Ibroker nach 24 Std. nicht erreichbar
ich habe den ioBroker-RasPi 1.4.2 auf eine RaspberyPi3 installiert. Nachts passiert etwas, so das ich den am nächsten Morgen vom Strom nehmen muss.
Weder die Admin GUI von noch ein Ping auf den Raspberry geht dann noch.
Kann das die Ursache sein ?:
` > 2018-10-04 06:34:24.891 - error: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 1 ()
2018-10-04 06:34:29.259 - debug: fritzdect.0 [{"identifier":"099950067621","id":"16","functionbitmask":"320","fwversion":"04.70","manufacturer":"AVM","productname":"FRITZ!DECT 301","present":"1","name":"Heizkörper_Flur","temperature":{"celsius":"200","offset":"0"},"hkr":{"tist":"40","tsoll":"42","absenk":"32","komfort":"42","lock":"0","devicelock":"0","errorcode":"0","batterylow":"0","windowopenactiv":"0","battery":"100","nextchange":{"endperiod":"1538632800","tchange":"32"},"summeractive":"0","holidayactive":"0"}}]
2018-10-04 06:34:29.261 - debug: fritzdect.0 Comet_099950067621 : errorcode :0
2018-10-04 06:34:29.270 - debug: fritzdect.0 redis pmessage io.fritzdect.0.* io.fritzdect.0.Comet_099950067621.errorcode {"val":"0","ack":true,"ts":1538627669266,"q":0,"from":"system.adapter.fritzdect.0","lc":1538574803800}
2018-10-04 06:34:29.273 - debug: fritzdect.0 stateChange fritzdect.0.Comet_099950067621.errorcode {"val":"0","ack":true,"ts":1538627669266,"q":0,"from":"system.adapter.fritzdect.0","lc":1538574803800}
2018-10-04 06:34:56.085 - error: Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:63749
2018-10-04 06:34:56.085 - error: Caught by controller[0]: return faL
2018-10-04 06:34:56.085 - error: Caught by controller[0]: SyntaxError: Invalid or unexpected token
2018-10-04 06:34:56.085 - error: Caught by controller[0]: at createScript (vm.js:80:10)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Module._compile (module.js:616:28)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Module.load (module.js:565:32)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Module.require (module.js:596:17)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at require (internal/module.js:11:18)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
2018-10-04 06:34:56.086 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
2018-10-04 06:34:56.087 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Module.require (module.js:596:17)
2018-10-04 06:34:56.091 - error: Caught by controller[0]: at require (internal/module.js:11:18)
2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
2018-10-04 06:34:56.091 - error: Caught by controller[0]: at Module.load (module.js:565:32)
2018-10-04 06:34:56.091 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Module.require (module.js:596:17)
2018-10-04 06:34:56.092 - error: Caught by controller[0]: at require (internal/module.js:11:18)
2018-10-04 06:34:56.092 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:23:27
2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Module.load (module.js:565:32)
2018-10-04 06:34:56.092 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:34:56.092 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
2018-10-04 06:34:56.093 - error: Caught by controller[0]: at Function.Module.runMain (module.js:693:10)
2018-10-04 06:34:56.093 - error: Caught by controller[0]: at startup (bootstrap_node.js:188:16)
2018-10-04 06:34:56.093 - error: Caught by controller[0]: at bootstrap_node.js:609:3
2018-10-04 06:34:56.093 - error: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 1 ()
2018-10-04 06:35:27.280 - error: Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:63749
2018-10-04 06:35:27.281 - error: Caught by controller[0]: return faL
2018-10-04 06:35:27.281 - error: Caught by controller[0]: SyntaxError: Invalid or unexpected token
2018-10-04 06:35:27.281 - error: Caught by controller[0]: at createScript (vm.js:80:10)
2018-10-04 06:35:27.281 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
2018-10-04 06:35:27.281 - error: Caught by controller[0]: at Module._compile (module.js:616:28)
2018-10-04 06:35:27.281 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
2018-10-04 06:35:27.281 - error: Caught by controller[0]: at Module.load (module.js:565:32)
2018-10-04 06:35:27.281 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Module.require (module.js:596:17)
2018-10-04 06:35:27.282 - error: Caught by controller[0]: at require (internal/module.js:11:18)
2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Module.load (module.js:565:32)
2018-10-04 06:35:27.282 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:35:27.282 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Module.load (module.js:565:32)
2018-10-04 06:35:27.283 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Module.require (module.js:596:17)
2018-10-04 06:35:27.283 - error: Caught by controller[0]: at require (internal/module.js:11:18)
2018-10-04 06:35:27.283 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:23:27
2018-10-04 06:35:27.283 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
2018-10-04 06:35:27.284 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:35:27.284 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
2018-10-04 06:35:27.284 - error: Caught by controller[0]: at Function.Module.runMain (module.js:693:10)
2018-10-04 06:35:27.284 - error: Caught by controller[0]: at startup (bootstrap_node.js:188:16)
2018-10-04 06:35:27.284 - error: Caught by controller[0]: at bootstrap_node.js:609:3
2018-10-04 06:35:27.284 - error: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 1 ()
2018-10-04 06:35:58.514 - error: Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:63749
2018-10-04 06:35:58.515 - error: Caught by controller[0]: return faL
2018-10-04 06:35:58.515 - error: Caught by controller[0]: SyntaxError: Invalid or unexpected token
2018-10-04 06:35:58.515 - error: Caught by controller[0]: at createScript (vm.js:80:10)
2018-10-04 06:35:58.515 - error: Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
2018-10-04 06:35:58.515 - error: Caught by controller[0]: at Module._compile (module.js:616:28)
2018-10-04 06:35:58.515 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
2018-10-04 06:35:58.515 - error: Caught by controller[0]: at Module.load (module.js:565:32)
2018-10-04 06:35:58.516 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Module.require (module.js:596:17)
2018-10-04 06:35:58.516 - error: Caught by controller[0]: at require (internal/module.js:11:18)
2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Module.load (module.js:565:32)
2018-10-04 06:35:58.516 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Module._compile (module.js:652:30)
2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Module.load (module.js:565:32)
2018-10-04 06:35:58.517 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Module.require (module.js:596:17)
2018-10-04 06:35:58.517 - error: Caught by controller[0]: at require (internal/module.js:11:18)
2018-10-04 06:35:58.517 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:23:27
2018-10-04 06:35:58.517 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
2018-10-04 06:35:58.518 - error: Caught by controller[0]: at tryModuleLoad (module.js:505:12)
2018-10-04 06:35:58.518 - error: Caught by controller[0]: at Function.Module._load (module.js:497:3)
2018-10-04 06:35:58.518 - error: Caught by controller[0]: at Function.Module.runMain (module.js:693:10)
2018-10-04 06:35:58.518 - error: Caught by controller[0]: at startup (bootstrap_node.js:188:16)
2018-10-04 06:35:58.518 - error: Caught by controller[0]: at bootstrap_node.js:609:3
2018-10-04 06:35:58.518 - error: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 1 ()
2018-10-04 06:36:29.718 - error: Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:63749
2018-10-04 06:36:29.718 - error: Caught by controller[0]: return faL
2018-10-04 06:36:29.719 - error: Caught by controller[0]:</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous> `
Es sieht so aus als ob ein File korrupt geworden ist … das sieht eher danach aus das deine SD Karte langsam den geist aufgibt ...
habe den Fehler mittlerweile gefunden. Das Gehäuse ließ den RaspberyPi3 zu heiß werden, dann schaltet er ja ab.
Das mit der Karte werde ich mal im Auge behalten, Danke 8-)
