  4. 0.6.5 installation
    5.4k
0.6.5 installation
41 Beiträge 10 Kommentatoren 7.9k Aufrufe
    Pman
    Ich kann die 0.6.5 nicht installieren. Log:
    install adapter vis
    npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
    npm
    WARN cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
    got /opt/iobroker/node_modules/iobroker.vis/admin
    upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
    upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
    ERROR:
    ERROR: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
    ERROR:                             console.warn('Adapter "' + obj._id + ' is disabled                                                          ^
    ERROR: TypeError: Cannot read property '_id' of null    at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
        at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
        at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
        at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
        at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
        at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
        at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
        at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
    ERROR: process exited with code 8</anonymous></anonymous></anonymous>
      Ich hab es auch gerade probiert.
      Lief sehr schnell, konnte daher nicht alles sehen
      War auch ein cannot run in wd dabei, dann lief es schnell weiter und endete schließlich in exit with code 0 OK!
      Habe es am tablet über den admin gemacht. Komme im Moment auch nicht an das vollständige log.
      Rainer
      Gesendet von meinem LIFETAB_S785X mit Tapatalk
        Pman
        Habe schon alles probiert, löschen und neu installieren gibt den selben Fehler. Irgendwas ist da wohl wieder schief gelaufen bei mir :evil:
          Hast du beim controller die 0.7.4?
            Pman
            Ja, 0.7.4 und auch sonst alles auf neustem Stand.
            EDIT:
            iobroker update gibt viele Fehler:
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-material-png/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-material-svg/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-mfd-png/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-mfd-svg/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-open-icon-library-png/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-ultimate-png/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.javascript/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.knx/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.legacy/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.megad/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.mqtt/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.node-red/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.ping/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.s7/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sayit/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.simple-api/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.socketio/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.owfs/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.pushover/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.rickshaw/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sonos/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis-colorpicker/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis-hqwidgets/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis-lcars/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis-metro/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.web/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.zwave/master/package.json. Error: Error: ETIMEDOUT
            Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.yr/master/package.json. Error: Error: ETIMEDOUT
            update done
            Adapter    "zwave"         : 0.1.0
            Adapter    "yr"            : 0.1.7
            Adapter    "web"           : 0.4.2    , installed 0.4.2
            Adapter    "vis-metro"     : 0.1.2
            Adapter    "vis-lcars"     : 0.1.4
            Adapter    "vis-hqwidgets" : 0.1.0
            Adapter    "vis-colorpicker": 0.1.0
            Adapter    "vis"           : 0.6.5
            Adapter    "sonos"         : 0.1.6
            Adapter    "rickshaw"      : 0.2.2
            Adapter    "pushover"      : 0.1.1    , installed 0.1.1
            Adapter    "owfs"          : 0.0.2
            Adapter    "onkyo"         : 0.1.9
            Adapter    "socketio"      : 0.4.4
            Adapter    "simple-api"    : 0.1.1
            Adapter    "sayit"         : 0.3.9
            Adapter    "s7"            : 0.1.2
            Adapter    "ping"          : 0.1.4    , installed 0.1.4
            Adapter    "node-red"      : 0.3.3
            Adapter    "mqtt"          : 0.2.9    , installed 0.2.9
            Adapter    "megad"         : 0.1.1
            Adapter    "legacy"        : 0.1.12
            Adapter    "knx"           : 0.0.1
            Controller "js-controller" : 0.7.4    , installed 0.7.4
            Adapter    "javascript"    : 0.4.13   , installed 0.4.13
            Adapter    "icons-ultimate-png": 0.1.0    , installed 0.1.0
            Adapter    "icons-open-icon-library-png": 0.1.1
            Adapter    "icons-mfd-svg" : 0.1.0    , installed 0.1.0
            Adapter    "icons-mfd-png" : 0.1.0
            Adapter    "icons-material-svg": 0.1.0
            Adapter    "icons-material-png": 0.1.0
            Adapter    "icons-addictive-flavour-png": 0.1.0
            Adapter    "ical"          : 1.0.2
            Adapter    "hmm"           : 0.1.1    , installed 0.1.1
            Adapter    "hue"           : 0.3.0    , installed 0.3.0
            Adapter    "hm-rpc"        : 0.5.1    , installed 0.5.1
            Adapter    "hm-rega"       : 0.2.2    , installed 0.2.2
            Adapter    "history"       : 0.1.3
            Adapter    "example"       : 0.1.1    , installed 0.1.1
            Adapter    "fritzbox"      : 0.2.1
            Adapter    "flot"          : 0.1.1
            Adapter    "email"         : 0.1.2
            Adapter    "dwd"           : 0.1.9    , installed 0.1.9
            Adapter    "cul"           : 0.0.4
            Adapter    "b-control-em"  : 0.1.1
            Adapter    "artnet"        : 0.0.3
            Adapter    "admin"         : 0.5.4    , installed 0.5.4
            • htreckslerH Offline
              htreckslerH Offline
              htrecksler
              Forum Testing
              Bei mir hat's geklappt. Erst den Controller und dann vis.
              Anschließend kompletter Neustart. –> läuft.
              Nur die paar hqwidgets die ich im Einsatz hatte sind jetzt weg.
              Also immer schön Bluefox in Ruhe lassen damit er die fertig kriegt :D :D :D
              Gruss Hermann
              ioBroker auf Proxmox (Debian) auf IntelNuc als Produktivsystem
                @Pman:
                EDIT:
                iobroker update gibt viele Fehler: `
                Ja, seit ca. zwei Wochen gibt es bei der Art update die Timeouts.
                Vielleicht sind es ja die Ursachen für dein Problem.
                Außerdem scheint es für mich, als ob der npm-server am Wochenende immer Probleme hat.
                Ein Versuch (von einem Laien):
                cd /opt/iobroker
                npm cache clean
                npm install iobroker.vis --production
                Viel Glück
                Rainer
                  Pman
                  npm http GET https://registry.npmjs.org/iobroker.vis
                  npm http 200 https://registry.npmjs.org/iobroker.vis
                  npm http GET https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.6.5.tgz
                  npm http 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.6.5.tgz
                  > iobroker.vis@0.6.5 install /opt/iobroker/node_modules/iobroker.vis
                  2015-07-26 10:51:07.185  - info: vis.0 starting. Version 0.6.5 in /opt/iobroker/node_modules/iobroker.vis
                  2015-07-26 10:51:10.467  - info: vis.0 Changes in index.html detected => update cache.manifest
                  2015-07-26 10:51:10.525  - info: vis.0 Upload vis anew, while changes detected...
                  2015-07-26 10:51:16.656  - error: vis.0
                  2015-07-26 10:51:16.663  - error: vis.0 /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275                            console.warn('Adapter "' + obj._id + ' is disabled
                  2015-07-26 10:51:16.945  - error: vis.0 TypeError: Cannot read property '_id' of null    at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                  2015-07-26 10:51:16.984  - info: vis.0 Uploaded.
                  iobroker.vis@0.6.5 node_modules/iobroker.vis</anonymous></anonymous></anonymous>
                    Also mit den Fehlermeldungen müsste Bluefox was anfangen können - ich kann es nicht :(
                    Nur noch vorsorglich die Frage zu deiner Hardware:
                    Deinen anderen posts hatte ich entnommen, dass du vielleicht mit Äpfeln arbeitest ???
                    Rainer
                      susouke
                      also ich kann das Problem bestätigen. Leider bin ich noch sehr neu was ccu.io/iobroker angeht.
                      Hab gerade meine raspberrypi2 neu aufgesetzt und iobroker neu installiert, jetzt hänge ich bei dem beschriebenen Problem mit "VIS" fest.
                      Es war also nichts installiert außer das nackte Raspian, nodejs ist 0.10.22
                      Vorher lief iobroker ohne Probleme, allerdings weiß ich nicht mehr welche Version ich verwendet habe. Das Setup war ca. 2 Wochen alt.
                        Hallo susouke und Willkommen im Forum,
                        @susouke:
                        Hab gerade meine raspberrypi2 neu aufgesetzt und iobroker neu installiert, `
                        komplett neu - jetzt gerade??
                        RasPi plattgemacht??
                        @susouke:
                        Vorher lief iobroker ohne Probleme, allerdings weiß ich nicht mehr welche Version ich verwendet habe. Das Setup war ca. 2 Wochen alt. `
                        hast du da drüberinstalliert?
                        Rainer
                          susouke
                          @susouke:
                          RasPi plattgemacht?? `
                          Den Raspi2 hab ich extra für ccu.io bestellt und danach festgestellt das iobroker doch etwas cooler ist :D
                          Das ganze Thema ist noch sehr neu für mich, hab über noobs einfach das Image neu installiert (das wird ersetzt).
                          Also iobroker ist komplett gelöscht und muss dann neu installiert werden. Das habe ich gemacht und jetzt hänge ich fest :D
                            @susouke:
                            Also iobroker ist komplett gelöscht und muss dann neu installiert werden. Das habe ich gemacht und jetzt hänge ich fest `
                            Bei einem neueinspielen des Images wohl eher "ausradiert" ;-)
                            Gut,
                            Installation, gemäß http://www.iobroker.net/docu/?page_id=4 … stallation ??
                            • nodejs installiert
                            • mkdir /opt/iobroker
                            • cd /opt/iobroker
                            • npm install iobroker
                            Danach bist du noch auf den admin gekommen?
                            • von dort aus vis-Instanz erstellt?
                            • Aufruf von <ipdesraspi>:8082/vis/edit.html klappt nicht??
                            Irgendwelche Fehlermeldungen in der Konsole?
                            Irgendwelche Fehlermeldungen im log?
                            Soweit erstmal
                            Rainer</ipdesraspi>
                              susouke
                              Ja genau so habe ich es gemacht inkl. das mit root.
                              Admin-Seite geht ohne Probleme darüber wollte ich dan vis installieren, das ist die Ausgabe:
                              ! $ ./iobroker add vis
                              ! install adapter vis
                              ! npm install –production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
                              ! npm
                              ! WARN cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
                              ! got /opt/iobroker/node_modules/iobroker.vis/admin
                              ! upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                              ! upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                              ! ERROR:
                              ! ERROR: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                              ! ERROR: console.warn('Adapter "' + obj._id + ' is disabled ^
                              ! ERROR: TypeError: Cannot read property '_id' of null at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                              ! at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                              ! at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
                              ! at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                              ! at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                              ! at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
                              ! at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                              ! at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                              ! at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                              ! at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
                              ! ERROR: process exited with code 8</anonymous></anonymous></anonymous>
                              Das gleiche steht natürlich auch im normalen log.
                              Ich kann schauen ob in der Konsole noch was kommt…
                                Das müsste Bluefox sich ansehen, Sorry
                                Rainer
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  @susouke:
                                  ! npm
                                  ! ERROR:
                                  Ich kann schauen ob in der Konsole noch was kommt… `
                                  Es ist folgendes. Normalerweise ist vis "enabled". Bei dir es ist disabled. (Kann das sein?)
                                  Du kannst trotzdem einfach vis updaten mit:
                                  cd /opt/iobroker
                                    susouke
                                    VIS ist nicht enabled, es wird als installiert angezeigt in der Adapterliste (zumindest ist die Mülltonne zum entfernen da).
                                    Es taucht aber nicht in der Instanzliste auf. Hab schon mehrfach ein update gemacht und auch nochmal neu installiert.
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      @susouke:
                                      Es taucht aber nicht in der Instanzliste auf. Hab schon mehrfach ein update gemacht und auch nochmal neu installiert. `
                                      Mülltonne zeigt, dass Adapter auf der Festplatte ist und mit der Mülltonne kann man den von der Festplatte löschen.
                                      Instanz braucht man trotzdem.
                                        Es taucht solange nicht in der Instanzenliste auf, bis du es zugefügt hast.
                                        Im Reiter Adapter auf das + ganz rechts klicken, oder in der Konsole mit
                                        cd /opt/iobroker
                                        ./iobroker add vis
                                        Rainer
                                          Pman
                                          Der selbe Fehler kommt ja, wenn ich vis garnicht installiert habe (Verzeichnis iobroker.vis existiert auch nicht), nicht beim Update. Das Log im ersten Post ist bei der Installation von vis, nicht beim update.
