  4. InfluxDB neu - Backitup Fehler
    6.5k
3 Beiträge 2 Kommentatoren 265 Aufrufe 2 Beobachtet
    Beowolf
    ich musste meine influxDB neu installieren.
    Jetzt bekomme ich im log von ioBroker diese Meldungen wenn backitup eine Sicherung machen soll.
    backitup.0
    	2025-10-22 11:39:20.738	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    backitup.0
    	2025-10-22 11:38:40.872	error	[iobroker] Error: Command failed: influxd backup -portable -database home -host 192.168.49.43:8088 "/opt/iobroker/backups/influxDB_2025_10_22-11_34_45_backupiobroker" 2025/10/22 11:34:45 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (0)... 2025/10/22 11:34:47 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (1)... 2025/10/22 11:34:49 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (2)... 2025/10/22 11:34:51 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (3)... 2025/10/22 11:34:53 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (4)... 2025/10/22 11:34:55 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (5)... 2025/10/22 11:34:57 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 3.01s and retrying (6)... 2025/10/22 11:35:00 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 11.441s and retrying (7)... 2025/10/22 11:35:12 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 43.477s and retrying (8)... 2025/10/22 11:35:55 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2m45.216s and retrying (9)... backup: dial tcp 192.168.49.43:8088: connect: connection refused
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] backup: dial tcp 192.168.49.43:8088: connect: connection refused
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] 2025/10/22 11:35:55 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2m45.216s and retrying (9)...
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] 2025/10/22 11:35:12 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 43.477s and retrying (8)...
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] 2025/10/22 11:35:00 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 11.441s and retrying (7)...
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] 2025/10/22 11:34:57 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 3.01s and retrying (6)...
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] 2025/10/22 11:34:55 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (5)...
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] 2025/10/22 11:34:53 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (4)...
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] 2025/10/22 11:34:51 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (3)...
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] 2025/10/22 11:34:49 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (2)...
    backitup.0
    	2025-10-22 11:38:40.871	error	[iobroker/influxDB] 2025/10/22 11:34:47 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (1)...
    backitup.0
    	2025-10-22 11:38:40.870	error	[iobroker/influxDB] 2025/10/22 11:34:45 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused. Waiting 2s and retrying (0)...
    backitup.0
    	2025-10-22 11:38:40.870	error	[iobroker/influxDB] Error: Command failed: influxd backup -portable -database home -host 192.168.49.43:8088 "/opt/iobroker/backups/influxDB_2025_10_22-11_34_45_backupiobroker"
    Im Influx-Adapter aknn ich die Verbindung testen - alles ok. Daten werden auch in die Datenbank geschrieben.
    Ich weiß nicht wo ich suchen soll.
    Die Natur braucht nicht unseren Schutz, sie braucht unsere Abwesenheit.
    • B Beowolf
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      @beowolf sagte in InfluxDB neu - Backitup Fehler:
      Aus der Doku:
      https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#influxdb-backup
      Wenn die InfluxDB von einem entfernten Server gesichert werden soll, müssen in der influxdb.conf auf dem entfernten Server die Remote-Rechte für den RPC-Dienst angepasst werden.
      bind-address = "<InfluxDB-IP>:8088"
      oder
      bind-address = "0.0.0.0:8088"
      B 1 Antwort Letzte Antwort
      • Marc BergM Marc Berg
        Aus der Doku:
        oder
        Beowolf
        schrieb am zuletzt editiert von Beowolf
        @marc-berg
        Danke. Wie immer, kaum macht man es richtig, funktioniert es. 🤠
