  3. Einsteigerfragen
  4. syncthing " .. signature verification"-Fehler
    5.3k
3 Beiträge 2 Kommentatoren 270 Aufrufe 2 Beobachtet
  • hruH Offline
    hruH Offline
    hru
    ich bekomme bei sudo apt update die Meldung
    Err:16 https://apt.syncthing.net syncthing InRelease
      Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key FBA2E162F2F44657B38F0309E5665F9BD5970C47, which is needed to verify signature. Signing key on 37C84554E7E0A261E4F76E1ED26E6ED000654A3E is not bound:            No binding signature at time 2026-01-31T01:39:55Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    Fetched 84.5 kB in 1s (152 kB/s)
    All packages are up to date.
    Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://apt.syncthing.net syncthing InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key FBA2E162F2F44657B38F0309E5665F9BD5970C47, which is needed to verify signature. Signing key on 37C84554E7E0A261E4F76E1ED26E6ED000654A3E is not bound:            No binding signature at time 2026-01-31T01:39:55Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    Warning: Failed to fetch https://apt.syncthing.net/dists/syncthing/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key FBA2E162F2F44657B38F0309E5665F9BD5970C47, which is needed to verify signature. Signing key on 37C84554E7E0A261E4F76E1ED26E6ED000654A3E is not bound:            No binding signature at time 2026-01-31T01:39:55Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    Warning: Some index files failed to download. They have been ignored, or old ones used instead.
    Was muss ich tun, um die Signatur zu aktualisieren?
    Danke und Gruß
    Hartmut
    PV-Anlage:
    13,5 kWp, WR: Sungrow SH10RT, Speicher: Sungrow SBR128, Heizstab: MyPV AC ELWA2
    Sonstige Geräte:
    ShellyPlusSmoke Rauchwarnmelder, Shelly Gas Warnmelder, Shelly Flood,
    IR-Leseköpfe für Stromzähler
    • hruH hru
      Danke und Gruß
      Hartmut
      @hru sagte in syncthing " .. signature verification"-Fehler:
      Du musst den Key bzw. das entsprechende Repository nochmal installieren.
      Hier steht wie das geht:
      • hruH Offline
        hruH Offline
        hru
        super, hat funktioniert!
        Vielen Dank für die schnelle und kompetente Unterstützung!
        Gruß Hartmut
        PV-Anlage:
        Sonstige Geräte:
