<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst]]]></title><description><![CDATA[<p dir="auto">Hallo Leute,</p>
<p dir="auto">habe heute mal wieder eine Update session auf meinen Rechnern gemacht. Leider wird jetzt auf meinem Slave PI der Sonoff Zigbee 3.0 nicht mehr erkannt:</p>
<pre><code>pi@iobroker2:/dev/serial $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@iobroker2:/dev/serial $ ls -la /dev/serial/by-id/
ls: cannot access '/dev/serial/by-id/': No such file or directory
</code></pre>
<p dir="auto">Das war die einzige Aktion die ich vollzogen habe:</p>
<pre><code>pi@iobroker2:~ $ sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  libfuse2 raspinfo
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
  avahi-daemon base-files chromium-browser chromium-browser-l10n
  chromium-codecs-ffmpeg-extra cups-browsed cups-filters
  cups-filters-core-drivers ffmpeg grep isc-dhcp-client isc-dhcp-common
  libatspi2.0-0 libavahi-client-dev libavahi-client3 libavahi-common-data
  libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
  libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58
  libavdevice58 libavfilter7 libavformat58 libavresample4 libavutil56
  libcupsfilters1 libfontembed1 libncurses6 libncursesw6 libpam-systemd
  libpostproc55 libssh-gcrypt-4 libswresample3 libswscale5 libsynctex2
  libsystemd0 libtinfo5 libtinfo6 libudev-dev libudev1 libwebp6 libwebpdemux2
  libwebpmux3 libwidevinecdm0 libxpm4 lxplug-bluetooth lxplug-cputemp
  lxplug-menu lxplug-network lxplug-ptbatt lxplug-updater ncurses-base
  ncurses-bin ncurses-term raspberrypi-sys-mods rp-prefapps rpi-eeprom
  rpi-imager systemd systemd-sysv systemd-timesyncd traceroute tzdata udev
  usb.ids
68 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 130 MB of archives.
After this operation, 206 MB disk space will be freed.
Get:1 http://archive.raspberrypi.org/debian bullseye/main armhf chromium-browser-l10n all 113.0.5672.95-rpt1 [5,713 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf base-files armhf 11.1+rpi1+deb11u7 [70.4 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf grep armhf 3.6-1+deb11u1 [381 kB]
Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf ncurses-bin armhf 6.2+20201114-2+deb11u1 [421 kB]
Get:5 http://archive.raspberrypi.org/debian bullseye/main armhf chromium-browser armhf 113.0.5672.95-rpt1 [86.0 MB]
Get:7 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf systemd-sysv armhf 247.3-7+rpi1+deb11u2 [114 kB]
Get:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf ncurses-base all 6.2+20201114-2+deb11u1 [272 kB]
Get:9 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libudev-dev armhf 247.3-7+rpi1+deb11u2 [124 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libpam-systemd armhf 247.3-7+rpi1+deb11u2 [261 kB]
Get:10 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libsystemd0 armhf 247.3-7+rpi1+deb11u2 [346 kB]
Get:11 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf systemd-timesyncd armhf 247.3-7+rpi1+deb11u2 [131 kB]
Get:12 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf systemd armhf 247.3-7+rpi1+deb11u2 [4,252 kB]
Get:17 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libavahi-core7 armhf 0.8-5+deb11u2 [107 kB]
Get:13 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf udev armhf 247.3-7+rpi1+deb11u2 [1,431 kB]
Get:14 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libudev1 armhf 247.3-7+rpi1+deb11u2 [162 kB]
Get:15 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libavahi-glib1 armhf 0.8-5+deb11u2 [44.1 kB]
Get:16 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf avahi-daemon armhf 0.8-5+deb11u2 [91.2 kB]
Get:18 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libavahi-compat-libdnssd-dev armhf 0.8-5+deb11u2 [65.5 kB]
Get:19 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libavahi-client-dev armhf 0.8-5+deb11u2 [66.3 kB]
Get:20 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libavahi-compat-libdnssd1 armhf 0.8-5+deb11u2 [50.9 kB]
Get:21 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libavahi-client3 armhf 0.8-5+deb11u2 [58.3 kB]
Get:22 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libavahi-common-dev armhf 0.8-5+deb11u2 [69.5 kB]
Get:24 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libavahi-common-data armhf 0.8-5+deb11u2 [124 kB]
Get:23 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libavahi-common3 armhf 0.8-5+deb11u2 [55.7 kB]
Get:26 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcupsfilters1 armhf 1.28.7-1+deb11u2 [133 kB]
Get:25 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libatspi2.0-0 armhf 2.38.0-4+deb11u1 [62.1 kB]
Get:27 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf cups-browsed armhf 1.28.7-1+deb11u2 [146 kB]
Get:28 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libncurses6 armhf 6.2+20201114-2+deb11u1 [79.5 kB]
Get:29 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libtinfo6 armhf 6.2+20201114-2+deb11u1 [328 kB]
Get:30 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libncursesw6 armhf 6.2+20201114-2+deb11u1 [105 kB]
Get:31 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf tzdata all 2021a-1+deb11u10 [286 kB]
Get:32 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf isc-dhcp-client armhf 4.4.1-2.3+deb11u2 [296 kB]
Get:33 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf isc-dhcp-common armhf 4.4.1-2.3+deb11u2 [145 kB]
Get:34 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf traceroute armhf 1:2.1.0-2+deb11u1 [48.9 kB]
Get:35 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf ncurses-term all 6.2+20201114-2+deb11u1 [505 kB]
Get:36 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf cups-filters-core-drivers armhf 1.28.7-1+deb11u2 [190 kB]
Get:37 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libfontembed1 armhf 1.28.7-1+deb11u2 [73.2 kB]
Get:38 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf cups-filters armhf 1.28.7-1+deb11u2 [560 kB]
Get:39 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libssh-gcrypt-4 armhf 0.9.7-0+deb11u1 [190 kB]
Get:40 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libwebp6 armhf 0.6.1-2.1+deb11u1 [225 kB]
Get:41 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libwebpmux3 armhf 0.6.1-2.1+deb11u1 [94.4 kB]
Get:42 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libsynctex2 armhf 2020.20200327.54578-7+deb11u1 [70.3 kB]
Get:45 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libxpm4 armhf 1:3.5.12-1.1~deb11u1 [44.0 kB]
Get:46 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf usb.ids all 2023.01.16-0+deb11u1 [206 kB]
Get:43 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libtinfo5 armhf 6.2+20201114-2+deb11u1 [324 kB]
Get:47 http://archive.raspberrypi.org/debian bullseye/main armhf chromium-codecs-ffmpeg-extra armhf 113.0.5672.95-rpt1 [1,028 kB]
Get:44 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libwebpdemux2 armhf 0.6.1-2.1+deb11u1 [86.8 kB]
Get:48 http://archive.raspberrypi.org/debian bullseye/main armhf ffmpeg armhf 7:4.3.6-0+deb11u1+rpt1 [1,583 kB]
Get:49 http://archive.raspberrypi.org/debian bullseye/main armhf libavdevice58 armhf 7:4.3.6-0+deb11u1+rpt1 [159 kB]
Get:50 http://archive.raspberrypi.org/debian bullseye/main armhf libavfilter7 armhf 7:4.3.6-0+deb11u1+rpt1 [1,783 kB]
Get:51 http://archive.raspberrypi.org/debian bullseye/main armhf libswscale5 armhf 7:4.3.6-0+deb11u1+rpt1 [261 kB]
Get:52 http://archive.raspberrypi.org/debian bullseye/main armhf libavformat58 armhf 7:4.3.6-0+deb11u1+rpt1 [1,568 kB]
Get:53 http://archive.raspberrypi.org/debian bullseye/main armhf libavcodec58 armhf 7:4.3.6-0+deb11u1+rpt1 [9,118 kB]
Get:54 http://archive.raspberrypi.org/debian bullseye/main armhf libswresample3 armhf 7:4.3.6-0+deb11u1+rpt1 [122 kB]
Get:55 http://archive.raspberrypi.org/debian bullseye/main armhf libpostproc55 armhf 7:4.3.6-0+deb11u1+rpt1 [97.6 kB]
Get:56 http://archive.raspberrypi.org/debian bullseye/main armhf libavresample4 armhf 7:4.3.6-0+deb11u1+rpt1 [108 kB]
Get:57 http://archive.raspberrypi.org/debian bullseye/main armhf libavutil56 armhf 7:4.3.6-0+deb11u1+rpt1 [465 kB]
Get:58 http://archive.raspberrypi.org/debian bullseye/main armhf libwidevinecdm0 armhf 4.10.2252.0+3 [5,991 kB]
Get:59 http://archive.raspberrypi.org/debian bullseye/main armhf lxplug-bluetooth armhf 0.33 [24.9 kB]
Get:60 http://archive.raspberrypi.org/debian bullseye/main armhf lxplug-cputemp armhf 0.11 [9,700 B]
Get:61 http://archive.raspberrypi.org/debian bullseye/main armhf lxplug-menu armhf 0.4 [22.9 kB]
Get:62 http://archive.raspberrypi.org/debian bullseye/main armhf lxplug-network armhf 0.33 [38.2 kB]
Get:63 http://archive.raspberrypi.org/debian bullseye/main armhf lxplug-ptbatt armhf 0.21 [15.0 kB]
Get:64 http://archive.raspberrypi.org/debian bullseye/main armhf lxplug-updater armhf 0.14 [13.9 kB]
Get:65 http://archive.raspberrypi.org/debian bullseye/main armhf raspberrypi-sys-mods armhf 20230510~bullseye [18.4 kB]
Get:66 http://archive.raspberrypi.org/debian bullseye/main armhf rp-prefapps armhf 0.47 [319 kB]
Get:67 http://archive.raspberrypi.org/debian bullseye/main armhf rpi-eeprom armhf 16.1-1 [2,396 kB]
Get:68 http://archive.raspberrypi.org/debian bullseye/main armhf rpi-imager armhf 1.7.5+rpt1 [366 kB]
Fetched 130 MB in 22s (5,953 kB/s)
Reading changelogs... Done
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 113407 files and directories currently installed.)
Preparing to unpack .../base-files_11.1+rpi1+deb11u7_armhf.deb ...................................................................................................]
Unpacking base-files (11.1+rpi1+deb11u7) over (11.1+rpi1+deb11u6) ...
Setting up base-files (11.1+rpi1+deb11u7) ...
Installing new version of config file /etc/debian_version ...
Preparing to unpack .../grep_3.6-1+deb11u1_armhf.deb ...
Unpacking grep (3.6-1+deb11u1) over (3.6-1) ...
Setting up grep (3.6-1+deb11u1) ...
Preparing to unpack .../ncurses-bin_6.2+20201114-2+deb11u1_armhf.deb ...
Unpacking ncurses-bin (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
Setting up ncurses-bin (6.2+20201114-2+deb11u1) ...
Preparing to unpack .../ncurses-base_6.2+20201114-2+deb11u1_all.deb ...
Unpacking ncurses-base (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
Setting up ncurses-base (6.2+20201114-2+deb11u1) ...
Preparing to unpack .../systemd-sysv_247.3-7+rpi1+deb11u2_armhf.deb ...
Unpacking systemd-sysv (247.3-7+rpi1+deb11u2) over (247.3-7+rpi1+deb11u1) ...
Preparing to unpack .../libpam-systemd_247.3-7+rpi1+deb11u2_armhf.deb ...
Unpacking libpam-systemd:armhf (247.3-7+rpi1+deb11u2) over (247.3-7+rpi1+deb11u1) ...
Preparing to unpack .../libudev-dev_247.3-7+rpi1+deb11u2_armhf.deb ...
Unpacking libudev-dev:armhf (247.3-7+rpi1+deb11u2) over (247.3-7+rpi1+deb11u1) ...
Preparing to unpack .../libsystemd0_247.3-7+rpi1+deb11u2_armhf.deb ...
Unpacking libsystemd0:armhf (247.3-7+rpi1+deb11u2) over (247.3-7+rpi1+deb11u1) ...
Setting up libsystemd0:armhf (247.3-7+rpi1+deb11u2) ...
Preparing to unpack .../systemd-timesyncd_247.3-7+rpi1+deb11u2_armhf.deb ...
Unpacking systemd-timesyncd (247.3-7+rpi1+deb11u2) over (247.3-7+rpi1+deb11u1) ...
Preparing to unpack .../systemd_247.3-7+rpi1+deb11u2_armhf.deb ...
Unpacking systemd (247.3-7+rpi1+deb11u2) over (247.3-7+rpi1+deb11u1) ...
Preparing to unpack .../udev_247.3-7+rpi1+deb11u2_armhf.deb ...
Unpacking udev (247.3-7+rpi1+deb11u2) over (247.3-7+rpi1+deb11u1) ...
Preparing to unpack .../libudev1_247.3-7+rpi1+deb11u2_armhf.deb ...
Unpacking libudev1:armhf (247.3-7+rpi1+deb11u2) over (247.3-7+rpi1+deb11u1) ...
Setting up libudev1:armhf (247.3-7+rpi1+deb11u2) ...
Preparing to unpack .../00-libavahi-glib1_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-glib1:armhf (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../01-avahi-daemon_0.8-5+deb11u2_armhf.deb ...
Unpacking avahi-daemon (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../02-libavahi-core7_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-core7:armhf (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../03-libavahi-compat-libdnssd-dev_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-compat-libdnssd-dev:armhf (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../04-libavahi-client-dev_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-client-dev:armhf (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../05-libavahi-compat-libdnssd1_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-compat-libdnssd1:armhf (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../06-libavahi-client3_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-client3:armhf (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../07-libavahi-common-dev_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-common-dev:armhf (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../08-libavahi-common3_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-common3:armhf (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../09-libavahi-common-data_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-common-data:armhf (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
Preparing to unpack .../10-chromium-browser-l10n_113.0.5672.95-rpt1_all.deb ...
Unpacking chromium-browser-l10n (113.0.5672.95-rpt1) over (109.0.5414.112-rpt2) ...
Preparing to unpack .../11-libatspi2.0-0_2.38.0-4+deb11u1_armhf.deb ...
Unpacking libatspi2.0-0:armhf (2.38.0-4+deb11u1) over (2.38.0-4) ...
Preparing to unpack .../12-chromium-browser_113.0.5672.95-rpt1_armhf.deb ...
Unpacking chromium-browser (113.0.5672.95-rpt1) over (109.0.5414.112-rpt2) ...
Preparing to unpack .../13-chromium-codecs-ffmpeg-extra_113.0.5672.95-rpt1_armhf.deb ...
Unpacking chromium-codecs-ffmpeg-extra (113.0.5672.95-rpt1) over (109.0.5414.112-rpt2) ...
Preparing to unpack .../14-libcupsfilters1_1.28.7-1+deb11u2_armhf.deb ...
Unpacking libcupsfilters1:armhf (1.28.7-1+deb11u2) over (1.28.7-1+deb11u1) ...
Preparing to unpack .../15-cups-browsed_1.28.7-1+deb11u2_armhf.deb ...
Unpacking cups-browsed (1.28.7-1+deb11u2) over (1.28.7-1+deb11u1) ...
Preparing to unpack .../16-libncurses6_6.2+20201114-2+deb11u1_armhf.deb ...
Unpacking libncurses6:armhf (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
Preparing to unpack .../17-libtinfo6_6.2+20201114-2+deb11u1_armhf.deb ...
Unpacking libtinfo6:armhf (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
Setting up libtinfo6:armhf (6.2+20201114-2+deb11u1) ...
(Reading database ... 113403 files and directories currently installed.)
Preparing to unpack .../libncursesw6_6.2+20201114-2+deb11u1_armhf.deb ...
Unpacking libncursesw6:armhf (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
Setting up libncursesw6:armhf (6.2+20201114-2+deb11u1) ...
Preparing to unpack .../00-tzdata_2021a-1+deb11u10_all.deb ...
Unpacking tzdata (2021a-1+deb11u10) over (2021a-1+deb11u8) ...
Preparing to unpack .../01-isc-dhcp-client_4.4.1-2.3+deb11u2_armhf.deb ...
Unpacking isc-dhcp-client (4.4.1-2.3+deb11u2) over (4.4.1-2.3+deb11u1) ...
Preparing to unpack .../02-isc-dhcp-common_4.4.1-2.3+deb11u2_armhf.deb ...
Unpacking isc-dhcp-common (4.4.1-2.3+deb11u2) over (4.4.1-2.3+deb11u1) ...
Preparing to unpack .../03-traceroute_1%3a2.1.0-2+deb11u1_armhf.deb ...
Unpacking traceroute (1:2.1.0-2+deb11u1) over (1:2.1.0-2) ...
Preparing to unpack .../04-ncurses-term_6.2+20201114-2+deb11u1_all.deb ...
Unpacking ncurses-term (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
Preparing to unpack .../05-cups-filters-core-drivers_1.28.7-1+deb11u2_armhf.deb ...
Unpacking cups-filters-core-drivers (1.28.7-1+deb11u2) over (1.28.7-1+deb11u1) ...
Preparing to unpack .../06-libfontembed1_1.28.7-1+deb11u2_armhf.deb ...
Unpacking libfontembed1:armhf (1.28.7-1+deb11u2) over (1.28.7-1+deb11u1) ...
Preparing to unpack .../07-cups-filters_1.28.7-1+deb11u2_armhf.deb ...
Unpacking cups-filters (1.28.7-1+deb11u2) over (1.28.7-1+deb11u1) ...
Preparing to unpack .../08-ffmpeg_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking ffmpeg (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../09-libavdevice58_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking libavdevice58:armhf (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../10-libavfilter7_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking libavfilter7:armhf (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../11-libswscale5_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking libswscale5:armhf (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../12-libavformat58_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking libavformat58:armhf (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../13-libavcodec58_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking libavcodec58:armhf (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../14-libswresample3_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking libswresample3:armhf (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../15-libpostproc55_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking libpostproc55:armhf (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../16-libavresample4_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking libavresample4:armhf (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../17-libavutil56_7%3a4.3.6-0+deb11u1+rpt1_armhf.deb ...
Unpacking libavutil56:armhf (7:4.3.6-0+deb11u1+rpt1) over (7:4.3.5-0+deb11u1+rpt3) ...
Preparing to unpack .../18-libssh-gcrypt-4_0.9.7-0+deb11u1_armhf.deb ...
Unpacking libssh-gcrypt-4:armhf (0.9.7-0+deb11u1) over (0.9.5-1+deb11u1) ...
Preparing to unpack .../19-libwebp6_0.6.1-2.1+deb11u1_armhf.deb ...
Unpacking libwebp6:armhf (0.6.1-2.1+deb11u1) over (0.6.1-2.1) ...
Preparing to unpack .../20-libwebpmux3_0.6.1-2.1+deb11u1_armhf.deb ...
Unpacking libwebpmux3:armhf (0.6.1-2.1+deb11u1) over (0.6.1-2.1) ...
Preparing to unpack .../21-libsynctex2_2020.20200327.54578-7+deb11u1_armhf.deb ...
Unpacking libsynctex2:armhf (2020.20200327.54578-7+deb11u1) over (2020.20200327.54578-7) ...
Preparing to unpack .../22-libtinfo5_6.2+20201114-2+deb11u1_armhf.deb ...
Unpacking libtinfo5:armhf (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
Preparing to unpack .../23-libwebpdemux2_0.6.1-2.1+deb11u1_armhf.deb ...
Unpacking libwebpdemux2:armhf (0.6.1-2.1+deb11u1) over (0.6.1-2.1) ...
Preparing to unpack .../24-libwidevinecdm0_4.10.2252.0+3_armhf.deb ...
Unpacking libwidevinecdm0 (4.10.2252.0+3) over (4.10.2252.0+1) ...
Preparing to unpack .../25-libxpm4_1%3a3.5.12-1.1~deb11u1_armhf.deb ...
Unpacking libxpm4:armhf (1:3.5.12-1.1~deb11u1) over (1:3.5.12-1) ...
Preparing to unpack .../26-lxplug-bluetooth_0.33_armhf.deb ...
Unpacking lxplug-bluetooth (0.33) over (0.32) ...
Preparing to unpack .../27-lxplug-cputemp_0.11_armhf.deb ...
Unpacking lxplug-cputemp (0.11) over (0.10) ...
Preparing to unpack .../28-lxplug-menu_0.4_armhf.deb ...
Unpacking lxplug-menu (0.4) over (0.3) ...
Preparing to unpack .../29-lxplug-network_0.33_armhf.deb ...
Unpacking lxplug-network (0.33) over (0.32) ...
Preparing to unpack .../30-lxplug-ptbatt_0.21_armhf.deb ...
Unpacking lxplug-ptbatt (0.21) over (0.20) ...
Preparing to unpack .../31-lxplug-updater_0.14_armhf.deb ...
Unpacking lxplug-updater (0.14) over (0.13) ...
Preparing to unpack .../32-raspberrypi-sys-mods_20230510~bullseye_armhf.deb ...
Unpacking raspberrypi-sys-mods (20230510~bullseye) over (20230329) ...
Preparing to unpack .../33-rp-prefapps_0.47_armhf.deb ...
Unpacking rp-prefapps (0.47) over (0.46) ...
Preparing to unpack .../34-rpi-eeprom_16.1-1_armhf.deb ...
Unpacking rpi-eeprom (16.1-1) over (16.0-1) ...
Preparing to unpack .../35-rpi-imager_1.7.5+rpt1_armhf.deb ...
Unpacking rpi-imager (1.7.5+rpt1) over (1.7.4+rpt1) ...
Preparing to unpack .../36-usb.ids_2023.01.16-0+deb11u1_all.deb ...
Unpacking usb.ids (2023.01.16-0+deb11u1) over (2022.05.20-0+deb11u1) ...
Setting up libssh-gcrypt-4:armhf (0.9.7-0+deb11u1) ...
Setting up rp-prefapps (0.47) ...
Setting up chromium-codecs-ffmpeg-extra (113.0.5672.95-rpt1) ...
Setting up libxpm4:armhf (1:3.5.12-1.1~deb11u1) ...
Setting up libfontembed1:armhf (1.28.7-1+deb11u2) ...
Setting up traceroute (1:2.1.0-2+deb11u1) ...
update-alternatives: using /usr/bin/traceroute.db to provide /usr/bin/traceroute (traceroute) in auto mode
update-alternatives: using /usr/bin/traceroute6.db to provide /usr/bin/traceroute6 (traceroute6) in auto mode
update-alternatives: using /usr/bin/lft.db to provide /usr/bin/lft (lft) in auto mode
update-alternatives: using /usr/bin/traceproto.db to provide /usr/bin/traceproto (traceproto) in auto mode
update-alternatives: using /usr/sbin/tcptraceroute.db to provide /usr/sbin/tcptraceroute (tcptraceroute) in auto mode
Setting up lxplug-ptbatt (0.21) ...
Setting up isc-dhcp-client (4.4.1-2.3+deb11u2) ...
Setting up systemd (247.3-7+rpi1+deb11u2) ...
Setting up libatspi2.0-0:armhf (2.38.0-4+deb11u1) ...
Setting up raspberrypi-sys-mods (20230510~bullseye) ...
Setting up lxplug-menu (0.4) ...
Setting up libavutil56:armhf (7:4.3.6-0+deb11u1+rpt1) ...
Setting up tzdata (2021a-1+deb11u10) ...
Current default time zone: 'Europe/Berlin'
Local time is now:      Tue Jun 20 08:49:01 CEST 2023.
Universal Time is now:  Tue Jun 20 06:49:01 UTC 2023.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
Setting up libwidevinecdm0 (4.10.2252.0+3) ...
Setting up lxplug-bluetooth (0.33) ...
Setting up libavahi-common-data:armhf (0.8-5+deb11u2) ...
Setting up libncurses6:armhf (6.2+20201114-2+deb11u1) ...
Setting up systemd-timesyncd (247.3-7+rpi1+deb11u2) ...
Setting up udev (247.3-7+rpi1+deb11u2) ...
Setting up usb.ids (2023.01.16-0+deb11u1) ...
Setting up libwebp6:armhf (0.6.1-2.1+deb11u1) ...
Setting up libpostproc55:armhf (7:4.3.6-0+deb11u1+rpt1) ...
Setting up libudev-dev:armhf (247.3-7+rpi1+deb11u2) ...
Setting up lxplug-network (0.33) ...
Setting up chromium-browser (113.0.5672.95-rpt1) ...
Setting up chromium-browser-l10n (113.0.5672.95-rpt1) ...
Setting up rpi-eeprom (16.1-1) ...
Setting up rpi-imager (1.7.5+rpt1) ...
Setting up lxplug-cputemp (0.11) ...
Setting up libswscale5:armhf (7:4.3.6-0+deb11u1+rpt1) ...
Setting up isc-dhcp-common (4.4.1-2.3+deb11u2) ...
Setting up libwebpmux3:armhf (0.6.1-2.1+deb11u1) ...
Setting up libtinfo5:armhf (6.2+20201114-2+deb11u1) ...
Setting up libcupsfilters1:armhf (1.28.7-1+deb11u2) ...
Setting up lxplug-updater (0.14) ...
Setting up libsynctex2:armhf (2020.20200327.54578-7+deb11u1) ...
Setting up ncurses-term (6.2+20201114-2+deb11u1) ...
Setting up systemd-sysv (247.3-7+rpi1+deb11u2) ...
Setting up libwebpdemux2:armhf (0.6.1-2.1+deb11u1) ...
Setting up libavahi-common3:armhf (0.8-5+deb11u2) ...
Setting up libswresample3:armhf (7:4.3.6-0+deb11u1+rpt1) ...
Setting up cups-filters-core-drivers (1.28.7-1+deb11u2) ...
Setting up libavresample4:armhf (7:4.3.6-0+deb11u1+rpt1) ...
Setting up libavahi-common-dev:armhf (0.8-5+deb11u2) ...
Setting up libpam-systemd:armhf (247.3-7+rpi1+deb11u2) ...
Setting up libavcodec58:armhf (7:4.3.6-0+deb11u1+rpt1) ...
Setting up libavahi-glib1:armhf (0.8-5+deb11u2) ...
Setting up cups-filters (1.28.7-1+deb11u2) ...
Setting up libavahi-core7:armhf (0.8-5+deb11u2) ...
Setting up libavahi-client3:armhf (0.8-5+deb11u2) ...
Setting up cups-browsed (1.28.7-1+deb11u2) ...
Setting up libavformat58:armhf (7:4.3.6-0+deb11u1+rpt1) ...
Setting up libavahi-client-dev:armhf (0.8-5+deb11u2) ...
Setting up libavahi-compat-libdnssd1:armhf (0.8-5+deb11u2) ...
Setting up avahi-daemon (0.8-5+deb11u2) ...
Setting up libavfilter7:armhf (7:4.3.6-0+deb11u1+rpt1) ...
Setting up libavahi-compat-libdnssd-dev:armhf (0.8-5+deb11u2) ...
Setting up libavdevice58:armhf (7:4.3.6-0+deb11u1+rpt1) ...
Setting up ffmpeg (7:4.3.6-0+deb11u1+rpt1) ...
Processing triggers for mailcap (3.69) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for initramfs-tools (0.140) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for cups (2.3.3op2-3+deb11u2) ...
Updating PPD files for cups-filters ...
Processing triggers for gnome-menus (3.36.0-1) ...
Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
Processing triggers for man-db (2.9.4-2) ...
Processing triggers for dbus (1.12.24-0+deb11u1) ...
Processing triggers for install-info (6.7.0.dfsg.2-6) ...
pi@iobroker2:~ $ sudo reboot
client_loop: send disconnect: Broken pipe
micha@iMac-Micha ~ % ssh pi@192.168.200.42
pi@192.168.200.42's password:
Linux iobroker2 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Jun 20 08:59:46 2023
pi@iobroker2:~ $ iob status
Objects type: jsonl
States  type: jsonl
</code></pre>
<p dir="auto">Habe andere USB-Ports versucht --&gt; kein Erfolg.<br />
Wo kann ich denn noch suchen?</p>
]]></description><link>https://forum.iobroker.net/topic/66286/sonoff-zigbee-3-0-wird-nicht-mehr-erkannt-upgrade-gelöst</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 14:17:04 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/66286.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Jun 2023 07:25:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Wed, 21 Jun 2023 08:48:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Master:</p>
<pre><code>admin@macmini-iobroker:~$ dpkg --print-architecture
amd64
</code></pre>
<p dir="auto">Slave1:</p>
<pre><code>pi@iobroker:~ $ dpkg --print-architecture
arm64
</code></pre>
<p dir="auto">Slave2:</p>
<pre><code>pi@iobroker2:~ $ dpkg --print-architecture
armhf
</code></pre>
<p dir="auto">also der, der die USB Probleme hatte. Das heisst den müsste ich neu aufsetzen.</p>
<p dir="auto">Hier ist mir aber immer noch nicht ganz klar, wie der Restore des Salzes dann über BackitUp funktioniert.<br />
Für diese Client gibt es eine BackitUp-Instanz, die ZigBee sichert.</p>
<p dir="auto">Wenn ich jetzt nur diesen Slave neu installieren möchte, dann weiss ich nicht, wie das mit dem Restore funktioniert (da die anderen ja nicht restored werden sollen). Gehört ja aber nicht hierher....</p>
]]></description><link>https://forum.iobroker.net/post/1006184</link><guid isPermaLink="true">https://forum.iobroker.net/post/1006184</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Wed, 21 Jun 2023 08:48:58 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Wed, 21 Jun 2023 08:36:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a></p>
<p dir="auto">Ein Upgrade auf Bookworm kannst du so oder so machen.<br />
Ich würde aber halt bei der Gelegenheit das große Rad drehen und auf ein reines 64bit-System wechseln.</p>
<p dir="auto">Wie schaut es denn nun konkret bei dir aus?</p>
]]></description><link>https://forum.iobroker.net/post/1006181</link><guid isPermaLink="true">https://forum.iobroker.net/post/1006181</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Jun 2023 08:36:02 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Wed, 21 Jun 2023 08:34:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Das heisst, wenn</p>
<pre><code>dpkg --print-architecture
</code></pre>
<p dir="auto">und</p>
<pre><code>uname -m
</code></pre>
<p dir="auto">auf 64Bit hinweisen, dann kann ich mir einigermaßen sicher sein, dass ich 64Bit am Start habe und damit auch ein Update auf 'bookworm' vornehmen kann (auch wenn ich weiss, dass eine Neuinstallation besser ist)?</p>
]]></description><link>https://forum.iobroker.net/post/1006178</link><guid isPermaLink="true">https://forum.iobroker.net/post/1006178</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Wed, 21 Jun 2023 08:34:03 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Wed, 21 Jun 2023 08:26:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a></p>
<p dir="auto">Das zeigt dir die Architektur für das 'userland'. Bei 64bit müsste da was von arm64 stehen, bei 32bit steht da was von 'armhf'.</p>
]]></description><link>https://forum.iobroker.net/post/1006177</link><guid isPermaLink="true">https://forum.iobroker.net/post/1006177</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Jun 2023 08:26:50 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Wed, 21 Jun 2023 07:38:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Danke für Deine Antwort.</p>
<p dir="auto">Das heisst mit</p>
</code></pre>
<p dir="auto">bekomme ich "korrekt angezeigt, ob ich auf 32Bit oder 64Bit unterwegs bin?</p>
]]></description><link>https://forum.iobroker.net/post/1006165</link><guid isPermaLink="true">https://forum.iobroker.net/post/1006165</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Wed, 21 Jun 2023 07:38:26 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Wed, 21 Jun 2023 07:28:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a> sagte in <a href="/post/1006134">Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst]</a>:</p>
<blockquote>
<p dir="auto">Damit sollten die alle schon auf 64Bit OS sein, oder?</p>
</blockquote>
<p dir="auto">Nicht unbedingt. Raspberrypi OS haben zuletzt den Blödsinn angefangen den Kernel in 64bit auszurollen, das sog. userland aber bei 32bit zu belassen.<br />
Mit uname -m prüfst du nur den Kernel.</p>
<p dir="auto">Zu<br />
1.) Siehe zuvor, du wirst einen Hybriden haben<br />
Eine kommende Version von iob diag hat den Check drin.</p>
<p dir="auto">2.) Bei einem reinen 64bit-System ja. Bei einem Hybrid würde ich es neuaufsetzen.</p>
<p dir="auto">[Edit:]<br />
Das userland kannst du dir so anschauen:</p>
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1006157</link><guid isPermaLink="true">https://forum.iobroker.net/post/1006157</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Jun 2023 07:28:30 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Wed, 21 Jun 2023 06:13:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">muss nochmals nachfragen...<br />
Habe meine Maschinen gestern gecheckt:</p>
<pre><code>admin@macmini-iobroker:~$ uname -m
x86_64
</code></pre>
<pre><code>pi@iobroker2:~ $ uname -m
aarch64
</code></pre>
<pre><code>pi@iobroker:~ $ uname -m
aarch64
</code></pre>
<p dir="auto">Dazu zwei Fragen:</p>
<ol>
<li>
<p dir="auto">Kannst Du Dir erklären warum dann der Standardweg aus <a href="https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev?_=1687246153280">https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev?_=1687246153280</a> nicht funktioniert hat, sondern nur der letzte Schritt (32 Bit System)?</p>
</li>
<li>
<p dir="auto">Wenn 64 Bit installiert ist, müsste ein Update auf Bookworm möglich sein, oder (also ohne Neuinstallation)?</p>
</li>
</ol>
]]></description><link>https://forum.iobroker.net/post/1006134</link><guid isPermaLink="true">https://forum.iobroker.net/post/1006134</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Wed, 21 Jun 2023 06:13:51 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 08:28:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a> sagte in <a href="/post/1005687">Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade)</a>:</p>
<blockquote>
<p dir="auto">Im Ernst ich muss neu installieren???</p>
</blockquote>
<p dir="auto">Ja, ein Wechsel der Prozessor-Architektur ist nur per Neuinstallation möglich.</p>
<blockquote>
<p dir="auto">Ist ja in dem Fall nicht einfach OS drauf und Restore, sondern Influx und Grafana neu machen.</p>
</blockquote>
<p dir="auto">Öh, doch, ist im Wesentlichen einfach OS drauf, Influx installieren, Grafana installieren (gibt ja Repos dafür), ioBroker installieren, Backup einspielen, fertig.</p>
]]></description><link>https://forum.iobroker.net/post/1005688</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005688</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 20 Jun 2023 08:28:49 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 08:25:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Hab jetzt immerhin mal</p>
<pre><code>pi@iobroker2:~ $ who -r
         run-level 3  2023-06-20 10:19
</code></pre>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/1005683">Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade)</a>:</p>
<blockquote>
<p dir="auto">Das musst du eh komplett neuinstallieren</p>
</blockquote>
<p dir="auto">Das macht mir jetzt schon Kopfzerbrechen, habe einen MACmini mit Debian als Master und zwei PIs als Slave.<br />
Die neu zu installieren (mit Influx und Grafana), da schlottern mir jetzt schon die Knie.<br />
<p dir="auto">Machst Du oder jemand anders ein Tutorial dazu?</p>
]]></description><link>https://forum.iobroker.net/post/1005687</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005687</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Tue, 20 Jun 2023 08:25:04 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 08:18:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a> sagte in <a href="/post/1005682">Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade)</a>:</p>
<blockquote>
<p dir="auto">Einfachster und sauberster Weg dahin?</p>
</blockquote>
<p dir="auto">Ich würde an deiner Stelle in den nächsten Wochen/Monaten (sobald es released worden ist) auf ein RaspberryOS 'Bookworm' 64bit wechseln. Das musst du eh komplett neuinstallieren, dann kannst du es gleich in der 'Lite'-Version ohne Desktop installieren.<br />
Da hat sich dann auch das Problem mit udev erledigt, die Version dort funktioniert ohne Klimmzüge.</p>
]]></description><link>https://forum.iobroker.net/post/1005683</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005683</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 20 Jun 2023 08:18:58 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 08:12:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">ok, danke, will do so.</p>
<p dir="auto">und jetzt noch dazu:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/1005662">Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade)</a>:</p>
<blockquote>
<p dir="auto">Und stell die Kiste auf Serverbetrieb (ohne Desktop) um. Ein Chromium hat da z. B. nix zu suchen.</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1005682</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005682</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Tue, 20 Jun 2023 08:12:58 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 08:10:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a> sagte in <a href="/post/1005679">Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade)</a>:</p>
<blockquote>
<p dir="auto">Wie erfahre ich jetzt wann das Paket gefixt ist und ich den</p>
</blockquote>
<p dir="auto">Mal regelmäßig per</p>
<pre><code>sudo apt update
apt policy udev
</code></pre>
<p dir="auto">prüfen ob eine passende Version vom RaspberryOS hochgeladen wurde.</p>
<p dir="auto">Offengesagt wundert es mich schon, wie lange das Paket schon neben der Spur hängt.</p>
]]></description><link>https://forum.iobroker.net/post/1005680</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005680</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 20 Jun 2023 08:10:01 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 08:07:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Vielen Dank für Deine Hilfe! Jetzt hat es geklappt:</p>
<pre><code>pi@iobroker2:~ $ apt policy udev
udev:
  Installed: 247.3-7+deb11u3
  Candidate: 247.3-7+rpi1+deb11u2
  Version table:
     247.3-7+rpi1+deb11u2 500
        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
 *** 247.3-7+deb11u3 500
        500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
        100 /var/lib/dpkg/status
pi@iobroker2:~ $ ls -l /dev/serial/by-id/
total 0
lrwxrwxrwx 1 root root 13 Jun 20 10:03 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0 -&gt; ../../ttyUSB0
pi@iobroker2:~ $
</code></pre>
<pre><code>sudo apt-mark hold udev
</code></pre>
<p dir="auto">wieder rausnehmen kann?</p>
]]></description><link>https://forum.iobroker.net/post/1005679</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005679</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Tue, 20 Jun 2023 08:07:05 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 08:00:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a></p>
<p dir="auto">Du musst das auch vollständig lesen.<br />
Genau deine Situation mit einem 32bit-RaspberryOS ist im letzten Absatz erläutert.</p>
]]></description><link>https://forum.iobroker.net/post/1005675</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005675</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 20 Jun 2023 08:00:02 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 07:54:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/1005671">Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade)</a>:</p>
<blockquote>
<p dir="auto">sudo apt-key adv --keyserver <a href="http://keyserver.ubuntu.com" rel="nofollow ugc">keyserver.ubuntu.com</a> --recv-keys 0E98404D386FA1D9</p>
</blockquote>
<p dir="auto">Das hat geklappt, danke.<br />
Trotzdem bekomme ich wohl nicht das hin was es sein sollte:</p>
udev:
  Installed: 247.3-7+rpi1+deb11u2
  Version table:
 *** 247.3-7+rpi1+deb11u2 500
     247.3-7+deb11u3 500
pi@iobroker2:~ $ sudo apt -t bullseye-proposed-updates install udev
udev is already the newest version (247.3-7+rpi1+deb11u2).
  libfuse2 raspinfo
0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
udev:
  Version table:
     247.3-7+deb11u3 500
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1005674</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005674</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Tue, 20 Jun 2023 07:54:22 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 07:42:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a> sagte in <a href="/post/1005670">Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade)</a>:<br />
Dir fehlt:</p>
<blockquote>
<p dir="auto">NO_PUBKEY 0E98404D386FA1D9</p>
</blockquote>
<p dir="auto">Also</p>
<pre><code>sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
sudo apt update
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1005671</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005671</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 20 Jun 2023 07:42:48 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 07:40:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/1005667">Sonor Zigbee 3.0 wird nicht mehr erkannt (nach apt upgrade)</a>:</p>
<blockquote>
<p dir="auto">Musst nur die key-ID anpassen.</p>
</blockquote>
<p dir="auto">auf welche? Sorry bin zu doof <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":disappointed:" alt="😞" /></p>
<pre><code>pi@iobroker2:/etc/apt/sources.list.d $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
Executing: /tmp/apt-key-gpghome.EEfmRwEucb/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
gpg: key DC30D7C23CBBABEE: public key "Debian Archive Automatic Signing Key (10/buster) &lt;ftpmaster@debian.org&gt;" imported
gpg: Total number processed: 1
gpg:               imported: 1
pi@iobroker2:/etc/apt/sources.list.d $ sudo apt update
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
Get:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
Err:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
pi@iobroker2:/etc/apt/sources.list.d $ sudo apt -t bullseye-proposed-updates install udev
E: The value 'bullseye-proposed-updates' is invalid for APT::Default-Release as such a release is not available in the sources
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1005670</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005670</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Tue, 20 Jun 2023 07:40:41 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 07:37:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a></p>
<p dir="auto">Steht alles im verlinkten Post drin.<br />
]]></description><link>https://forum.iobroker.net/post/1005667</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005667</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 20 Jun 2023 07:37:03 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 07:35:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Hi, danke für die Antwort.<br />
Leider bekomme ich noch einen Fehler:</p>
<pre><code>pi@iobroker2:/etc/apt/sources.list.d $ sudo nano bullseye-proposed-updates.list
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Get:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Err:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1005666</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005666</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Tue, 20 Jun 2023 07:35:14 GMT</pubDate></item><item><title><![CDATA[Reply to Sonoff Zigbee 3.0 wird nicht mehr erkannt (upgrade)[gelöst] on Tue, 20 Jun 2023 07:32:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a></p>
<p dir="auto">Dürfte das sein:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev?_=1687246153280">https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev?_=1687246153280</a></p>
<p dir="auto"><code>udev armhf 247.3-7+rpi1+deb11u2</code> und dessen 'Drumherum' ist kaputt.</p>
]]></description><link>https://forum.iobroker.net/post/1005662</link><guid isPermaLink="true">https://forum.iobroker.net/post/1005662</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 20 Jun 2023 07:32:49 GMT</pubDate></item></channel></rss>
