@asgothian ich bekomme folgende Meldungen wenn ich temperature_calibration an Thermostat sende
v5.1.25
012
Log-Größe: 32.9 KB
Zeit
Nachricht
zigbee.0
	2021-11-04 00:26:03.916	debug	Non-pingable device 0x50325ffffe6314aa TS0601 was last seen '127.197' seconds ago.
zigbee.0
	2021-11-04 00:25:03.916	debug	Non-pingable device 0x50325ffffe6314aa TS0601 was last seen '67.197' seconds ago.
zigbee.0
	2021-11-03 23:24:03.915	debug	Non-pingable device 0x50325ffffe6314aa TS0601 was last seen '7.196' seconds ago.
zigbee.0
	2021-11-03 23:23:56.750	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.local_temperature_calibration:{"val":"0.0","ack":true,"ts":1635981836743,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836743}
zigbee.0
	2021-11-03 23:23:56.748	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.msg_from_zigbee:{"val":"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":7,\"dp\":27,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,0]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":50,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1635981836743,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836743}
zigbee.0
	2021-11-03 23:23:56.746	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.link_quality:{"val":141,"ack":true,"ts":1635981836743,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836640}
zigbee.0
	2021-11-03 23:23:56.742	info	State value to set for "zigbee.0.50325ffffe6314aa.local_temperature_calibration" has to be type "number" but received type "string"
zigbee.0
	2021-11-03 23:23:56.734	warn	ELEVATED publishToState: value generated '"0.0"' from device 50325ffffe6314aa for 'Offset to be used in the local_temperature'
zigbee.0
	2021-11-03 23:23:56.733	warn	ELEVATED publishToState: message received '{"local_temperature_calibration":"0.0"}' from device 50325ffffe6314aa type 'TV01-ZB'
zigbee.0
	2021-11-03 23:23:56.732	debug	Publish {"local_temperature_calibration":"0.0"} to "50325ffffe6314aa"
zigbee.0
	2021-11-03 23:23:56.732	warn	ELEVATED publishToState: value generated '"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":7,\"dp\":27,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,0]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":50,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 50325ffffe6314aa for 'Message from Zigbee'
zigbee.0
	2021-11-03 23:23:56.731	warn	ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":7,\"dp\":27,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,0]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":50,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 50325ffffe6314aa type 'TV01-ZB'
zigbee.0
	2021-11-03 23:23:56.731	warn	ELEVATED publishToState: value generated '141' from device 50325ffffe6314aa for 'Link quality'
zigbee.0
	2021-11-03 23:23:56.730	warn	ELEVATED publishToState: message received '{"linkquality":141}' from device 50325ffffe6314aa type 'TV01-ZB'
zigbee.0
	2021-11-03 23:23:56.721	debug	Type commandGetData device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836719,"_linkquality":141},"mapped":{"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_e9ba97vf"},{"modelID":"TS0601","manufacturerName":"_TZE200_hue3yfsn"}],"model":"TV01-ZB","vendor":"Moes","description":"Thermostat radiator valve","fromZigbee":[{"cluster":"manuSpecificTuya","type":["commandGetData","commandSetDataResponse","raw"]},{"cluster":"manuSpecificTuya","type":["commandSetTimeRequest"]}],"toZigbee":[{"key":["system_mode","window_detection","frost_detection","child_lock","current_heating_setpoint","local_temperature_calibration","holiday_temperature","comfort_temperature","eco_temperature","boost_mode","open_window_temperature","heating_stop","preset"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"switch","features":[{"type":"binary","name":"state","property":"window_detection","access":3,"value_on":"ON","value_off":"OFF","description":"Enables/disables window detection on the device","value_toggle":"TOGGLE"}]},{"type":"binary","name":"frost_detection","property":"frost_detection","access":3,"value_on":true,"value_off":false,"description":"Enables/disables frost detection on the device"},{"type":"binary","name":"heating_stop","property":"heating_stop","access":3,"value_on":true,"value_off":false,"description":"Stop heating"},{"type":"numeric","name":"holiday_temperature","property":"holiday_temperature","access":3,"description":"Holiday mode temperature"},{"type":"numeric","name":"comfort_temperature","property":"comfort_temperature","access":3,"description":"Comfort mode temperature"},{"type":"numeric","name":"eco_temperature","property":"eco_temperature","access":3,"description":"Eco mode temperature"},{"type":"numeric","name":"open_window_temperature","property":"open_window_temperature","access":3,"description":"Open window mode temperature"},{"type":"numeric","name":"boost_heating_countdown","property":"boost_heating_countdown","access":1,"description":"Boost heating countdown"},{"type":"numeric","name":"error_status","property":"error_status","access":1,"description":"Error status"},{"type":"climate","features":[{"type":"numeric","name":"current_heating_setpoint","property":"current_heating_setpoint","access":3,"value_min":5,"value_max":29.5,"value_step":1,"unit":"°C","description":"Temperature setpoint"},{"type":"numeric","name":"local_temperature","property":"local_temperature","access":1,"unit":"°C","description":"Current temperature measured on the device"},{"type":"numeric","name":"local_temperature_calibration","property":"local_temperature_calibration","access":3,"unit":"°C","description":"Offset to be used in the local_temperature"},{"type":"enum","name":"system_mode","property":"system_mode","access":3,"values":["off","heat","auto"],"description":"Mode of this device"},{"type":"enum","name":"preset","property":"preset","access":3,"values":["auto","manual","holiday"],"description":"Mode of this device (similar to system_mode)"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[]},"name":"0x50325ffffe6314aa"} incoming event: {"type":"commandGetData","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836719,"_linkquality":141},"endpoint":"[Circular]","data":{"status":0,"transid":7,"dp":27,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,0]}},"linkquality":141,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":50,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
zigbee.0
	2021-11-03 23:23:56.720	debug	Received Zigbee message from '0x50325ffffe6314aa', type 'commandGetData', cluster 'manuSpecificTuya', data '{"status":0,"transid":7,"dp":27,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,0]}}' from endpoint 1 with groupID 0
zigbee.0
	2021-11-03 23:23:56.719	debug	handleMessage. {"type":"commandGetData","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836719,"_linkquality":141},"endpoint":"[Circular]","data":{"status":0,"transid":7,"dp":27,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,0]}},"linkquality":141,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":50,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
zigbee.0
	2021-11-03 23:23:56.693	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.local_temperature:{"val":"21.3","ack":true,"ts":1635981836691,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836691}
zigbee.0
	2021-11-03 23:23:56.687	info	State value to set for "zigbee.0.50325ffffe6314aa.local_temperature" has to be type "number" but received type "string"
zigbee.0
	2021-11-03 23:23:56.649	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.msg_from_zigbee:{"val":"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":6,\"dp\":24,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,213]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":49,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1635981836641,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836641}
zigbee.0
	2021-11-03 23:23:56.646	silly	States user redis pmessage zigbee.0.*/zigbee.0.50325ffffe6314aa.link_quality:{"val":141,"ack":true,"ts":1635981836640,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1635981836640}
zigbee.0
	2021-11-03 23:23:56.623	warn	ELEVATED publishToState: value generated '"21.3"' from device 50325ffffe6314aa for 'Current temperature measured on the device'
zigbee.0
	2021-11-03 23:23:56.622	warn	ELEVATED publishToState: message received '{"local_temperature":"21.3"}' from device 50325ffffe6314aa type 'TV01-ZB'
zigbee.0
	2021-11-03 23:23:56.619	debug	Publish {"local_temperature":"21.3"} to "50325ffffe6314aa"
zigbee.0
	2021-11-03 23:23:56.618	warn	ELEVATED publishToState: value generated '"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":6,\"dp\":24,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,213]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":49,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 50325ffffe6314aa for 'Message from Zigbee'
zigbee.0
	2021-11-03 23:23:56.617	warn	ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"commandGetData\",\"data\":{\"status\":0,\"transid\":6,\"dp\":24,\"datatype\":2,\"fn\":0,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,213]}},\"linkquality\":141,\"groupID\":0,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":49,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 50325ffffe6314aa type 'TV01-ZB'
zigbee.0
	2021-11-03 23:23:56.616	warn	ELEVATED publishToState: value generated '141' from device 50325ffffe6314aa for 'Link quality'
zigbee.0
	2021-11-03 23:23:56.615	warn	ELEVATED publishToState: message received '{"linkquality":141}' from device 50325ffffe6314aa type 'TV01-ZB'
zigbee.0
	2021-11-03 23:23:56.596	debug	Type commandGetData device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836591,"_linkquality":141},"mapped":{"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_e9ba97vf"},{"modelID":"TS0601","manufacturerName":"_TZE200_hue3yfsn"}],"model":"TV01-ZB","vendor":"Moes","description":"Thermostat radiator valve","fromZigbee":[{"cluster":"manuSpecificTuya","type":["commandGetData","commandSetDataResponse","raw"]},{"cluster":"manuSpecificTuya","type":["commandSetTimeRequest"]}],"toZigbee":[{"key":["system_mode","window_detection","frost_detection","child_lock","current_heating_setpoint","local_temperature_calibration","holiday_temperature","comfort_temperature","eco_temperature","boost_mode","open_window_temperature","heating_stop","preset"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"switch","features":[{"type":"binary","name":"state","property":"window_detection","access":3,"value_on":"ON","value_off":"OFF","description":"Enables/disables window detection on the device","value_toggle":"TOGGLE"}]},{"type":"binary","name":"frost_detection","property":"frost_detection","access":3,"value_on":true,"value_off":false,"description":"Enables/disables frost detection on the device"},{"type":"binary","name":"heating_stop","property":"heating_stop","access":3,"value_on":true,"value_off":false,"description":"Stop heating"},{"type":"numeric","name":"holiday_temperature","property":"holiday_temperature","access":3,"description":"Holiday mode temperature"},{"type":"numeric","name":"comfort_temperature","property":"comfort_temperature","access":3,"description":"Comfort mode temperature"},{"type":"numeric","name":"eco_temperature","property":"eco_temperature","access":3,"description":"Eco mode temperature"},{"type":"numeric","name":"open_window_temperature","property":"open_window_temperature","access":3,"description":"Open window mode temperature"},{"type":"numeric","name":"boost_heating_countdown","property":"boost_heating_countdown","access":1,"description":"Boost heating countdown"},{"type":"numeric","name":"error_status","property":"error_status","access":1,"description":"Error status"},{"type":"climate","features":[{"type":"numeric","name":"current_heating_setpoint","property":"current_heating_setpoint","access":3,"value_min":5,"value_max":29.5,"value_step":1,"unit":"°C","description":"Temperature setpoint"},{"type":"numeric","name":"local_temperature","property":"local_temperature","access":1,"unit":"°C","description":"Current temperature measured on the device"},{"type":"numeric","name":"local_temperature_calibration","property":"local_temperature_calibration","access":3,"unit":"°C","description":"Offset to be used in the local_temperature"},{"type":"enum","name":"system_mode","property":"system_mode","access":3,"values":["off","heat","auto"],"description":"Mode of this device"},{"type":"enum","name":"preset","property":"preset","access":3,"values":["auto","manual","holiday"],"description":"Mode of this device (similar to system_mode)"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[]},"name":"0x50325ffffe6314aa"} incoming event: {"type":"commandGetData","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836591,"_linkquality":141},"endpoint":"[Circular]","data":{"status":0,"transid":6,"dp":24,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,213]}},"linkquality":141,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":49,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
zigbee.0
	2021-11-03 23:23:56.595	debug	Received Zigbee message from '0x50325ffffe6314aa', type 'commandGetData', cluster 'manuSpecificTuya', data '{"status":0,"transid":6,"dp":24,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,213]}}' from endpoint 1 with groupID 0
zigbee.0
	2021-11-03 23:23:56.592	debug	handleMessage. {"type":"commandGetData","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x50325ffffe6314aa","_networkAddress":32413,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_hue3yfsn","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1635981836591,"_linkquality":141},"endpoint":"[Circular]","data":{"status":0,"transid":6,"dp":24,"datatype":2,"fn":0,"data":{"type":"Buffer","data":[0,0,0,213]}},"linkquality":141,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":49,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
zigbee.0
	2021-11-03 23:23:55.384	debug	target: {"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":32413,"deviceIeeeAddress":"0x50325ffffe6314aa","clusters":{"genBasic":{"attributes":{"modelId":"TS0601","manufacturerName":"_TZE200_hue3yfsn","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}
