Mit der Beta Version 2.4.3 funktioniert der Zugriff wieder. Danke für das Beheben, wer auch immer das war
H
Latest posts made by hugi
RE: Viessmann Adapter keine Verbindung mehr
@thomas-braun @Samson71
Ich habe den iob diag ausgeführt und die Fehlermeldung aus dem Log rauskopiert. Ich hoffe das hilft beim Blick in die Glaskugel.{"error":"invalid_request","error_description":"Invalid request: Missing or empty code parameter"} AxiosError: Request failed with status code 400
========== Start marking the full check here =========== ```bash Script v.2025-08-09 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 12 (bookworm) Static hostname: raspberrypi Icon name: computer Kernel: Linux 6.6.51+rpt-rpi-2712 Architecture: arm64 OS is similar to: Model : Raspberry Pi 5 Model B Rev 1.0 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 10:45:47 up 18:27, 3 users, load average: 0.29, 0.16, 0.11 CPU threads: 4 *** LIFE CYCLE STATUS *** Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Mon 2025-10-06 10:45:47 CEST Universal time: Mon 2025-10-06 08:45:47 UTC RTC time: Mon 2025-10-06 08:45:47 Time zone: Europe/Zurich (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Display-Manager: x lightdm.service - Light Display Manager Desktop: Session: tty System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix' *** MEMORY *** total used free shared buff/cache available Mem: 8.4G 2.5G 4.3G 5.9M 1.7G 5.9G Swap: 209M 0B 209M Total: 8.7G 2.5G 4.5G Active iob-Instances: 19 8052 M total memory 2424 M used memory 2254 M active memory 1252 M inactive memory 4101 M free memory 283 M buffer memory 1344 M swap cache 199 M total swap 0 M used swap 199 M free swap *** top - Table Of Processes *** top - 10:45:47 up 18:27, 3 users, load average: 0.29, 0.16, 0.11 Tasks: 207 total, 2 running, 205 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 8052.3 total, 4101.2 free, 2424.8 used, 1628.8 buff/cache MiB Swap: 200.0 total, 200.0 free, 0.0 used. 5627.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * lightdm.service loaded failed failed Light Display Manager LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.8G 0 3.8G 0% /dev tmpfs tmpfs 1.6G 5.4M 1.6G 1% /run /dev/mmcblk0p2 ext4 29G 11G 17G 39% / tmpfs tmpfs 4.0G 0 4.0G 0% /dev/shm tmpfs tmpfs 5.0M 48K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 78M 433M 16% /boot/firmware tmpfs tmpfs 806M 144K 806M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Oct 5 16:18:35 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe smsc95xx.macaddr=2C:CF:67:1F:04:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=3f5521b5-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Sun Oct 5 16:18:35 2025] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add-4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none. [Sun Oct 5 16:18:36 2025] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab98-e9f0235e06b3 r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 3.2G /var/ 2.1G /var/cache/apt 2.1G /var/cache 2.0G /var/cache/apt/archives 648M /var/log Archived and active journals take up 646.7M in the file system. /opt/iobroker/backups: 37M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 339M /opt/iobroker/iobroker-data/ 131M /opt/iobroker/iobroker-data/files 94M /opt/iobroker/iobroker-data/backup-objects 47M /opt/iobroker/iobroker-data/files/admin.admin 46M /opt/iobroker/iobroker-data/files/admin.admin/custom/assets The five largest files in iobroker-data are: 58M /opt/iobroker/iobroker-data/objects.jsonl 56M /opt/iobroker/iobroker-data/states.jsonl 8.6M /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js 4.6M /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js 4.4M /opt/iobroker/iobroker-data/files/yahka.admin/yahka.admin.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v22.20.0 /usr/bin/node v22.20.0 /usr/bin/npm 10.9.3 /usr/bin/npx 10.9.3 /usr/bin/corepack 0.34.0 nodejs: Installed: 22.20.0-1nodesource1 Candidate: 22.20.0-1nodesource1 Version table: *** 22.20.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 22.19.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.18.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.16.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.14.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.12.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.11.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.10.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.9.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.8.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.7.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.6.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.3.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.2.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.1.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.0.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 18.20.4+dfsg-1~deb12u1 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: █████ ██ ██ ██████ ██████ ██████ ██████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ███ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ███████ ██████ ██████ ██████ ██████ ██ *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: raspberrypi raspberrypi (version: 7.0.7, hostname: raspberrypi , alive, uptime: 62226) Core adapters versions js-controller: 7.0.7 admin: 7.7.2 javascript: 8.9.2 nodejs modules from github: 1 +-- iobroker.renault@0.0.21 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#88555e6024eac2d1f016a9a1ef25f7c1bf965aea) Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.digitalstrom.0 : digitalstrom : raspberrypi - enabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled + system.adapter.fronius.0 : fronius : raspberrypi - enabled system.adapter.go-e.0 : go-e : raspberrypi - disabled + system.adapter.harmony.0 : harmony : raspberrypi - enabled + system.adapter.hue.0 : hue : raspberrypi - enabled, port: 443 + system.adapter.javascript.0 : javascript : raspberrypi - enabled system.adapter.mihome.0 : mihome : raspberrypi - disabled, port: 9898, bind: 0.0.0.0 + system.adapter.mystrom.0 : mystrom : raspberrypi - enabled + system.adapter.netatmo.0 : netatmo : raspberrypi - enabled system.adapter.nuki-extended.0 : nuki-extended : raspberrypi - disabled + system.adapter.renault.0 : renault : raspberrypi - enabled system.adapter.roborock.0 : roborock : raspberrypi - disabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 system.adapter.sonos.0 : sonos : raspberrypi - disabled + system.adapter.swiss-weather-api.0 : swiss-weather-api : raspberrypi - enabled + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.viessmannapi.0 : viessmannapi : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.yahka.0 : yahka : raspberrypi - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hue.0 : hue : raspberrypi - enabled, port: 443 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬────────────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼────────────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴────────────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): Stable (default) Upgrade policy: none Installed ioBroker-Adapters Used repository: Stable (default) Adapter "admin" : 7.7.2 , installed 7.7.2 Adapter "backitup" : 3.3.5 , installed 3.3.5 Adapter "digitalstrom" : 2.3.0 , installed 2.3.0 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "fronius" : 2.1.1 , installed 2.1.1 Adapter "go-e" : 1.0.41 , installed 1.0.41 Adapter "harmony" : 1.5.0 , installed 1.5.0 Adapter "hue" : 3.16.2 , installed 3.16.2 Adapter "javascript" : 8.9.2 , installed 8.9.2 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "mihome" : 1.4.0 , installed 1.4.0 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "nuki-extended": 2.7.0 , installed 2.7.0 Adapter "roborock" : 0.6.18 , installed 0.6.18 Adapter "rpi2" : 2.4.0 , installed 2.4.0 Adapter "shelly" : 10.2.0 , installed 10.2.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "swiss-weather-api": 2.2.2, installed 2.2.2 Adapter "telegram" : 4.1.0 , installed 4.1.0 Adapter "viessmannapi" : 2.3.0 , installed 2.3.0 Adapter "web" : 7.0.8 , installed 7.0.8 Adapter "ws" : 2.6.2 , installed 2.6.2 Adapter "yahka" : 1.1.5 , installed 1.1.5 Objects and States Please stand by - This may take a while Objects: 44134 States: 37103 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 5097 866/sshd: /usr/sbin tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 72003 17125/iobroker.js-c tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 74838 17125/iobroker.js-c tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 294632 28542/cupsd tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 75320 17372/io.shelly.0 tcp 0 0 127.0.0.1:43769 0.0.0.0:* LISTEN 1001 77117 17387/io.yahka.0 tcp6 0 0 :::61991 :::* LISTEN 1001 74736 17291/io.harmony.0 tcp6 0 0 :::33667 :::* LISTEN 1001 72254 17387/io.yahka.0 tcp6 0 0 :::22 :::* LISTEN 0 5099 866/sshd: /usr/sbin tcp6 0 0 ::1:631 :::* LISTEN 0 294631 28542/cupsd tcp6 0 0 :::8082 :::* LISTEN 1001 77077 17556/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 74908 17143/io.admin.0 udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 74737 17291/io.harmony.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 4978 679/avahi-daemon: r udp 0 0 0.0.0.0:46945 0.0.0.0:* 104 4980 679/avahi-daemon: r udp6 0 0 :::46250 :::* 104 4981 679/avahi-daemon: r udp6 0 0 :::5353 :::* 104 4979 679/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-10-06 10:33:22.580 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:34:22.504 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:34:22.570 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:35:22.593 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:35:22.637 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:36:22.041 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:36:22.140 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:37:22.065 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:37:22.180 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:38:22.104 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:38:22.205 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:39:22.497 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:39:22.680 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:40:22.524 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:40:22.628 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:41:22.070 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:41:22.176 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:42:22.115 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:42:22.220 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:43:22.109 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:43:22.210 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:44:22.126 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:44:22.224 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string" 2025-10-06 10:45:22.134 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunazimuth" has to be type "number" but received type "string" 2025-10-06 10:45:22.237 - info: digitalstrom.0 (17246) State value to set for "digitalstrom.0.apartment.sensors.outdoor.sunelevation" has to be type "number" but received type "string"
iob diag has finished.
pi@raspberrypi:~ $ ========== Start marking the full check here ===========
Script v.2025-08-09 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 12 (bookworm) Static hostname: raspberrypi Icon name: computer Kernel: Linux 6.6.51+rpt-rpi-2712 Architecture: arm64 OS is similar to: Model : Raspberry Pi 5 Model B Rev 1.0 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 10:45:47 up 18:27, 3 users, load average: 0.29, 0.16, 0.11 CPU threads: 4 *** LIFE CYCLE STATUS *** Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Mon 2025-10-06 10:45:47 CEST Universal time: Mon 2025-10-06 08:45:47 UTC RTC time: Mon 2025-10-06 08:45:47 Time zone: Europe/Zurich (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Display-Manager: x lightdm.service - Light Display Manager Desktop: Session: tty ============ Mark until here for C&P =============
@thomas-braun ich habe das selbe Problem, leider hat da deine Lösung nichts gebracht und ich habe immer noch keine Verbindung. Hast du noch weitere tips?
