  4. [gelöst]Nach Update auf Node 16 startet IOBROKER nicht mehr
    5.4k
65 Beiträge 5 Kommentatoren 8.9k Aufrufe 4 Beobachtet
  • C chemieka
    @thomas-braun sagte in Nach Update auf Node 16 startet IOBROKER nicht mehr:
    cd /opt/iobroker && npm prune
    ok das dauert etwas. MoM
    oberhalb ein paar Warns
    npm WARN skipping integrity check for git dependency ssh://git@github.com/ioBrok                                             er/ioBroker.flot.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node modul                 e, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If y                 ou've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions,                  so you do not need this installed.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it exte                 nds the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now de                 precated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URL                 SearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installe                 d separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regre                 ssion when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.c                 om/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random(                 ) in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for detai                 ls.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issu                 es/3142
    Der Rest läuft bisher ohne Fehler aber läuft noch
    @chemieka
    Mach das Fenster in deinem puTTY breiter.
    Oder verwende ein vernünftiges Terminal.
      @chemieka
      chemieka
      npm WARN cleanup Failed to remove some directories [
      npm WARN cleanup   [
      npm WARN cleanup     '/opt/iobroker/node_modules/iobroker.js-controller',
      npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.js-controller'] {
      npm WARN cleanup       errno: -39,
      npm WARN cleanup       code: 'ENOTEMPTY',
      npm WARN cleanup       syscall: 'rmdir',
      npm WARN cleanup       path: '/opt/iobroker/node_modules/iobroker.js-controller'
      npm WARN cleanup     }
      npm WARN cleanup   ],
      npm WARN cleanup   [
      npm WARN cleanup     }
      npm WARN cleanup   ]
      npm WARN cleanup ]
      npm ERR! git dep preparation failed
      npm ERR! signal SIGINT
      npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
      npm ERR! npm WARN using --force Recommended protections disabled.
      npm ERR!     /home/iobroker/.npm/_logs/2023-06-20T21_11_58_090Z-debug-0.log
      C 1 Antwort Letzte Antwort
      • C chemieka
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        chemieka
        @chemieka
        Schade noch der gleiche Fehler:
        pi@ioBroker-RasPi4:/opt/iobroker $ iob update
        node:internal/modules/cjs/loader:1078
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
            at Module._load (node:internal/modules/cjs/loader:920:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
            at node:internal/main/run_main_module:23:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        Node.js v18.16.0
        • C chemieka
          @chemieka
            throw err;
            requireStack: []
          Node.js v18.16.0
          @chemieka sagte in Nach Update auf Node 16 startet IOBROKER nicht mehr:
          Das ist klar...
          Von iob update hatte ich im übrigen auch nichts geschrieben...
          Vollständige Ausgabe von
          cd /opt/iobroker && npm ls
          sagt nun? (Vollständig heißt von der vollständigen Eingabezeile bis zum abschließenden leeren Prompt).
            Das ist klar...
            chemieka
            Das ist klar...
            pi@ioBroker-RasPi4:~ $ cd /opt/iobroker && npm ls
            npm ERR! code ELSPROBLEMS
            npm ERR! extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
            npm ERR! extraneous: @alcalzone/jsonl-db@2.5.3 /opt/iobroker/node_modules/@alcalzone/jsonl-db
            npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
            npm ERR! extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
            npm ERR! extraneous: @apollon/iobroker-tools@0.2.1 /opt/iobroker/node_modules/@apollon/iobroker-tools
            npm ERR! extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
            npm ERR! extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
            npm ERR! extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
            npm ERR! extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
            npm ERR! extraneous: @greenlock/manager@3.1.0 /opt/iobroker/node_modules/@greenlock/manager
            npm ERR! extraneous: @iobroker/db-base@4.0.24 /opt/iobroker/node_modules/@iobroker/db-base
            npm ERR! extraneous: @iobroker/db-objects-file@4.0.24 /opt/iobroker/node_modules/@iobroker/db-objects-file
            npm ERR! extraneous: @iobroker/db-objects-jsonl@4.0.24 /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
            npm ERR! extraneous: @iobroker/db-objects-redis@4.0.24 /opt/iobroker/node_modules/@iobroker/db-objects-redis
            npm ERR! extraneous: @iobroker/db-states-file@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-file
            npm ERR! extraneous: @iobroker/db-states-jsonl@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
            npm ERR! extraneous: @iobroker/db-states-redis@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-redis
            npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
            npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
            npm ERR! extraneous: @iobroker/js-controller-common-db@4.0.24 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
            npm ERR! extraneous: @iobroker/js-controller-common@4.0.24 /opt/iobroker/node_modules/@iobroker/js-controller-common
            npm ERR! extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
            npm ERR! extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
            npm ERR! extraneous: @iobroker/socket-classes@1.0.2 /opt/iobroker/node_modules/@iobroker/socket-classes
            npm ERR! extraneous: @iobroker/ws-server@2.1.0 /opt/iobroker/node_modules/@iobroker/ws-server
            npm ERR! extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
            npm ERR! extraneous: @root/acme@ /opt/iobroker/node_modules/@root/acme
            npm ERR! extraneous: @root/asn1@1.0.0 /opt/iobroker/node_modules/@root/asn1
            npm ERR! extraneous: @root/csr@0.8.1 /opt/iobroker/node_modules/@root/csr
            npm ERR! extraneous: @root/encoding@1.0.1 /opt/iobroker/node_modules/@root/encoding
            npm ERR! extraneous: @root/greenlock-express@ /opt/iobroker/node_modules/@root/greenlock-express
            npm ERR! extraneous: @root/greenlock@ /opt/iobroker/node_modules/@root/greenlock
            npm ERR! extraneous: @root/keypairs@ /opt/iobroker/node_modules/@root/keypairs
            npm ERR! extraneous: @root/mkdirp@1.0.0 /opt/iobroker/node_modules/@root/mkdirp
            npm ERR! extraneous: @root/pem@1.0.4 /opt/iobroker/node_modules/@root/pem
            npm ERR! extraneous: @root/request@1.9.2 /opt/iobroker/node_modules/@root/request
            npm ERR! extraneous: @root/x509@0.7.2 /opt/iobroker/node_modules/@root/x509
            npm ERR! extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
            npm ERR! extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
            npm ERR! extraneous: @sentry/hub@ /opt/iobroker/node_modules/@sentry/hub
            npm ERR! extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
            npm ERR! extraneous: @sentry/minimal@6.19.7 /opt/iobroker/node_modules/@sentry/minimal
            npm ERR! extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
            npm ERR! extraneous: @sentry/types@7.56.0 /opt/iobroker/node_modules/@sentry/types
            npm ERR! extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
            npm ERR! extraneous: @serialport/binding-mock@10.2.2 /opt/iobroker/node_modules/@serialport/binding-mock
            npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
            npm ERR! extraneous: @serialport/bindings-interface@1.2.2 /opt/iobroker/node_modules/@serialport/bindings-interface
            npm ERR! extraneous: @serialport/parser-byte-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-byte-length
            npm ERR! extraneous: @serialport/parser-cctalk@10.5.0 /opt/iobroker/node_modules/@serialport/parser-cctalk
            npm ERR! extraneous: @serialport/parser-delimiter@10.5.0 /opt/iobroker/node_modules/@serialport/parser-delimiter
            npm ERR! extraneous: @serialport/parser-inter-byte-timeout@10.5.0 /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
            npm ERR! extraneous: @serialport/parser-packet-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-packet-length
            npm ERR! extraneous: @serialport/parser-readline@10.5.0 /opt/iobroker/node_modules/@serialport/parser-readline
            npm ERR! extraneous: @serialport/parser-ready@10.5.0 /opt/iobroker/node_modules/@serialport/parser-ready
            npm ERR! extraneous: @serialport/parser-regex@10.5.0 /opt/iobroker/node_modules/@serialport/parser-regex
            npm ERR! extraneous: @serialport/parser-slip-encoder@10.5.0 /opt/iobroker/node_modules/@serialport/parser-slip-encoder
            npm ERR! extraneous: @serialport/parser-spacepacket@10.5.0 /opt/iobroker/node_modules/@serialport/parser-spacepacket
            npm ERR! extraneous: @serialport/stream@10.5.0 /opt/iobroker/node_modules/@serialport/stream
            npm ERR! extraneous: @sindresorhus/is@5.4.1 /opt/iobroker/node_modules/@sindresorhus/is
            npm ERR! extraneous: @szmarczak/http-timer@5.0.1 /opt/iobroker/node_modules/@szmarczak/http-timer
            npm ERR! extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
            npm ERR! extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
            npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
            npm ERR! extraneous: @types/http-cache-semantics@4.0.1 /opt/iobroker/node_modules/@types/http-cache-semantics
            npm ERR! extraneous: @types/http-proxy@1.17.11 /opt/iobroker/node_modules/@types/http-proxy
            npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
            npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
            npm ERR! extraneous: @types/triple-beam@1.3.2 /opt/iobroker/node_modules/@types/triple-beam
            npm ERR! extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
            npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
            npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/accepts
            npm ERR! extraneous: acme-http-01-standalone@3.0.5 /opt/iobroker/node_modules/acme-http-01-standalone
            npm ERR! extraneous: acorn-globals@7.0.1 /opt/iobroker/node_modules/acorn-globals
            npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
            npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/acorn
            npm ERR! extraneous: after@0.8.2 /opt/iobroker/node_modules/after
            npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/agent-base
            npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/ajv
            npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
            npm ERR! extraneous: alexa-cookie2@4.1.3 /opt/iobroker/node_modules/alexa-cookie2
            npm ERR! extraneous: alexa-remote2@5.10.1 /opt/iobroker/node_modules/alexa-remote2
            npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
            npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
            npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
            npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
            npm ERR! extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
            npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
            npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuffer.slice
            npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
            npm ERR! extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
            npm ERR! extraneous: assert-plus@1.0.0 /opt/iobroker/node_modules/assert-plus
            npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limiter
            npm ERR! extraneous: async@ /opt/iobroker/node_modules/async
            npm ERR! extraneous: asynckit@0.4.0 /opt/iobroker/node_modules/asynckit
            npm ERR! extraneous: at-least-node@1.0.0 /opt/iobroker/node_modules/at-least-node
            npm ERR! extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
            npm ERR! extraneous: aws-sign2@0.7.0 /opt/iobroker/node_modules/aws-sign2
            npm ERR! extraneous: aws4@1.12.0 /opt/iobroker/node_modules/aws4
            npm ERR! extraneous: backo2@1.0.2 /opt/iobroker/node_modules/backo2
            npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
            npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
            npm ERR! extraneous: base64-arraybuffer@0.1.4 /opt/iobroker/node_modules/base64-arraybuffer
            npm ERR! extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
            npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
            npm ERR! extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
            npm ERR! extraneous: bignumber.js@9.1.1 /opt/iobroker/node_modules/bignumber.js
            npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/binary-extensions
            npm ERR! extraneous: binary@0.3.0 /opt/iobroker/node_modules/binary
            npm ERR! extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
            npm ERR! extraneous: binrpc@3.3.1 /opt/iobroker/node_modules/binrpc
            npm ERR! extraneous: bl@4.1.0 /opt/iobroker/node_modules/bl
            npm ERR! extraneous: blob@0.0.5 /opt/iobroker/node_modules/blob
            npm ERR! extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
            npm ERR! extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
            npm ERR! extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
            npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
            npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/braces
            npm ERR! extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
            npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/buffer-from
            npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/buffer
            npm ERR! extraneous: bufferhelper@0.2.1 /opt/iobroker/node_modules/bufferhelper
            npm ERR! extraneous: buffers@0.1.1 /opt/iobroker/node_modules/buffers
            npm ERR! extraneous: busboy@ /opt/iobroker/node_modules/busboy
            npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
            npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
            npm ERR! extraneous: cacheable-lookup@7.0.0 /opt/iobroker/node_modules/cacheable-lookup
            npm ERR! extraneous: cacheable-request@10.2.11 /opt/iobroker/node_modules/cacheable-request
            npm ERR! extraneous: call-bind@1.0.2 /opt/iobroker/node_modules/call-bind
            npm ERR! extraneous: callsite@1.0.0 /opt/iobroker/node_modules/callsite
            npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/camelcase
            npm ERR! extraneous: canvas@ /opt/iobroker/node_modules/canvas
            npm ERR! extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
            npm ERR! extraneous: caseless@0.12.0 /opt/iobroker/node_modules/caseless
            npm ERR! extraneous: cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
            npm ERR! extraneous: chainsaw@0.1.0 /opt/iobroker/node_modules/chainsaw
            npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
            npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/chokidar
            npm ERR! extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
            npm ERR! extraneous: ci-info@3.8.0 /opt/iobroker/node_modules/ci-info
            npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/cliui
            npm ERR! extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
            npm ERR! extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
            npm ERR! extraneous: coap@ /opt/iobroker/node_modules/coap
            npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
            npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
            npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
            npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
            npm ERR! extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
            npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
            npm ERR! extraneous: color@4.2.3 /opt/iobroker/node_modules/color
            npm ERR! extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
            npm ERR! extraneous: combined-stream@1.0.8 /opt/iobroker/node_modules/combined-stream
            npm ERR! extraneous: commist@1.1.0 /opt/iobroker/node_modules/commist
            npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-bind
            npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/component-emitter
            npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/component-inherit
            npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
            npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
            npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
            npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
            npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/concat-stream
            npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
            npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
            npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
            npm ERR! extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
            npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser
            npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/cookie-signature
            npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie
            npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/core-util-is
            npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
            npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/cross-spawn
            npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
            npm ERR! extraneous: crypto-js@4.0.0 /opt/iobroker/node_modules/crypto-js
            npm ERR! extraneous: crypto@1.0.1 /opt/iobroker/node_modules/crypto
            npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
            npm ERR! extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
            npm ERR! extraneous: daemonize2@0.4.2 /opt/iobroker/node_modules/daemonize2
            npm ERR! extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
            npm ERR! extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
            npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/debug
            npm ERR! extraneous: decache@4.6.1 /opt/iobroker/node_modules/decache
            npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize
            npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
            npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
            npm ERR! extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
            npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
            npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
            npm ERR! extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
            npm ERR! extraneous: define-properties@1.2.0 /opt/iobroker/node_modules/define-properties
            npm ERR! extraneous: delayed-stream@1.0.0 /opt/iobroker/node_modules/delayed-stream
            npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
            npm ERR! extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
            npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/depd
            npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
            npm ERR! extraneous: detect-libc@2.0.1 /opt/iobroker/node_modules/detect-libc
            npm ERR! extraneous: dgram@1.0.1 /opt/iobroker/node_modules/dgram
            npm ERR! extraneous: diskusage@1.1.3 /opt/iobroker/node_modules/diskusage
            npm ERR! extraneous: dns-packet@1.3.4 /opt/iobroker/node_modules/dns-packet
            npm ERR! extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
            npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
            npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
            npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/duplexify
            npm ERR! extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
            npm ERR! extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
            npm ERR! extraneous: echarts@4.9.0 /opt/iobroker/node_modules/echarts
            npm ERR! extraneous: eckles@1.4.1 /opt/iobroker/node_modules/eckles
            npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
            npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/emoji-regex
            npm ERR! extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
            npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
            npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
            npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
            npm ERR! extraneous: engine.io-parser@2.2.1 /opt/iobroker/node_modules/engine.io-parser
            npm ERR! extraneous: engine.io@3.6.1 /opt/iobroker/node_modules/engine.io
            npm ERR! extraneous: entities@ /opt/iobroker/node_modules/entities
            npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/error-ex
            npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
            npm ERR! extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
            npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/escalade
            npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
            npm ERR! extraneous: escodegen@2.0.0 /opt/iobroker/node_modules/escodegen
            npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima
            npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/estraverse
            npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
            npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
            npm ERR! extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
            npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/eventemitter3
            npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
            npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
            npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-fileupload
            npm ERR! extraneous: express-session@1.17.3 /opt/iobroker/node_modules/express-session
            npm ERR! extraneous: express@ /opt/iobroker/node_modules/express
            npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/extend
            npm ERR! extraneous: extsprintf@1.3.0 /opt/iobroker/node_modules/extsprintf
            npm ERR! extraneous: eyes@0.1.8 /opt/iobroker/node_modules/eyes
            npm ERR! extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
            npm ERR! extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
            npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
            npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
            npm ERR! extraneous: fast-xml-parser@3.21.1 /opt/iobroker/node_modules/fast-xml-parser
            npm ERR! extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
            npm ERR! extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
            npm ERR! extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
            npm ERR! extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
            npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/fill-range
            npm ERR! extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
            npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/find-up
            npm ERR! extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
            npm ERR! extraneous: follow-redirects@1.15.2 /opt/iobroker/node_modules/follow-redirects
            npm ERR! extraneous: forever-agent@0.6.1 /opt/iobroker/node_modules/forever-agent
            npm ERR! extraneous: form-data-encoder@ /opt/iobroker/node_modules/form-data-encoder
            npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
            npm ERR! extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
            npm ERR! extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
            npm ERR! extraneous: from@0.1.7 /opt/iobroker/node_modules/from
            npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
            npm ERR! extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
            npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
            npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
            npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
            npm ERR! extraneous: function-bind@1.1.1 /opt/iobroker/node_modules/function-bind
            npm ERR! extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
            npm ERR! extraneous: gaxios@5.1.0 /opt/iobroker/node_modules/gaxios
            npm ERR! extraneous: gcp-metadata@5.2.0 /opt/iobroker/node_modules/gcp-metadata
            npm ERR! extraneous: geolocation-utils@ /opt/iobroker/node_modules/geolocation-utils
            npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller-file
            npm ERR! extraneous: get-intrinsic@1.2.1 /opt/iobroker/node_modules/get-intrinsic
            npm ERR! extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
            npm ERR! extraneous: get-stream@6.0.1 /opt/iobroker/node_modules/get-stream
            npm ERR! extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
            npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
            npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
            npm ERR! extraneous: glob@7.2.3 /opt/iobroker/node_modules/glob
            npm ERR! extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
            npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
            npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
            npm ERR! extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
            npm ERR! extraneous: got@ /opt/iobroker/node_modules/got
            npm ERR! extraneous: greenlock-express@4.0.3 /opt/iobroker/node_modules/greenlock-express
            npm ERR! extraneous: greenlock-manager-fs@3.1.1 /opt/iobroker/node_modules/greenlock-manager-fs
            npm ERR! extraneous: greenlock-store-fs@3.2.2 /opt/iobroker/node_modules/greenlock-store-fs
            npm ERR! extraneous: greenlock@4.0.4 /opt/iobroker/node_modules/greenlock
            npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
            npm ERR! extraneous: har-schema@2.0.0 /opt/iobroker/node_modules/har-schema
            npm ERR! extraneous: har-validator@5.1.5 /opt/iobroker/node_modules/har-validator
            npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
            npm ERR! extraneous: has-cors@1.1.0 /opt/iobroker/node_modules/has-cors
            npm ERR! extraneous: has-property-descriptors@1.0.0 /opt/iobroker/node_modules/has-property-descriptors
            npm ERR! extraneous: has-proto@1.0.1 /opt/iobroker/node_modules/has-proto
            npm ERR! extraneous: has-symbols@1.0.3 /opt/iobroker/node_modules/has-symbols
            npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
            npm ERR! extraneous: has@1.0.3 /opt/iobroker/node_modules/has
            npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
            npm ERR! extraneous: help-me@3.0.0 /opt/iobroker/node_modules/help-me
            npm ERR! extraneous: homematic-xmlrpc@1.0.2 /opt/iobroker/node_modules/homematic-xmlrpc
            npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/hosted-git-info
            npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
            npm ERR! extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
            npm ERR! extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
            npm ERR! extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
            npm ERR! extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
            npm ERR! extraneous: http-proxy-middleware@2.0.6 /opt/iobroker/node_modules/http-proxy-middleware
            npm ERR! extraneous: http-proxy-response-rewrite@0.0.1 /opt/iobroker/node_modules/http-proxy-response-rewrite
            npm ERR! extraneous: http-proxy@1.18.1 /opt/iobroker/node_modules/http-proxy
            npm ERR! extraneous: http-signature@1.2.0 /opt/iobroker/node_modules/http-signature
            npm ERR! extraneous: http2-wrapper@ /opt/iobroker/node_modules/http2-wrapper
            npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/https-proxy-agent
            npm ERR! extraneous: https@1.0.0 /opt/iobroker/node_modules/https
            npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/human-signals
            npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
            npm ERR! extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
            npm ERR! extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
            npm ERR! extraneous: indexof@0.0.1 /opt/iobroker/node_modules/indexof
            npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
            npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/inherits
            npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
            npm ERR! extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
            npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/invert-kv
            npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
            npm ERR! invalid: iobroker.alexa2@ /opt/iobroker/node_modules/iobroker.alexa2
            npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
            npm ERR! invalid: iobroker.daswetter@ /opt/iobroker/node_modules/iobroker.daswetter
            npm ERR! invalid: iobroker.dwd@ /opt/iobroker/node_modules/iobroker.dwd
            npm ERR! invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
            npm ERR! invalid: iobroker.fritzbox@ /opt/iobroker/node_modules/iobroker.fritzbox
            npm ERR! invalid: iobroker.history@ /opt/iobroker/node_modules/iobroker.history
            npm ERR! invalid: iobroker.hm-rega@ /opt/iobroker/node_modules/iobroker.hm-rega
            npm ERR! invalid: iobroker.hm-rpc@ /opt/iobroker/node_modules/iobroker.hm-rpc
            npm ERR! invalid: iobroker.hue-extended@ /opt/iobroker/node_modules/iobroker.hue-extended
            npm ERR! invalid: iobroker.hue@ /opt/iobroker/node_modules/iobroker.hue
            npm ERR! invalid: iobroker.iot@ /opt/iobroker/node_modules/iobroker.iot
            npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
            npm ERR! invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR! invalid: iobroker.life360@ /opt/iobroker/node_modules/iobroker.life360
            npm ERR! invalid: iobroker.mihome-vacuum@ /opt/iobroker/node_modules/iobroker.mihome-vacuum
            npm ERR! invalid: iobroker.scenes@ /opt/iobroker/node_modules/iobroker.scenes
            npm ERR! invalid: iobroker.shelly@ /opt/iobroker/node_modules/iobroker.shelly
            npm ERR! extraneous: iobroker.simple-api@ /opt/iobroker/node_modules/iobroker.simple-api
            npm ERR! invalid: iobroker.smartmeter@ /opt/iobroker/node_modules/iobroker.smartmeter
            npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker.socketio
            npm ERR! invalid: iobroker.spotify-premium@ /opt/iobroker/node_modules/iobroker.spotify-premium
            npm ERR! invalid: iobroker.tr-064@ /opt/iobroker/node_modules/iobroker.tr-064
            npm ERR! invalid: iobroker.trashschedule@ /opt/iobroker/node_modules/iobroker.trashschedule
            npm ERR! extraneous: iobroker.type-detector@1.1.2 /opt/iobroker/node_modules/iobroker.type-detector
            npm ERR! invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
            npm ERR! invalid: iobroker.vis-map@ /opt/iobroker/node_modules/iobroker.vis-map
            npm ERR! invalid: iobroker.vis-players@ /opt/iobroker/node_modules/iobroker.vis-players
            npm ERR! invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
            npm ERR! invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
            npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
            npm ERR! extraneous: iobroker.ws@1.3.0 /opt/iobroker/node_modules/iobroker.ws
            npm ERR! extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
            npm ERR! extraneous: ip@1.1.8 /opt/iobroker/node_modules/ip
            npm ERR! extraneous: ipaddr.js@1.9.1 /opt/iobroker/node_modules/ipaddr.js
            npm ERR! extraneous: is-arrayish@0.3.2 /opt/iobroker/node_modules/is-arrayish
            npm ERR! extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
            npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
            npm ERR! extraneous: is-core-module@2.12.1 /opt/iobroker/node_modules/is-core-module
            npm ERR! extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
            npm ERR! extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
            npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
            npm ERR! extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
            npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
            npm ERR! extraneous: is-plain-obj@3.0.0 /opt/iobroker/node_modules/is-plain-obj
            npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
            npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/is-stream
            npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/is-typedarray
            npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/is-utf8
            npm ERR! extraneous: is@3.3.0 /opt/iobroker/node_modules/is
            npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/isarray
            npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/isexe
            npm ERR! extraneous: isstream@0.1.2 /opt/iobroker/node_modules/isstream
            npm ERR! extraneous: jsbn@0.1.1 /opt/iobroker/node_modules/jsbn
            npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
            npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
            npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
            npm ERR! extraneous: json-schema-traverse@0.4.1 /opt/iobroker/node_modules/json-schema-traverse
            npm ERR! extraneous: json-stringify-safe@5.0.1 /opt/iobroker/node_modules/json-stringify-safe
            npm ERR! extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
            npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/jsonc-parser
            npm ERR! extraneous: jsonwebtoken@8.5.1 /opt/iobroker/node_modules/jsonwebtoken
            npm ERR! extraneous: jsprim@1.4.2 /opt/iobroker/node_modules/jsprim
            npm ERR! extraneous: jszip@ /opt/iobroker/node_modules/jszip
            npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
            npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
            npm ERR! extraneous: keypairs@1.2.14 /opt/iobroker/node_modules/keypairs
            npm ERR! extraneous: keyv@4.5.2 /opt/iobroker/node_modules/keyv
            npm ERR! extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
            npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
            npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/lcid
            npm ERR! extraneous: le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
            npm ERR! extraneous: le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
            npm ERR! extraneous: le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
            npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
            npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
            npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
            npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/load-json-file
            npm ERR! extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
            npm ERR! extraneous: localforage@ /opt/iobroker/node_modules/localforage
            npm ERR! extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
            npm ERR! extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
            npm ERR! extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
            npm ERR! extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
            npm ERR! extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
            npm ERR! extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
            npm ERR! extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
            npm ERR! extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
            npm ERR! extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
            npm ERR! extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
            npm ERR! extraneous: logform@ /opt/iobroker/node_modules/logform
            npm ERR! extraneous: long-timeout@0.1.1 /opt/iobroker/node_modules/long-timeout
            npm ERR! extraneous: lowercase-keys@3.0.0 /opt/iobroker/node_modules/lowercase-keys
            npm ERR! extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
            npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
            npm ERR! extraneous: luxon@ /opt/iobroker/node_modules/luxon
            npm ERR! extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
            npm ERR! extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
            npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
            npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
            npm ERR! extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
            npm ERR! extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
            npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/merge-stream
            npm ERR! extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
            npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/micromatch
            npm ERR! extraneous: mime-db@1.52.0 /opt/iobroker/node_modules/mime-db
            npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/mime-types
            npm ERR! extraneous: mime@3.0.0 /opt/iobroker/node_modules/mime
            npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/mimic-fn
            npm ERR! extraneous: mimic-response@4.0.0 /opt/iobroker/node_modules/mimic-response
            npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/minimatch
            npm ERR! extraneous: minimist@ /opt/iobroker/node_modules/minimist
            npm ERR! extraneous: minipass@5.0.0 /opt/iobroker/node_modules/minipass
            npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
            npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
            npm ERR! extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
            npm ERR! extraneous: moment@ /opt/iobroker/node_modules/moment
            npm ERR! extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
            npm ERR! extraneous: mqtt-packet@ /opt/iobroker/node_modules/mqtt-packet
            npm ERR! extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
            npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/ms
            npm ERR! extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
            npm ERR! extraneous: nan@ /opt/iobroker/node_modules/nan
            npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
            npm ERR! extraneous: nearest-color@0.4.4 /opt/iobroker/node_modules/nearest-color
            npm ERR! extraneous: negotiator@0.6.3 /opt/iobroker/node_modules/negotiator
            npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
            npm ERR! extraneous: node-abi@3.45.0 /opt/iobroker/node_modules/node-abi
            npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/node-addon-api
            npm ERR! extraneous: node-fetch@2.6.11 /opt/iobroker/node_modules/node-fetch
            npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
            npm ERR! extraneous: node-gyp-build@4.6.0 /opt/iobroker/node_modules/node-gyp-build
            npm ERR! extraneous: node-hue-api@ /opt/iobroker/node_modules/node-hue-api
            npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
            npm ERR! extraneous: node-rest-client@ /opt/iobroker/node_modules/node-rest-client
            npm ERR! extraneous: node-schedule@2.1.1 /opt/iobroker/node_modules/node-schedule
            npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
            npm ERR! extraneous: node.extend@2.0.2 /opt/iobroker/node_modules/node.extend
            npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
            npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/normalize-package-data
            npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
            npm ERR! extraneous: normalize-url@8.0.0 /opt/iobroker/node_modules/normalize-url
            npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/npm-run-path
            npm ERR! extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
            npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
            npm ERR! extraneous: nwsapi@2.2.5 /opt/iobroker/node_modules/nwsapi
            npm ERR! extraneous: oauth-sign@0.9.0 /opt/iobroker/node_modules/oauth-sign
            npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
            npm ERR! extraneous: object-hash@2.2.0 /opt/iobroker/node_modules/object-hash
            npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/object-inspect
            npm ERR! extraneous: object-keys@1.1.1 /opt/iobroker/node_modules/object-keys
            npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/object.assign
            npm ERR! extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
            npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
            npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/once
            npm ERR! extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
            npm ERR! extraneous: onedrive-api@ /opt/iobroker/node_modules/onedrive-api
            npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/onetime
            npm ERR! extraneous: open-sml@ /opt/iobroker/node_modules/open-sml
            npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
            npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/os-locale
            npm ERR! extraneous: p-cancelable@3.0.0 /opt/iobroker/node_modules/p-cancelable
            npm ERR! extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
            npm ERR! extraneous: pako@ /opt/iobroker/node_modules/pako
            npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/parse-json
            npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/parse5
            npm ERR! extraneous: parseqs@0.0.6 /opt/iobroker/node_modules/parseqs
            npm ERR! extraneous: parseuri@0.0.6 /opt/iobroker/node_modules/parseuri
            npm ERR! extraneous: parseurl@1.3.3 /opt/iobroker/node_modules/parseurl
            npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
            npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
            npm ERR! extraneous: passport@ /opt/iobroker/node_modules/passport
            npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/path-exists
            npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
            npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/path-key
            npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
            npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
            npm ERR! extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
            npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/path-type
            npm ERR! extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
            npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause
            npm ERR! extraneous: performance-now@2.1.0 /opt/iobroker/node_modules/performance-now
            npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
            npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
            npm ERR! extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
            npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/pify
            npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/pinkie-promise
            npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/pinkie
            npm ERR! extraneous: point-in-polygon@1.0.1 /opt/iobroker/node_modules/point-in-polygon
            npm ERR! extraneous: prebuild-install@7.1.1 /opt/iobroker/node_modules/prebuild-install
            npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
            npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
            npm ERR! extraneous: promisify-child-process@4.1.1 /opt/iobroker/node_modules/promisify-child-process
            npm ERR! extraneous: prompt@ /opt/iobroker/node_modules/prompt
            npm ERR! extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
            npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
            npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
            npm ERR! extraneous: put@0.0.6 /opt/iobroker/node_modules/put
            npm ERR! extraneous: qs@ /opt/iobroker/node_modules/qs
            npm ERR! extraneous: querystring@0.2.1 /opt/iobroker/node_modules/querystring
            npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
            npm ERR! extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
            npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
            npm ERR! extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
            npm ERR! extraneous: rasha@1.2.5 /opt/iobroker/node_modules/rasha
            npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
            npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
            npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/read-pkg-up
            npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/read-pkg
            npm ERR! extraneous: read@1.0.7 /opt/iobroker/node_modules/read
            npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
            npm ERR! extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
            npm ERR! extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
            npm ERR! extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
            npm ERR! extraneous: redirect-https@1.3.1 /opt/iobroker/node_modules/redirect-https
            npm ERR! extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
            npm ERR! extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
            npm ERR! extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
            npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
            npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
            npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/require-directory
            npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/require-main-filename
            npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
            npm ERR! extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
            npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/resolve
            npm ERR! extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
            npm ERR! extraneous: responselike@3.0.0 /opt/iobroker/node_modules/responselike
            npm ERR! extraneous: retry-request@4.2.2 /opt/iobroker/node_modules/retry-request
            npm ERR! extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
            npm ERR! extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
            npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
            npm ERR! extraneous: rrule@2.7.2 /opt/iobroker/node_modules/rrule
            npm ERR! extraneous: rrweb-cssom@ /opt/iobroker/node_modules/rrweb-cssom
            npm ERR! extraneous: rsa-compat@1.9.4 /opt/iobroker/node_modules/rsa-compat
            npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/safe-buffer
            npm ERR! extraneous: safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
            npm ERR! extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
            npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
            npm ERR! extraneous: sax@0.4.3 /opt/iobroker/node_modules/sax
            npm ERR! extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
            npm ERR! extraneous: send@0.18.0 /opt/iobroker/node_modules/send
            npm ERR! extraneous: seq-logging@ /opt/iobroker/node_modules/seq-logging
            npm ERR! extraneous: serialport@10.5.0 /opt/iobroker/node_modules/serialport
            npm ERR! extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
            npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
            npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
            npm ERR! extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
            npm ERR! extraneous: sharp@ /opt/iobroker/node_modules/sharp
            npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/shebang-command
            npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/shebang-regex
            npm ERR! extraneous: shelly-iot@1.1.2 /opt/iobroker/node_modules/shelly-iot
            npm ERR! extraneous: side-channel@1.0.4 /opt/iobroker/node_modules/side-channel
            npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/signal-exit
            npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
            npm ERR! extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
            npm ERR! extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
            npm ERR! extraneous: smartmeter-obis@ /opt/iobroker/node_modules/smartmeter-obis
            npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.io-adapter
            npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/socket.io-client
            npm ERR! extraneous: socket.io-parser@3.4.3 /opt/iobroker/node_modules/socket.io-parser
            npm ERR! extraneous: socket.io@2.5.0 /opt/iobroker/node_modules/socket.io
            npm ERR! extraneous: sorted-array-functions@1.3.0 /opt/iobroker/node_modules/sorted-array-functions
            npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/source-map-support
            npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/source-map
            npm ERR! extraneous: spdx-correct@3.2.0 /opt/iobroker/node_modules/spdx-correct
            npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-exceptions
            npm ERR! extraneous: spdx-expression-parse@3.0.1 /opt/iobroker/node_modules/spdx-expression-parse
            npm ERR! extraneous: spdx-license-ids@3.0.13 /opt/iobroker/node_modules/spdx-license-ids
            npm ERR! extraneous: split@1.0.1 /opt/iobroker/node_modules/split
            npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/split2
            npm ERR! extraneous: sshpk@ /opt/iobroker/node_modules/sshpk
            npm ERR! extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
            npm ERR! extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
            npm ERR! extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
            npm ERR! extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
            npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/stream-shift
            npm ERR! extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
            npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/string_decoder
            npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/string-width
            npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
            npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/strip-bom
            npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/strip-final-newline
            npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
            npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
            npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
            npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
            npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
            npm ERR! extraneous: tar-fs@ /opt/iobroker/node_modules/tar-fs
            npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
            npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
            npm ERR! extraneous: tcp-ping@0.1.1 /opt/iobroker/node_modules/tcp-ping
            npm ERR! extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
            npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/through
            npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
            npm ERR! extraneous: to-array@0.1.4 /opt/iobroker/node_modules/to-array
            npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
            npm ERR! extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
            npm ERR! extraneous: tough-cookie@4.1.3 /opt/iobroker/node_modules/tough-cookie
            npm ERR! extraneous: tr-064@0.2.0 /opt/iobroker/node_modules/tr-064
            npm ERR! extraneous: tr-O64@0.2.4 /opt/iobroker/node_modules/tr-O64
            npm ERR! extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
            npm ERR! extraneous: traverse@0.3.9 /opt/iobroker/node_modules/traverse
            npm ERR! extraneous: treemap-js@1.2.1 /opt/iobroker/node_modules/treemap-js
            npm ERR! extraneous: triple-beam@1.3.0 /opt/iobroker/node_modules/triple-beam
            npm ERR! extraneous: tunnel-agent@0.6.0 /opt/iobroker/node_modules/tunnel-agent
            npm ERR! extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
            npm ERR! extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
            npm ERR! extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
            npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
            npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/typescript
            npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
            npm ERR! extraneous: ultron@1.1.1 /opt/iobroker/node_modules/ultron
            npm ERR! extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
            npm ERR! extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
            npm ERR! extraneous: uri-js@ /opt/iobroker/node_modules/uri-js
            npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
            npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
            npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
            npm ERR! extraneous: ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
            npm ERR! extraneous: util-deprecate@1.0.2 /opt/iobroker/node_modules/util-deprecate
            npm ERR! extraneous: utils-merge@1.0.1 /opt/iobroker/node_modules/utils-merge
            npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/validate-npm-package-license
            npm ERR! extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
            npm ERR! extraneous: verror@1.10.0 /opt/iobroker/node_modules/verror
            npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
            npm ERR! extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
            npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
            npm ERR! extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
            npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
            npm ERR! extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
            npm ERR! extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
            npm ERR! extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
            npm ERR! extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
            npm ERR! extraneous: whatwg-url@ /opt/iobroker/node_modules/whatwg-url
            npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/which-module
            npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/which
            npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
            npm ERR! extraneous: winston-daily-rotate-file@4.7.1 /opt/iobroker/node_modules/winston-daily-rotate-file
            npm ERR! extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
            npm ERR! extraneous: winston-syslog@2.7.0 /opt/iobroker/node_modules/winston-syslog
            npm ERR! extraneous: winston-transport@4.5.0 /opt/iobroker/node_modules/winston-transport
            npm ERR! extraneous: winston@ /opt/iobroker/node_modules/winston
            npm ERR! extraneous: word-wrap@1.2.3 /opt/iobroker/node_modules/word-wrap
            npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/wrap-ansi
            npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
            npm ERR! extraneous: ws@ /opt/iobroker/node_modules/ws
            npm ERR! extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
            npm ERR! extraneous: xml2js@0.4.23 /opt/iobroker/node_modules/xml2js
            npm ERR! extraneous: xml2json-light@1.0.6 /opt/iobroker/node_modules/xml2json-light
            npm ERR! extraneous: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
            npm ERR! extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
            npm ERR! extraneous: xmlhttprequest-ssl@1.6.3 /opt/iobroker/node_modules/xmlhttprequest-ssl
            npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
            npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
            npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/y18n
            npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
            npm ERR! extraneous: yargs-parser@5.0.1 /opt/iobroker/node_modules/yargs-parser
            npm ERR! invalid: yargs@ /opt/iobroker/node_modules/yargs
            npm ERR! extraneous: yeast@0.1.2 /opt/iobroker/node_modules/yeast
            npm ERR! extraneous: zlib@1.0.5 /opt/iobroker/node_modules/zlib
            npm ERR! extraneous: zrender@4.3.2 /opt/iobroker/node_modules/zrender
            iobroker.inst@2.0.3 /opt/iobroker
            ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
            ├── @alcalzone/jsonl-db@2.5.3 extraneous
            ├── @alcalzone/pak@ extraneous
            ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
            ├── @apollon/iobroker-tools@0.2.1 extraneous
            ├── @colors/colors@ extraneous
            ├── @dabh/diagnostics@ extraneous
            ├── @datalust/winston-seq@1.0.2 extraneous
            ├── @googleapis/drive@5.1.0 extraneous
            ├── @greenlock/manager@3.1.0 extraneous
            ├── @iobroker/db-base@4.0.24 extraneous
            ├── @iobroker/db-objects-file@4.0.24 extraneous
            ├── @iobroker/db-objects-jsonl@4.0.24 extraneous
            ├── @iobroker/db-objects-redis@4.0.24 extraneous
            ├── @iobroker/db-states-file@4.0.24 extraneous
            ├── @iobroker/db-states-jsonl@4.0.24 extraneous
            ├── @iobroker/db-states-redis@4.0.24 extraneous
            ├── @iobroker/js-controller-adapter@ extraneous
            ├── @iobroker/js-controller-cli@ extraneous
            ├── @iobroker/js-controller-common-db@4.0.24 extraneous
            ├── @iobroker/js-controller-common@4.0.24 extraneous
            ├── @iobroker/plugin-base@1.2.1 extraneous
            ├── @iobroker/plugin-sentry@1.2.1 extraneous
            ├── @iobroker/socket-classes@1.0.2 extraneous
            ├── @iobroker/ws-server@2.1.0 extraneous
            ├── @mapbox/node-pre-gyp@ extraneous
            ├── @root/acme@ extraneous
            ├── @root/asn1@1.0.0 extraneous
            ├── @root/csr@0.8.1 extraneous
            ├── @root/encoding@1.0.1 extraneous
            ├── @root/greenlock-express@ extraneous
            ├── @root/greenlock@ extraneous
            ├── @root/keypairs@ extraneous
            ├── @root/mkdirp@1.0.0 extraneous
            ├── @root/pem@1.0.4 extraneous
            ├── @root/request@1.9.2 extraneous
            ├── @root/x509@0.7.2 extraneous
            ├── @sentry-internal/tracing@ extraneous
            ├── @sentry/core@ extraneous
            ├── @sentry/hub@ extraneous
            ├── @sentry/integrations@ extraneous
            ├── @sentry/minimal@6.19.7 extraneous
            ├── @sentry/node@ extraneous
            ├── @sentry/types@7.56.0 extraneous
            ├── @sentry/utils@ extraneous
            ├── @serialport/binding-mock@10.2.2 extraneous
            ├── @serialport/bindings-cpp@ extraneous
            ├── @serialport/bindings-interface@1.2.2 extraneous
            ├── @serialport/parser-byte-length@10.5.0 extraneous
            ├── @serialport/parser-cctalk@10.5.0 extraneous
            ├── @serialport/parser-delimiter@10.5.0 extraneous
            ├── @serialport/parser-inter-byte-timeout@10.5.0 extraneous
            ├── @serialport/parser-packet-length@10.5.0 extraneous
            ├── @serialport/parser-readline@10.5.0 extraneous
            ├── @serialport/parser-ready@10.5.0 extraneous
            ├── @serialport/parser-regex@10.5.0 extraneous
            ├── @serialport/parser-slip-encoder@10.5.0 extraneous
            ├── @serialport/parser-spacepacket@10.5.0 extraneous
            ├── @serialport/stream@10.5.0 extraneous
            ├── @sindresorhus/is@5.4.1 extraneous
            ├── @szmarczak/http-timer@5.0.1 extraneous
            ├── @tootallnate/once@2.0.0 extraneous
            ├── @types/bl@5.1.0 extraneous
            ├── @types/caseless@0.12.2 extraneous
            ├── @types/http-cache-semantics@4.0.1 extraneous
            ├── @types/http-proxy@1.17.11 extraneous
            ├── @types/request@2.48.8 extraneous
            ├── @types/tough-cookie@4.0.2 extraneous
            ├── @types/triple-beam@1.3.2 extraneous
            • C chemieka
              @thomas-braun sagte in Nach Update auf Node 16 startet IOBROKER nicht mehr:
              Das ist klar...
              chemieka
              @chemieka
              ├── abab@2.0.6 extraneous
              ├── abbrev@1.1.1 extraneous
              ├── accepts@1.3.8 extraneous
              ├── acme-http-01-standalone@3.0.5 extraneous
              ├── acorn-globals@7.0.1 extraneous
              ├── acorn-walk@8.2.0 extraneous
              ├── acorn@ extraneous
              ├── after@0.8.2 extraneous
              ├── agent-base@6.0.2 extraneous
              ├── ajv@ extraneous
              ├── alcalzone-shared@ extraneous
              ├── alexa-cookie2@4.1.3 extraneous
              ├── alexa-remote2@5.10.1 extraneous
              ├── ansi-regex@5.0.1 extraneous
              ├── ansi-styles@4.3.0 extraneous
              ├── anymatch@3.1.3 extraneous
              ├── aproba@2.0.0 extraneous
              ├── are-we-there-yet@2.0.0 extraneous
              ├── array-flatten@1.1.1 extraneous
              ├── arraybuffer.slice@0.0.7 extraneous
              ├── arrify@2.0.1 extraneous
              ├── asn1@0.2.6 extraneous
              ├── assert-plus@1.0.0 extraneous
              ├── async-limiter@1.0.1 extraneous
              ├── async@ extraneous
              ├── asynckit@0.4.0 extraneous
              ├── at-least-node@1.0.0 extraneous
              ├── aws-iot-device-sdk@ extraneous
              ├── aws-sign2@0.7.0 extraneous
              ├── aws4@1.12.0 extraneous
              ├── backo2@1.0.2 extraneous
              ├── balanced-match@1.0.2 extraneous
              ├── base-64@1.0.0 extraneous
              ├── base64-arraybuffer@0.1.4 extraneous
              ├── base64-js@1.5.1 extraneous
              ├── base64id@2.0.0 extraneous
              ├── bcrypt-pbkdf@1.0.2 extraneous
              ├── bignumber.js@9.1.1 extraneous
              ├── binary-extensions@2.2.0 extraneous
              ├── binary@0.3.0 extraneous
              ├── bindings@1.5.0 extraneous
              ├── binrpc@3.3.1 extraneous
              ├── bl@4.1.0 extraneous
              ├── blob@0.0.5 extraneous
              ├── bluebird@3.7.2 extraneous
              ├── body-parser@1.20.2 extraneous
              ├── bottleneck@2.19.5 extraneous
              ├── brace-expansion@1.1.11 extraneous
              ├── braces@3.0.2 extraneous
              ├── buffer-equal-constant-time@1.0.1 extraneous
              ├── buffer-from@1.1.2 extraneous
              ├── buffer@5.7.1 extraneous
              ├── bufferhelper@0.2.1 extraneous
              ├── buffers@0.1.1 extraneous
              ├── busboy@ extraneous
              ├── byte-length@1.0.2 extraneous
              ├── bytes@3.1.2 extraneous
              ├── cacheable-lookup@7.0.0 extraneous
              ├── cacheable-request@10.2.11 extraneous
              ├── call-bind@1.0.2 extraneous
              ├── callsite@1.0.0 extraneous
              ├── camelcase@3.0.0 extraneous
              ├── canvas@ extraneous
              ├── capitalize@2.0.4 extraneous
              ├── caseless@0.12.0 extraneous
              ├── cert-info@1.5.1 extraneous
              ├── chainsaw@0.1.0 extraneous
              ├── charenc@0.0.2 extraneous
              ├── chokidar@3.5.3 extraneous
              ├── chownr@2.0.0 extraneous
              ├── ci-info@3.8.0 extraneous
              ├── cliui@3.2.0 extraneous
              ├── cluster-key-slot@1.1.2 extraneous
              ├── coap-packet@1.1.1 extraneous
              ├── coap@ extraneous
              ├── code-point-at@1.1.0 extraneous
              ├── coffeescript@1.12.7 extraneous
              ├── color-convert@2.0.1 extraneous
              ├── color-name@1.1.4 extraneous
              ├── color-string@1.9.1 extraneous
              ├── color-support@1.1.3 extraneous
              ├── color@4.2.3 extraneous
              ├── colors@1.4.0
              ├── colorspace@1.1.4 extraneous
              ├── combined-stream@1.0.8 extraneous
              ├── commist@1.1.0 extraneous
              ├── component-bind@1.0.0 extraneous
              ├── component-emitter@1.3.0 extraneous
              ├── component-inherit@0.0.3 extraneous
              ├── compress-json@2.1.2 extraneous
              ├── compressible@2.0.18 extraneous
              ├── compression@1.7.4 extraneous
              ├── concat-map@0.0.1 extraneous
              ├── concat-stream@1.6.2 extraneous
              ├── connect-flash@0.1.1 extraneous
              ├── console-control-strings@1.1.0 extraneous
              ├── content-disposition@0.5.4 extraneous
              ├── content-type@1.0.5 extraneous
              ├── cookie-parser@1.4.6 extraneous
              ├── cookie-signature@1.0.6 extraneous
              ├── cookie@0.4.1 extraneous
              ├── core-util-is@1.0.3 extraneous
              ├── cron-parser@ extraneous
              ├── cross-spawn@7.0.3 extraneous
              ├── crypt@0.0.2 extraneous
              ├── crypto-js@4.0.0 extraneous
              ├── crypto@1.0.1 extraneous
              ├── cssstyle@ extraneous
              ├── cycle@1.0.3 extraneous
              ├── daemonize2@0.4.2 extraneous
              ├── dashdash@1.14.1 extraneous
              ├── data-urls@4.0.0 extraneous
              ├── debug@2.6.9 extraneous
              ├── decache@4.6.1 extraneous
              ├── decamelize@1.2.0 extraneous
              ├── decimal.js@10.4.3 extraneous
              ├── decompress-response@6.0.0 extraneous
              ├── deep-clone@3.0.3 extraneous
              ├── deep-extend@0.6.0 extraneous
              ├── deep-is@0.1.4 extraneous
              ├── defer-to-connect@2.0.1 extraneous
              ├── define-properties@1.2.0 extraneous
              ├── delayed-stream@1.0.0 extraneous
              ├── delegates@1.0.0 extraneous
              ├── denque@1.5.1 extraneous
              ├── depd@2.0.0 extraneous
              ├── destroy@1.2.0 extraneous
              ├── detect-libc@2.0.1 extraneous
              ├── dgram@1.0.1 extraneous
              ├── diskusage@1.1.3 extraneous
              ├── dns-packet@1.3.4 extraneous
              ├── domexception@4.0.0 extraneous
              ├── dropbox-v2-api@ extraneous
              ├── duplexer@0.1.2 extraneous
              ├── duplexify@4.1.2 extraneous
              ├── ecc-jsbn@0.1.2 extraneous
              ├── ecdsa-sig-formatter@1.0.11 extraneous
              ├── echarts@4.9.0 extraneous
              ├── eckles@1.4.1 extraneous
              ├── ee-first@1.1.1 extraneous
              ├── emoji-regex@8.0.0 extraneous
              ├── enabled@2.0.0 extraneous
              ├── encodeurl@1.0.2 extraneous
              ├── end-of-stream@1.4.4 extraneous
              ├── engine.io-client@ extraneous
              ├── engine.io-parser@2.2.1 extraneous
              ├── engine.io@3.6.1 extraneous
              ├── entities@ extraneous
              ├── error-ex@1.3.2 extraneous
              ├── es6-promise@4.2.8 extraneous
              ├── esbuild@0.11.23 extraneous
              ├── escalade@3.1.1 extraneous
              ├── escape-html@1.0.3 extraneous
              ├── escodegen@2.0.0 extraneous
              ├── esprima@4.0.1 extraneous
              ├── estraverse@5.3.0 extraneous
              ├── esutils@2.0.3 extraneous
              ├── etag@1.8.1 extraneous
              ├── event-stream@4.0.1 extraneous
              ├── eventemitter3@4.0.7 extraneous
              ├── execa@5.1.1 extraneous
              ├── expand-template@2.0.3 extraneous
              ├── express-fileupload@ extraneous
              ├── express-session@1.17.3 extraneous
              ├── express@ extraneous
              ├── extend@3.0.2 extraneous
              ├── extsprintf@1.3.0 extraneous
              ├── eyes@0.1.8 extraneous
              ├── fast-deep-equal@3.1.3 extraneous
              ├── fast-json-stable-stringify@2.1.0 extraneous
              ├── fast-levenshtein@2.0.6 extraneous
              ├── fast-text-encoding@1.0.6 extraneous
              ├── fast-xml-parser@3.21.1 extraneous
              ├── fastseries@2.0.0 extraneous
              ├── fecha@4.2.3 extraneous
              ├── file-stream-rotator@0.6.1 extraneous
              ├── file-uri-to-path@1.0.0 extraneous
              ├── fill-range@7.0.1 extraneous
              ├── finalhandler@1.2.0 extraneous
              ├── find-up@1.1.2 extraneous
              ├── fn.name@1.1.0 extraneous
              ├── follow-redirects@1.15.2 extraneous
              ├── forever-agent@0.6.1 extraneous
              ├── form-data-encoder@ extraneous
              ├── form-data@4.0.0 extraneous
              ├── forwarded@0.2.0 extraneous
              ├── fresh@0.5.2 extraneous
              ├── from@0.1.7 extraneous
              ├── fs-constants@1.0.0 extraneous
              ├── fs-extra@7.0.1
              ├── fs-minipass@2.1.0 extraneous
              ├── fs.realpath@1.0.0 extraneous
              ├── fsevents@ extraneous
              ├── ftp@0.3.10 extraneous
              ├── function-bind@1.1.1 extraneous
              ├── gauge@3.0.2 extraneous
              ├── gaxios@5.1.0 extraneous
              ├── gcp-metadata@5.2.0 extraneous
              ├── geolocation-utils@ extraneous
              ├── get-caller-file@1.0.3 extraneous
              ├── get-intrinsic@1.2.1 extraneous
              ├── get-ssl-certificate@2.3.3 extraneous
              ├── get-stream@6.0.1 extraneous
              ├── getpass@0.1.7 extraneous
              ├── github-from-package@0.0.0 extraneous
              ├── glob-parent@5.1.2 extraneous
              ├── glob@7.2.3 extraneous
              ├── glossy@0.1.7 extraneous
              ├── google-auth-library@ extraneous
              ├── google-p12-pem@4.0.1 extraneous
              ├── googleapis-common@6.0.4 extraneous
              ├── got@ extraneous
              ├── greenlock-express@4.0.3 extraneous
              ├── greenlock-manager-fs@3.1.1 extraneous
              ├── greenlock-store-fs@3.2.2 extraneous
              ├── greenlock@4.0.4 extraneous
              ├── gtoken@6.1.2 extraneous
              ├── har-schema@2.0.0 extraneous
              ├── har-validator@5.1.5 extraneous
              ├── has-binary2@1.0.3 extraneous
              ├── has-cors@1.1.0 extraneous
              ├── has-property-descriptors@1.0.0 extraneous
              ├── has-proto@1.0.1 extraneous
              ├── has-symbols@1.0.3 extraneous
              ├── has-unicode@2.0.1 extraneous
              ├── has@1.0.3 extraneous
              ├── he@1.2.0 extraneous
              ├── help-me@3.0.0 extraneous
              ├── homematic-xmlrpc@1.0.2 extraneous
              ├── hosted-git-info@2.8.9 extraneous
              ├── hot-patcher@1.0.0 extraneous
              ├── html-encoding-sniffer@3.0.0 extraneous
              ├── http-cache-semantics@4.1.1 extraneous
              ├── http-errors@2.0.0 extraneous
              ├── http-proxy-agent@5.0.0 extraneous
              ├── http-proxy-middleware@2.0.6 extraneous
              ├── http-proxy-response-rewrite@0.0.1 extraneous
              ├── http-proxy@1.18.1 extraneous
              ├── http-signature@1.2.0 extraneous
              ├── http2-wrapper@ extraneous
              ├── https-proxy-agent@5.0.1 extraneous
              ├── https@1.0.0 extraneous
              ├── human-signals@2.1.0 extraneous
              ├── iconv-lite@0.4.24 extraneous
              ├── ieee754@1.2.1 extraneous
              ├── immediate@3.0.6 extraneous
              ├── indexof@0.0.1 extraneous
              ├── inflight@1.0.6 extraneous
              ├── inherits@2.0.4 extraneous
              ├── ini@1.3.8 extraneous
              ├── int64-buffer@1.0.1 extraneous
              ├── invert-kv@1.0.0 extraneous
              ├── iobroker.admin@ invalid: "6.3.5" from the root project
              ├── iobroker.alexa2@ invalid: "3.23.2" from the root project
              ├── iobroker.backitup@ invalid: "2.6.23" from the root project
              ├── iobroker.daswetter@ invalid: "3.1.8" from the root project
              ├── iobroker.dwd@ invalid: "2.8.3" from the root project
              ├── iobroker.flot@ invalid: "github:ioBroker/ioBroker.flot#f112917fab740b1ac72739496395a682d4d6d41e" from the root project
              ├── iobroker.fritzbox@ invalid: "^0.5.0" from the root project
              ├── iobroker.harmony@1.2.2
              ├── iobroker.history@ invalid: "2.2.4" from the root project
              ├── iobroker.hm-rega@ invalid: "3.0.46" from the root project
              ├── iobroker.hm-rpc@ invalid: "1.15.16" from the root project
              ├── iobroker.hue-extended@ invalid: "2.0.0" from the root project
              ├── iobroker.hue@ invalid: "3.7.1" from the root project
              ├── iobroker.ical@1.13.2
              ├── iobroker.iot@ invalid: "1.14.5" from the root project
              ├── iobroker.javascript@ invalid: "7.0.3" from the root project
              ├── iobroker.js-controller@ invalid: "4.0.24" from the root project
              ├── iobroker.life360@ invalid: "github:MiGoller/ioBroker.life360#master" from the root project
              ├── iobroker.mihome-vacuum@ invalid: "3.11.0" from the root project
              ├── iobroker.pushover@3.0.3
              ├── iobroker.scenes@ invalid: "2.3.9" from the root project
              ├── iobroker.shelly@ invalid: "github:iobroker-community-adapters/ioBroker.shelly" from the root project
              ├── iobroker.simple-api@ extraneous
              ├── iobroker.smartmeter@ invalid: "3.3.4" from the root project
              ├── iobroker.socketio@4.2.0 extraneous
              ├── iobroker.spotify-premium@ invalid: "1.2.1" from the root project
              ├── iobroker.tr-064@ invalid: "4.2.18" from the root project
              ├── iobroker.trashschedule@ invalid: "2.2.0" from the root project
              ├── iobroker.type-detector@1.1.2 extraneous
              ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
              ├── iobroker.vis-history@1.0.0
              ├── iobroker.vis-map@ invalid: "1.0.4" from the root project
              ├── iobroker.vis-players@ invalid: "0.1.6" from the root project
              ├── iobroker.vis@ invalid: "1.4.16" from the root project
              ├── iobroker.web@ invalid: "4.3.0" from the root project
              ├── iobroker.ws.server@1.0.1 extraneous
              ├── iobroker.ws@1.3.0 extraneous
              ├── iobroker@2.0.3
              ├── ioredis@ extraneous
              ├── ip@1.1.8 extraneous
              ├── ipaddr.js@1.9.1 extraneous
              ├── is-arrayish@0.3.2 extraneous
              ├── is-binary-path@2.1.0 extraneous
              ├── is-buffer@1.1.6 extraneous
              ├── is-core-module@2.12.1 extraneous
              ├── is-empty-object@1.1.1 extraneous
              ├── is-extglob@2.1.1 extraneous
              ├── is-fullwidth-code-point@3.0.0 extraneous
              ├── is-glob@4.0.3 extraneous
              ├── is-number@7.0.0 extraneous
              ├── is-plain-obj@3.0.0 extraneous
              ├── is-potential-custom-element-name@1.0.1 extraneous
              ├── is-stream@2.0.1 extraneous
              ├── is-typedarray@1.0.0 extraneous
              ├── is-utf8@0.2.1 extraneous
              ├── is@3.3.0 extraneous
              ├── isarray@1.0.0 extraneous
              ├── isexe@2.0.0 extraneous
              ├── isstream@0.1.2 extraneous
              ├── jsbn@0.1.1 extraneous
              ├── jsdom@ extraneous
              ├── json-bigint@1.0.0 extraneous
              ├── json-buffer@3.0.1 extraneous
              ├── json-schema-traverse@0.4.1 extraneous
              ├── json-stringify-safe@5.0.1 extraneous
              ├── jsonata@ extraneous
              ├── jsonc-parser@ extraneous
              ├── jsonwebtoken@8.5.1 extraneous
              ├── jsprim@1.4.2 extraneous
              ├── jszip@ extraneous
              ├── jwa@2.0.0 extraneous
              ├── jws@4.0.0 extraneous
              ├── keypairs@1.2.14 extraneous
              ├── keyv@4.5.2 extraneous
              ├── kuler@2.0.0 extraneous
              ├── layerr@0.1.2 extraneous
              ├── lcid@1.0.0 extraneous
              ├── le-acme-core@2.1.4 extraneous
              ├── le-challenge-fs@2.0.9 extraneous
              ├── le-sni-auto@2.1.9 extraneous
              ├── leven@2.1.0 extraneous
              ├── levn@0.3.0 extraneous
              ├── lie@3.3.0 extraneous
              ├── load-json-file@1.1.0 extraneous
              ├── loadavg-windows@1.1.1 extraneous
              ├── localforage@ extraneous
              ├── lodash.defaults@4.2.0 extraneous
              ├── lodash.flatten@4.4.0 extraneous
              ├── lodash.includes@4.3.0 extraneous
              ├── lodash.isarguments@3.1.0 extraneous
              ├── lodash.isboolean@3.0.3 extraneous
              ├── lodash.isinteger@4.0.4 extraneous
              ├── lodash.isnumber@3.0.3 extraneous
              ├── lodash.isplainobject@4.0.6 extraneous
              ├── lodash.isstring@4.0.1 extraneous
              ├── lodash.once@4.1.1 extraneous
              ├── logform@ extraneous
              ├── long-timeout@0.1.1 extraneous
              ├── lowercase-keys@3.0.0 extraneous
              ├── lru_map@0.3.3 extraneous
              ├── lru-cache@6.0.0 extraneous
              ├── luxon@ extraneous
              ├── make-dir@3.1.0 extraneous
              ├── map-stream@0.0.7 extraneous
              ├── md5@2.3.0 extraneous
              ├── mdns-discovery@0.2.6 extraneous
              ├── media-typer@0.3.0 extraneous
              ├── merge-descriptors@1.0.1 extraneous
              ├── merge-stream@2.0.0 extraneous
              ├── methods@1.1.2 extraneous
              ├── micromatch@4.0.5 extraneous
              ├── mime-db@1.52.0 extraneous
              ├── mime-types@2.1.35 extraneous
              ├── mime@3.0.0 extraneous
              ├── mimic-fn@2.1.0 extraneous
              ├── mimic-response@4.0.0 extraneous
              ├── minimatch@3.1.2 extraneous
              ├── minimist@ extraneous
              ├── minipass@5.0.0 extraneous
              ├── minizlib@2.1.2 extraneous
              ├── mkdirp-classic@0.5.3 extraneous
              ├── mkdirp@1.0.4 extraneous
              ├── moment@ extraneous
              ├── mqtt-connection@4.1.0 extraneous
              ├── mqtt-packet@ extraneous
              ├── mqtt@ extraneous
              ├── ms@2.0.0 extraneous
              ├── mute-stream@0.0.8 extraneous
              ├── nan@ extraneous
              ├── napi-build-utils@1.0.2 extraneous
              ├── nearest-color@0.4.4 extraneous
              ├── negotiator@0.6.3 extraneous
              ├── nested-property@4.0.0 extraneous
              ├── node-abi@3.45.0 extraneous
              ├── node-addon-api@ extraneous
              ├── node-fetch@2.6.11 extraneous
              ├── node-forge@ extraneous
              ├── node-gyp-build@4.6.0 extraneous
              ├── node-hue-api@ extraneous
              ├── node-inspect@2.0.0 extraneous
              ├── node-rest-client@ extraneous
              ├── node-schedule@2.1.1 extraneous
              ├── node-wol@0.1.1 extraneous
              ├── node.extend@2.0.2 extraneous
              ├── nopt@5.0.0 extraneous
              ├── normalize-package-data@2.5.0 extraneous
              ├── normalize-path@3.0.0 extraneous
              ├── normalize-url@8.0.0 extraneous
              ├── npm-run-path@4.0.1 extraneous
              ├── npmlog@5.0.1 extraneous
              ├── number-is-nan@1.0.1 extraneous
              ├── nwsapi@2.2.5 extraneous
              ├── oauth-sign@0.9.0 extraneous
              ├── object-assign@4.1.1 extraneous
              ├── object-hash@2.2.0 extraneous
              ├── object-inspect@ extraneous
              ├── object-keys@1.1.1 extraneous
              ├── object.assign@ extraneous
              ├── on-finished@2.4.1 extraneous
              ├── on-headers@1.0.2 extraneous
              ├── once@1.4.0 extraneous
              ├── one-time@1.0.0 extraneous
              ├── onedrive-api@ extraneous
              ├── onetime@5.1.2 extraneous
              ├── open-sml@ extraneous
              ├── optionator@0.8.3 extraneous
              ├── os-locale@1.4.0 extraneous
              ├── p-cancelable@3.0.0 extraneous
              ├── p-map@2.1.0 extraneous
              ├── pako@ extraneous
              ├── parse-json@2.2.0 extraneous
              ├── parse5@ extraneous
              ├── parseqs@0.0.6 extraneous
              ├── parseuri@0.0.6 extraneous
              ├── parseurl@1.3.3 extraneous
              ├── passport-local@1.0.0 extraneous
              ├── passport-strategy@1.0.0 extraneous
              ├── passport@ extraneous
              ├── path-exists@2.1.0 extraneous
              ├── path-is-absolute@1.0.1 extraneous
              ├── path-key@3.1.1 extraneous
              ├── path-parse@1.0.7 extraneous
              ├── path-posix@1.0.0 extraneous
              ├── path-to-regexp@0.1.7 extraneous
              ├── path-type@1.1.0 extraneous
              ├── pause-stream@0.0.11 extraneous
              ├── pause@0.0.1 extraneous
              ├── performance-now@2.1.0 extraneous
              ├── picocolors@1.0.0 extraneous
              ├── picomatch@2.3.1 extraneous
              ├── pidusage@3.0.2 extraneous
              ├── pify@2.3.0 extraneous
              ├── pinkie-promise@2.0.1 extraneous
              ├── pinkie@2.0.4 extraneous
              ├── point-in-polygon@1.0.1 extraneous
              ├── prebuild-install@7.1.1 extraneous
              ├── prelude-ls@1.1.2 extraneous
              ├── process-nextick-args@2.0.1 extraneous
              ├── promisify-child-process@4.1.1 extraneous
              ├── prompt@ extraneous
              ├── proxy-addr@2.0.7 extraneous
              ├── proxy-from-env@1.1.0 extraneous
              ├── pump@3.0.0 extraneous
              ├── put@0.0.6 extraneous
              ├── qs@ extraneous
              ├── querystring@0.2.1 extraneous
              ├── querystringify@2.2.0 extraneous
              ├── quick-lru@5.1.1 extraneous
              ├── random-bytes@1.0.0 extraneous
              ├── range-parser@1.2.1 extraneous
              ├── rasha@1.2.5 extraneous
              ├── raw-body@2.5.2 extraneous
              ├── rc@1.2.8 extraneous
              ├── read-pkg-up@1.0.1 extraneous
              ├── read-pkg@1.1.0 extraneous
              ├── read@1.0.7 extraneous
              ├── readable-stream@ extraneous
              ├── readdirp@3.6.0 extraneous
              ├── readline-sync@1.4.10 extraneous
              ├── readline@1.3.0 extraneous
              ├── redirect-https@1.3.1 extraneous
              ├── redis-commands@1.7.0 extraneous
              ├── redis-errors@1.2.0 extraneous
              ├── redis-parser@3.0.0 extraneous
              ├── reinterval@1.1.0 extraneous
              ├── request-promise@4.2.6 extraneous
              ├── require-directory@2.1.1 extraneous
              ├── require-main-filename@1.0.1 extraneous
              ├── requires-port@1.0.0 extraneous
              ├── resolve-alpn@1.2.1 extraneous
              ├── resolve@ extraneous
              ├── respjs@4.2.0 extraneous
              ├── responselike@3.0.0 extraneous
              ├── retry-request@4.2.2 extraneous
              ├── retry@0.12.0 extraneous
              ├── revalidator@0.1.8 extraneous
              ├── rimraf@3.0.2 extraneous
              ├── rrule@2.7.2 extraneous
              ├── rrweb-cssom@ extraneous
              ├── rsa-compat@1.9.4 extraneous
              ├── safe-buffer@5.1.2 extraneous
              ├── safe-replace@1.1.0 extraneous
              ├── safe-stable-stringify@2.4.3 extraneous
              ├── safer-buffer@2.1.2 extraneous
              ├── sax@0.4.3 extraneous
              ├── saxes@6.0.0 extraneous
              ├── semver@5.7.1
              ├── send@0.18.0 extraneous
              ├── seq-logging@ extraneous
              ├── serialport@10.5.0 extraneous
              ├── serve-static@1.15.0 extraneous
              ├── set-blocking@2.0.0 extraneous
              ├── setimmediate@1.0.5 extraneous
              ├── setprototypeof@1.2.0 extraneous
              ├── sharp@ extraneous
              ├── shebang-command@2.0.0 extraneous
              ├── shebang-regex@3.0.0 extraneous
              ├── shelly-iot@1.1.2 extraneous
              ├── side-channel@1.0.4 extraneous
              ├── signal-exit@3.0.7 extraneous
              ├── simple-concat@1.0.1 extraneous
              ├── simple-get@3.1.1 extraneous
              ├── simple-swizzle@0.2.2 extraneous
              ├── smartmeter-obis@ extraneous
              ├── socket.io-adapter@1.1.2 extraneous
              ├── socket.io-client@ extraneous
              ├── socket.io-parser@3.4.3 extraneous
              ├── socket.io@2.5.0 extraneous
              ├── sorted-array-functions@1.3.0 extraneous
              ├── source-map-support@0.5.21 extraneous
              ├── source-map@0.6.1 extraneous
              ├── spdx-correct@3.2.0 extraneous
              ├── spdx-exceptions@2.3.0 extraneous
              ├── spdx-expression-parse@3.0.1 extraneous
              ├── spdx-license-ids@3.0.13 extraneous
              ├── split@1.0.1 extraneous
              ├── split2@3.2.2 extraneous
              ├── sshpk@ extraneous
              ├── stack-trace@0.0.10 extraneous
              ├── standard-as-callback@2.1.0 extraneous
              ├── statuses@2.0.1 extraneous
              ├── stream-combiner@0.2.2 extraneous
              ├── stream-shift@1.0.1 extraneous
              ├── streamsearch@1.1.0 extraneous
              ├── string_decoder@1.1.1 extraneous
              ├── string-width@4.2.3 extraneous
              ├── strip-ansi@6.0.1 extraneous
              ├── strip-bom@2.0.0 extraneous
              ├── strip-final-newline@2.0.0 extraneous
              ├── strip-json-comments@2.0.1 extraneous
              ├── strnum@1.0.5 extraneous
              ├── suncalc2@1.8.1 extraneous
              ├── supports-preserve-symlinks-flag@1.0.0 extraneous
              ├── symbol-tree@3.2.4 extraneous
              ├── tar-fs@ extraneous
              ├── tar-stream@2.2.0 extraneous
              ├── tar@ extraneous
              ├── tcp-ping@0.1.1 extraneous
              ├── text-hex@1.0.0 extraneous
              ├── through@2.3.8 extraneous
              ├── through2@2.0.5 extraneous
              ├── to-array@0.1.4 extraneous
              ├── to-regex-range@5.0.1 extraneous
              ├── toidentifier@1.0.1 extraneous
              ├── tough-cookie@4.1.3 extraneous
              ├── tr-064@0.2.0 extraneous
              ├── tr-O64@0.2.4 extraneous
              ├── tr46@4.1.1 extraneous
              ├── traverse@0.3.9 extraneous
              ├── treemap-js@1.2.1 extraneous
              ├── triple-beam@1.3.0 extraneous
              ├── tunnel-agent@0.6.0 extraneous
              ├── tweetnacl@0.14.5 extraneous
              ├── type-check@0.3.2 extraneous
              ├── type-is@1.6.18 extraneous
              ├── typedarray@0.0.6 extraneous
              ├── typescript@ extraneous
              ├── uid-safe@2.1.5 extraneous
              ├── ultron@1.1.1 extraneous
              ├── unix-dgram@2.0.6 extraneous
              ├── unpipe@1.0.0 extraneous
              ├── uri-js@ extraneous
              ├── url-join@4.0.1 extraneous
              ├── url-parse@1.5.10 extraneous
              ├── url-template@2.0.8 extraneous
              ├── ursa-optional@0.9.10 extraneous
              ├── util-deprecate@1.0.2 extraneous
              ├── utils-merge@1.0.1 extraneous
              ├── validate-npm-package-license@3.0.4 extraneous
              ├── vary@1.1.2 extraneous
              ├── verror@1.10.0 extraneous
              ├── virtual-tsc@0.6.2 extraneous
              ├── w3c-xmlserializer@4.0.0 extraneous
              ├── wake_on_lan@1.0.0 extraneous
              ├── weak-daemon@1.0.3 extraneous
              ├── webdav@ extraneous
              ├── webidl-conversions@7.0.0 extraneous
              ├── websocket-stream@5.5.2 extraneous
              ├── whatwg-encoding@2.0.0 extraneous
              ├── whatwg-mimetype@3.0.0 extraneous
              ├── whatwg-url@ extraneous
              ├── which-module@1.0.0 extraneous
              ├── which@2.0.2 extraneous
              ├── wide-align@1.1.5 extraneous
              ├── winston-daily-rotate-file@4.7.1 extraneous
              ├── winston-seq-updated@1.0.4 extraneous
              ├── winston-syslog@2.7.0 extraneous
              ├── winston-transport@4.5.0 extraneous
              ├── winston@ extraneous
              ├── word-wrap@1.2.3 extraneous
              ├── wrap-ansi@2.1.0 extraneous
              ├── wrappy@1.0.2 extraneous
              ├── ws@ extraneous
              ├── xml-name-validator@4.0.0 extraneous
              ├── xml2js@0.4.23 extraneous
              ├── xml2json-light@1.0.6 extraneous
              ├── xmlbuilder@0.4.2 extraneous
              ├── xmlchars@2.2.0 extraneous
              ├── xmlhttprequest-ssl@1.6.3 extraneous
              ├── xregexp@2.0.0 extraneous
              ├── xtend@4.0.2 extraneous
              ├── y18n@3.2.2 extraneous
              ├── yallist@4.0.0 extraneous
              ├── yargs-parser@5.0.1 extraneous
              ├── yargs@ invalid: "^7.0.2" from the root project
              ├── yeast@0.1.2 extraneous
              ├── zlib@1.0.5 extraneous
              └── zrender@4.3.2 extraneous
              npm ERR!     /home/iobroker/.npm/_logs/2023-06-20T21_38_40_453Z-debug-0.log
              pi@ioBroker-RasPi4:/opt/iobroker $
              C Thomas BraunT 2 Antworten Letzte Antwort
              • C chemieka
                @chemieka
                ├── ajv@ extraneous
                ├── colors@1.4.0
                ├── fs-extra@7.0.1
                ├── got@ extraneous
                ├── iobroker@2.0.3
                ├── nan@ extraneous
                ├── qs@ extraneous
                ├── semver@5.7.1
                ├── tar@ extraneous
                ├── ws@ extraneous
                chemieka
                schrieb am zuletzt editiert von chemieka
                @chemieka
                musste wieder teilen. Schaut nicht gut aus oder?
                • C chemieka
                  @chemieka
                  ├── ajv@ extraneous
                  ├── colors@1.4.0
                  ├── fs-extra@7.0.1
                  ├── got@ extraneous
                  ├── iobroker@2.0.3
                  ├── nan@ extraneous
                  ├── qs@ extraneous
                  ├── semver@5.7.1
                  ├── tar@ extraneous
                  ├── ws@ extraneous
                  @chemieka sagte in Nach Update auf Node 16 startet IOBROKER nicht mehr:
                  4.0.24
                  cd /opt/iobroker
                  sudo -u iobroker npm install iobroker.js-controller@4.0.24
                  C 1 Antwort Letzte Antwort
                    4.0.24
                    cd /opt/iobroker
                    chemieka
                    ok MOM vorgang läuft
                    • C chemieka
                      chemieka
                      @chemieka
                      pi@ioBroker-RasPi4:~ $ cd /opt/iobroker && npm ls
                      npm ERR! code ELSPROBLEMS
                      npm ERR! extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                      npm ERR! extraneous: @alcalzone/jsonl-db@2.5.3 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                      npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
                      npm ERR! extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                      npm ERR! extraneous: @apollon/iobroker-tools@0.2.1 /opt/iobroker/node_modules/@apollon/iobroker-tools
                      npm ERR! extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
                      npm ERR! extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
                      npm ERR! extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                      npm ERR! extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                      npm ERR! extraneous: @greenlock/manager@3.1.0 /opt/iobroker/node_modules/@greenlock/manager
                      npm ERR! extraneous: @iobroker/db-base@4.0.24 /opt/iobroker/node_modules/@iobroker/db-base
                      npm ERR! extraneous: @iobroker/db-objects-file@4.0.24 /opt/iobroker/node_modules/@iobroker/db-objects-file
                      npm ERR! extraneous: @iobroker/db-objects-jsonl@4.0.24 /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                      npm ERR! extraneous: @iobroker/db-objects-redis@4.0.24 /opt/iobroker/node_modules/@iobroker/db-objects-redis
                      npm ERR! extraneous: @iobroker/db-states-file@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-file
                      npm ERR! extraneous: @iobroker/db-states-jsonl@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                      npm ERR! extraneous: @iobroker/db-states-redis@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-redis
                      npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                      npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                      npm ERR! extraneous: @iobroker/js-controller-common-db@4.0.24 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                      npm ERR! extraneous: @iobroker/js-controller-common@4.0.24 /opt/iobroker/node_modules/@iobroker/js-controller-common
                      npm ERR! extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                      npm ERR! extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                      npm ERR! extraneous: @iobroker/socket-classes@1.0.2 /opt/iobroker/node_modules/@iobroker/socket-classes
                      npm ERR! extraneous: @iobroker/ws-server@2.1.0 /opt/iobroker/node_modules/@iobroker/ws-server
                      npm ERR! extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                      npm ERR! extraneous: @root/acme@ /opt/iobroker/node_modules/@root/acme
                      npm ERR! extraneous: @root/asn1@1.0.0 /opt/iobroker/node_modules/@root/asn1
                      npm ERR! extraneous: @root/csr@0.8.1 /opt/iobroker/node_modules/@root/csr
                      npm ERR! extraneous: @root/encoding@1.0.1 /opt/iobroker/node_modules/@root/encoding
                      npm ERR! extraneous: @root/greenlock-express@ /opt/iobroker/node_modules/@root/greenlock-express
                      npm ERR! extraneous: @root/greenlock@ /opt/iobroker/node_modules/@root/greenlock
                      npm ERR! extraneous: @root/keypairs@ /opt/iobroker/node_modules/@root/keypairs
                      npm ERR! extraneous: @root/mkdirp@1.0.0 /opt/iobroker/node_modules/@root/mkdirp
                      npm ERR! extraneous: @root/pem@1.0.4 /opt/iobroker/node_modules/@root/pem
                      npm ERR! extraneous: @root/request@1.9.2 /opt/iobroker/node_modules/@root/request
                      npm ERR! extraneous: @root/x509@0.7.2 /opt/iobroker/node_modules/@root/x509
                      npm ERR! extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                      npm ERR! extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
                      npm ERR! extraneous: @sentry/hub@ /opt/iobroker/node_modules/@sentry/hub
                      npm ERR! extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
                      npm ERR! extraneous: @sentry/minimal@6.19.7 /opt/iobroker/node_modules/@sentry/minimal
                      npm ERR! extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                      npm ERR! extraneous: @sentry/types@7.56.0 /opt/iobroker/node_modules/@sentry/types
                      npm ERR! extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                      npm ERR! extraneous: @serialport/binding-mock@10.2.2 /opt/iobroker/node_modules/@serialport/binding-mock
                      npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
                      npm ERR! extraneous: @serialport/bindings-interface@1.2.2 /opt/iobroker/node_modules/@serialport/bindings-interface
                      npm ERR! extraneous: @serialport/parser-byte-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-byte-length
                      npm ERR! extraneous: @serialport/parser-cctalk@10.5.0 /opt/iobroker/node_modules/@serialport/parser-cctalk
                      npm ERR! extraneous: @serialport/parser-delimiter@10.5.0 /opt/iobroker/node_modules/@serialport/parser-delimiter
                      npm ERR! extraneous: @serialport/parser-inter-byte-timeout@10.5.0 /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
                      npm ERR! extraneous: @serialport/parser-packet-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-packet-length
                      npm ERR! extraneous: @serialport/parser-readline@10.5.0 /opt/iobroker/node_modules/@serialport/parser-readline
                      npm ERR! extraneous: @serialport/parser-ready@10.5.0 /opt/iobroker/node_modules/@serialport/parser-ready
                      npm ERR! extraneous: @serialport/parser-regex@10.5.0 /opt/iobroker/node_modules/@serialport/parser-regex
                      npm ERR! extraneous: @serialport/parser-slip-encoder@10.5.0 /opt/iobroker/node_modules/@serialport/parser-slip-encoder
                      npm ERR! extraneous: @serialport/parser-spacepacket@10.5.0 /opt/iobroker/node_modules/@serialport/parser-spacepacket
                      npm ERR! extraneous: @serialport/stream@10.5.0 /opt/iobroker/node_modules/@serialport/stream
                      npm ERR! extraneous: @sindresorhus/is@5.4.1 /opt/iobroker/node_modules/@sindresorhus/is
                      npm ERR! extraneous: @szmarczak/http-timer@5.0.1 /opt/iobroker/node_modules/@szmarczak/http-timer
                      npm ERR! extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                      npm ERR! extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                      npm ERR! extraneous: @types/http-cache-semantics@4.0.1 /opt/iobroker/node_modules/@types/http-cache-semantics
                      npm ERR! extraneous: @types/http-proxy@1.17.11 /opt/iobroker/node_modules/@types/http-proxy
                      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                      npm ERR! extraneous: @types/triple-beam@1.3.2 /opt/iobroker/node_modules/@types/triple-beam
                      npm ERR! extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                      npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                      npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/accepts
                      npm ERR! extraneous: acme-http-01-standalone@3.0.5 /opt/iobroker/node_modules/acme-http-01-standalone
                      npm ERR! extraneous: acorn-globals@7.0.1 /opt/iobroker/node_modules/acorn-globals
                      npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
                      npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/acorn
                      npm ERR! extraneous: after@0.8.2 /opt/iobroker/node_modules/after
                      npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/agent-base
                      npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/ajv
                      npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
                      npm ERR! extraneous: alexa-cookie2@4.1.3 /opt/iobroker/node_modules/alexa-cookie2
                      npm ERR! extraneous: alexa-remote2@5.10.1 /opt/iobroker/node_modules/alexa-remote2
                      npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                      npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                      npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                      npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                      npm ERR! extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                      npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                      npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuffer.slice
                      npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                      npm ERR! extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                      npm ERR! extraneous: assert-plus@1.0.0 /opt/iobroker/node_modules/assert-plus
                      npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limiter
                      npm ERR! extraneous: async@ /opt/iobroker/node_modules/async
                      npm ERR! extraneous: asynckit@0.4.0 /opt/iobroker/node_modules/asynckit
                      npm ERR! extraneous: at-least-node@1.0.0 /opt/iobroker/node_modules/at-least-node
                      npm ERR! extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
                      npm ERR! extraneous: aws-sign2@0.7.0 /opt/iobroker/node_modules/aws-sign2
                      npm ERR! extraneous: aws4@1.12.0 /opt/iobroker/node_modules/aws4
                      npm ERR! extraneous: backo2@1.0.2 /opt/iobroker/node_modules/backo2
                      npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                      npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                      npm ERR! extraneous: base64-arraybuffer@0.1.4 /opt/iobroker/node_modules/base64-arraybuffer
                      npm ERR! extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                      npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
                      npm ERR! extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                      npm ERR! extraneous: bignumber.js@9.1.1 /opt/iobroker/node_modules/bignumber.js
                      npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/binary-extensions
                      npm ERR! extraneous: binary@0.3.0 /opt/iobroker/node_modules/binary
                      npm ERR! extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                      npm ERR! extraneous: binrpc@3.3.1 /opt/iobroker/node_modules/binrpc
                      npm ERR! extraneous: bl@4.1.0 /opt/iobroker/node_modules/bl
                      npm ERR! extraneous: blob@0.0.5 /opt/iobroker/node_modules/blob
                      npm ERR! extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                      npm ERR! extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                      npm ERR! extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                      npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
                      npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/braces
                      npm ERR! extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                      npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/buffer-from
                      npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                      npm ERR! extraneous: bufferhelper@0.2.1 /opt/iobroker/node_modules/bufferhelper
                      npm ERR! extraneous: buffers@0.1.1 /opt/iobroker/node_modules/buffers
                      npm ERR! extraneous: busboy@ /opt/iobroker/node_modules/busboy
                      npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                      npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                      npm ERR! extraneous: cacheable-lookup@7.0.0 /opt/iobroker/node_modules/cacheable-lookup
                      npm ERR! extraneous: cacheable-request@10.2.11 /opt/iobroker/node_modules/cacheable-request
                      npm ERR! extraneous: call-bind@1.0.2 /opt/iobroker/node_modules/call-bind
                      npm ERR! extraneous: callsite@1.0.0 /opt/iobroker/node_modules/callsite
                      npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/camelcase
                      npm ERR! extraneous: canvas@ /opt/iobroker/node_modules/canvas
                      npm ERR! extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                      npm ERR! extraneous: caseless@0.12.0 /opt/iobroker/node_modules/caseless
                      npm ERR! extraneous: cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
                      npm ERR! extraneous: chainsaw@0.1.0 /opt/iobroker/node_modules/chainsaw
                      npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                      npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/chokidar
                      npm ERR! extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                      npm ERR! extraneous: ci-info@3.8.0 /opt/iobroker/node_modules/ci-info
                      npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/cliui
                      npm ERR! extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                      npm ERR! extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                      npm ERR! extraneous: coap@ /opt/iobroker/node_modules/coap
                      npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
                      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                      npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                      npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                      npm ERR! extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                      npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                      npm ERR! extraneous: color@4.2.3 /opt/iobroker/node_modules/color
                      npm ERR! extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                      npm ERR! extraneous: combined-stream@1.0.8 /opt/iobroker/node_modules/combined-stream
                      npm ERR! extraneous: commist@1.1.0 /opt/iobroker/node_modules/commist
                      npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-bind
                      npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/component-emitter
                      npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/component-inherit
                      npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                      npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                      npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                      npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                      npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/concat-stream
                      npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                      npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                      npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                      npm ERR! extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                      npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser
                      npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/cookie-signature
                      npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie
                      npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/core-util-is
                      npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
                      npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/cross-spawn
                      npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                      npm ERR! extraneous: crypto-js@4.0.0 /opt/iobroker/node_modules/crypto-js
                      npm ERR! extraneous: crypto@1.0.1 /opt/iobroker/node_modules/crypto
                      npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                      npm ERR! extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                      npm ERR! extraneous: daemonize2@0.4.2 /opt/iobroker/node_modules/daemonize2
                      npm ERR! extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                      npm ERR! extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/debug
                      npm ERR! extraneous: decache@4.6.1 /opt/iobroker/node_modules/decache
                      npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize
                      npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                      npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                      npm ERR! extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                      npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                      npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                      npm ERR! extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                      npm ERR! extraneous: define-properties@1.2.0 /opt/iobroker/node_modules/define-properties
                      npm ERR! extraneous: delayed-stream@1.0.0 /opt/iobroker/node_modules/delayed-stream
                      npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                      npm ERR! extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                      npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/depd
                      npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                      npm ERR! extraneous: detect-libc@2.0.1 /opt/iobroker/node_modules/detect-libc
                      npm ERR! extraneous: dgram@1.0.1 /opt/iobroker/node_modules/dgram
                      npm ERR! extraneous: diskusage@1.1.3 /opt/iobroker/node_modules/diskusage
                      npm ERR! extraneous: dns-packet@1.3.4 /opt/iobroker/node_modules/dns-packet
                      npm ERR! extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                      npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                      npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                      npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/duplexify
                      npm ERR! extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                      npm ERR! extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                      npm ERR! extraneous: echarts@4.9.0 /opt/iobroker/node_modules/echarts
                      npm ERR! extraneous: eckles@1.4.1 /opt/iobroker/node_modules/eckles
                      npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                      npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/emoji-regex
                      npm ERR! extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                      npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                      npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                      npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
                      npm ERR! extraneous: engine.io-parser@2.2.1 /opt/iobroker/node_modules/engine.io-parser
                      npm ERR! extraneous: engine.io@3.6.1 /opt/iobroker/node_modules/engine.io
                      npm ERR! extraneous: entities@ /opt/iobroker/node_modules/entities
                      npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/error-ex
                      npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                      npm ERR! extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                      npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/escalade
                      npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                      npm ERR! extraneous: escodegen@2.0.0 /opt/iobroker/node_modules/escodegen
                      npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima
                      npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/estraverse
                      npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                      npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                      npm ERR! extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                      npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/eventemitter3
                      npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                      npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                      npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-fileupload
                      npm ERR! extraneous: express-session@1.17.3 /opt/iobroker/node_modules/express-session
                      npm ERR! extraneous: express@ /opt/iobroker/node_modules/express
                      npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/extend
                      npm ERR! extraneous: extsprintf@1.3.0 /opt/iobroker/node_modules/extsprintf
                      npm ERR! extraneous: eyes@0.1.8 /opt/iobroker/node_modules/eyes
                      npm ERR! extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                      npm ERR! extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                      npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                      npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                      npm ERR! extraneous: fast-xml-parser@3.21.1 /opt/iobroker/node_modules/fast-xml-parser
                      npm ERR! extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                      npm ERR! extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                      npm ERR! extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                      npm ERR! extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                      npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/fill-range
                      npm ERR! extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                      npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/find-up
                      npm ERR! extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                      npm ERR! extraneous: follow-redirects@1.15.2 /opt/iobroker/node_modules/follow-redirects
                      npm ERR! extraneous: forever-agent@0.6.1 /opt/iobroker/node_modules/forever-agent
                      npm ERR! extraneous: form-data-encoder@ /opt/iobroker/node_modules/form-data-encoder
                      npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                      npm ERR! extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                      npm ERR! extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                      npm ERR! extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                      npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                      npm ERR! extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                      npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                      npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                      npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                      npm ERR! extraneous: function-bind@1.1.1 /opt/iobroker/node_modules/function-bind
                      npm ERR! extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                      npm ERR! extraneous: gaxios@5.1.0 /opt/iobroker/node_modules/gaxios
                      npm ERR! extraneous: gcp-metadata@5.2.0 /opt/iobroker/node_modules/gcp-metadata
                      npm ERR! extraneous: geolocation-utils@ /opt/iobroker/node_modules/geolocation-utils
                      npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller-file
                      npm ERR! extraneous: get-intrinsic@1.2.1 /opt/iobroker/node_modules/get-intrinsic
                      npm ERR! extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                      npm ERR! extraneous: get-stream@6.0.1 /opt/iobroker/node_modules/get-stream
                      npm ERR! extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                      npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                      npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                      npm ERR! extraneous: glob@7.2.3 /opt/iobroker/node_modules/glob
                      npm ERR! extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                      npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                      npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                      npm ERR! extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                      npm ERR! extraneous: got@ /opt/iobroker/node_modules/got
                      npm ERR! extraneous: greenlock-express@4.0.3 /opt/iobroker/node_modules/greenlock-express
                      npm ERR! extraneous: greenlock-manager-fs@3.1.1 /opt/iobroker/node_modules/greenlock-manager-fs
                      npm ERR! extraneous: greenlock-store-fs@3.2.2 /opt/iobroker/node_modules/greenlock-store-fs
                      npm ERR! extraneous: greenlock@4.0.4 /opt/iobroker/node_modules/greenlock
                      npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                      npm ERR! extraneous: har-schema@2.0.0 /opt/iobroker/node_modules/har-schema
                      npm ERR! extraneous: har-validator@5.1.5 /opt/iobroker/node_modules/har-validator
                      npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
                      npm ERR! extraneous: has-cors@1.1.0 /opt/iobroker/node_modules/has-cors
                      npm ERR! extraneous: has-property-descriptors@1.0.0 /opt/iobroker/node_modules/has-property-descriptors
                      npm ERR! extraneous: has-proto@1.0.1 /opt/iobroker/node_modules/has-proto
                      npm ERR! extraneous: has-symbols@1.0.3 /opt/iobroker/node_modules/has-symbols
                      npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                      npm ERR! extraneous: has@1.0.3 /opt/iobroker/node_modules/has
                      npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                      npm ERR! extraneous: help-me@3.0.0 /opt/iobroker/node_modules/help-me
                      npm ERR! extraneous: homematic-xmlrpc@1.0.2 /opt/iobroker/node_modules/homematic-xmlrpc
                      npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/hosted-git-info
                      npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                      npm ERR! extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                      npm ERR! extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                      npm ERR! extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                      npm ERR! extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                      npm ERR! extraneous: http-proxy-middleware@2.0.6 /opt/iobroker/node_modules/http-proxy-middleware
                      npm ERR! extraneous: http-proxy-response-rewrite@0.0.1 /opt/iobroker/node_modules/http-proxy-response-rewrite
                      npm ERR! extraneous: http-proxy@1.18.1 /opt/iobroker/node_modules/http-proxy
                      npm ERR! extraneous: http-signature@1.2.0 /opt/iobroker/node_modules/http-signature
                      npm ERR! extraneous: http2-wrapper@ /opt/iobroker/node_modules/http2-wrapper
                      npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/https-proxy-agent
                      npm ERR! extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                      npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/human-signals
                      npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                      npm ERR! extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                      npm ERR! extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                      npm ERR! extraneous: indexof@0.0.1 /opt/iobroker/node_modules/indexof
                      npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                      npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/inherits
                      npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
                      npm ERR! extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                      npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/invert-kv
                      npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                      npm ERR! invalid: iobroker.alexa2@ /opt/iobroker/node_modules/iobroker.alexa2
                      npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                      npm ERR! invalid: iobroker.daswetter@ /opt/iobroker/node_modules/iobroker.daswetter
                      npm ERR! invalid: iobroker.dwd@ /opt/iobroker/node_modules/iobroker.dwd
                      npm ERR! invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                      npm ERR! invalid: iobroker.fritzbox@ /opt/iobroker/node_modules/iobroker.fritzbox
                      npm ERR! invalid: iobroker.history@ /opt/iobroker/node_modules/iobroker.history
                      npm ERR! invalid: iobroker.hm-rega@ /opt/iobroker/node_modules/iobroker.hm-rega
                      npm ERR! invalid: iobroker.hm-rpc@ /opt/iobroker/node_modules/iobroker.hm-rpc
                      npm ERR! invalid: iobroker.hue-extended@ /opt/iobroker/node_modules/iobroker.hue-extended
                      npm ERR! invalid: iobroker.hue@ /opt/iobroker/node_modules/iobroker.hue
                      npm ERR! invalid: iobroker.iot@ /opt/iobroker/node_modules/iobroker.iot
                      npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                      npm ERR! invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                      npm ERR! invalid: iobroker.life360@ /opt/iobroker/node_modules/iobroker.life360
                      npm ERR! invalid: iobroker.mihome-vacuum@ /opt/iobroker/node_modules/iobroker.mihome-vacuum
                      npm ERR! invalid: iobroker.scenes@ /opt/iobroker/node_modules/iobroker.scenes
                      npm ERR! invalid: iobroker.shelly@ /opt/iobroker/node_modules/iobroker.shelly
                      npm ERR! extraneous: iobroker.simple-api@ /opt/iobroker/node_modules/iobroker.simple-api
                      npm ERR! invalid: iobroker.smartmeter@ /opt/iobroker/node_modules/iobroker.smartmeter
                      npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker.socketio
                      npm ERR! invalid: iobroker.spotify-premium@ /opt/iobroker/node_modules/iobroker.spotify-premium
                      npm ERR! invalid: iobroker.tr-064@ /opt/iobroker/node_modules/iobroker.tr-064
                      npm ERR! invalid: iobroker.trashschedule@ /opt/iobroker/node_modules/iobroker.trashschedule
                      npm ERR! extraneous: iobroker.type-detector@1.1.2 /opt/iobroker/node_modules/iobroker.type-detector
                      npm ERR! invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                      npm ERR! invalid: iobroker.vis-map@ /opt/iobroker/node_modules/iobroker.vis-map
                      npm ERR! invalid: iobroker.vis-players@ /opt/iobroker/node_modules/iobroker.vis-players
                      npm ERR! invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                      npm ERR! invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                      npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
                      npm ERR! extraneous: iobroker.ws@1.3.0 /opt/iobroker/node_modules/iobroker.ws
                      npm ERR! extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                      npm ERR! extraneous: ip@1.1.8 /opt/iobroker/node_modules/ip
                      npm ERR! extraneous: ipaddr.js@1.9.1 /opt/iobroker/node_modules/ipaddr.js
                      npm ERR! extraneous: is-arrayish@0.3.2 /opt/iobroker/node_modules/is-arrayish
                      npm ERR! extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                      npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                      npm ERR! extraneous: is-core-module@2.12.1 /opt/iobroker/node_modules/is-core-module
                      npm ERR! extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                      npm ERR! extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                      npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                      npm ERR! extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                      npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                      npm ERR! extraneous: is-plain-obj@3.0.0 /opt/iobroker/node_modules/is-plain-obj
                      npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                      npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/is-stream
                      npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/is-typedarray
                      npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/is-utf8
                      npm ERR! extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                      npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/isarray
                      npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/isexe
                      npm ERR! extraneous: isstream@0.1.2 /opt/iobroker/node_modules/isstream
                      npm ERR! extraneous: jsbn@0.1.1 /opt/iobroker/node_modules/jsbn
                      npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                      npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
                      npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                      npm ERR! extraneous: json-schema-traverse@0.4.1 /opt/iobroker/node_modules/json-schema-traverse
                      npm ERR! extraneous: json-stringify-safe@5.0.1 /opt/iobroker/node_modules/json-stringify-safe
                      npm ERR! extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                      npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/jsonc-parser
                      npm ERR! extraneous: jsonwebtoken@8.5.1 /opt/iobroker/node_modules/jsonwebtoken
                      npm ERR! extraneous: jsprim@1.4.2 /opt/iobroker/node_modules/jsprim
                      npm ERR! extraneous: jszip@ /opt/iobroker/node_modules/jszip
                      npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                      npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                      npm ERR! extraneous: keypairs@1.2.14 /opt/iobroker/node_modules/keypairs
                      npm ERR! extraneous: keyv@4.5.2 /opt/iobroker/node_modules/keyv
                      npm ERR! extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                      npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                      npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/lcid
                      npm ERR! extraneous: le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
                      npm ERR! extraneous: le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
                      npm ERR! extraneous: le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
                      npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                      npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                      npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                      npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/load-json-file
                      npm ERR! extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                      npm ERR! extraneous: localforage@ /opt/iobroker/node_modules/localforage
                      npm ERR! extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                      npm ERR! extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                      npm ERR! extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                      npm ERR! extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                      npm ERR! extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                      npm ERR! extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                      npm ERR! extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                      npm ERR! extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                      npm ERR! extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                      npm ERR! extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                      npm ERR! extraneous: logform@ /opt/iobroker/node_modules/logform
                      npm ERR! extraneous: long-timeout@0.1.1 /opt/iobroker/node_modules/long-timeout
                      npm ERR! extraneous: lowercase-keys@3.0.0 /opt/iobroker/node_modules/lowercase-keys
                      npm ERR! extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                      npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                      npm ERR! extraneous: luxon@ /opt/iobroker/node_modules/luxon
                      npm ERR! extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                      npm ERR! extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                      npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                      npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
                      npm ERR! extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                      npm ERR! extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                      npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/merge-stream
                      npm ERR! extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                      npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/micromatch
                      npm ERR! extraneous: mime-db@1.52.0 /opt/iobroker/node_modules/mime-db
                      npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/mime-types
                      npm ERR! extraneous: mime@3.0.0 /opt/iobroker/node_modules/mime
                      npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/mimic-fn
                      npm ERR! extraneous: mimic-response@4.0.0 /opt/iobroker/node_modules/mimic-response
                      npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/minimatch
                      npm ERR! extraneous: minimist@ /opt/iobroker/node_modules/minimist
                      npm ERR! extraneous: minipass@5.0.0 /opt/iobroker/node_modules/minipass
                      npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                      npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                      npm ERR! extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                      npm ERR! extraneous: moment@ /opt/iobroker/node_modules/moment
                      npm ERR! extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                      npm ERR! extraneous: mqtt-packet@ /opt/iobroker/node_modules/mqtt-packet
                      npm ERR! extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/ms
                      npm ERR! extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                      npm ERR! extraneous: nan@ /opt/iobroker/node_modules/nan
                      npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                      npm ERR! extraneous: nearest-color@0.4.4 /opt/iobroker/node_modules/nearest-color
                      npm ERR! extraneous: negotiator@0.6.3 /opt/iobroker/node_modules/negotiator
                      npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                      npm ERR! extraneous: node-abi@3.45.0 /opt/iobroker/node_modules/node-abi
                      npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/node-addon-api
                      npm ERR! extraneous: node-fetch@2.6.11 /opt/iobroker/node_modules/node-fetch
                      npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                      npm ERR! extraneous: node-gyp-build@4.6.0 /opt/iobroker/node_modules/node-gyp-build
                      npm ERR! extraneous: node-hue-api@ /opt/iobroker/node_modules/node-hue-api
                      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                      npm ERR! extraneous: node-rest-client@ /opt/iobroker/node_modules/node-rest-client
                      npm ERR! extraneous: node-schedule@2.1.1 /opt/iobroker/node_modules/node-schedule
                      npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                      npm ERR! extraneous: node.extend@2.0.2 /opt/iobroker/node_modules/node.extend
                      npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                      npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/normalize-package-data
                      npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                      npm ERR! extraneous: normalize-url@8.0.0 /opt/iobroker/node_modules/normalize-url
                      npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/npm-run-path
                      npm ERR! extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                      npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
                      npm ERR! extraneous: nwsapi@2.2.5 /opt/iobroker/node_modules/nwsapi
                      npm ERR! extraneous: oauth-sign@0.9.0 /opt/iobroker/node_modules/oauth-sign
                      npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                      npm ERR! extraneous: object-hash@2.2.0 /opt/iobroker/node_modules/object-hash
                      npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/object-inspect
                      npm ERR! extraneous: object-keys@1.1.1 /opt/iobroker/node_modules/object-keys
                      npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/object.assign
                      npm ERR! extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                      npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
                      npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                      npm ERR! extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                      npm ERR! extraneous: onedrive-api@ /opt/iobroker/node_modules/onedrive-api
                      npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/onetime
                      npm ERR! extraneous: open-sml@ /opt/iobroker/node_modules/open-sml
                      npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                      npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/os-locale
                      npm ERR! extraneous: p-cancelable@3.0.0 /opt/iobroker/node_modules/p-cancelable
                      npm ERR! extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                      npm ERR! extraneous: pako@ /opt/iobroker/node_modules/pako
                      npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/parse-json
                      npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/parse5
                      npm ERR! extraneous: parseqs@0.0.6 /opt/iobroker/node_modules/parseqs
                      npm ERR! extraneous: parseuri@0.0.6 /opt/iobroker/node_modules/parseuri
                      npm ERR! extraneous: parseurl@1.3.3 /opt/iobroker/node_modules/parseurl
                      npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                      npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
                      npm ERR! extraneous: passport@ /opt/iobroker/node_modules/passport
                      npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/path-exists
                      npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                      npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/path-key
                      npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                      npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                      npm ERR! extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                      npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/path-type
                      npm ERR! extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                      npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause
                      npm ERR! extraneous: performance-now@2.1.0 /opt/iobroker/node_modules/performance-now
                      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                      npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                      npm ERR! extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                      npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/pify
                      npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/pinkie-promise
                      npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/pinkie
                      npm ERR! extraneous: point-in-polygon@1.0.1 /opt/iobroker/node_modules/point-in-polygon
                      npm ERR! extraneous: prebuild-install@7.1.1 /opt/iobroker/node_modules/prebuild-install
                      npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                      npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                      npm ERR! extraneous: promisify-child-process@4.1.1 /opt/iobroker/node_modules/promisify-child-process
                      npm ERR! extraneous: prompt@ /opt/iobroker/node_modules/prompt
                      npm ERR! extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                      npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                      npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                      npm ERR! extraneous: put@0.0.6 /opt/iobroker/node_modules/put
                      npm ERR! extraneous: qs@ /opt/iobroker/node_modules/qs
                      npm ERR! extraneous: querystring@0.2.1 /opt/iobroker/node_modules/querystring
                      npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
                      npm ERR! extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                      npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
                      npm ERR! extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                      npm ERR! extraneous: rasha@1.2.5 /opt/iobroker/node_modules/rasha
                      npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                      npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                      npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/read-pkg-up
                      npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/read-pkg
                      npm ERR! extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                      npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                      npm ERR! extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                      npm ERR! extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                      npm ERR! extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                      npm ERR! extraneous: redirect-https@1.3.1 /opt/iobroker/node_modules/redirect-https
                      npm ERR! extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                      npm ERR! extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                      npm ERR! extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                      npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                      npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
                      npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/require-directory
                      npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/require-main-filename
                      npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
                      npm ERR! extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                      npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/resolve
                      npm ERR! extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                      npm ERR! extraneous: responselike@3.0.0 /opt/iobroker/node_modules/responselike
                      npm ERR! extraneous: retry-request@4.2.2 /opt/iobroker/node_modules/retry-request
                      npm ERR! extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                      npm ERR! extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                      npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                      npm ERR! extraneous: rrule@2.7.2 /opt/iobroker/node_modules/rrule
                      npm ERR! extraneous: rrweb-cssom@ /opt/iobroker/node_modules/rrweb-cssom
                      npm ERR! extraneous: rsa-compat@1.9.4 /opt/iobroker/node_modules/rsa-compat
                      npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/safe-buffer
                      npm ERR! extraneous: safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
                      npm ERR! extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                      npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                      npm ERR! extraneous: sax@0.4.3 /opt/iobroker/node_modules/sax
                      npm ERR! extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                      npm ERR! extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                      npm ERR! extraneous: seq-logging@ /opt/iobroker/node_modules/seq-logging
                      npm ERR! extraneous: serialport@10.5.0 /opt/iobroker/node_modules/serialport
                      npm ERR! extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                      npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                      npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                      npm ERR! extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                      npm ERR! extraneous: sharp@ /opt/iobroker/node_modules/sharp
                      npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/shebang-command
                      npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/shebang-regex
                      npm ERR! extraneous: shelly-iot@1.1.2 /opt/iobroker/node_modules/shelly-iot
                      npm ERR! extraneous: side-channel@1.0.4 /opt/iobroker/node_modules/side-channel
                      npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/signal-exit
                      npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                      npm ERR! extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                      npm ERR! extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                      npm ERR! extraneous: smartmeter-obis@ /opt/iobroker/node_modules/smartmeter-obis
                      npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.io-adapter
                      npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/socket.io-client
                      npm ERR! extraneous: socket.io-parser@3.4.3 /opt/iobroker/node_modules/socket.io-parser
                      npm ERR! extraneous: socket.io@2.5.0 /opt/iobroker/node_modules/socket.io
                      npm ERR! extraneous: sorted-array-functions@1.3.0 /opt/iobroker/node_modules/sorted-array-functions
                      npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/source-map-support
                      npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/source-map
                      npm ERR! extraneous: spdx-correct@3.2.0 /opt/iobroker/node_modules/spdx-correct
                      npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-exceptions
                      npm ERR! extraneous: spdx-expression-parse@3.0.1 /opt/iobroker/node_modules/spdx-expression-parse
                      npm ERR! extraneous: spdx-license-ids@3.0.13 /opt/iobroker/node_modules/spdx-license-ids
                      npm ERR! extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                      npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/split2
                      npm ERR! extraneous: sshpk@ /opt/iobroker/node_modules/sshpk
                      npm ERR! extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                      npm ERR! extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                      npm ERR! extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                      npm ERR! extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                      npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/stream-shift
                      npm ERR! extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                      npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/string_decoder
                      npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/string-width
                      npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                      npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/strip-bom
                      npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/strip-final-newline
                      npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                      npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                      npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                      npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                      npm ERR! extraneous: tar-fs@ /opt/iobroker/node_modules/tar-fs
                      npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
                      npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
                      npm ERR! extraneous: tcp-ping@0.1.1 /opt/iobroker/node_modules/tcp-ping
                      npm ERR! extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                      npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                      npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                      npm ERR! extraneous: to-array@0.1.4 /opt/iobroker/node_modules/to-array
                      npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                      npm ERR! extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                      npm ERR! extraneous: tough-cookie@4.1.3 /opt/iobroker/node_modules/tough-cookie
                      npm ERR! extraneous: tr-064@0.2.0 /opt/iobroker/node_modules/tr-064
                      npm ERR! extraneous: tr-O64@0.2.4 /opt/iobroker/node_modules/tr-O64
                      npm ERR! extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                      npm ERR! extraneous: traverse@0.3.9 /opt/iobroker/node_modules/traverse
                      npm ERR! extraneous: treemap-js@1.2.1 /opt/iobroker/node_modules/treemap-js
                      npm ERR! extraneous: triple-beam@1.3.0 /opt/iobroker/node_modules/triple-beam
                      npm ERR! extraneous: tunnel-agent@0.6.0 /opt/iobroker/node_modules/tunnel-agent
                      npm ERR! extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                      npm ERR! extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                      npm ERR! extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                      npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
                      npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/typescript
                      npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
                      npm ERR! extraneous: ultron@1.1.1 /opt/iobroker/node_modules/ultron
                      npm ERR! extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                      npm ERR! extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                      npm ERR! extraneous: uri-js@ /opt/iobroker/node_modules/uri-js
                      npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                      npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
                      npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                      npm ERR! extraneous: ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
                      npm ERR! extraneous: util-deprecate@1.0.2 /opt/iobroker/node_modules/util-deprecate
                      npm ERR! extraneous: utils-merge@1.0.1 /opt/iobroker/node_modules/utils-merge
                      npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/validate-npm-package-license
                      npm ERR! extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                      npm ERR! extraneous: verror@1.10.0 /opt/iobroker/node_modules/verror
                      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                      npm ERR! extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                      npm ERR! extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                      npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
                      npm ERR! extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                      npm ERR! extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                      npm ERR! extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                      npm ERR! extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                      npm ERR! extraneous: whatwg-url@ /opt/iobroker/node_modules/whatwg-url
                      npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/which-module
                      npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/which
                      npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                      npm ERR! extraneous: winston-daily-rotate-file@4.7.1 /opt/iobroker/node_modules/winston-daily-rotate-file
                      npm ERR! extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                      npm ERR! extraneous: winston-syslog@2.7.0 /opt/iobroker/node_modules/winston-syslog
                      npm ERR! extraneous: winston-transport@4.5.0 /opt/iobroker/node_modules/winston-transport
                      npm ERR! extraneous: winston@ /opt/iobroker/node_modules/winston
                      npm ERR! extraneous: word-wrap@1.2.3 /opt/iobroker/node_modules/word-wrap
                      npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/wrap-ansi
                      npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/ws
                      npm ERR! extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                      npm ERR! extraneous: xml2js@0.4.23 /opt/iobroker/node_modules/xml2js
                      npm ERR! extraneous: xml2json-light@1.0.6 /opt/iobroker/node_modules/xml2json-light
                      npm ERR! extraneous: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
                      npm ERR! extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                      npm ERR! extraneous: xmlhttprequest-ssl@1.6.3 /opt/iobroker/node_modules/xmlhttprequest-ssl
                      npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                      npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
                      npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/y18n
                      npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                      npm ERR! extraneous: yargs-parser@5.0.1 /opt/iobroker/node_modules/yargs-parser
                      npm ERR! invalid: yargs@ /opt/iobroker/node_modules/yargs
                      npm ERR! extraneous: yeast@0.1.2 /opt/iobroker/node_modules/yeast
                      npm ERR! extraneous: zlib@1.0.5 /opt/iobroker/node_modules/zlib
                      npm ERR! extraneous: zrender@4.3.2 /opt/iobroker/node_modules/zrender
                      iobroker.inst@2.0.3 /opt/iobroker
                      ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                      ├── @alcalzone/jsonl-db@2.5.3 extraneous
                      ├── @alcalzone/pak@ extraneous
                      ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                      ├── @apollon/iobroker-tools@0.2.1 extraneous
                      ├── @colors/colors@ extraneous
                      ├── @dabh/diagnostics@ extraneous
                      ├── @datalust/winston-seq@1.0.2 extraneous
                      ├── @googleapis/drive@5.1.0 extraneous
                      ├── @greenlock/manager@3.1.0 extraneous
                      ├── @iobroker/db-base@4.0.24 extraneous
                      ├── @iobroker/db-objects-file@4.0.24 extraneous
                      ├── @iobroker/db-objects-jsonl@4.0.24 extraneous
                      ├── @iobroker/db-objects-redis@4.0.24 extraneous
                      ├── @iobroker/db-states-file@4.0.24 extraneous
                      ├── @iobroker/db-states-jsonl@4.0.24 extraneous
                      ├── @iobroker/db-states-redis@4.0.24 extraneous
                      ├── @iobroker/js-controller-adapter@ extraneous
                      ├── @iobroker/js-controller-cli@ extraneous
                      ├── @iobroker/js-controller-common-db@4.0.24 extraneous
                      ├── @iobroker/js-controller-common@4.0.24 extraneous
                      ├── @iobroker/plugin-base@1.2.1 extraneous
                      ├── @iobroker/plugin-sentry@1.2.1 extraneous
                      ├── @iobroker/socket-classes@1.0.2 extraneous
                      ├── @iobroker/ws-server@2.1.0 extraneous
                      ├── @mapbox/node-pre-gyp@ extraneous
                      ├── @root/acme@ extraneous
                      ├── @root/asn1@1.0.0 extraneous
                      ├── @root/csr@0.8.1 extraneous
                      ├── @root/encoding@1.0.1 extraneous
                      ├── @root/greenlock-express@ extraneous
                      ├── @root/greenlock@ extraneous
                      ├── @root/keypairs@ extraneous
                      ├── @root/mkdirp@1.0.0 extraneous
                      ├── @root/pem@1.0.4 extraneous
                      ├── @root/request@1.9.2 extraneous
                      ├── @root/x509@0.7.2 extraneous
                      ├── @sentry-internal/tracing@ extraneous
                      ├── @sentry/core@ extraneous
                      ├── @sentry/hub@ extraneous
                      ├── @sentry/integrations@ extraneous
                      ├── @sentry/minimal@6.19.7 extraneous
                      ├── @sentry/node@ extraneous
                      ├── @sentry/types@7.56.0 extraneous
                      ├── @sentry/utils@ extraneous
                      ├── @serialport/binding-mock@10.2.2 extraneous
                      ├── @serialport/bindings-cpp@ extraneous
                      ├── @serialport/bindings-interface@1.2.2 extraneous
                      ├── @serialport/parser-byte-length@10.5.0 extraneous
                      ├── @serialport/parser-cctalk@10.5.0 extraneous
                      ├── @serialport/parser-delimiter@10.5.0 extraneous
                      ├── @serialport/parser-inter-byte-timeout@10.5.0 extraneous
                      ├── @serialport/parser-packet-length@10.5.0 extraneous
                      ├── @serialport/parser-readline@10.5.0 extraneous
                      ├── @serialport/parser-ready@10.5.0 extraneous
                      ├── @serialport/parser-regex@10.5.0 extraneous
                      ├── @serialport/parser-slip-encoder@10.5.0 extraneous
                      ├── @serialport/parser-spacepacket@10.5.0 extraneous
                      ├── @serialport/stream@10.5.0 extraneous
                      ├── @sindresorhus/is@5.4.1 extraneous
                      ├── @szmarczak/http-timer@5.0.1 extraneous
                      ├── @tootallnate/once@2.0.0 extraneous
                      ├── @types/bl@5.1.0 extraneous
                      ├── @types/caseless@0.12.2 extraneous
                      ├── @types/http-cache-semantics@4.0.1 extraneous
                      ├── @types/http-proxy@1.17.11 extraneous
                      ├── @types/request@2.48.8 extraneous
                      ├── @types/tough-cookie@4.0.2 extraneous
                      ├── @types/triple-beam@1.3.2 extraneous
                      • C chemieka
                        @chemieka
                        chemieka
                        @chemieka
                        ├── abab@2.0.6 extraneous
                        ├── abbrev@1.1.1 extraneous
                        ├── accepts@1.3.8 extraneous
                        ├── acme-http-01-standalone@3.0.5 extraneous
                        ├── acorn-globals@7.0.1 extraneous
                        ├── acorn-walk@8.2.0 extraneous
                        ├── acorn@ extraneous
                        ├── after@0.8.2 extraneous
                        ├── agent-base@6.0.2 extraneous
                        ├── ajv@ extraneous
                        ├── alcalzone-shared@ extraneous
                        ├── alexa-cookie2@4.1.3 extraneous
                        ├── alexa-remote2@5.10.1 extraneous
                        ├── ansi-regex@5.0.1 extraneous
                        ├── ansi-styles@4.3.0 extraneous
                        ├── anymatch@3.1.3 extraneous
                        ├── aproba@2.0.0 extraneous
                        ├── are-we-there-yet@2.0.0 extraneous
                        ├── array-flatten@1.1.1 extraneous
                        ├── arraybuffer.slice@0.0.7 extraneous
                        ├── arrify@2.0.1 extraneous
                        ├── asn1@0.2.6 extraneous
                        ├── assert-plus@1.0.0 extraneous
                        ├── async-limiter@1.0.1 extraneous
                        ├── async@ extraneous
                        ├── asynckit@0.4.0 extraneous
                        ├── at-least-node@1.0.0 extraneous
                        ├── aws-iot-device-sdk@ extraneous
                        ├── aws-sign2@0.7.0 extraneous
                        ├── aws4@1.12.0 extraneous
                        ├── backo2@1.0.2 extraneous
                        ├── balanced-match@1.0.2 extraneous
                        ├── base-64@1.0.0 extraneous
                        ├── base64-arraybuffer@0.1.4 extraneous
                        ├── base64-js@1.5.1 extraneous
                        ├── base64id@2.0.0 extraneous
                        ├── bcrypt-pbkdf@1.0.2 extraneous
                        ├── bignumber.js@9.1.1 extraneous
                        ├── binary-extensions@2.2.0 extraneous
                        ├── binary@0.3.0 extraneous
                        ├── bindings@1.5.0 extraneous
                        ├── binrpc@3.3.1 extraneous
                        ├── bl@4.1.0 extraneous
                        ├── blob@0.0.5 extraneous
                        ├── bluebird@3.7.2 extraneous
                        ├── body-parser@1.20.2 extraneous
                        ├── bottleneck@2.19.5 extraneous
                        ├── brace-expansion@1.1.11 extraneous
                        ├── braces@3.0.2 extraneous
                        ├── buffer-equal-constant-time@1.0.1 extraneous
                        ├── buffer-from@1.1.2 extraneous
                        ├── buffer@5.7.1 extraneous
                        ├── bufferhelper@0.2.1 extraneous
                        ├── buffers@0.1.1 extraneous
                        ├── busboy@ extraneous
                        ├── byte-length@1.0.2 extraneous
                        ├── bytes@3.1.2 extraneous
                        ├── cacheable-lookup@7.0.0 extraneous
                        ├── cacheable-request@10.2.11 extraneous
                        ├── call-bind@1.0.2 extraneous
                        ├── callsite@1.0.0 extraneous
                        ├── camelcase@3.0.0 extraneous
                        ├── canvas@ extraneous
                        ├── capitalize@2.0.4 extraneous
                        ├── caseless@0.12.0 extraneous
                        ├── cert-info@1.5.1 extraneous
                        ├── chainsaw@0.1.0 extraneous
                        ├── charenc@0.0.2 extraneous
                        ├── chokidar@3.5.3 extraneous
                        ├── chownr@2.0.0 extraneous
                        ├── ci-info@3.8.0 extraneous
                        ├── cliui@3.2.0 extraneous
                        ├── cluster-key-slot@1.1.2 extraneous
                        ├── coap-packet@1.1.1 extraneous
                        ├── coap@ extraneous
                        ├── code-point-at@1.1.0 extraneous
                        ├── coffeescript@1.12.7 extraneous
                        ├── color-convert@2.0.1 extraneous
                        ├── color-name@1.1.4 extraneous
                        ├── color-string@1.9.1 extraneous
                        ├── color-support@1.1.3 extraneous
                        ├── color@4.2.3 extraneous
                        ├── colors@1.4.0
                        ├── colorspace@1.1.4 extraneous
                        ├── combined-stream@1.0.8 extraneous
                        ├── commist@1.1.0 extraneous
                        ├── component-bind@1.0.0 extraneous
                        ├── component-emitter@1.3.0 extraneous
                        ├── component-inherit@0.0.3 extraneous
                        ├── compress-json@2.1.2 extraneous
                        ├── compressible@2.0.18 extraneous
                        ├── compression@1.7.4 extraneous
                        ├── concat-map@0.0.1 extraneous
                        ├── concat-stream@1.6.2 extraneous
                        ├── connect-flash@0.1.1 extraneous
                        ├── console-control-strings@1.1.0 extraneous
                        ├── content-disposition@0.5.4 extraneous
                        ├── content-type@1.0.5 extraneous
                        ├── cookie-parser@1.4.6 extraneous
                        ├── cookie-signature@1.0.6 extraneous
                        ├── cookie@0.4.1 extraneous
                        ├── core-util-is@1.0.3 extraneous
                        ├── cron-parser@ extraneous
                        ├── cross-spawn@7.0.3 extraneous
                        ├── crypt@0.0.2 extraneous
                        ├── crypto-js@4.0.0 extraneous
                        ├── crypto@1.0.1 extraneous
                        ├── cssstyle@ extraneous
                        ├── cycle@1.0.3 extraneous
                        ├── daemonize2@0.4.2 extraneous
                        ├── dashdash@1.14.1 extraneous
                        ├── data-urls@4.0.0 extraneous
                        ├── debug@2.6.9 extraneous
                        ├── decache@4.6.1 extraneous
                        ├── decamelize@1.2.0 extraneous
                        ├── decimal.js@10.4.3 extraneous
                        ├── decompress-response@6.0.0 extraneous
                        ├── deep-clone@3.0.3 extraneous
                        ├── deep-extend@0.6.0 extraneous
                        ├── deep-is@0.1.4 extraneous
                        ├── defer-to-connect@2.0.1 extraneous
                        ├── define-properties@1.2.0 extraneous
                        ├── delayed-stream@1.0.0 extraneous
                        ├── delegates@1.0.0 extraneous
                        ├── denque@1.5.1 extraneous
                        ├── depd@2.0.0 extraneous
                        ├── destroy@1.2.0 extraneous
                        ├── detect-libc@2.0.1 extraneous
                        ├── dgram@1.0.1 extraneous
                        ├── diskusage@1.1.3 extraneous
                        ├── dns-packet@1.3.4 extraneous
                        ├── domexception@4.0.0 extraneous
                        ├── dropbox-v2-api@ extraneous
                        ├── duplexer@0.1.2 extraneous
                        ├── duplexify@4.1.2 extraneous
                        ├── ecc-jsbn@0.1.2 extraneous
                        ├── ecdsa-sig-formatter@1.0.11 extraneous
                        ├── echarts@4.9.0 extraneous
                        ├── eckles@1.4.1 extraneous
                        ├── ee-first@1.1.1 extraneous
                        ├── emoji-regex@8.0.0 extraneous
                        ├── enabled@2.0.0 extraneous
                        ├── encodeurl@1.0.2 extraneous
                        ├── end-of-stream@1.4.4 extraneous
                        ├── engine.io-client@ extraneous
                        ├── engine.io-parser@2.2.1 extraneous
                        ├── engine.io@3.6.1 extraneous
                        ├── entities@ extraneous
                        ├── error-ex@1.3.2 extraneous
                        ├── es6-promise@4.2.8 extraneous
                        ├── esbuild@0.11.23 extraneous
                        ├── escalade@3.1.1 extraneous
                        ├── escape-html@1.0.3 extraneous
                        ├── escodegen@2.0.0 extraneous
                        ├── esprima@4.0.1 extraneous
                        ├── estraverse@5.3.0 extraneous
                        ├── esutils@2.0.3 extraneous
                        ├── etag@1.8.1 extraneous
                        ├── event-stream@4.0.1 extraneous
                        ├── eventemitter3@4.0.7 extraneous
                        ├── execa@5.1.1 extraneous
                        ├── expand-template@2.0.3 extraneous
                        ├── express-fileupload@ extraneous
                        ├── express-session@1.17.3 extraneous
                        ├── express@ extraneous
                        ├── extend@3.0.2 extraneous
                        ├── extsprintf@1.3.0 extraneous
                        ├── eyes@0.1.8 extraneous
                        ├── fast-deep-equal@3.1.3 extraneous
                        ├── fast-json-stable-stringify@2.1.0 extraneous
                        ├── fast-levenshtein@2.0.6 extraneous
                        ├── fast-text-encoding@1.0.6 extraneous
                        ├── fast-xml-parser@3.21.1 extraneous
                        ├── fastseries@2.0.0 extraneous
                        ├── fecha@4.2.3 extraneous
                        ├── file-stream-rotator@0.6.1 extraneous
                        ├── file-uri-to-path@1.0.0 extraneous
                        ├── fill-range@7.0.1 extraneous
                        ├── finalhandler@1.2.0 extraneous
                        ├── find-up@1.1.2 extraneous
                        ├── fn.name@1.1.0 extraneous
                        ├── follow-redirects@1.15.2 extraneous
                        ├── forever-agent@0.6.1 extraneous
                        ├── form-data-encoder@ extraneous
                        ├── form-data@4.0.0 extraneous
                        ├── forwarded@0.2.0 extraneous
                        ├── fresh@0.5.2 extraneous
                        ├── from@0.1.7 extraneous
                        ├── fs-constants@1.0.0 extraneous
                        ├── fs-extra@7.0.1
                        ├── fs-minipass@2.1.0 extraneous
                        ├── fs.realpath@1.0.0 extraneous
                        ├── fsevents@ extraneous
                        ├── ftp@0.3.10 extraneous
                        ├── function-bind@1.1.1 extraneous
                        ├── gauge@3.0.2 extraneous
                        ├── gaxios@5.1.0 extraneous
                        ├── gcp-metadata@5.2.0 extraneous
                        ├── geolocation-utils@ extraneous
                        ├── get-caller-file@1.0.3 extraneous
                        ├── get-intrinsic@1.2.1 extraneous
                        ├── get-ssl-certificate@2.3.3 extraneous
                        ├── get-stream@6.0.1 extraneous
                        ├── getpass@0.1.7 extraneous
                        ├── github-from-package@0.0.0 extraneous
                        ├── glob-parent@5.1.2 extraneous
                        ├── glob@7.2.3 extraneous
                        ├── glossy@0.1.7 extraneous
                        ├── google-auth-library@ extraneous
                        ├── google-p12-pem@4.0.1 extraneous
                        ├── googleapis-common@6.0.4 extraneous
                        ├── got@ extraneous
                        ├── greenlock-express@4.0.3 extraneous
                        ├── greenlock-manager-fs@3.1.1 extraneous
                        ├── greenlock-store-fs@3.2.2 extraneous
                        ├── greenlock@4.0.4 extraneous
                        ├── gtoken@6.1.2 extraneous
                        ├── har-schema@2.0.0 extraneous
                        ├── har-validator@5.1.5 extraneous
                        ├── has-binary2@1.0.3 extraneous
                        ├── has-cors@1.1.0 extraneous
                        ├── has-property-descriptors@1.0.0 extraneous
                        ├── has-proto@1.0.1 extraneous
                        ├── has-symbols@1.0.3 extraneous
                        ├── has-unicode@2.0.1 extraneous
                        ├── has@1.0.3 extraneous
                        ├── he@1.2.0 extraneous
                        ├── help-me@3.0.0 extraneous
                        ├── homematic-xmlrpc@1.0.2 extraneous
                        ├── hosted-git-info@2.8.9 extraneous
                        ├── hot-patcher@1.0.0 extraneous
                        ├── html-encoding-sniffer@3.0.0 extraneous
                        ├── http-cache-semantics@4.1.1 extraneous
                        ├── http-errors@2.0.0 extraneous
                        ├── http-proxy-agent@5.0.0 extraneous
                        ├── http-proxy-middleware@2.0.6 extraneous
                        ├── http-proxy-response-rewrite@0.0.1 extraneous
                        ├── http-proxy@1.18.1 extraneous
                        ├── http-signature@1.2.0 extraneous
                        ├── http2-wrapper@ extraneous
                        ├── https-proxy-agent@5.0.1 extraneous
                        ├── https@1.0.0 extraneous
                        ├── human-signals@2.1.0 extraneous
                        ├── iconv-lite@0.4.24 extraneous
                        ├── ieee754@1.2.1 extraneous
                        ├── immediate@3.0.6 extraneous
                        ├── indexof@0.0.1 extraneous
                        ├── inflight@1.0.6 extraneous
                        ├── inherits@2.0.4 extraneous
                        ├── ini@1.3.8 extraneous
                        ├── int64-buffer@1.0.1 extraneous
                        ├── invert-kv@1.0.0 extraneous
                        ├── iobroker.admin@ invalid: "6.3.5" from the root project
                        ├── iobroker.alexa2@ invalid: "3.23.2" from the root project
                        ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                        ├── iobroker.daswetter@ invalid: "3.1.8" from the root project
                        ├── iobroker.dwd@ invalid: "2.8.3" from the root project
                        ├── iobroker.flot@ invalid: "github:ioBroker/ioBroker.flot#f112917fab740b1ac72739496395a682d4d6d41e" from the root project
                        ├── iobroker.fritzbox@ invalid: "^0.5.0" from the root project
                        ├── iobroker.harmony@1.2.2
                        ├── iobroker.history@ invalid: "2.2.4" from the root project
                        ├── iobroker.hm-rega@ invalid: "3.0.46" from the root project
                        ├── iobroker.hm-rpc@ invalid: "1.15.16" from the root project
                        ├── iobroker.hue-extended@ invalid: "2.0.0" from the root project
                        ├── iobroker.hue@ invalid: "3.7.1" from the root project
                        ├── iobroker.ical@1.13.2
                        ├── iobroker.iot@ invalid: "1.14.5" from the root project
                        ├── iobroker.javascript@ invalid: "7.0.3" from the root project
                        ├── iobroker.js-controller@ invalid: "4.0.24" from the root project
                        ├── iobroker.life360@ invalid: "github:MiGoller/ioBroker.life360#master" from the root project
                        ├── iobroker.mihome-vacuum@ invalid: "3.11.0" from the root project
                        ├── iobroker.pushover@3.0.3
                        ├── iobroker.scenes@ invalid: "2.3.9" from the root project
                        ├── iobroker.shelly@ invalid: "github:iobroker-community-adapters/ioBroker.shelly" from the root project
                        ├── iobroker.simple-api@ extraneous
                        ├── iobroker.smartmeter@ invalid: "3.3.4" from the root project
                        ├── iobroker.socketio@4.2.0 extraneous
                        ├── iobroker.spotify-premium@ invalid: "1.2.1" from the root project
                        ├── iobroker.tr-064@ invalid: "4.2.18" from the root project
                        ├── iobroker.trashschedule@ invalid: "2.2.0" from the root project
                        ├── iobroker.type-detector@1.1.2 extraneous
                        ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                        ├── iobroker.vis-history@1.0.0
                        ├── iobroker.vis-map@ invalid: "1.0.4" from the root project
                        ├── iobroker.vis-players@ invalid: "0.1.6" from the root project
                        ├── iobroker.vis@ invalid: "1.4.16" from the root project
                        ├── iobroker.web@ invalid: "4.3.0" from the root project
                        ├── iobroker.ws.server@1.0.1 extraneous
                        ├── iobroker.ws@1.3.0 extraneous
                        ├── iobroker@2.0.3
                        ├── ioredis@ extraneous
                        ├── ip@1.1.8 extraneous
                        ├── ipaddr.js@1.9.1 extraneous
                        ├── is-arrayish@0.3.2 extraneous
                        ├── is-binary-path@2.1.0 extraneous
                        ├── is-buffer@1.1.6 extraneous
                        ├── is-core-module@2.12.1 extraneous
                        ├── is-empty-object@1.1.1 extraneous
                        ├── is-extglob@2.1.1 extraneous
                        ├── is-fullwidth-code-point@3.0.0 extraneous
                        ├── is-glob@4.0.3 extraneous
                        ├── is-number@7.0.0 extraneous
                        ├── is-plain-obj@3.0.0 extraneous
                        ├── is-potential-custom-element-name@1.0.1 extraneous
                        ├── is-stream@2.0.1 extraneous
                        ├── is-typedarray@1.0.0 extraneous
                        ├── is-utf8@0.2.1 extraneous
                        ├── is@3.3.0 extraneous
                        ├── isarray@1.0.0 extraneous
                        ├── isexe@2.0.0 extraneous
                        ├── isstream@0.1.2 extraneous
                        ├── jsbn@0.1.1 extraneous
                        ├── jsdom@ extraneous
                        ├── json-bigint@1.0.0 extraneous
                        ├── json-buffer@3.0.1 extraneous
                        ├── json-schema-traverse@0.4.1 extraneous
                        ├── json-stringify-safe@5.0.1 extraneous
                        ├── jsonata@ extraneous
                        ├── jsonc-parser@ extraneous
                        ├── jsonwebtoken@8.5.1 extraneous
                        ├── jsprim@1.4.2 extraneous
                        ├── jszip@ extraneous
                        ├── jwa@2.0.0 extraneous
                        ├── jws@4.0.0 extraneous
                        ├── keypairs@1.2.14 extraneous
                        ├── keyv@4.5.2 extraneous
                        ├── kuler@2.0.0 extraneous
                        ├── layerr@0.1.2 extraneous
                        ├── lcid@1.0.0 extraneous
                        ├── le-acme-core@2.1.4 extraneous
                        ├── le-challenge-fs@2.0.9 extraneous
                        ├── le-sni-auto@2.1.9 extraneous
                        ├── leven@2.1.0 extraneous
                        ├── levn@0.3.0 extraneous
                        ├── lie@3.3.0 extraneous
                        ├── load-json-file@1.1.0 extraneous
                        ├── loadavg-windows@1.1.1 extraneous
                        ├── localforage@ extraneous
                        ├── lodash.defaults@4.2.0 extraneous
                        ├── lodash.flatten@4.4.0 extraneous
                        ├── lodash.includes@4.3.0 extraneous
                        ├── lodash.isarguments@3.1.0 extraneous
                        ├── lodash.isboolean@3.0.3 extraneous
                        ├── lodash.isinteger@4.0.4 extraneous
                        ├── lodash.isnumber@3.0.3 extraneous
                        ├── lodash.isplainobject@4.0.6 extraneous
                        ├── lodash.isstring@4.0.1 extraneous
                        ├── lodash.once@4.1.1 extraneous
                        ├── logform@ extraneous
                        ├── long-timeout@0.1.1 extraneous
                        ├── lowercase-keys@3.0.0 extraneous
                        ├── lru_map@0.3.3 extraneous
                        ├── lru-cache@6.0.0 extraneous
                        ├── luxon@ extraneous
                        ├── make-dir@3.1.0 extraneous
                        ├── map-stream@0.0.7 extraneous
                        ├── md5@2.3.0 extraneous
                        ├── mdns-discovery@0.2.6 extraneous
                        ├── media-typer@0.3.0 extraneous
                        ├── merge-descriptors@1.0.1 extraneous
                        ├── merge-stream@2.0.0 extraneous
                        ├── methods@1.1.2 extraneous
                        ├── micromatch@4.0.5 extraneous
                        ├── mime-db@1.52.0 extraneous
                        ├── mime-types@2.1.35 extraneous
                        ├── mime@3.0.0 extraneous
                        ├── mimic-fn@2.1.0 extraneous
                        ├── mimic-response@4.0.0 extraneous
                        ├── minimatch@3.1.2 extraneous
                        ├── minimist@ extraneous
                        ├── minipass@5.0.0 extraneous
                        ├── minizlib@2.1.2 extraneous
                        ├── mkdirp-classic@0.5.3 extraneous
                        ├── mkdirp@1.0.4 extraneous
                        ├── moment@ extraneous
                        ├── mqtt-connection@4.1.0 extraneous
                        ├── mqtt-packet@ extraneous
                        ├── mqtt@ extraneous
                        ├── ms@2.0.0 extraneous
                        ├── mute-stream@0.0.8 extraneous
                        ├── nan@ extraneous
                        ├── napi-build-utils@1.0.2 extraneous
                        ├── nearest-color@0.4.4 extraneous
                        ├── negotiator@0.6.3 extraneous
                        ├── nested-property@4.0.0 extraneous
                        ├── node-abi@3.45.0 extraneous
                        ├── node-addon-api@ extraneous
                        ├── node-fetch@2.6.11 extraneous
                        ├── node-forge@ extraneous
                        ├── node-gyp-build@4.6.0 extraneous
                        ├── node-hue-api@ extraneous
                        ├── node-inspect@2.0.0 extraneous
                        ├── node-rest-client@ extraneous
                        ├── node-schedule@2.1.1 extraneous
                        ├── node-wol@0.1.1 extraneous
                        ├── node.extend@2.0.2 extraneous
                        ├── nopt@5.0.0 extraneous
                        ├── normalize-package-data@2.5.0 extraneous
                        ├── normalize-path@3.0.0 extraneous
                        ├── normalize-url@8.0.0 extraneous
                        ├── npm-run-path@4.0.1 extraneous
                        ├── npmlog@5.0.1 extraneous
                        ├── number-is-nan@1.0.1 extraneous
                        ├── nwsapi@2.2.5 extraneous
                        ├── oauth-sign@0.9.0 extraneous
                        ├── object-assign@4.1.1 extraneous
                        ├── object-hash@2.2.0 extraneous
                        ├── object-inspect@ extraneous
                        ├── object-keys@1.1.1 extraneous
                        ├── object.assign@ extraneous
                        ├── on-finished@2.4.1 extraneous
                        ├── on-headers@1.0.2 extraneous
                        ├── once@1.4.0 extraneous
                        ├── one-time@1.0.0 extraneous
                        ├── onedrive-api@ extraneous
                        ├── onetime@5.1.2 extraneous
                        ├── open-sml@ extraneous
                        ├── optionator@0.8.3 extraneous
                        ├── os-locale@1.4.0 extraneous
                        ├── p-cancelable@3.0.0 extraneous
                        ├── p-map@2.1.0 extraneous
                        ├── pako@ extraneous
                        ├── parse-json@2.2.0 extraneous
                        ├── parse5@ extraneous
                        ├── parseqs@0.0.6 extraneous
                        ├── parseuri@0.0.6 extraneous
                        ├── parseurl@1.3.3 extraneous
                        ├── passport-local@1.0.0 extraneous
                        ├── passport-strategy@1.0.0 extraneous
                        ├── passport@ extraneous
                        ├── path-exists@2.1.0 extraneous
                        ├── path-is-absolute@1.0.1 extraneous
                        ├── path-key@3.1.1 extraneous
                        ├── path-parse@1.0.7 extraneous
                        ├── path-posix@1.0.0 extraneous
                        ├── path-to-regexp@0.1.7 extraneous
                        ├── path-type@1.1.0 extraneous
                        ├── pause-stream@0.0.11 extraneous
                        ├── pause@0.0.1 extraneous
                        ├── performance-now@2.1.0 extraneous
                        ├── picocolors@1.0.0 extraneous
                        ├── picomatch@2.3.1 extraneous
                        ├── pidusage@3.0.2 extraneous
                        ├── pify@2.3.0 extraneous
                        ├── pinkie-promise@2.0.1 extraneous
                        ├── pinkie@2.0.4 extraneous
                        ├── point-in-polygon@1.0.1 extraneous
                        ├── prebuild-install@7.1.1 extraneous
                        ├── prelude-ls@1.1.2 extraneous
                        ├── process-nextick-args@2.0.1 extraneous
                        ├── promisify-child-process@4.1.1 extraneous
                        ├── prompt@ extraneous
                        ├── proxy-addr@2.0.7 extraneous
                        ├── proxy-from-env@1.1.0 extraneous
                        ├── pump@3.0.0 extraneous
                        ├── put@0.0.6 extraneous
                        ├── qs@ extraneous
                        ├── querystring@0.2.1 extraneous
                        ├── querystringify@2.2.0 extraneous
                        ├── quick-lru@5.1.1 extraneous
                        ├── random-bytes@1.0.0 extraneous
                        ├── range-parser@1.2.1 extraneous
                        ├── rasha@1.2.5 extraneous
                        ├── raw-body@2.5.2 extraneous
                        ├── rc@1.2.8 extraneous
                        ├── read-pkg-up@1.0.1 extraneous
                        ├── read-pkg@1.1.0 extraneous
                        ├── read@1.0.7 extraneous
                        ├── readable-stream@ extraneous
                        ├── readdirp@3.6.0 extraneous
                        ├── readline-sync@1.4.10 extraneous
                        ├── readline@1.3.0 extraneous
                        ├── redirect-https@1.3.1 extraneous
                        ├── redis-commands@1.7.0 extraneous
                        ├── redis-errors@1.2.0 extraneous
                        ├── redis-parser@3.0.0 extraneous
                        ├── reinterval@1.1.0 extraneous
                        ├── request-promise@4.2.6 extraneous
                        ├── require-directory@2.1.1 extraneous
                        ├── require-main-filename@1.0.1 extraneous
                        ├── requires-port@1.0.0 extraneous
                        ├── resolve-alpn@1.2.1 extraneous
                        ├── resolve@ extraneous
                        ├── respjs@4.2.0 extraneous
                        ├── responselike@3.0.0 extraneous
                        ├── retry-request@4.2.2 extraneous
                        ├── retry@0.12.0 extraneous
                        ├── revalidator@0.1.8 extraneous
                        ├── rimraf@3.0.2 extraneous
                        ├── rrule@2.7.2 extraneous
                        ├── rrweb-cssom@ extraneous
                        ├── rsa-compat@1.9.4 extraneous
                        ├── safe-buffer@5.1.2 extraneous
                        ├── safe-replace@1.1.0 extraneous
                        ├── safe-stable-stringify@2.4.3 extraneous
                        ├── safer-buffer@2.1.2 extraneous
                        ├── sax@0.4.3 extraneous
                        ├── saxes@6.0.0 extraneous
                        ├── semver@5.7.1
                        ├── send@0.18.0 extraneous
                        ├── seq-logging@ extraneous
                        ├── serialport@10.5.0 extraneous
                        ├── serve-static@1.15.0 extraneous
                        ├── set-blocking@2.0.0 extraneous
                        ├── setimmediate@1.0.5 extraneous
                        ├── setprototypeof@1.2.0 extraneous
                        ├── sharp@ extraneous
                        ├── shebang-command@2.0.0 extraneous
                        ├── shebang-regex@3.0.0 extraneous
                        ├── shelly-iot@1.1.2 extraneous
                        ├── side-channel@1.0.4 extraneous
                        ├── signal-exit@3.0.7 extraneous
                        ├── simple-concat@1.0.1 extraneous
                        ├── simple-get@3.1.1 extraneous
                        ├── simple-swizzle@0.2.2 extraneous
                        ├── smartmeter-obis@ extraneous
                        ├── socket.io-adapter@1.1.2 extraneous
                        ├── socket.io-client@ extraneous
                        ├── socket.io-parser@3.4.3 extraneous
                        ├── socket.io@2.5.0 extraneous
                        ├── sorted-array-functions@1.3.0 extraneous
                        ├── source-map-support@0.5.21 extraneous
                        ├── source-map@0.6.1 extraneous
                        ├── spdx-correct@3.2.0 extraneous
                        ├── spdx-exceptions@2.3.0 extraneous
                        ├── spdx-expression-parse@3.0.1 extraneous
                        ├── spdx-license-ids@3.0.13 extraneous
                        ├── split@1.0.1 extraneous
                        ├── split2@3.2.2 extraneous
                        ├── sshpk@ extraneous
                        ├── stack-trace@0.0.10 extraneous
                        ├── standard-as-callback@2.1.0 extraneous
                        ├── statuses@2.0.1 extraneous
                        ├── stream-combiner@0.2.2 extraneous
                        ├── stream-shift@1.0.1 extraneous
                        ├── streamsearch@1.1.0 extraneous
                        ├── string_decoder@1.1.1 extraneous
                        ├── string-width@4.2.3 extraneous
                        ├── strip-ansi@6.0.1 extraneous
                        ├── strip-bom@2.0.0 extraneous
                        ├── strip-final-newline@2.0.0 extraneous
                        ├── strip-json-comments@2.0.1 extraneous
                        ├── strnum@1.0.5 extraneous
                        ├── suncalc2@1.8.1 extraneous
                        ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                        ├── symbol-tree@3.2.4 extraneous
                        ├── tar-fs@ extraneous
                        ├── tar-stream@2.2.0 extraneous
                        ├── tar@ extraneous
                        ├── tcp-ping@0.1.1 extraneous
                        ├── text-hex@1.0.0 extraneous
                        ├── through@2.3.8 extraneous
                        ├── through2@2.0.5 extraneous
                        ├── to-array@0.1.4 extraneous
                        ├── to-regex-range@5.0.1 extraneous
                        ├── toidentifier@1.0.1 extraneous
                        ├── tough-cookie@4.1.3 extraneous
                        ├── tr-064@0.2.0 extraneous
                        ├── tr-O64@0.2.4 extraneous
                        ├── tr46@4.1.1 extraneous
                        ├── traverse@0.3.9 extraneous
                        ├── treemap-js@1.2.1 extraneous
                        ├── triple-beam@1.3.0 extraneous
                        ├── tunnel-agent@0.6.0 extraneous
                        ├── tweetnacl@0.14.5 extraneous
                        ├── type-check@0.3.2 extraneous
                        ├── type-is@1.6.18 extraneous
                        ├── typedarray@0.0.6 extraneous
                        ├── typescript@ extraneous
                        ├── uid-safe@2.1.5 extraneous
                        ├── ultron@1.1.1 extraneous
                        ├── unix-dgram@2.0.6 extraneous
                        ├── unpipe@1.0.0 extraneous
                        ├── uri-js@ extraneous
                        ├── url-join@4.0.1 extraneous
                        ├── url-parse@1.5.10 extraneous
                        ├── url-template@2.0.8 extraneous
                        ├── ursa-optional@0.9.10 extraneous
                        ├── util-deprecate@1.0.2 extraneous
                        ├── utils-merge@1.0.1 extraneous
                        ├── validate-npm-package-license@3.0.4 extraneous
                        ├── vary@1.1.2 extraneous
                        ├── verror@1.10.0 extraneous
                        ├── virtual-tsc@0.6.2 extraneous
                        ├── w3c-xmlserializer@4.0.0 extraneous
                        ├── wake_on_lan@1.0.0 extraneous
                        ├── weak-daemon@1.0.3 extraneous
                        ├── webdav@ extraneous
                        ├── webidl-conversions@7.0.0 extraneous
                        ├── websocket-stream@5.5.2 extraneous
                        ├── whatwg-encoding@2.0.0 extraneous
                        ├── whatwg-mimetype@3.0.0 extraneous
                        ├── whatwg-url@ extraneous
                        ├── which-module@1.0.0 extraneous
                        ├── which@2.0.2 extraneous
                        ├── wide-align@1.1.5 extraneous
                        ├── winston-daily-rotate-file@4.7.1 extraneous
                        ├── winston-seq-updated@1.0.4 extraneous
                        ├── winston-syslog@2.7.0 extraneous
                        ├── winston-transport@4.5.0 extraneous
                        ├── winston@ extraneous
                        ├── word-wrap@1.2.3 extraneous
                        ├── wrap-ansi@2.1.0 extraneous
                        ├── wrappy@1.0.2 extraneous
                        ├── ws@ extraneous
                        ├── xml-name-validator@4.0.0 extraneous
                        ├── xml2js@0.4.23 extraneous
                        ├── xml2json-light@1.0.6 extraneous
                        ├── xmlbuilder@0.4.2 extraneous
                        ├── xmlchars@2.2.0 extraneous
                        ├── xmlhttprequest-ssl@1.6.3 extraneous
                        ├── xregexp@2.0.0 extraneous
                        ├── xtend@4.0.2 extraneous
                        ├── y18n@3.2.2 extraneous
                        ├── yallist@4.0.0 extraneous
                        ├── yargs-parser@5.0.1 extraneous
                        ├── yargs@ invalid: "^7.0.2" from the root project
                        ├── yeast@0.1.2 extraneous
                        ├── zlib@1.0.5 extraneous
                        └── zrender@4.3.2 extraneous
                        npm ERR!     /home/iobroker/.npm/_logs/2023-06-20T21_38_40_453Z-debug-0.log
                        pi@ioBroker-RasPi4:/opt/iobroker $ ^C
                        pi@ioBroker-RasPi4:/opt/iobroker $ cd /opt/iobroker
                        pi@ioBroker-RasPi4:/opt/iobroker $ sudo -u iobroker npm install iobroker.js-controller@4.0.24
                        npm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                        npm ERR! dest /opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'
                        npm ERR!     /home/iobroker/.npm/_logs/2023-06-20T21_45_26_653Z-debug-0.log
                        Thomas BraunT C 2 Antworten Letzte Antwort
                        • C chemieka
                          @chemieka
                          ├── ajv@ extraneous
                          ├── colors@1.4.0
                          ├── fs-extra@7.0.1
                          ├── got@ extraneous
                          ├── iobroker@2.0.3
                          ├── nan@ extraneous
                          ├── qs@ extraneous
                          ├── semver@5.7.1
                          ├── tar@ extraneous
                          ├── ws@ extraneous
                          npm ERR! errno -39
                          @chemieka
                          cd ~
                          find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
                          Danach noch mal
                          cd /opt/iobroker
                          C 1 Antwort Letzte Antwort
                          • C chemieka
                            @chemieka
                            ├── ajv@ extraneous
                            ├── colors@1.4.0
                            ├── fs-extra@7.0.1
                            ├── got@ extraneous
                            ├── iobroker@2.0.3
                            ├── nan@ extraneous
                            ├── qs@ extraneous
                            ├── semver@5.7.1
                            ├── tar@ extraneous
                            ├── ws@ extraneous
                            npm ERR! errno -39
                            chemieka
                            @chemieka
                            Evtl. macht es doch Sinn das System neu aufzulegen. Ein Backup hatte ich mit dem Adapter gemacht. Dann solllte doch alles Wiederherstellbar sein.
                            Oder hast du noch eine Idee ?
                            • C chemieka
                              @chemieka
                              @chemieka sagte in Nach Update auf Node 16 startet IOBROKER nicht mehr:
                              Die steht doch oben.
                                @chemieka
                                cd ~
                                Danach noch mal
                                cd /opt/iobroker
                                chemieka
                                @thomas-braun sagte in Nach Update auf Node 16 startet IOBROKER nicht mehr:
                                läuft nach dem find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" ; &> /dev/null
                                kam keine Rückmeldung, denke muss so sein.
                                • C chemieka
                                  chemieka
                                  schrieb am zuletzt editiert von chemieka
                                  zunächst die Warns
                                  npm WARN skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.flot.git
                                  npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                  npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                                  npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                  npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                  npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                  npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                  npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                  • C chemieka
                                    chemieka
                                    npm WARN cleanup Failed to remove some directories [
                                    npm WARN cleanup   [
                                    npm WARN cleanup     '/opt/iobroker/node_modules/unix-dgram',
                                    npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/unix-dgram'] {
                                    npm WARN cleanup       errno: -39,
                                    npm WARN cleanup       code: 'ENOTEMPTY',
                                    npm WARN cleanup       syscall: 'rmdir',
                                    npm WARN cleanup       path: '/opt/iobroker/node_modules/unix-dgram'
                                    npm WARN cleanup     }
                                    npm WARN cleanup   ],
                                    npm WARN cleanup   [
                                    npm WARN cleanup     }
                                    npm WARN cleanup   ]
                                    npm WARN cleanup ]
                                    npm ERR! command failed
                                    npm ERR! signal SIGINT
                                    npm ERR! command sh -c node iobroker.js setup first
                                    npm ERR!     /home/iobroker/.npm/_logs/2023-06-20T21_58_44_223Z-debug-0.log
                                    • C chemieka
                                      npm WARN cleanup   [
                                      npm WARN cleanup     }
                                      npm WARN cleanup   ],
                                      npm WARN cleanup   [
                                      npm WARN cleanup     }
                                      npm WARN cleanup   ]
                                      npm WARN cleanup ]
                                      @chemieka
                                      Ich muss mal pennen gehen.
                                        chemieka
                                        leider auch kein Erfolg. wenn du noch Vorschläge hättest würde ich die morgen umsetzen. Vielen Dank für deine Mühe.
                                        • mickymM Offline
                                          mickymM Offline
                                          mickym
                                          Ich würde halt das ganze modules Verzeichnis neu aufbauen lassen: https://forum.iobroker.net/post/831638
                                          Aber meine Meinung kennt ihr ja diesbezgl.
