    2. pgemultra
    P
    • Posts 7
    pgemultra
    @pgemultra
    pgemultra Follow
    Latest posts made by pgemultra
    • RE: echarts start mit 404 Seite
      @pgemultra
                              v.2023-10-10
      model name      : Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.0.1
      Installation:           Docker
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
      Pending OS-Updates:     2
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                              /usr/bin/node           v18.18.2
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              /usr/bin/corepack       0.19.0
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      MEMORY:
      Mem:            3.9G        3.4G        270M         38M        558M        551M
      Swap:           4.5G        2.5G        2.1G
      Total:          8.5G        5.9G        2.3G
      Active iob-Instances:   20
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.12
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : buanet-iob
                                  -  enabled, port: 8081, bind: 192.168.1.30, run as: a
      dmin
      + system.adapter.web.0                    : web                   : buanet-iob
                                  -  enabled, port: 8082, bind: 192.168.1.30, run as: a
      dmin
        system.adapter.web.1                    : web                   : buanet-iob
                                  - disabled, port: 8086, bind: 192.168.1.30, run as: a
      dmin
      Objects:                8671
      States:                 9369
      Size of iob-Database:
      111M    /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/states.jsonl
      Nun der Summary.
      P
      pgemultra
      #Sorry!!!
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Hardware Vendor : Synology
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.0.1
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       12:55:03 up 20:08,  0 user,  load average: 1.37, 0.87, 0.57
      CPU threads: 4
      *** Time and Time Zones ***
      Wed Oct 25 10:55:03 UTC 2023
      Wed Oct 25 12:55:03 CEST 2023
      CEST +0200
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            3.9G        3.4G        236M         38M        582M        541M
               3766 M total memory
               3250 M used memory
                907 M active memory
                931 M inactive memory
                225 M free memory
                 20 M buffer memory
                534 M swap cache
               4307 M total swap
               2348 M used swap
               1959 M free swap
      *** FILESYSTEM ***
      Filesystem             Type   Size  Used Avail Use% Mounted on
      /dev/mapper/cachedev_2 btrfs   11T  1.8T  8.8T  17% /
      tmpfs                  tmpfs   64M     0   64M   0% /dev
      tmpfs                  tmpfs  1.9G     0  1.9G   0% /sys/fs/cgroup
      shm                    tmpfs   64M     0   64M   0% /dev/shm
      /dev/mapper/cachedev_2 btrfs   11T  1.8T  8.8T  17% /opt/iobroker
      tmpfs                  tmpfs  1.9G     0  1.9G   0% /proc/acpi
      tmpfs                  tmpfs  1.9G     0  1.9G   0% /proc/scsi
      tmpfs                  tmpfs  1.9G     0  1.9G   0% /sys/firmware
      sudo: unable to resolve host buanet-iob: Name or service not known
      [Wed Oct 25 09:11:24 2023]  [<ffffffff81210761>] ext4_filemap_fault+0x31/0x50
      TARGET             SOURCE
        FSTYPE OPTIONS
      /                  /dev/mapper/cachedev_2[/@syno/@docker/btrfs/subvolumes/e530488
      0cae6e1e8ee5b0c58127dd5a4d7d6173ab6d0fa9d3e43e9b801590f4a]       btrfs  rw,nodev,
      relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_all
      ocator,subvolid=516,subvol=/@syno/@docker/btrfs/subvolumes/e5304880cae6e1e8ee5b0c
      |-/opt/iobroker    /dev/mapper/cachedev_2[/@syno/@docker/volumes/2714d0d94b519291
      420c4fa9c5d165aaf5d81aea9c5a53662500c1dab68ee755/_data]          btrfs  rw,nodev,
      ocator,subvolid=257,subvol=/@syno
      |-/etc/resolv.conf /dev/mapper/cachedev_2[/@syno/@docker/containers/c5c00b4963c34
      be46aaeb7f0d2b89c0fefb46f21cd86b34e7756372da10f69ba/resolv.conf] btrfs  rw,nodev,
      |-/etc/hostname    /dev/mapper/cachedev_2[/@syno/@docker/containers/c5c00b4963c34
      be46aaeb7f0d2b89c0fefb46f21cd86b34e7756372da10f69ba/hostname]    btrfs  rw,nodev,
      `-/etc/hosts       /dev/mapper/cachedev_2[/@syno/@docker/containers/c5c00b4963c34
      be46aaeb7f0d2b89c0fefb46f21cd86b34e7756372da10f69ba/hosts]       btrfs  rw,nodev,
      /var:
      34M     /var/
      32M     /var/lib
      19M     /var/lib/apt/lists
      19M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      23M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      489M    /opt/iobroker/iobroker-data/
      312M    /opt/iobroker/iobroker-data/files
      66M     /opt/iobroker/iobroker-data/files/echarts.admin
      57M     /opt/iobroker/iobroker-data/files/echarts
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0a
      fecd.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.ma
      p
      18M     /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always
      prefer the links 'by-id':
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   1
      Adapter State
      s-timeandweather    : buanet-iob                               - disabled
        system.adapter.vis.0                    : vis                   : buanet-iob
                                  -  enabled
      dmin
      dmin
      + instance is alive
      dmin
      + system.adapter.backitup.0               : backitup              : buanet-iob
                                  -  enabled
      + system.adapter.cloud.0                  : cloud                 : buanet-iob
                                  -  enabled
        system.adapter.cloud.1                  : cloud                 : buanet-iob
                                  - disabled
        system.adapter.daswetter.0              : daswetter             : buanet-iob
                                  -  enabled
        system.adapter.discovery.0              : discovery             : buanet-iobrok
      er-2023                     - disabled
        system.adapter.echarts.0                : echarts               : buanet-iob
                                  - disabled
      + system.adapter.eusec.1                  : eusec                 : buanet-iob
                                  -  enabled
        system.adapter.flot.0                   : flot                  : buanet-iob
                                  - disabled
      + system.adapter.harmony.0                : harmony               : buanet-iob
                                  -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : buanet-iob
                                  -  enabled
      + system.adapter.hm-rpc.2                 : hm-rpc                : buanet-iob
                                  -  enabled, port: 0
      + system.adapter.hm-rpc.4                 : hm-rpc                : buanet-iob
                                  -  enabled, port: 0
      + system.adapter.homepilot20.0            : homepilot20           : buanet-iob
                                  -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : buanet-iob
                                  - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : buanet-iob
                                  - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : buanet-iob
                                  - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : buanet-iob
                                  - disabled
      + system.adapter.info.0                   : info                  : buanet-iob
                                  -  enabled
      + system.adapter.javascript.0             : javascript            : buanet-iob
                                  -  enabled
        system.adapter.mobile.0                 : mobile                : buanet-iob
                                  - disabled
      + system.adapter.onkyo.0                  : onkyo                 : buanet-iob
                                  -  enabled
      + system.adapter.shelly.0                 : shelly                : buanet-iob
                                  -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sma-em.0                 : sma-em                : buanet-iob
                                  -  enabled
      + system.adapter.socketio.0               : socketio              : buanet-iob
                                  -  enabled, port: 8084, bind: 192.168.1.30, run as: a
      dmin
      + system.adapter.sql.0                    : sql                   : buanet-iob
                                  -  enabled, port: 3307
      + system.adapter.stiebel-isg.0            : stiebel-isg           : buanet-iob
                                  -  enabled
      + system.adapter.telegram.0               : telegram              : buanet-iob
                                  -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : buanet-iob
                                  - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : buanet-iob
                                  -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : buanet-iob
                                  - disabled
        system.adapter.vis-metro.0              : vis-metro             : buanet-iob
                                  - disabled
        system.adapter.vis-timeandweather.0     : vi
      dmin
                                  -  enabled, port: 0
                                  -  enabled, port: 0
      dmin
      dmin
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "eusec"        : 1.1.2    , installed 1.1.2
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "icons-icons8" : 0.0.1    , installed 0.0.1
      Adapter    "icons-material-png": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "shelly"       : 6.4.5    , installed 6.4.5
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "stiebel-isg"  : 1.7.7    , installed 1.7.7
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Objects and States
      Objects:        8671
      States:         9369
      Hit:1 http://deb.debian.org/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 2
      *** Listening Ports ***
             1826545    -              Active Internet connections (only servers)
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       U
      ser       Inode      PID/Program name
      tcp        0      0 192.168.1.30:8084       0.0.0.0:*               LISTEN      1
      000       1836872    -
      tcp        0      0 127.0.0.1:33300         0.0.0.0:*               LISTEN      0
                166086     -
      tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0
                47190      -
      tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0
                33064      -
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0
                26518      -
      tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      5
      5         66264      -
      tcp        0      0 127.0.0.1:18617         0.0.0.0:*               LISTEN      0
                100370     -
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1
      000       1829184    -
      tcp        0      0 192.168.1.29:2010       0.0.0.0:*               LISTEN      1
      000       1826739    -
      tcp        0      0 0.0.0.0:6011            0.0.0.0:*               LISTEN      2
      54178     83263      -
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0
                41532      -
      tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0
                31333      -
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0
                44948      -
      tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0
                122123     -
      tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0
                45740      -
      tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0
                41075      -
      tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0
                114287     -
      tcp        0      0 0.0.0.0:5510            0.0.0.0:*               LISTEN      1
      92868     98026      -
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1
      000       1826924    -
      tcp        0      0 192.168.1.30:49160      0.0.0.0:*               LISTEN      0
                99467      -
      tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0
                41526      -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1
      000       1826917    -
      tcp        0      0 0.0.0.0:873             0.0.0.0:*               LISTEN      0
                45599      -
      tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0
                41528      -
      tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1
      000       1829797    -
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0
                44949      -
      tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0
                45760      -
      tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0
                41779      -
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0
                21928      -
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0
                41530      -
      tcp        0      0 192.168.1.30:8081       0.0.0.0:*               LISTEN      1
      000       5636854    -
      tcp        0      0 192.168.1.30:2001       0.0.0.0:*               LISTEN      1
      000
      udp        0      0 192.168.1.3
      tcp        0      0 192.168.1.29:50001      0.0.0.0:*               LISTEN      0
               82399      -
      tcp        0      0 192.168.1.30:8082       0.0.0.0:*               LISTEN      1
      000       1840223    -
      tcp        0      0 0.0.0.0:50002           0.0.0.0:*               LISTEN      0
                80883      -
      tcp        0      0 192.168.1.30:49170      0.0.0.0:*               LISTEN      2
      54178     83189      -
      tcp6       0      0 :::21                   :::*                    LISTEN      0
                47191      -
      tcp6       0      0 :::662                  :::*                    LISTEN      0
                34014      -
      tcp6       0      0 :::22                   :::*                    LISTEN      0
                26520      -
      tcp6       0      0 :::443                  :::*                    LISTEN      0
                41533      -
      tcp6       0      0 :::892                  :::*                    LISTEN      0
                31337      -
      tcp6       0      0 :::445                  :::*                    LISTEN      0
                44946      -
      tcp6       0      0 :::3261                 :::*                    LISTEN      0
                44017      -
      tcp6       0      0 :::3263                 :::*                    LISTEN      0
                44016      -
      tcp6       0      0 :::1984                 :::*                    LISTEN      1
      000       1829785    -
      tcp6       0      0 :::3264                 :::*                    LISTEN      0
                44018      -
      tcp6       0      0 :::3265                 :::*                    LISTEN      0
                48629      -
      tcp6       0      0 :::2049                 :::*                    LISTEN      0
                45751      -
      tcp6       0      0 :::6690                 :::*                    LISTEN      0
                114288     -
      tcp6       0      0 :::5510                 :::*                    LISTEN      1
      92868     98027      -
      tcp6       0      0 :::61991                :::*                    LISTEN      1
      000       1833015    -
      tcp6       0      0 :::5000                 :::*                    LISTEN      0
                41527      -
      tcp6       0      0 :::873                  :::*                    LISTEN      0
                45600      -
      tcp6       0      0 :::5001                 :::*                    LISTEN      0
                41529      -
      tcp6       0      0 :::8554                 :::*                    LISTEN      1
      000       1829789    -
      tcp6       0      0 :::139                  :::*                    LISTEN      0
                44947      -
      tcp6       0      0 :::4045                 :::*                    LISTEN      0
                45762      -
      tcp6       0      0 :::5357                 :::*                    LISTEN      0
                41780      -
      tcp6       0      0 :::111                  :::*                    LISTEN      0
                21931      -
      tcp6       0      0 :::80                   :::*                    LISTEN      0
                41531      -
      udp        0      0 127.0.0.1:59675         0.0.0.0:*                           2
      54178     83190      -
      udp        0      0 127.0.0.1:323           0.0.0.0:*                           0
                31493      -
      udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1
      000       1829790    -
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1
      000       1833016    -
      udp        0      0 192.168.1.29:55900      0.0.0.0:*                           0
                82401      -                  0:55900      0.0.0.0:*
              254178     83191      -
      udp        0      0 192.168.1.30:55901      0.0.0.0:*                           0
                99469      -
      udp        0      0 0.0.0.0:45665           0.0.0.0:*                           1
      000       1832572    -
      udp        0      0 0.0.0.0:662             0.0.0.0:*                           0
                33062      -
      udp        0      0 127.0.0.1:778           0.0.0.0:*                           0
                33034      -
      udp        0      0 0.0.0.0:892             0.0.0.0:*                           0
                31331      -
      udp        0      0 0.0.0.0:56277           0.0.0.0:*                           0
                34099      -
      udp        0      0 0.0.0.0:40050           0.0.0.0:*                           1
      000       2067110    -
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0
                34097      -
      udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1
      000       1836675    -
      udp        0      0 0.0.0.0:3702            0.0.0.0:*                           9
      9         31695      -
      9         31693      -
      udp        0      0 0.0.0.0:46779           0.0.0.0:*                           0
                66387      -
      udp        0      0 127.0.0.1:50920         0.0.0.0:*                           0
                82400      -
      udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0
                26415      -
      udp        0      0 0.0.0.0:9998            0.0.0.0:*
                26414      -
      udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0
                26413      -
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0
                99470      -
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           2
      54178     83192      -
                82402      -
                43364      -
      udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0
                47289      -
      udp        0      0 0.0.0.0:55256           0.0.0.0:*                           1
      000       1946958    -
      udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0
                45750      -
      udp        0      0 127.0.0.1:38993         0.0.0.0:*                           0
                99468      -
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0
                20026      -
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0
                31495      -
      udp        0      0 192.168.1.255:137       0.0.0.0:*                           0
                32687      -
      udp        0      0 192.168.1.29:137        0.0.0.0:*                           0
                32686      -
                32683      -
      udp        0      0 192.168.1.30:137        0.0.0.0:*                           0
                32682      -
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0
                32656      -
      udp        0      0 192.168.1.255:138       0.0.0.0:*                           0
                32689      -
      udp        0      0 192.168.1.29:138        0.0.0.0:*                           0
                32688      -
                32685      -
      udp        0      0 192.168.1.30:138        0.0.0.0:*                           0
                32684      -
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0
                32657      -
      udp        0      0 0.0.0.0:49298           0.0.0.0:*                           0
                21927      -
      udp        0      0 127.0.0.1:161           0.0.0.0:*                           0
                41074      -
      udp6       0      0 ::1:323                 :::*                                0
                31494      -
      udp6       0      0 :::662                  :::*                                0
                33066      -
      udp6       0      0 :::892                  :::*                                0
                31335      -
      udp6       0      0 :::60515                :::*                                0
                21930      -
      udp6       0      0 :::5353                 :::*                                0
                34098      -
      udp6       0      0 :::34245                :::*                                0
                34100      -
      udp6       0      0 :::3702                 :::*                                9
      9         31699      -
      9         31697      -
      udp6       0      0 :::4045                 :::*                                0
                45761      -
      udp6       0      0 :::2049                 :::*                                0
                45752      -
      udp6       0      0 :::111                  :::*                                0
                21929      -
      udp6       0      0 :::123                  :::*                                0
                31496      -
      udp6       0      0 :::8443                 :::*                                1
      000       1829798    -
      1  - info: ho2023-10-25 12:55:39.944  - info: homepilot20.0 (464) State value to
      set for "homepilot20.0.Scene.5009.isExecutable" has to be type "boolean" but rece
      ived type "number"
      2023-10-25 12:55:39.945  - info: homepilot20.0 (464) State value to set for "home
      pilot20.0.Scene.5010.active" has to be type "boolean" but received type "number"
      pilot20.0.Scene.5010.isExecutable" has to be type "boolean" but received type "nu
      mber"
      pilot20.0.Scene.5013.active" has to be type "boolean" but received type "number"
      pilot20.0.Scene.5013.isExecutable" has to be type "boolean" but received type "nu
      mber"
      2023-10-25 12:55:39.946  - info: homepilot20.0 (464) State value to set for "home
      pilot20.0.Scene.5015.active" has to be type "boolean" but received type "number"
      pilot20.0.Scene.5015.isExecutable" has to be type "boolean" but received type "nu
      mber"
      pilot20.0.Scene.5017.active" has to be type "boolean" but received type "number"
      pilot20.0.Scene.5017.isExecutable" has to be type "boolean" but received type "nu
      mber"
      mber"
      mber"
      pilot20.0.Scene.5020.active" has to be type "boolean" but received type "number"
      2023-10-25 12:55:39.947  - info: homepilot20.0 (464) State value to set for "home
      pilot20.0.Scene.5020.isExecutable" has to be type "boolean" but received type "nu
      mber"
      pilot20.0.Scene.5021.active" has to be type "boolean" but received type "number"
      pilot20.0.Scene.5021.isExecutable" has to be type "boolean" but received type "nu
      mber"
      2023-10-25 12:55:39.948  - info: homepilot20.0 (464) State value to set for "home
      pilot20.0.Scene.5022.active" has to be type "boolean" but received type "number"
      pilot20.0.Scene.5022.isExecutable" has to be type "boolean" but received type "nu
      mber"
      2023-10-25 12:55:39.989  - info: homepilot20.0 (464) State value to set for "home
      pilot20.0.Scene.5023.active" has to be type "boolean" but received type "number"
      2023-10-25 12:55:39.990  - info: homepilot20.0 (464) State value to set for "home
      pilot20.0.Scene.5023.isExecutable" has to be type "boolean" but received type "nu
      mber"
      pilot20.0.Scene.5024.active" has to be type "boolean" but received type "number"
      pilot20.0.Scene.5024.isExecutable" has to be type "boolean" but received type "nu
      Copy text starting here:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.0.1
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
      CEST +0200
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
               3766 M total memory
               3250 M used memory
                907 M active memory
                225 M free memory
                 20 M buffer memory
                534 M swap cache
               4307 M total swap
               2348 M used swap
               1959 M free swap
      *** FILESYSTEM ***
      TARGET             SOURCE
        FSTYPE OPTIONS
      /var:
      34M     /var/
      32M     /var/lib
      19M     /var/lib/apt
      13M     /var/lib/dpkg
      fecd.js.map
      p
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
                                  -  enabled
      dmin
      dmin
      + instance is alive
      dmin
                                  -  enabled
                                  -  enabled
                                  - disabled
                                  -  enabled
      er-2023                     - disabled
                                  - disabled
                                  -  enabled
                                  - disabled
                                  -  enabled
                                  -  enabled
                                  -  enabled, port: 0
                                  -  enabled, port: 0
                                  -  enabled
                                  - disabled
                                  - disabled
                                  - disabled
                                  - disabled
                                  -  enabled
                                  -  enabled
                                  - disabled
                                  -  enabled
                                  -  enabled
      dmin
                                  -  enabled
                                  - disabled
                                  -  enabled
                                  - disabled
                                  - disabled
      dmin
                                  -  enabled, port: 0
                                  -  enabled, port: 0
      dmin
      dmin
      Objects and States
      Objects:        8671
      States:         9369
      Pending Updates: 2
      Teil 2 folgt
      P
      pgemultra
                              v.2023-10-10
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.0.1
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
      MEMORY:
      Mem:            3.9G        3.4G        289M         37M        571M        584M
      Swap:           4.5G        2.5G        2.0G
      Active iob-Instances:   21
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      dmin
      dmin
      dmin
      Objects:                8670
      States:                 9369
      20M     /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      Anbei das Ergebnis.
      Ich habe die Instanz echart neu installiert. nun fehlt noch das Bild des Icon im Tab-Menu.
      Können Sie etwas identifizieren?
      P
      pgemultra
      Danke, hat leider keine Wirkung erzielt.
      P
      pgemultra
    • echarts start mit 404 Seite
      Hallo Zusammen,
      nach dem Umzug auf Synology NAS mit Docker liefert echarts : 404 Oops! The page you're looking for can't be found. 😔
      File tab.html not found
      und nicht die Startseite zum editieren der Charts. Mit der Bitte um Hilfe und Tipps.
      Der Adapter 1.5.1 ist installiert. Es existieren keine Hinweise im log.
      P
      pgemultra
    • RE: Adapter Aufzählungen Stift Zeichen fehlt
      Hallo Rainer,
      ich habe die enums neu geladen, das editiersymbol "stift" fehlt.
      Oder liegt es an meinem Verständnis der Beschreibung und des editieren der enums.
      P
      pgemultra
    • Adapter Aufzählungen Stift Zeichen fehlt
      Gem. Beschreibung soll im Reiter Aufzählungen 4 Symbole rechts existieren, Links das Stift Symbol zu editieren, dann hinzufügen,löschen, Eigenschaften.
      Bei mir nicht vorhanden, wer kann mir helfen?
      Ein editieren der Objekte in den Aufzählung ist somit nicht machbar! Oder gibt es eine Option.
      VG Peter
      P
      pgemultra
