Rolladen/Beschattung Blockly
ich habe mir folgendes einfaches Blockly zusammen geklickt.
Es funktioniert aber nicht.
Kann mir einer der Spezis vielleicht sagen wo ich da meinen Fehler eingebaut habe.
Hier der export
<xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="025W,vKkAw^{oaLn#?{k" x="-837" y="-412"><field name="COMMENT">Kommentar</field> <next><block type="on" id="[A/^r*g:1xbUF4OHUqj!"><field name="OID">weatherunderground.0.current.temp_c</field> <field name="CONDITION">ne</field> <statement name="STATEMENT"><block type="controls_if" id="3drE2#7[?4(6%Xl(F)w{"><value name="IF0"><block type="time_compare" id="p9/4|1%s,,A;/BQ,-#:f"><mutation end_time="true"></mutation> <field name="OPTION">between</field> <field name="START_TIME">10:00</field> <field name="END_TIME">20:00</field></block></value> <statement name="DO0"><block type="controls_if" id="h|_NPlK@BJ=P!NR|r:7?"><mutation elseif="1"></mutation> <value name="IF0"><block type="logic_operation" id="a.h`?p4?W/ZJii{yjRh+"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="_5H;+jU5l.Au2K(7t=Wa"><field name="OP">GT</field> <value name="A"><block type="get_value" id="r2V7h0ipiGV;W(~TB+12"><field name="ATTR">val</field> <field name="OID">weatherunderground.0.current.temp_c</field></block></value> <value name="B"><block type="math_number" id="f;T3}6D]Xg/6z260.`fg"><field name="NUM">23</field></block></value></block></value> <value name="B"><block type="logic_compare" id="[8q+*CXWXyNrL-.rf#=H"><field name="OP">GT</field> <value name="A"><block type="get_value" id="Gu88%e*lsH7=Q;Y.1j@w"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.NEQ1296140.1.BRIGHTNESS</field></block></value> <value name="B"><block type="math_number" id="#KxsJQ{}yh1V9@Zyo2Vm"><field name="NUM">200</field></block></value></block></value></block></value> <statement name="DO0"><block type="controls_if" id="7`4r`m*8qqH~w~4#QUcG"><value name="IF0"><block type="logic_compare" id=",`.,.AiYaFHV[0~WOCMc"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="CMXy.LP)L^.q*v!6YT=6"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.OEQ0429874.1.STATE</field></block></value> <value name="B"><block type="logic_boolean" id="MUtE)Y_XPETBvb+7}vq1"><field name="BOOL">FALSE</field></block></value></block></value> <statement name="DO0"><block type="control" id="iU@~#H2;bcdlY?QvL.zW"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.0.OEQ0259191.1.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="NvWqI9{*hSbI1n)KL6-O"><field name="NUM">70</field></block></value> <next><block type="control" id="XfjVm;;_1E[KES{?5X=u"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.0.OEQ0259579.1.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="[ai%|D3-NYC/Jd/Y^DK2"><field name="NUM">50</field></block></value> <next><block type="control" id="V]@n=;yFN7a}DGZ%cW~*"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.0.OEQ0050030.1.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="ryu24Si)|b~Je*]^nEP9"><field name="NUM">50</field></block></value></block></next></block></next></block></statement> <next><block type="debug" id="c;B/43|A-AlvB+wjwUBQ"><field name="Severity">debug</field> <value name="TEXT"><shadow type="text" id="67^Q=Kd)fij7+o3m0(Rj"><field name="TEXT">Beschattung</field></shadow></value></block></next></block></statement> <value name="IF1"><block type="logic_operation" id="#)WrPdx|S5eU||f8*;oW"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="CP|Rw%pNYH2USxJNN+Xv"><field name="OP">LTE</field> <value name="A"><block type="get_value" id="}PHqqS!AGZndv2+LrgZn"><field name="ATTR">val</field> <field name="OID">weatherunderground.0.current.temp_c</field></block></value> <value name="B"><block type="math_number" id="4d/|k5M/gMH2j8TORCX4"><field name="NUM">23</field></block></value></block></value> <value name="B"><block type="logic_compare" id="uYkP3l;t~jhh9`a;chw!"><field name="OP">LT</field> <value name="A"><block type="get_value" id="%je[;-7K~=s#oTV*+dYm"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.NEQ1296140.1.BRIGHTNESS</field></block></value> <value name="B"><block type="math_number" id="RU(0%J;QuQa)+6{@RMTT"><field name="NUM">210</field></block></value></block></value></block></value> <statement name="DO1"><block type="control" id="?:(?jC@rtT;t1){oI[2|"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.0.OEQ0259191.1.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="y%/y_!2m}M!fSr=Lek+J"><field name="NUM">100</field></block></value> <next><block type="control" id="t:nPDB`(UW1*JK[LZZ^;"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.0.OEQ0259579.1.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="#kpwOsrwW;N)NF.{Rf0B"><field name="NUM">100</field></block></value> <next><block type="control" id="]UAA`SjHrzIrapR]}gb~"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.0.OEQ0050030.1.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="^E9nzjSRk6-Vho8*E%YV"><field name="NUM">100</field></block></value></block></next></block></next></block></statement></block></statement></block></statement></block></next></block></xml>
