  4. Error in GUI
    6.4k
Error in GUI
46 Beiträge 10 Kommentatoren 2.4k Aufrufe 9 Beobachtet
  • mikep500M Offline
    mikep500M Offline
    mikep500
    #41
    So, hab jetzt mal alle Updates gemacht. Schaut jetzt so aus. Keine Fragen bitte zu aktuellen Betriebssystemen. Ich kenne mich null aus und im Solaranzeigenforum wurde es so empfohlen.
    Jetzt hab ich aber das Problem, dass mein Passwort angeblich nicht stimmt. ========== Start marking the full check here ===========
    Script v.2026-01-31
    *** BASE SYSTEM ***
     Static hostname: solaranzeige
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     17:34:01 up 9 min,  4 users,  load average: 0.27, 0.32, 0.27
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest        stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2026-02-06 17:34:02 CET
               Universal time: Fri 2026-02-06 16:34:02 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         true
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi        -user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix        '
    *** MEMORY ***
    Mem:            8.2G        1.6G        4.9G        121M        1.8G        6.6G
    Swap:           209M          0B        209M
    Total:          8.4G        1.6G        5.2G
    Active iob-Instances:   4
             7820 M total memory
             1540 M used memory
             2110 M active memory
              676 M inactive memory
             4720 M free memory
               68 M buffer memory
             1600 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 17:34:02 up 9 min,  4 users,  load average: 0.27, 0.32, 0.27
    Tasks: 262 total,   1 running, 261 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7820.8 total,   4720.2 free,   1540.0 used,   1669.3 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6280.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     1.6G  3.0M  1.6G   1% /run
    /dev/mmcblk0p2 ext4       57G   11G   44G  21% /
    tmpfs          tmpfs     3.9G   16K  3.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   86M  425M  17% /boot/firmware
    tmpfs          tmpfs     783M   32K  783M   1% /run/user/1000
    [Fri Feb  6 17:24:18 2026] EXT4-fs (mmcblk0p2): mounted filesystem 7909438b-2884        -423e-aa05-577fdea75c97 ro with ordered data mode. Quota mode: none.
    [Fri Feb  6 17:24:20 2026] EXT4-fs (mmcblk0p2): re-mounted 7909438b-2884-423e-aa        05-577fdea75c97 r/w.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id        =1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=002        2,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.5G    /var/
    2.4G    /var/cache/apt
    2.4G    /var/cache
    2.3G    /var/cache/apt/archives
    549M    /var/lib
    Archived and active journals take up 275.8M in the file system.
    /opt/iobroker/backups:
    15M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    176M    /opt/iobroker/iobroker-data/
    163M    /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    13M     /opt/iobroker/iobroker-data/objects.jsonl
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.j        s
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescrip        t/tsWorker.js
    4.3M    /opt/iobroker/iobroker-data/files/jarvis/js/vendor.6018d81d.js
    3.7M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/assets/index-D        Xg_kRe6.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AQ02MT9K-if00-port0
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A10NIY56-if00-port0
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    solaranzeige        solaranzeige (version: 7.0.7, hostname: solaranzeige  , aliv        e, uptime: 552)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.11
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : solaranzeige        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
    + system.adapter.backitup.0               : backitup              : solaranzeige        -  enabled
    + system.adapter.backitup.2               : backitup              : solaranzeige        -  enabled
      system.adapter.bestway.0                : bestway               : solaranzeige        - disabled
      system.adapter.broadlink2.0             : broadlink2            : solaranzeige        - disabled
      system.adapter.discovery.0              : discovery             : solaranzeige        - disabled
      system.adapter.fritzdect.0              : fritzdect             : solaranzeige        - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : solaranzeige        - disabled
      system.adapter.hass.0                   : hass                  : solaranzeige        - disabled, port: 8123
      system.adapter.hass.1                   : hass                  : solaranzeige        - disabled, port: 8123
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : solaranzeige        - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : solaranzeige        - disabled
      system.adapter.influxdb.0               : influxdb              : solaranzeige        - disabled, port: 8086
      system.adapter.jarvis.0                 : jarvis                : solaranzeige        - disabled
      system.adapter.javascript.0             : javascript            : solaranzeige        - disabled
      system.adapter.javascript.1             : javascript            : solaranzeige        - disabled
      system.adapter.mqtt.0                   : mqtt                  : solaranzeige        - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : solaranzeige        - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.ping.0                   : ping                  : solaranzeige        - disabled
      system.adapter.vis-bars.0               : vis-bars              : solaranzeige        - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : solaranzeige        - disabled
      system.adapter.vis-metro.0              : vis-metro             : solaranzeige        - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : solaranzeige        - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : solaranzeige        - disabled
      system.adapter.vis.0                    : vis                   : solaranzeige        - disabled
      system.adapter.web.0                    : web                   : solaranzeige        - disabled, port: 8082, bind: 0.0.0.0, run as: admi        n
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                                     │        auto upgrade │
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │        false        │
    │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │        false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "bestway"      : 0.0.4    , installed 0.0.4
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "hass"         : 1.4.0    , installed 1.3.0  [Updatable]
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.0.11 [Updatable]
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        704
    States:         513
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://packages.sury.org/php bookworm InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Get:7 https://repos.influxdata.com/debian stable InRelease [6913 B]
    Hit:8 https://deb.nodesource.com/node_22.x nodistro InRelease
    Fetched 6913 B in 2s (4510 B/s)
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN        116        7812       826/mosquitto
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN        0          10383      1191/smbd
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN        0          9296       1099/lighttpd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN        114        8528       1363/influxd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          1007       839/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN        0          10382      1191/smbd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       8780       1637/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       8775       1637/iobroker.js-co
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN        0          6969       815/cupsd
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN        0          7764       763/connmand
    tcp6       0      0 :::9595                 :::*                    LISTEN        0          7162       816/java
    tcp6       0      0 :::1883                 :::*                    LISTEN        116        7813       826/mosquitto
    tcp6       0      0 :::139                  :::*                    LISTEN        0          10381      1191/smbd
    tcp6       0      0 :::80                   :::*                    LISTEN        0          9295       1099/lighttpd
    tcp6       0      0 :::445                  :::*                    LISTEN        0          10380      1191/smbd
    tcp6       0      0 :::8111                 :::*                    LISTEN        0          10398      816/java
    tcp6       0      0 :::8086                 :::*                    LISTEN        114        11436      1363/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN        1001       10019      1810/io.admin.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN        0          6968       815/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN        115        9961       1636/grafana
    tcp6       0      0 ::1:53                  :::*                    LISTEN        0          7768       763/connmand
    udp        0      0 127.0.0.1:53            0.0.0.0:*        0          7756       763/connmand
    udp        0      0 192.168.178.255:137     0.0.0.0:*        0          9398       1164/nmbd
    udp        0      0 192.168.178.71:137      0.0.0.0:*        0          9397       1164/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*        0          9382       1164/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*        0          9400       1164/nmbd
    udp        0      0 192.168.178.71:138      0.0.0.0:*        0          9399       1164/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*        0          9383       1164/nmbd
    udp        0      0 0.0.0.0:33656           0.0.0.0:*        104        5726       631/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*        104        5724       631/avahi-daemon: r
    udp        0      0 0.0.0.0:51314           0.0.0.0:*        0          10364      763/connmand
    udp6       0      0 ::1:53                  :::*        0          7760       763/connmand
    udp6       0      0 :::546                  :::*        0          9282       763/connmand
    udp6   33024      0 fe80::ec51:f680:1c3:546 :::*        0          7961       752/NetworkManager
    udp6       0      0 :::5353                 :::*        104        5725       631/avahi-daemon: r
    udp6       0      0 :::42985                :::*        104        5727       631/avahi-daemon: r
    2026-02-06 17:25:00.388  - info: host.solaranzeige Copyright (c) 2014-2024 bluef        ox, 2014 hobbyquaker
    2026-02-06 17:25:00.390  - info: host.solaranzeige hostname: solaranzeige, node:        v22.22.0
    2026-02-06 17:25:00.391  - info: host.solaranzeige ip addresses: 192.168.178.71        2003:d2:5729:4200:d6bd:33ba:dcd:8a03 fe80::ec51:f680:1c3e:53c9
    2026-02-06 17:25:01.769  - info: host.solaranzeige connected to Objects and Stat        es
    2026-02-06 17:25:01.803  - info: host.solaranzeige added notifications configura        tion of host
    2026-02-06 17:25:03.383  - info: host.solaranzeige 26 instances found
    2026-02-06 17:25:03.440  - info: host.solaranzeige starting 3 instances
    2026-02-06 17:25:04.046  - info: host.solaranzeige instance system.adapter.admin        .0 in version "7.7.22" started with pid 1810
    2026-02-06 17:25:07.870  - info: host.solaranzeige instance system.adapter.backi        tup.0 in version "3.3.13" started with pid 1818
    2026-02-06 17:25:10.691  - info: backitup.0 (1818) starting. Version 3.3.13 in /        opt/iobroker/node_modules/iobroker.backitup, node: v22.22.0, js-controller: 7.0.        7
    2026-02-06 17:25:11.330  - info: backitup.0 (1818) [iobroker] backup will be act        ivated at 02:40 every 1 day(s)
    2026-02-06 17:25:11.925  - info: host.solaranzeige instance system.adapter.backi        tup.2 in version "3.3.13" started with pid 1858
    2026-02-06 17:25:13.743  - info: admin.0 (1810) starting. Version 7.7.22 in /opt        /iobroker/node_modules/iobroker.admin, node: v22.22.0, js-controller: 7.0.7
    2026-02-06 17:25:13.830  - info: admin.0 (1810) requesting all objects
    2026-02-06 17:25:14.822  - info: admin.0 (1810) received all objects
    2026-02-06 17:25:15.223  - info: admin.0 (1810) socket.io server listening on po        rt 8081
    2026-02-06 17:25:15.227  - info: admin.0 (1810) http server listening on port 80        81
    2026-02-06 17:25:15.228  - info: admin.0 (1810) Use link "http://127.0.0.1:8081"        to configure.
    2026-02-06 17:25:16.177  - info: backitup.2 (1858) starting. Version 3.3.13 in /        opt/iobroker/node_modules/iobroker.backitup, node: v22.22.0, js-controller: 7.0.        7
    2026-02-06 17:25:16.263  - info: backitup.2 (1858) [iobroker] backup will be act        ivated at 02:40 every 1 day(s)
    2026-02-06 17:31:12.427  - warn: admin.0 (1810) Invalid password for admin. Wron        g attempts: 1
    2026-02-06 17:31:27.047  - warn: admin.0 (1810) Invalid password for admin. Wron        g attempts: 2
    2026-02-06 17:31:37.379  - warn: admin.0 (1810) Invalid password for Admin. Wron        g attempts: 1
    2026-02-06 17:32:03.873  - warn: admin.0 (1810) Invalid password for admin. Wron        g attempts: 3
    2026-02-06 17:32:34.171  - warn: admin.0 (1810) Invalid password for admin. Wron        g attempts: 4
    iob diag has finished.
    • mikep500M mikep500
      Script v.2026-01-31
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               7820 M total memory
               1540 M used memory
               4720 M free memory
                 68 M buffer memory
               1600 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      3.5G    /var/
      2.4G    /var/cache/apt
      2.4G    /var/cache
      549M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.22
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:        704
      States:         513
      #42
      @mikep500
      Und hier bekommst du die Empfehlung aktuelles Zeug zu verwenden. Der Support für Bookworm wird im Sommer seitens Debian stark zurück gefahren. Ende of Life ist für Juni geplant.
      • mikep500M Offline
        mikep500M Offline
        mikep500
        #43
        Als Profi wüsste ich das. Ich möchte nur das Monitoring für meine PV Anlage und über IOBroker die Visualisierung meiner Solarthermie.
        Das würde evt mein C64 noch hin bekommen. Aber den hab ich nicht mehr.
          #44
          @mikep500
          Dann würde ich auch auf 'Profis' hören, wenn ich selber keiner bin.
          • mikep500M Offline
            mikep500M Offline
            mikep500
            #45
            ich hab doch keine Ahnung ob der Solaranzeigenkram auf dem neuen System läuft
              #46
              @mikep500 Warum soll der nicht laufen?
              Und wenn er nicht liefe, dann wäre spätestens das der Grund die Finger von der Sache zu lassen, offenbar wäre das Zeug dann nicht besonders vertraunenserweckend.
