    2. Philipp 1
    P
    Philipp 1
    @Philipp 1
    Philipp 1 Follow
    Latest posts made by Philipp 1
    • RE: SONOFF Zigbee 3.0 Dongle findet keine Gerät (Zigbee)
      @asgothian
      sorry dafür, ist mir gerade echt peinlich.... 😲
      hab's angepasst aber funktionieren tut es leider trotzdem nicht, jetzt kommt folgende Meldung in der log
      zigbee.0
      17386	2024-07-03 15:36:55.992	error	Error herdsman start
      zigbee.0
      17386	2024-07-03 15:36:55.991	error	Failed to start Zigbee
      zigbee.0
      17386	2024-07-03 15:36:55.990	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      zigbee.0
      17386	2024-07-03 15:36:55.798	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      17386	2024-07-03 15:36:55.782	info	Starting Zigbee npm ...
      zigbee.0
      17386	2024-07-03 15:36:55.781	info	Try to reconnect. 1 attempts left
      zigbee.0
      17386	2024-07-03 15:36:45.776	error	Error herdsman start
      zigbee.0
      17386	2024-07-03 15:36:45.775	error	Failed to start Zigbee
      zigbee.0
      17386	2024-07-03 15:36:45.774	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
      zigbee.0
      17386	2024-07-03 15:36:00.769	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"6669cf1b65afed11bb53404e71c9e8b5","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6669cf1b65afed11bb53404e71c9e8b5-if00-port0","vendorId":"10c4","productId":"ea60"}]
      zigbee.0
      17386	2024-07-03 15:36:00.577	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      zigbee.0
      17386	2024-07-03 15:35:39.667	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      17386	2024-07-03 15:35:39.244	info	Starting Zigbee npm ...
      zigbee.0
      17386	2024-07-03 15:35:39.241	info	delete old Backup files. keep only last 10
      zigbee.0
      17386	2024-07-03 15:35:39.125	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.3, js-controller: 5.0.19
      laut Fehler in der log hab ich angeblich ein 2. Instanz laufen (hab ich nicht), hab daher mal die panID geändert.
      Dann kam folgender log dabei raus. Start ohne Fehler aber kurze Zeit später kommt der selbe Fehler wieder...
      zigbee.0
      17437	2024-07-03 15:46:53.280	error	Error herdsman start
      zigbee.0
      17437	2024-07-03 15:46:53.280	error	Failed to start Zigbee
      zigbee.0
      17437	2024-07-03 15:46:53.277	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      zigbee.0
      17437	2024-07-03 15:46:53.013	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      17437	2024-07-03 15:46:52.995	info	Starting Zigbee npm ...
      zigbee.0
      17437	2024-07-03 15:46:52.992	info	Try to reconnect. 1 attempts left
      zigbee.0
      17437	2024-07-03 15:46:42.984	error	Error herdsman start
      zigbee.0
      17437	2024-07-03 15:46:42.983	error	Failed to start Zigbee
      zigbee.0
      17437	2024-07-03 15:46:42.981	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
      zigbee.0
      17437	2024-07-03 15:45:36.776	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      17437	2024-07-03 15:45:36.369	info	Starting Zigbee npm ...
      zigbee.0
      17437	2024-07-03 15:45:36.366	info	delete old Backup files. keep only last 10
      zigbee.0
      17437	2024-07-03 15:45:36.250	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.3, js-controller: 5.0.19
      zigbee.0
      17409	2024-07-03 15:45:27.031	info	terminating
      zigbee.0
      17409	2024-07-03 15:45:26.626	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      17409	2024-07-03 15:45:26.624	info	terminating
      zigbee.0
      17409	2024-07-03 15:45:26.623	warn	Failed to stop zigbee during startup
      zigbee.0
      17409	2024-07-03 15:45:26.539	info	Zigbee: disabling joining new devices.
      zigbee.0
      17409	2024-07-03 15:45:26.529	info	cleaned everything up...
      zigbee.0
      17409	2024-07-03 15:45:26.527	info	Got terminate signal TERMINATE_YOURSELF
      zigbee.0
      17409	2024-07-03 15:45:13.454	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"6669cf1b65afed11bb53404e71c9e8b5","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6669cf1b65afed11bb53404e71c9e8b5-if00-port0","vendorId":"10c4","productId":"ea60"}]
      Ich hoffe das hilft, um herauszufinden was ich falsch mache... Danke nochmal
      P
      Philipp 1
      @arteck und @Asgothian
      ich habe mir jetzt einen zweiten Stick besorgt und diesen eingesteckt. Ohne irgendetwas an der Firmware zu machen. Dieser wird nicht erkannt und im Log kommt folgende Fehlermeldung. Hilft das vielleicht weiter?
      zigbee.0
      1242	2024-07-03 07:32:39.067	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"6669cf1b65afed11bb53404e71c9e8b5","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6669cf1b65afed11bb53404e71c9e8b5-if00-port0","vendorId":"10c4","productId":"ea60"}]
      zigbee.0
      1242	2024-07-03 07:32:38.683	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      zigbee.0
      1242	2024-07-03 07:32:35.969	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      1242	2024-07-03 07:32:35.953	error	Error herdsman start
      zigbee.0
      1242	2024-07-03 07:32:35.952	error	Failed to start Zigbee
      zigbee.0
      1242	2024-07-03 07:32:35.950	error	Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_44f8e99b6cafed11bfc63d4e71c9e8b5-if00-port0"
      zigbee.0
      1242	2024-07-03 07:32:35.924	info	Starting Zigbee npm ...
      zigbee.0
      1242	2024-07-03 07:32:35.923	info	Try to reconnect. 1 attempts left
      zigbee.0
      1242	2024-07-03 07:32:25.936	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      1242	2024-07-03 07:32:25.917	error	Error herdsman start
      zigbee.0
      1242	2024-07-03 07:32:25.916	error	Failed to start Zigbee
      zigbee.0
      1242	2024-07-03 07:32:25.913	error	Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_44f8e99b6cafed11bfc63d4e71c9e8b5-if00-port0"
      zigbee.0
      1242	2024-07-03 07:32:25.326	info	Starting Zigbee npm ...
      zigbee.0
      1242	2024-07-03 07:32:25.323	info	delete old Backup files. keep only last 10
      zigbee.0
      1242	2024-07-03 07:32:25.170	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.3, js-controller: 5.0.19
      um jeglichen Tipp wäre ich sehr dankbar. Und vielen Dank für Eure Hilfe
      P
      Philipp 1
      @asgothian
      hatte ich auch schon mal geguckt, Kanal 11 ist der mit dem wenigsten traffic.
      Ich weiß nur nicht, ob die vielleicht alle schon zu voll sind….
      P
      Philipp 1
      Dank für eure Hilfe. Das ich was falsche mache, weiß ich, ich hoffe nur ihr könnt mir sagen was 😉
      @arteck Soory wegen dem Log.
      Das mit den Wifi Geräten habe ich auch erst gedacht und mir dann extra nochmal beim Amazon diesen Sonoff Adapter(https://www.amazon.de/dp/B08BFW697F?ref=ppx_yo2ov_dt_b_product_details&th=1) bestellt, aber damit geht es auch nicht...
      Hier ein Auszug aus dem Log (Ich hoffe diesmal richtig reingestellt, sorry nochmal dafür):
      zigbee.0
      39310	2024-06-21 11:47:56.495	info	debug devices set to []
      zigbee.0
      39310	2024-06-21 11:47:56.004	info	Zigbee started
      zigbee.0
      39310	2024-06-21 11:47:56.001	info	Currently no devices.
      zigbee.0
      39310	2024-06-21 11:47:55.977	info	--> transmitPower : high+
      zigbee.0
      39310	2024-06-21 11:47:55.943	info	Unable to disable LED, unsupported function.
      zigbee.0
      39310	2024-06-21 11:47:55.931	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      zigbee.0
      39310	2024-06-21 11:47:54.948	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      39310	2024-06-21 11:47:54.560	info	Starting Zigbee npm ...
      zigbee.0
      39310	2024-06-21 11:47:54.557	info	delete old Backup files. keep only last 10
      zigbee.0
      39310	2024-06-21 11:47:54.445	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.3, js-controller: 5.0.19
      zigbee.0
      4753	2024-06-21 11:47:46.521	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      4753	2024-06-21 11:47:46.518	info	terminating
      zigbee.0
      4753	2024-06-21 11:47:46.019	info	Zigbee: disabling joining new devices.
      zigbee.0
      4753	2024-06-21 11:47:46.016	info	cleaned everything up...
      zigbee.0
      4753	2024-06-21 11:47:46.013	info	Got terminate signal TERMINATE_YOURSELF
      zigbee.0
      4753	2024-06-21 11:46:09.757	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"44f8e99b6cafed11bfc63d4e71c9e8b5","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_44f8e99b6cafed11bfc63d4e71c9e8b5-if00-port0","vendorId":"10c4","productId":"ea60"}]
      zigbee.0
      4753	2024-06-21 11:45:59.322	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"44f8e99b6cafed11bfc63d4e71c9e8b5","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_44f8e99b6cafed11bfc63d4e71c9e8b5-if00-port0","vendorId":"10c4","productId":"ea60"}]
      zigbee.0
      4753	2024-06-21 11:44:43.939	info	Zigbee: stop joining
      zigbee.0
      4753	2024-06-21 11:43:42.652	info	Zigbee: allowing new devices to join.
      zigbee.0
      4753	2024-06-21 11:43:40.817	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"44f8e99b6cafed11bfc63d4e71c9e8b5","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_44f8e99b6cafed11bfc63d4e71c9e8b5-if00-port0","vendorId":"10c4","productId":"ea60"}]
      @Asgothian hier ein Screenshot von den Einstellungen.
      Ich muss dazu sagen, das der Adapter anfangs nicht lief und ich diesen via SSH geupdatet habe. Danach wurde er grün.
      P
      Philipp 1
    • SONOFF Zigbee 3.0 Dongle findet keine Gerät (Zigbee)
      habe einen SONOFF Zigbee 3.0 USB Dongle Plus,Zigbee Gateway TI CC2652P + CP2102N Zigbee USB Stick,Zigbee Hub für ZHA in Home Assistant or Zigbee2MQTT,Open HAB etc. gekauft. Diesen angeschlossen aber finde keine Geräte, habe es mit Tuya Steckdosen probiert aber auch mit einem Sonoff Temperatur Sensor. Adapter ist grün und der Log (siehe unten) zeigt auch keinen Fehler. Jemand eine Idee woran das liegen könnte? Oder fehlen noch Informationen meinerseits?
      Danke euch
      Philipp
      zigbee.0
      4753 2024-06-20 22:35:00.557 info Zigbee: stop joining
      zigbee.0
      4753 2024-06-20 22:33:59.295 info Zigbee: allowing new devices to join.
      zigbee.0
      4753 2024-06-20 22:33:57.229 info List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"44f8e99b6cafed11bfc63d4e71c9e8b5","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_44f8e99b6cafed11bfc63d4e71c9e8b5-if00-port0","vendorId":"10c4","productId":"ea60"}]
      zigbee.0
      4753 2024-06-20 22:33:39.997 info debug devices set to []
      zigbee.0
      4753 2024-06-20 22:33:39.625 info Zigbee started
      zigbee.0
      4753 2024-06-20 22:33:39.623 info Currently no devices.
      zigbee.0
      4753 2024-06-20 22:33:39.612 info --> transmitPower : high+
      zigbee.0
      4753 2024-06-20 22:33:39.589 info Unable to disable LED, unsupported function.
      zigbee.0
      4753 2024-06-20 22:33:39.579 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      zigbee.0
      4753 2024-06-20 22:33:38.710 info Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      4753 2024-06-20 22:33:38.322 info Starting Zigbee npm ...
      zigbee.0
      4753 2024-06-20 22:33:38.319 info delete old Backup files. keep only last 10
      zigbee.0
      4753 2024-06-20 22:33:38.206 info starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.3, js-controller: 5.0.19
      zigbee.0
      4690 2024-06-20 22:33:29.499 info terminating
      zigbee.0
      4690 2024-06-20 22:33:29.042 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      4690 2024-06-20 22:33:29.039 info terminating
      zigbee.0
      4690 2024-06-20 22:33:29.012 info Zigbee: disabling joining new devices.
      zigbee.0
      4690 2024-06-20 22:33:28.997 info cleaned everything up...
      zigbee.0
      4690 2024-06-20 22:33:28.993 info Got terminate signal TERMINATE_YOURSELF
      zigbee.0
      4690 2024-06-20 22:33:05.414 info List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"44f8e99b6cafed11bfc63d4e71c9e8b5","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_44f8e99b6cafed11bfc63d4e71c9e8b5-if00-port0","vendorId":"10c4","productId":"ea60"}]
      zigbee.0
      4690 2024-06-20 22:33:05.272 error getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      zigbee.0
      4690 2024-06-20 22:33:03.481 error Error herdsman start
      zigbee.0
      4690 2024-06-20 22:33:03.480 error Failed to start Zigbee
      zigbee.0
      4690 2024-06-20 22:33:03.478 error Starting zigbee-herdsman problem : "failed to connect to zigate adapter [object Object] after 5000ms"
      zigbee.0
      4690 2024-06-20 22:32:58.258 info Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      4690 2024-06-20 22:32:58.232 info Starting Zigbee npm ...
      zigbee.0
      4690 2024-06-20 22:32:58.228 info Try to reconnect. 1 attempts left
      P
      Philipp 1
