    2. simar
    simar
    @simar
    14
    simar Follow
    Latest posts made by simar
    • RE: Fehler bei Shelly Adaper Installation
      Habe nach einer neuinstallation leider wieder das selbe Problem. Kann es nicht mit deinen letzten Befehlen lösen. Kannst du bitte nochmals helfen. (weis nicht wie Code Tags einfügen)
      $ ./iobroker url "https://github.com/schmupu/ioBroker.shelly/tarball/master" shelly
      install https://github.com/schmupu/ioBroker.shelly/tarball/master
      NPM version: 6.14.10
      npm install https://github.com/schmupu/ioBroker.shelly/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
      upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
      upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
      upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
      upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
      process exited with code 0
      simar
      @Thomas-Braun said in Fehler bei Shelly Adaper Installation:
      cd /opt/iobroker && npm cache clean --force
      Danke Thomas, hat funktioniert
      simar
      @simar $
      ./iobroker add shelly  --host raspberrypi
      NPM version: 6.14.8
      npm install iobroker.shelly@4.0.3 --loglevel error --prefix "/opt/iobroker" (System call)
      npm
      ERR!
      code
       EINTEGRITY
      npm
       ERR! errno EINTEGRITY
      npm
      ERR! Invalid response body while trying to fetch https://registry.npmjs.org/typedarray: Integrity verification failed for sha512-MOtT4rW6q0jko4EuJ2l25Veb5coa8CP6h7duOR/DLXXk2ZWjFGokVpWSneavhxToXzY0raT74ioxReuXtmKTag== (/home/iobroker/.npm/_cacache/content-v2/sha512/30/eb/53e2b5baab48e4a3812e276976e5579be5ca1af023fa87b76e391fc32d75e4d995a3146a245695929de6af8714e85f3634ada4fbe22a3145eb97b662936a)
      npm
      ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-11-20T11_52_33_378Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.shelly@4.0.3: 1
      ERROR: process exited with code 25
      MOD-Edit: Code in code-tags gesetzt!
      simar
    • Fehler bei Shelly Adaper Installation
      Guten Tag
      beim Versuch den Shelly Adapter zu Installieren bekomme ich immer diese Fehlermeldung. Iobroker läuft auf einem Raspberry pi 3b. Kann mir jemand helfen? Wäre sehr dankbar.
      Grüsse, Markus
      simar
