  2. English
  4. Node-Red Adapter SSH Key generation not possible
node-red projektnode-rednode-red adapter
5 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • H Offline
    huibuh420
    |Systemdata|
    |Hardwaresystem: Raspberry Pi 4
    |Arbeitsspeicher:| 2GB |
    |Festplattenart:| SD-Karte
    |Betriebssystem:| Raspbian
    |Node-Version:| 3.0.2
    |Nodejs-Version:| 10.x.x |
    |NPM-Version:| 6.x.x |
    I would like to connect my flow with github.
    To connect the flow with a github repo I need to generate a SSH key.
    The problem is now, that it's not showing any key after pressing "Schlüssel generieren".
    In the logs I can't find any errors.
    What is the root cause?
    • H huibuh420
      |Systemdata|
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      @huibuh420 sagte in Node-Red Adapter SSH Key generation not possible:
      You have not installed the package "openssh-client".
      H 1 Antwort Letzte Antwort
      • Marc BergM Marc Berg
        huibuh420
        @marc-berg I already did. It seems like to me, that the command is inside iobroker not accessible. Maybe this is an issue with the docker build?
        With the exec node I tried to execute ssh-keygen inside node-red.
        => This seems like to me, that the command is not visible inside the docker container.
        mickymM Marc BergM 2 Antworten Letzte Antwort
        • H huibuh420
          mickymM Offline
          mickymM Offline
          mickym
          @huibuh420 you have to install the openssh-cliient package in directory
          /opt/iobroker/iobroker-data/node.red
          • H huibuh420
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            A client properly installed via the package manager is located at /usr/bin and is therefore accessible via the path environment variable. I installed the openssh-client package via the Docker environment variable "PACKAGES".
