    2. markuslommer
    markuslommer
    @markuslommer
    markuslommer Follow
    Latest posts made by markuslommer
    • RE: [HowTo] ioBroker unter Docker auf Synology DiskStation
      @andre Eben habe ich nochmal den container gekilled, das Verzeichnis geleert und neu gestartet:
      Folgendes Log erscheint. Nach ca 10 Minuten scheint er nun fertig zu sein und ist erreichbar. Damit bin ich einen großen Schritt weiter. Dankeschön!
      ---------------     2020-06-29 22:08:07      ---------------
      -----       Welcome to your ioBroker-container!        -----
      -----          Startupscript is now running.           -----
      -----                Please be patient!                -----
      -----              Debugging information               -----
      -----                      System                      -----
      -----               arch:      x86_64                  -----
      -----                     Versions                     -----
      -----               image:     v4.2.4beta              -----
      -----               node:      v12.18.1                -----
      -----               npm:       6.14.5                  -----
      -----                       ENV                        -----
      -----               AVAHI:     false                   -----
      -----               PACKAGES:  nano                    -----
      -----               SETGID:    1000                    -----
      -----               SETUID:    1000                    -----
      -----         Step 1 of 5: Preparing container         -----
      Installing additional packages is set by ENV.
      The following packages will be installed: nano...
      Done.
      -----   Step 2 of 5: Detecting ioBroker installation   -----
      There is no data detected in /opt/iobroker. Restoring initial ioBroker installation...
      Done.
      -----   Step 3 of 5: Checking ioBroker installation    -----
      (Re)Setting folder permissions (This might take a while! Please be patient!)...
      Done.
      Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
      Done.
      Looks like this is a new and empty installation of ioBroker.
      Hostname needs to be updated to  iobroker...
      The host for instance "system.adapter.admin.0" was changed from "b81caf8b79fd" to "iobroker".
      The host for instance "system.adapter.discovery.0" was changed from "b81caf8b79fd" to "iobroker".
      The host for instance "system.adapter.info.0" was changed from "b81caf8b79fd" to "iobroker".
      Done.
      -----      Step 4 of 5: Applying special settings      -----
      Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      For more information take a look at readme.md on Github!
      -----          Step 5 of 5: ioBroker startup           -----
      Starting ioBroker...
      host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
      host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
      host.iobroker check instance "system.adapter.info.0" for host "iobroker"
      Send diag info: {"uuid":"7abd3182-d399-f7bd-da19-9550d8babede","language":"","country":"","hosts":[{"version":"3.1.5","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.18.1","arch":"x64","adapters":{"admin":{"version":"4.0.10","platform":"Javascript/Node.js"},"discovery":{"version":"2.3.5","platform":"Javascript/Node.js"},"info":{"version":"1.7.2","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"Intel(R) Celeron(R) CPU J3355 @ 2.00GHz","cpus":2,"mem":1916919808,"ostype":"Linux","city":""}
      hash changed or no sources cached => force download of new sources
      Send diag info: {"uuid":"7abd3182-d399-f7bd-da19-9550d8babede","language":"de","country":"","hosts":[{"version":"3.1.5","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.18.1","arch":"x64","adapters":{"admin":{"version":"4.0.10","platform":"Javascript/Node.js"},"discovery":{"version":"2.3.5","platform":"Javascript/Node.js"},"info":{"version":"1.7.2","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"Intel(R) Celeron(R) CPU J3355 @ 2.00GHz","cpus":2,"mem":1916919808,"ostype":"Linux","city":""}
      ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      markuslommer
      @andre es handelt sich um eine clean install nach deiner Anleitung. Zuvor hatte ich die Anleitung mit ioBroker direkt in dokker versucht, diese threads aber wieder gelöscht, nachdem ich gelesen hatte, dass die Anleitung outdated war.
      markuslommer
      Hallo Andre,
      hier nun das komplette Log, wie im v3 Anleitungsthread requested:
      Nach Ausführung ist die Instanz unter ihrer IP Adresse nicht erreichbar.
      Kannst du daraus erkennen, wo das Problem liegt?
      Viele Grüße
      Markus
      ---------------     2020-06-27 08:04:44      ---------------
      -----                      System                      -----
      -----                       ENV                        -----
      debconf: unable to initialize frontend: Dialog
      debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
      debconf: falling back to frontend: Readline
      debconf: unable to initialize frontend: Readline
      debconf: (This frontend requires a controlling tty.)
      debconf: falling back to frontend: Teletype
      dpkg-preconfigure: unable to re-open stdin:
      Vormals nicht ausgewähltes Paket nano wird gewählt.
      (Lese Datenbank ...
      (Lese Datenbank ... 5%
      (Lese Datenbank ... 10%
      (Lese Datenbank ... 15%
      (Lese Datenbank ... 20%
      (Lese Datenbank ... 25%
      (Lese Datenbank ... 30%
      (Lese Datenbank ... 35%
      (Lese Datenbank ... 40%
      (Lese Datenbank ... 45%
      (Lese Datenbank ... 50%
      (Lese Datenbank ... 55%
      (Lese Datenbank ... 60%
      (Lese Datenbank ... 65%
      (Lese Datenbank ... 70%
      (Lese Datenbank ... 75%
      (Lese Datenbank ... 80%
      (Lese Datenbank ... 85%
      (Lese Datenbank ... 90%
      (Lese Datenbank ... 95%
      (Lese Datenbank ... 100%
      (Lese Datenbank ... 25565 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../archives/nano_3.2-3_amd64.deb ...
      Entpacken von nano (3.2-3) ...
      nano (3.2-3) wird eingerichtet ...
      update-alternatives: /bin/nano wird verwendet, um /usr/bin/editor (editor) im automatischen Modus bereitzustellen
      update-alternatives: /bin/nano wird verwendet, um /usr/bin/pico (pico) im automatischen Modus bereitzustellen
      Done.
      Existing installation of ioBroker detected in /opt/iobroker.
      Done.
      Done.
      Hostname in ioBroker does not match the hostname of this container.
      Updating hostname to  iobroker...
      A host with the name "iobroker" already exists!
      Done.
      host.iobroker check instance "system.adapter.admin.0" for host "a2e2a3097bbf"
      host.iobroker check instance "system.adapter.discovery.0" for host "a2e2a3097bbf"
      host.iobroker check instance "system.adapter.info.0" for host "a2e2a3097bbf"
      Hier gehts zur Hilfe.
      markuslommer
