    2. SunkHD
    • Topics 5
    • Posts 37
    SunkHD
    @SunkHD
    32
    37
    SunkHD Follow
    Latest posts made by SunkHD
    • RE: Js-Controller lässt sich nicht auf 7.x upgraden
      @thomas-braun erledigt. jetzt backup durchführen?
      posted in Pflege des Betriebssystems
      SunkHD
      SunkHD
      @thomas-braun hab jetzt nochmal versucht Js-Controller 7.X zu installieren, diesmal hat es geklappt.
      SunkHD
      SunkHD
      ioBroker nodejs fixer 2025-02-23
      You requested to install latest version from nodejs v20 tree.
      Your current setup is:
      /usr/bin/nodejs 	v22.14.0
      /usr/bin/node 		v22.14.0
      /usr/bin/npm 		11.1.0
      /usr/bin/npx 		11.1.0
      /usr/bin/corepack 	0.31.0
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 22.14.0-1nodesource1
        Candidate: 22.14.0-1nodesource1
        Version table:
       *** 22.14.0-1nodesource1 100
              100 /var/lib/dpkg/status
           20.18.3-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
           20.18.2-1nodesource1 600
           20.18.1-1nodesource1 600
           20.18.0-1nodesource1 600
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2+rpi1 500
              500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v22.14.0. Do you want to install latest version from nodejs v.20 tree?
      Press <y> to continue or any other key to quit
      Trying to fix your installation now. Please be patient.
      rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
      Waiting for ioBroker to shut down - Give me a minute...
      Removing dfsg-nodejs
      *** These repos are active on your system:
      Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
      Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:3 https://download.docker.com/linux/raspbian bookworm InRelease
      Hit:4 https://repo.homebridge.io stable InRelease
      Reading package lists... Done
      W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      W: Skipping acquire of configured file 'non-free-firmware/binary-armhf/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian bookworm InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
      W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en' as repository 'http://raspbian.raspberrypi.org/raspbian bookworm InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
      W: Skipping acquire of configured file 'non-free-firmware/dep11/Components-armhf.yml' as repository 'http://raspbian.raspberrypi.org/raspbian bookworm InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Get:5 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
      Get:6 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [10.6 kB]
      Fetched 22.8 kB in 1s (16.8 kB/s)
      Installing nodejs now!
      Installing the nodejs!
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
      SunkHD
      SunkHD
      @thomas-braun okay verstehe. (das upgrade lief leider schon bevor du geantwortet hattest)
      SunkHD
      SunkHD
      hab das update durchgeführt. Version bleibt jedoch auf 22
      pi@raspberrypi:~ $ nodejs -v
      v22.14.0
      SunkHD
      SunkHD
      war ein bissel voreilig, das update von Bookworm ist jetzt fertig.
      pi@raspberrypi:~ $ cat /etc/debian_version
      12.9
      SunkHD
      SunkHD
      @thomas-braun okay
      SunkHD
      SunkHD
      @thomas-braun said in Js-Controller lässt sich nicht auf 7.x upgraden:
      cd
      ├─┬ iobroker.ham@5.3.1 (git+ssh://git@github.com/ioBroker/ioBroker.ham.git#6a73ba47abc87c927187f2b9354e2edd028cf2e5)
      │ └─┬ homebridge-ring@11.7.1
      │   └── ring-client-api@11.7.1
      └─┬ iobroker.ring@3.2.2
        └── ring-client-api@11.7.3
      kommt vom homebridge Adapter
      SunkHD
      SunkHD
      @thomas-braun möchte ich ja. aber kann ich mein Backup vom alten System einspielen? das wäre echt Arbeit alles wieder zum laufen zu bringen
      SunkHD
      SunkHD
      @arteck ne xD hab ich erst überlesen, deswegen mein Edit ganz unten. Update läuft gerade noch
      SunkHD
      SunkHD
