  4. Error Code 25 beim Update von vis auf 0.6.12
    5.4k
9 Beiträge 2 Kommentatoren 2.8k Aufrufe
  • htreckslerH Offline
    htreckslerH Offline
    htrecksler
    Forum Testing
    Folgender Eintrag im Log:
    ! 2015-08-16 09:46:09.000 - info: iobroker npm install --production --prefix "C:/Program Files/iobroker/node_modules/iobroker.vis" (System call) 2015-08-16 09:46:10.653 - info: vis.0 starting. Version 0.6.12 in C:/Program Files/iobroker/node_modules/iobroker.vis 2015-08-16 09:46:11.683 - info: iobroker module.js:340 throw err; ^ Error: Cannot find module 'C:\Program Files\iobroker\node_modules\iobroker.vis\node_modules\grunt\lib\grunt' at Function.Module._resolveFilename (module.js:338:15) at Function.Module._load (module.js:280:25) at Function.Module.runMain (module.js:497:10) at startup (node.js:119:16) at node.js:906:3 ! 2015-08-16 09:46:11.683 - info: iobroker 2015-08-16 09:46:11.698 - info: iobroker npm 2015-08-16 09:46:11.698 - info: iobroker 2015-08-16 09:46:11.698 - info: iobroker ERR! iobroker.vis@0.6.12 prepublish: `node node_modules/grunt/lib/grunt prepublish`npm 2015-08-16 09:46:11.698 - info: iobroker ERR! 2015-08-16 09:46:11.698 - info: iobroker Exit status 8npm ERR! 2015-08-16 09:46:11.698 - info: iobroker npm ERR! Failed at the iobroker.vis@0.6.12 prepublish script. npm ERR! 2015-08-16 09:46:11.698 - info: iobroker This is most likely a problem with the iobroker.vis package,npm 2015-08-16 09:46:11.698 - info: iobroker ERR! not with npm itself.npm ERR! Tell the author that this fails on your system: npm ERR! node node_modules/grunt/lib/grunt prepublish npm ERR! You can get their info via: npm ERR! npm owner ls iobroker.vis npm 2015-08-16 09:46:11.698 - info: iobroker ERR! There is likely additional logging output above.npm 2015-08-16 09:46:11.698 - info: iobroker ERR! System Windows_NT 6.1.7601npm ERR! command 2015-08-16 09:46:11.698 - info: iobroker "C:\\Program Files\\nodejs\\\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/iobroker/node_modules/iobroker.vis"npm ERR! cwd C:\Windows\system32 npm ERR! node -v v0.10.29 npm ERR! npm -v 1.4.14 ! 2015-08-16 09:46:11.698 - info: iobroker npm ERR! 2015-08-16 09:46:11.698 - info: iobroker code ELIFECYCLEnpm 2015-08-16 09:46:11.714 - info: iobroker exit 25 !
    js.controller [0.7.7]
    admin [0.5.7]
    Gruss Hermann
    ioBroker auf Proxmox (Debian) auf IntelNuc als Produktivsystem
      htreckslerH Offline
      htrecksler
      Forum Testing
      Nach einem Neustart des Rechners wird jetzt im Admin die Version 0.6.12 angezeigt,
      öffnet man aber vis im edit, so wird dort die 0.6.11 gezeigt.
      Es kam auch nicht die sonst übliche Meldung "neue Version gefunden" beim Start von vis
      Gruss Hermann
        Dann ist sie nicht richtig installiert.
        Versuch es mal mit:
        cd /opt/iobroker/
        npm cache clean
        npm install iobroker.vis --production
        Vielleicht gab es beim update wieder Probleme mit npm
        Rainer
        Gesendet von meinem LIFETAB_S785X mit Tapatalk
          htreckslerH Offline
          htrecksler
          Forum Testing
          hab ich gemacht, und
          • Browserdaten gelöscht
          • vis Adapter neu gestartet
          • vis Adapter entfernt und neu hinzugefügt
          • host neu gestartet
          • gesamten Rechner rebootet
          Ergebnis: im edit Modus von vis wird immer noch die alte Version angezeigt, im log steht aber:
          Gruss Hermann
            OK, dann hat vermutlich der böse Bluefox vergessen im editor die Version anzupassen (???)
            Schönen Sonntag
            Rainer
            EDIT:
            Nein!
            Bei mir steht da 0.6.12!
            Beim Versuch über den link bei instances auf den editor zu kommen erscheint:
            Cannot GET /%web_protocol%://192.168.2.190:%web_port%/vis/edit.html
              htreckslerH Offline
              htrecksler
              Forum Testing
              Unglaublich, oder
              Gruss Hermann
                @htrecksler:
                CODE: ALLES AUSWÄHLEN
                starting. Version 0.6.12 in C:/Program Files/iobroker/node_modules/iobroker.vis[/codee] `
                Da fallen mir nur noch ein:
                im Ordner /opt/iobroker/
                ./iobroker upload vis
                ./iobroker upgrade vis
                jeweils eins von beiden
                und vor dem zweiten vielleicht ein ./iobroker update
                mehr möglichkeiten fallen mir im Moment nicht ein.
                Rainer
                  htreckslerH Offline
                  htrecksler
                  Forum Testing
                  Das wars…
                  iobroker upload vis
                  und danach
                  iobroker update
                  jetzt steht auch im edit-Modus die richtige version
                  Gruss Hermann
                    Die Reihenfolge bringt nix.
                    Der upload wars dann
                    Dann viel Spaß damit
                    Rainer
