  3. Einsteigerfragen
  4. Deconz neu installieren
    5.5k
29 Beiträge 2 Kommentatoren 4.0k Aufrufe 3 Beobachtet
  • Q Qax1
    @qax1
    pi@raspy-io:~ $ sudo systemctl enable deconz.service
    Created symlink /etc/systemd/system/multi-user.target.wants/deconz.service → /li                       b/systemd/system/deconz.service.
    pi@raspy-io:~ $
    @qax1
    Mach bitte dein puTTY Mäusekino breiter, damit nicht die Hälfte abgeschnitten wird. Oder verwende ein richtiges Terminal.
    journalctl -u deconz.service
    sagt?
    Q 1 Antwort Letzte Antwort
      @qax1
      sagt?
      Q Offline
      Q Offline
      Qax1
      pi@raspy-io:~ $ ^C
      pi@raspy-io:~ $ journalctl -u deconz.service
      -- Journal begins at Wed 2023-05-03 05:11:24 CEST, ends at Sun 2023-06-11 11:18:06 CEST. --
      Jun 11 11:06:07 raspy-io systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
      Jun 11 11:06:08 raspy-io deCONZ[2787]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
      Jun 11 11:06:09 raspy-io deCONZ[2787]: libpng warning: iCCP: known incorrect sRGB profile
      Jun 11 11:06:13 raspy-io deCONZ[2787]: This plugin does not support propagateSizeHints()
      Jun 11 11:15:46 raspy-io systemd[1]: Stopping deCONZ: ZigBee gateway -- REST API...
      Jun 11 11:15:50 raspy-io systemd[1]: deconz.service: Main process exited, code=exited, status=143/n/a
      Jun 11 11:15:50 raspy-io systemd[1]: deconz.service: Failed with result 'exit-code'.
      Jun 11 11:15:50 raspy-io systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
      Jun 11 11:15:50 raspy-io systemd[1]: deconz.service: Consumed 9min 34.081s CPU time.
      pi@raspy-io:~ $
      • Q Qax1
        pi@raspy-io:~ $ ^C
        pi@raspy-io:~ $
        @qax1
        sudo systemctl restart deconz
          @qax1
          Q Offline
          Q Offline
          Qax1
          pi@raspy-io:~ $ sudo systemctl restart deconz
          -- Journal begins at Wed 2023-05-03 05:11:24 CEST, ends at Sun 2023-06-11 11:28:58 CEST. --
          -- Boot 9be28b290cf247fcbc6504d71473c838 --
          Jun 11 11:28:54 raspy-io systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
          Jun 11 11:28:55 raspy-io deCONZ[830]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
          Jun 11 11:28:55 raspy-io deCONZ[830]: libpng warning: iCCP: known incorrect sRGB profile
          Jun 11 11:28:58 raspy-io deCONZ[830]: This plugin does not support propagateSizeHints()
          pi@raspy-io:~ $
          • Q Qax1
            pi@raspy-io:~ $
            @qax1
            systemctl status deconz
              @qax1
              Q Offline
              Q Offline
              Qax1
              @thomas-braun sagte in Deconz neu installieren:
              pi@raspy-io:~ $ ^C
              pi@raspy-io:~ $ systemctl status deconz
              ● deconz.service - deCONZ: ZigBee gateway -- REST API
                   Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
                   Active: active (running) since Sun 2023-06-11 11:28:54 CEST; 4min 18s ago
                 Main PID: 830 (deCONZ)
                    Tasks: 4 (limit: 3933)
                      CPU: 4min 13.767s
                   CGroup: /system.slice/deconz.service
                           └─830 /usr/bin/deCONZ -platform minimal --http-port=80
              pi@raspy-io:~ $
              • Q Qax1
                pi@raspy-io:~ $ ^C
                        CPU: 4min 13.767s
                pi@raspy-io:~ $
                @qax1
                Läuft also.
                  @qax1
                  Läuft also.
                  Q Offline
                  Q Offline
                  Qax1
                  Findet aber das Gateway nicht....
                  • Q Qax1
                    @qax1 sagte in Deconz neu installieren:
                    Wer oder was?
                    Der iobroker.deconz-Adapter?
                      Wer oder was?
                      Q Offline
                      Q Offline
                      Qax1
                      schrieb am zuletzt editiert von Qax1
                      Die Phoscon-App finde den ConBee2 nicht.
                      Beim IObroker bin ich noch gar nicht.
                      Ich brauch erst mal n Kaffe ...
                      • Q Qax1
                        @qax1
                        Redest du von der web-Oberfläche oder von dem Deconz-GUI?
                          @qax1
                          Q Offline
                          Q Offline
                          Qax1
                          Nein, die hatte ich noch nie installiert,
                          hab schon immer Paspyan ohne Desktop, und DeCONZ ohne GUI.
                          Nun können die ersten Zigbee Geräte über die Phoscon App angelernt werden. Weitere Informationen hierzu gibt es in der Phoscon App Dokumentation.
                          Über die Phoscon APP dann die Geräte angelernt.
                          Das Ding ...
                          • Q Qax1
                            Das Ding ...
                            @qax1
                            Starte die Kiste mal sauber durch.
                              @qax1
                              Q Offline
                              Q Offline
                              Qax1
                              So, nach Raspy und Rechner Neustart finde ich wenigstens das Gatewax wieder.
                              Aber die Lichtersuche bleibt erfolglos.
                              Wenn ich jetzt eine Karte mit dem fertigen Image flashe
                              finde ich inerhalb 1 Minute 4-5 Geräte..
                              Eine andere Karte mit IObroker und Zigbee Adapter funktioniert auch.
                              Ist das eine schei... wenn man keine Ahnung hat.
                              • Q Qax1
                                @qax1
                                Von phoscon selber hab ich keine Ahnung.
                                  @qax1
                                  Q Offline
                                  Q Offline
                                  Qax1
                                  Trotzdem 1000 Dank für deine Mühen.
                                  Gruß Stefan
