 23:23:36.192 - debug: roborock.0 (238444) Mapped room matched: 4517900 with name: Küche
        2023-06-26 23:23:36.193 - debug: roborock.0 (238444) Mapped room matched: 4524523 with name: Flur
        2023-06-26 23:24:34.133 - debug: roborock.0 (238444) Latest data requested
        2023-06-26 23:24:34.134 - debug: roborock.0 (238444) getParameter: get_status
        2023-06-26 23:24:34.217 - debug: roborock.0 (238444) dps debug: {"id":3421,"result":[{"msg_ver":2,"msg_seq":111,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}]}
        2023-06-26 23:24:34.220 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:24:34.222 - debug: roborock.0 (238444) get_status: {"msg_ver":2,"msg_seq":111,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}
        2023-06-26 23:24:34.227 - debug: roborock.0 (238444) getParameter: get_room_mapping
        2023-06-26 23:24:34.272 - debug: roborock.0 (238444) dps debug: {"id":6719,"result":[{"msg_ver":2,"msg_seq":112,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}]}
        2023-06-26 23:24:34.273 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:24:34.363 - debug: roborock.0 (238444) dps debug: {"id":5414,"result":[[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]}
        2023-06-26 23:24:34.364 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:24:34.365 - debug: roborock.0 (238444) All mapped rooms: [[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]
        2023-06-26 23:24:34.365 - debug: roborock.0 (238444) Mapped room matched: 4526290 with name: Gäste WC
        2023-06-26 23:24:34.366 - debug: roborock.0 (238444) Mapped room matched: 4526403 with name: Wohnzimmer
        2023-06-26 23:24:34.366 - debug: roborock.0 (238444) Mapped room matched: 4517900 with name: Küche
        2023-06-26 23:24:34.367 - debug: roborock.0 (238444) Mapped room matched: 4524523 with name: Flur
        2023-06-26 23:24:34.367 - debug: roborock.0 (238444) getParameter: get_consumable
        2023-06-26 23:24:34.404 - debug: roborock.0 (238444) dps debug: {"id":9665,"result":[{"main_brush_work_time":143990,"side_brush_work_time":143990,"filter_work_time":143990,"filter_element_work_time":11508,"sensor_dirty_time":4105}]}
        2023-06-26 23:24:34.406 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:24:34.407 - debug: roborock.0 (238444) Consumables of robot: [{"main_brush_work_time":143990,"side_brush_work_time":143990,"filter_work_time":143990,"filter_element_work_time":11508,"sensor_dirty_time":4105}]
        2023-06-26 23:24:34.408 - debug: roborock.0 (238444) getParameter: get_network_info
        2023-06-26 23:24:34.472 - debug: roborock.0 (238444) dps debug: {"id":5738,"result":{"ssid":"xxx","ip":"xxx","mac":"xxx","bssid":"xxx","rssi":-74}}
        2023-06-26 23:24:34.473 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:24:34.474 - debug: roborock.0 (238444) getParameter: get_server_timer
        2023-06-26 23:24:34.475 - debug: roborock.0 (238444) getParameter: get_timer
        2023-06-26 23:24:34.512 - debug: roborock.0 (238444) dps debug: {"id":3571,"result":[["1674918037884","off",0]]}
        2023-06-26 23:24:34.513 - debug: roborock.0 (238444) Length of message queue: 2
        2023-06-26 23:24:34.513 - debug: roborock.0 (238444) get_server_timer: [["1674918037884","off",0]]
        2023-06-26 23:24:34.523 - debug: roborock.0 (238444) dps debug: {"id":9998,"result":[]}
        2023-06-26 23:24:34.524 - debug: roborock.0 (238444) Length of message queue: 1
        2023-06-26 23:24:34.524 - debug: roborock.0 (238444) get_timer: []
        2023-06-26 23:24:35.930 - debug: roborock.0 (238444) homedata successfully updated
        2023-06-26 23:24:36.043 - debug: roborock.0 (238444) dps debug: {"id":5525,"result":["ok"]}
        2023-06-26 23:24:36.044 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:24:36.044 - debug: roborock.0 (238444) getParameter: get_room_mapping
        2023-06-26 23:24:36.080 - debug: roborock.0 (238444) dps debug: {"id":5887,"result":[{"msg_ver":2,"msg_seq":119,"state":8,"battery":100,"clean_time":17,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":1,"adbumper_status":[0,0,0]}]}
        2023-06-26 23:24:36.081 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:24:36.122 - debug: roborock.0 (238444) dps debug: {"id":5171,"result":[[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]}
        2023-06-26 23:24:36.122 - debug: roborock.0 (238444) Length of message queue: 0
        2023-06-26 23:24:36.123 - debug: roborock.0 (238444) All mapped rooms: [[16,"4526290"],[17,"4526403"],[18,"4517900"],[19,"4524523"]]
        2023-06-26 23:24:36.123 - debug: roborock.0 (238444) Mapped room matched: 4526290 with name: Gäste WC
        2023-06-26 23:24:36.124 - debug: roborock.0 (238444) Mapped room matched: 4526403 with name: Wohnzimmer
        2023-06-26 23:24:36.124 - debug: roborock.0 (238444) Mapped room matched: 4517900 with name: Küche
        2023-06-26 23:24:36.125 - debug: roborock.0 (238444) Mapped room matched: 4524523 with name: Flur
        2023-06-26 23:24:54.454 - info: host.ioBroker-RasPi "system.adapter.roborock.0" disabled
        2023-06-26 23:24:54.456 - info: host.ioBroker-RasPi stopInstance system.adapter.roborock.0 (force=false, process=true)
        2023-06-26 23:24:54.462 - info: roborock.0 (238444) Got terminate signal TERMINATE_YOURSELF
        2023-06-26 23:24:54.464 - info: roborock.0 (238444) terminating
        2023-06-26 23:24:54.465 - debug: roborock.0 (238444) Plugin sentry destroyed
        2023-06-26 23:24:54.466 - info: roborock.0 (238444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-06-26 23:24:54.550 - info: host.ioBroker-RasPi stopInstance system.adapter.roborock.0 send kill signal
        2023-06-26 23:24:54.967 - info: roborock.0 (238444) terminating
        2023-06-26 23:24:55.059 - info: host.ioBroker-RasPi instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          jahnbesJ Offline
          jahnbesJ Offline
          jahnbes
          #730
          @copystring Vielleicht bin doch ich es, der sich irrt - so war es. Ich habe zwar die log-Ausschriften nicht verstanden, den -meinen- Fehler aber trotzdem gefunden. Es lag nicht am Adapter.
          Gruß Bert.
          • I Offline
            I Offline
            Io-Alex
            #731
            @copystring
            Hallo
            Ist geplant demnächst den roborock s7 max ultra zu unterstützen?
            Mit freundlichen Grüßen
            copystringC jona7oJ 3 Antworten Letzte Antwort
            • I Io-Alex
              @copystring
              Hallo
              copystringC Offline
              copystringC Offline
              copystring
              #732
              @io-alex Ja, kommt bald. Habe aktuell extrem Zeitmangel.
              • I Io-Alex
                @copystring
                Hallo
                jona7oJ Offline
                jona7oJ Offline
                jona7o
                #733
                @io-alex @copystring
                Erstmal danke für die tolle Arbeit. Bei mir sieht das aktuell nach Installation des dev Stands so aus im Log:
                roborock.0
                2023-06-30 00:00:06.106	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                roborock.0
                2023-06-30 00:00:06.101	info	terminating
                roborock.0
                2023-06-30 00:00:06.069	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module './undefined'Require stack:- /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js- /opt/iobroker/node_modules/iobroker.roborock/main.js
                roborock.0
                2023-06-30 00:00:06.067	error	Error: Cannot find module './undefined'Require stack:- /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js- /opt/iobroker/node_modules/iobroker.roborock/main.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1072:15) at Function.Module._load (node:internal/modules/cjs/loader:925:27) at Module.require (node:internal/modules/cjs/loader:1139:19) at require (node:internal/modules/helpers:121:18) at new vacuum (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:47:31) at /opt/iobroker/node_modules/iobroker.roborock/main.js:195:28
                roborock.0
                2023-06-30 00:00:06.056	error	unhandled promise rejection: Cannot find module './undefined'Require stack:- /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js- /opt/iobroker/node_modules/iobroker.roborock/main.js
                roborock.0
                2023-06-30 00:00:06.054	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                roborock.0
                2023-06-30 00:00:04.585	error	The model roborock.vacuum.a65 is not supported. Get in touch with the dev to get this robot supported.
                roborock.0
                2023-06-30 00:00:04.580	info	MQTT initialized
                Liegt das bei mir auch am s7 max ultra oder habe ich noch ein anderes Problem? Eigentlich hätte ich auch noch einen normalen S7 in meinem Account.
                • I Io-Alex
                  @copystring
                  Hallo
                  copystringC Offline
                  copystringC Offline
                  copystring
                  #734
                  @io-alex said in Roborock Adapter tester gesucht:
                  @copystring
                  Hallo
                  Ist eingebaut. Bitte die dev testen und ein Debuglog hier anhängen: https://github.com/copystring/ioBroker.roborock/tree/dev
                  G D 2 Antworten Letzte Antwort
                    @copystring
                    Hallo
                    guergen
                    #735
                    Moin, ich wollte den Adapter mal testen, wo muss ich mich denn anmelden? die von mir gefundene adresse euiot.irgendwas scheint nicht zu existieren?
                    In der Doku finde ich nix...
                    Hab einen S5 vom Xiaomi
                      @copystring
                      Hallo
                      Dimi
                      #736
                      @copystring
                      Hi, das oben beschriebene Verhalten hast du dir noch nicht angeschaut oder? Denn auch mit der neuen dev läd er die Karte minütlich neu. Ich meine jetzt aber nicht die Kartendarstellung im Adapter sondern die Karte in der app bzw. die Karte im Roboter. Es ist so als ob er bei jedem aktualisierungsintervall (60s) das Stockwerk neu läd auch wenn sich das Stockwerk nicht geändert hat. Deaktiviere ich den Adapter wird es nicht mehr getriggert und die Karte und somit die Position des Saugers bleibt erhalten. Ich dachte schon der Sauger hat ein Problem und kann sich seine Position nicht mehr merken. Ich will dich da nicht stressen. Hast ja geschrieben das du Zeitmangel hast. Sollte er eine Info sein.
                      • D Dimi
                        @copystring
                        copystringC Offline
                        copystringC Offline
                        copystring
                        #737
                        @dimi Nein, konnte ich mir nicht angucken. Wie oben bereits gesagt, wollte ich wissen, ab wann es nicht mehr ging. Darauf bist du nicht eingegangen.
                          Dimi
                          #738
                          @copystring
                          Doch hatte was dazu geschrieben:
                          • D Dimi
                            @copystring
                            copystringC Offline
                            copystringC Offline
                            copystring
                            #739
                            @dimi Naja, das würde keinen Sinn ergeben. Nur weil ein Roboter dazugekommen ist, hat sich das Verhalten der Karte nicht verändert.
                            Wenn du dir aber nicht sicher bist, müsstest du es ohnehin ausprobieren.
                            Hier sind alle Änderungen der: https://github.com/copystring/ioBroker.roborock/commits/dev.
                            Du kannst jede Änderung mit der rechten Maustaste anklicken und den Link kopieren. Über den Link dann den Adapter installieren und so herausfinden, welche Version lief.
                              Dimi
                              #740
                              @copystring
                              Ah cool wusste ich nicht. Werde ich testen und dir dann berichten.
                                Dimi
                                schrieb am zuletzt editiert von Dimi
                                #741
                                @copystring
                                Also jetzt bin ich verwirrt. Ich bin jetzt bis zu der Version vom 28 März zurück und das Verhalten ist das gleiche. Kann es sein das es schon immer so war und ich es nicht gemerkt habe? Aber was ich nicht verstehe ist, warum triggert der Adpater bei jedem Aktualisierung (Intervall 60) ein Kartenspeichern und Laden des gleichen Stockwerks. Das hat halt den Effekt das der Sauger seine Position verliert. Beispiel: Ich lasse per Pin&Go den Sauger irgednwo hinfahren. Er stoppt. Wenn der Adapter aktualisiert, zeigt mir die App auf dem Handy das der Sauger wieder auf der Ladestation ist. Habe nur ich das Verhalten? Ein Kartenspeichern sollte nur dann statt finden wenn man das Stockwerk manuell auswählt oder wenn der Sauger auf die Ladestation fährt. So passiert es wenn der Adapter nicht aktiv ist.
                                Nachtrag: Also ich habe jetzt auch mal die main Version installiert. Das Verhalten ist da das gleiche. Kann es sein das Roborock was an der API geändert hat? Alles sehr komisch.
                                • D Dimi
                                  @copystring
                                  copystringC Offline
                                  copystringC Offline
                                  copystring
                                  #742
                                  @dimi Ich habe den gleichen Saugroboter wie du. S6 MaxV und kann das Problem mit der aktuellen dev nicht reproduzieren.
                                  Der Adapter hat übrigens gar keine Option eingebaut, Karten zu speichern. Nur das Laden und Lesen ist implementiert.
                                  Aber ich sehe, dass dein System auf einem arm64 System läuft. Ist das ein RPi?
                                  Teste doch mal ioBroker mit dem Adapter auf einem Windows System. Tritt da der Fehler auch auf?
                                  • copystringC Offline
                                    copystringC Offline
                                    copystring
                                    schrieb am zuletzt editiert von copystring
                                    #743
                                    Die letzten Wochen war ich damit beschäftigt, wie man das Mitschneiden des Datenverkehrs realisieren könnte (daher der Zeitmangel :) )
                                    Dies ging vor einiger Zeit mal direkt über ein Subscribe im MQTT Client des Adapters.
                                    Anscheinen hat Roborock das aber mitbekommen, und die Möglichkeit gesperrt.
                                    Mit der neuesten dev ist jetzt möglich zusammen mit mitmproxy den Datenverkehr dann doch wieder mitzuschneiden.
                                    Das funktioniert folgendermaßen:
                                    • Die aktuelle dev installieren (https://github.com/copystring/ioBroker.roborock/tree/dev)
                                    • Auf dem selben PC, auf dem ioBroker läuft, mitmproxy wie folgt installieren:
                                      -- pipx install mitmproxy
                                      -- pipx inject mitmproxy websocket
                                      -- pipx inject mitmproxy websocket-client
                                    • Und so starten: mitmweb.exe --listen-port 9090 --web-port 9091 --mode wireguard -s C:\iobroker\node_modules\ioBroker.roborock\lib\sniffing\mitmproxy_roborock.py
                                      ggf. den Pfad von mitmproxy_roborock.py auf eure Installation anpassen.
                                    • Anschließend öffnet sich im Browser das Fenster von mitmproxy und ein QR Code. Darüber Wireguard am Handy einrichten. Ihr benötigt dann noch das entsprechende Zertifikat von mitmproxy: https://docs.mitmproxy.org/stable/concepts-certificates/. Bitte fragt mich nicht, wie das zu installieren ist. Ihr müsst euch auskennen!
                                    • Dann Wireguard auf dem Handy aktivieren und die Roborock App öffnen.
                                    Das sieht dann z.B. so aus:
                                    Dadurch ist nun möglich, auch neue und unbekannte Befehle mitzuschneiden, welche direkt von der App kommen.
                                      Dimi
                                      #744
                                      @copystring
                                      Ja es läuft auf einem RPi 4 mit 64 Bit. Das laden würde ja schon aureichen um die Karte im Roboter erneut zu laden. Ich bin mir sicher das war am Anfang nicht so. Könnte es sein das es was mit der aktualisierung des js-controllers zu tun hat? Der wurde letztens auf die Version 5.0.5 aktualisiert. Bin im beta Repository.
                                      Wenn ich die Tage Zeit finde werde ich mal den iobroker mal auf Windows installieren um es damit zu testen.
                                      Nachtrag:
                                      Ich konnte das Problem gerade lösen. Ich habe lediglich einen raum saugen lassen nachdem der Adapter neu instelliert wurde. Danach wird die Karte auch nicht ständig neu geladen. Anscheinend habe ich unbewusst immer den Sauger einen raum saugen lassen, so dass ich das Problem nie hatte. Es reicht wohl nicht aus nur den Befehl Pin&Go auszuführen.
                                      • D Dimi
                                        @copystring
                                        Nachtrag:
                                        copystringC Offline
                                        copystringC Offline
                                        copystring
                                        #745
                                        @dimi Verstehe nicht so ganz was du geschrieben hast, aber toll, dass du es lösen konntest. 👍
                                          copystringC Offline
                                          copystring
                                          #746
                                          Wenn mit der aktuellen dev keine gravierenden Fehler auftreten, wird dies der nächste Release werden.
                                          Wer mag, kann testen und die Fehler auf GitHub erstellen.
