  4. [Javascript] Midas (Aquatemp) Poolheizung
359 Beiträge 25 Kommentatoren 107.0k Aufrufe 25 Beobachtet
  • P PietNB
    @oxident Prima das es dir keine Ruhe gelassen hat👏 .
    Gute Nachrichten. Ein erster Test zeigt das jetzt schonmal die Verbindung steht. Jetzt muss ich noch ein paar Parameter anpassen die bei meiner Pumpe anders sind. Der Parameter "Mode" wird schonmal aktualisiert von "off" auf "heat". Den Rest probiere ich heute Abend bestimmt noch aus. Ein paar Fehlermeldungen stehen auch noch an.
    javascript.0
    2023-06-28 19:34:05.796	error	at processImmediate (internal/timers.js:464:21)
    javascript.0
    2023-06-28 19:34:05.796	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5708:41)
    javascript.0
    2023-06-28 19:34:05.796	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:596:29)
    javascript.0
    2023-06-28 19:34:05.796	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1214:38)
    javascript.0
    2023-06-28 19:34:05.796	error	at Object.<anonymous> (script.js.Poolheizung:825:5)
    javascript.0
    2023-06-28 19:34:05.795	error	at updateDeviceSetTemp (script.js.Poolheizung:716:36)
    javascript.0
    2023-06-28 19:34:05.793	error	Error in callback: TypeError: Cannot read property 'toString' of null
    javascript.0
    2023-06-28 19:34:05.755	warn	Read-only state "0_userdata.0.Poolheizung.rawJSON" has been written without ack-flag with value "null"
    javascript.0
    2023-06-28 19:34:05.755	warn	Read-only state "0_userdata.0.Poolheizung.coilTemp" has been written without ack-flag with value "null"
    javascript.0
    2023-06-28 19:34:05.754	warn	Read-only state "0_userdata.0.Poolheizung.suctionTemp" has been written without ack-flag with value "null"
    javascript.0
    2023-06-28 19:34:05.750	warn	Read-only state "0_userdata.0.Poolheizung.tempOut" has been written without ack-flag with value "null"
    javascript.0
    2023-06-28 19:34:05.742	warn	Read-only state "0_userdata.0.Poolheizung.tempIn" has been written without ack-flag with value "null"
    javascript.0
    2023-06-28 19:34:05.740	warn	Read-only state "0_userdata.0.Poolheizung.errorLevel" has been written without ack-flag with value "null"
    javascript.0
    2023-06-28 19:34:05.725	warn	Read-only state "0_userdata.0.Poolheizung.ambient" has been written without ack-flag with value "null"
    javascript.0
    2023-06-28 19:34:05.575	info	script.js.Poolheizung: registered 3 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    javascript.0
    2023-06-28 19:34:05.541	info	script.js.Poolheizung: erstelle Objekte
    javascript.0
    2023-06-28 19:34:05.514	info	Start javascript script.js.Poolheizung
    javascript.0
    2023-06-28 19:34:02.824	info	Stop script script.js.Poolheizung
    Mir ist aufgefallen das die App jetzt bei Anmeldung jetzt die Meldung "Token ist abgelaufen" meldet. Um die App zu nutzen muss ich mich neu anmelden. Wenn die App dann auf ist kommt immer sporadisch eine Einblendung "IOT irgendwas...?
    Danke nochmal..
    PietNB
    #134
    @pietnb Hmm...so stark unterscheiden sich die WP´s nicht. Meine Poolsana Prime hat die gleichen "T-Parameter" wie deine. Es fehlt nur T-17.
    Eigentlich müsste die Werte doch dann angezeigt werden?😎
    • O Offline
      O Offline
      oxident
      #135
      Cool, das ist doch schonmal ein Lichtblick. Ich glaube, die obigen Fehlermeldungen sollten verschwinden, sobald richtige Werte kommen.
      Das mit der App könnte etwas mit dem "Keep-Alive" zu tun haben. Das habe ich noch nicht ganz verstanden, aber wir stehen ja noch am Anfang.
      Interessant wäre hauptsächlich erstmal der DP "rawJSON". Wird der bei Dir schon befüllt?
      Was die Parameterzuordnungen angeht, da müssen wir uns mal etwas überlegen damit es für alle funktioniert ;-)
      Bis dahin bist Du natürlich herzlich eingeladen, wild "herumzuhacken" :-D
      P 1 Antwort Letzte Antwort
      • O oxident
        PietNB
        schrieb am zuletzt editiert von PietNB
        #136
        @oxident Bei DP "rawJSON" steht bei mir das:
        [{"value":"0","code":"Power"},{"value":"1","code":"Mode"},{"value":"0","code":"Manual-mute"},{"value":"0","code":"T01"},{"value":"0","code":"T02"},{"value":"0","code":"2074"},{"value":"0","code":"2075"},{"value":"0","code":"2076"},{"value":"0","code":"2077"},{"value":"0","code":"H03"},{"value":"0","code":"Set_Temp"},{"value":"8.0","code":"R08"},{"value":"35.0","code":"R09"},{"value":"15.0","code":"R10"},{"value":"40.0","code":"R11"},{"value":"27.0","code":"R01"},{"value":"27.0","code":"R02"},{"value":"27.0","code":"R03"},{"value":"0","code":"T03"},{"value":"0","code":"1158"},{"value":"0","code":"1159"},{"value":"114","code":"F17"},{"value":"1","code":"H02"},{"value":"0","code":"T04"},{"value":"0","code":"T05"},{"value":"0","code":"T07"},{"value":"0","code":"T14"},{"value":"0","code":"T17"}]
        Ich denke ein paar Werte sind drin (value?) aber einige T03, T04 usw. sind noch leer.
        O 2 Antworten Letzte Antwort
        • P PietNB
          O Offline
          O Offline
          oxident
          #137
          @pietnb Komisch. Du könntest auf die Schnelle mal testen, ob sich etwas ändert, wenn Du alle Vorkommnisse von z. B. T01 in T1 änderst. Einfach "stumpf" über Suchen & Ersetzen.
          Klingt unlogisch, scheint aber bei manchen Modellen wohl so zu sein.
          • P PietNB
            O Offline
            O Offline
            oxident
            #138
            @pietnb Wir könnten es auch auf die "harte Tour" versuchen. Im Github-Repo für das HA-Projekt gibt es diese kurze Anleitung, zumindest für Android-Nutzer: https://github.com/radical-squared/aquatemp#data-from-mobile-app
            Traust Du Dir das zu? ;-)
            P 2 Antworten Letzte Antwort
            • O oxident
              PietNB
              #139
              @oxident Ich werde beide Varianten heute Abend mal testen und berichten. Danke
              • O oxident
                PietNB
                #140
                @oxident Variante 1 T01 in T1 zu tauschen, hat wohl funktioniert. Leider werden mir die Werte nur in der "rawJSON" angezeigt:
                [{"value":"0","code":"Power"},{"value":"1","code":"Mode"},{"value":"0","code":"Manual-mute"},{"value":"17.0","code":"T1"},{"value":"24.5","code":"T2"},{"value":"0","code":"2074"},{"value":"0","code":"2075"},{"value":"0","code":"2076"},{"value":"0","code":"2077"},{"value":"0","code":"H03"},{"value":"0","code":"Set_Temp"},{"value":"8.0","code":"R08"},{"value":"35.0","code":"R09"},{"value":"15.0","code":"R10"},{"value":"40.0","code":"R11"},{"value":"27.0","code":"R01"},{"value":"27.0","code":"R02"},{"value":"27.0","code":"R03"},{"value":"25.0","code":"T3"},{"value":"0","code":"1158"},{"value":"0","code":"1159"},{"value":"114","code":"F17"},{"value":"1","code":"H02"},{"value":"23.0","code":"T4"},{"value":"23.0","code":"T5"},{"value":"0","code":"T07"},{"value":"0","code":"T14"},{"value":"0","code":"T17"}]
                Ich habe zum Test mal alle Werte T01, T02, T03, T04, T05 geändert. Jetzt stehen da überall plausible Werte aber leider noch nicht bei den Objekten. Muss ich da auch noch was anpassen?
                • P PietNB
                  PietNB
                  #141
                  Korrektur: Jetzt wird der Wert "Umgebungstemperatur" T5 auch bei den Objekten angezeigt. Leider nur der eine Wert😒
                  O 1 Antwort Letzte Antwort
                  • P PietNB
                    O Offline
                    O Offline
                    oxident
                    #142
                    @pietnb Könntest Du mal in Zeile 193 die // am Anfang entfernen?
                                //log(JSON.stringify(response));
                    Dann müsstest Du im Log u.a. die Rückgabe der device_id sehen. Die bräuchte ich mal, damit wir für die verschiedenen Heizungstypen die Zuordnung unterscheiden können.
                    Ich denke, Deine Parameternamen sind nämlich diese hier: https://github.com/radical-squared/aquatemp/blob/Custom-component/custom_components/aqua_temp/parameters/1442284873216843776.json
                    • F Offline
                      flyer99
                      #143
                      Also bei mir funktioniert alles noch einwandfrei ... Ich hätte aber mal ne andere Frage (ich weiß das du gerade ein wenig arbeit hast, somit pressiert das auch nicht ..)
                      Der Wert "Ansauglufttemperatur" fällt bei mir im Betrieb der WP auf z.B. 4,0°C ab .... das kann doch dann nicht die Ansauglufttemperatur sein ? Ist das evtl. die Temperatur der Luft nach dem Kompressor ??
                      Wie gesagt, hat keine Eile ....
                      Raspberry 4, Bullseye, mit dem Raspi 7" Touchdisplay was ioBroker betrifft ...
                      • O oxident
                        PietNB
                        #144
                        @oxident Die device_id ist 1640588423515365376. Kann man aus der AquaTemp App auslesen.
                        Ich hatte die device_id bereits in der Liste im Script ergänzt, habe diese aber jetzt gelöscht und auf einmal waren die meisten Werte auch da😁
                        Hier aber trotzdem der Log.
                        5:24:17.895	info	javascript.0 (1373) Stop script script.js.Poolheizung
                        15:24:17.908	info	javascript.0 (1373) Start javascript script.js.Poolheizung
                        15:24:17.936	info	javascript.0 (1373) script.js.Poolheizung: erstelle Objekte
                        15:24:17.945	info	javascript.0 (1373) script.js.Poolheizung: registered 3 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                        15:24:18.251	info	javascript.0 (1373) script.js.Poolheizung: {"statusCode":200,"body":{"sessionid":null,"error_code":"0","error_msg":"Success","error_msg_code":"","totalSize":null,"totalPage":null,"nextPage":null,"objectResult":[{"deviceType":"","device_status":"ONLINE","is_fault":false,"device_id":"1640588423515365376","productId":"1442284873216843776","deviceNickName":"Poolheizung","device_type":"","deviceCode":"0C7FEDC2A9F5","isFault":false,"deviceName":"0C7FEDC2A9F5","deviceId":"1640588423515365376","deviceStatus":"ONLINE","device_name":"0C7FEDC2A9F5","device_code":"0C7FEDC2A9F5","product_id":"1442284873216843776","model":null,"sn":null,"device_nick_name":"Poolheizung","projectId":null}],"isReusltSuc":true},"headers":{"date":"Fri, 30 Jun 2023 13:24:21 GMT","content-type":"application/json;charset=UTF-8","transfer-encoding":"chunked","connection":"close","vary":"Origin, Access-Control-Request-Method, Access-Control-Request-Headers","x-content-type-options":"nosniff","x-xss-protection":"1; mode=block","x-frame-options":"DENY"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cloud.linked-go.com:449","port":"449","hostname":"cloud.linked-go.com","hash":null,"search":null,"query":null,"pathname":"/crmservice/api/app/device/deviceList","path":"/crmservice/api/app/device/deviceList","href":"https://cloud.linked-go.com:449/crmservice/api/app/device/deviceList"},"method":"POST","headers":{"x-token":"EX9zSegfqmZAif9ekGLQXqPdgbhFN/BGYjgfyDU2bi6RfQUEUn0Pf63OFN9yQgXRqOxLXNUeG8QdwxEcodA41Q==","accept":"application/json","content-type":"application/json","content-length":148}}}
                        15:24:30.103	info	javascript.0 (1373) script.js.Poolheizung: {"statusCode":200,"body":{"sessionid":null,"error_code":"0","error_msg":"Success","error_msg_code":"","totalSize":null,"totalPage":null,"nextPage":null,"objectResult":[{"deviceType":"","device_status":"ONLINE","is_fault":false,"device_id":"1640588423515365376","productId":"1442284873216843776","deviceNickName":"Poolheizung","device_type":"","deviceCode":"0C7FEDC2A9F5","isFault":false,"deviceName":"0C7FEDC2A9F5","deviceId":"1640588423515365376","deviceStatus":"ONLINE","device_name":"0C7FEDC2A9F5","device_code":"0C7FEDC2A9F5","product_id":"1442284873216843776","model":null,"sn":null,"device_nick_name":"Poolheizung","projectId":null}],"isReusltSuc":true},"headers":{"date":"Fri, 30 Jun 2023 13:24:33 GMT","content-type":"application/json;charset=UTF-8","transfer-encoding":"chunked","connection":"close","vary":"Origin, Access-Control-Request-Method, Access-Control-Request-Headers","x-content-type-options":"nosniff","x-xss-protection":"1; mode=block","x-frame-options":"DENY"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cloud.linked-go.com:449","port":"449","hostname":"cloud.linked-go.com","hash":null,"search":null,"query":null,"pathname":"/crmservice/api/app/device/deviceList","path":"/crmservice/api/app/device/deviceList","href":"https://cloud.linked-go.com:449/crmservice/api/app/device/deviceList"},"method":"POST","headers":{"x-token":"EX9zSegfqmZAif9ekGLQXqPdgbhFN/BGYjgfyDU2bi6RfQUEUn0Pf63OFN9yQgXRqOxLXNUeG8QdwxEcodA41Q==","accept":"application/json","content-type":"application/json","content-length":148}}}
                        Hätte gedacht das meine ID auch in die Auflistung gehört?
                        • F flyer99
                          O Offline
                          O Offline
                          oxident
                          #145
                          @flyer99 Mir kam der Wert auch immer etwas komisch vor. In der App ist er als in der Tat als "Suction Temp" bezeichnet...
                          Die Umgebungstemperatur ist ja aber andererseits such vorhanden (und stimmig).
                          Hmm, bin kein Klinatechniker aber Deine Vermutung klingt logisch!
                          • P PietNB
                            O Offline
                            O Offline
                            oxident
                            #146
                            @pietnb Ich glaube, die Entwickler beim Hersteller haben selber Device- und ProductID verwechselt. Letztere ist richtig und gehört auch in die Auflistung.
                            Darauf bezieht sich auch zufälligerweise der obige GitHub-Link!
                            Werde am WE leider zu nichts kommen, aber wir schaffen das schon noch ;-)
                            • O oxident
                              PietNB
                              #147
                              @oxident Ich bekomme im "rawJSON" jetzt viele Werte angezeigt. Leider erscheinen die Werte nicht unter den Objekten? Gersten wurden T1-T4 und der Mode angezeigt. weil ich nach dem ganzen gefummel nicht mehr genau wusste was jetzt genau ich gemacht habe, habe ich nochmal alles neu gemacht. Nun sind die Werte in der Objekten bis auf Mode und Ambient Temp wieder weg???
                              [{"value":"0","code":"Power"},{"value":"1","code":"Mode"},{"value":"0","code":"Manual-mute"},{"value":"17.0","code":"T1"},{"value":"21.5","code":"T2"},{"value":"0","code":"2074"},{"value":"0","code":"2075"},{"value":"0","code":"2076"},{"value":"0","code":"2077"},{"value":"0","code":"H03"},{"value":"0","code":"Set_Temp"},{"value":"8.0","code":"R08"},{"value":"35.0","code":"R09"},{"value":"15.0","code":"R10"},{"value":"40.0","code":"R11"},{"value":"27.0","code":"R01"},{"value":"27.0","code":"R02"},{"value":"27.0","code":"R03"},{"value":"23.5","code":"T3"},{"value":"0","code":"1158"},{"value":"0","code":"1159"},{"value":"114","code":"F17"},{"value":"1","code":"H02"},{"value":"16.0","code":"T4"},{"value":"19.0","code":"T5"},{"value":"0","code":"T7"},{"value":"0","code":"T14"},{"value":"0","code":"T17"}]
                              Warum werden die Daten nicht unter den Objekten angezeigt? Ich weis nicht weiter?
                              • P PietNB
                                O Offline
                                O Offline
                                oxident
                                #148
                                @pietnb Im Code wird ja (weiter unten) dann auch die Zuordnung vorgenommen. Ich denke, da ist der Hund begraben...
                                Hoffe aber, das in den nächsten Tagen auch selber angehen zu können.
                                • O oxident
                                  PietNB
                                  #149
                                  @oxident Moin. Habe gestern noch etwas mit den Werten rumprobiert, kann aber nicht sagen was genau jetzt anders ist. Inzwischen werden fast alle unterstützten Werte angezeigt. Aktuell fehlt nur noch die "setTemp" (Solltemperatur).
                                  Hier stehen im Code ja auch die Solltemperaturen für die einzelnen Modi (R01-R03) im rawJASON. Evtl. kann man damit was anfangen?
                                  • P PietNB
                                    O Offline
                                    O Offline
                                    oxident
                                    schrieb am zuletzt editiert von oxident
                                    #150
                                    @pietnb Ich habe jetzt mal angefangen, das ein wenig "in Form" zu gießen.
                                    Vielleicht machst Du Dir lieber vorher eine Kopie Deines aktuellen Skripts ;-)
                                    // Midas Poolheizung
                                    // v0.0.8c
                                    // Changelog:
                                    // 0.0.8: Testweise Unterstützung von neu registrierten Anlagen
                                    // 0.0.7: Kleinigkeiten überarbeitet
                                    //        weitere Modelle hinzugefügt
                                    // 0.0.6: Gültigkeitsprüfung des Zertifikats deaktiviert (Dank an znyde)
                                    //        Kompatibilität mit Promo Next Modellen durch generische Product-ID (Dank an znyde)
                                    // 0.0.5: weitere Abfragewerte hinzugefügt (Kompressor- und Ansaugtemperatur)
                                    // 0.0.4: Tokenverfall jetzt 60min nach Skriptstart und nicht zu jeder vollen Stunde (Dank an dering)
                                    // 0.0.3: Datenpunkte beim Start automatisch anlegen (Dank an Andy200877)
                                    // 0.0.2: Token bei jedem Set-Vorgang prüfen und ggf. neu anfordern (Dank an dering)
                                    // ANFANG konfigurierbare Elemente -----
                                    const username = "EMAIL";
                                    var password = "KENNWORT";
                                    const interval = 30; // Abfrageintervall in Sekunden
                                    const dpRoot = "0_userdata.0.Poolheizung"; // Stammordner der Datenpunkte
                                    var apilevel = 1;   // 1: AquaTemp-Accounts, die vor v.1.5.8 erstellt wurden
                                                        // 2: HiTemp-Accounts
                                                        // 3: AquaTemp-Accounts, die mit neueren App-Versionen erstellt wurden
                                    // ENDE --------------------------------
                                    var cloudURL;
                                    var token = "";
                                    var tokenRefreshTimer;
                                    var device = "";
                                    // ProductIDs:
                                    // Gruppe 1:
                                    // 1132174963097280512: Midas/Poolsana InverPro
                                    const AQUATEMP_POOLSANA="1132174963097280512";
                                    // Gruppe 2:
                                    // 1442284873216843776:
                                    const AQUATEMP_OTHER1="1442284873216843776";
                                    var product = "";
                                    var reachable = false;
                                    function setupEndpoints() {
                                        if(apilevel==1) {
                                            cloudURL = "https://cloud.linked-go.com/cloudservice/api";
                                        } else if(apilevel==2) {
                                        } else if(apilevel==3) {
                                            cloudURL = "https://cloud.linked-go.com:449/crmservice/api";
                                            password = require('crypto').createHash('md5').update(password).digest("hex");
                                    function clearValues() {
                                        saveValue("error", true, "boolean");
                                        saveValue("consumption", 0, "number");
                                        saveValue("state", false, "boolean");
                                    function saveValue(key, value, sType) {
                                        var dp = dpRoot + "." + key;
                                        if ( !existsState(dp )) {
                                            createState(dp,value,{name: key,  type: 'number', role: 'value'}, function () {});
                                        } else {
                                            setState(dp,value,true);
                                    function findCodeVal(result, code) {
                                        //log(code);
                                        for(var i=0; i<result.length; i++) {
                                            //log(result[i].code);
                                            if(result[i].code.indexOf(code) >= 0) {
                                                return result[i].value;
                                        return "";
                                    function createobjects() {
                                        log ("erstelle Objekte");
                                        createState(dpRoot + '.ambient', {read: true, write: false,  type: "number", unit:"°C", role: "value.temperature", name: "Umgebungstemperatur"});
                                        createState(dpRoot + '.connection', {read: true, write: false,  type: "boolean", role: "state", name: "Verbindung", def: false});
                                        createState(dpRoot + '.consumption', {read: true, write: false,  type: "number", unit:"W", role: "value.power", name: "Stromverbrauch", def: 0});
                                        createState(dpRoot + '.error', {read: true, write: false,  type: "boolean", role: "state", name: "Fehler", def: false});
                                        createState(dpRoot + '.errorCode', {read: true, write: false,  type: "string", name: "Fehlercode", def: ""});
                                        createState(dpRoot + '.errorLevel', {read: true, write: false,  type: "number", name: "Fehlerlevel"});
                                        createState(dpRoot + '.errorMessage', {read: true, write: false,  type: "string", name: "Fehlermeldung", def: ""});
                                        createState(dpRoot + '.mode', {read: true, write: true,  type: "string", states: "-1:off;0:cool;1:heat;2:auto", name: "Modus", def: ""});
                                        createState(dpRoot + '.rotor', {read: true, write: false,  type: "number", unit:"rpm", def: 0, name: "Lüfterdrehzahl"});
                                        createState(dpRoot + '.silent', {read: true, write: true,  type: "boolean", role: "state", name: "Silent", def: false});
                                        createState(dpRoot + '.state', {read: true, write: false,  type: "boolean", role: "state", name: "Status", def: false});
                                        createState(dpRoot + '.tempIn', {read: true, write: false,  type: "number", unit:"°C", role: "value.temperature", name: "Eingangstemperatur"});
                                        createState(dpRoot + '.tempOut', {read: true, write: false,  type: "number", unit:"°C", role: "value.temperature", name: "Ausgangstemperatur"});
                                        createState(dpRoot + '.tempSet', {read: true, write: true,  type: "number", unit:"°C", role: "level.temperature", name: "Solltemperatur"});
                                        createState(dpRoot + '.suctionTemp', {read: true, write: false,  type: "number", unit:"°C", name: "Luftansaugtemperatur"});
                                        createState(dpRoot + '.coilTemp', {read: true, write: false,  type: "number", unit:"°C", role: "value.temperature", name: "Kompressortemperatur"});
                                        createState(dpRoot + '.rawJSON', {read: true, write: false,  type: "array", name: "komplette Rückgabe"});
                                    function updateToken() {
                                        if(token=="") {
                                            //log("Token Neuanforderung");
                                            var request = require('request');
                                            var options;
                                            if(apilevel<3) {
                                                options = {
                                                    url: cloudURL + '/app/user/login.json',
                                                    method: 'POST',
                                                    json: { "user_name": username, "password": password, "type": "2" },
                                                    rejectUnauthorized: false
                                            } else {
                                                options = {
                                                    url: cloudURL + '/app/user/login',
                                                    method: 'POST',
                                                    json: { "userName": username, "password": password, "type": "2" },
                                            //log(JSON.stringify(options));
                                            request(options,function (error, response, body){
                                                if(parseInt(body.error_code)==0) {
                                                    if(apilevel<3) {
                                                        token = body.object_result["x-token"];
                                                    } else {
                                                        token = body.objectResult["x-token"];
                                                    //log("Login ok! Token " + token);
                                                    updateDeviceID();
                                                } else {
                                                    // Login-Fehler
                                                    //log("Login-Fehler in updateToken(): " + response.body, "error");
                                                    token = "";
                                                    saveValue("connection", false, "boolean");
                                        } else {
                                            updateDeviceID();
                                    function updateDeviceID() {
                                        if(token!="") {
                                            var optionsDev;
                                            if(apilevel<3) {
                                                optionsDev = {
                                                    url: cloudURL + '/app/device/deviceList.json',
                                                    headers: { "x-token": token },
                                                    body: {"product_ids": [
                                                            "1132174963097280512",
                                                            "1186904563333062656",
                                                            "1158905952238313472",
                                                            "1245226668902080512",
                                                            "1548963836789501952",
                                                    method: 'POST',
                                                    json: true,
                                            } else {
                                                optionsDev = {
                                                    url: cloudURL + '/app/device/deviceList',
                                                    body: {"productIds": [
                                                    method: 'POST',
                                                    json: true,
                                            request(optionsDev,function (error, response, body){
                                                //log(JSON.stringify(body.object_result));
                                                    //token = body.object_result["x-token"];
                                                    if(apilevel<3) {
                                                        device = body.object_result[0].device_code;
                                                        product = body.object_result[0].product_id;
                                                        reachable = (body.object_result[0].device_status=="ONLINE");
                                                    } else {
                                                        device = body.objectResult[0].deviceCode;
                                                        product = body.object_result[0].productId;
                                                        reachable = (body.objectResult[0].deviceStatus=="ONLINE");
                                                    //log(product);
                                                    if(reachable) {
                                                        saveValue("connection", true, "boolean");
                                                        if(device!="") updateDeviceStatus(device);
                                                    } else {
                                                        // offline
                                                        device = "";
                                                } else {
                                                    // Login-Fehler
                                                    //log("Fehler in updateDeviceID(): " + response.body, "error");
                                                    token = "";
                                                    device = "";
                                                    reachable = false;
                                    function updateDeviceStatus(devicecode) {
                                        if(token!="") {
                                            var optionsDev;
                                            if(apilevel<3) {
                                                optionsDev = {
                                                    url: cloudURL + '/app/device/getDeviceStatus.json',
                                                    json: { "device_code": devicecode },
                                                    method: 'POST',
                                            } else {
                                                optionsDev = {
                                                    url: cloudURL + '/app/device/getDeviceStatus',
                                                    json: { "deviceCode": devicecode },
                                                    method: 'POST',
                                                    if(apilevel<3) {
                                                        if(body.object_result["is_fault"]==true) {
                                                            // TODO: Fehlerbeschreibung abrufen
                                                            //clearValues();
                                                            updateDeviceDetails(devicecode);
                                                            updateDeviceErrorMsg(devicecode);
                                                        } else {
                                                            // kein Fehler
                                                            saveValue("error", false, "boolean");
                                                            saveValue("errorMessage", "", "string");
                                                            saveValue("errorCode", "", "string");
                                                            saveValue("errorLevel", 0, "number");
                                                    } else {
                                                        if(body.objectResult["is_fault"]==true) {
                                                            //clearValues();
                                                        } else {
                                                            // kein Fehler
                                                } else {
                                                    // Login-Fehler
                                                    //log("Fehler in updateDeviceStatus(): " + response.body, "error");
                                                    token = "";
                                                    device = "";
                                    function updateDeviceErrorMsg(devicecode) {
                                        if(token!="") {
                                            var optionsDev;
                                            if(apilevel<3) {
                                                optionsDev = {
                                                    url: cloudURL + '/app/device/getFaultDataByDeviceCode.json',
                                                    method: 'POST',
                                                    //headers: {"content-type": "application/json"},
                                                    //charset: 'utf8',
                                                    //json: true
                                            } else {
                                                optionsDev = {
                                                    url: cloudURL + '/app/device/getFaultDataByDeviceCode',
                                                    method: 'POST',
                                                    //charset: 'utf8',
                                                    //json: true
                                                    if(apilevel<3) {
                                                        saveValue("errorMessage", body.object_result[0].description, "string");
                                                        saveValue("errorCode", body.object_result[0].fault_code, "string");
                                                        saveValue("errorLevel", body.object_result[0].error_level, "string");
                                                    } else {
                                                        saveValue("errorMessage", body.objectResult[0].description, "string");
                                                        saveValue("errorCode", body.objectResult[0].fault_code, "string");
                                                        saveValue("errorLevel", body.objectResult[0].error_level, "string");
                                                } else {
                                                    // Login-Fehler
                                                    //log("Fehler in updateDeviceErrorMsg(): " + response.body, "error");
                                                    token = "";
                                                    device = "";
                                    function updateDeviceDetails(devicecode) {
                                        if(token!="") {
                                            var optionsDev;
                                            if(apilevel<3) {
                                                if(product==AQUATEMP_POOLSANA) {
                                                    optionsDev = {
                                                        url: cloudURL + '/app/device/getDataByCode.json',
                                                        json: { "device_code": devicecode, "protocal_codes":["Power","Mode","Manual-mute","T01","T02","2074","2075","2076","2077","H03","Set_Temp","R08","R09","R10","R11","R01","R02","R03","T03","1158","1159","F17","H02","T04","T05","T07","T14","T17"] },
                                                        // "protocal_codes":["Power","Mode","Manual-mute","T01","T02","2074","2075","2076","2077","H03","Set_Temp","R08","R09","R10","R11","R01","R02","R03","T03","1158","1159","F17","H02","T04","T05"]
                                                        method: 'POST',
                                                } else if(product==AQUATEMP_OTHER1) {
                                                    optionsDev = {
                                                        json: { "device_code": devicecode, "protocal_codes":["Power","Mode","Manual-mute","T1","T2","T3","T4","T5","2074","2075","2076","2077","H03","Set_Temp","R08","R09","R10","R11","R01","R02","R03","T03","1158","1159","F17","H02","T4","T5","T7","T14","T17"] },
                                                        method: 'POST',
                                            } else {
                                                    optionsDev = {
                                                        url: cloudURL + '/app/device/getDataByCode',
                                                        json: { "deviceCode": devicecode, "protocalCodes":["Power","Mode","Manual-mute","T01","T02","2074","2075","2076","2077","H03","Set_Temp","R08","R09","R10","R11","R01","R02","R03","T03","1158","1159","F17","H02","T04","T05","T07","T14","T17"] },
                                                        method: 'POST',
                                                } else if (product==AQUATEMP_OTHER1) {
                                                    optionsDev = {
                                                        json: { "deviceCode": devicecode, "protocalCodes":["Power","Mode","Manual-mute","T1","T2","T3","T4","T5","2074","2075","2076","2077","H03","Set_Temp","R08","R09","R10","R11","R01","R02","R03","T03","1158","1159","F17","H02","T4","T5","T7","T14","T17"] },
                                                        method: 'POST',
                                                    if(apilevel<3) {
                                                        saveValue("rawJSON", body.object_result, "string");
                                                        if(findCodeVal(body.object_result, "Power")=="1") {
        // Stromverbrauch T07 x T14 in Watt
        saveValue("consumption", parseFloat(findCodeVal(body.object_result, "T07")) * parseFloat(findCodeVal(body.object_result, "T14")), "number");
        // Luftansaug-Temperatur T01
        saveValue("suctionTemp", parseFloat(findCodeVal(body.object_result, "T01")), "number");
        // Inlet-Temperatur T02
        saveValue("tempIn", parseFloat(findCodeVal(body.object_result, "T02")), "number");
        // outlet-Temperatur T03
        saveValue("tempOut", parseFloat(findCodeVal(body.object_result, "T03")), "number");
        // Coil-Temperatur T04
        saveValue("coilTemp", parseFloat(findCodeVal(body.object_result, "T04")), "number");
        // Umgebungs-Temperatur T05
        saveValue("ambient", parseFloat(findCodeVal(body.object_result, "T05")), "number");
        // Stromverbrauch T7 x T14 in Watt
        saveValue("consumption", parseFloat(findCodeVal(body.object_result, "T7")) * parseFloat(findCodeVal(body.object_result, "T14")), "number");
        // Luftansaug-Temperatur T1
        saveValue("suctionTemp", parseFloat(findCodeVal(body.object_result, "T1")), "number");
        // Inlet-Temperatur T2
        saveValue("tempIn", parseFloat(findCodeVal(body.object_result, "T2")), "number");
        // outlet-Temperatur T3
        saveValue("tempOut", parseFloat(findCodeVal(body.object_result, "T3")), "number");
        // Coil-Temperatur T4
        saveValue("coilTemp", parseFloat(findCodeVal(body.object_result, "T4")), "number");
        // Umgebungs-Temperatur T5
        saveValue("ambient", parseFloat(findCodeVal(body.object_result, "T5")), "number");
                                                            // Lüfter-Drehzahl T17
                                                            saveValue("rotor", parseInt(findCodeVal(body.object_result, "T17")), "number");
                                                        } else {
                                                            saveValue("rotor", 0, "number");
                                                        // Ziel-Temperatur Set_Temp
                                                        saveValue("tempSet", parseFloat(findCodeVal(body.object_result, "Set_Temp")), "number");
                                                        // Flüstermodus Manual-mute
                                                        if(findCodeVal(body.object_result, "Manual-mute")=="1") {
                                                            saveValue("silent", true, "boolean");
                                                        } else {
                                                            saveValue("silent", false, "boolean");
                                                        // Zustand Power
                                                            saveValue("state", true, "boolean");
                                                            saveValue("mode", findCodeVal(body.object_result,"Mode"), "string");
                                                        } else {
                                                            saveValue("mode", "-1", "string");
                                                        // Durchlauf ENDE
                                                        //log(findCodeVal(body.object_result, "T07"));
                                                    } else {
                                                        saveValue("rawJSON", body.objectResult, "string");
                                                        if(findCodeVal(body.objectResult, "Power")=="1") {
                                                            saveValue("consumption", parseFloat(findCodeVal(body.objectResult, "T07")) * parseFloat(findCodeVal(body.objectResult, "T14")), "number");
                                                            saveValue("rotor", parseInt(findCodeVal(body.objectResult, "T17")), "number");
                                                            saveValue("suctionTemp", parseFloat(findCodeVal(body.objectResult, "T01")), "number");
                                                            saveValue("tempIn", parseFloat(findCodeVal(body.objectResult, "T02")), "number");
                                                            saveValue("tempOut", parseFloat(findCodeVal(body.objectResult, "T03")), "number");
                                                            saveValue("coilTemp", parseFloat(findCodeVal(body.objectResult, "T04")), "number");
                                                        } else {
                                                        saveValue("tempSet", parseFloat(findCodeVal(body.objectResult, "Set_Temp")), "number");
                                                        saveValue("ambient", parseFloat(findCodeVal(body.objectResult, "T05")), "number");
                                                        if(findCodeVal(body.objectResult, "Manual-mute")=="1") {
                                                        } else {
                                                        // Zustand Power
                                                            saveValue("mode", findCodeVal(body.objectResult,"Mode"), "string");
                                                        } else {
                                                        // Durchlauf ENDE
                                                } else {
                                                    // Login-Fehler
                                                    //log("Fehler in updateDeviceDetails(): " + response.body, "error");
                                                    token = "";
                                                    device = "";
                                    function updateDevicePower(devicecode, power) {
                                        var powerOpt;
                                        var powerMode = 2;
                                        if(power==-1) {
                                            // aus
                                            powerOpt = 0;
                                            powerMode = -1;
                                        } else if(power==0) {
                                            // an und kühlen
                                            powerOpt = 1;
                                            powerMode = 0;
                                        } else if(power==1) {
                                            // an und heizen
                                            powerOpt = 1;
                                            powerMode = 1;
                                        } else if(power==2) {
                                            // an und auto
                                            powerOpt = 1;
                                            powerMode = 2;
                                        } else {
                                            log("ungülter Zustand!");
                                            return;
                                        if(token!="") {
                                            var optionsDev;
                                            if(apilevel<3) {
                                                optionsDev = {
                                                    url: cloudURL + '/app/device/control.json',
                                                    json: {"param":[{ "device_code": devicecode, "protocol_code": "Power","value": powerOpt }]},
                                                    method: 'POST',
                                            } else {
                                                optionsDev = {
                                                    url: cloudURL + '/app/device/control',
                                                    json: {"param":[{ "deviceCode": devicecode, "protocolCode": "Power","value": powerOpt }]},
                                                    method: 'POST',
                                                //log(devicecode);
                                                    saveValue("mode", power, "string");
                                                    if(power>=0) updateDeviceMode(device, power);
                                                } else {
                                                    log("Zustandsänderung fehlgeschlagen!", "error");
                                    function updateDeviceMode(devicecode, mode) {
                                        if(token!="") {
                                            var optionsDev;
                                            if(apilevel<3) {
                                                optionsDev = {
                                                    json: {"param":[{ "device_code": devicecode, "protocol_code": "mode","value": mode }]},
                                                    method: 'POST',
                                                    //charset: 'utf8',
                                                    //json: true
                                            } else {
                                                optionsDev = {
                                                    json: {"param":[{ "deviceCode": devicecode, "protocolCode": "mode","value": mode }]},
                                                    method: 'POST',
                                                    //charset: 'utf8',
                                                    //json: true
                                                //log(devicecode);
                                                    saveValue("mode", mode, "string");
                                                } else {
                                                    token = "";
                                                    device = "";
                                    function updateDeviceSilent(devicecode, silent) {
                                        var silentMode;
                                        if(silent) {
                                            silentMode = "1";
                                        } else {
                                            silentMode = "0";
                                        if(token!="") {
                                            var optionsDev;
                                            if(apilevel<3) {
                                                optionsDev = {
                                                    json: {"param":[{ "device_code": devicecode, "protocol_code": "Manual-mute","value": silentMode }]},
                                                    method: 'POST',
                                                    //charset: 'utf8',
                                                    //json: true
                                            } else {
                                                optionsDev = {
                                                    json: {"param":[{ "deviceCode": devicecode, "protocolCode": "Manual-mute","value": silentMode }]},
                                                    method: 'POST',
                                                    //charset: 'utf8',
                                                    //json: true
                                                //log(devicecode);
                                                    saveValue("silent", silent, "boolean");
                                                } else {
                                                    token = "";
                                                    device = "";
                                    function updateDeviceSetTemp(devicecode, temperature) {
                                        var sTemperature = temperature.toString().replace(",", ".");
                                        var sMode = getState(dpRoot + ".mode").val;
                                        if(sMode=="-1") {
                                            //log("Gerät einschalten um Temperatur zu ändern!", 'warn');
                                            return;
                                        } else if(sMode=="0") {
                                            sMode = "R01"; // Kühlen
                                        } else if(sMode=="1") {
                                            sMode = "R02"; // Heizen
                                        } else if(sMode=="2") {
                                            sMode = "R03"; // Auto
                                        if(token!="") {
                                            var optionsDev;
                                            if(apilevel<3) {
                                                optionsDev = {
                                                    json: {"param":[{ "device_code": devicecode, "protocol_code": "R01","value": sTemperature },{ "device_code": devicecode, "protocol_code": "R02","value": sTemperature },{ "device_code": devicecode, "protocol_code": "R03","value": sTemperature },{ "device_code": devicecode, "protocol_code": "Set_Temp","value": sTemperature }]},
                                                    method: 'POST',
                                                    //charset: 'utf8',
                                                    //json: true
                                            } else {
                                                optionsDev = {
                                                    json: {"param":[{ "deviceCode": devicecode, "protocolCode": "R01","value": sTemperature },{ "deviceCode": devicecode, "protocolCode": "R02","value": sTemperature },{ "deviceCode": devicecode, "protocolCode": "R03","value": sTemperature },{ "deviceCode": devicecode, "protocolCode": "Set_Temp","value": sTemperature }]},
                                                    method: 'POST',
                                                    //charset: 'utf8',
                                                    //json: true
                                                //log(devicecode);
                                                    saveValue("tempSet", temperature, "number");
                                                } else {
                                                    token = "";
                                                    device = "";
                                    // Beginn des Skripts
                                    setupEndpoints();
                                    createobjects(); // DPs anlegen
                                    updateToken(); // Zugriffstoken erfragen und aktuelle Werte lesen
                                    schedule('*/' + interval + ' * * * * *', function () {
                                        // regelmäßig Token und Zustand abfragen
                                        updateToken();
                                        // gewünschte Änderungen ausführen
                                        if(!getState(dpRoot + ".mode").ack) {
                                            updateDevicePower(device, getState(dpRoot + ".mode").val);
                                        if(!getState(dpRoot + ".silent").ack) {
                                            updateDevicePower(device, getState(dpRoot + ".silent").val);
                                    tokenRefreshTimer = setInterval(function () {
                                        // Token verfällt nach 60min
                                        token = "";
                                        //log("Token nach Intervall verworfen.")
                                        updateToken();
                                    }, 3600000);
                                    on({id: dpRoot + ".mode", change: "ne", ack: false}, function (obj) {
                                        updateToken();
                                    on({id: dpRoot + ".silent", change: "ne", ack: false}, function (obj) {
                                        updateToken();
                                        updateDeviceSilent(device, getState(dpRoot + ".silent").val);
                                    on({id: dpRoot + ".tempSet", change: "ne", ack: false}, function (obj) {
                                        updateToken();
                                        updateDeviceSetTemp(device, getState(dpRoot + ".tempSet").val);
                                    T P R 3 Antworten Letzte Antwort
                                    • O oxident
                                      // v0.0.8c
                                      // Changelog:
                                      var cloudURL;
                                      var token = "";
                                      var device = "";
                                      // ProductIDs:
                                      // Gruppe 1:
                                      // Gruppe 2:
                                      var product = "";
                                          if(apilevel==1) {
                                          } else {
                                          //log(code);
                                          return "";
                                          if(token=="") {
                                              var options;
                                              if(apilevel<3) {
                                                  options = {
                                                      method: 'POST',
                                              } else {
                                                  options = {
                                                      method: 'POST',
                                                      if(apilevel<3) {
                                                      } else {
                                                      updateDeviceID();
                                                  } else {
                                                      // Login-Fehler
                                                      token = "";
                                          } else {
                                              updateDeviceID();
                                          if(token!="") {
                                              var optionsDev;
                                              if(apilevel<3) {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      json: true,
                                              } else {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      json: true,
                                                      if(apilevel<3) {
                                                      } else {
                                                      //log(product);
                                                      if(reachable) {
                                                      } else {
                                                          // offline
                                                          device = "";
                                                  } else {
                                                      // Login-Fehler
                                                      token = "";
                                                      device = "";
                                                      reachable = false;
                                          if(token!="") {
                                              var optionsDev;
                                              if(apilevel<3) {
                                                  optionsDev = {
                                                      method: 'POST',
                                              } else {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      if(apilevel<3) {
                                                              //clearValues();
                                                          } else {
                                                              // kein Fehler
                                                      } else {
                                                              //clearValues();
                                                          } else {
                                                              // kein Fehler
                                                  } else {
                                                      // Login-Fehler
                                                      token = "";
                                                      device = "";
                                          if(token!="") {
                                              var optionsDev;
                                              if(apilevel<3) {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      //charset: 'utf8',
                                                      //json: true
                                              } else {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      //charset: 'utf8',
                                                      //json: true
                                                      if(apilevel<3) {
                                                      } else {
                                                  } else {
                                                      // Login-Fehler
                                                      token = "";
                                                      device = "";
                                          if(token!="") {
                                              var optionsDev;
                                              if(apilevel<3) {
                                                      optionsDev = {
                                                          method: 'POST',
                                                      optionsDev = {
                                                          method: 'POST',
                                              } else {
                                                      optionsDev = {
                                                          method: 'POST',
                                                      optionsDev = {
                                                          method: 'POST',
                                                      if(apilevel<3) {
                                                          } else {
                                                          } else {
                                                          // Zustand Power
                                                          } else {
                                                          // Durchlauf ENDE
                                                      } else {
                                                          } else {
                                                          } else {
                                                          // Zustand Power
                                                          } else {
                                                          // Durchlauf ENDE
                                                  } else {
                                                      // Login-Fehler
                                                      token = "";
                                                      device = "";
                                          var powerOpt;
                                          var powerMode = 2;
                                          if(power==-1) {
                                              // aus
                                              powerOpt = 0;
                                              powerMode = -1;
                                              // an und kühlen
                                              powerOpt = 1;
                                              powerMode = 0;
                                              // an und heizen
                                              powerOpt = 1;
                                              powerMode = 1;
                                              // an und auto
                                              powerOpt = 1;
                                              powerMode = 2;
                                          } else {
                                              return;
                                          if(token!="") {
                                              var optionsDev;
                                              if(apilevel<3) {
                                                  optionsDev = {
                                                      method: 'POST',
                                              } else {
                                                  optionsDev = {
                                                      method: 'POST',
                                                  //log(devicecode);
                                                  } else {
                                          if(token!="") {
                                              var optionsDev;
                                              if(apilevel<3) {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      //charset: 'utf8',
                                                      //json: true
                                              } else {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      //charset: 'utf8',
                                                      //json: true
                                                  //log(devicecode);
                                                  } else {
                                                      token = "";
                                                      device = "";
                                          var silentMode;
                                          if(silent) {
                                              silentMode = "1";
                                          } else {
                                              silentMode = "0";
                                          if(token!="") {
                                              var optionsDev;
                                              if(apilevel<3) {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      //charset: 'utf8',
                                                      //json: true
                                              } else {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      //charset: 'utf8',
                                                      //json: true
                                                  //log(devicecode);
                                                  } else {
                                                      token = "";
                                                      device = "";
                                          if(sMode=="-1") {
                                              return;
                                          if(token!="") {
                                              var optionsDev;
                                              if(apilevel<3) {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      //charset: 'utf8',
                                                      //json: true
                                              } else {
                                                  optionsDev = {
                                                      method: 'POST',
                                                      //charset: 'utf8',
                                                      //json: true
                                                  //log(devicecode);
                                                  } else {
                                                      token = "";
                                                      device = "";
                                      setupEndpoints();
                                          updateToken();
                                          token = "";
                                          updateToken();
                                      }, 3600000);
                                          updateToken();
                                          updateToken();
                                          updateToken();
                                      tklein
                                      #151
                                      @oxident hi, ist das die aktuellste version des scriptes?
                                      • O oxident
                                        // v0.0.8c
                                        // Changelog:
                                        var cloudURL;
                                        var token = "";
                                        var device = "";
                                        // ProductIDs:
                                        // Gruppe 1:
                                        // Gruppe 2:
                                        var product = "";
                                            if(apilevel==1) {
                                            } else {
                                            //log(code);
                                            return "";
                                            if(token=="") {
                                                var options;
                                                if(apilevel<3) {
                                                    options = {
                                                        method: 'POST',
                                                } else {
                                                    options = {
                                                        method: 'POST',
                                                        if(apilevel<3) {
                                                        } else {
                                                        updateDeviceID();
                                                    } else {
                                                        // Login-Fehler
                                                        token = "";
                                            } else {
                                                updateDeviceID();
                                            if(token!="") {
                                                var optionsDev;
                                                if(apilevel<3) {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        json: true,
                                                } else {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        json: true,
                                                        if(apilevel<3) {
                                                        } else {
                                                        //log(product);
                                                        if(reachable) {
                                                        } else {
                                                            // offline
                                                            device = "";
                                                    } else {
                                                        // Login-Fehler
                                                        token = "";
                                                        device = "";
                                                        reachable = false;
                                            if(token!="") {
                                                var optionsDev;
                                                if(apilevel<3) {
                                                    optionsDev = {
                                                        method: 'POST',
                                                } else {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        if(apilevel<3) {
        //clearValues();
                                                            } else {
        // kein Fehler
                                                        } else {
        //clearValues();
                                                            } else {
        // kein Fehler
                                                    } else {
                                                        // Login-Fehler
                                                        token = "";
                                                        device = "";
                                            if(token!="") {
                                                var optionsDev;
                                                if(apilevel<3) {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        //charset: 'utf8',
                                                        //json: true
                                                } else {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        //charset: 'utf8',
                                                        //json: true
                                                        if(apilevel<3) {
                                                        } else {
                                                    } else {
                                                        // Login-Fehler
                                                        token = "";
                                                        device = "";
                                            if(token!="") {
                                                var optionsDev;
                                                if(apilevel<3) {
                                                        optionsDev = {
                                                            method: 'POST',
                                                        optionsDev = {
                                                            method: 'POST',
                                                } else {
                                                        optionsDev = {
                                                            method: 'POST',
                                                        optionsDev = {
                                                            method: 'POST',
                                                        if(apilevel<3) {
                                                            } else {
                                                            } else {
                                                            // Zustand Power
                                                            } else {
                                                            // Durchlauf ENDE
                                                        } else {
                                                            } else {
                                                            } else {
                                                            // Zustand Power
                                                            } else {
                                                            // Durchlauf ENDE
                                                    } else {
                                                        // Login-Fehler
                                                        token = "";
                                                        device = "";
                                            var powerOpt;
                                            var powerMode = 2;
                                            if(power==-1) {
                                                // aus
                                                powerOpt = 0;
                                                powerMode = -1;
                                                // an und kühlen
                                                powerOpt = 1;
                                                powerMode = 0;
                                                // an und heizen
                                                powerOpt = 1;
                                                powerMode = 1;
                                                // an und auto
                                                powerOpt = 1;
                                                powerMode = 2;
                                            } else {
                                                return;
                                            if(token!="") {
                                                var optionsDev;
                                                if(apilevel<3) {
                                                    optionsDev = {
                                                        method: 'POST',
                                                } else {
                                                    optionsDev = {
                                                        method: 'POST',
                                                    //log(devicecode);
                                                    } else {
                                            if(token!="") {
                                                var optionsDev;
                                                if(apilevel<3) {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        //charset: 'utf8',
                                                        //json: true
                                                } else {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        //charset: 'utf8',
                                                        //json: true
                                                    //log(devicecode);
                                                    } else {
                                                        token = "";
                                                        device = "";
                                            var silentMode;
                                            if(silent) {
                                                silentMode = "1";
                                            } else {
                                                silentMode = "0";
                                            if(token!="") {
                                                var optionsDev;
                                                if(apilevel<3) {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        //charset: 'utf8',
                                                        //json: true
                                                } else {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        //charset: 'utf8',
                                                        //json: true
                                                    //log(devicecode);
                                                    } else {
                                                        token = "";
                                                        device = "";
                                            if(sMode=="-1") {
                                                return;
                                            if(token!="") {
                                                var optionsDev;
                                                if(apilevel<3) {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        //charset: 'utf8',
                                                        //json: true
                                                } else {
                                                    optionsDev = {
                                                        method: 'POST',
                                                        //charset: 'utf8',
                                                        //json: true
                                                    //log(devicecode);
                                                    } else {
                                                        token = "";
                                                        device = "";
                                        setupEndpoints();
                                            updateToken();
                                            token = "";
                                            updateToken();
                                        }, 3600000);
                                            updateToken();
                                            updateToken();
                                            updateToken();
                                        PietNB
                                        #152
                                        @oxident Hab das Script gleich mal ausprobiert. Zeigt eigentlich die gleichen Werte wie das optimierte vorher. Mir sind aber 2 Sachen aufgefallen:
                                        -tempOut t3 stimmt nicht mit dem Wert in der rawJSON überein Bsp. t3 soll 22,5°C ->Objekt Anzeige 25°C
                                        -tempSet Solltemperatur wird noch immer mit "0" angezeigt->die R01-R03 Werte zeige die richtige Temperatur an
                                        Weiterhin bekomme ich eine Fehlermeldung:
                                        javascript.0
                                        2023-07-03 17:38:00.113	error	Error in request callback: TypeError: Cannot read property '0' of undefined
                                        • T tklein
                                          O Offline
                                          O Offline
                                          oxident
                                          #153
                                          @tklein Jein, ist eigentlich eher die Entwicklungsversion für diejenigen, bei denen folgendes zutrifft:
                                          • Registrierung wurde erst vor kurzem (?) mit der neuen AquaTemp-App gemacht
                                          • Wärmepumpe ist nicht baugleich mit meiner Poolsana InverPro
