    2. ahzurdan
    A
    ahzurdan
    @ahzurdan
    ahzurdan Follow
    Latest posts made by ahzurdan
    • RE: [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.
      Hallo Gemeinde,
      ich versuche das Skript auf meinem Pi4 laufen zu lassen (JS 4.8.4, node-mihome da drin eingetragen, user/pass im Skript)
      Ich bekomme aber nur Fehler beim Skriptstart. Was habe ich vergessen?
      vg
      Sven
      javascript.0 2021-01-28 15:17:41.974 error (2380) at Script.runInContext (vm.js:133:20)
      javascript.0 2021-01-28 15:17:41.974 error (2380) at script.js.skripte.Allgemein.Purify:3:16
      javascript.0 2021-01-28 15:17:41.974 error (2380) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:389:36)
      javascript.0 2021-01-28 15:17:41.973 error (2380) at require (internal/modules/cjs/helpers.js:25:18)
      javascript.0 2021-01-28 15:17:41.973 error (2380) at Module.require (internal/modules/cjs/loader.js:692:17)
      javascript.0 2021-01-28 15:17:41.973 error (2380) at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      javascript.0 2021-01-28 15:17:41.973 error (2380) at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      javascript.0 2021-01-28 15:17:41.973 error (2380) at Module.load (internal/modules/cjs/loader.js:653:32)
      javascript.0 2021-01-28 15:17:41.973 error (2380) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      javascript.0 2021-01-28 15:17:41.972 error (2380) at Module._compile (internal/modules/cjs/loader.js:778:30)
      javascript.0 2021-01-28 15:17:41.972 error (2380) at Object.<anonymous> (/opt/iobroker/node_modules/node-mihome/lib/index.js:5:16)
      javascript.0 2021-01-28 15:17:41.972 error (2380) at require (internal/modules/cjs/helpers.js:25:18)
      javascript.0 2021-01-28 15:17:41.972 error (2380) at Module.require (internal/modules/cjs/loader.js:692:17)
      javascript.0 2021-01-28 15:17:41.972 error (2380) at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      javascript.0 2021-01-28 15:17:41.972 error (2380) at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      javascript.0 2021-01-28 15:17:41.972 error (2380) at Module.load (internal/modules/cjs/loader.js:653:32)
      javascript.0 2021-01-28 15:17:41.971 error (2380) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      javascript.0 2021-01-28 15:17:41.971 error (2380) at Module._compile (internal/modules/cjs/loader.js:778:30)
      javascript.0 2021-01-28 15:17:41.971 error (2380) at Object.<anonymous> (/opt/iobroker/node_modules/node-mihome/lib/device.js:1:16)
      javascript.0 2021-01-28 15:17:41.971 error (2380) at require (internal/modules/cjs/helpers.js:25:18)
      javascript.0 2021-01-28 15:17:41.971 error (2380) at Module.require (internal/modules/cjs/loader.js:692:17)
      javascript.0 2021-01-28 15:17:41.971 error (2380) at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      javascript.0 2021-01-28 15:17:41.970 error (2380) at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      javascript.0 2021-01-28 15:17:41.970 error (2380) at Module.load (internal/modules/cjs/loader.js:653:32)
      javascript.0 2021-01-28 15:17:41.970 error (2380) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      javascript.0 2021-01-28 15:17:41.970 error (2380) at Module._compile (internal/modules/cjs/loader.js:778:30)
      javascript.0 2021-01-28 15:17:41.970 error (2380) at Object.<anonymous> (/opt/iobroker/node_modules/node-mihome/lib/models.js:6:54)
      javascript.0 2021-01-28 15:17:41.970 error (2380) at Array.forEach (<anonymous>:null:null)
      javascript.0 2021-01-28 15:17:41.969 error (2380) at glob.sync.forEach.modelPath (/opt/iobroker/node_modules/node-mihome/lib/models.js:9:23)
      javascript.0 2021-01-28 15:17:41.969 error (2380) at require (internal/modules/cjs/helpers.js:25:18)
      javascript.0 2021-01-28 15:17:41.969 error (2380) at Module.require (internal/modules/cjs/loader.js:692:17)
      javascript.0 2021-01-28 15:17:41.969 error (2380) at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      javascript.0 2021-01-28 15:17:41.969 error (2380) at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      javascript.0 2021-01-28 15:17:41.968 error (2380) at Module.load (internal/modules/cjs/loader.js:653:32)
      javascript.0 2021-01-28 15:17:41.968 error (2380) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      javascript.0 2021-01-28 15:17:41.968 error (2380) script.js.skripte.Allgemein.Purify: /opt/iobroker/node_modules/node-mihome/lib/devices/imibar.cooker.mbihr3.js:26
      posted in JavaScript
      A
      ahzurdan
    • RE: Alexa holt sich die Geräte nicht aus der Cloud
      Spannend... in der freien Variante gehts nicht mehr.. Wenn ich IOBroker.pro mit IOT eintrage, dann gehts sofort ohne weitere Änderungen... Nun gut, hab mich mal lizenziert.. das ist es ja auch wert - nur die 2 verlorenen Tage tun weh.
      A
      ahzurdan
    • Alexa holt sich die Geräte nicht aus der Cloud
      Liebe Gemeinde,
      ich finde IOBroker sehr schick und wollte jetzt mein "Alexa, "tu was"" von einer anderen Cloud-Lösung (Homematic mit VPN verbunden u anderer Alexa-Skill) komplett auf IOBroker umstellen.
      Habe auch alle möglichen Tutorials durchgeschaut und konfiguriert - aber bleibe jetzt stecken. Wenn ich die Geräteerkennung (Alexa, aktualisiere Geräte) ausführe, dann findet sie nur die paar HUE-Geräte, die ich habe - aber nichts, was von Homematic kommt (und ja in die iobroker.net-cloud hochgeladen sein sollte).
      Mein Setup:
      Raspi 3 mit IOBroker drauf
      Cloud-Verbindung u App-Key (2.6.2 bzw. 2.7.1 probiert u. Web-Instanz 2.4.1) steht - schon mehrmals installiert- ich sehe auch unter Einstellungen/Smart Geräte meine Geräte, die von der Homematic-RPC-Instanz kommen (Büro Verschluß, Licht Küche und so weiter und so fort) im IOBroker.
      Alexa2 (1.1.3) läuft - da sehe ich unter Objekte die Echos, Multiroom.. halt alles, was die Alexa an sich erkannt hat.
      IOBroker Skill installiert u auch da konfiguriert (app key)... auch den Key schon mehrmals erzeugt und auf dem Adapter sowie dem Skill eingetragen - er sagt auch, dass es gekoppelt ist.
      Den Skill hatte ich auch schon mehrmals deaktiviert/aktiviert.
      Ich würde vermuten, mehr braucht man nicht, damit dann die Geräte, die z.B. die Homematic Instanz liefert, dann bei der Alexa Gerätesuche erkannt werden.
      Habe ich was vergessen?
      --- schnipp ---
      Auzug vom Cloud-Log
      cloud.0 2019-04-06 08:14:37.685 debug Created ALEXA device: Büro Verschluß ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      cloud.0 2019-04-06 08:14:37.685 debug Created ALEXA device: Durchgang Verschluß ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      cloud.0 2019-04-06 08:14:37.684 debug Created ALEXA device: EG Erker Verschluß ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      cloud.0 2019-04-06 08:14:37.684 debug Created ALEXA device: EG Flur Licht.STATE ["turnOn","turnOff"]
      cloud.0 2019-04-06 08:14:37.683 debug Created ALEXA device: Hobbyraum Licht ["setPercentage","incrementPercentage","decrementPercentage","turnOn","turnOff"]
      cloud.0 2019-04-06 08:14:37.683 debug Created ALEXA device: Küche Licht ["turnOn","turnOff","setPercentage","incrementPercentage","decrementPercentage"]
      cloud.0 2019-04-06 08:14:37.682 debug Created ALEXA device: Küche Sicherheit ["turnOn","turnOff"]
      --- schnapp ---
      viele Grüße
      Ahzurdan
      A
      ahzurdan
