@fastfoot
der Erste Teil mit dem Schalten des Shellys läuft schon mal super! Oder fast
Ich hab einen "Fehler" den ich nicht nachvollziehen kann:
oder
<variables>
<variable type="" id="smfipXSz7c$2VGi]fdHq">user</variable>
</variables>
<block type="on_ext" id="`r[e|Zre^i1M[,4#LQb8" x="13" y="12">
<value name="OID0">
<shadow type="field_oid" id="p{9:o5Vc#A]O|ijP.6kH">
<field name="oid">mqtt.0.rfid.leser.send</field>
</shadow>
</value>
<statement name="STATEMENT">
<block type="variables_set" id="9zW]qjf1.oJ:*r(`Snhp">
<field name="VAR" id="smfipXSz7c$2VGi]fdHq" variabletype="">user</field>
<value name="VALUE">
<block type="get_attr" id="#OJnwsvskALVr7ICmA7E">
<value name="PATH">
<shadow type="text" id="?D?b78:-+x}`/|k;DtM;">
<field name="TEXT">username</field>
</shadow>
</value>
<value name="OBJECT">
<block type="on_source" id="]:H5pqerc{6Gyrkz1+P:">
</block>
</value>
</block>
</value>
<next>
<block type="controls_if" id="5Z}lU*NMnk]zNAgzO*W7">
<value name="IF0">
<block type="logic_compare" id="CgTx-f8!A72aCn4qgw!4">
<field name="OP">EQ</field>
<value name="A">
<block type="variables_get" id="82(vIy)iBDo#^9g7zX`h">
</block>
</value>
<value name="B">
<block type="text" id="+4Hvp,mBGMnKJVnTj_DY">
<field name="TEXT">Felix_Merk</field>
</block>
</value>
</block>
</value>
<statement name="DO0">
<block type="controls_if" id="5atN0y`}7v.,-CWFc{7+">
<value name="IF0">
<block type="logic_compare" id="t}Prj}J%L_3NhJWc3RFc">
<value name="A">
<block type="get_value" id="|2.+HO)ztM2;q[q!I.H6">
<field name="OID">shelly.0.SHSW-1#F4282B#2.Relay0.Switch</field>
</block>
</value>
<value name="B">
<block type="logic_boolean" id="x-jP*Fd?NV+Sp|hhl_1N">
</block>
</value>
</block>
</value>
<block type="control" id="[0Pd9wpD:kB|qifUBtvQ">
<block type="logic_boolean" id="VR-P7mpXpzO{e0)})fm)">
</block>
</value>
</block>
</statement>
<statement name="ELSE">
<block type="control" id="i9zorrxcYyWgt:Owx]S/">
<block type="logic_boolean" id="}]GVlr$BK-~JwT1~|tv0">
</block>
</value>
</block>
</statement>
</block>
</statement>
</block>
</next>
</block>
</statement>
</block>
</xml>
BlocklyJavascriptTypeScript
Protokoll
Ausgewählte Blöcke exportieren
<variables>
</variables>
<value name="OID0">
</shadow>
</value>
<value name="PATH">
</shadow>
</value>
</block>
</value>
</block>
</value>
<next>
<value name="IF0">
<value name="A">
</block>
</value>
<value name="B">
</block>
</value>
</block>
</value>
<block type="toggle" id="O^Dz6KQS3aV=x*=SUJHd">
</block>
</statement>
</block>
</next>
</block>
</statement>
</block>
</xml>
<variables>
</variables>
<value name="OID0">
</shadow>
</value>
<value name="PATH">
</shadow>
</value>
</block>
</value>
</block>
</value>
<next>
<value name="IF0">
<value name="A">
</block>
</value>
<value name="B">
</block>
</value>
</block>
</value>
</block>
</statement>
</block>
</next>
</block>
</statement>
</block>
</xml>
Wenn der shelly aus ist (false) und ich hebe den RFID tag ran, geht das Licht an, wie es soll. Wenn ich ich den Tag aber nochmal hinhalte passiert nichts. Erst beim zweiten mal hinhalten (Zeit spielt keine Rolle) geht das Licht wieder aus.
Lässt sich beliebig oft wiederholen.... beim ausschalten muss ich immer zweimal hinhalten.
An was liegt das?
Liebe Grüße
