  3. Einsteigerfragen
  4. nach js update Iobroker tot ;)
    5.5k
27 Beiträge 4 Kommentatoren 2.6k Aufrufe 3 Beobachtet
  • W wurschtbrot
    hier einmal neu
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     20:42:02 up  2:06,  1 user,  load average: 3.79, 3.68, 3.36
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=52.1'C
    volt=0.9060V
    *** Time and Time Zones ***
                   Local time: Sun 2023-06-11 20:42:02 BST
               Universal time: Sun 2023-06-11 19:42:02 UTC
                     RTC time: n/a
                    Time zone: Europe/London (BST, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            1.9G        1.2G        167M        0.0K        534M        754M
    Swap:            99M         14M         85M
    Total:          2.0G        1.2G        253M
             1872 M total memory
             1171 M used memory
              172 M active memory
             1409 M inactive memory
              167 M free memory
               91 M buffer memory
              442 M swap cache
               99 M total swap
               14 M used swap
               85 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G  7.3G   49G  13% /
    devtmpfs       devtmpfs  776M     0  776M   0% /dev
    tmpfs          tmpfs     937M     0  937M   0% /dev/shm
    tmpfs          tmpfs     375M  812K  374M   1% /run
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
    [Sun Jun 11 18:35:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:34:2C:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7177a16e-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Jun 11 18:35:41 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Jun 11 18:35:41 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Jun 11 18:35:43 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.2G    /var/
    795M    /var/log
    793M    /var/log/journal/d283fbb865d54e58ad2494ba594a26a4
    167M    /var/cache
    Archived and active journals take up 792.2M in the file system.
    /opt/iobroker/backups:
    26M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    591M    /opt/iobroker/iobroker-data/
    267M    /opt/iobroker/iobroker-data/files
    187M    /opt/iobroker/iobroker-data/sonosCache
    96M     /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/objects.json.migrated
    8.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.0
    /usr/bin/node           v16.20.0
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    nodejs:
      Installed: 16.20.0-deb-1nodesource1
      Candidate: 16.20.0-deb-1nodesource1
      Version table:
     *** 16.20.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.adguard.1                : adguard               : iobr22                                   -  enabled
      system.adapter.admin.0                  : admin                 : iobr22                                   - disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobr22                                   -  enabled
      system.adapter.backitup.0               : backitup              : iobr22                                   - disabled
    + system.adapter.bosch-ebike.0            : bosch-ebike           : iobr22                                   -  enabled
    + system.adapter.bring.0                  : bring                 : iobr22                                   -  enabled
    + system.adapter.bshb.0                   : bshb                  : iobr22                                   -  enabled
    + system.adapter.chromecast.0             : chromecast            : iobr22                                   -  enabled
    + system.adapter.discovery.0              : discovery             : iobr22                                   -  enabled
      system.adapter.dwd.0                    : dwd                   : iobr22                                   -  enabled
    + system.adapter.echarts.0                : echarts               : iobr22                                   -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobr22                                   - disabled
    + system.adapter.followthesun.0           : followthesun          : iobr22                                   -  enabled
    + system.adapter.heizoel.0                : heizoel               : iobr22                                   -  enabled
    + system.adapter.history.0                : history               : iobr22                                   -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobr22                                   -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : iobr22                                   -  enabled
      system.adapter.ical.0                   : ical                  : iobr22                                   -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobr22                                   -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobr22                                   -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobr22                                   -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobr22                                   -  enabled
    + system.adapter.javascript.0             : javascript            : iobr22                                   -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : iobr22                                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobr22                                   -  enabled, port: 1883, bind: 192.168.178.141
    + system.adapter.net-tools.0              : net-tools             : iobr22                                   -  enabled
      system.adapter.nina.0                   : nina                  : iobr22                                   -  enabled
    + system.adapter.node-red.0               : node-red              : iobr22                                   -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.nut.0                    : nut                   : iobr22                                   - disabled
      system.adapter.octoprint.0              : octoprint             : iobr22                                   -  enabled
      system.adapter.philips-tv.0             : philips-tv            : iobr22                                   -  enabled
    + system.adapter.ping.0                   : ping                  : iobr22                                   -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobr22                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : iobr22                                   -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.snmp.0                   : snmp                  : iobr22                                   - disabled
    + system.adapter.sonos.0                  : sonos                 : iobr22                                   -  enabled
      system.adapter.systeminfo.0             : systeminfo            : iobr22                                   -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobr22                                   -  enabled
    + system.adapter.tr-064.1                 : tr-064                : iobr22                                   -  enabled
    + system.adapter.tr-064.2                 : tr-064                : iobr22                                   -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobr22                                   -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobr22                                   -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobr22                                   -  enabled
      system.adapter.vis-history.0            : vis-history           : iobr22                                   -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobr22                                   -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobr22                                   -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobr22                                   -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobr22                                   -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobr22                                   -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobr22                                   -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobr22                                   -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobr22                                   -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobr22                                   -  enabled
      system.adapter.vis.0                    : vis                   : iobr22                                   -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobr22                                   -  enabled
      system.adapter.web.0                    : web                   : iobr22                                   - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobr22                                   -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "adguard"      : 0.0.8    , installed 0.0.8
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "bshb"         : 0.2.4    , installed 0.2.4
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
    Adapter    "followthesun" : 0.4.1    , installed 0.4.1
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "snmp"         : 2.4.7    , installed 2.4.7
    Adapter    "sonos"        : 2.2.3    , installed 2.2.3
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Objects and States
    Objects:        19018
    States:         15908
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 166
    *** Listening Ports ***
    tcp        0      0 192.168.178.141:1883    0.0.0.0:*               LISTEN      1001       40343      9055/io.mqtt.0
    tcp        0      0 192.168.178.141:1884    0.0.0.0:*               LISTEN      1001       40344      9055/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37347      8389/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       38196      8389/iobroker.js-co
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       71371      12782/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9770       539/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       37434      8486/node-red
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       47219      10182/io.sonos.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          9772       539/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13766      700/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       40158      8893/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9655       391/avahi-daemon: r
    udp        0      0 0.0.0.0:50429           0.0.0.0:*                           108        9657       391/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       44427      9781/io.shelly.0
    udp6       0      0 :::5353                 :::*                                108        9656       391/avahi-daemon: r
    udp6       0      0 :::40791                :::*                                108        9658       391/avahi-daemon: r
    2023-06-11 20:43:50.445  - warn: shelly.0 (9781) [authEnabled] 192.168.178.156 (shelly1 / shelly1-58BF25D8700A / SHSW-1#58BF25D8700A#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:50.682  - warn: shelly.0 (9781) [authEnabled] 192.168.178.161 (shelly1 / shelly1-E8DB84AB7C26 / SHSW-1#E8DB84AB7C26#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.018  - warn: shelly.0 (9781) [authEnabled] 192.168.178.172 (shelly1pm / shelly1pm-34945472B5A9 / SHSW-PM#34945472B5A9#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.316  - warn: shelly.0 (9781) [authEnabled] 192.168.178.151 (shellyswitch25 / shellyswitch25-3C6105E553A4 / SHSW-25#3C6105E553A4#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.530  - warn: shelly.0 (9781) [authEnabled] 192.168.178.166 (shellyswitch25 / shellyswitch25-98CDAC2D0858 / SHSW-25#98CDAC2D0858#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.572  - warn: shelly.0 (9781) [authEnabled] 192.168.178.150 (shellyswitch25 / shellyswitch25-E8DB84A1B284 / SHSW-25#E8DB84A1B284#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.580  - warn: shelly.0 (9781) [authEnabled] 192.168.178.154 (shellyswitch25 / shellyswitch25-E8DB84AAB39C / SHSW-25#E8DB84AAB39C#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.584  - warn: shelly.0 (9781) [authEnabled] 192.168.178.152 (shellyswitch25 / shellyswitch25-84CCA89FF0A5 / SHSW-25#84CCA89FF0A5#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.591  - warn: shelly.0 (9781) [authEnabled] 192.168.178.155 (shellyswitch25 / shellyswitch25-C8C9A375029E / SHSW-25#C8C9A375029E#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.646  - warn: shelly.0 (9781) [authEnabled] 192.168.178.158 (shellyem3 / shellyem3-E8DB84D72806 / SHEM-3#E8DB84D72806#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.649  - warn: shelly.0 (9781) [authEnabled] 192.168.178.173 (shellyem3 / shellyem3-485519DC0AEF / SHEM-3#485519DC0AEF#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:51.766  - warn: shelly.0 (9781) [authEnabled] 192.168.178.153 (shellyswitch25 / shellyswitch25-D8BFC01A558C / SHSW-25#D8BFC01A558C#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:52.354  - info: octoprint.0 (13661) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.octoprint, node: v16.20.0, js-controller: 4.0.24
    2023-06-11 20:43:52.860  - warn: adguard.1 (10779) No connection to the server could be established. (Error: connect ECONNREFUSED 192.168.178.141:80)
    2023-06-11 20:43:53.423  - info: host.iobr22 iobroker npm-install: NPM version: 8.19.4
    2023-06-11 20:43:53.425  - info: host.iobr22 iobroker npm-install: Installing iobroker.philips-tv@0.5.3... (System call)
    2023-06-11 20:43:54.614  - info: octoprint.0 (13661) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
    2023-06-11 20:43:55.273  - warn: shelly.0 (9781) [authEnabled] 192.168.178.170 (shellyplug-s / shellyplug-s-4022D882E3C5 / SHPLG-S#4022D882E3C5#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:55.288  - warn: shelly.0 (9781) [authEnabled] 192.168.178.169 (shellyplug-s / shellyplug-s-4022D881CACB / SHPLG-S#4022D881CACB#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:55.699  - warn: shelly.0 (9781) [authEnabled] 192.168.178.157 (shelly1pm / shelly1pm-8CAAB574CB6C / SHSW-PM#8CAAB574CB6C#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:55.710  - warn: shelly.0 (9781) [authEnabled] 192.168.178.164 (shelly1 / shelly1-E8DB84AB993A / SHSW-1#E8DB84AB993A#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:55.719  - warn: shelly.0 (9781) [authEnabled] 192.168.178.165 (shelly1 / shelly1-E89F6D860650 / SHSW-1#E89F6D860650#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:55.745  - warn: shelly.0 (9781) [authEnabled] 192.168.178.156 (shelly1 / shelly1-58BF25D8700A / SHSW-1#58BF25D8700A#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:56.098  - warn: shelly.0 (9781) [authEnabled] 192.168.178.161 (shelly1 / shelly1-E8DB84AB7C26 / SHSW-1#E8DB84AB7C26#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-11 20:43:56.232  - warn: shelly.0 (9781) [authEnabled] 192.168.178.172 (shelly1pm / shelly1pm-34945472B5A9 / SHSW-PM#34945472B5A9#1): This device is not protected via restricted login (see adapter documentation for details)
    iob diag has finished.
    Press any key for a summary
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.92-v7l+
    Installation:           Native
    Timezone:               Europe/London (BST, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     166
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v16.20.0
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            1.9G        1.3G        111M        0.0K        484M        668M
    Swap:            99M         54M         45M
    Total:          2.0G        1.3G        156M
    Active iob-Instances:   31
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                19018
    States:                 15908
    Size of iob-Database:
    4.0K    /opt/iobroker/iobroker-data/objects.json.old
    0       /opt/iobroker/iobroker-data/objects.json.broken
    6.5M    /opt/iobroker/iobroker-data/states.jsonl
    2.4M    /opt/iobroker/iobroker-data/states.json.migrated
    2.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    4.0K    /opt/iobroker/iobroker-data/states.json.old
    0       /opt/iobroker/iobroker-data/states.json.broken
    jetzt aber oder
    @wurschtbrot wie schafft man es die code-tags mitten aus dem damit vorbereiteten Code herauszuoperieren?
    hab sie wieder re-implantiert!
    • W wurschtbrot
      @glasfaser
      nein ging gar nichts jezt mit dem befehlt iob start admin
      läuft es wieder
      danke euch habt ihr ne Anleitung um die Updates vom Os zu machen
      @wurschtbrot sagte in nach js update Iobroker tot ;):
      Setz die Zeitzone zunächst mal richtig. Das ist wichtig und keine Kosmetik.
      Geht in
      sudo raspi-config
      Anschließend
      iob stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
        GlasfaserG Offline
        GlasfaserG Offline
        @homoran sagte in nach js update Iobroker tot ;):
        Sorry ... konnte ich mir nicht verkneifen ..
        das sind die Wurstfinger von @wurschtbrot 😂
        W 1 Antwort Letzte Antwort
        • W wurschtbrot
          @glasfaser
          läuft es wieder
          @wurschtbrot
          Und dann mach den Sprung auf nodejs@18 noch. nodejs@16 ist in der Auslaufphase. EOL im September 23.
          • GlasfaserG Glasfaser
            W Offline
            W Offline
            wurschtbrot
            @glasfaser ;=)
            @Thomas-Braun gibts da eine Anleitung will nicht wieder was falsches aus dem Internet ziehen
            1000 Dank euch....
            aktuell laufen noch die Updates durch....
            • W wurschtbrot
              @glasfaser ;=)
              1000 Dank euch....
              steht in seiner Signatur
              • W wurschtbrot
                @glasfaser ;=)
                1000 Dank euch....
                Zun nodejs updates? Steht in meiner Signatur drin.
                  W Offline
                  W Offline
                  wurschtbrot
                  ich glaube es ist heute schon zu spät,
                  aber bei mir kommt nach diesem Befehl nichts
                  pi@iobr22:~ $ cd /opt/iobroker
                  pi@iobr22:/opt/iobroker $ npm ls | grep -E 'github|ERR'
                  • W wurschtbrot
                    Das ist doch prima.
                    Im Idealfall wird nichts zurückgeliefert
                    Also keine Fehler und auch nix aus dem GitHub geangelt.
                    Weiter machen. :-)
                      Das ist doch prima.
                      Weiter machen. :-)
                      W Offline
                      W Offline
                      wurschtbrot
                      schrieb am zuletzt editiert von wurschtbrot
                      hat sich erledigt manchmal hilft denken auch.....
                      • W wurschtbrot
                        W Offline
                        W Offline
                        wurschtbrot
                        nach den ganzen update Zeugs sollte alles wieder gut sein oder.....
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Architecture    : aarch64
                        Docker          : false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=raspbian
                        ID_LIKE=debian
                         22:47:10 up 22 min,  1 user,  load average: 4.54, 2.64, 1.27
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        temp=51.1'C
                        volt=0.9060V
                                       Local time: Sun 2023-06-11 22:47:10 CEST
                                   Universal time: Sun 2023-06-11 20:47:10 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            1.8G        1.0G         70M        0.0K        752M        754M
                        Swap:            99M          0B         99M
                        Total:          1.9G        1.0G        170M
                                 1849 M total memory
                                 1026 M used memory
                                 1016 M active memory
                                  450 M inactive memory
                                   70 M free memory
                                  157 M buffer memory
                                  595 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4       59G  7.5G   49G  14% /
                        devtmpfs       devtmpfs  667M     0  667M   0% /dev
                        tmpfs          tmpfs     925M     0  925M   0% /dev/shm
                        tmpfs          tmpfs     370M  804K  370M   1% /run
                        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                        tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
                        [Sun Jun 11 22:25:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:34:2C:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7177a16e-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Sun Jun 11 22:25:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Sun Jun 11 22:25:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Sun Jun 11 22:25:07 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                        /var:
                        1.2G    /var/
                        812M    /var/log
                        809M    /var/log/journal/d283fbb865d54e58ad2494ba594a26a4
                        169M    /var/cache
                        Archived and active journals take up 808.2M in the file system.
                        589M    /opt/iobroker/iobroker-data/
                        14M     /opt/iobroker/iobroker-data/objects.jsonl
                        /usr/bin/nodejs         v18.16.0
                        /usr/bin/node           v18.16.0
                        /usr/bin/npm            9.5.1
                        /usr/bin/npx            9.5.1
                        nodejs:
                          Installed: 18.16.0-deb-1nodesource1
                          Candidate: 18.16.0-deb-1nodesource1
                          Version table:
                         *** 18.16.0-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.3.5
                        javascript:     6.1.4
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobr22                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.nina.0                   : nina                  : iobr22                                   -  enabled
                        + system.adapter.octoprint.0              : octoprint             : iobr22                                   -  enabled
                        + system.adapter.philips-tv.0             : philips-tv            : iobr22                                   -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobr22                                   -  enabled
                        + system.adapter.web.0                    : web                   : iobr22                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + instance is alive
                        Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                        Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                        Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                        Objects and States
                        Objects:        19024
                        States:         15935
                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       24185      2414/iobroker.js-co
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       26674      2414/iobroker.js-co
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1777       524/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       30801      3098/io.jarvis.0
                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26174      2510/node-red
                        tcp        0      0 192.168.178.141:1884    0.0.0.0:*               LISTEN      1001       24340      2595/io.mqtt.0
                        tcp        0      0 192.168.178.141:1883    0.0.0.0:*               LISTEN      1001       24339      2595/io.mqtt.0
                        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       27745      2721/io.sonos.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          1779       524/sshd: /usr/sbin
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30590      3328/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24240      2435/io.admin.0
                        udp        0      0 0.0.0.0:45194           0.0.0.0:*                           1001       33675      -
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       26866      2548/io.chromecast.
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13065      379/avahi-daemon: r
                        udp        0      0 0.0.0.0:48514           0.0.0.0:*                           108        13067      379/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24486      2701/io.shelly.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3864       662/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        13066      379/avahi-daemon: r
                        udp6       0      0 :::45079                :::*                                108        13068      379/avahi-daemon: r
                        2023-06-11 22:49:01.573  - warn: shelly.0 (2701) [authEnabled] 192.168.178.166 (shellyswitch25 / shellyswitch25-98CDAC2D0858 / SHSW-25#98CDAC2D0858#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:01.756  - warn: shelly.0 (2701) [authEnabled] 192.168.178.154 (shellyswitch25 / shellyswitch25-E8DB84AAB39C / SHSW-25#E8DB84AAB39C#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:01.933  - warn: shelly.0 (2701) [authEnabled] 192.168.178.161 (shelly1 / shelly1-E8DB84AB7C26 / SHSW-1#E8DB84AB7C26#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:03.378  - info: host.iobr22 instance system.adapter.systeminfo.0 started with pid 3781
                        2023-06-11 22:49:03.474  - warn: shelly.0 (2701) [authEnabled] 192.168.178.150 (shellyswitch25 / shellyswitch25-E8DB84A1B284 / SHSW-25#E8DB84A1B284#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:03.524  - warn: shelly.0 (2701) [authEnabled] 192.168.178.169 (shellyplug-s / shellyplug-s-4022D881CACB / SHPLG-S#4022D881CACB#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:04.150  - warn: shelly.0 (2701) [authEnabled] 192.168.178.170 (shellyplug-s / shellyplug-s-4022D882E3C5 / SHPLG-S#4022D882E3C5#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:04.331  - warn: shelly.0 (2701) [authEnabled] 192.168.178.172 (shelly1pm / shelly1pm-34945472B5A9 / SHSW-PM#34945472B5A9#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:04.679  - warn: shelly.0 (2701) [authEnabled] 192.168.178.151 (shellyswitch25 / shellyswitch25-3C6105E553A4 / SHSW-25#3C6105E553A4#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:04.811  - warn: shelly.0 (2701) [authEnabled] 192.168.178.164 (shelly1 / shelly1-E8DB84AB993A / SHSW-1#E8DB84AB993A#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:05.047  - warn: shelly.0 (2701) [authEnabled] 192.168.178.165 (shelly1 / shelly1-E89F6D860650 / SHSW-1#E89F6D860650#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:05.271  - warn: shelly.0 (2701) [authEnabled] 192.168.178.152 (shellyswitch25 / shellyswitch25-84CCA89FF0A5 / SHSW-25#84CCA89FF0A5#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:05.521  - warn: shelly.0 (2701) [authEnabled] 192.168.178.158 (shellyem3 / shellyem3-E8DB84D72806 / SHEM-3#E8DB84D72806#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:05.711  - warn: shelly.0 (2701) [authEnabled] 192.168.178.173 (shellyem3 / shellyem3-485519DC0AEF / SHEM-3#485519DC0AEF#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:05.940  - warn: shelly.0 (2701) [authEnabled] 192.168.178.157 (shelly1pm / shelly1pm-8CAAB574CB6C / SHSW-PM#8CAAB574CB6C#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:06.096  - warn: shelly.0 (2701) [authEnabled] 192.168.178.156 (shelly1 / shelly1-58BF25D8700A / SHSW-1#58BF25D8700A#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:06.671  - warn: shelly.0 (2701) [authEnabled] 192.168.178.153 (shellyswitch25 / shellyswitch25-D8BFC01A558C / SHSW-25#D8BFC01A558C#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:06.773  - warn: shelly.0 (2701) [authEnabled] 192.168.178.155 (shellyswitch25 / shellyswitch25-C8C9A375029E / SHSW-25#C8C9A375029E#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:06.835  - warn: shelly.0 (2701) [authEnabled] 192.168.178.166 (shellyswitch25 / shellyswitch25-98CDAC2D0858 / SHSW-25#98CDAC2D0858#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:06.886  - warn: adguard.1 (2793) No connection to the server could be established. (Error: connect ECONNREFUSED 192.168.178.141:80)
                        2023-06-11 22:49:06.951  - warn: shelly.0 (2701) [authEnabled] 192.168.178.154 (shellyswitch25 / shellyswitch25-E8DB84AAB39C / SHSW-25#E8DB84AAB39C#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:07.203  - warn: shelly.0 (2701) [authEnabled] 192.168.178.161 (shelly1 / shelly1-E8DB84AB7C26 / SHSW-1#E8DB84AB7C26#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:08.677  - warn: shelly.0 (2701) [authEnabled] 192.168.178.169 (shellyplug-s / shellyplug-s-4022D881CACB / SHPLG-S#4022D881CACB#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:08.732  - warn: shelly.0 (2701) [authEnabled] 192.168.178.150 (shellyswitch25 / shellyswitch25-E8DB84A1B284 / SHSW-25#E8DB84A1B284#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-06-11 22:49:09.366  - warn: shelly.0 (2701) [authEnabled] 192.168.178.170 (shellyplug-s / shellyplug-s-4022D882E3C5 / SHPLG-S#4022D882E3C5#1): This device is not protected via restricted login (see adapter documentation for details)
                        Copy text starting here:
                                             v.2023-04-16
                        Kernel:                 6.1.21-v8+
                        User-ID:                1000
                        X-Server:               false
                        Pending OS-Updates:     0
                        Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                                /usr/bin/npm            9.5.1
                                                /usr/bin/npx            9.5.1
                        MEMORY:
                        Mem:            1.8G        1.2G        240M        0.0K        371M        543M
                        Swap:            99M        1.0M         98M
                        Total:          1.9G        1.2G        338M
                        Active iob-Instances:   34
                                                admin                   6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                19024
                        States:                 15935
                        6.1M    /opt/iobroker/iobroker-data/states.jsonl
                        • W wurschtbrot
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=raspbian
                          ID_LIKE=debian
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=51.1'C
                          volt=0.9060V
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   1849 M total memory
                                   1026 M used memory
                                     70 M free memory
                                    157 M buffer memory
                                    595 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          1.2G    /var/
                          812M    /var/log
                          169M    /var/cache
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          javascript:     6.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        19024
                          States:         15935
                          Pending Updates: 0
                                               v.2023-04-16
                          Kernel:                 6.1.21-v8+
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            9.5.1
                                                  /usr/bin/npx            9.5.1
                          MEMORY:
                          Swap:            99M        1.0M         98M
                                                  admin                   6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                19024
                          States:                 15935
                          @wurschtbrot
                          Ja, jetzt ist alles senkrecht.
                          Richte dir den Backitup-Adapter noch ein und nutze den für Backups und nicht die schrägen Kommandos.
                            @wurschtbrot
                            W Offline
                            W Offline
                            wurschtbrot
                            @thomas-braun alles klar mach ich musste ich nur wieder Aktivieren und gleich ein Backup damit auf Google Drive gemacht
                            dank dir für die schnelle und kompetente Hilfe ;)
                            schönen Abend noch
