  4. [Fehler] Vis/Web Adapter (mehr kann ich leider nicht beschreiben)
    5.6k
4 Beiträge 2 Kommentatoren 1.0k Aufrufe
    andyb
    Ich hab im Log folgende Fehler wenn ich versuche Vis edit zu öffnen. Vis view funktioniert aber.
    Das öffnen von Vis edit scheitert mit "no connection"
    Alle Adapter aktuell auf Stand latest.
    host.orangepiplus2e	2017-11-06 07:54:13.881	info	Restart adapter system.adapter.web.0 because enabled
    host.orangepiplus2e	2017-11-06 07:54:13.881	error	instance system.adapter.web.0 terminated with code 0 (OK)
    host.orangepiplus2e	2017-11-06 07:54:13.881	error	Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    host.orangepiplus2e	2017-11-06 07:54:13.880	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    host.orangepiplus2e	2017-11-06 07:54:13.880	error	Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    host.orangepiplus2e	2017-11-06 07:54:13.880	error	Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.orangepiplus2e	2017-11-06 07:54:13.879	error	Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    host.orangepiplus2e	2017-11-06 07:54:13.879	error	Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    host.orangepiplus2e	2017-11-06 07:54:13.879	error	Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.orangepiplus2e	2017-11-06 07:54:13.878	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    host.orangepiplus2e	2017-11-06 07:54:13.878	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    host.orangepiplus2e	2017-11-06 07:54:13.877	error	Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2872:17)
    host.orangepiplus2e	2017-11-06 07:54:13.873	error	Caught by controller[0]: RangeError: Maximum call stack size exceeded
    web.0	2017-11-06 07:54:13.678	error	uncaught exception: Maximum call stack size exceeded
    Edit:
    über https://iobroker.pro/vis/edit.html?mobil#main komme ich ohne Fehlermeldung drauf
    über 192.xxx.xxx.xxx:8082/vis/edit.html?mobil#main geht nix
    Versteh ich nicht…..
      andyb
      Keiner nen Tip? :-(
      • htreckslerH Offline
        htreckslerH Offline
        htrecksler
        Forum Testing
        nur ein Versuch… so eine Meldung hatte ich noch nie...
        was ist wenn du vis im Ansichtsmodus öffnest und dann in der befehlsleiste das index in edit änderst?
        Gruss Hermann
        ioBroker auf Proxmox (Debian) auf IntelNuc als Produktivsystem
          andyb
          Sehr komisch, dann gehts….
          Schließe ich den Browser aber und gehe dann gleich mit dem edit link rein gehts nicht
          Klicke ich im "Instanzen" Reiter öffnet er den Editor mit meinem anderen Projekt, geh ich dann über Projekte auf mein anderes Projekt gehts auch wieder nicht....
          Sehr komisch. Mal beobachten
