Sonos Adapter Problem mit Sonos Beam
Hallo Jungs, habe ein Problem das ich über SayIt nicht meine Beam "angesteuert" bekomme.
host.IoBroker 2018-07-19 21:02:08.007 error instance system.adapter.sonos.0 terminated with code 0 (OK) Caught 2018-07-19 21:02:08.006 error by controller[0]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-07-19 21:02:08.006 error by controller[0]: at tryOnTimeout (timers.js:250:5) Caught 2018-07-19 21:02:08.005 error by controller[0]: at ontimeout (timers.js:396:15) Caught 2018-07-19 21:02:08.005 error by controller[0]: at Timeout.playOnSonos [as _onTimeout] (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:907:9) Caught 2018-07-19 21:02:08.002 error by controller[0]: at fadeOut (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:725:20) Caught 2018-07-19 21:02:07.986 error by controller[0]: TypeError: Cannot create property 'actual' on boolean 'false' sonos.0 2018-07-19 21:02:07.895 info terminating sonos.0 2018-07-19 21:02:07.879 info terminating sonos.0 2018-07-19 21:02:07.875 error at Timer.listOnTimeout (timers.js:214:5) sonos.0 2018-07-19 21:02:07.875 error at tryOnTimeout (timers.js:250:5) sonos.0 2018-07-19 21:02:07.875 error at ontimeout (timers.js:396:15) sonos.0 2018-07-19 21:02:07.875 error at Timeout.playOnSonos [as _onTimeout] (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:907:9) sonos.0 2018-07-19 21:02:07.875 error at fadeOut (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:725:20) sonos.0 2018-07-19 21:02:07.875 error TypeError: Cannot create property 'actual' on boolean 'false' sonos.0 2018-07-19 21:02:07.874 error uncaught exception: Cannot create property 'actual' on boolean 'false' sonos.0 2018-07-19 21:02:07.820 info try to control id sonos.0.root.192_168_178_42.tts with {"val":"70;http://192.168.178.43:8082/state/sayit.0.tts.mp3","ack":false,"ts":1532026927815,"q":0,"from":"system.adapter.sayit.0","lc":153202692 sayit.0 2018-07-19 21:02:07.783 info Copied file "/opt/iobroker/node_modules/iobroker.sayit/lib/../sayit.0.say.mp3" to "/opt/iobroker/cache/02b51b320cde111850a78713d47771bc.mp3" sayit.0 2018-07-19 21:02:07.743 info Set "sonos.0.root.192_168_178_42.tts: 70;http://192.168.178.43:8082/state/sayit.0.tts.mp3 sayit.0 2018-07-19 21:02:07.328 info saying: Hallo Test
Jemand eine Idee woran das liegt oder ist die Sonos Beam noch zu neu?…
Sonos Play 1 seit adapter update 1.7.0 bis 1.7.2 das gleiche problem mit 1.6.2 alles O.K. ?????
iobroker 2018-07-20 11:18:29.957 info upgrade sonos@1.6.2
sonos.0 2018-07-20 11:17:07.034 info http sonos server listening on port 8080
sonos.0 2018-07-20 11:17:06.941 info starting. Version 1.7.2 in C:/ioBroker/node_modules/iobroker.sonos, node: v6.14.3
host.SERVER 2018-07-20 11:17:04.222 info instance system.adapter.sonos.0 started with pid 26584
sayit.0 2018-07-20 11:17:02.066 info Set "sonos.0.root.192_168_178_29.tts: 70;http://192.168.178.23:8082/state/sayit.0.tts.mp3
sayit.0 2018-07-20 11:17:01.879 info saying: DeckenfluterAusgeschaltet
sayit.0 2018-07-20 11:17:00.863 info Set "sonos.0.root.192_168_178_29.tts: 49;http://192.168.178.23:8082/state/sayit.0.tts.mp3
sayit.0 2018-07-20 11:17:00.863 info saying: C:\ioBroker\node_modules\iobroker.sayit/gong.mp3
sayit.0 2018-07-20 11:16:35.394 info Set "sonos.0.root.192_168_178_29.tts: 70;http://192.168.178.23:8082/state/sayit.0.tts.mp3
sayit.0 2018-07-20 11:16:35.097 info saying: DeckenfluterEingeschaltet
host.SERVER 2018-07-20 11:16:34.206 info Restart adapter system.adapter.sonos.0 because enabled
host.SERVER 2018-07-20 11:16:34.206 error instance system.adapter.sonos.0 terminated with code 0 (OK)
Caught 2018-07-20 11:16:34.206 error by controller[0]: at Timer.listOnTimeout (timers.js:214:5)
Caught 2018-07-20 11:16:34.206 error by controller[0]: at tryOnTimeout (timers.js:250:5)
Caught 2018-07-20 11:16:34.206 error by controller[0]: at ontimeout (timers.js:396:15)
Caught 2018-07-20 11:16:34.206 error by controller[0]: at Timeout.playOnSonos [as _onTimeout] (C:\ioBroker\node_modules\iobroker.sonos\main.js:987:9)
Caught 2018-07-20 11:16:34.190 error by controller[0]: at fadeOut (C:\ioBroker\node_modules\iobroker.sonos\main.js:805:20)
Caught 2018-07-20 11:16:34.190 error by controller[0]: TypeError: Cannot create property 'actual' on boolean 'false'
sonos.0 2018-07-20 11:16:34.144 info terminating
sonos.0 2018-07-20 11:16:34.128 error at Timer.listOnTimeout (timers.js:214:5)
sonos.0 2018-07-20 11:16:34.128 error at tryOnTimeout (timers.js:250:5)
sonos.0 2018-07-20 11:16:34.128 error at ontimeout (timers.js:396:15)
sonos.0 2018-07-20 11:16:34.128 error at Timeout.playOnSonos [as _onTimeout] (C:\ioBroker\node_modules\iobroker.sonos\main.js:987:9)
sonos.0 2018-07-20 11:16:34.128 error at fadeOut (C:\ioBroker\node_modules\iobroker.sonos\main.js:805:20)
sonos.0 2018-07-20 11:16:34.128 error TypeError: Cannot create property 'actual' on boolean 'false'
sonos.0 2018-07-20 11:16:34.128 error uncaught exception: Cannot create property 'actual' on boolean 'false'
sonos.0 2018-07-20 11:16:34.113 info try to control id sonos.0.root.192_168_178_29.tts with {"val":"49;http://192.168.178.23:8082/state/sayit. … r
sayit.0 2018-07-20 11:16:34.082 info Set "sonos.0.root.192_168_178_29.tts: 49;http://192.168.178.23:8082/state/sayit.0.tts.mp3
sayit.0 2018-07-20 11:16:34.066 info saying: C:\ioBroker\node_modules\iobroker.sayit/gong.mp3
sayit.0 2018-07-20 11:15:28.019 info All files uploaded
sayit.0 2018-07-20 11:15:27.879 info Upload announce mp3 files
sayit.0 2018-07-20 11:15:27.863 info starting. Version 1.6.8 in C:/ioBroker/node_modules/iobroker.sayit, node: v6.14.3
host.SERVER 2018-07-20 11:15:26.659 info instance system.adapter.sayit.0 started with pid 25796
host.SERVER 2018-07-20 11:15:24.159 info instance system.adapter.sayit.0 terminated with code 0 (OK)
host.SERVER 2018-07-20 11:15:24.128 info stopInstance timeout "1000 system.adapter.sayit.0 killing pid 6824
host.SERVER 2018-07-20 11:15:23.112 info stopInstance system.adapter.sayit.0
sayit.0 2018-07-20 11:15:23.113 info stopping...
host.SERVER 2018-07-20 11:15:23.112 info object change system.adapter.sayit.0
host.SERVER 2018-07-20 11:15:02.956 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
Komisch, hab auch gerade auf 1.6.2 downgraded und jetzt geht es?!
Scheint wohl noch ein kleiner Bug im Adapter zu sein?
Ich kann das ebenfalls bestätigen. Ab 1.7.0 habe ich den beschriebenen Fehler. Ein Downgrade auf 1.6.2 löst das Problem.
Kann sein dass das problem selbst mit der neusten Version so ist
