  3. Einsteigerfragen
  4. Installation
  5. nach Updates der node Versionen geht nichts mehr
16 Beiträge 4 Kommentatoren 28.7k Aufrufe 3 Beobachtet
  • DJMarc75D DJMarc75
    @marc91 sagte in nach Updates der node Versionen geht nichts mehr:
    E: The repository 'http://archive.ubuntu.com/ubuntu hirsute Release' no longer has a Release file.
    E: The repository 'http://archive.ubuntu.com/ubuntu hirsute-updates Release' no longer has a Release file.
    E: The repository 'http://archive.ubuntu.com/ubuntu hirsute-security Release' no longer has a Release file.
    Pending Updates: 72
    https://fridge.ubuntu.com/2022/01/21/ubuntu-21-04-hirsute-hippo-end-of-life-reached-on-january-20-2022/
    marc91
    @djmarc75
    hm das heißt, ich muss eine neue Ubuntu Version installieren?
    • M marc91
      @djmarc75
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      natürlich
      Lehrling seit 1975 !!!
        natürlich
        marc91
        @djmarc75
        Danke!
        wenn ich nun sudo apt update eingebe kommt folgendes:
        Hit:1 https://deb.nodesource.com/node_18.x bullseye InRelease
        Ign:2 http://archive.ubuntu.com/ubuntu hirsute InRelease
        Ign:3 http://archive.ubuntu.com/ubuntu hirsute-updates InRelease
        Ign:4 http://archive.ubuntu.com/ubuntu hirsute-security InRelease
        Err:5 http://archive.ubuntu.com/ubuntu hirsute Release
          404  Not Found [IP: 91.189.91.38 80]
        Err:6 http://archive.ubuntu.com/ubuntu hirsute-updates Release
        Err:7 http://archive.ubuntu.com/ubuntu hirsute-security Release
        Reading package lists... Done
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        und danach bei apt upgrade:
        Calculating upgrade... Done
        The following NEW packages will be installed:
          distro-info libllvm12
        The following packages will be upgraded:
          accountsservice apparmor apt apt-utils base-passwd bind9-dnsutils bind9-host bind9-libs busybox-static ca-certificates command-not-found cpio curl distro-info-data isc-dhcp-client isc-dhcp-common libaccountsservice0 libapparmor1
          libapt-pkg6.0 libcurl4 libdrm-amdgpu1 libdrm-common libdrm-intel1 libdrm-nouveau2 libdrm-radeon1 libdrm2 libgcrypt20 libgl1-mesa-dri libglapi-mesa libglib2.0-data libglx-mesa0 libhogweed6 liblz4-1 libnettle8 libntfs-3g883 libpam-modules
          libpam-modules-bin libpam-runtime libpolkit-gobject-1-0 libprocps8 libpython3.9-minimal libpython3.9-stdlib libssh-4 libssl1.1 libuv1 libx11-data libxml2 login manpages networkd-dispatcher ntfs-3g openssh-client openssh-server
          openssh-sftp-server openssl passwd postfix procps python-apt-common python3-apt python3-commandnotfound python3-distupgrade python3-gdbm python3-update-manager python3.9 python3.9-minimal ssh tzdata ubuntu-advantage-tools
          ubuntu-release-upgrader-core ufw update-manager-core usrmerge vim-common vim-tiny xxd
        76 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
        Need to get 52.7 MB of archives.
        After this operation, 93.8 MB of additional disk space will be used.
        Do you want to continue? [Y/n] y
        Err:1 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 login amd64 1:4.8.1-1ubuntu8.1
          404  Not Found [IP: 185.125.190.36 80]
        Err:2 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 base-passwd amd64 3.5.49ubuntu1
        Ign:3 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libgcrypt20 amd64 1.8.7-2ubuntu2.1
        Ign:4 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 liblz4-1 amd64 1.9.3-1ubuntu0.1
        Err:5 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libapt-pkg6.0 amd64 2.2.4ubuntu0.1
        Err:6 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 apt amd64 2.2.4ubuntu0.1
        Err:7 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 apt-utils amd64 2.2.4ubuntu0.1
        Err:8 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpam-modules-bin amd64 1.3.1-5ubuntu6.21.04.1
        Err:9 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpam-modules amd64 1.3.1-5ubuntu6.21.04.1
        Err:10 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libssl1.1 amd64 1.1.1j-1ubuntu3.6
        Ign:11 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3.9 amd64 3.9.5-3ubuntu0~21.04.1
        Ign:12 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpython3.9-stdlib amd64 3.9.5-3ubuntu0~21.04.1
        Ign:13 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3.9-minimal amd64 3.9.5-3ubuntu0~21.04.1
        Ign:14 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpython3.9-minimal amd64 3.9.5-3ubuntu0~21.04.1
        Ign:15 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 tzdata all 2021e-0ubuntu0.21.04
        Ign:16 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ntfs-3g amd64 1:2017.3.23AR.3-3ubuntu4.1
        Ign:17 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libntfs-3g883 amd64 1:2017.3.23AR.3-3ubuntu4.1
        Err:18 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 openssh-sftp-server amd64 1:8.4p1-5ubuntu1.2
        Err:19 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpam-runtime all 1.3.1-5ubuntu6.21.04.1
        Err:20 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libprocps8 amd64 2:3.3.16-5ubuntu3.1
        Err:21 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 procps amd64 2:3.3.16-5ubuntu3.1
        Err:22 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 openssh-server amd64 1:8.4p1-5ubuntu1.2
        Err:23 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 passwd amd64 1:4.8.1-1ubuntu8.1
        Err:24 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 openssh-client amd64 1:8.4p1-5ubuntu1.2
        Err:25 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ssh all 1:8.4p1-5ubuntu1.2
        Ign:26 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libnettle8 amd64 3.7-2.1ubuntu1.1
        Ign:27 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libhogweed6 amd64 3.7-2.1ubuntu1.1
        Err:28 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 usrmerge all 24ubuntu3.1
        Err:29 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 openssl amd64 1.1.1j-1ubuntu3.6
        Ign:30 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ca-certificates all 20210119ubuntu0.21.04.1
        Ign:31 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 distro-info-data all 0.46ubuntu4.3
        Ign:32 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 isc-dhcp-client amd64 4.4.1-2.2ubuntu6.2
        Ign:33 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 isc-dhcp-common amd64 4.4.1-2.2ubuntu6.2
        Err:34 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libapparmor1 amd64 3.0.0-0ubuntu7.1
        Err:35 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libglib2.0-data all 2.68.1-1~ubuntu21.04.1
        Ign:36 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libxml2 amd64 2.9.10+dfsg-6.3ubuntu0.1
        Err:37 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 networkd-dispatcher all 2.1-2~ubuntu21.04.1
        Err:38 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python-apt-common all 2.2.0~ubuntu0.21.04.1
        Err:39 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-apt amd64 2.2.0~ubuntu0.21.04.1
        Err:40 http://archive.ubuntu.com/ubuntu hirsute/main amd64 distro-info amd64 1.0
        Err:41 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ubuntu-advantage-tools amd64 27.5~21.04.1
        Ign:42 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 xxd amd64 2:8.2.2434-1ubuntu1.3
        Ign:43 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 vim-tiny amd64 2:8.2.2434-1ubuntu1.3
        Ign:44 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 vim-common all 2:8.2.2434-1ubuntu1.3
        Ign:45 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 accountsservice amd64 0.6.55-0ubuntu13.3
        Ign:46 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libaccountsservice0 amd64 0.6.55-0ubuntu13.3
        Ign:47 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpolkit-gobject-1-0 amd64 0.105-30ubuntu0.1
        Err:48 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 apparmor amd64 3.0.0-0ubuntu7.1
        Ign:49 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libuv1 amd64 1.40.0-1ubuntu0.1
        Ign:50 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-dnsutils amd64 1:9.16.8-1ubuntu3.3
        Ign:51 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-libs amd64 1:9.16.8-1ubuntu3.3
        Ign:52 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-host amd64 1:9.16.8-1ubuntu3.3
        Ign:53 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 busybox-static amd64 1:1.30.1-6ubuntu2.1
        Ign:54 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-gdbm amd64 3.9.5-0ubuntu3~21.04
        Err:55 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 command-not-found all 20.10.2
        Err:56 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-commandnotfound all 20.10.2
        Ign:57 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 cpio amd64 2.13+dfsg-4ubuntu0.3
        Err:58 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-common all 2.4.105-3~21.04.1
        Err:59 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm2 amd64 2.4.105-3~21.04.1
        Ign:60 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libx11-data all 2:1.7.0-2ubuntu0.1
        Err:61 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 manpages all 5.10-1ubuntu0.1
        Err:62 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ubuntu-release-upgrader-core all 1:21.04.17
        Err:63 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-distupgrade all 1:21.04.17
        Err:64 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-update-manager all 1:21.04.10
        Err:65 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 update-manager-core all 1:21.04.10
        Err:66 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ufw all 0.36-7.1ubuntu1
        Ign:67 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libssh-4 amd64 0.9.5-1ubuntu0.1
        Ign:68 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 curl amd64 7.74.0-1ubuntu2.3
        Ign:69 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libcurl4 amd64 7.74.0-1ubuntu2.3
        Err:70 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-amdgpu1 amd64 2.4.105-3~21.04.1
        Err:71 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-intel1 amd64 2.4.105-3~21.04.1
        Err:72 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-nouveau2 amd64 2.4.105-3~21.04.1
        Err:73 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-radeon1 amd64 2.4.105-3~21.04.1
        Err:74 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libglx-mesa0 amd64 21.0.3-0ubuntu0.3
        Err:75 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libgl1-mesa-dri amd64 21.0.3-0ubuntu0.3
        Err:76 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libglapi-mesa amd64 21.0.3-0ubuntu0.3
        Err:77 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libllvm12 amd64 1:12.0.0-3ubuntu1~21.04.2
        Err:78 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 postfix amd64 3.5.6-1ubuntu0.2
        Err:3 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libgcrypt20 amd64 1.8.7-2ubuntu2.1
        Err:4 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 liblz4-1 amd64 1.9.3-1ubuntu0.1
        Err:11 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3.9 amd64 3.9.5-3ubuntu0~21.04.1
        Err:12 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpython3.9-stdlib amd64 3.9.5-3ubuntu0~21.04.1
        Err:13 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3.9-minimal amd64 3.9.5-3ubuntu0~21.04.1
        Err:14 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpython3.9-minimal amd64 3.9.5-3ubuntu0~21.04.1
        Err:15 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 tzdata all 2021e-0ubuntu0.21.04
        Err:16 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ntfs-3g amd64 1:2017.3.23AR.3-3ubuntu4.1
        Err:17 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libntfs-3g883 amd64 1:2017.3.23AR.3-3ubuntu4.1
        Err:26 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libnettle8 amd64 3.7-2.1ubuntu1.1
        Err:27 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libhogweed6 amd64 3.7-2.1ubuntu1.1
        Err:30 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ca-certificates all 20210119ubuntu0.21.04.1
        Err:31 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 distro-info-data all 0.46ubuntu4.3
        Err:32 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 isc-dhcp-client amd64 4.4.1-2.2ubuntu6.2
        Err:33 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 isc-dhcp-common amd64 4.4.1-2.2ubuntu6.2
        Err:36 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libxml2 amd64 2.9.10+dfsg-6.3ubuntu0.1
        Err:42 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 xxd amd64 2:8.2.2434-1ubuntu1.3
        Err:43 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 vim-tiny amd64 2:8.2.2434-1ubuntu1.3
        Err:44 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 vim-common all 2:8.2.2434-1ubuntu1.3
        Err:45 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 accountsservice amd64 0.6.55-0ubuntu13.3
        Err:46 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libaccountsservice0 amd64 0.6.55-0ubuntu13.3
        Err:47 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpolkit-gobject-1-0 amd64 0.105-30ubuntu0.1
        Err:49 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libuv1 amd64 1.40.0-1ubuntu0.1
        Err:50 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-dnsutils amd64 1:9.16.8-1ubuntu3.3
        Err:51 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-libs amd64 1:9.16.8-1ubuntu3.3
        Err:52 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-host amd64 1:9.16.8-1ubuntu3.3
        Err:53 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 busybox-static amd64 1:1.30.1-6ubuntu2.1
        Err:54 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-gdbm amd64 3.9.5-0ubuntu3~21.04
        Err:57 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 cpio amd64 2.13+dfsg-4ubuntu0.3
        Err:60 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libx11-data all 2:1.7.0-2ubuntu0.1
        Err:67 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libssh-4 amd64 0.9.5-1ubuntu0.1
        Err:68 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 curl amd64 7.74.0-1ubuntu2.3
        Err:69 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libcurl4 amd64 7.74.0-1ubuntu2.3
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/shadow/login_4.8.1-1ubuntu8.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/base-passwd/base-passwd_3.5.49ubuntu1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libg/libgcrypt20/libgcrypt20_1.8.7-2ubuntu2.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/l/lz4/liblz4-1_1.9.3-1ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/libapt-pkg6.0_2.2.4ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt_2.2.4ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt-utils_2.2.4ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/pam/libpam-modules-bin_1.3.1-5ubuntu6.21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/pam/libpam-modules_1.3.1-5ubuntu6.21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1j-1ubuntu3.6_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3.9/python3.9_3.9.5-3ubuntu0~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3.9/libpython3.9-stdlib_3.9.5-3ubuntu0~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3.9/python3.9-minimal_3.9.5-3ubuntu0~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3.9/libpython3.9-minimal_3.9.5-3ubuntu0~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/t/tzdata/tzdata_2021e-0ubuntu0.21.04_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/ntfs-3g/ntfs-3g_2017.3.23AR.3-3ubuntu4.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/ntfs-3g/libntfs-3g883_2017.3.23AR.3-3ubuntu4.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/openssh-sftp-server_8.4p1-5ubuntu1.2_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/pam/libpam-runtime_1.3.1-5ubuntu6.21.04.1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/procps/libprocps8_3.3.16-5ubuntu3.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/procps/procps_3.3.16-5ubuntu3.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/openssh-server_8.4p1-5ubuntu1.2_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/shadow/passwd_4.8.1-1ubuntu8.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/openssh-client_8.4p1-5ubuntu1.2_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/ssh_8.4p1-5ubuntu1.2_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/nettle/libnettle8_3.7-2.1ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/nettle/libhogweed6_3.7-2.1ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/usrmerge/usrmerge_24ubuntu3.1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/openssl_1.1.1j-1ubuntu3.6_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/ca-certificates/ca-certificates_20210119ubuntu0.21.04.1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/d/distro-info-data/distro-info-data_0.46ubuntu4.3_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-client_4.4.1-2.2ubuntu6.2_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-common_4.4.1-2.2ubuntu6.2_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apparmor/libapparmor1_3.0.0-0ubuntu7.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/glib2.0/libglib2.0-data_2.68.1-1~ubuntu21.04.1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libx/libxml2/libxml2_2.9.10+dfsg-6.3ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/networkd-dispatcher/networkd-dispatcher_2.1-2~ubuntu21.04.1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python-apt/python-apt-common_2.2.0~ubuntu0.21.04.1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python-apt/python3-apt_2.2.0~ubuntu0.21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/d/distro-info/distro-info_1.0_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.5~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/v/vim/xxd_8.2.2434-1ubuntu1.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/v/vim/vim-tiny_8.2.2434-1ubuntu1.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/v/vim/vim-common_8.2.2434-1ubuntu1.3_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/accountsservice/accountsservice_0.6.55-0ubuntu13.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/accountsservice/libaccountsservice0_0.6.55-0ubuntu13.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/policykit-1/libpolkit-gobject-1-0_0.105-30ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apparmor/apparmor_3.0.0-0ubuntu7.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libu/libuv1/libuv1_1.40.0-1ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/bind9/bind9-dnsutils_9.16.8-1ubuntu3.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/bind9/bind9-libs_9.16.8-1ubuntu3.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/bind9/bind9-host_9.16.8-1ubuntu3.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/busybox/busybox-static_1.30.1-6ubuntu2.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3-stdlib-extensions/python3-gdbm_3.9.5-0ubuntu3~21.04_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/command-not-found/command-not-found_20.10.2_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/command-not-found/python3-commandnotfound_20.10.2_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/cpio/cpio_2.13+dfsg-4ubuntu0.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-common_2.4.105-3~21.04.1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm2_2.4.105-3~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libx/libx11/libx11-data_1.7.0-2ubuntu0.1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/m/manpages/manpages_5.10-1ubuntu0.1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/ubuntu-release-upgrader-core_21.04.17_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/python3-distupgrade_21.04.17_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/update-manager/python3-update-manager_21.04.10_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/update-manager/update-manager-core_21.04.10_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ufw/ufw_0.36-7.1ubuntu1_all.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libs/libssh/libssh-4_0.9.5-1ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/curl/curl_7.74.0-1ubuntu2.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/curl/libcurl4_7.74.0-1ubuntu2.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-amdgpu1_2.4.105-3~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-intel1_2.4.105-3~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-nouveau2_2.4.105-3~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-radeon1_2.4.105-3~21.04.1_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/m/mesa/libglx-mesa0_21.0.3-0ubuntu0.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/m/mesa/libgl1-mesa-dri_21.0.3-0ubuntu0.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/m/mesa/libglapi-mesa_21.0.3-0ubuntu0.3_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/l/llvm-toolchain-12/libllvm12_12.0.0-3ubuntu1~21.04.2_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/postfix/postfix_3.5.6-1ubuntu0.2_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
        kannst du mir helfen was da schiefläuft ?
        HomoranH DJMarc75D 2 Antworten Letzte Antwort
        • M marc91
          @djmarc75
          Danke!
          weil
          @djmarc75 sagte in nach Updates der node Versionen geht nichts mehr:
          was hattest du denn vor mit
          • M marc91
            @djmarc75
            Danke!
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            nein, nutze kein Ubuntu und wollte Dir nur einen Hinweis geben.
            Zumal Du auch nicht auf die aktuelle Version von Ubuntu upgegraded hast
            Immernoch hirsuite !
              weil
              marc91
              @homoran ich dachte das ich mit den befehlen eine neue Ubuntu Version Installiere.
              kann diese denn Updaten ohne das System neu aufzusetzen?
              • M marc91
                nee, damit kann man nur die bestehende Version aktualisieren
                  marc91
                  ok danke!
                  kannst du mir sagen wie oder wo ich nachlesen kann wie ich die veraltete Version erneuern kann?
                  • M marc91
                    ok danke!
                    leider nein!
                    ich nutze ein Release Upgrade immer um mein System neu aufzubauen.
                    Nach ca. 2 Jahren halte ichbdas für angebracht.
                    Backup sichern
                    Neu installieren mit allen aktuellen Versionen
                    Backup wieder herstellen
                    fertig!
                    @Thomas-Braun hat ein Tutorial für Debian geschrieben
                      leider nein!
                      Backup sichern
                      fertig!
                      marc91
                      damit kann ich etwas anfangen.
                      vielen dank für die Hilfe!
                      • M marc91
                        @marc91
                        In die Ubuntu-Falle gelaufen.
                        Andere als die LTS-Versionen haben nur eine Lebenserwartung von 9 Monaten, danach werden die auch Recht zügig von den Servern gekratzt.
                        Installier das aktuelle Debian Bookworm, damit hast du so ca. 2,5 Jahre Ruhe.
                          @marc91
                          marc91
                          Vielen Dank für die Hilfe!
                          System neu aufgesetzt, Benutzer erstellt um nicht weiter als Root etwas zu versaubeuteln und statt Ubuntu Debian Bookworm installiert.
                          Das System läuft nun wieder ohne Probleme.
