  4. Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst]
    5.4k
21 Beiträge 2 Kommentatoren 2.4k Aufrufe 2 Beobachtet
    @reutli
    Dürfte das sein:
    https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev?_=1687246153280
    udev armhf 247.3-7+rpi1+deb11u2 und dessen 'Drumherum' ist kaputt.
    Und stell die Kiste auf Serverbetrieb (ohne Desktop) um. Ein Chromium hat da z. B. nix zu suchen.
    reutli
    Hi, danke für die Antwort.
    Leider bekomme ich noch einen Fehler:
    pi@iobroker2:/etc/apt/sources.list.d $ sudo nano bullseye-proposed-updates.list
    pi@iobroker2:/etc/apt/sources.list.d $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Err:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
    Reading package lists... Done
    W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
    E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    pi@iobroker2:/etc/apt/sources.list.d $ sudo apt -t bullseye-proposed-updates install udev
    E: The value 'bullseye-proposed-updates' is invalid for APT::Default-Release as such a release is not available in the sources
    iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
    *Wer freundlich ist, dem wird freundlich geholfen *
    • R reutli
      @reutli
      Steht alles im verlinkten Post drin.
      Musst nur die key-ID anpassen.
      R 1 Antwort Letzte Antwort
        @reutli
        reutli
        @thomas-braun sagte in Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade):
        auf welche? Sorry bin zu doof 😞
        pi@iobroker2:/etc/apt/sources.list.d $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
        Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
        Executing: /tmp/apt-key-gpghome.EEfmRwEucb/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
        gpg: key DC30D7C23CBBABEE: public key "Debian Archive Automatic Signing Key (10/buster) <ftpmaster@debian.org>" imported
        gpg: Total number processed: 1
        gpg:               imported: 1
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Get:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
        Err:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease
        • R reutli
          gpg:               imported: 1
          @reutli sagte in Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade):
          Dir fehlt:
          Also
          sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
          sudo apt update
            Dir fehlt:
            Also
            sudo apt update
            reutli
            Das hat geklappt, danke.
            Trotzdem bekomme ich wohl nicht das hin was es sein sollte:
            pi@iobroker2:~ $ apt policy udev
            udev:
              Installed: 247.3-7+rpi1+deb11u2
              Candidate: 247.3-7+rpi1+deb11u2
              Version table:
             *** 247.3-7+rpi1+deb11u2 500
                 247.3-7+deb11u3 500
                    500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
            pi@iobroker2:~ $ sudo apt -t bullseye-proposed-updates install udev
            udev is already the newest version (247.3-7+rpi1+deb11u2).
            The following packages were automatically installed and are no longer required:
              libfuse2 raspinfo
            Use 'sudo apt autoremove' to remove them.
            0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
            udev:
              Version table:
                 247.3-7+deb11u3 500
            • R reutli
              udev:
                Version table:
                   247.3-7+deb11u3 500
                libfuse2 raspinfo
              udev:
                Version table:
                   247.3-7+deb11u3 500
              @reutli
              Du musst das auch vollständig lesen.
              Genau deine Situation mit einem 32bit-RaspberryOS ist im letzten Absatz erläutert.
                @reutli
                reutli
                Vielen Dank für Deine Hilfe! Jetzt hat es geklappt:
                udev:
                  Installed: 247.3-7+deb11u3
                  Version table:
                 *** 247.3-7+deb11u3 500
                pi@iobroker2:~ $ ls -l /dev/serial/by-id/
                total 0
                lrwxrwxrwx 1 root root 13 Jun 20 10:03 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0 -> ../../ttyUSB0
                pi@iobroker2:~ $
                Wie erfahre ich jetzt wann das Paket gefixt ist und ich den
                sudo apt-mark hold udev
                wieder rausnehmen kann?
                • R reutli
                  udev:
                    Version table:
                  total 0
                  pi@iobroker2:~ $
                  Mal regelmäßig per
                  sudo apt update
                  apt policy udev
                  prüfen ob eine passende Version vom RaspberryOS hochgeladen wurde.
                  Offengesagt wundert es mich schon, wie lange das Paket schon neben der Spur hängt.
                    Mal regelmäßig per
                    sudo apt update
                    apt policy udev
                    reutli
                    ok, danke, will do so.
                    und jetzt noch dazu:
                    Einfachster und sauberster Weg dahin?
                    • R reutli
                      Ich würde an deiner Stelle in den nächsten Wochen/Monaten (sobald es released worden ist) auf ein RaspberryOS 'Bookworm' 64bit wechseln. Das musst du eh komplett neuinstallieren, dann kannst du es gleich in der 'Lite'-Version ohne Desktop installieren.
                      Da hat sich dann auch das Problem mit udev erledigt, die Version dort funktioniert ohne Klimmzüge.
                        reutli
                        Hab jetzt immerhin mal
                        pi@iobroker2:~ $ who -r
                                 run-level 3  2023-06-20 10:19
                        Im Ernst ich muss neu installieren???
                        Das macht mir jetzt schon Kopfzerbrechen, habe einen MACmini mit Debian als Master und zwei PIs als Slave.
                        Die neu zu installieren (mit Influx und Grafana), da schlottern mir jetzt schon die Knie.
                        Ist ja in dem Fall nicht einfach OS drauf und Restore, sondern Influx und Grafana neu machen.
                        Machst Du oder jemand anders ein Tutorial dazu?
                        • R reutli
                          Ja, ein Wechsel der Prozessor-Architektur ist nur per Neuinstallation möglich.
                          Öh, doch, ist im Wesentlichen einfach OS drauf, Influx installieren, Grafana installieren (gibt ja Repos dafür), ioBroker installieren, Backup einspielen, fertig.
                            reutli
                            muss nochmals nachfragen...
                            Habe meine Maschinen gestern gecheckt:
                            admin@macmini-iobroker:~$ uname -m
                            x86_64
                            pi@iobroker2:~ $ uname -m
                            aarch64
                            pi@iobroker:~ $ uname -m
                            aarch64
                            Damit sollten die alle schon auf 64Bit OS sein, oder?
                            Dazu zwei Fragen:
                            1. Kannst Du Dir erklären warum dann der Standardweg aus https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev?_=1687246153280 nicht funktioniert hat, sondern nur der letzte Schritt (32 Bit System)?
                            2. Wenn 64 Bit installiert ist, müsste ein Update auf Bookworm möglich sein, oder (also ohne Neuinstallation)?
                            • R reutli
                              x86_64
                              aarch64
                              aarch64
                              Dazu zwei Fragen:
                              @reutli sagte in Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst]:
                              Nicht unbedingt. Raspberrypi OS haben zuletzt den Blödsinn angefangen den Kernel in 64bit auszurollen, das sog. userland aber bei 32bit zu belassen.
                              Mit uname -m prüfst du nur den Kernel.
                              Zu
                              1.) Siehe zuvor, du wirst einen Hybriden haben
                              Eine kommende Version von iob diag hat den Check drin.
                              2.) Bei einem reinen 64bit-System ja. Bei einem Hybrid würde ich es neuaufsetzen.
                              [Edit:]
                              Das userland kannst du dir so anschauen:
                              dpkg --print-architecture
                                Zu
                                [Edit:]
                                reutli
                                Danke für Deine Antwort.
                                Das heisst mit
                                bekomme ich "korrekt angezeigt, ob ich auf 32Bit oder 64Bit unterwegs bin?
                                • R reutli
                                  Das heisst mit
                                  @reutli
                                  Das zeigt dir die Architektur für das 'userland'. Bei 64bit müsste da was von arm64 stehen, bei 32bit steht da was von 'armhf'.
                                    @reutli
                                    reutli
                                    Das heisst, wenn
                                    und
                                    uname -m
                                    auf 64Bit hinweisen, dann kann ich mir einigermaßen sicher sein, dass ich 64Bit am Start habe und damit auch ein Update auf 'bookworm' vornehmen kann (auch wenn ich weiss, dass eine Neuinstallation besser ist)?
                                    • R reutli
                                      Das heisst, wenn
                                      und
                                      uname -m
                                      @reutli
                                      Ein Upgrade auf Bookworm kannst du so oder so machen.
                                      Ich würde aber halt bei der Gelegenheit das große Rad drehen und auf ein reines 64bit-System wechseln.
                                      Wie schaut es denn nun konkret bei dir aus?
                                        @reutli
                                        reutli
                                        Master:
                                        admin@macmini-iobroker:~$ dpkg --print-architecture
                                        amd64
                                        Slave1:
                                        pi@iobroker:~ $ dpkg --print-architecture
                                        arm64
                                        Slave2:
                                        pi@iobroker2:~ $ dpkg --print-architecture
                                        armhf
                                        also der, der die USB Probleme hatte. Das heisst den müsste ich neu aufsetzen.
                                        Hier ist mir aber immer noch nicht ganz klar, wie der Restore des Salzes dann über BackitUp funktioniert.
                                        Für diese Client gibt es eine BackitUp-Instanz, die ZigBee sichert.
                                        Wenn ich jetzt nur diesen Slave neu installieren möchte, dann weiss ich nicht, wie das mit dem Restore funktioniert (da die anderen ja nicht restored werden sollen). Gehört ja aber nicht hierher....
