    2. LinusJ
    L
    • Posts 10
    LinusJ
    @LinusJ
    15
    LinusJ Follow
    Latest posts made by LinusJ
    • RE: RPI2 Adapter steuert GPIOs nicht mehr
      @thomas-braun OMG DANKE
      Er geht wieder.
      Der ist nähmlich wichtig, weil der ioBroker(raspberry) in der Garage ist und an den GPIOs Relais angeschlossen sind, die Lichter und andere Sachen in der Garage steuert.
      Ich bin dir so unendlich dankbar. Ich versuche schon so lange den zu reparieren. Danke Danke Danke
      L
      LinusJ
      2021-07-19 17:07:24.094  - info: host.ioBroker received SIGTERM
      2021-07-19 17:07:24.131  - info: vis-inventwo.0 (7439) cleaned everything up...
      2021-07-19 17:07:24.123  - info: web.0 (7469) terminated http server on port 8082
      2021-07-19 17:07:24.113  - info: backitup.0 (6710) cleaned everything up...
      2021-07-19 17:07:24.128  - info: info.0 (6790) cleaned everything up...
      2021-07-19 17:07:24.122  - info: simple-api.0 (7324) terminating http server on port 8087
      2021-07-19 17:07:24.127  - info: terminal.0 (7405) terminating http server on port 8088
      2021-07-19 17:07:24.122  - info: fritzdect.0 (6775) cleaned everything up...
      2021-07-19 17:07:24.155  - info: yahka.0 (7484) cleaning up ...
      2021-07-19 17:07:24.187  - info: yahka.0 (7484) cleaned up ...
      2021-07-19 17:07:24.190  - info: javascript.0 (6982) Stop script script.js.common.ButtonSteuerung_schalter
      2021-07-19 17:07:24.133  - info: terminal.0 (7405) terminated http server on port 8088
      2021-07-19 17:07:24.100  - info: admin.0 (6684) terminating https server on port 8081
      2021-07-19 17:07:24.212  - info: iot.0 (6809) Connection changed: disconnect
      2021-07-19 17:07:24.214  - info: iot.0 (6809) Connection lost
      2021-07-19 17:07:24.198  - info: javascript.0 (6982) Stop script script.js.common.Datenpunkt_aktualisierung
      2021-07-19 17:07:24.202  - info: javascript.0 (6982) Stop script script.js.common.DatumUhrzeit
      2021-07-19 17:07:24.217  - info: javascript.0 (6982) Stop script script.js.common.GarageRestart
      2021-07-19 17:07:24.218  - info: javascript.0 (6982) Stop script script.js.common.GaragenSteuerung
      2021-07-19 17:07:24.220  - info: javascript.0 (6982) Stop script script.js.common.Kurzbefehle
      2021-07-19 17:07:24.221  - info: javascript.0 (6982) Stop script script.js.common.Lautstärkenregelung
      2021-07-19 17:07:24.223  - info: javascript.0 (6982) Stop script script.js.common.Radio
      2021-07-19 17:07:24.224  - info: javascript.0 (6982) Stop script script.js.common.Relay
      2021-07-19 17:07:24.225  - info: javascript.0 (6982) Stop script script.js.common.SolaxCloud
      2021-07-19 17:07:24.226  - info: javascript.0 (6982) Stop script script.js.common.Wetterwarnung
      2021-07-19 17:07:24.227  - info: javascript.0 (6982) Stop script script.js.common.Wöchentlicher_Restart
      2021-07-19 17:07:24.228  - info: javascript.0 (6982) Stop script script.js.common.restart
      2021-07-19 17:07:24.230  - info: javascript.0 (6982) Stop script script.js.durchfahrt
      2021-07-19 17:07:24.173  - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
      2021-07-19 17:07:24.175  - info: host.ioBroker stopInstance system.adapter.alexa2.0 (force=false, process=false)
      2021-07-19 17:07:24.176  - info: host.ioBroker stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2021-07-19 17:07:24.178  - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2021-07-19 17:07:24.180  - info: host.ioBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
      2021-07-19 17:07:24.182  - info: host.ioBroker stopInstance system.adapter.divera247.0 (force=false, process=false)
      2021-07-19 17:07:24.183  - info: host.ioBroker stopInstance system.adapter.dwd.0 (force=false, process=false)
      2021-07-19 17:07:24.187  - info: host.ioBroker stopInstance canceled schedule system.adapter.dwd.0
      2021-07-19 17:07:24.188  - info: host.ioBroker stopInstance system.adapter.fritzbox.0 (force=false, process=true)
      2021-07-19 17:07:24.189  - info: host.ioBroker stopInstance system.adapter.fritzdect.0 (force=false, process=true)
      2021-07-19 17:07:24.195  - info: host.ioBroker stopInstance system.adapter.info.0 (force=false, process=true)
      2021-07-19 17:07:24.197  - info: host.ioBroker stopInstance system.adapter.iot.0 (force=false, process=true)
      2021-07-19 17:07:24.199  - info: host.ioBroker stopInstance system.adapter.javascript.0 (force=false, process=true)
      2021-07-19 17:07:24.201  - info: host.ioBroker stopInstance system.adapter.openweathermap.0 (force=false, process=false)
      2021-07-19 17:07:24.202  - info: host.ioBroker stopInstance canceled schedule system.adapter.openweathermap.0
      2021-07-19 17:07:24.204  - info: host.ioBroker stopInstance system.adapter.rpi2.0 (force=false, process=true)
      2021-07-19 17:07:24.205  - info: host.ioBroker stopInstance system.adapter.simple-api.0 (force=false, process=true)
      2021-07-19 17:07:24.207  - info: host.ioBroker stopInstance system.adapter.solax.0 (force=false, process=true)
      2021-07-19 17:07:24.209  - info: host.ioBroker stopInstance system.adapter.telegram.0 (force=false, process=true)
      2021-07-19 17:07:24.211  - info: host.ioBroker stopInstance system.adapter.terminal.0 (force=false, process=true)
      2021-07-19 17:07:24.213  - info: host.ioBroker stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
      2021-07-19 17:07:24.214  - info: host.ioBroker stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
      2021-07-19 17:07:24.215  - info: host.ioBroker stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
      2021-07-19 17:07:24.216  - info: host.ioBroker stopInstance system.adapter.vis-justgage.0 (force=false, process=false)
      2021-07-19 17:07:24.217  - info: host.ioBroker stopInstance system.adapter.vis.0 (force=false, process=false)
      2021-07-19 17:07:24.218  - info: host.ioBroker stopInstance system.adapter.web.0 (force=false, process=true)
      2021-07-19 17:07:24.220  - info: host.ioBroker stopInstance system.adapter.yahka.0 (force=false, process=true)
      2021-07-19 17:07:24.221  - info: host.ioBroker stopInstance system.adapter.yr.0 (force=false, process=false)
      2021-07-19 17:07:24.223  - info: host.ioBroker stopInstance canceled schedule system.adapter.yr.0
      2021-07-19 17:07:24.328  - info: fritzbox.0 (6756) State value to set for "fritzbox.0.calls.ringActualNumbers" has to be type "string" but received type "object"
      2021-07-19 17:07:24.334  - info: fritzbox.0 (6756) State value to set for "fritzbox.0.calls.connectNumbers" has to be type "string" but received type "object"
      2021-07-19 17:07:24.336  - info: fritzbox.0 (6756) State value to set for "fritzbox.0.calls.counterActualCalls.ringCount" has to be type "string" but received type "number"
      2021-07-19 17:07:24.347  - info: fritzbox.0 (6756) State value to set for "fritzbox.0.calls.counterActualCalls.callCount" has to be type "string" but received type "number"
      2021-07-19 17:07:24.356  - info: fritzbox.0 (6756) State value to set for "fritzbox.0.calls.counterActualCalls.connectCount" has to be type "string" but received type "number"
      2021-07-19 17:07:24.358  - info: fritzbox.0 (6756) State value to set for "fritzbox.0.calls.counterActualCalls.allActiveCount" has to be type "string" but received type "number"
      2021-07-19 17:07:24.532  - info: admin.0 (6684) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.535  - info: mqtt.0 (6699) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.540  - info: backitup.0 (6710) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.544  - info: discovery.0 (6721) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.552  - info: fritzbox.0 (6756) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.556  - info: fritzdect.0 (6775) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.559  - info: info.0 (6790) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.566  - info: iot.0 (6809) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.570  - info: javascript.0 (6982) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.574  - info: rpi2.0 (7290) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.581  - info: simple-api.0 (7324) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.585  - info: solax.0 (7378) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.588  - info: telegram.0 (7393) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.596  - info: terminal.0 (7405) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.600  - info: web.0 (7469) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.604  - info: yahka.0 (7484) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 17:07:24.666  - info: rpi2.0 (7290) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.670  - info: solax.0 (7378) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.671  - info: web.0 (7469) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.709  - info: info.0 (6790) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.713  - info: vis-inventwo.0 (7439) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.718  - info: fritzdect.0 (6775) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.720  - info: discovery.0 (6721) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.720  - info: simple-api.0 (7324) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.715  - info: backitup.0 (6710) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.729  - info: yahka.0 (7484) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.738  - info: admin.0 (6684) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.737  - info: terminal.0 (7405) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.745  - info: iot.0 (6809) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.808  - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
      2021-07-19 17:07:24.812  - info: javascript.0 (6982) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.847  - info: host.ioBroker stopInstance system.adapter.mqtt.0 send kill signal
      2021-07-19 17:07:24.848  - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2021-07-19 17:07:24.849  - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
      2021-07-19 17:07:24.852  - info: host.ioBroker stopInstance system.adapter.fritzbox.0 send kill signal
      2021-07-19 17:07:24.853  - info: host.ioBroker stopInstance system.adapter.fritzdect.0 send kill signal
      2021-07-19 17:07:24.854  - info: host.ioBroker stopInstance system.adapter.info.0 send kill signal
      2021-07-19 17:07:24.855  - info: host.ioBroker stopInstance system.adapter.iot.0 send kill signal
      2021-07-19 17:07:24.855  - info: host.ioBroker stopInstance system.adapter.javascript.0 send kill signal
      2021-07-19 17:07:24.856  - info: host.ioBroker stopInstance system.adapter.rpi2.0 send kill signal
      2021-07-19 17:07:24.857  - info: host.ioBroker stopInstance system.adapter.simple-api.0 send kill signal
      2021-07-19 17:07:24.858  - info: host.ioBroker stopInstance system.adapter.solax.0 send kill signal
      2021-07-19 17:07:24.859  - info: host.ioBroker stopInstance system.adapter.telegram.0 send kill signal
      2021-07-19 17:07:24.860  - info: host.ioBroker stopInstance system.adapter.terminal.0 send kill signal
      2021-07-19 17:07:24.861  - info: host.ioBroker stopInstance system.adapter.web.0 send kill signal
      2021-07-19 17:07:24.862  - info: host.ioBroker stopInstance system.adapter.yahka.0 send kill signal
      2021-07-19 17:07:24.914  - info: mqtt.0 (6699) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.925  - info: telegram.0 (7393) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:24.943  - info: fritzbox.0 (6756) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 17:07:25.563  - info: host.ioBroker instance system.adapter.rpi2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:25.614  - info: host.ioBroker instance system.adapter.solax.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:25.689  - info: host.ioBroker instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:25.825  - info: host.ioBroker stopInstance system.adapter.admin.0 killing pid 6684
      2021-07-19 17:07:25.881  - info: host.ioBroker stopInstance system.adapter.mqtt.0 killing pid 6699
      2021-07-19 17:07:25.883  - info: host.ioBroker stopInstance system.adapter.fritzbox.0 killing pid 6756
      2021-07-19 17:07:25.885  - info: host.ioBroker stopInstance system.adapter.javascript.0 killing pid 6982
      2021-07-19 17:07:25.886  - info: host.ioBroker stopInstance system.adapter.telegram.0 killing pid 7393
      2021-07-19 17:07:26.236  - info: host.ioBroker instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:26.238  - info: host.ioBroker instance system.adapter.vis-inventwo.0 terminated while should be started once
      2021-07-19 17:07:26.240  - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:26.434  - info: host.ioBroker instance system.adapter.fritzdect.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:26.435  - info: host.ioBroker instance system.adapter.simple-api.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:26.479  - info: host.ioBroker instance system.adapter.terminal.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:26.619  - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:26.621  - info: host.ioBroker instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:26.623  - info: host.ioBroker instance system.adapter.yahka.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:26.639  - info: host.ioBroker All instances are stopped.
      2021-07-19 17:07:26.649  - info: host.ioBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-19 17:07:26.650  - info: host.ioBroker All instances are stopped.
      2021-07-19 17:07:26.938  - warn: host.ioBroker instance system.adapter.mqtt.0 terminated due to SIGTERM
      2021-07-19 17:07:26.939  - info: host.ioBroker instance system.adapter.mqtt.0 terminated with code null ()
      2021-07-19 17:07:26.940  - info: host.ioBroker All instances are stopped.
      2021-07-19 17:07:26.941  - warn: host.ioBroker instance system.adapter.fritzbox.0 terminated due to SIGTERM
      2021-07-19 17:07:26.942  - info: host.ioBroker instance system.adapter.fritzbox.0 terminated with code null ()
      2021-07-19 17:07:26.943  - info: host.ioBroker All instances are stopped.
      2021-07-19 17:07:26.946  - warn: host.ioBroker instance system.adapter.javascript.0 terminated due to SIGTERM
      2021-07-19 17:07:26.947  - info: host.ioBroker instance system.adapter.javascript.0 terminated with code null ()
      2021-07-19 17:07:26.948  - info: host.ioBroker All instances are stopped.
      2021-07-19 17:07:26.949  - warn: host.ioBroker instance system.adapter.telegram.0 terminated due to SIGTERM
      2021-07-19 17:07:26.950  - info: host.ioBroker instance system.adapter.telegram.0 terminated with code null ()
      2021-07-19 17:07:26.951  - info: host.ioBroker All instances are stopped.
      2021-07-19 17:07:27.032  - info: host.ioBroker terminated
      2021-07-19 17:07:30.264  - info: host.ioBroker iobroker.js-controller version 3.3.11 js-controller starting
      2021-07-19 17:07:30.277  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-07-19 17:07:30.278  - info: host.ioBroker hostname: ioBroker, node: v12.22.2
      2021-07-19 17:07:30.279  - info: host.ioBroker ip addresses: 192.168.178.62 2003:df:af19:4700:b7e:694a:44a1:812b fe80::6ea7:dc25:16b:d801 fe80::789d:b5ff:fe36:5437
      2021-07-19 17:07:31.485  - info: host.ioBroker connected to Objects and States
      2021-07-19 17:07:31.665  - info: host.ioBroker added notifications configuration of host
      2021-07-19 17:07:32.415  - info: host.ioBroker 27 instances found
      2021-07-19 17:07:32.539  - info: host.ioBroker starting 22 instances
      2021-07-19 17:07:32.709  - info: host.ioBroker instance system.adapter.admin.0 started with pid 8401
      2021-07-19 17:07:36.353  - info: admin.0 (8401) starting. Version 5.1.12 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:07:36.469  - info: admin.0 (8401) requesting all states
      2021-07-19 17:07:36.471  - info: admin.0 (8401) requesting all objects
      2021-07-19 17:07:36.685  - info: host.ioBroker instance system.adapter.mqtt.0 started with pid 8416
      2021-07-19 17:07:39.309  - info: admin.0 (8401) received all objects
      2021-07-19 17:07:39.667  - info: admin.0 (8401) https server listening on port 8081
      2021-07-19 17:07:39.668  - info: admin.0 (8401) Use link "https://localhost:8081" to configure.
      2021-07-19 17:07:40.287  - info: mqtt.0 (8416) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:07:40.642  - info: host.ioBroker instance system.adapter.backitup.0 started with pid 8431
      2021-07-19 17:07:40.726  - warn: admin.0 (8401) State "admin.0.info.connection" has no existing object, this might lead to an error in future versions
      2021-07-19 17:07:40.898  - warn: admin.0 (8401) Cannot parse "undefined"
      2021-07-19 17:07:40.910  - error: admin.0 (8401) error
      2021-07-19 17:07:41.157  - warn: admin.0 (8401) Cannot parse "undefined"
      2021-07-19 17:07:41.188  - info: mqtt.0 (8416) Starting MQTT authenticated server on 0.0.0.0:1883
      2021-07-19 17:07:44.936  - info: host.ioBroker instance system.adapter.discovery.0 started with pid 8438
      2021-07-19 17:07:46.163  - info: mqtt.0 (8416) Client [Garagensteuerung] connected with secret 1626707266087_4811
      2021-07-19 17:07:46.487  - info: mqtt.0 (8416) Client [Garagensteuerung] subscribes on topic "/garage/data"
      2021-07-19 17:07:48.269  - info: discovery.0 (8438) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:07:48.583  - info: backitup.0 (8431) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:07:48.663  - info: host.ioBroker instance scheduled system.adapter.dwd.0 */5 * * * *
      2021-07-19 17:07:48.690  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 8461
      2021-07-19 17:07:48.772  - info: backitup.0 (8431) [iobroker] backup was activated at 01:30 every 1 day(s)
      2021-07-19 17:07:52.310  - info: dwd.0 (8461) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:07:52.856  - info: host.ioBroker instance system.adapter.fritzbox.0 started with pid 8476
      2021-07-19 17:07:53.382  - info: dwd.0 (8461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-07-19 17:07:54.026  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-07-19 17:07:55.756  - info: fritzbox.0 (8476) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:07:55.824  - info: fritzbox.0 (8476) try to connect: 192.168.178.1
      2021-07-19 17:07:55.869  - info: fritzbox.0 (8476) adapter connected to fritzbox: 192.168.178.1
      2021-07-19 17:07:55.894  - info: fritzbox.0 (8476) State value to set for "fritzbox.0.calls.ringActualNumbers" has to be type "string" but received type "object"
      2021-07-19 17:07:55.897  - info: fritzbox.0 (8476) State value to set for "fritzbox.0.calls.connectNumbers" has to be type "string" but received type "object"
      2021-07-19 17:07:55.899  - info: fritzbox.0 (8476) State value to set for "fritzbox.0.calls.counterActualCalls.ringCount" has to be type "string" but received type "number"
      2021-07-19 17:07:55.902  - info: fritzbox.0 (8476) State value to set for "fritzbox.0.calls.counterActualCalls.callCount" has to be type "string" but received type "number"
      2021-07-19 17:07:55.904  - info: fritzbox.0 (8476) State value to set for "fritzbox.0.calls.counterActualCalls.connectCount" has to be type "string" but received type "number"
      2021-07-19 17:07:55.906  - info: fritzbox.0 (8476) State value to set for "fritzbox.0.calls.counterActualCalls.allActiveCount" has to be type "string" but received type "number"
      2021-07-19 17:07:56.629  - info: host.ioBroker instance system.adapter.fritzdect.0 started with pid 8491
      2021-07-19 17:07:59.144  - info: fritzdect.0 (8491) starting. Version 2.1.15 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:07:59.194  - info: fritzdect.0 (8491) fritzdect entered ready
      2021-07-19 17:07:59.253  - info: fritzdect.0 (8491) fritzdect uses USER: Fritz-Smart
      2021-07-19 17:07:59.254  - info: fritzdect.0 (8491) start creating devices/groups
      2021-07-19 17:08:01.026  - info: host.ioBroker instance system.adapter.info.0 started with pid 8506
      2021-07-19 17:08:01.227  - info: fritzdect.0 (8491) CREATE Devices 2
      2021-07-19 17:08:01.541  - info: fritzdect.0 (8491) setting up temperatur
      2021-07-19 17:08:01.571  - info: fritzdect.0 (8491) setting up thermostat
      2021-07-19 17:08:01.760  - info: fritzdect.0 (8491) setting up thermostat nextchange
      2021-07-19 17:08:01.804  - info: fritzdect.0 (8491) setting up switch
      2021-07-19 17:08:01.851  - info: fritzdect.0 (8491) setting up powermeter
      2021-07-19 17:08:01.861  - info: fritzdect.0 (8491) setting up temperatur
      2021-07-19 17:08:01.869  - info: fritzdect.0 (8491) setting up simpleonoff
      2021-07-19 17:08:01.894  - info: fritzdect.0 (8491) finished creating devices/groups (if any)
      2021-07-19 17:08:01.895  - info: fritzdect.0 (8491) start creating templates
      2021-07-19 17:08:04.549  - info: fritzdect.0 (8491) create Templates 5
      2021-07-19 17:08:04.611  - info: fritzdect.0 (8491) setting up Template Dusche abends
      2021-07-19 17:08:04.661  - info: host.ioBroker instance system.adapter.iot.0 started with pid 8525
      2021-07-19 17:08:04.693  - info: fritzdect.0 (8491) setting up Template Dusche an
      2021-07-19 17:08:04.752  - info: fritzdect.0 (8491) setting up Template Dusche aus
      2021-07-19 17:08:04.805  - info: fritzdect.0 (8491) setting up Template Dusche morgens
      2021-07-19 17:08:04.862  - info: fritzdect.0 (8491) setting up Template Weihnachtsbeleuchtung
      2021-07-19 17:08:04.906  - info: fritzdect.0 (8491) finished creating templates (if any)
      2021-07-19 17:08:04.907  - info: fritzdect.0 (8491) start initial updating devices/groups
      2021-07-19 17:08:06.987  - info: info.0 (8506) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:07.073  - info: fritzdect.0 (8491) State value to set for "fritzdect.0.DECT_119600802296.windowopenactiveendtime" has to be type "number" but received type "string"
      2021-07-19 17:08:07.077  - info: fritzdect.0 (8491) State value to set for "fritzdect.0.DECT_119600802296.boostactiveendtime" has to be type "number" but received type "string"
      2021-07-19 17:08:07.080  - info: fritzdect.0 (8491) State value to set for "fritzdect.0.DECT_119600802296.endperiod" has to be type "number" but received type "string"
      2021-07-19 17:08:07.382  - info: fritzdect.0 (8491) finished initial updating devices/groups
      2021-07-19 17:08:07.384  - info: fritzdect.0 (8491) going over to cyclic polling, messages to poll activity only in debug-mode
      2021-07-19 17:08:08.847  - info: host.ioBroker instance system.adapter.javascript.0 started with pid 8712
      2021-07-19 17:08:11.087  - info: info.0 (8506) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
      2021-07-19 17:08:11.235  - info: iot.0 (8525) starting. Version 1.8.22 in /opt/iobroker/node_modules/iobroker.iot, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:11.592  - info: iot.0 (8525) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2021-07-19 17:08:11.931  - info: info.0 (8506) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
      2021-07-19 17:08:11.955  - info: info.0 (8506) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
      2021-07-19 17:08:11.957  - info: info.0 (8506) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
      2021-07-19 17:08:11.959  - info: info.0 (8506) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
      2021-07-19 17:08:12.397  - info: info.0 (8506) State value to set for "info.0.sysinfo.battery.raspberry" has to be stringified but received type "object"
      2021-07-19 17:08:12.423  - info: info.0 (8506) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
      2021-07-19 17:08:12.445  - info: info.0 (8506) State value to set for "info.0.sysinfo.system.hardware.raspberry" has to be stringified but received type "object"
      2021-07-19 17:08:12.834  - info: host.ioBroker instance scheduled system.adapter.openweathermap.0 23 * * * *
      2021-07-19 17:08:12.900  - info: host.ioBroker instance system.adapter.openweathermap.0 started with pid 9003
      2021-07-19 17:08:13.752  - info: iot.0 (8525) Connection changed: connect
      2021-07-19 17:08:16.748  - info: host.ioBroker instance system.adapter.rpi2.0 started with pid 9039
      2021-07-19 17:08:17.699  - info: openweathermap.0 (9003) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:18.913  - info: javascript.0 (8712) starting. Version 5.1.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:19.287  - info: javascript.0 (8712) requesting all states
      2021-07-19 17:08:19.310  - info: javascript.0 (8712) requesting all objects
      2021-07-19 17:08:20.661  - info: host.ioBroker instance system.adapter.simple-api.0 started with pid 9058
      2021-07-19 17:08:20.997  - info: rpi2.0 (9039) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:21.450  - info: javascript.0 (8712) received all objects
      2021-07-19 17:08:21.568  - info: javascript.0 (8712) received all states
      2021-07-19 17:08:21.824  - error: rpi2.0 (9039) No Value found for cpu_frequency
      2021-07-19 17:08:21.892  - error: rpi2.0 (9039) No Value found for net_received
      2021-07-19 17:08:21.895  - error: rpi2.0 (9039) No Value found for net_send
      2021-07-19 17:08:21.967  - error: rpi2.0 (9039) Cannot initialize GPIO: Error: The module '/opt/iobroker/node_modules/epoll/build/Release/epoll.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 64. This version of Node.js requires
      NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
      2021-07-19 17:08:21.983  - error: rpi2.0 (9039) cannot use GPIO: TypeError: Cannot read property 'setMode' of null
      2021-07-19 17:08:22.088  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load1" has to be type "number" but received type "string"
      2021-07-19 17:08:22.106  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load5" has to be type "number" but received type "string"
      2021-07-19 17:08:22.130  - info: javascript.0 (8712) Start javascript script.js.common.ButtonSteuerung_schalter
      2021-07-19 17:08:22.110  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load15" has to be type "number" but received type "string"
      2021-07-19 17:08:22.264  - info: javascript.0 (8712) script.js.common.ButtonSteuerung_schalter: registered 3 subscriptions and 0 schedules
      2021-07-19 17:08:22.266  - info: javascript.0 (8712) Start javascript script.js.common.Datenpunkt_aktualisierung
      2021-07-19 17:08:22.316  - info: javascript.0 (8712) script.js.common.Datenpunkt_aktualisierung: registered 0 subscriptions and 1 schedule
      2021-07-19 17:08:22.317  - info: javascript.0 (8712) Start javascript script.js.common.DatumUhrzeit
      2021-07-19 17:08:22.344  - info: javascript.0 (8712) script.js.common.DatumUhrzeit: registered 0 subscriptions and 2 schedules
      2021-07-19 17:08:22.346  - info: javascript.0 (8712) Start javascript script.js.common.GarageRestart
      2021-07-19 17:08:22.364  - info: javascript.0 (8712) script.js.common.GarageRestart: registered 0 subscriptions and 1 schedule
      2021-07-19 17:08:22.366  - info: javascript.0 (8712) Start javascript script.js.common.GaragenSteuerung
      2021-07-19 17:08:22.379  - info: javascript.0 (8712) script.js.common.GaragenSteuerung: registered 9 subscriptions and 0 schedules
      2021-07-19 17:08:22.381  - info: javascript.0 (8712) Start javascript script.js.common.Kurzbefehle
      2021-07-19 17:08:22.394  - info: javascript.0 (8712) script.js.common.Kurzbefehle: registered 5 subscriptions and 0 schedules
      2021-07-19 17:08:22.396  - info: javascript.0 (8712) Start javascript script.js.common.Lautstärkenregelung
      2021-07-19 17:08:22.412  - info: javascript.0 (8712) script.js.common.Lautstärkenregelung: registered 0 subscriptions and 2 schedules
      2021-07-19 17:08:22.414  - info: javascript.0 (8712) Start javascript script.js.common.Radio
      2021-07-19 17:08:22.426  - info: javascript.0 (8712) script.js.common.Radio: registered 3 subscriptions and 0 schedules
      2021-07-19 17:08:22.428  - info: javascript.0 (8712) Start javascript script.js.common.Relay
      2021-07-19 17:08:22.442  - info: javascript.0 (8712) script.js.common.Relay: registered 2 subscriptions and 0 schedules
      2021-07-19 17:08:22.444  - info: javascript.0 (8712) Start javascript script.js.common.Wetterwarnung
      2021-07-19 17:08:22.455  - info: javascript.0 (8712) script.js.common.Wetterwarnung: registered 1 subscription and 0 schedules
      2021-07-19 17:08:22.478  - info: javascript.0 (8712) Start javascript script.js.common.Wöchentlicher_Restart
      2021-07-19 17:08:22.491  - info: javascript.0 (8712) script.js.common.Wöchentlicher_Restart: registered 0 subscriptions and 1 schedule
      2021-07-19 17:08:22.494  - info: javascript.0 (8712) Start javascript script.js.common.restart
      2021-07-19 17:08:22.524  - info: javascript.0 (8712) script.js.common.restart: registered 1 subscription and 1 schedule
      2021-07-19 17:08:22.788  - info: javascript.0 (8712) Start javascript script.js.durchfahrt
      2021-07-19 17:08:22.815  - info: javascript.0 (8712) script.js.durchfahrt: registered 1 subscription and 0 schedules
      2021-07-19 17:08:23.081  - info: javascript.0 (8712) Start javascript script.js.common.SolaxCloud
      2021-07-19 17:08:23.119  - info: javascript.0 (8712) script.js.common.SolaxCloud: registered 1 subscription and 1 schedule
      2021-07-19 17:08:23.222  - info: openweathermap.0 (9003) Terminated (NO_ERROR): Without reason
      2021-07-19 17:08:23.848  - info: host.ioBroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
      2021-07-19 17:08:24.527  - info: simple-api.0 (9058) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:24.595  - info: simple-api.0 (9058) simpleAPI server listening on port 8087
      2021-07-19 17:08:24.597  - info: simple-api.0 (9058) Allow states only when user is owner: false
      2021-07-19 17:08:24.621  - info: simple-api.0 (9058) http server listening on port 8087
      2021-07-19 17:08:24.695  - info: host.ioBroker instance system.adapter.solax.0 started with pid 9122
      2021-07-19 17:08:27.857  - info: solax.0 (9122) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.solax, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:28.632  - info: host.ioBroker instance system.adapter.telegram.0 started with pid 9137
      2021-07-19 17:08:32.611  - info: host.ioBroker instance system.adapter.terminal.0 started with pid 9148
      2021-07-19 17:08:32.665  - info: telegram.0 (9137) starting. Version 1.9.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:35.761  - info: terminal.0 (9148) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.terminal, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:35.941  - info: terminal.0 (9148) http server listening on port 8088
      2021-07-19 17:08:39.039  - info: vis-google-fonts.0 (9167) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:39.179  - error: vis-google-fonts.0 (9167) Error: Unknown user in group "1": system.user.api
      2021-07-19 17:08:39.730  - info: vis-google-fonts.0 (9167) Terminated (NO_ERROR): Without reason
      2021-07-19 17:08:40.419  - info: host.ioBroker instance system.adapter.vis-google-fonts.0 terminated while should be started once
      2021-07-19 17:08:43.237  - info: vis-inventwo.0 (9182) starting. Version 3.0.11 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:47.032  - info: vis.0 (9197) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:47.608  - info: vis.0 (9197) vis license is OK.
      2021-07-19 17:08:48.922  - error: vis.0 (9197) Error: Unknown user in group "1": system.user.api
      2021-07-19 17:08:48.929  - error: vis.0 (9197) Error: Unknown user in group "1": system.user.api
      2021-07-19 17:08:49.002  - info: host.ioBroker instance system.adapter.web.0 started with pid 9213
      2021-07-19 17:08:49.698  - info: vis.0 (9197) Terminated (NO_ERROR): Without reason
      2021-07-19 17:08:50.327  - info: host.ioBroker instance system.adapter.vis.0 terminated while should be started once
      2021-07-19 17:08:52.433  - info: web.0 (9213) starting. Version 3.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:52.581  - info: host.ioBroker instance system.adapter.yahka.0 started with pid 9229
      2021-07-19 17:08:52.896  - info: web.0 (9213) socket.io server listening on port 8082
      2021-07-19 17:08:52.907  - info: web.0 (9213) http server listening on port 8082
      2021-07-19 17:08:55.866  - info: yahka.0 (9229) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.yahka, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:08:55.916  - info: yahka.0 (9229) adapter ready, checking config
      2021-07-19 17:08:55.940  - info: yahka.0 (9229) adding ColoLight with UUID: 79b26087-fa08-4240-8f24-d61163b16fa4
      2021-07-19 17:08:55.970  - info: yahka.0 (9229) adding Bett-Licht with UUID: ec8fcbc4-5527-4c63-9bfe-a11d4eb292cb
      2021-07-19 17:08:55.991  - info: yahka.0 (9229) adding Steckdose1 with UUID: 12068a0f-a9d0-47c5-97b1-8b68b37bd2be
      2021-07-19 17:08:55.999  - info: yahka.0 (9229) adding Heizung with UUID: 901db165-849a-4715-86bc-095a2989c0d9
      2021-07-19 17:08:56.014  - info: yahka.0 (9229) adding Garagentor with UUID: eb975574-a3b2-4c0a-9953-c3aa23b9d845
      2021-07-19 17:08:56.027  - info: yahka.0 (9229) adding Radio with UUID: 7061dc05-5b03-43ec-a1e0-f0d6d501f717
      2021-07-19 17:08:56.033  - info: yahka.0 (9229) adding Treffen with UUID: 2d71d2e2-72ca-449f-9d45-82cdf1ba59fb
      2021-07-19 17:08:56.039  - info: yahka.0 (9229) adding Essen with UUID: 34b2009b-a215-4906-b6c9-7d867e3278b5
      2021-07-19 17:08:56.045  - info: yahka.0 (9229) adding Fertig with UUID: b2a9c621-331c-47ea-8d4d-133d9cf4e9a8
      2021-07-19 17:08:56.051  - info: yahka.0 (9229) adding Licht Fenster with UUID: 2a623e09-0b16-43ed-ae2f-da77db8fcbd9
      2021-07-19 17:08:56.058  - info: yahka.0 (9229) adding Licht Tor with UUID: 61ccf80c-2092-4c55-b519-709c8aa00f66
      2021-07-19 17:08:56.065  - info: yahka.0 (9229) adding Licht Treppe with UUID: 325dd33a-ae33-475e-9fc6-007a3aa61ae8
      2021-07-19 17:08:56.071  - info: yahka.0 (9229) adding Licht Spiegel with UUID: 3e8d4263-cb0f-4890-86e9-32e003dbe7a6
      2021-07-19 17:08:56.077  - info: yahka.0 (9229) adding Garage Durchfahrt with UUID: c34a4278-a796-4dc9-bb73-4722d78940b9
      2021-07-19 17:08:56.083  - info: yahka.0 (9229) adding Linus Deckenlampe with UUID: 51a32b37-a153-40b0-bfd8-2b03ebd5a4f1
      2021-07-19 17:08:56.097  - info: yahka.0 (9229) publishing bridge JahnHausen on 0.0.0.0
      2021-07-19 17:08:57.687  - info: host.ioBroker instance scheduled system.adapter.yr.0 * 6 * * * *
      2021-07-19 17:08:57.731  - info: host.ioBroker instance system.adapter.yr.0 started with pid 9246
      2021-07-19 17:09:00.672  - info: yr.0 (9246) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:09:00.803  - warn: yr.0 (9246) State "yr.0.forecast.info.diagram" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.044  - info: yr.0 (9246) got weather data from yr.no
      2021-07-19 17:09:01.079  - warn: yr.0 (9246) State "yr.0.forecast.day0.date" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.081  - warn: yr.0 (9246) State "yr.0.forecast.day0.icon" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.083  - warn: yr.0 (9246) State "yr.0.forecast.day0.state" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.085  - warn: yr.0 (9246) State "yr.0.forecast.day0.temperatureMin" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.087  - warn: yr.0 (9246) State "yr.0.forecast.day0.temperatureMax" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.089  - warn: yr.0 (9246) State "yr.0.forecast.day0.precipitation" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.091  - warn: yr.0 (9246) State "yr.0.forecast.day0.windDirection" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.093  - warn: yr.0 (9246) State "yr.0.forecast.day0.windSpeed" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.095  - warn: yr.0 (9246) State "yr.0.forecast.day0.pressure" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.097  - warn: yr.0 (9246) State "yr.0.forecast.day0.temperatureActual" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.098  - warn: yr.0 (9246) State "yr.0.forecast.day1.date" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.100  - warn: yr.0 (9246) State "yr.0.forecast.day1.icon" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.102  - warn: yr.0 (9246) State "yr.0.forecast.day1.state" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.103  - warn: yr.0 (9246) State "yr.0.forecast.day1.temperatureMin" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.105  - warn: yr.0 (9246) State "yr.0.forecast.day1.temperatureMax" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.107  - warn: yr.0 (9246) State "yr.0.forecast.day1.precipitation" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.108  - warn: yr.0 (9246) State "yr.0.forecast.day1.windDirection" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.110  - warn: yr.0 (9246) State "yr.0.forecast.day1.windSpeed" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.112  - warn: yr.0 (9246) State "yr.0.forecast.day1.pressure" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.113  - warn: yr.0 (9246) State "yr.0.forecast.day2.date" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.115  - warn: yr.0 (9246) State "yr.0.forecast.day2.icon" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.116  - warn: yr.0 (9246) State "yr.0.forecast.day2.state" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.118  - warn: yr.0 (9246) State "yr.0.forecast.day2.temperatureMin" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.120  - warn: yr.0 (9246) State "yr.0.forecast.day2.temperatureMax" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.121  - warn: yr.0 (9246) State "yr.0.forecast.day2.precipitation" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.123  - warn: yr.0 (9246) State "yr.0.forecast.day2.windDirection" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.124  - warn: yr.0 (9246) State "yr.0.forecast.day2.windSpeed" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.126  - warn: yr.0 (9246) State "yr.0.forecast.day2.pressure" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.128  - warn: yr.0 (9246) State "yr.0.forecast.info.html" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:01.152  - warn: yr.0 (9246) State "yr.0.forecast.info.object" has no existing object, this might lead to an error in future versions
      2021-07-19 17:09:06.352  - info: host.ioBroker instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2021-07-19 17:09:21.742  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load1" has to be type "number" but received type "string"
      2021-07-19 17:09:21.745  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load5" has to be type "number" but received type "string"
      2021-07-19 17:09:21.747  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load15" has to be type "number" but received type "string"
      2021-07-19 17:10:00.126  - info: javascript.0 (8712) script.js.common.SolaxCloud: new request...
      2021-07-19 17:10:00.150  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 9319
      2021-07-19 17:10:00.361  - warn: javascript.0 (8712) You are assigning a number to the state "0_userdata.0.SolaxCloud.lastRequest" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
      2021-07-19 17:10:00.387  - warn: javascript.0 (8712)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
      2021-07-19 17:10:00.388  - warn: javascript.0 (8712)     at script.js.common.SolaxCloud:18:7
      2021-07-19 17:10:00.389  - warn: javascript.0 (8712)     at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
      2021-07-19 17:10:00.390  - warn: javascript.0 (8712)     at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      2021-07-19 17:10:00.391  - warn: javascript.0 (8712)     at Request.emit (events.js:314:20)
      2021-07-19 17:10:00.392  - warn: javascript.0 (8712)     at Request.EventEmitter.emit (domain.js:483:12)
      2021-07-19 17:10:00.392  - warn: javascript.0 (8712)     at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
      2021-07-19 17:10:00.393  - warn: javascript.0 (8712)     at Request.emit (events.js:314:20)
      2021-07-19 17:10:00.394  - warn: javascript.0 (8712)     at Request.EventEmitter.emit (domain.js:483:12)
      2021-07-19 17:10:00.394  - warn: javascript.0 (8712)     at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
      2021-07-19 17:10:00.395  - warn: javascript.0 (8712)     at Object.onceWrapper (events.js:420:28)
      2021-07-19 17:10:00.396  - warn: javascript.0 (8712)     at IncomingMessage.emit (events.js:326:22)
      2021-07-19 17:10:00.396  - warn: javascript.0 (8712)     at IncomingMessage.EventEmitter.emit (domain.js:483:12)
      2021-07-19 17:10:00.397  - warn: javascript.0 (8712)     at endReadableNT (_stream_readable.js:1241:12)
      2021-07-19 17:10:00.398  - warn: javascript.0 (8712)     at processTicksAndRejections (internal/process/task_queues.js:84:21)
      2021-07-19 17:10:00.416  - info: javascript.0 (8712) State value to set for "0_userdata.0.SolaxCloud.lastRequest" has to be type "string" but received type "number"
      2021-07-19 17:10:04.180  - info: dwd.0 (9319) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.2, js-controller: 3.3.11
      2021-07-19 17:10:07.147  - info: dwd.0 (9319) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-07-19 17:10:07.709  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-07-19 17:10:21.673  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load1" has to be type "number" but received type "string"
      2021-07-19 17:10:21.675  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load5" has to be type "number" but received type "string"
      2021-07-19 17:10:21.677  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load15" has to be type "number" but received type "string"
      2021-07-19 17:11:21.666  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load1" has to be type "number" but received type "string"
      2021-07-19 17:11:21.668  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load5" has to be type "number" but received type "string"
      2021-07-19 17:11:21.671  - info: rpi2.0 (9039) State value to set for "rpi2.0.cpu.load15" has to be type "number" but received type "string"
      L
      LinusJ
      @thomas-braun So sieht der Log beim Restarten aus:
      2021-07-19 16:55:06.095  - info: mqtt.0 (5780) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.100  - info: admin.0 (5765) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.111  - info: backitup.0 (5799) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.130  - info: fritzbox.0 (5840) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.137  - info: iot.0 (5893) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.126  - info: discovery.0 (5806) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.141  - info: info.0 (5874) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.147  - info: fritzdect.0 (5859) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.150  - info: simple-api.0 (6401) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.147  - info: rpi2.0 (6382) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.161  - info: javascript.0 (6092) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.189  - info: discovery.0 (5806) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.191  - info: vis-inventwo.0 (6525) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.196  - info: rpi2.0 (6382) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.201  - info: web.0 (6557) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.203  - info: yahka.0 (6572) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.201  - info: backitup.0 (5799) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.205  - info: solax.0 (6465) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.206  - info: terminal.0 (6491) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.211  - info: simple-api.0 (6401) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.231  - info: solax.0 (6465) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.235  - info: telegram.0 (6480) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.242  - info: terminal.0 (6491) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.246  - info: web.0 (6557) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.249  - info: yahka.0 (6572) Got terminate signal TERMINATE_YOURSELF
      2021-07-19 16:55:06.255  - info: dwd.0 (6627) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.260  - info: iot.0 (5893) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.263  - info: info.0 (5874) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.260  - info: admin.0 (5765) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.267  - info: fritzdect.0 (5859) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.279  - info: javascript.0 (6092) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.320  - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
      2021-07-19 16:55:06.322  - info: host.ioBroker stopInstance system.adapter.mqtt.0 send kill signal
      2021-07-19 16:55:06.322  - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2021-07-19 16:55:06.323  - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
      2021-07-19 16:55:06.324  - info: host.ioBroker stopInstance system.adapter.fritzbox.0 send kill signal
      2021-07-19 16:55:06.325  - info: host.ioBroker stopInstance system.adapter.fritzdect.0 send kill signal
      2021-07-19 16:55:06.326  - info: host.ioBroker stopInstance system.adapter.info.0 send kill signal
      2021-07-19 16:55:06.326  - info: host.ioBroker stopInstance system.adapter.iot.0 send kill signal
      2021-07-19 16:55:06.333  - info: host.ioBroker stopInstance system.adapter.javascript.0 send kill signal
      2021-07-19 16:55:06.336  - info: host.ioBroker stopInstance system.adapter.rpi2.0 send kill signal
      2021-07-19 16:55:06.337  - info: host.ioBroker stopInstance system.adapter.simple-api.0 send kill signal
      2021-07-19 16:55:06.338  - info: host.ioBroker stopInstance system.adapter.solax.0 send kill signal
      2021-07-19 16:55:06.339  - info: host.ioBroker stopInstance system.adapter.telegram.0 send kill signal
      2021-07-19 16:55:06.341  - info: host.ioBroker stopInstance system.adapter.terminal.0 send kill signal
      2021-07-19 16:55:06.342  - info: host.ioBroker stopInstance system.adapter.web.0 send kill signal
      2021-07-19 16:55:06.342  - info: host.ioBroker stopInstance system.adapter.yahka.0 send kill signal
      2021-07-19 16:55:06.461  - info: fritzbox.0 (5840) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.469  - info: telegram.0 (6480) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.485  - info: mqtt.0 (5780) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-19 16:55:06.834  - warn: dwd.0 (6627) get state error: Connection is closed.
      2021-07-19 16:55:06.839  - error: dwd.0 (6627) Unhandled promise rejection. This error originated either by throwing        inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-07-19 16:55:06.840  - error: dwd.0 (6627) unhandled promise rejection: DB closed
      2021-07-19 16:55:06.856  - error: dwd.0 (6627) Error: DB closed
          at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
          at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
          at Object.onceWrapper (events.js:421:26)
          at Socket.emit (events.js:314:20)
          at Socket.EventEmitter.emit (domain.js:483:12)
          at TCP.<anonymous> (net.js:675:12)
      2021-07-19 16:55:06.858  - error: dwd.0 (6627) DB closed
      2021-07-19 16:55:07.342  - error: host.ioBroker instance system.adapter.dwd.0 terminated with code 156 (START_IMMEDIA        TELY_AFTER_STOP)
      2021-07-19 16:55:07.545  - info: host.ioBroker instance system.adapter.vis-inventwo.0 terminated while should be star        ted once
      2021-07-19 16:55:07.549  - info: host.ioBroker stopInstance system.adapter.mqtt.0 killing pid 5780
      2021-07-19 16:55:07.551  - info: host.ioBroker stopInstance system.adapter.fritzbox.0 killing pid 5840
      2021-07-19 16:55:07.552  - info: host.ioBroker stopInstance system.adapter.telegram.0 killing pid 6480
      2021-07-19 16:55:07.604  - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IM        MEDIATELY_AFTER_STOP)
      2021-07-19 16:55:07.808  - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMM        EDIATELY_AFTER_STOP)
      2021-07-19 16:55:07.811  - info: host.ioBroker instance system.adapter.rpi2.0 terminated with code 156 (START_IMMEDIA        TELY_AFTER_STOP)
      2021-07-19 16:55:07.812  - info: host.ioBroker instance system.adapter.solax.0 terminated with code 156 (START_IMMEDI        ATELY_AFTER_STOP)
      2021-07-19 16:55:07.814  - info: host.ioBroker instance system.adapter.terminal.0 terminated with code 156 (START_IMM        EDIATELY_AFTER_STOP)
      2021-07-19 16:55:07.815  - info: host.ioBroker instance system.adapter.web.0 terminated with code 156 (START_IMMEDIAT        ELY_AFTER_STOP)
      2021-07-19 16:55:09.027  - warn: host.ioBroker instance system.adapter.mqtt.0 terminated due to SIGTERM
      2021-07-19 16:55:09.027  - info: host.ioBroker instance system.adapter.mqtt.0 terminated with code null ()
      2021-07-19 16:55:09.028  - info: host.ioBroker All instances are stopped.
      2021-07-19 16:55:09.029  - warn: host.ioBroker instance system.adapter.fritzbox.0 terminated due to SIGTERM
      2021-07-19 16:55:09.029  - info: host.ioBroker instance system.adapter.fritzbox.0 terminated with code null ()
      2021-07-19 16:55:09.030  - info: host.ioBroker All instances are stopped.
      2021-07-19 16:55:09.031  - warn: host.ioBroker instance system.adapter.telegram.0 terminated due to SIGTERM
      2021-07-19 16:55:09.032  - info: host.ioBroker instance system.adapter.telegram.0 terminated with code null ()
      2021-07-19 16:55:09.032  - info: host.ioBroker All instances are stopped.
      2021-07-19 16:55:09.535  - error: host.ioBroker-Server Cannot move /opt/iobroker/iobroker-data/objects.json.new to /o        pt/iobroker/iobroker-data/objects.json: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.        json.new'. Try direct write as fallback
      2021-07-19 16:55:09.684  - info: host.ioBroker terminated
      2021-07-19 16:55:13.039  - info: host.ioBroker iobroker.js-controller version 3.3.11 js-controller starting
      2021-07-19 16:55:13.050  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-07-19 16:55:13.052  - info: host.ioBroker hostname: ioBroker, node: v12.22.2
      2021-07-19 16:55:13.053  - info: host.ioBroker ip addresses: 192.168.178.62 2003:df:af19:4700:b7e:694a:44a1:812b fe80        ::6ea7:dc25:16b:d801 fe80::789d:b5ff:fe36:5437
      2021-07-19 16:55:14.288  - info: host.ioBroker connected to Objects and States
      2021-07-19 16:55:14.471  - info: host.ioBroker added notifications configuration of host
      2021-07-19 16:55:15.206  - info: host.ioBroker 27 instances found
      2021-07-19 16:55:15.341  - info: host.ioBroker starting 22 instances
      2021-07-19 16:55:15.494  - info: host.ioBroker instance system.adapter.admin.0 started with pid 6684
      2021-07-19 16:55:19.123  - info: admin.0 (6684) starting. Version 5.1.12 in /opt/iobroker/node_modules/iobroker.admin        , node: v12.22.2, js-controller: 3.3.11
      2021-07-19 16:55:19.335  - info: admin.0 (6684) requesting all states
      2021-07-19 16:55:19.337  - info: admin.0 (6684) requesting all objects
      2021-07-19 16:55:21.270  - info: host.ioBroker instance system.adapter.mqtt.0 started with pid 6699
      2021-07-19 16:55:21.843  - info: admin.0 (6684) received all objects
      2021-07-19 16:55:22.199  - info: admin.0 (6684) https server listening on port 8081
      2021-07-19 16:55:22.202  - info: admin.0 (6684) Use link "https://localhost:8081" to configure.
      2021-07-19 16:55:23.268  - warn: admin.0 (6684) State "admin.0.info.connection" has no existing object, this might le        ad to an error in future versions
      L
      LinusJ
      Das verstehe ich gerade nicht. Welches automatische rebuild beim starten?
      L
      LinusJ
      Okay, Sorry
      pi@ioBroker:~ $ iobroker rebuild rpi2
      npm rebuild --loglevel error (System call1) in "/opt/iobroker/node_modules/iobroker.rpi2"
      Rebuild rpi2 done
      L
      LinusJ
      @thomas-braun Immer noch der gleiche Fehler.
      Also muss es jetzt am Adapter liegen, oder?
      L
      LinusJ
      @thomas-braun Oh, Danke für die schnelle Antwort.
      Ich habe jetzt NodeJS so installiert, wie du es dort berschreiben hast. Der Adapter hat aber immer nochden gleichen Fehlercode!
      Wenn ich
      which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      ausführe kommt:
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.2
      v12.22.2
      6.14.13
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 http://archive.raspberrypi.org/debian buster InRelease
      OK:3 https://deb.nodesource.com/node_12.x buster InRelease
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           12.22.2-1nodesource1
        Installationskandidat: 12.22.2-1nodesource1
        Versionstabelle:
       *** 12.22.2-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
      raus. Das ist doch alles richtig, oder?
      L
      LinusJ
    • RPI2 Adapter steuert GPIOs nicht mehr
      Moin,
      wenn ich node.js und NPM auf die Versionen update, die unten stehen, dann kann der rpi2 Adapter nicht mehr die GPIOs bedienen. Woran könnte das liegen?
      Dieser Fehlercode kommt da:
      rpi2.0 2021-07-19 14:41:54.003	error	cannot use GPIO: TypeError: Cannot read property 'setMode' of null
      rpi2.0 2021-07-19 14:41:53.999	error	Cannot initialize GPIO: Error: The module '/opt/iobroker/node_modules/epoll/build/Release/epoll.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 64. This version of Node.js requires NODE_MODULE_VERSION 72. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
      rpi2.0 2021-07-19 14:41:53.742	error	No Value found for net_send
      rpi2.0 2021-07-19 14:41:53.739	error	No Value found for net_received
      rpi2.0 2021-07-19 14:41:53.684	error	No Value found for cpu_frequency
      Hier die Daten zum System:
      Platform: linux
      Betriebssystem: linux
      Architektur: arm
      CPUs: 4
      Geschwindigkeit: 1200 MHz
      Modell: ARMv7 Processor rev 4 (v7l)
      RAM: 924.21 MB
      Node.js: v12.22.3
      NPM: : 7.20.0
      Festplatte Größe: 58.26 GB
      Festplatte frei: 46.59 GB
      Anzahl der Adapter: 348
      Danke schon mal
      LG Linus
      L
      LinusJ
    • RE: Vis-Inventwo Widgets werden nicht angezeigt
      @Hant0r Nein, ich habe keine Lösung für das Problem! Es gab in der Familie ein neus iPad und das alte (iPad Air2) wurde umfunktioniert in unsere Schaltzentrale.
      L
      LinusJ
    • Vis-Inventwo Widgets werden nicht angezeigt
      Moin,
      Ich habe auf meinem Raspberry Pi3 den Adapter VIS-Inventwo installiert, aber er wird auf dem iPad der 3. Generation nicht angezeigt. Auf jedem anderem iPad, was wir hier im Haus haben, wird es angezeigt! Hat jemand eine Idee wie man das beheben könnte oder ist das ein Fehler im Adapter?
      ioBroker System Informationen:
      Architektur: arm
      RAM: 926.07 MB
      Node.js: v10.19.0
      NPM: 6.13.4
      Version vom Adapter: 1.2.3
      L
      LinusJ
