  4. SMA Semp Adapter meldet Fehler
    6.5k
12 Beiträge 2 Kommentatoren 500 Aufrufe 2 Beobachtet
  • Y Offline
    Y Offline
    yablu87
    mein SMA Semp Adapter 1.5.3 gibt seit heute Fehlermeldungen aus. Liegt es daran, dass er nicht mit node.js 20.18.0 kompatibel ist? Es lief aber die ganze Zeit und ich habe nichts verändert.
    Viele Grüße
    2025-11-30 12:51:35.070 - info: host.ioBroker-new Restart adapter system.adapter.semp.0 because enabled
    2025-11-30 12:52:05.618 - info: host.ioBroker-new instance system.adapter.semp.0 in version "1.5.3" started with pid 192016
    2025-11-30 12:52:06.015 - error: host.ioBroker-new Caught by controller[0]: /opt/iobroker/node_modules/iobroker.semp/main.js:11
    2025-11-30 12:52:06.016 - error: host.ioBroker-new Caught by controller[0]: const { v4: uuidv4 } = require("uuid");
    2025-11-30 12:52:06.016 - error: host.ioBroker-new Caught by controller[0]: ^
    2025-11-30 12:52:06.016 - error: host.ioBroker-new Caught by controller[0]: Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.semp/node_modules/uuid/dist-node/index.js from /opt/iobroker/node_modules/iobroker.semp/main.js not supported.
    2025-11-30 12:52:06.016 - error: host.ioBroker-new Caught by controller[0]: Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.semp/main.js to a dynamic import() which is available in all CommonJS modules.
    2025-11-30 12:52:06.016 - error: host.ioBroker-new Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.semp/main.js:11:24) {
    2025-11-30 12:52:06.016 - error: host.ioBroker-new Caught by controller[0]: code: 'ERR_REQUIRE_ESM'
    2025-11-30 12:52:06.016 - error: host.ioBroker-new Caught by controller[0]: }
    2025-11-30 12:52:06.016 - error: host.ioBroker-new Caught by controller[1]: Node.js v20.18.0
    2025-11-30 12:52:06.016 - error: host.ioBroker-new instance system.adapter.semp.0 terminated with code 1 (JS_CONTROLLER_STOPPED)```
    • Y yablu87
      Viele Grüße
      @yablu87
      Wie ist der Gesamtzustand der Kiste? Gib mal die Ausgabe von
      iob diag
      zum Besten.
      • Y Offline
        Y Offline
        yablu87
        2025-11-30 13:13:23.091  - info: host.ioBroker-new Restart adapter system.adapter.semp.0 because enabled
        2025-11-30 13:13:53.663  - info: host.ioBroker-new instance system.adapter.semp.0 in version "1.5.3" started with pid 192326
        2025-11-30 13:13:54.065  - error: host.ioBroker-new Caught by controller[0]: /opt/iobroker/node_modules/iobroker.semp/main.js:11
        2025-11-30 13:13:54.065  - error: host.ioBroker-new Caught by controller[0]: const { v4: uuidv4 } = require("uuid");
        2025-11-30 13:13:54.065  - error: host.ioBroker-new Caught by controller[0]:                        ^
        2025-11-30 13:13:54.065  - error: host.ioBroker-new Caught by controller[0]: Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.semp/node_modules/uuid/dist-node/index.js from /opt/iobroker/node_modules/iobroker.semp/main.js not supported.
        2025-11-30 13:13:54.065  - error: host.ioBroker-new Caught by controller[0]: Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.semp/main.js to a dynamic import() which is available in all CommonJS modules.
        2025-11-30 13:13:54.065  - error: host.ioBroker-new Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.semp/main.js:11:24) {
        2025-11-30 13:13:54.065  - error: host.ioBroker-new Caught by controller[0]:   code: 'ERR_REQUIRE_ESM'
        2025-11-30 13:13:54.066  - error: host.ioBroker-new Caught by controller[0]: }
        2025-11-30 13:13:54.066  - error: host.ioBroker-new Caught by controller[1]: Node.js v20.18.0
        2025-11-30 13:13:54.066  - error: host.ioBroker-new instance system.adapter.semp.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2025-11-30 13:13:54.066  - info: host.ioBroker-new Restart adapter system.adapter.semp.0 because enabled
        2025-11-30 13:14:25.085  - info: host.ioBroker-new instance system.adapter.semp.0 in version "1.5.3" started with pid 192566
        2025-11-30 13:14:25.874  - error: host.ioBroker-new Caught by controller[0]: /opt/iobroker/node_modules/iobroker.semp/main.js:11
        2025-11-30 13:14:25.874  - error: host.ioBroker-new Caught by controller[0]: const { v4: uuidv4 } = require("uuid");
        2025-11-30 13:14:25.878  - error: host.ioBroker-new Caught by controller[0]:                        ^
        2025-11-30 13:14:25.878  - error: host.ioBroker-new Caught by controller[0]: Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.semp/node_modules/uuid/dist-node/index.js from /opt/iobroker/node_modules/iobroker.semp/main.js not supported.
        2025-11-30 13:14:25.878  - error: host.ioBroker-new Caught by controller[0]: Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.semp/main.js to a dynamic import() which is available in all CommonJS modules.
        2025-11-30 13:14:25.878  - error: host.ioBroker-new Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.semp/main.js:11:24) {
        2025-11-30 13:14:25.878  - error: host.ioBroker-new Caught by controller[0]:   code: 'ERR_REQUIRE_ESM'
        2025-11-30 13:14:25.878  - error: host.ioBroker-new Caught by controller[0]: }
        2025-11-30 13:14:25.878  - error: host.ioBroker-new Caught by controller[1]: Node.js v20.18.0
        2025-11-30 13:14:25.878  - error: host.ioBroker-new instance system.adapter.semp.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2025-11-30 13:14:25.878  - info: host.ioBroker-new Restart adapter system.adapter.semp.0 because enabled
        • Y Offline
          Y Offline
          yablu87
          ist das richtig?
          • Y yablu87
            ist das richtig?
            @yablu87
            Nein. Gib in deinem Terminal
            iob diag
            ein und poste die vollständige Ausgabe hier.
            • Y Offline
              Y Offline
              yablu87
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
               Static hostname: ioBroker-new
                     Icon name: computer-container
                       Chassis: container ☐
                Virtualization: lxc
                        Kernel: Linux 6.8.12-1-pve
                  Architecture: x86-64
              OS is similar to:
              model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
              Docker          : false
              Virtualization  : lxc
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               13:14:23 up 184 days, 20:12,  2 users,  load average: 0.92, 0.51, 0.37
              CPU threads: 1
              *** LIFE CYCLE STATUS ***
              Operating System is the current Debian stable version codenamed 'bookworm'!
              *** TIME AND TIMEZONES ***
                             Local time: Sun 2025-11-30 13:14:23 CET
                         Universal time: Sun 2025-11-30 12:14:23 UTC
                               RTC time: n/a
                            NTP service: inactive
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              admin
              HOME=/home/admin
              GROUPS=admin sudo users iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev
              *** DISPLAY-SERVER SETUP ***
              Display-Server:         false
              Unit display-manager.service could not be found.
              Display-Manager:
              Desktop:
              Session:
              *** MEMORY ***
              Mem:            4.3G        1.7G        1.2G         53K        1.4G        2.6G
              Swap:           536M        8.1M        528M
              Total:          4.8G        1.7G        1.8G
              Active iob-Instances:   20
                       4096 M total memory
                       1619 M used memory
                       1545 M active memory
                       1093 M inactive memory
                       1173 M free memory
                          0 M buffer memory
                       1302 M swap cache
                        512 M total swap
                          7 M used swap
                        504 M free swap
              top - 13:14:23 up 184 days, 20:12,  2 users,  load average: 0.92, 0.51, 0.37
              Tasks:  43 total,   1 running,  42 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   4096.0 total,   1172.4 free,   1621.0 used,   1302.7 buff/cache
              MiB Swap:    512.0 total,    504.3 free,      7.7 used.   2475.0 avail Mem
              *** FAILED SERVICES ***
                UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
              * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
              * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
              * postfix@-.service       loaded failed failed Postfix Mail Transport Agent (instance -)
              3 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              dmesg: read kernel buffer failed: Operation not permitted
              No critical errors detected
              *** FILESYSTEM ***
              Filesystem                       Type      Size  Used Avail Use% Mounted on
              /dev/mapper/pve-vm--100--disk--0 ext4       32G  7.0G   23G  24% /
              none                             tmpfs     492K  4.0K  488K   1% /dev
              udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
              tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
              tmpfs                            tmpfs     3.2G  108K  3.2G   1% /run
              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
              Show mounted filesystems:
              TARGET SOURCE                           FSTYPE OPTIONS
              /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
              /var:
              820M    /var/
              357M    /var/log/journal/a85bfdc919744c72bbde1c27b0f38790
              357M    /var/log
              315M    /var/cache
              Archived and active journals take up 42.0M in the file system.
              /opt/iobroker/backups:
              646M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              602M    /opt/iobroker/iobroker-data/
              295M    /opt/iobroker/iobroker-data/files
              248M    /opt/iobroker/iobroker-data/backup-objects
              47M     /opt/iobroker/iobroker-data/files/admin.admin
              46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
              34M     /opt/iobroker/iobroker-data/states.jsonl
              24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
              19M     /opt/iobroker/iobroker-data/objects.jsonl
              11M     /opt/iobroker/iobroker-data/files/vis.0/main/img/Hintergrundbild_+.jpg
              11M     /opt/iobroker/iobroker-data/files/vis-2.0/main/img/Hintergrundbild_+.jpg
              USB-Devices by-id:
              No Devices found 'by-id'
              *** ZigBee Settings ***
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.18.0
              /usr/bin/node           v20.18.0
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.29.3
              nodejs:
                Installed: 20.18.0-1nodesource1
                Candidate: 20.19.6-1nodesource1
                Version table:
                   20.19.6-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                   20.19.5-1nodesource1 1001
                   20.19.4-1nodesource1 1001
                   20.19.3-1nodesource1 1001
                   20.19.2-1nodesource1 1001
                   20.19.1-1nodesource1 1001
                   20.19.0-1nodesource1 1001
                   20.18.3-1nodesource1 1001
                   20.18.2-1nodesource1 1001
                   20.18.1-1nodesource1 1001
               *** 20.18.0-1nodesource1 1001
                      100 /var/lib/dpkg/status
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.20.4+dfsg-1~deb12u1 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                      500 http://security.debian.org bookworm-security/main amd64 Packages
              No problems detected
              Errors in npm tree: 0
              The current Node.js version (v20.18.0) is vulnerable to the following CVEs:
              CVE-2025-23083(high): With the aid of the diagnostics_channel utility, an event can be hooked into whenever a worker thread is created. This is not limited only to workers but also exposes internal workers, where an instance of them can be fetched, and its constructor can be grabbed and reinstated for malicious usage.
              This vulnerability affects Permission Model users (--permission) on Node.js v20, v22, and v23.
              Patched versions: ^20.18.2 || ^22.13.1 || ^23.6.1
              CVE-2025-23085(medium): A memory leak could occur when a remote peer abruptly closes the socket without sending a GOAWAY notification. Additionally, if an invalid header was detected by nghttp2, causing the connection to be terminated by the peer, the same leak was triggered. This flaw could lead to increased memory consumption and potential denial of service under certain conditions.
              This vulnerability affects HTTP/2 Server users on Node.js v18.x, v20.x, v22.x and v23.x.
              Patched versions: ^18.20.6 || ^20.18.2 || ^22.13.1 || ^23.6.1
              CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
              Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
              CVE-2025-23167(medium): A flaw in Node.js 20's HTTP parser allows improper termination of HTTP/1 headers using `\r\n\rX` instead of the required `\r\n\r\n`.
              This inconsistency enables request smuggling, allowing attackers to bypass proxy-based access controls and submit unauthorized requests.
              The issue was resolved by upgrading `llhttp` to version 9, which enforces correct header termination.
              Impact:
              * This vulnerability affects only Node.js 20.x users prior to the `llhttp` v9 upgrade.
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              ioBroker-new        ioBroker-new (version: 7.0.7, hostname: ioBroker-new  , alive, uptime: 4337)
              Core adapters versions
              js-controller:  7.0.7
              admin:          7.7.19
              javascript:     9.0.11
              nodejs modules from github:     1
              +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#cca20bad1deed833cc044cbdf12888045fd89cdb)
              Adapter State
              + system.adapter.admin.0                  : admin                 : ioBroker-new                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : ioBroker-new                             -  enabled
              + system.adapter.backitup.0               : backitup              : ioBroker-new                             -  enabled
              + system.adapter.cloud.0                  : cloud                 : ioBroker-new                             -  enabled
              + system.adapter.device-reminder.0        : device-reminder       : ioBroker-new                             -  enabled
                system.adapter.devices.0                : devices               : ioBroker-new                             - disabled
                system.adapter.discovery.0              : discovery             : ioBroker-new                             - disabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker-new                             -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker-new                             -  enabled
              + system.adapter.go-e.0                   : go-e                  : ioBroker-new                             -  enabled
                system.adapter.go-e.1                   : go-e                  : ioBroker-new                             - disabled
              + system.adapter.ham.0                    : ham                   : ioBroker-new                             -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-new                             -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : ioBroker-new                             - disabled
                system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-new                             - disabled
                system.adapter.influxdb.0               : influxdb              : ioBroker-new                             - disabled, port: 8086
                system.adapter.influxdb.1               : influxdb              : ioBroker-new                             - disabled, port: 8086
              + system.adapter.iot.0                    : iot                   : ioBroker-new                             -  enabled
              + system.adapter.javascript.0             : javascript            : ioBroker-new                             -  enabled
              + system.adapter.modbus.0                 : modbus                : ioBroker-new                             -  enabled
              + system.adapter.modbus.1                 : modbus                : ioBroker-new                             -  enabled
              + system.adapter.node-red.0               : node-red              : ioBroker-new                             -  enabled, port: 1880, bind: 0.0.0.0
                system.adapter.pushover.0               : pushover              : ioBroker-new                             - disabled
              + system.adapter.roborock.0               : roborock              : ioBroker-new                             -  enabled
                system.adapter.semp.0                   : semp                  : ioBroker-new                             -  enabled
                system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-new                             - disabled
              + system.adapter.tradfri.0                : tradfri               : ioBroker-new                             -  enabled
              + system.adapter.tuya.0                   : tuya                  : ioBroker-new                             -  enabled
                system.adapter.vis-2.0                  : vis-2                 : ioBroker-new                             - disabled
                system.adapter.vis-homekittiles.0       : vis-homekittiles      : ioBroker-new                             - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-new                             - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-new                             - disabled
                system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-new                             - disabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-new                             - disabled
                system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-new                             - disabled
                system.adapter.vis-metro.0              : vis-metro             : ioBroker-new                             - disabled
                system.adapter.vis.0                    : vis                   : ioBroker-new                             -  enabled
              + system.adapter.web.0                    : web                   : ioBroker-new                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              │ (index) │ name               │ url                                                     │ auto upgrade │
              │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
              │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
              Upgrade policy: none
              Installed ioBroker-Adapters
              Adapter    "admin"        : 7.7.19   , installed 7.7.19
              Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
              Adapter    "backitup"     : 3.3.10   , installed 3.3.10
              Adapter    "cloud"        : 5.0.1    , installed 5.0.1
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "devices"      : 1.2.8    , installed 1.2.8
              Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
              Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
              Adapter    "go-e"         : 1.0.41   , installed 1.0.41
              Adapter    "ham"          : 5.3.1    , installed 5.3.1
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "ical"         : 1.18.1   , installed 1.18.1
              Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
              Adapter    "iot"          : 5.0.7    , installed 5.0.7
              Adapter    "javascript"   : 9.0.11   , installed 9.0.11
              Controller "js-controller": 7.0.7    , installed 7.0.7
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "node-red"     : 5.2.1    , installed 5.2.1
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "roborock"     : 0.6.18   , installed 0.6.18
              Adapter    "semp"         : 1.5.4    , installed 1.5.3  [Updatable]
              Adapter    "socketio"     : 6.7.1    , installed 7.0.8
              Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
              Adapter    "vis-homekittiles": 0.4.6 , installed 0.4.6
              Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
              Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
              Adapter    "web"          : 7.0.8    , installed 7.0.8
              Adapter    "ws"           : 2.6.2    , installed 3.0.19
              Objects and States
              Objects:        6561
              States:         5642
              Hit:1 http://security.debian.org bookworm-security InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 152
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       393503749  190967/node-red
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9473       1/init
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       393499900  190856/iobroker.js-
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       393499895  190856/iobroker.js-
              tcp        0      0 192.168.178.33:2001     0.0.0.0:*               LISTEN      1001       393503834  191027/io.hm-rpc.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          9573       1/init
              tcp6       0      0 :::111                  :::*                    LISTEN      0          9475       1/init
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       393504457  191205/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       393500019  190874/io.admin.0
              tcp6       0      0 :::7906                 :::*                    LISTEN      1001       393504456  190984/io.roborock.
              tcp6       0      0 :::6824                 :::*                    LISTEN      1001       393504455  190984/io.roborock.
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       393504194  191105/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       393504195  191105/io.tuya.0
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9474       1/init
              udp        0      0 0.0.0.0:43912           0.0.0.0:*                           1001       393504651  191257/io.tradfri.0
              udp6       0      0 :::111                  :::*                                0          9476       1/init
              • Y yablu87
                ```bash
                Script v.2025-08-09
                *** BASE SYSTEM ***
                  Virtualization: lxc
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 1
                                 RTC time: n/a
                          RTC in local TZ: no
                admin
                HOME=/home/admin
                iobroker
                HOME=/home/iobroker
                Display-Manager:
                Desktop:
                Session:
                *** MEMORY ***
                         4096 M total memory
                         1619 M used memory
                         1173 M free memory
                            0 M buffer memory
                         1302 M swap cache
                          512 M total swap
                            7 M used swap
                          504 M free swap
                *** FILESYSTEM ***
                /var:
                820M    /var/
                357M    /var/log
                315M    /var/cache
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                Impact:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.7.19
                javascript:     9.0.11
                Adapter State
                + instance is alive
                Objects and States
                Objects:        6561
                States:         5642
                @yablu87 sagte in SMA Semp Adapter meldet Fehler:
                DRINGEND updaten...
                Und künftig regelmäßig aktuell halten.
                In den nächster Zeit solltest du ohnehin einen aktuellen Container auf Basis von 'Trixie'/ Debian 13 ausrollen.
                sudo apt update
                sudo apt full-upgrade
                Und dann auch nodejs updaten:
                iob nodejs-update
                Y 1 Antwort Letzte Antwort
                • Y yablu87
                  ```bash
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 1
                                   RTC time: n/a
                            RTC in local TZ: no
                  admin
                  HOME=/home/admin
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:
                  Desktop:
                  Session:
                  *** MEMORY ***
                           4096 M total memory
                           1619 M used memory
                           1173 M free memory
                              0 M buffer memory
                           1302 M swap cache
                            512 M total swap
                              7 M used swap
                            504 M free swap
                  *** FILESYSTEM ***
                  /var:
                  820M    /var/
                  357M    /var/log
                  315M    /var/cache
                  USB-Devices by-id:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  Impact:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.7.19
                  javascript:     9.0.11
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        6561
                  States:         5642
                  Und wenn das alles up-to-date ist updatest du den Adapter selber auch.
                    DRINGEND updaten...
                    sudo apt update
                    iob nodejs-update
                    Y Offline
                    Y Offline
                    yablu87
                    @Thomas-Braun sagte in SMA Semp Adapter meldet Fehler:
                    Wie geht das? Oder soll ich dafür einen neuen Thread machen?
                      Y Offline
                      Y Offline
                      yablu87
                      Hab ich gemacht, das war es scheinbar schon, Danke!
                      • Y yablu87
                        Das kann dir einer der Docker-Kapitäne wohl besser erklären.
                        Hab ich gemacht,
                        Die vorherigen Updates auch?
                        • Y Offline
                          Y Offline
                          yablu87
                          schrieb am zuletzt editiert von yablu87
                          Ja, alle Updates gemacht und es sieht gut aus. Vielen Dank.
