2025-08-15 11:45:54.607 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 11:45:54.615 - info: dwd.1 (29477) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 11:45:54.934 - info: dwd.1 (29477) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 11:45:55.444 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29477 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 11:49:31.008 - info: host.debIOBroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 29492
2025-08-15 11:49:31.655 - info: openweathermap.0 (29492) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.4, js-controller: 7.0.6
2025-08-15 11:49:34.623 - info: awtrix-light.0 (20571) error ECONNABORTED from custom?name=weatherstat: timeout of 3000ms exceeded
2025-08-15 11:49:34.624 - warn: awtrix-light.0 (20571) (custom?name=weatherstat) Unable to update custom app "weatherstat": AxiosError: timeout of 3000ms exceeded
2025-08-15 11:49:39.677 - info: openweathermap.0 (29492) Terminated (NO_ERROR): Without reason
2025-08-15 11:49:40.186 - info: host.debIOBroker instance system.adapter.openweathermap.0 having pid 29492 terminated with code 0 (NO_ERROR)
2025-08-15 11:50:54.006 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29508
2025-08-15 11:50:54.626 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 11:50:54.632 - info: dwd.1 (29508) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 11:50:54.963 - info: dwd.1 (29508) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 11:50:55.474 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29508 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 11:55:54.006 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29523
2025-08-15 11:55:54.639 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 11:55:54.645 - info: dwd.1 (29523) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 11:55:54.982 - info: dwd.1 (29523) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 11:55:55.494 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29523 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:00:54.006 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29538
2025-08-15 12:00:54.631 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:00:54.638 - info: dwd.1 (29538) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:00:54.964 - info: dwd.1 (29538) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:00:55.475 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29538 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:02:17.485 - error: accuweather.0 (20541) Status: 400 text: Bad Request - User action required!
2025-08-15 12:02:17.733 - error: accuweather.0 (20541) Status: 400 text: Bad Request - User action required!
2025-08-15 12:05:54.006 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29553
2025-08-15 12:05:54.640 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:05:54.646 - info: dwd.1 (29553) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:05:54.975 - info: dwd.1 (29553) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:05:55.486 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29553 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:10:54.006 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29568
2025-08-15 12:10:54.631 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:10:54.637 - info: dwd.1 (29568) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:10:54.962 - info: dwd.1 (29568) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:10:55.473 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29568 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:15:54.008 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29583
2025-08-15 12:15:54.635 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:15:54.643 - info: dwd.1 (29583) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:15:54.974 - info: dwd.1 (29583) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:15:55.483 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29583 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:16:01.602 - info: awtrix-light.0 (20571) error ECONNABORTED from stats: timeout of 3000ms exceeded
2025-08-15 12:18:01.720 - info: awtrix-light.0 (20571) error ECONNABORTED from settings: timeout of 3000ms exceeded
2025-08-15 12:18:01.720 - warn: awtrix-light.0 (20571) (settings) Received error: {"message":"timeout of 3000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 3000ms exceeded\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/axios/lib/adapters/http.js:657:16)\n at RedirectableRequest.emit (node:events:524:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at Timeout. (/opt/iobroker/node_modules/follow-redirects/index.js:221:12)\n at listOnTimeout (node:internal/timers:581:17)\n at processTimers (node:internal/timers:519:7)\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":3000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/json","User-Agent":"axios/1.11.0","Accept-Encoding":"gzip, compress, deflate, br"},"baseURL":"http://192.168.178.26:80/api/","responseType":"json","url":"settings","method":"get","allowAbsoluteUrls":true},"code":"ECONNABORTED"}
2025-08-15 12:18:01.720 - error: awtrix-light.0 (20571) [setApiConnected] Unable to refresh settings, apps or indicators: AxiosError: timeout of 3000ms exceeded
2025-08-15 12:20:54.008 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29598
2025-08-15 12:20:54.637 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:20:54.644 - info: dwd.1 (29598) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:20:54.979 - info: dwd.1 (29598) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:20:55.490 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29598 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:25:54.006 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29613
2025-08-15 12:25:54.626 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:25:54.633 - info: dwd.1 (29613) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:25:54.985 - info: dwd.1 (29613) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:25:55.496 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29613 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:30:54.007 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29628
2025-08-15 12:30:54.618 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:30:54.625 - info: dwd.1 (29628) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:30:54.947 - info: dwd.1 (29628) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:30:55.458 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29628 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:35:54.007 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29643
2025-08-15 12:35:54.624 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:35:54.632 - info: dwd.1 (29643) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:35:54.991 - info: dwd.1 (29643) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:35:55.503 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29643 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:40:54.006 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29658
2025-08-15 12:40:54.632 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:40:54.638 - info: dwd.1 (29658) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:40:55.021 - info: dwd.1 (29658) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:40:55.532 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29658 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:45:54.006 - info: host.debIOBroker instance system.adapter.dwd.1 in version "2.8.5" started with pid 29676
2025-08-15 12:45:54.631 - warn: awtrix-light.0 (20571) [createAppRequestObj] Found enabled thresholds for custom app "dwdwarn" - data type is invalid (string)
2025-08-15 12:45:54.638 - info: dwd.1 (29676) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.4, js-controller: 7.0.6
2025-08-15 12:45:54.976 - info: dwd.1 (29676) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-08-15 12:45:55.487 - info: host.debIOBroker instance system.adapter.dwd.1 having pid 29676 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-08-15 12:46:18.874 - info: admin.0 (11224) ==> Connected system.user.admin from ::ffff:192.168.178.20
Latest posts made by Tobias Richter
    RE: 3 Fragen zu ioBroker -> Awtrix Lightposted in Einsteigerfragen
    RE: 3 Fragen zu ioBroker -> Awtrix Lightposted in Einsteigerfragen@mcm1957
 https://hastebin.mingweisamuel.com/osegifosaw.sql
 hoffe das hilftPS: das Problem dass der Text auf englisch ist, habe ich lösen können.
    3 Fragen zu ioBroker -> Awtrix Lightposted in EinsteigerfragenHallo erstmal.
 Ich benutze jetzt schon lange iObroker um meine Awtrix-Light zu betanken. Bisher lief immer alles prima, doch seit kurzem gibt es einige Probleme.
 Ich hoffe ich finde hier hilfe.Problem 1.
 Die Awtrix zeigt einige Sachen verpixelt an beim Umschwenken der Anzeigen. Oder der Text hört einfach auf zu scrollen... hier ein Screenshot:
 Vlt hat das etwas mit dieser Fehlermeldung zu tun... keine Ahnung?
  Problem 2.
 Ich nutze "OpenWeathermap" zum anzeigen des aktuellen Wetters. Bisher war das immer auf deutsch... jetzt steht da aber zb statt "klarer himmel" - clear sky... Wie stell ich das denn wieder um?und Problem 3.
 Seit dem die probleme Aufgetreten sind, stellte ich auch fest, dass unten ein gelber Punkt blinkt.
 Da ich seit gut nem halben jahr weder die Firmware aktualisiert habe (ist die neuste bereits installiert) noch was am iObroker geändert habe, wundert mich das schon etwas.Vielen Dank vorab.
 Trytogetme
